  4. Test Adapter rtspStream v0.0.x GitHub
    6.5k
rtsp stream
157 Beiträge 36 Kommentatoren 36.1k Aufrufe 53 Beobachtet
  • L Offline
    Lumumba
    #85
    Schade, zu lang kein Backup gemacht ich Trottel :-)
    Naja, macht keine Systemlast, aber Fehlermeldungen...
    • BluelinuxB Offline
      BluelinuxB Offline
      Bluelinux
      #86
      Hat jemand noch eine Idee wie ich diesen Adapter deinstalliert bekomme????
      • BluelinuxB Bluelinux
        #87
        @Bluelinux
        iobroker del adaptername
        BluelinuxB 1 Antwort Letzte Antwort
          @Bluelinux
          BluelinuxB Offline
          BluelinuxB Offline
          Bluelinux
          #88
          @Thomas-Braun das klappt leider nicht.... bekomme das kack ding nicht vom iobroker
            #89
            @Bluelinux Mit welchen Meldungen aus der Konsole?
              BluelinuxB Offline
              BluelinuxB Offline
              Bluelinux
              #90
              @Thomas-Braun
              iobroker@ioBroker-Debian:~$ iobroker del rtspStream
              Commands:
              iobroker setup [--objects <host>] [--states <host>] [custom]
              iobroker start - starts the js-controller
              iobroker stop - stops the js-controller
              iobroker start <adapter>[.instance] - starts a specified adapter instance
              iobroker stop <adapter>.[instance] - stops a specified adapter instance
              iobroker start all - starts js-controller and all adapters
              iobroker restart - restarts the js-controller
              iobroker restart <adapter>[.instance] - restarts a specified adapter
              iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
                 --wait stops the execution until the debugger is attached.
                 --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
              iobroker info - shows the host info
              iobroker logs [adapter] [--watch] [--lines=1000]
              iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
              iobroker install <adapter> - installs a specified adapter
              iobroker rebuild <adapter>|self [--install]
              iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
              iobroker del <adapter> - remove adapter from system
              iobroker del <adapter>.<instance> - remove adapter instance
              iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
              iobroker upgrade [repository url]
              iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
              iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
              iobroker upload <pathToLocalFile> <pathIniobroker>
              iobroker upload all - upload all adapter files to make them available for instances
              iobroker upload <adapter> - upload specified adapter files to make them available for instances
              iobroker object get <id> - get object specified by id
              iobroker object set <id> <json-value> - set object with the given id by providing a new json object
              iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
              iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
              iobroker object del <id|pattern> [--yes]
              iobroker object chmod <object-mode> [state-mode] <id>
              iobroker object chown <user> <group> <id>
              iobroker object list <id>
              iobroker state get <id> - get state, specified by id
              iobroker state getplain <id> [--pretty]
              iobroker state getvalue <id>
              iobroker state set <id> <value> [ack]
              iobroker state del <id>
              iobroker message <adapter>[.instance] <command> [<message>]
              iobroker list <type> [filter]
              iobroker chmod <mode> <file>
              iobroker chown <user> <group> <file>
              iobroker touch <file>
              iobroker rm <file>
              iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
              iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
              iobroker file rm <iobroker-path-to-delete>
              iobroker file sync
              iobroker user add <user> [--ingroup group] [--password pass]
              iobroker user del <user>
              iobroker user passwd <user> [--password pass]
              iobroker user enable <user>
              iobroker user disable <user>
              iobroker user get <user>
              iobroker user check <user> [--password pass]
              iobroker group add <group>
              iobroker group del <group>
              iobroker group list <group>
              iobroker group enable <group>
              iobroker group disable <group>
              iobroker group get <group>
              iobroker group adduser <group> <user>
              iobroker group deluser <group> <user>
              iobroker host this
              iobroker host <hostname>
              iobroker host set <hostname>
              iobroker host remove <hostname>
              iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
              iobroker license <license.file or license.text>
              iobroker cert create
              iobroker cert view [<certificate name>]
              iobroker clean
              iobroker backup
              iobroker restore <backup name or path> - restore a specified backup
              iobroker validate <backup name or path> - validate a specified backup
              iobroker <command> --timeout 5000
              iobroker status [all|<adapter>.<instance>]
              iobroker repo [name]
              iobroker repo add <name> <path or url>
              iobroker repo set <name>
              iobroker repo del <name>
              iobroker uuid
              iobroker unsetup
              iobroker fix - execute the installation fixer script, this updates your ioBroker installation
