  4. JavaScript
  5. [Vorlage] Flexibles Timerskript + Vis
javascripttemplate
500 Beiträge 40 Kommentatoren 165.5k Aufrufe 63 Beobachtet
  • gelberlemmyG gelberlemmy
    @gelberlemmy
    so keine Änderung. Die Fehlermeldungen gehen auch erst los, sobald ich in den Spalten "undefined" auswähle.
    javascript.0	2020-07-31 21:13:37.206	error	(21270) at processImmediate (internal/timers.js:456:21)
    javascript.0	2020-07-31 21:13:37.206	error	(21270) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.0	2020-07-31 21:13:37.205	error	(21270) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.0	2020-07-31 21:13:37.205	error	(21270) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.0	2020-07-31 21:13:37.204	error	(21270) at Object.<anonymous> (script.js.common.TimerTarget:1112:98)
    javascript.0	2020-07-31 21:13:37.204	error	(21270) at DetermineNextActiveAstroDay (script.js.common.TimerTarget:520:32)
    javascript.0	2020-07-31 21:13:37.203	error	(21270) at CheckTodayAstroIsOver (script.js.common.TimerTarget:631:15)
    javascript.0	2020-07-31 21:13:37.203	error	(21270) Error in callback: TypeError: Cannot read property 'setMinutes' of undefined
    javascript.0	2020-07-31 21:13:37.199	error	(21270) Cannot get astro date for "undefined"
    javascript.0	2020-07-31 21:13:37.198	info	(21270) script.js.common.TimerTarget: Reaching CheckTodayAstroIsOver(AstroChoice=undefined Shift=0)
    javascript.0	2020-07-31 21:13:37.198	info	(21270) script.js.common.TimerTarget: Reaching DetermineNextActiveAstroDay(whichone=-1 GoToTommorrow=false)
    javascript.0	2020-07-31 21:13:37.197	info	(21270) script.js.common.TimerTarget: Astro choosen
    javascript.0	2020-07-31 21:13:37.196	info	(21270) script.js.common.TimerTarget: Reaching MakeTable
    javascript.0	2020-07-31 21:13:37.195	info	(21270) script.js.common.TimerTarget: Reaching SwitchEditMode(whichone, onoff), whichonex=undefined TimerCount=1 onoff=true
    javascript.0	2020-07-31 21:13:33.022	info	(21270) script.js.common.TimerTarget: Reaching MakeTable
    javascript.0	2020-07-31 21:13:33.021	info	(21270) script.js.common.TimerTarget: Reaching SwitchEditMode(whichone, onoff), whichonex=undefined TimerCount=1 onoff=true
    javascript.0	2020-07-31 21:13:22.307	info	(21270) script.js.common.TimerTarget: Template TimerTarget changed, typeof=string Wert=
    javascript.0	2020-07-31 21:13:22.267	info	(21270) script.js.common.TimerTarget: Timertemplate changed to undefined
    javascript.0	2020-07-31 21:13:22.266	info	(21270) script.js.common.TimerTarget: Reaching MakeTable
    javascript.0	2020-07-31 21:13:22.266	info	(21270) script.js.common.TimerTarget: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=1 onoff=false
    javascript.0	2020-07-31 21:13:22.263	info	(21270) script.js.common.TimerTarget: Typeof MyTimer[undefined]=undefined
    javascript.0	2020-07-31 21:13:22.262	info	(21270) script.js.common.TimerTarget: Reaching WriteToTemplate(whichone), whichone=undefined
    gelberlemmyG Offline
    gelberlemmy
    #248
    Habe mir jetzt einen Button für den Regelneustart gebaut 😁
    P 1 Antwort Letzte Antwort
      Pittini
      #249
      @gelberlemmy sagte in [Vorlage] Flexibles Timerskript + Vis:
      Als workaround sinnvoll, aber ich bin hartnäckig und will trotzdem wissen was da los ist. Vorallem weil nur Du das Problem hast. An obigem Screen sieht man ja schön das da alles leer ist im Änderungsbereich, schon das darf nicht sein.
      Kannst Du mal bitte zur Sicherheit in Vis ein komplett leeres neues Projekt anlegen und da eine einzige Seite machen mit den Widgets aus dem zur Verfügung gestellten View.
      Solltest Du Anydesk haben, würd ich mir das gerne mal live anschauen, wär vermutlich am sinnvollsten. ID kannste mir ja ggfs. im Chat durchgeben.
      gelberlemmyG 2 Antworten Letzte Antwort
      • P Pittini
        gelberlemmy
        #250
        @Pittini wenn Anydesk kostenfrei ist, sehr sehr gerne.
