  4. Test Adapter EnOcean v0.3.x
    6.4k
enocean
265 Beiträge 31 Kommentatoren 88.9k Aufrufe 12 Beobachtet
  • Jey CeeJ Jey Cee
    @AlCalzone:
    Der Multisensor crasht den Adapter. Fix => https://github.com/Jey-Cee/ioBroker.enocean/pull/7 `
    Den Fix hab ich übernommen. Läuft der Multisensor und liefert er auch alle Daten an ioBroker?
    Edit: Was kostet der Sensor?
    Grantlhaua
    #247
    @Jey-Cee said in Test Adapter EnOcean v0.3.x:
    @AlCalzone:
    Hallo @Jey-Cee
    Hier schreibst du er is implementiert. Das würde mir sehr helfen wenn das geht :)
    • JackDanielJ Offline
      JackDanielJ Offline
      JackDaniel
      #248
      der adapter funktioniert nicht mehr unter Node.js: v12.16.3 😢
      $ ./iobroker url "https://github.com/Jey-Cee/ioBroker.enocean"
      install https://github.com/Jey-Cee/ioBroker.enocean/tarball/66e50e5d1b55213d303b710c25dd12c5a5487458
      NPM version: 6.14.4
      npm install https://github.com/Jey-Cee/ioBroker.enocean/tarball/66e50e5d1b55213d303b710c25dd12c5a5487458 --loglevel error --prefix "/opt/iobroker" (System call)
      node-aead-crypto not needed on this system, since all ciphers are natively supported
      In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’   v8::String::Utf8Value path(info[0]->ToString());                                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));        ^
      In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));        ^
      In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^
      In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1742:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^
      ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void   void init(v8::Handle<v8::Object> target) {                 ^~~~~~../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token   void init(v8::Handle<v8::Object> target) {                                  ^../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope   void init(v8::Handle<v8::Object> target) {                                    ^~~~~~
      ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’   void init(v8::Handle<v8::Object> target) {                                    ^~~~~~                                    tzset
      In file included from ../../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope NODE_MODULE(serialport, init);                         ^~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
      ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’ NODE_MODULE(serialport, init);                         ^~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
      make: *** [serialport.target.mk:112: Release/obj.target/serialport/src/serialport.o] Fehler 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.enocean/node_modules/serialport
      gyp ERR! node -v v12.16.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the serialport@6.2.2 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-07T06_47_11_803Z-debug.log
      ERROR: host.raspberrypi Cannot install https://github.com/Jey-Cee/ioBroker.enocean/tarball/66e50e5d1b55213d303b710c25dd12c5a5487458: 1
      Carpe diem
        Mareleon
        #249
        hatte das gleiche Problem nach Node.js update auf 12.17.0, konnte es aber lösen durch Installation von serialport über npm.
        Dazu habe ich erstmal den Enocean Adapter deinstalliert und dann über
        npm install serialport
        einmal eine Neuinstallation des serialports forciert.
        Danach einfach wieder Adapter installieren und dann ging alles wie gewohnt
        JackDanielJ 1 Antwort Letzte Antwort
        • AxelF1977A Offline
          AxelF1977A Offline
          AxelF1977
          schrieb am zuletzt editiert von AxelF1977
          #250
          Moin,
          der Adapter will mal wieder nicht. Ich habe heute mein System neu aufgebaut. Basis ist Proxmox. ioBroker läuft in einer VM mit Debian 10.14.
          Rechner ist gleich geblieben. Auch vorher war es ein Debian 10.14.
          Ich habe das Backup eingespielt und alles läuft, bis auf den Enocean Adapter. Bzw. finde ich keine Schnittstellen. Ich kann den USB Anschuß nicht wählen.
          Ich habe schon ausgeführt
          Denn das Log sagt er kann sich nicht mit ihm verbinden
          enocean.0	2020-06-01 01:41:21.328	warn	(15246) Unable to connect to serial port. + {}
          enocean.0	2020-06-01 01:41:21.295	info	(15246) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.enocean, node: v12.17.0, js-controller: 3.1.4
          Den Adapter habe ich mehrmals deinstalliert und neu installiert.