              iobroker multihost <enable|disable> [--secure true|false]
              iobroker multihost browse
              iobroker multihost connect
              iobroker compact status - show if compact mode is enabled in general
              iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
              iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
              iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
              iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
              iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
              iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
              iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
              iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
              iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
              iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
              iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
              iobroker version [adapter] - show version of js-controller or specified adapter
              iobroker [adapter] -v - show version of js-controller or specified adapter
              Options:
               --help     Hilfe anzeigen  [boolean]
               --version  Version anzeigen  [boolean]
              das hier kommt dann
                @Thomas-Braun
                Commands:
                iobroker rm <file>
                iobroker file sync
                iobroker host this
                iobroker clean
                iobroker backup
                iobroker uuid
                iobroker unsetup
                Options:
                das hier kommt dann
                #91
                @Bluelinux
                iobroker list adapters
                  @Bluelinux
                  BluelinuxB Offline
                  BluelinuxB Offline
                  Bluelinux
                  #92
                  @Thomas-Braun
                  iobroker@ioBroker-Debian:~$ iobroker list adapters
                  system.adapter.admin                   : admin          - v4.1.6
                  system.adapter.alexa2                  : alexa2         - v3.3.1
                  system.adapter.backitup                : backitup       - v1.6.0
                  system.adapter.cloud                   : cloud          - v3.0.4
                  system.adapter.daswetter               : daswetter      - v3.0.1
                  system.adapter.discovery               : discovery      - v2.3.11
                  system.adapter.dwd                     : dwd            - v2.4.10
                  system.adapter.firetv                  : firetv         - v1.0.0
                  system.adapter.flot                    : flot           - v1.10.2
                  system.adapter.fritzbox                : fritzbox       - v0.3.1
                  system.adapter.fritzdect               : fritzdect      - v0.3.2
                  system.adapter.fullybrowser            : fullybrowser   - v1.0.4
                  system.adapter.history                 : history        - v1.9.10
                  system.adapter.ical                    : ical           - v1.7.1
                  system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                  system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
                  system.adapter.influxdb                : influxdb       - v1.9.2
                  system.adapter.info                    : info           - v1.7.7
                  system.adapter.iot                     : iot            - v1.7.0
                  system.adapter.javascript              : javascript     - v4.6.22
                  system.adapter.kodi                    : kodi           - v2.0.4
                  system.adapter.mclighting              : mclighting     - v0.1.1
                  system.adapter.mihome-vacuum           : mihome-vacuum  - v2.1.1
                  system.adapter.moma                    : moma           - v1.2.6
                  system.adapter.mqtt                    : mqtt           - v2.1.7
                  system.adapter.nina                    : nina           - v0.0.23
                  system.adapter.nuc                     : nuc            - v0.1.3
                  system.adapter.parser                  : parser         - v1.0.7
                  system.adapter.ping                    : ping           - v1.4.8
                  system.adapter.proxy                   : proxy          - v1.2.1
                  system.adapter.pushover                : pushover       - v2.0.2
                  system.adapter.radar2                  : radar2         - v2.0.1
                  system.adapter.rpi2                    : rpi2           - v1.2.0
                  system.adapter.rtspStream              : rtspStream     - v0.0.2
                  system.adapter.samsung                 : samsung        - v0.2.9
                  system.adapter.simple-api              : simple-api     - v2.4.6
                  system.adapter.socketio                : socketio       - v3.0.12
                  system.adapter.sonoff                  : sonoff         - v2.3.3
                  system.adapter.sql                     : sql            - v1.15.2
                  system.adapter.synology                : synology       - v0.1.18
                  system.adapter.systeminfo              : systeminfo     - v0.3.1
                  system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
                  system.adapter.telegram                : telegram       - v1.5.9
                  system.adapter.text2command            : text2command   - v2.0.3
                  system.adapter.tr-064                  : tr-064         - v4.0.12
                  system.adapter.upnp                    : upnp           - v1.0.16
                  system.adapter.vis                     : vis            - v1.2.6
                  system.adapter.vis-bars                : vis-bars       - v0.1.4