          Pittini
          #251
          @gelberlemmy
          Ja, is kostenlos für Privatnutzung. https://anydesk.com/de/downloads
          F gelberlemmyG 2 Antworten Letzte Antwort
          • P Pittini
            @gelberlemmy
            fastfoot
            #252
            @Pittini Hallo, ich habe ein Problem beim Löschen der Timer festgestellt(V2.1.7)
            Erstellt wurden 4 Timer, der Einfachheit halber wurden hier nur die Ziele zugewiesen
            Löschen möchte ich nun Timer 3(Schlafzimmer), gelöscht wird jedoch Timer 2(Play2)
            Ein weiterer Versuch, den Timer(nun Timer 2) zu löschen, löscht wiederum den darüberliegenden Timer 1(Play1)
            Hier das
            javascript.2 2020-08-02 20:22:59.612 info (158) script.js.Forum.Timer: Timer Schedule 2 killed
            javascript.2 2020-08-02 20:22:59.611 info (158) script.js.Forum.Timer: Timer Schedule 1 killed
            javascript.2 2020-08-02 20:22:59.610 info (158) Stop script script.js.Forum.Timer
            javascript.2 2020-08-02 20:22:01.309 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:22:01.309 info (158) script.js.Forum.Timer: Now Delete last channel=javascript.2.Timer.2
            javascript.2 2020-08-02 20:22:01.306 info (158) script.js.Forum.Timer: Reaching CreateTimerCountList()
            javascript.2 2020-08-02 20:22:01.306 info (158) script.js.Forum.Timer: Timer Schedule 2 killed
            javascript.2 2020-08-02 20:22:01.305 info (158) script.js.Forum.Timer: Reaching DeleteTimer(whichone), whichone=1
            javascript.2 2020-08-02 20:21:46.066 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=hue.0.Lampe_Schlafzimmer.on
            javascript.2 2020-08-02 20:21:46.052 info (158) script.js.Forum.Timer: Timertemplate changed to 1
            javascript.2 2020-08-02 20:21:46.051 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:21:46.051 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=3 onoff=false
            javascript.2 2020-08-02 20:21:46.049 info (158) script.js.Forum.Timer: Typeof MyTimer[1]=object
            javascript.2 2020-08-02 20:21:46.049 info (158) script.js.Forum.Timer: Reaching WriteToTemplate(whichone), whichone=1
            javascript.2 2020-08-02 20:21:41.598 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:21:41.578 info (158) script.js.Forum.Timer: Timertemplate changed to 2
            javascript.2 2020-08-02 20:21:41.578 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:21:41.578 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=3 onoff=false
            javascript.2 2020-08-02 20:21:41.576 info (158) script.js.Forum.Timer: Typeof MyTimer[2]=object
            javascript.2 2020-08-02 20:21:41.576 info (158) script.js.Forum.Timer: Reaching WriteToTemplate(whichone), whichone=2
            javascript.2 2020-08-02 20:20:59.378 info (158) script.js.Forum.Timer: Timertemplate changed to 1
            javascript.2 2020-08-02 20:20:59.377 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:20:59.377 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=3 onoff=false
            javascript.2 2020-08-02 20:20:59.375 info (158) script.js.Forum.Timer: Typeof MyTimer[1]=object
            javascript.2 2020-08-02 20:20:59.375 info (158) script.js.Forum.Timer: Reaching WriteToTemplate(whichone), whichone=1
            javascript.2 2020-08-02 20:20:48.033 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:20:48.033 info (158) script.js.Forum.Timer: Now Delete last channel=javascript.2.Timer.3
            javascript.2 2020-08-02 20:20:48.026 info (158) script.js.Forum.Timer: Reaching CreateTimerCountList()
            javascript.2 2020-08-02 20:20:48.026 info (158) script.js.Forum.Timer: Timer Schedule 3 killed
            javascript.2 2020-08-02 20:20:48.025 info (158) script.js.Forum.Timer: Reaching DeleteTimer(whichone), whichone=2
            javascript.2 2020-08-02 20:19:45.315 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=hue.0.Lampe_Schlafzimmer.on
            javascript.2 2020-08-02 20:19:45.292 info (158) script.js.Forum.Timer: Timertemplate changed to 2
            javascript.2 2020-08-02 20:19:45.292 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:45.291 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:45.284 info (158) script.js.Forum.Timer: Typeof MyTimer[2]=object
            javascript.2 2020-08-02 20:19:45.284 info (158) script.js.Forum.Timer: Reaching WriteToTemplate(whichone), whichone=2
            javascript.2 2020-08-02 20:19:39.327 info (158) script.js.Forum.Timer: Settings saved
            javascript.2 2020-08-02 20:19:38.327 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:38.326 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:38.325 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:38.324 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,3 GoToTommorrow=false)
            javascript.2 2020-08-02 20:19:38.324 info (158) script.js.Forum.Timer: Timer Schedule 4 killed
            javascript.2 2020-08-02 20:19:38.323 info (158) script.js.Forum.Timer: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
            javascript.2 2020-08-02 20:19:38.323 info (158) script.js.Forum.Timer: New TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:38.323 info (158) script.js.Forum.Timer: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Play1_Wohnzimmer.on,hue.0.Lampe_Schlafzimmer.on,hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:19:38.322 info (158) script.js.Forum.Timer: Original TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:38.322 info (158) script.js.Forum.Timer: Reaching CreateTimerTargetsNameList()
            javascript.2 2020-08-02 20:19:38.320 info (158) script.js.Forum.Timer: Reaching WriteToTimer, whichone=3
            javascript.2 2020-08-02 20:19:35.848 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:35.847 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
            javascript.2 2020-08-02 20:19:35.843 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:19:35.843 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:35.842 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
            javascript.2 2020-08-02 20:19:31.242 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=
            javascript.2 2020-08-02 20:19:31.229 info (158) script.js.Forum.Timer: Timertemplate changed to 3
            javascript.2 2020-08-02 20:19:31.229 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:31.228 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:31.226 info (158) script.js.Forum.Timer: Typeof MyTimer[3]=object
            javascript.2 2020-08-02 20:19:31.226 info (158) script.js.Forum.Timer: Reaching WriteToTemplate(whichone), whichone=3
            javascript.2 2020-08-02 20:19:29.317 info (158) script.js.Forum.Timer: Settings saved
            javascript.2 2020-08-02 20:19:28.316 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:28.315 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:28.314 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:28.314 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,2 GoToTommorrow=false)
            javascript.2 2020-08-02 20:19:28.314 info (158) script.js.Forum.Timer: Timer Schedule 3 killed
            javascript.2 2020-08-02 20:19:28.314 info (158) script.js.Forum.Timer: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