          Node und Node.js 12.17.0
          npm 6.14.4
          Jemand eine Idee was ich noch machen kann? Ich hatte das letztes Jahr schonmal, da reichte es den Adapter neu zu installieren, diesmal leider nicht.
          ASROCK Deskmini Intel I3 8100 16GB mit Proxmox VM ioBroker VM DIYHue| CCU piVCCU + FHEM auf Raspberry | Maria DB mit Grafana und Prometheus auf Tinker Board
          AxelF1977A 1 Antwort Letzte Antwort
          • AxelF1977A AxelF1977
            Moin,
            npm 6.14.4
            AxelF1977A Offline
            AxelF1977A Offline
            AxelF1977
            #251
            @AxelF1977 sagte in Test Adapter EnOcean v0.3.x:
            Moin,
            npm 6.14.4
            Hat sicher erledigt. ich lasse es aber mal drin, falls noch einer mal das Problem hat.
            Was ich nicht wusste, ist das ich unter Proxmox die USB Sticks an die VM´s durchreichen muss. Nachdem ich das erledigt hatte
            https://pve.proxmox.com/wiki/USB_Devices_in_Virtual_Machines#Assigning_Devices_to_VMs
            läuft nun wieder alles wie gewohnt und gewünscht.
            Ich sage trotzdem Danke
            • M Mareleon
              JackDanielJ Offline
              JackDanielJ Offline
              JackDaniel
              #252
              @Mareleon
              thx, ging bei mir genau so 👍
              Carpe diem
              • G Grantlhaua
                Guten Morgen,
                den
                Eltako 4824664 Multisensor MS IP44 EnOcean mit Eltako 2719447 Funk-Sendemodul für Wetterdaten, FWS 61-24 V DC
                Viele Grüße
                Grantlhaua
                schrieb am zuletzt editiert von Grantlhaua
                #253
                @Jey-Cee
                Guten Morgen,
                ist der Multisensor von weiter oben eigentlich implimentiert oder nicht? Würde immer noch gerne ein Paar Raff-Stores mit Shellys ausrüsten, brauche aber die Wetterdaten für den Windwächter...
                Danke!
                • G Grantlhaua
                  @Jey-Cee
                  Guten Morgen,
                  Danke!
                  Jey CeeJ Offline
                  Jey CeeJ Offline
                  Jey Cee
                  #254
                  @Grantlhaua hast du es den getestet? Ich hab den sensor nicht und die implementierung kommt von Alcazon. Der code von ihm ist im Adapter.
                  Mehr kann ich dazu nicht sagen.
                  Persönlicher Support
                  Spenden -> paypal.me/J3YC33
                  G 2 Antworten Letzte Antwort
                  • Jey CeeJ Jey Cee
                    Grantlhaua
                    #255
                    @Jey-Cee
                    Sobald ich ein paar Minuten Zeit hab spiel ich mich mal damit :) Danke trotzdem!
                    G 1 Antwort Letzte Antwort
                    • Jey CeeJ Jey Cee
                      Grantlhaua
                      #256
                      Ich habe eben versucht den Enocean Adapter zu installieren, leider ist die Instanz immer auf gelb und ich kann keine Schnittstelle (Meinen eingesteckten USB300 Stick) auswählen. Weißt du vielleicht wo das Problem liegen könnte?
                      Der Multisensor müsste gehen. Hab hier im Tread einen Post gefunden, der sagt er funktioniert 1A.
