  4. Nur 1x Update Adapter möglich
update adapter
22 Beiträge 4 Kommentatoren 2.6k Aufrufe 3 Beobachtet
    Thaibodo
    schrieb am zuletzt editiert von Thaibodo
    Danke für den Hinweis. Ich bin lernfähig. ;-)
    pi@raspbi-iobroker:/opt/iobroker $ apt policy grafana
    grafana:
      Installed: 6.6.2
      Candidate: 6.6.2
      Version table:
     *** 6.6.2 100
         2.6.0+dfsg-3+b1 500
    Grafana läuft gar nicht mehr auf dem Rasbi. Hat nicht funktioniert. Wie bekomme ich das weg?
    Und gibt es eine Möglichkeit, die Paketdatenbank zu erneuern?
    Sorry für sie vielen Fragen.
    ioBroker auf Raspi 4
      Thaibodo
      Ich glaube, da hat sich nichts geändert.
      pi@raspbi-iobroker:/ $ sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-dev
      Reading package lists... Done
      Building dependency tree
      build-essential is already the newest version (12.6).
      You might want to run 'apt --fix-broken install' to correct these.
      The following packages have unmet dependencies:
       grafana : Depends: libfontconfig1 but it is not going to be installed
       libcairo2-dev : Depends: libcairo2 (= 1.16.0-4+rpt1) but it is not going to be installed
                       Depends: libcairo-gobject2 (= 1.16.0-4+rpt1) but it is not going to be installed
                       Depends: libcairo-script-interpreter2 (= 1.16.0-4+rpt1) but it is not going to be installed
                       Depends: libfontconfig1-dev (>= 2.2.95) but it is not going to be installed
                       Depends: libx11-dev but it is not going to be installed
                       Depends: libxrender-dev (>= 0.6) but it is not going to be installed
                       Depends: libxext-dev but it is not going to be installed
                       Depends: libsm-dev but it is not going to be installed
                       Depends: libxcb1-dev (>= 1.6) but it is not going to be installed
                       Depends: libxcb-render0-dev (>= 1.6) but it is not going to be installed
                       Depends: libxcb-shm0-dev but it is not going to be installed
                       Depends: libglib2.0-dev but it is not going to be installed
       libgif-dev : Depends: libgif7 (= 5.1.4-3) but it is not going to be installed
       libjpeg-dev : Depends: libjpeg62-turbo-dev (>= 1:1.5.2-2) but it is not going to be installed
       libpango1.0-dev : Depends: gir1.2-pango-1.0 (= 1.42.4-8~deb10u1) but it is not going to be installed
                         Depends: libfontconfig1-dev (>= 2.11.91) but it is not going to be installed
                         Depends: libfribidi-dev (>= 0.19.7) but it is not going to be installed
                         Depends: libglib2.0-dev (>= 2.34.0) but it is not going to be installed
                         Depends: libharfbuzz-dev (>= 0.9.9) but it is not going to be installed
                         Depends: libpango-1.0-0 (= 1.42.4-8~deb10u1) but it is not going to be installed
                         Depends: libpangocairo-1.0-0 (= 1.42.4-8~deb10u1) but it is not going to be installed
                         Depends: libpangoft2-1.0-0 (= 1.42.4-8~deb10u1) but it is not going to be installed
                         Depends: libpangoxft-1.0-0 (= 1.42.4-8~deb10u1) but it is not going to be installed
                         Depends: libxft-dev but it is not going to be installed
                         Depends: libxrender-dev but it is not going to be installed
                         Depends: pango1.0-tools (= 1.42.4-8~deb10u1) but it is not going to be installed
       libpixman-1-dev : Depends: libpixman-1-0 (= 0.36.0-1+rpt1) but it is not going to be installed
       librsvg2-dev : Depends: gir1.2-rsvg-2.0 (= 2.44.10-2.1+rpi1) but it is not going to be installed
                      Depends: libgdk-pixbuf2.0-dev (>= 2.23.5-2) but it is not going to be installed
                      Depends: libglib2.0-dev (>= 2.24.0) but it is not going to be installed
                      Depends: librsvg2-2 (= 2.44.10-2.1+rpi1) but it is not going to be installed
                      Depends: librsvg2-common (= 2.44.10-2.1+rpi1) but it is not going to be installed
      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
      pi@raspbi-iobroker:/ $ cd /opt/iobroker
      pi@raspbi-iobroker:/opt/iobroker $ npm install canvas --unsafe-perm=true
      > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@10.21.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      Package pixman-1 was not found in the pkg-config search path.
      Perhaps you should add the directory containing `pixman-1.pc'
      to the PKG_CONFIG_PATH environment variable
      No package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.118-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v10.21.0
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.118-v7l+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v10.21.0
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the canvas@2.6.1 install script.
      npm ERR!     /home/iobroker/.npm/_logs/2020-07-23T15_17_51_827Z-debug.log
      • T Thaibodo
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        @Thaibodo
        Versuch mal mit
        sudo apt remove grafana
        Dann ein
        sudo apt update
        apt policy libcairo2
        Ausgabe zeigen...
          Thaibodo
          @Thomas-Braun sagte in Nur 1x Update Adapter möglich:
          Sorry für die Verzögerung, aber ich lebe in Thailand und bin euch zurzeit 5 Stunden voraus.
          pi@raspbi-iobroker:~ $ sudo apt remove grafana
          The following packages will be REMOVED:
            grafana
          0 upgraded, 0 newly installed, 1 to remove and 1 not upgraded.
          1 not fully installed or removed.
          After this operation, 103 MB disk space will be freed.
