  4. Node-Red 2.0.0 - keine Systemobjekte u. andere Probleme
    1.0k
node-red
15 Beiträge 3 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • mickymM Offline
    mickymM Offline
    mickym
    So ich habe nun auf 2.0 aktualisiert:
    node-red.0	2020-07-02 10:44:27.567	warn	(16553) (node:16576) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 stateChange listeners added to [Adapter]. Use emitter.setMaxListeners() to increase limit
    node-red.0	2020-07-02 10:44:27.393	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.337	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.308	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.304	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.299	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.294	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.285	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.225	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.208	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.184	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.174	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.162	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.158	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.153	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.149	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:27.143	info	(16576) Automatic objects creation is not enabled. You can enable it in the node configuration
    node-red.0	2020-07-02 10:44:24.953	warn	(16576) slow connection to states DB. Still waiting ...
    node-red.0	2020-07-02 10:44:16.103	info	(16553) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0	2020-07-02 10:44:15.337	info	(16553) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.18.2, js-controller: 3.1.6
    • Ich bekomme auch keine Werte aus den Systemadaptern. :(
    • Die Warnmeldungen, die angeblich mit Version 16.x sind immer noch da (s. https://forum.iobroker.net/topic/30355/node-red-adapter)
    • Was es mit der Automatic Creation of Objects nun auf sich hat - erklärt sich mir ebenfalls nicht - s. Log
    • Das man den Zugriff auf die Palettenverwaltung in settings.js nun manuell aktivieren muss - erschließt sich mir nicht - da ich ja einige zusätzliche Module installiert habe.
    • mickymM Offline
      mickymM Offline
      mickym
      Warum die Systemobjekte wohl nicht gefunden wurden - liegt wohl daran, dass vor dem Pfad ein Präfix node-red/0/ geschrieben wird:
      node-red/0/system/adapter/admin/0/alive anstelle von system.adapter.admin.0.alive
      • mickymM mickym
        mickymM Offline
        mickymM Offline
        mickym
        Ich habe nun auf allen iobroker-out nodes die autoCreate mittels "Ignore messages for non existing states" auf "false" (String) gestellt und bekomme diese Meldungen immer noch. (s. auch: https://forum.iobroker.net/topic/30355/node-red-adapter/8)
        Auch wenn man das Debug Level auf silly einstellt - dann bekommt man keine Infos welche Nodes diese Meldung erzeugen:
        node-red.0	2020-07-03 13:19:55.627	silly	(12975) States user redis pmessage 0_userdata.0.homekit.devices.MAX_016da9.TargetTemperature/0_userdata.0.homekit.devices.MAX_016da9.TargetTemperature:{"val":"12.0","ack":false,"ts":1593775195399,"q":
        node-red.0	2020-07-03 13:19:55.626	silly	(12975) States user redis pmessage 0_userdata.0.homekit.devices.MAX_016da2.TargetTemperature/0_userdata.0.homekit.devices.MAX_016da2.TargetTemperature:{"val":"12.0","ack":true,"ts":1593775195399,"q":0
        node-red.0	2020-07-03 13:19:55.625	silly	(12975) States user redis pmessage zigbee.0.group_2.state/zigbee.0.group_2.state:{"val":false,"ack":false,"ts":1593775195398,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":15
        node-red.0	2020-07-03 13:19:55.624	silly	(12975) States user redis pmessage zigbee.0.group_1.state/zigbee.0.group_1.state:{"val":false,"ack":false,"ts":1593775195397,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":15
        node-red.0	2020-07-03 13:19:55.503	debug	(12956) 3 Jul 13:19:55 - [info] [exec:FHEM crfToken ermitteln] curl -s -D - 'http://localhost:8083/fhem?XHR=1' | awk '/X-FHEM-csrfToken/{print $2}'
        node-red.0	2020-07-03 13:19:55.128	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:55.114	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:55.096	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:55.062	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:55.048	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.996	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.950	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.937	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.924	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.910	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.833	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.764	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.689	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.641	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.626	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:54.592	info	(12975) Automatic objects creation is not enabled. You can enable it in the node configuration
        node-red.0	2020-07-03 13:19:52.688	debug	(12956) 3 Jul 13:19:52 - [info] [exec:iobroker start tr-064.0] iobroker start tr-064.0
        node-red.0	2020-07-03 13:19:52.101	silly	(12975) States user redis pmessage ping.0.MWHome.192_168_178_1/ping.0.MWHome.192_168_178_1:{"val":true,"ack":true,"ts":1593775191955,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc
        node-red.0	2020-07-03 13:19:51.630	debug	(12956) 3 Jul 13:19:51 - [info] [exec:FHEM crfToken ermitteln] curl -s -D - 'http://localhost:8083/fhem?XHR=1' | awk '/X-FHEM-csrfToken/{print $2}'
        Weiterhin habe ich festgestellt, dass die neuen Versionen wesentlich träger im Browser reagieren und die Performance im Editor schlechter geworden ist. Mag an neuen Funktionen liegen - aber erwähnen wollte ich es mal.
