  4. JavaScript
  5. E3DC Hauskraftwerk steuern
    1.0k
3.6k Beiträge 73 Kommentatoren 2.2m Aufrufe 64 Beobachtet
  • A ArnoD
    ok , habe es jetzt auch gesehen.
    Die Zeile wäre so richtig:
    createUserStates(instanz, false, statesToCreate, function(){log('Jetzt sind alle States abgearbeitet');});
    Habe da mal was Versucht und vergessen wieder die richtige Variable einzutragen.
    Fehler ist in Version 0.1.13 dann behoben.
    smartboartS Offline
    smartboartS Offline
    smartboart
    #66
    @ArnoD hab noch nen Fehler im Log...
    nachdem ich den State angelegt hatte wars gut..
    sagt dir das was?
    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at processImmediate (internal/timers.js:456:21)
    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.1	2020-07-12 17:53:42.365	warn	(1767) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1987:5)
    javascript.1	2020-07-12 17:53:42.365	warn	(1767) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    javascript.1	2020-07-12 17:53:42.364	warn	(1767) You are assigning a object to the state "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON" which expects a string. Please fix your code to use a string or change the state type to object
    javascript.1	2020-07-12 17:53:42.360	warn	(1767) at processImmediate (internal/timers.js:456:21)
    javascript.1	2020-07-12 17:53:42.360	warn	(1767) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.1	2020-07-12 17:53:42.360	warn	(1767) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.1	2020-07-12 17:53:42.359	warn	(1767) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.1	2020-07-12 17:53:42.359	warn	(1767) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1985:22)
    javascript.1	2020-07-12 17:53:42.353	warn	(1767) getState "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON_00" not found (3)
    S A 2 Antworten Letzte Antwort
    • A ArnoD
      Ich habe es unter dem Pfad: /home/iobroker/E3DC-Control/
      installiert.
      smartboartS Offline
      smartboartS Offline
      smartboart
      schrieb am zuletzt editiert von smartboart
      #67
      @ArnoD sagte in E3DC Hauskraftwerk steuern:
      installiert.
      kurze Frage noch dazu...Hast du nur die config Datei oder alles dort installiert?
      ich habe alles da rein installiert und musste dennoch mit
      sudo chmod 666 e3dc.config.txt Schreibrechte vergeben, damit das Script die Datei beschreiben konnte...
      sieht so aus bei mir...
      • smartboartS smartboart
        sagt dir das was?
        stevie77
        #68
        @smartboart Den habe ich auch...
        • S stevie77
          smartboartS Offline
          smartboartS Offline
          smartboart
          #69
          @stevie77 sagte in E3DC Hauskraftwerk steuern:
          Was? den Fehler im log?
            stevie77
            #70
            @smartboart Äh, ja, sorry, in diesem komischen Forum gehen die Zusammenhänge ja immer flöten weil es schlecht lesbar ist. Ja, ich meinte den Fehler im Log, den habe ich auch...
            • S stevie77
              smartboartS Offline
              smartboartS Offline
              smartboart
              #71
              @stevie77 ok, dann wird arno sicher was finden...Ich habe den State manuell angelegt , dann taucht das nicht mehr im log auf.
              Musstest du auch Schreibrechte für die Config vergeben und hast du auch komplett E3DC Control unter iobroker abgelegt?
                stevie77
                #72
                @smartboart Ich bin nicht so fit mit ioBroker, aber vielleicht probiere ich das auch mal so nen State anzulegen. Weiß nur nicht, ob das dann nicht weitere Fehler verdeckt (wo vielleicht auch noch was fehlt oder so).
                Bei mir laufen ioBroker und E3DC-Control in zwei separaten fertigen Docker-Containern und ich habe ein Verzeichnis /home/iobroker/e3dc-config-transfer innerhalb des ioBroker-Containers auf das Konfigurationsverzeichnis des E3DC-Control-Docker-Containers auf dem Host gemappt. Schreibt der ioBroker die Konfigurationsdatei in dieses Verzeichnis, dann landet sie automatisch im Konfigurationsverzeichnis von E3DC-Control.
                Rechte musste ich keine vergeben, weil der ioBroker-Benutzer unter /home/iobroker wohl von Haus aus alle Rechte besitzt.
                  sagt dir das was?
                  ArnoD
                  #73
                  @smartboart sagte in E3DC Hauskraftwerk steuern:
                  Diesen State sollte es auch nicht geben.
                  Was bedeutet das irgendwo im Script versucht wird, auf den State "HistoryJSON_00" zuzugreifen.
                  Muss ich prüfen.
                  Komisch ist nur das bei mir der Fehler nicht auftritt.
                    installiert.
                    ArnoD
                    #74
                    installiert.
