  4. (Alexa Adapter) Cannot find module 'https-proxy-agent'
    6.7k
alexahttps-proxy-agenterror
31 Beiträge 7 Kommentatoren 4.9k Aufrufe 7 Beobachtet
  • moelskiM moelski
    Ja ist sauber installiert.
    Hat ja bis vor dem Update alles sauber gelaufen.
    @moelski
    Das es bislang lief heißt ja nix.
    Bei mir schaut das so aus:
    pi@raspberrypi:~$ cd /opt/iobroker/
    pi@raspberrypi:/opt/iobroker$ npm list http-proxy-agent
    iobroker.inst@2.0.3 /opt/iobroker
    ├─┬ iobroker.alexa2@3.2.8
    │ └─┬ virtual-device-sdk@1.7.3
    │   └── http-proxy-agent@4.0.1
    └─┬ iobroker.nuki-extended@2.2.6
      └─┬ npm@6.14.6
        └─┬ npm-registry-fetch@4.0.5
          └─┬ make-fetch-happen@5.0.2
            └── http-proxy-agent@2.1.0
    Was liefert denn
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    Unabhängig vom Ergebnis würde ich auf node12 updaten.
    • C Offline
      Chrischo
      bei mir erscheinen die gleichen Fehlermeldungen seit dem Update auf 3.2.8.
      host.raspberrypi	2020-07-17 13:46:15.780	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2020-07-17 13:46:15.779	error	Caught by controller[0]: }
      host.raspberrypi	2020-07-17 13:46:15.779	error	Caught by controller[0]: ]
      host.raspberrypi	2020-07-17 13:46:15.779	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.alexa2/main.js'
      host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js',
      host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js',
      host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: requireStack: [
      host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
      host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
      host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
      host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
      host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
      host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js:41:23)
      host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
      host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
      host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
      host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
      host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
      host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js
      host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js
      host.raspberrypi	2020-07-17 13:46:15.774	error	Caught by controller[0]: Require stack:
      host.raspberrypi	2020-07-17 13:46:15.774	error	Caught by controller[0]: Error: Cannot find module 'https-proxy-agent'
      host.raspberrypi	2020-07-17 13:46:15.774	error	Caught by controller[0]: ^
      host.raspberrypi	2020-07-17 13:46:15.773	error	Caught by controller[0]: throw err;
      host.raspberrypi	2020-07-17 13:46:15.773	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
      pi@raspberrypi:~ $ cd /opt/iobroker/
      pi@raspberrypi:/opt/iobroker $ npm list http-proxy-agent
      ├─┬ iobroker.unifi@0.5.5
      │ └─┬ node-unifi@1.3.3
      │   └─┬ snyk@1.346.0
      │     └─┬ proxy-agent@3.1.1
      │       ├── http-proxy-agent@2.1.0
      │       └─┬ pac-proxy-agent@3.0.1
      │         └── http-proxy-agent@2.1.0
      └─┬ iobroker.vis-weather@2.5.2
        └─┬ npm@6.14.5
          └─┬ npm-registry-fetch@4.0.4
      /usr/bin/nodejs
      v12.18.2
      /usr/bin/node
      v12.18.2
      /usr/bin/npm
      6.14.5
      nodejs:
        Installed: 12.18.2-1nodesource1
        Candidate: 12.18.2-1nodesource1
        Version table:
       *** 12.18.2-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main arm64 Packages
           10.21.0~dfsg-1~deb10u1 500
              500 http://deb.debian.org/debian-security buster/updates/main arm64 Packages
           10.19.0~dfsg1-1 500
              500 http://deb.debian.org/debian buster/main arm64 Packages
      Der Alexa Adapter lässt sich auch nicht mehr starten.
      Selbst bei einem Downgrade auf die ältere und zuvor funktionierende Version funktioniert nicht mehr und es kommen die gleichen Fehlermeldungen.
      Interessanter Weise hat das Update auf einem zweiten Raspi mit nahezu den gleichen Adaptern problemlos funktioniert. Beide Raspis sind aktuell.
      Vielleicht kann jemand helfen?
      Vielen Dank
        Bibo*13
        ich habe das gleiche Problem, nach Upgarde auf 3.2.8 startet die Instance nicht mehr.
        Gibt es da mittlerweile etwas Neues?
        • J Offline
          Jan1
          bei mir läuft es ohne Probleme, aber meine Ausgabe zu dem angemeckerten Modul sieht so aus:
          jan@Beelink:/opt/iobroker$ npm list http-proxy-agent
          └── (empty)
          Das ist bei mir gar nicht vorhanden, wobei ich es manuell finden kann:
          • moelskiM Offline
            moelskiM Offline
            moelski
            Ok hier die Ausgaben von ...