        • mickymM Offline
          mickymM Offline
          mickym
          Ich habe im Gegensatz zu früher nun auch das Problem, dass ich die Browserfenster nach längerer Inaktivität seit dieser Version immer neu aktualisieren muss - bzw. NodeRED neu geladen werden muss.
          Das war früher nicht der Fall - kann man das Verhalten wieder wie bei der Version 1.13.x ändern, sodass die Verbindung permanent bleibt?
          • F Offline
            firehero
            Ich habe das Problem, dass im Node-Red die Values von Objekten im IoBroker nicht mehr verwendet werden.
            Eine im IoBroker angelegte Variabel beschreibe ich mit den Werten 1 und 2.
            Diese Werte möchte ich in Node-Red auswerten und etwas steuern. Das ging letzte Woche noch.
            Wenn ich die Werte mit ioBroker in direkt mit msg.payload verbinde, den Wert in den Objekten ändere zeigt es mir bei Debug nichts an.
            Hat jemand ähnliches Problem?
            VG Axel
            • mickymM Offline
              mickymM Offline
              mickym
              Schade - dass hier keine Rückmeldungen kommen. Ich werde nun wieder zurück auf Version 1.13.x gehen - da bei dem Update anscheinend mehrere Dinge nicht mehr funktionieren, die man aber erst nach und nach raus bekommt, da die Flows - wenn man sie nicht antastet erst mal gehen.
              Wichtig ist, dass anscheinend die Einstellungen der Projektverwaltung beim Upgrade nicht übernommen wurden.
              Jedenfalls kann ich nun keine Status mehr festschreiben:
              Desweiteren bin ich nicht mehr in der Lage meine light-scheduler Nodes zu bearbeiten. Ich werde das gleich nochmal checken, wenn ich wieder auf die vorher stabile Version zurückgehe:
              Ich hoffe - ich bekomme das System wieder stabil, wie es vorher war .
              • mickymM Offline
                mickymM Offline
                mickym
                So ich habe jetzt das ganze System wieder auf den Stand vor den Adapter updates vor dem 1.7.2020 wiederhergestellt.
                Jetzt funktionieren die Nodes wieder und auch die Projektverwaltung.
                Es scheint, dass mit dem Adapter Update auch die NodeRed Version aktualisiert wurde. Nur weiß ich nicht, ob die Fehler auf den Adapter oder die NodeRed Versions Updates zurückzuführen sind.
                So schaut der LightScheduler normal aus:
                Die Version des Adapters, die vorher drauf war und bei der alles noch funktioniert hat war 1.13.0 und NodeRED Version 1.0.2
                • mickymM Offline
                  mickymM Offline
                  mickym
                  Ich habe mal im NodeRED Unterforum einen eigenen Thread erstellt, weil hier evtl. zuwenig Resonanz und vielleicht zu unspezifisch ist.
                  Nach dem Downgrade und anschließenden Upgrade auf 1.17.2 funktionierte die Projektfunktion zwar noch - aber durch das Update der NodeRED version von 1.0.2 auf 1.1.2 gehen wohl die Light Scheduler Nodes nicht mehr. (Nachtrag: Gibt es aber auf GitHub schon eine Meldung - hat nichts mit dem Adapter zu tun. https://github.com/niklaswall/node-red-contrib-light-scheduler/issues/52 )
                  Ich gehe mal davon aus, dass das jedoch ein Problem innerhalb von NodeRED mit der neuen Oberfläche und nicht des Adapters ist.
                  Hier deshalb auch noch ein Link zum NodeRED an sich: Probleme nach NodeRED Update auf Version 1.1
                  • mickymM mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    Kann es sein, dass die GIT Konfiguration bei der Adapterversion 2.0.0 nicht mehr ausgelesen wird und deshalb die Projektfunktion nicht mehr funktioniert?
                    siehe
                    • mickymM mickym
                      Systemdata Bitte Ausfüllen
                      Hardwaresystem: Pi4
                      Arbeitsspeicher: 4GB
                      Festplattenart: SD-Karte
                      Betriebssystem: Raspbian Buster
                      Node-Version:
                      Nodejs-Version: 12.18.2
                      NPM-Version: 6.14.5
                      Installationsart:
                      Image genutzt:
                      Ort/Name der Imagedatei:
                      Seit dem ich nun auf die stable Version 17 aktualisiert habe - kann ich auf die System-Objekte nicht mehr zugreifen.
                      Damit konnte ich immer sehr gut den Status der Instanzen abfragen.
                      Zum Beispiel: system.adapter.admin.0.alive
                      Warum ändert man eigentlich super funktionierende Funktionen ab - und sperrt nun den Zugriff. Das ging alles vor dem Update noch!!!
                      mickymM Offline
                      mickymM Offline
                      mickym
                      Gibts hier Neuigkeiten?
                      • mickymM mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        Was sagen die Entwickler?