            javascript.2 2020-08-02 20:19:28.314 info (158) script.js.Forum.Timer: New TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:28.313 info (158) script.js.Forum.Timer: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Play1_Wohnzimmer.on,hue.0.Lampe_Schlafzimmer.on,hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:19:28.313 info (158) script.js.Forum.Timer: Original TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:28.313 info (158) script.js.Forum.Timer: Reaching CreateTimerTargetsNameList()
            javascript.2 2020-08-02 20:19:28.311 info (158) script.js.Forum.Timer: Reaching WriteToTimer, whichone=2
            javascript.2 2020-08-02 20:19:26.690 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:26.689 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=true
            javascript.2 2020-08-02 20:19:26.682 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=hue.0.Lampe_Schlafzimmer.on
            javascript.2 2020-08-02 20:19:26.682 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:26.681 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=true
            javascript.2 2020-08-02 20:19:19.904 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=
            javascript.2 2020-08-02 20:19:19.823 info (158) script.js.Forum.Timer: Timertemplate changed to 2
            javascript.2 2020-08-02 20:19:19.823 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:19.823 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:19.821 info (158) script.js.Forum.Timer: Typeof MyTimer[2]=object
            javascript.2 2020-08-02 20:19:19.820 info (158) script.js.Forum.Timer: Reaching WriteToTemplate(whichone), whichone=2
            javascript.2 2020-08-02 20:19:15.524 info (158) script.js.Forum.Timer: Settings saved
            javascript.2 2020-08-02 20:19:14.523 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:14.522 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:14.522 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,1 GoToTommorrow=false)
            javascript.2 2020-08-02 20:19:14.522 info (158) script.js.Forum.Timer: Timer Schedule 2 killed
            javascript.2 2020-08-02 20:19:14.522 info (158) script.js.Forum.Timer: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
            javascript.2 2020-08-02 20:19:14.521 info (158) script.js.Forum.Timer: New TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:14.521 info (158) script.js.Forum.Timer: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Play1_Wohnzimmer.on,hue.0.Lampe_Schlafzimmer.on,hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:19:14.520 info (158) script.js.Forum.Timer: Original TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:14.520 info (158) script.js.Forum.Timer: Reaching CreateTimerTargetsNameList()
            javascript.2 2020-08-02 20:19:14.518 info (158) script.js.Forum.Timer: Reaching WriteToTimer, whichone=1
            javascript.2 2020-08-02 20:19:12.872 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:12.872 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
            javascript.2 2020-08-02 20:19:12.866 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=hue.0.Play2_Wohnzimmer.on
            javascript.2 2020-08-02 20:19:12.866 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:12.865 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
            javascript.2 2020-08-02 20:19:07.532 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=
            javascript.2 2020-08-02 20:19:07.480 info (158) script.js.Forum.Timer: Timertemplate changed to 1
            javascript.2 2020-08-02 20:19:07.479 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:07.479 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:07.472 info (158) script.js.Forum.Timer: Typeof MyTimer[1]=object
            javascript.2 2020-08-02 20:19:07.472 info (158) script.js.Forum.Timer: Reaching WriteToTemplate(whichone), whichone=1
            javascript.2 2020-08-02 20:19:03.643 info (158) script.js.Forum.Timer: Settings saved
            javascript.2 2020-08-02 20:19:02.643 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:02.642 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:02.642 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=false
            javascript.2 2020-08-02 20:19:02.642 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,0 GoToTommorrow=false)
            javascript.2 2020-08-02 20:19:02.641 info (158) script.js.Forum.Timer: Timer Schedule 1 killed
            javascript.2 2020-08-02 20:19:02.641 info (158) script.js.Forum.Timer: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
            javascript.2 2020-08-02 20:19:02.641 info (158) script.js.Forum.Timer: New TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:02.640 info (158) script.js.Forum.Timer: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Play1_Wohnzimmer.on,hue.0.Lampe_Schlafzimmer.on,hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:19:02.640 info (158) script.js.Forum.Timer: Original TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:19:02.639 info (158) script.js.Forum.Timer: Reaching CreateTimerTargetsNameList()
            javascript.2 2020-08-02 20:19:02.637 info (158) script.js.Forum.Timer: Reaching WriteToTimer, whichone=0
            javascript.2 2020-08-02 20:19:00.161 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:00.161 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=true
            javascript.2 2020-08-02 20:19:00.157 info (158) script.js.Forum.Timer: Template TimerTarget changed, typeof=string Wert=hue.0.Play1_Wohnzimmer.on
            javascript.2 2020-08-02 20:19:00.156 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:19:00.156 info (158) script.js.Forum.Timer: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=true
            web.0 2020-08-02 20:18:50.740 info (530) ==>Connected system.user.admin from ::ffff:192.168.178.39
            web.0 2020-08-02 20:18:50.235 info (530) <==Disconnect system.user.admin from ::ffff:192.168.178.39 vis.0
            web.0 2020-08-02 20:18:37.020 info (530) ==>Connected system.user.admin from ::ffff:192.168.178.39
            javascript.2 2020-08-02 20:17:53.065 info (158) script.js.Forum.Timer: Reaching MakeTable
            javascript.2 2020-08-02 20:17:53.064 info (158) script.js.Forum.Timer: New TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:17:53.064 info (158) script.js.Forum.Timer: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Play1_Wohnzimmer.on,hue.0.Lampe_Schlafzimmer.on,hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:17:53.063 info (158) script.js.Forum.Timer: Original TargetNames are:Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:17:53.062 info (158) script.js.Forum.Timer: Reaching CreateTimerTargetsNameList()
            javascript.2 2020-08-02 20:17:53.062 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,3 GoToTommorrow=false)
            javascript.2 2020-08-02 20:17:53.061 info (158) script.js.Forum.Timer: Timer CreateState(s) finished!
            javascript.2 2020-08-02 20:17:53.059 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,2 GoToTommorrow=false)
            javascript.2 2020-08-02 20:17:53.058 info (158) script.js.Forum.Timer: Timer CreateState(s) finished!
            javascript.2 2020-08-02 20:17:53.051 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,1 GoToTommorrow=false)
            javascript.2 2020-08-02 20:17:53.050 info (158) script.js.Forum.Timer: Timer CreateState(s) finished!
            javascript.2 2020-08-02 20:17:53.048 info (158) script.js.Forum.Timer: Reaching SetTimer(whichone=,0 GoToTommorrow=false)
            javascript.2 2020-08-02 20:17:53.046 info (158) script.js.Forum.Timer: Timer CreateState(s) finished!