          Do you want to continue? [Y/n]
          perl: warning: Setting locale failed.
          perl: warning: Please check that your locale settings:
          	LANGUAGE = (unset),
          	LC_ALL = (unset),
          	LC_CTYPE = "UTF-8",
          	LANG = "de_DE.UTF-8"
              are supported and installed on your system.
          perl: warning: Falling back to a fallback locale ("de_DE.UTF-8").
          locale: Cannot set LC_CTYPE to default locale: No such file or directory
          locale: Kann LC_ALL nicht auf die Standard-Lokale einstellen: Datei oder Verzeichnis nicht gefunden
          (Reading database ... 47165 files and directories currently installed.)
          Removing grafana (6.6.2) ...
          pi@raspbi-iobroker:~ $ sudo apt update
          Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
          Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
          Get:3 https://deb.nodesource.com/node_10.x buster InRelease [4584 B]
          Get:4 https://repos.influxdata.com/debian buster InRelease [4731 B]
          Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
          Get:6 http://archive.raspberrypi.org/debian buster/main armhf Packages [330 kB]
          Get:7 https://repos.influxdata.com/debian buster/stable armhf Packages [929 B]
          Get:8 https://deb.nodesource.com/node_10.x buster/main armhf Packages [765 B]
          Fetched 13.4 MB in 14s (989 kB/s)
          16 packages can be upgraded. Run 'apt list --upgradable' to see them.
          pi@raspbi-iobroker:~ $ apt policy libcairo2
          libcairo2:
            Installed: (none)
            Candidate: 1.16.0-4+rpt1
            Version table:
               1.16.0-4+rpt1 500
                  500 http://archive.raspberrypi.org/debian buster/main armhf Packages
               1.16.0-4 500
          • T Thaibodo
              grafana
            	LANGUAGE = (unset),
            	LC_ALL = (unset),
            	LC_CTYPE = "UTF-8",
            libcairo2:
              Installed: (none)
              Version table:
                 1.16.0-4+rpt1 500
                 1.16.0-4 500
            @Thaibodo
            sudo apt update
            sudo apt dist-upgrade
            sudo reboot
            Und dann nochmal die ganzen Pakete:
            cd /opt/iobroker
              @Thaibodo
              sudo apt update
              sudo reboot
              cd /opt/iobroker
              Thaibodo
              @Thomas-Braun
              Hallo Thomas,
              ich verneige mich vor dir. Dank Deiner Geduld und Erklärung funktioniert es jetzt wieder. Vielen Dank.
              Ich wünsche dir ein sonniges Wochenende.
              Bodo
              • T Thaibodo
                @Thomas-Braun
                Hallo Thomas,
                Bodo
                @Thaibodo Ich würde den influx-Kram noch aus den Paketquellen löschen.
                Irgendwo in /etc/apt/sourceslist.d/ müsste es eine Datei geben, die einen Eintrag dazu hat. Die Zeilen dann mit # als erstem Zeichen in der Zeile auskommentieren.
                Und deine LOCALES würde ich auch vervollständigen.
                  Thaibodo
                  @Thomas-Braun
                  Hallo Thomas,
                  Influx benutze ich.
                  Bei den LOCALES bekomme ich auch Fehlermeldungen.
                  perl: warning: Falling back to the standard locale ("C").
                  Reloading keymap. This may take a short while
                  	LANGUAGE = (unset),
                  	LC_ALL = (unset),
                  	LC_CTYPE = "UTF-8",
                  Keine Ahnung, was er da von mir haben will.
                  • T Thaibodo
                    @Thomas-Braun
                    Hallo Thomas,
                    Influx benutze ich.
                    	LANGUAGE = (unset),
                    	LC_ALL = (unset),
                    	LC_CTYPE = "UTF-8",
                    @Thaibodo sagte in Nur 1x Update Adapter möglich:
                    are
                    Sorry, ich dachte der Influx-Kram sei für die zerbröselte grafana verantwortlich.
                    Wegen LOCALE:
                    https://www.thomas-krenn.com/de/wiki/Locales_unter_Ubuntu_konfigurieren
                    Funktioiert unter Raspberry OS / Debian genauso.
                      Thaibodo
                      Habe ich soweit alles gemacht, hat aber anscheinend nichts geändert.
                      pi@raspbi-iobroker:/etc/default $ ls
                      avahi-daemon   dbus                     locale              rpi-eeprom-update
                      bluetooth      fake-hwclock             networking          rsync
                      bsdmainutils   grafana-server.dpkg-new  nfs-common          rsyslog
                      console-setup  hwclock                  nss                 ssh
                      crda           influxdb                 raspberrypi-kernel  triggerhappy
                      cron           keyboard                 rng-tools           useradd
                      pi@raspbi-iobroker:/etc/default $ locale
                      LANG=de_DE.UTF-8
                      LANGUAGE=
                      LC_CTYPE=UTF-8
                      LC_NUMERIC="de_DE.UTF-8"
                      LC_TIME="de_DE.UTF-8"
                      LC_COLLATE="de_DE.UTF-8"
                      LC_MONETARY="de_DE.UTF-8"
                      LC_MESSAGES="de_DE.UTF-8"
                      LC_PAPER="de_DE.UTF-8"
                      LC_NAME="de_DE.UTF-8"
                      LC_ADDRESS="de_DE.UTF-8"
                      LC_TELEPHONE="de_DE.UTF-8"
                      LC_MEASUREMENT="de_DE.UTF-8"
                      LC_IDENTIFICATION="de_DE.UTF-8"
                      LC_ALL=
                      In der Datei LOCALE steht nur
                      LANG=de_DE.UTF-8
                      drin.
