  4. Iobroker startet nicht mehr im webbrowser
iobroker startet nicht mehriobroker startet nicht
23 Beiträge 5 Kommentatoren 2.4k Aufrufe 4 Beobachtet
  • d S.D d S.
    @Thomas-Braun danke für den Hinweis.
    pi@raspberrypi:/opt/iobroker $ iobroker list instances
     system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0                       .0, run as: admin
     system.adapter.backitup.0              : backitup              -  enabled
     system.adapter.ble.0                   : ble                   -  enabled
     system.adapter.broadlink2.0            : broadlink2            -  enabled
     system.adapter.cloud.0                 : cloud                 -  enabled
     system.adapter.daswetter.0             : daswetter             -  enabled
     system.adapter.discovery.0             : discovery             -  enabled
     system.adapter.dwd.0                   : dwd                   -  enabled
     system.adapter.ham.0                   : ham                   -  enabled
     system.adapter.info.0                  : info                  -  enabled
     system.adapter.javascript.0            : javascript            -  enabled
     system.adapter.lightify.0              : lightify              - disabled
     system.adapter.milight-smart-light.0   : milight-smart-light   - disabled
     system.adapter.ping.0                  : ping                  -  enabled
     system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
     system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
     system.adapter.vis.0                   : vis                   -  enabled
     system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0                       .0, run as: admin
     system.adapter.zigbee.0                : zigbee                - disabled
    + instance is alive
    pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.admin/admin.js --logs
    internal/modules/cjs/loader.js:638
       throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.admin/admin.js'
       at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
       at Function.Module._load (internal/modules/cjs/loader.js:562:25)
       at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
       at startup (internal/bootstrap/node.js:283:19)
       at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    pi@raspberrypi:/opt/iobroker $  find module '/opt/iobroker/node_modules/iobroker.admin/admin.js'
    find: ‘module’: Datei oder Verzeichnis nicht gefunden
    find: ‘/opt/iobroker/node_modules/iobroker.admin/admin.js’: Datei oder Verzeichnis nicht gefunden
    @d-S
    Es fällt auf, dass keine Instanz "alive" ist. Starte mal den ioBroker.
    d S.D 1 Antwort Letzte Antwort
      @d-S
      d S.D Offline
      d S.D Offline
      d S.
      @paul53 habe ich gemacht.
      cd C:\ioBroker
      iobroker start
      Aber beim Aufrufen vom Iobroker über die Webseite lädt es nur die ganze Zeit.
      • d S.D d S.
        cd C:\ioBroker
        iobroker start
        @d-S
        Wat nu? Oben bist du auf einem Linux unterwegs, der letzte post ist von einem Windows
        • d S.D Offline
          d S.D Offline
          d S.
          @Thomas-Braun @paul53 ich habe jetzt auf dem raspberry pi 3b+ den iobroker gestoppt. Dadurch läuft der raspberry auf jeden Fall schon einmal viel schneller als vorher. Ich habe eher die Vermutung, dass der iobroker (wie auch immer??) den Speicher belegt. Die SD-Karte im raspberry ist 32GB groß. Kennt ihr Möglichkeiten um das zu beheben? Grüße und Danke im Voraus
          • d S.D d S.
            @d-S
            who -r
              @d-S
              who -r
              d S.D Offline
              d S.D Offline
              d S.
              schrieb am zuletzt editiert von d S.
              @Thomas-Braun die Antwort ist:
              Runlevel 5 2020-07-01 20:15
              • d S.D d S.
                @d-S Hätte ich drauf wetten können.
                Server betreibt man im Runlevel 3, ohne Desktop. Grundsätzlich.
                Insbesondere aber so schmalbrüstige wie den Raspberry.
                  d S.D Offline
                  d S.D Offline
                  d S.
                  @Thomas-Braun Dankeschön. Habe es jetzt auf Runlevel 3 umgestellt und reboot durchgeführt. Allerdings kann ich immer noch keine Verbindung über (MeineIP:8081) zum Iobroker aufbauen. Die Seite lädt nur und eine Kreisel erscheint, mehr aber nicht.
                  • d S.D d S.
                    @d-S
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    Poste mal die komplette Eingabezeile mit.
                      @d-S
                      d S.D Offline
                      d S.D Offline
                      d S.