            javascript.2 2020-08-02 20:17:52.582 info (158) script.js.Forum.Timer: Reaching CreateTrigger()
            javascript.2 2020-08-02 20:17:52.582 info (158) script.js.Forum.Timer: Reaching ConvertPresence. TempPresence=true
            javascript.2 2020-08-02 20:17:52.581 info (158) script.js.Forum.Timer: Reaching SetValueListPairs()
            javascript.2 2020-08-02 20:17:52.580 info (158) script.js.Forum.Timer: Reaching CreateTimerCountList()
            javascript.2 2020-08-02 20:17:52.571 info (158) script.js.Forum.Timer: Names are: Play2_Wohnzimmer.on,Play1_Wohnzimmer.on,Lampe_Schlafzimmer.on,Strip_Bad.on
            javascript.2 2020-08-02 20:17:52.571 info (158) script.js.Forum.Timer: 4 Targets found - Targets are: hue.0.Play2_Wohnzimmer.on,hue.0.Play1_Wohnzimmer.on,hue.0.Lampe_Schlafzimmer.on,hue.0.Strip_Bad.on
            javascript.2 2020-08-02 20:17:52.571 info (158) script.js.Forum.Timer: GetParentId(Targets[y])=hue.0.Strip_Bad
            javascript.2 2020-08-02 20:17:52.570 info (158) script.js.Forum.Timer: GetParentId(Targets[y])=hue.0.Lampe_Schlafzimmer
            javascript.2 2020-08-02 20:17:52.570 info (158) script.js.Forum.Timer: GetParentId(Targets[y])=hue.0.Play1_Wohnzimmer
            javascript.2 2020-08-02 20:17:52.569 info (158) script.js.Forum.Timer: GetParentId(Targets[y])=hue.0.Play2_Wohnzimmer
            javascript.2 2020-08-02 20:17:52.568 info (158) script.js.Forum.Timer: Reaching Init()
            javascript.2 2020-08-02 20:17:52.568 info (158) script.js.Forum.Timer: Reaching Main
            javascript.2 2020-08-02 20:17:52.567 info (158) script.js.Forum.Timer: Initial CreateStates finished!
            javascript.2 2020-08-02 20:17:52.195 info (158) script.js.Forum.Timer: registered 0 subscriptions and 0 schedules
            javascript.2 2020-08-02 20:17:52.190 info (158) script.js.Forum.Timer: Starting TimerSkript V2.1.7
            javascript.2 2020-08-02 20:17:52.182 info (158) Start javascript script.js.Forum.Timer
            Zusätzlich, wenn Timer 3 eingestellt und eingeschaltet ist, dann wird zwar zum Zeitpunkt getriggert, jedoch meldet das LOG dann einen Fehler, Callback nicht erreichbar oder so ähnlich. (ist im LOG der Einfachheit halber nicht enthalten, da es nach einem Fix der gezeigten Fehler evtl automatisch verschwindet)
            Ich habe versucht, mehr Vorarbeit zu leisten, um den Fehler evtl. selbst zu finden, bin jedoch kläglich gescheitert :-(
            • P Pittini
              @gelberlemmy
              gelberlemmy
              #253
              @Pittini sagte in [Vorlage] Flexibles Timerskript + Vis:
              @gelberlemmy
              Danke. Schreibe Dir eine PN
              • F fastfoot
                Hier das
                Pittini
                #254
                @fastfoot sagte in [Vorlage] Flexibles Timerskript + Vis:
                Der Fehler is atypisch und bisher noch bei niemand aufgetreten. Ich kanns leider auch nicht reproduzieren. Da Du aber ne Fehlermeldung hast, würd ich mich gern erst mal da drum kümmern (also genau andersrum als Du dachtest). Poste bitte mal das Log wenn der Fehler auftritt.
                F 2 Antworten Letzte Antwort
                • P Pittini
                  fastfoot
                  #255
                  Also ich habe ein komplett neues System aufgesetzt, nur mit JS und Hue-Adapter und VIS, Hier nochmal die Ausgangssituation, diesmal mit Zeiten
                  Gelöscht wird nun Timer3(Play2), in der VIS verschwindet jedoch Timer2
                  Nun lösche ich wieder die Play2(nun Timer2), in der VIS verschwindet jedoch Timer1
                  Was jetzt aber absolut unverständlich ist, die originalen Zeiten der ersten beiden Timer wurden mit den verbleibenden Zielen gemischt, d.h. die Play2 geht um 19:22:00 an und um 19:22:30 aus, wie es eigentlich für den Strip gescheduled war. (siehe auch LOG Zeilen 219 + 224). Der gestern beschriebene Fehler erscheint zur Zeit des originalen Timers 4(in Bild3 Timer2)
                  2020-08-03 19:17:07.526  - Start javascript script.js.common.Timer217
                  2020-08-03 19:17:07.535  - script.js.common.Timer217: Starting TimerSkript V2.1.7
                  2020-08-03 19:17:07.548  - script.js.common.Timer217: registered 0 subscriptions and 0 schedules
                  2020-08-03 19:17:07.981  - script.js.common.Timer217: Initial CreateStates finished!
                  2020-08-03 19:17:07.982  - script.js.common.Timer217: Reaching Main
                  2020-08-03 19:17:07.983  - script.js.common.Timer217: Reaching Init()
                  2020-08-03 19:17:07.985  - script.js.common.Timer217: GetParentId(Targets[y])=hue.0.Play2_Wohnzimmer
                  2020-08-03 19:17:07.987  - script.js.common.Timer217: GetParentId(Targets[y])=hue.0.Strip_Wohnzimmer
                  2020-08-03 19:17:07.988  - script.js.common.Timer217: 2 Targets found - Targets are: hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:17:07.988  - script.js.common.Timer217: Names are: Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:08.001  - script.js.common.Timer217: Reaching CreateTimerCountList()
                  2020-08-03 19:17:08.003  - script.js.common.Timer217: Reaching SetValueListPairs()
                  2020-08-03 19:17:08.004  - script.js.common.Timer217: Reaching ConvertPresence. TempPresence=true
                  2020-08-03 19:17:08.006  - script.js.common.Timer217: Reaching CreateTrigger()
                  2020-08-03 19:17:08.241  - script.js.common.Timer217: Timer CreateState(s) finished!
                  2020-08-03 19:17:08.243  - script.js.common.Timer217: Reaching SetTimer(whichone=,0 GoToTommorrow=false)
                  2020-08-03 19:17:08.252  - script.js.common.Timer217: Timer CreateState(s) finished!
                  2020-08-03 19:17:08.253  - script.js.common.Timer217: Reaching SetTimer(whichone=,1 GoToTommorrow=false)
                  2020-08-03 19:17:08.254  - script.js.common.Timer217: Reaching CreateTimerTargetsNameList()
                  2020-08-03 19:17:08.254  - script.js.common.Timer217: Original TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:08.255  - script.js.common.Timer217: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:17:08.255  - script.js.common.Timer217: New TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:08.257  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:14.087  - script.js.common.Timer217: AddTimer triggered, val=true
                  2020-08-03 19:17:14.088  - script.js.common.Timer217: Reaching AddNewTimer
                  2020-08-03 19:17:14.090  - script.js.common.Timer217: Timercount=3
                  2020-08-03 19:17:14.094  - script.js.common.Timer217: Reaching CreateTimerCountList()
                  2020-08-03 19:17:14.187  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=2
                  2020-08-03 19:17:14.188  - script.js.common.Timer217: Typeof MyTimer[2]=undefined
                  2020-08-03 19:17:14.192  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=3 onoff=false
                  2020-08-03 19:17:14.193  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:14.194  - script.js.common.Timer217: Timertemplate changed to 2
                  2020-08-03 19:17:14.336  - script.js.common.Timer217: Timer CreateState(s) finished!