                      Viele Grüße
                      • G Grantlhaua
                        Viele Grüße
                        Grantlhaua
                        #257
                        So, mitlerweile hab ich herrausgefunden dass ich den USB Port bei Proxmox durchschleifen muss. lieder bin ich da anscheinend zu doof dafür :(
                        P 1 Antwort Letzte Antwort
                        • G Grantlhaua
                          pgBroker
                          schrieb am zuletzt editiert von pgBroker
                          #258
                          ... falscher Reply 😶
                          • P Offline
                            pgBroker
                            #259
                            Nachdem die Einbindung von ein paar Hoppe Fenstergriffen per USB300 Stick auf Anhieb geklappt hatte, war ich mutig und habe mir 2 Eltako FAH60B Helligkeitssensoren für den Außenbereich bestellt, mit denen ich meine Rollläden helligkeitsabhängig steuern möchte. Leider werden die aber nicht korrekt eingebunden. Mit automatischer Erkennung erhalte ich im LOG:
                            info (1732) Teachin: true
                            info (1732) EEP A5-06-01 detected for device with ID 0587xxxx, manufacturer: ELTAKO
                            warn (1732) The EEP/description (A5-06-01/native) has not been found and is therefore not supported.
                            Liegt anscheinend daran, dass die EEP A5-06-01 nicht im Adapter definiert wurde.
                            Eingebunden wird er, aber ich sehe keine Datenpunkte für die Helligkeit:
                            Gibt es ne Chance, die Einzubauen? Bin gerne bereit Infos zu liefern und zu Testen, habe aber leider keine Ahnung vom Adapter-Bau.
                            Die Eltako FAH60 sind IMO die einzigen wetterfesten Helligkeitssensoren für den Außenbereich, die kein Stromkabel benötigen. Sind deshalb vielleicht auch für andere von Interesse für eine helligkeitsabhängige Rollladensteuerung.
                            • G Grantlhaua
                              @Jey-Cee
                              Grantlhaua
                              #260
                              @Jey-Cee
                              habs jetzt probiert und leider ist die EEP nicht drin.
                              Wär die EEP A5-13-01 UND 02, könnte man die noch hinzufügen oder läuft alles auf deinen neuen Adapter hinaus?
                              Vielen Dank!
                              • P pgBroker
                                pgBroker
                                #261
                                @pgBroker Habe einen Workaround gefunden:
                                Lese den Helligkeitswert über Node Red aus uns schreibe ihn in einen selbst erzeugten Datenpunkt in ioBroker.
                                -cs-- 1 Antwort Letzte Antwort
                                • P pgBroker
                                  -cs-- Offline
                                  -cs-- Offline
                                  -cs-
                                  schrieb am zuletzt editiert von -cs-
                                  #262
                                  aus mehreren Gründen welche ich nicht genauer erläutern möchte, habe ich mich von EnOcen verabschiedet, und möchte mein "Starterset" welches nur 1x zum Testen hergenommen wurde verkaufen.
                                  Einfach Ebay- Kleinanzeigen Anzeigennr.: 1536606778, dann müsstet Ihr es finden.
                                  (oder ist der Link hier erlaubt? ist dieser Beitrag erwünscht? Ich meine ja, da hier ja diejenigen sind, welche großes Interesse haben könnten falls nicht bitte bescheid geben)
                                  Wenn jemand Interesse hat, gehe ich für Forumsmitglieder nochmal 10.- € runter. Einfach PN schreiben.
                                  @Jey-Cee meinen Beitrag zur Entwicklung habe ich dennoch gerne gezahlt/gegeben und wünsche noch viel Erfolg.
                                  Chris
                                    batteliere
                                    #263
                                    ich versuche gerade vergeblich den Eltako FWS61 (Datenmodul für Multisensor MS) anzulernen.
                                    Der FWS61 wird im dem "Gerät hinzufügen" Dialog angeboten. Aber wenn ich den versuche zu koppeln, passiert einfach nichts. Im Log ist ebenfalls nichts zu sehen.
                                    Hat das schonmal jemand hinbekommen? Was kann ich noch versuchen?
                                    Danke! Gruß Thomas
                                    • B batteliere
                                      Danke! Gruß Thomas
                                      mustang
                                      #264
                                      @batteliere
                                      hallo - du bist im falschen Thread unterwegs. Schau doch mal bitte hier: [https://forum.iobroker.net/topic/37331/test-adapter-enocean-2-v0-3-x/396#](Link Adresse)
                                      • M mustang
                                        @batteliere
                                        batteliere
                                        #265
                                        @mustang Danke