                    Habe auch alles dort intalliert und musste auch die rechte manuell neu vergeben.
                    • A ArnoD
                      installiert.
                      smartboartS Offline
                      smartboartS Offline
                      smartboart
                      #75
                      @ArnoD ok danke....dann bin ich beruihgt..
                        ArnoD
                        #76
                        Kann es sein das du in Vis ein Widget verwendest, um die Monate im Diagramm zu wechseln, und dort mit 0 beginnst für Januar ?
                        Habe mir das einfach gemacht und 1 für Januar bis 12 für Dezember verwendet.
                        Ich kann im Script 0 ignorieren, dann wird aber der Januar bei dir nicht angezeigt :-)
                        • A ArnoD
                          smartboartS Offline
                          smartboartS Offline
                          smartboart
                          #77
                          @ArnoD soweit bin ich noch garnicht...
                          Ich habe meine vis noch nicht erstellt.
                          Das passiert bei mir( Fehler im log ) bei script neustart.
                          • smartboartS Offline
                            smartboartS Offline
                            smartboart
                            #78
                            vlt. hilft das,
                            nachdem ich den state angelegt habe sieht mein restart log nun so aus..
                            javascript.1	2020-07-12 19:23:51.794	info	(1840) script.js.common.PVAnlage.E3DCS10EPro: HistoryJSON_00 wurde unter HistoryJSON gespeichert
                            javascript.1	2020-07-12 19:23:51.787	info	(1840) script.js.common.PVAnlage.E3DCS10EPro: Jetzt sind alle States abgearbeitet
                            javascript.1	2020-07-12 19:23:51.776	info	(1840) script.js.common.PVAnlage.E3DCS10EPro: registered 5 subscriptions and 6 schedules
                            javascript.1	2020-07-12 19:23:51.763	info	(1840) script.js.common.PVAnlage.E3DCS10EPro: Schedule Automatik gestartet
                            javascript.1	2020-07-12 19:23:51.757	info	(1840) script.js.common.PVAnlage.E3DCS10EPro: JSON History ertellt
                            javascript.1	2020-07-12 19:23:51.717	info	(1840) Start javascript script.js.common.PVAnlage.E3DCS10EPro
                              vlt. hilft das,
                              ArnoD
                              #79
                              @smartboart
                              Ok, fehler gefunden.
                              Habe als Standard definition bei der Erstellung des State HistorySelect 0 eingetragen, was natürlich 1 sein muss.
                              Habe den Fehler korrigiert.
                              Bitte im State HistorySelect 1 eintragen, dann sollte die Meldung weg sein.
                              • A ArnoD
                                @smartboart
                                smartboartS Offline
                                smartboartS Offline
                                smartboart
                                #80
                                @ArnoD ok super also im script auf def 1
                                [PfadEbene1 + PfadEbene2[2] + 'HistorySelect', {'def':1, 'name':'Select Menü für materialdesign json chart' ,'type':'number'}],
                                  stevie77
                                  #81
                                  @ArnoD Ich hätte noch grundsätzliche Verständnisfragen. Sorry. :-)
                                  1. Ich hab das JavaScript nun auf 0.1.13 aktualisiert und das TypeScript angelegt. Wenn ich probehalber die im Kommentar verlinkte View E3DC-Control: Stand 25.06.2020 importiere, dann ist da kein Automatik-Button. Aber egal, kann ich quasi kopieren von z.B. "Daten anlegen" und auf den State 0_userdata.0.E3DC-Control.Allgemein.Automatik verknüpfen und den dann irgendwie true oder false setzen. Mehr macht der nicht, ne? Oder braucht man da ne Art Toggle-Button in Vis, weil die anderen beiden Daten nur ne Funktion aufrufen?
                                  2. Nur wenn 0_userdata.0.E3DC-Control.Allgemein.Automatik = true läuft das ganze Zeug um die Wettervorhersage an, richtig? Das würde dann vermutlich erklären, warum 0_userdata.0.E3DC-Control.Allgemein.PrognoseBerechnung_kWh_heute, 0_userdata.0.E3DC-Control.Allgemein.PrognoseFore_kWh_heute und 0_userdata.0.E3DC-Control.Allgemein.PrognoseProb_kWh_heute momentan alle auf 0 kWh stehen?
                                    0_userdata.0.E3DC-Control.Allgemein.Prognose_1 bis 4 haben allerdings Werte...
                                  3. Die Einstellungen 1-5 werden in der View nur angezeigt, wenn 0_userdata.0.E3DC-Control.Allgemein.Automatik = true? Sie sind nicht für die manuelle Auswahl gedacht, sondern nur in Verbindung mit der Wettervorhersage, ne?
                                    Wenn Automatik = true wird auch automatisch die Konfigurationsdatei von E3DC-Control (morgens irgendwann) erstellt, korrekt?