                  2020-08-03 19:17:14.339  - script.js.common.Timer217: Reaching SetTimer(whichone=,2 GoToTommorrow=false)
                  2020-08-03 19:17:14.339  - script.js.common.Timer217: Reaching CreateTimerTargetsNameList()
                  2020-08-03 19:17:14.340  - script.js.common.Timer217: Original TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:14.342  - script.js.common.Timer217: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:17:14.343  - script.js.common.Timer217: New TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:14.343  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:14.598  - script.js.common.Timer217: AddTimer triggered, val=false
                  2020-08-03 19:17:15.910  - script.js.common.Timer217: AddTimer triggered, val=true
                  2020-08-03 19:17:15.911  - script.js.common.Timer217: Reaching AddNewTimer
                  2020-08-03 19:17:15.912  - script.js.common.Timer217: Timercount=4
                  2020-08-03 19:17:15.918  - script.js.common.Timer217: Reaching CreateTimerCountList()
                  2020-08-03 19:17:16.077  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=3
                  2020-08-03 19:17:16.081  - script.js.common.Timer217: Typeof MyTimer[3]=undefined
                  2020-08-03 19:17:16.089  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=false
                  2020-08-03 19:17:16.091  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:16.097  - script.js.common.Timer217: Timertemplate changed to 3
                  2020-08-03 19:17:16.234  - script.js.common.Timer217: Timer CreateState(s) finished!
                  2020-08-03 19:17:16.236  - script.js.common.Timer217: Reaching SetTimer(whichone=,3 GoToTommorrow=false)
                  2020-08-03 19:17:16.237  - script.js.common.Timer217: Reaching CreateTimerTargetsNameList()
                  2020-08-03 19:17:16.239  - script.js.common.Timer217: Original TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:16.241  - script.js.common.Timer217: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:17:16.242  - script.js.common.Timer217: New TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:16.242  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:16.423  - script.js.common.Timer217: AddTimer triggered, val=false
                  2020-08-03 19:17:19.448  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=0
                  2020-08-03 19:17:19.450  - script.js.common.Timer217: Typeof MyTimer[0]=object
                  2020-08-03 19:17:19.454  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=false
                  2020-08-03 19:17:19.454  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:19.455  - script.js.common.Timer217: Timertemplate changed to 0
                  2020-08-03 19:17:29.844  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=true
                  2020-08-03 19:17:29.845  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:41.885  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=true
                  2020-08-03 19:17:41.885  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:47.343  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=true
                  2020-08-03 19:17:47.343  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:47.344  - script.js.common.Timer217: Template TimerTarget changed, typeof=string Wert=hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:17:47.350  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=true
                  2020-08-03 19:17:47.350  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:49.677  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=true
                  2020-08-03 19:17:49.677  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:51.766  - script.js.common.Timer217: Reaching WriteToTimer, whichone=0
                  2020-08-03 19:17:51.772  - script.js.common.Timer217: Reaching CreateTimerTargetsNameList()
                  2020-08-03 19:17:51.772  - script.js.common.Timer217: Original TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:51.773  - script.js.common.Timer217: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:17:51.775  - script.js.common.Timer217: New TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:17:51.775  - script.js.common.Timer217: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
                  2020-08-03 19:17:51.777  - script.js.common.Timer217: Timer Schedule 1 killed
                  2020-08-03 19:17:51.777  - script.js.common.Timer217: Reaching SetTimer(whichone=,0 GoToTommorrow=false)
                  2020-08-03 19:17:51.778  - script.js.common.Timer217: Timer 1 will be set, GoToTommorrow=false
                  2020-08-03 19:17:51.779  - script.js.common.Timer217: Reaching CreateTimeDaysString(whichone=0)
                  2020-08-03 19:17:51.780  - script.js.common.Timer217: Reaching MakeCronString(whichone=0)
                  2020-08-03 19:17:51.781  - script.js.common.Timer217: CronString for Timer 1 created 00 22 19 * * *
                  2020-08-03 19:17:51.796  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=false
                  2020-08-03 19:17:51.797  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:51.799  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:52.801  - script.js.common.Timer217: Settings saved
                  2020-08-03 19:17:53.963  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=1
                  2020-08-03 19:17:53.965  - script.js.common.Timer217: Typeof MyTimer[1]=object
                  2020-08-03 19:17:53.970  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=4 onoff=false
                  2020-08-03 19:17:53.970  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:53.971  - script.js.common.Timer217: Timertemplate changed to 1
                  2020-08-03 19:17:54.049  - script.js.common.Timer217: Template TimerTarget changed, typeof=string Wert=
                  2020-08-03 19:17:55.383  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
                  2020-08-03 19:17:55.384  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:17:56.812  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
                  2020-08-03 19:17:56.813  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:08.028  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
                  2020-08-03 19:18:08.029  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:10.932  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
                  2020-08-03 19:18:10.933  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:10.934  - script.js.common.Timer217: Template TimerTarget changed, typeof=string Wert=hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:18:10.942  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
                  2020-08-03 19:18:10.943  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:12.015  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=true
                  2020-08-03 19:18:12.015  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:13.210  - script.js.common.Timer217: Reaching WriteToTimer, whichone=1
                  2020-08-03 19:18:13.214  - script.js.common.Timer217: Reaching CreateTimerTargetsNameList()