                  system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                  system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.0
                  system.adapter.vis-history             : vis-history    - v1.0.0
                  system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.5
                  system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                  system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                  system.adapter.vis-material            : vis-material   - v0.1.3
                  system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
                  system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.19
                  system.adapter.vis-metro               : vis-metro      - v1.1.2
                  system.adapter.vis-players             : vis-players    - v0.1.6
                  system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
                  system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                  system.adapter.web                     : web            - v3.0.10
                  system.adapter.web-speedy              : web-speedy     - v0.2.0
                  system.adapter.wifilight               : wifilight      - v1.1.0
                  system.adapter.wled                    : wled           - v0.5.0
                  system.adapter.yahka                   : yahka          - v0.11.0
                  system.adapter.yr                      : yr             - v2.0.3
                  system.adapter.zigbee                  : zigbee         - v1.2.0
                    @Thomas-Braun
                    #93
                    @Bluelinux Keine Ahnung. Hat evtl. mit dem Großbuchstaben im Adapternamen zutun. Das wird vielleicht falsch interpretiert. Jedenfalls reagiert die Konsole, als sei der Befehl nicht komplett. Allerdings funktioniert eine Deinstallation über npm auch nicht.
                    BluelinuxB Thomas BraunT 2 Antworten Letzte Antwort
                      BluelinuxB Offline
                      BluelinuxB Offline
                      Bluelinux
                      #94
                      @Thomas-Braun hmmm na das ist ja echt merkwürdig oder??? nervt mich total das ich da so einen toten adapter habe .... schade aber danke für deine hilfe
                        bob der 1.
                        #95
                        @Bluelinux
                        Der Entwickler sollte das lösen odet man sollte von der Adminseite den 1 Post editieren das er sich nicht deinstallieren lässt.
                        Bekekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst
                        • B bob der 1.
                          @Bluelinux
                          bob der 1.
                          #96
                          @bob-der-1 sagte in Test Adapter rtspStream v0.0.x GitHub:
                          @Bluelinux
                          Der Entwickler sollte das lösen oder man sollte von der Adminseite den 1.Post editieren das er sich nicht deinstallieren lässt.
                          Bekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst.
                            #97
                            @Bluelinux Gibt ein issue dazu im git.
                              BluelinuxB Offline
                              BluelinuxB Offline
                              Bluelinux
                              #98
                              @Thomas-Braun ja aber da gibt es ja auch leider keine antwort so wie ich das sehe.... wirklich schade.....
                                #99
                                @Bluelinux Zumindest ist es geloggt.
                                  #100
                                  @Thomas-Braun sagte in Test Adapter rtspStream v0.0.x GitHub:
                                  @apollon77 Hast du da vielleicht noxh einen magischen npm-Befehl in petto? Mit den mir bekannten Dingen bekomme ich den Adapter nicht deinstalliert.
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #101
                                    @Thomas-Braun ich bin zwar nicht @apollon77, aber hab da noch ne idee:
                                    1. Instanz löschen
                                    2. per SSH auf den host verbinden
                                    3. in den Ordner node_modules im ioBroker Verzeichnis gehen
                                    4. sudo rm -R iobroker.rtspStream
                                    5. ioBroker neustarten
                                    Das sollte den Adapter Vollständig entfernen.
                                    Persönlicher Support
                                    Spenden -> paypal.me/J3YC33
                                    Thomas BraunT BluelinuxB 2 Antworten Letzte Antwort
                                    • Jey CeeJ Jey Cee
                                      1. Instanz löschen
                                      #102
                                      @Jey-Cee sagte in Test Adapter rtspStream v0.0.x GitHub:
                                      1. Instanz löschen
                                      Thanks! Das hat den Kram rausgekickt. Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändert werden müsste.
                                        1. Instanz löschen
                                        Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #103
                                        Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändeet werden müsste.
                                        Nur wenn man die Instanz vorher nicht löscht.
                                        • Jey CeeJ Jey Cee
                                          bob der 1.
                                          #104
                                          @Jey-Cee
                                          Die Instanz lässt sich bei mir nicht mal löschen!