            /usr/bin/nodejs
            v10.20.1
            /usr/bin/node
            v10.20.1
            /usr/bin/npm
            6.14.4
            nodejs:
              Installed: 10.20.1-1nodesource1
              Candidate: 10.20.1-1nodesource1
              Version table:
             *** 10.20.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
                 4.8.2~dfsg-1 500
                    500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
            Und hier noch die Ausgabe von dem npm Aufruf:
            dominik@SHome-IoBroker:~$ cd /opt/iobroker/
            dominik@SHome-IoBroker:/opt/iobroker$ npm list http-proxy-agent
            [sudo] password for dominik:
            └─┬ iobroker.alexa2@3.2.8
            Grüße Dominik
            Grüße Dominik
            • moelskiM moelski
              /usr/bin/nodejs
              v10.20.1
              /usr/bin/node
              v10.20.1
              /usr/bin/npm
              6.14.4
              nodejs:
                Version table:
                   4.8.2~dfsg-1 500
              Grüße Dominik
              @moelski
              Wenn beim Aufruf von npm im Verzeichnis /opt/iobroker nach dem sudo Passwort gefragt wird dürfte da irgendwas mit den Rechten für die User nicht stimmen.
              Jag mal den
              iobroker fix
              durch.
              Und ich würde an deiner Stelle den Absprung von Stretch planen. Je länger du das rauszögerst, umso komplizierter kann das werden.
              • moelskiM Offline
                moelskiM Offline
                moelski
                Moin !
                fix durchgeführt:
                    Checking ioBroker user and directory permissions (2/3)
                    Checking autostart (3/3)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                dominik@SHome-IoBroker:/opt/iobroker$ iobroker start
                dominik@SHome-IoBroker:/opt/iobroker$ iobroker fix^C
                Aber der Fehler mit dem Alexa bleibt leider immer noch.
                Stretch Update ... Hmm, ok da müsste ich dann wohl demnächst mal ran ...
                Grüße Dominik
                  mrzee
                  Bei mir ist es das gleiche.
                  System ist jedoch Ubuntu - nach dem letzten Update bekomme ich die gleichen Fehlermeldungen und stelle fest, dass der Pfad, auf den das Log verweist, gar nicht existiert.
                  Gleichmaßen kann ich den http-proxy-agent aber auch nicht neuinstallieren.
                  • M mrzee
                    @mrzee Für Ubuntu gelten die gleichen Anmerkungen zu nodejs wie zu Debian.
                      mrzee
                      schrieb am zuletzt editiert von mrzee
                      @Thomas-Braun
                      Danke - ich komme mit den ganzen Distris immer durcheinander. Ich habe das Problem aber gefunden:
                      Scheinbar wurde bei einem Update, entweder Adapter oder OS, das Verzeichnis /opt/iobroker/node_modules/https-proxy-agent wie auch immer beschädigt. Eine manuelle Neuinstallation via NPM hat funktioniert und der Adapter läuft wieder.
                        Bibo*13
                        Hi wunderbar das das Problem gefunden wurde.
                        Leider bin ich etwas unbedart und weiß nicht wie ich den fehlenden http-proxy-agent fixen soll.
                        Kann mir bitte jemand da auf die Sprünge helfen.
                        • C Offline
                          Chrischo
                          Würde mich auch interessieren. Habe den fixer laufen lassen - hat aber nicht geholfen. Habe die Instanz und den kompletten Adapter deinstalliert und anschließend neu installiert - leider auch keine Besserung. Das ist aber wirklich sehr ärgerlich.
                          • C Offline
                            Chrischo
                            Dabei bleibt´s dann stehen und der Adapter startet nicht.
                            • C Chrischo
                              @Chrischo Und was sagt das Log? Und ist nodejs sauber?
                              C 1 Antwort Letzte Antwort
                                Chrischo
                                @Thomas-Braun
                                nicht viel Neues :-(
                                host.raspberrypi	2020-07-19 14:20:20.839	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.raspberrypi	2020-07-19 14:20:20.839	error	Caught by controller[0]: }
                                host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: ]
                                host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.alexa2/main.js'
                                host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js',
                                host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js',
                                host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: requireStack: [
                                host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
                                host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                                host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                                host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                                host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                                host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js:41:23)
                                host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                                host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
                                host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                                host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                                host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
                                host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js
                                host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js
                                host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: Require stack:
                                host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: Error: Cannot find module 'https-proxy-agent'
                                host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: ^
                                host.raspberrypi	2020-07-19 14:20:20.834	error	Caught by controller[0]: throw err;
                                host.raspberrypi	2020-07-19 14:20:20.834	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
                                • C Chrischo
                                  @Thomas-Braun
                                  @Chrischo nodejs sauber?
                                    Chrischo
                                    @Thomas-Braun wie überprüfe ich die "Sauberkeit"?
                                    Augenscheinlich macht es keine Probleme.
                                    • C Chrischo
                                      @Chrischo
                                        @Chrischo
                                        Chrischo
                                        @Thomas-Braun
                                        pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                        /usr/bin/nodejs
                                        v12.18.2
                                        /usr/bin/node
                                        v12.18.2
                                        /usr/bin/npm
                                        6.14.5
                                        nodejs:
                                          Version table:
                                             10.19.0~dfsg1-1 500
                                        Das hatte ich aber bereits weiter oben im Beitrag schon gepostet.
                                        • C Chrischo
                                          @Thomas-Braun
                                          /usr/bin/nodejs
                                          v12.18.2
                                          /usr/bin/node
                                          v12.18.2
                                          /usr/bin/npm
                                          6.14.5
                                          nodejs:
                                            Version table:
                                               10.19.0~dfsg1-1 500
                                          @Chrischo Passt. Dann installier den Adapter nochmals frisch neu