                  2020-08-03 19:18:13.215  - script.js.common.Timer217: Original TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:18:13.216  - script.js.common.Timer217: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:18:13.216  - script.js.common.Timer217: New TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:18:13.217  - script.js.common.Timer217: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
                  2020-08-03 19:18:13.217  - script.js.common.Timer217: Timer Schedule 2 killed
                  2020-08-03 19:18:13.217  - script.js.common.Timer217: Reaching SetTimer(whichone=,1 GoToTommorrow=false)
                  2020-08-03 19:18:13.218  - script.js.common.Timer217: Timer 2 will be set, GoToTommorrow=false
                  2020-08-03 19:18:13.218  - script.js.common.Timer217: Reaching CreateTimeDaysString(whichone=1)
                  2020-08-03 19:18:13.220  - script.js.common.Timer217: Reaching MakeCronString(whichone=1)
                  2020-08-03 19:18:13.220  - script.js.common.Timer217: CronString for Timer 2 created 30 22 19 * * *
                  2020-08-03 19:18:13.225  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=false
                  2020-08-03 19:18:13.226  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:14.228  - script.js.common.Timer217: Settings saved
                  2020-08-03 19:18:16.478  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=2
                  2020-08-03 19:18:16.478  - script.js.common.Timer217: Typeof MyTimer[2]=object
                  2020-08-03 19:18:16.481  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=false
                  2020-08-03 19:18:16.482  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:16.482  - script.js.common.Timer217: Timertemplate changed to 2
                  2020-08-03 19:18:16.497  - script.js.common.Timer217: Template TimerTarget changed, typeof=string Wert=
                  2020-08-03 19:18:21.838  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=true
                  2020-08-03 19:18:21.840  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:30.710  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=true
                  2020-08-03 19:18:30.711  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:32.548  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=true
                  2020-08-03 19:18:32.548  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:32.549  - script.js.common.Timer217: Template TimerTarget changed, typeof=string Wert=hue.0.Play2_Wohnzimmer.on
                  2020-08-03 19:18:32.555  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=true
                  2020-08-03 19:18:32.556  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:34.174  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=true
                  2020-08-03 19:18:34.174  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:34.744  - script.js.common.Timer217: Reaching WriteToTimer, whichone=2
                  2020-08-03 19:18:34.754  - script.js.common.Timer217: Reaching CreateTimerTargetsNameList()
                  2020-08-03 19:18:34.755  - script.js.common.Timer217: Original TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:18:34.756  - script.js.common.Timer217: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:18:34.756  - script.js.common.Timer217: New TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:18:34.757  - script.js.common.Timer217: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
                  2020-08-03 19:18:34.757  - script.js.common.Timer217: Timer Schedule 3 killed
                  2020-08-03 19:18:34.758  - script.js.common.Timer217: Reaching SetTimer(whichone=,2 GoToTommorrow=false)
                  2020-08-03 19:18:34.758  - script.js.common.Timer217: Timer 3 will be set, GoToTommorrow=false
                  2020-08-03 19:18:34.759  - script.js.common.Timer217: Reaching CreateTimeDaysString(whichone=2)
                  2020-08-03 19:18:34.760  - script.js.common.Timer217: Reaching MakeCronString(whichone=2)
                  2020-08-03 19:18:34.760  - script.js.common.Timer217: CronString for Timer 3 created 00 23 19 * * *
                  2020-08-03 19:18:34.762  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=false
                  2020-08-03 19:18:34.763  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:34.764  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:35.765  - script.js.common.Timer217: Settings saved
                  2020-08-03 19:18:37.496  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=3
                  2020-08-03 19:18:37.497  - script.js.common.Timer217: Typeof MyTimer[3]=object
                  2020-08-03 19:18:37.501  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=4 onoff=false
                  2020-08-03 19:18:37.501  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:37.503  - script.js.common.Timer217: Timertemplate changed to 3
                  2020-08-03 19:18:37.521  - script.js.common.Timer217: Template TimerTarget changed, typeof=string Wert=
                  2020-08-03 19:18:38.648  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
                  2020-08-03 19:18:38.649  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:40.181  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
                  2020-08-03 19:18:40.182  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:50.408  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
                  2020-08-03 19:18:50.409  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:18:59.362  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
                  2020-08-03 19:18:59.363  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:19:01.614  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
                  2020-08-03 19:19:01.615  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:19:01.616  - script.js.common.Timer217: Template TimerTarget changed, typeof=string Wert=hue.0.Play2_Wohnzimmer.on
                  2020-08-03 19:19:01.621  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
                  2020-08-03 19:19:01.621  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:19:03.488  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=true
                  2020-08-03 19:19:03.488  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:19:04.640  - script.js.common.Timer217: Reaching WriteToTimer, whichone=3
                  2020-08-03 19:19:04.653  - script.js.common.Timer217: Reaching CreateTimerTargetsNameList()
                  2020-08-03 19:19:04.653  - script.js.common.Timer217: Original TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:19:04.654  - script.js.common.Timer217: Possible Target are:hue.0.Play2_Wohnzimmer.on,hue.0.Strip_Wohnzimmer.on
                  2020-08-03 19:19:04.655  - script.js.common.Timer217: New TargetNames are:Play2_Wohnzimmer,Strip_Wohnzimmer
                  2020-08-03 19:19:04.655  - script.js.common.Timer217: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
                  2020-08-03 19:19:04.655  - script.js.common.Timer217: Timer Schedule 4 killed