                                    Der nächste Schritt wäre jetzt also hier true einzustellen (erst mal direkt in den States mangels Button) und sehen, ob morgen Prognosewerte kommen und ob irgendwas von Einstellung 1-5 aktiv wird...
                                  4. Die View Prognose: Stand 02.07.2020 ist nur für die Auswertung und nicht erforderlich für die Wettervorhersage und aktive Steuerung von E3DC-Control? Bis auf die Überschrift bleibt die momentan komplett leer, was aber wohl an fehlenden Vorhersagedaten liegt und dass ich History und das andere Teil noch irgendwie zum Speichern der Daten verleiten muss (wie weiter unten kürzlich erwähnt).
                                  Nebenbei: Irgendwie witzig, es werden immer mehr Steuerungen...erst nur das Hauskraftwerk, dann wurde das von E3DC-Control gesteuert und nun ist E3DC-Control selbst auch fremdbestimmt durch ioBroker. ;-)
                                    ArnoD
                                    #82
                                    Wenn du es im Script machst musst du den State HistorySelect löschen und neu erstellen lassen oder du änderst diesen auch manuell auf 1.
                                    Den State HistoryJSON_00 kannst du dann auch wieder löschen :)
                                    • S stevie77
                                      ArnoD
                                      #83
                                      @stevie77
                                      zu 1: Kanst du dann die anderen beiden Widgets (materialdesign-Switch) HTsat und HTsun in deiner View sehen ?
                                      Kann es sein das bei dir der Adapter Material Design Widgets nicht installiert ist ?
                                      zu 2: Ja richtig, wenn Automatik auf false ist, werden keine Prognosen und Automatische Auswahl der Einstellungen benötigt. Werde ich aber noch ändern, so das immer die Prognosewerte gespeichert werden und nur die Einstellungen nicht geändert werden. Die State Prognose_1 bis 4 enthalten die Werte je Dachfläche in W von Forecast, diese werden bereits jetzt schon immer abgerufen.
                                      zu3: Ja richtig. Bitte aber vorher die Richtigen Werte im Script eintragen für die Einstellung 1-5
                                      zu4: Die View wird nur zur Visualisierung benötig.
                                      Ja, deswegen bin ich gerade dabei die RSCP Schnittstelle in Javascript nachzubauen. Scheitere aber immer noch an der AES Verschlüsselung die aber generell von Javascript unterstütz wird. Habe ja noch Zeit bis zu meiner Rente :-)
                                      S smartboartS 2 Antworten Letzte Antwort
                                      • A ArnoD
                                        @stevie77
                                        stevie77
                                        #84
                                        Danke für die Hilfe!
                                        Hast natürlich Recht! Mist, den habe ich irgendwie übersehen. 👓
                                        Nach der Adapterinstallation war der Adapter web.0 plötzlich rot und Vis ging dadurch auch nicht mehr 😨, aber nach Reload war alles wieder da. Nun auch mit den fehlenden 3 Elementen. Super.
                                        By the way, sieht man in Vis irgendwo in den Angaben (rechte Leiste), was für ein Widget das ist und aus welchem Adapter es kommt? Ich muss mir immer die Namen aufschreiben, damit ich das in der Leiste links wieder finde, falls ich nochmal eines davon brauche (oder halt durch kopieren)...ioBroker-Anfänger halt... 👶
                                        Das wäre cool. Dann muss man nicht sofort aufs Ganze gehen (ich habe z.B. die ganzen Werte für die 5 Einstellungen noch nicht durchschaut), kann aber trotzdem schon mal vergleichen, ob die Werte ungefähr hinkommen würden. Dachfläche 1 war heute weit daneben (muss ich sicherheitshalber auch nochmals nachrechnen), während Dachfläche 2 ganz gut getroffen wurde.
                                        Ja, da will ich gerade nicht ran. ;-) Mir fällt es irgendwie schwer zu verstehen, wie die Fälle genau gemeint sind und wie sie dann an meine Anlagen anzupassen wären. Naja, mal sehen...
                                        Was bedeutet das? Du willst langfristig ohne E3DC-Control auskommen und direkt vom ioBroker aus per Javascript das Hauskraftwerk steuern?
                                        • S stevie77
                                          ArnoD
                                          #85
                                          Wenn du das Widget im Vis Editor markierst, kannst du den Namen links oben in der Leiste im Reiter Widgets ablesen.
                                          Ja das wäre mein Ziel, denn nur so kann man das Ganze in einen Adapter integrieren, was die ganze Sache natürlich einfacher macht.
                                          Mann hätte auch mehr Möglichkeiten die einzelnen Werte abzurufen und zu ändern und benötigt auch den Modbus Adapter nicht mehr.