                  2020-08-03 19:19:04.656  - script.js.common.Timer217: Reaching SetTimer(whichone=,3 GoToTommorrow=false)
                  2020-08-03 19:19:04.656  - script.js.common.Timer217: Timer 4 will be set, GoToTommorrow=false
                  2020-08-03 19:19:04.657  - script.js.common.Timer217: Reaching CreateTimeDaysString(whichone=3)
                  2020-08-03 19:19:04.657  - script.js.common.Timer217: Reaching MakeCronString(whichone=3)
                  2020-08-03 19:19:04.657  - script.js.common.Timer217: CronString for Timer 4 created 30 23 19 * * *
                  2020-08-03 19:19:04.661  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=false
                  2020-08-03 19:19:04.662  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:19:04.663  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:19:05.663  - script.js.common.Timer217: Settings saved
                  2020-08-03 19:19:36.910  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=2
                  2020-08-03 19:19:36.911  - script.js.common.Timer217: Typeof MyTimer[2]=object
                  2020-08-03 19:19:36.916  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=3 TimerCount=4 onoff=false
                  2020-08-03 19:19:36.917  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:19:36.917  - script.js.common.Timer217: Timertemplate changed to 2
                  2020-08-03 19:20:23.227  - script.js.common.Timer217: Reaching DeleteTimer(whichone), whichone=2
                  2020-08-03 19:20:23.229  - script.js.common.Timer217: Timer Schedule 3 killed
                  2020-08-03 19:20:23.230  - script.js.common.Timer217: Reaching CreateTimerCountList()
                  2020-08-03 19:20:23.241  - script.js.common.Timer217: Now Delete last channel=javascript.0.Timer.3
                  2020-08-03 19:20:23.242  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:20:49.091  - script.js.common.Timer217: Reaching WriteToTemplate(whichone), whichone=1
                  2020-08-03 19:20:49.092  - script.js.common.Timer217: Typeof MyTimer[1]=object
                  2020-08-03 19:20:49.095  - script.js.common.Timer217: Reaching SwitchEditMode(whichone, onoff), whichonex=2 TimerCount=3 onoff=false
                  2020-08-03 19:20:49.095  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:20:49.096  - script.js.common.Timer217: Timertemplate changed to 1
                  2020-08-03 19:20:51.297  - script.js.common.Timer217: Reaching DeleteTimer(whichone), whichone=1
                  2020-08-03 19:20:51.298  - script.js.common.Timer217: Timer Schedule 2 killed
                  2020-08-03 19:20:51.299  - script.js.common.Timer217: Reaching CreateTimerCountList()
                  2020-08-03 19:20:51.304  - script.js.common.Timer217: Now Delete last channel=javascript.0.Timer.2
                  2020-08-03 19:20:51.305  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:22:00.016  - script.js.common.Timer217: Reaching DoAction(), aktiv=true Rolle=1 whichone=0 Presence=true MyTimer[whichone][13]=hue.0.Play2_Wohnzimmer.on MyTimer[whichone][14]=true
                  2020-08-03 19:22:00.017  - script.js.common.Timer217: Timer 1, Play2_Wohnzimmer, switched on
                  2020-08-03 19:22:00.018  - script.js.common.Timer217: Reaching SetLockStates() TriggerIndex=-1 SwitchingTimerIndex=0
                  2020-08-03 19:22:00.019  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:22:00.027  - script.js.common.Skript_1: hue.0.Play2_Wohnzimmer.onStatus: true
                  2020-08-03 19:22:30.016  - script.js.common.Timer217: Reaching DoAction(), aktiv=true Rolle=0 whichone=1 Presence=true MyTimer[whichone][13]=hue.0.Play2_Wohnzimmer.on MyTimer[whichone][14]=true
                  2020-08-03 19:22:30.017  - script.js.common.Timer217: Timer 2, Play2_Wohnzimmer, switched off
                  2020-08-03 19:22:30.017  - script.js.common.Timer217: Reaching SetLockStates() TriggerIndex=-1 SwitchingTimerIndex=1
                  2020-08-03 19:22:30.018  - script.js.common.Timer217: Reaching MakeTable
                  2020-08-03 19:22:30.023  - script.js.common.Skript_1: hue.0.Play2_Wohnzimmer.onStatus: false
                  2020-08-03 19:23:30.023  -  Error in callback: TypeError: Cannot read property '0' of undefined
                  2020-08-03 19:23:30.024  -      at DoAction (script.js.common.Timer217:665:71)
                  2020-08-03 19:23:30.025  -      at Object.<anonymous> (script.js.common.Timer217:608:13)
                  2020-08-03 19:23:30.025  -      at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1270:34)
                  2020-08-03 19:23:30.026  -      at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                  2020-08-03 19:23:30.026  -      at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                  2020-08-03 19:23:30.027  -      at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                  2020-08-03 19:23:30.027  -      at listOnTimeout (internal/timers.js:549:17)
                  2020-08-03 19:23:30.028  -      at processTimers (internal/timers.js:492:7)
                  2020-08-03 19:27:31.496  - Stop script script.js.common.Timer217
                  2020-08-03 19:27:31.498  - script.js.common.Timer217: Timer Schedule 1 killed
                  2020-08-03 19:27:31.498  - script.js.common.Timer217: Timer Schedule 2 killed
                  Lass mich doch wissen, was ich evtl. zusätzlich mitloggen soll um den Fehler einzugrenzen
                  • P Pittini
                    fastfoot
                    #256
                    Das verstehe ich nicht, das konnte so nicht funktionieren. Ich habe den Fehler jetzt gefunden, er steckt in der Funktion DeleteTimer() und fällt auf, wenn aus der Mitte des Arrays ein Timer gelöscht wird. Dabei ist mir auch aufgefallen, dass es der unterschiedlichen Behandlung der Arraypositionen nicht bedarf. Folgende Zeile(hier 10) deckt alle Fälle ab
                        /*if (whichone == 0) { //Erster Eintrag des Arrays soll gelöscht werden
                            NewArray = MyTimer.slice(whichone + 1, TimerCount);
                        else if (whichone == TimerCount - 1) {//Letzter Eintrag des Arrays soll gelöscht werden
                            NewArray = MyTimer.slice(0, whichone);
                        else { //Eintrag aus der Mitte des Array soll gelöscht werden
                            NewArray = TempArray.concat(MyTimer.slice(0, whichone - 1), MyTimer.slice(whichone, TimerCount));
                        NewArray = TempArray.concat(MyTimer.slice(0, whichone), MyTimer.slice(whichone + 1));
                    Damit baut sich die Tabelle nach dem Löschen jetzt richtig auf und auch die Timer stimmen danach.
                    • P Pittini
                      Thread zum Timerskript unter: https://github.com/Pittini/iobroker-Timer
                      Baerny
                      #257
                      @Pittini Hallo Pittini, ich würde gerne als Schaltziel einen "Alias" nehmen. wie ich gesehen und getestet habe ist dies auch möglich. Jedoch wird mit immer nur als Name "Stammordner für Alias, sh. Screenshot" angezeigt und das auch nur für Datenpunkte die in der ersten Ebene liegen. Was mache ich falsch ?
                      Gruß Baerny
                      CCU 2 | Intel NUC mit Proxmox
                      • B Baerny
                        Gruß Baerny
                        Pittini
                        #258
                        @Baerny sagte in [Vorlage] Flexibles Timerskript + Vis:
                        Du machst nix falsch, Alias Ordner isn Sonderfall. Normalerweise ist der übergeordnete Channel eines Dps, der mit dem Namen, deswegen nimmt das Skript defaultmäßig dann diesen. Du hast jetzt 2 Lösungswege. Entweder Du benutzt benutzerdefinierte Namen oder Du nutzt im Skript unter Optionen die Variante in Zeile 10 und stellst die auf false. Letzteres gilt dann aber global.
                        • F fastfoot
                          Pittini
                          #259
                          Kann wer anders diesen Fehler, bzw. Probleme beim löschen bestätigen?
                          F 1 Antwort Letzte Antwort
                          • P Pittini
                            Baerny
                            #260
                            @Pittini Danke, werde ich mal testen
                            • P Pittini
                              fastfoot
                              #261
                              Evtl. hast Du es ja überlesen, aber ich habe mittlerweile schon gezeigt, dass es sich um einen Fehler im Skript handelt, und der muss jeden Nutzer betreffen. Mich verwundert, wieso das nicht nachvollziehbar sein soll, es fällt doch schon rein optisch auf.
                              • F fastfoot
                                Pittini
                                #262
                                Muß ich mir bei Gelegenheit noch mal in Ruhe anschauen. Aber Du darfst mir glauben, ich hab hier drölfzich Timer erstellt und gelöscht, sowohl beim testen als auch im Produktivbetrieb und es hat mit dem alten Code immer gepasst. Aber ich werd gern Deine Variante mal durchtesten, wie die sich dann verhält wenns der erste oder letzte Timer ist.
                                • P Pittini
                                  fastfoot
                                  #263
                                  Hiermit kannst du sehr leicht prüfen, was mit der Originalversion falsch läuft und dass meine Variante funktioniert, es ist die abgespeckte DeleteTimer() Funktion und es wird aus einem Array mit 4 Feldern immer ein Feld gelöscht, von 0-3
                                  let MyTimer = ['T0','T1','T2','T3'];
                                  let TimerCount = MyTimer.length;
                                  function DeleteTimer(whichone, x){
                                      let TempArray = [];
                                      let NewArray = [];
                                          if(x)log('Richtig => ' + whichone + ' ' + NewArray);
                                          if(x)log('Falsch => ' + whichone + ' ' + NewArray);
                                      if(!x)log('Richtig => ' + whichone + ' ' + NewArray);
                                      //MyTimer = NewArray;
                                      //MakeTable();
                                  log('Original');
                                  for(let i = 0; i < TimerCount; i++){
                                      DeleteTimer(i,1);
                                  log('nach Änderung');
                                      DeleteTimer(i,0);
                                  • P Pittini
                                    gelberlemmy
                                    #264
                                    @Pittini einen grossen Dank an Deine persönliche Hilfe über Fernverwaltung. Fehler ist gefunden. Das Problem lag an meiner Tabs Vorlage. Wie auf meinen Screenshots zu sehen ist, habe ich oberhalb der VIS Tabs der einzelnen Seiten. Dort muss es einen Bug geben. Wenn wir dies ohne diese Tabs Voreinstellung ausführen besteht der Fehler nicht.
                                    HERZLICHEN DANK 👍 💯
                                      Saschag
                                      #265
                                      @Pittini
                                      Ich habe häufiger das Problem dass der Javascriptadapter abstürzt beim hinzufügen eines neuen Timers
                                      javascript.0	2020-08-15 22:20:03.237	info	(10516) received all objects
                                      javascript.0	2020-08-15 22:20:01.859	info	(10516) received all states
                                      javascript.0	2020-08-15 22:19:59.847	info	(10516) requesting all objects
                                      javascript.0	2020-08-15 22:19:59.845	info	(10516) requesting all states
                                      javascript.0	2020-08-15 22:19:59.751	info	(10516) starting. Version 4.6.17 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.18.3, js-controller: 3.1.6
                                      javascript.0	2020-08-15 22:19:26.560	error	(8468) at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                      javascript.0	2020-08-15 22:19:26.560	error	(8468) at runMicrotasks (<anonymous>)
                                      javascript.0	2020-08-15 22:19:26.560	error	(8468) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                                      javascript.0	2020-08-15 22:19:26.559	error	(8468) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                      javascript.0	2020-08-15 22:19:26.559	error	(8468) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:547:55
                                      javascript.0	2020-08-15 22:19:26.559	error	(8468) at script.js.Timer.TimerV217:260:17
                                      javascript.0	2020-08-15 22:19:26.559	error	(8468) at FillTimerArray (script.js.Timer.TimerV217:281:9)
                                      javascript.0	2020-08-15 22:19:26.559	error	(8468) at CreateDeviceTrigger (script.js.Timer.TimerV217:1056:5)
                                      javascript.0	2020-08-15 22:19:26.558	error	(8468) at on (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1151:28)
                                      javascript.0	2020-08-15 22:19:26.558	error	(8468) at Object.subscribe (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:112)
                                      javascript.0	2020-08-15 22:19:26.557	error	(8468) script.js.Timer.TimerV217: TypeError: Cannot read property 'period' of null
                                      Eine Idee und Danke im Voraus
                                      • S Saschag
                                        @Pittini
                                        Pittini
                                        #266
                                        @Saschag sagte in [Vorlage] Flexibles Timerskript + Vis:
                                        N komplettes Log wär schon hilfreich.
                                        • R Offline
                                          rotamint
                                          #267
                                          Hallo, guten Abend zusammen! Ich brauche bitte (mal wieder) Eure Hilfe. Ich habe den Aktor der Poolpumpe getauscht und einen neuen Namen vergeben. Die Timer haben sich nicht löschen lassen, daher habe ich in der Java-Instanz alles gelöscht ....
                                          Auch das Script habe ich neu installiert, auch wenn ich nicht wüsste, in welchem Zusammenhang es stehen sollte, dass ich immernoch folgende Meldung erhalte
                                          Sonoff.0.Poolpumpe war der alte Aktor, der existiert nicht mehr, und ich bin der Meinung, ich habe auch alles entsprechend gelöscht.
                                          Wer hat eine Idee, wo der Fehler versteckt sein könnte?
                                          Danke für Eure Hilfe!
                                          Schönen Abend, Gruß Stefan.