                      @Thomas-Braun
                      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which n                       pm && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      v12.18.2
                      /usr/bin/node
                      v12.18.2
                      /usr/bin/npm
                      6.14.5
                      nodejs:
                        Installiert:           12.18.2-1nodesource1
                        Installationskandidat: 12.18.2-1nodesource1
                        Versionstabelle:
                       *** 12.18.2-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                           10.21.0~dfsg-1~deb10u1+rpi1 500
                      pi@raspberrypi:~ $
                      Das kommt als Antwort.
                      • d S.D Offline
                        d S.D Offline
                        d S.
                        @Thomas-Braun Habe es jetzt geschafft, wieder die Verbindung herzustellen und sehe meine Adapter. Allerdings läuft es alles noch sehr sehr langsam. Gibt es eine Möglichkeit zu prüfen woran es liegt?
                        • d S.D d S.
                          @Thomas-Braun
                          /usr/bin/nodejs
                          v12.18.2
                          /usr/bin/node
                          v12.18.2
                          /usr/bin/npm
                          6.14.5
                          nodejs:
                            Versionstabelle:
                          pi@raspberrypi:~ $
                          @d-S Okay, das passt.
                          iobroker start all
                          bringt?
                          • d S.D d S.
                            @d-S Schau ins Log. Da könnten Meldungen laufen.
                              d S.D Offline
                              d S.D Offline
                              d S.
                              @Thomas-Braun
                              2020-07-01 21:38:25.388 - info: admin.0 (1082) received all objects
                              2020-07-01 21:38:27.204 - info: admin.0 (1082) http server listening on port 8081
                              2020-07-01 21:38:27.206 - info: admin.0 (1082) Use link "http://localhost:8081" to configure.
                              2020-07-01 21:38:32.004 - info: vis.0 (1233) starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:38:33.421 - info: vis.0 (1233) vis license is OK.
                              2020-07-01 21:38:43.010 - info: discovery.0 (1140) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:39:17.630 - info: vis.0 (1233) Terminated (NO_ERROR): Without reason
                              2020-07-01 21:39:29.845 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                              2020-07-01 21:39:52.191 - info: ham.0 (1266) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:39:52.273 - info: ham.0 (1266) No additional Libraries to install ...
                              2020-07-01 21:39:54.687 - info: broadlink2.0 (1268) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:40:10.813 - warn: host.raspberrypi instance system.adapter.dwd.0 already running with pid 1247
                              2020-07-01 21:40:16.087 - info: broadlink2.0 (1268) broadlink2 initialization started...
                              2020-07-01 21:40:16.088 - info: javascript.0 (1199) starting. Version 4.6.17 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:40:16.098 - info: ping.0 (1278) starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.ping, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:40:16.105 - info: broadlink2.0 (1268) Devices to add: []
                              2020-07-01 21:40:16.115 - info: broadlink2.0 (1268) Devices to rename:
                              2020-07-01 21:40:16.493 - info: javascript.0 (1199) requesting all states
                              2020-07-01 21:40:16.498 - info: javascript.0 (1199) requesting all objects
                              2020-07-01 21:40:26.161 - info: ble.0 (1240) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:40:32.603 - info: broadlink2.0 (1268) UDP socket listening on 0.0.0.0:15001
                              2020-07-01 21:40:32.607 - info: broadlink2.0 (1268) Discover Broadlink devices for 10sec on broadlink2.0
                              2020-07-01 21:40:54.556 - info: web.0 (1186) starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:41:17.349 - info: broadlink2.0 (1268) Device RM:0x27a9_78:0f:77:63:1e:4c dedected: address=192.168.2.119, mac=78:0f:77:63:1e:4c, typ=rmp, id=0x27a9 devtype=RM3 Pro Plus
                              2020-07-01 21:41:17.391 - info: javascript.0 (1199) received all states
                              2020-07-01 21:41:18.740 - info: ble.0 (1240) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                              2020-07-01 21:41:19.440 - info: web.0 (1186) socket.io server listening on port 8082
                              2020-07-01 21:41:19.448 - info: web.0 (1186) http server listening on port 8082
                              2020-07-01 21:41:18.752 - info: ble.0 (1240) enabled plugins: _default
                              2020-07-01 21:41:18.755 - info: ble.0 (1240) monitored services:
                              2020-07-01 21:41:22.515 - info: javascript.0 (1199) received all objects
                              2020-07-01 21:42:06.414 - error: dwd.0 (1247) uncaught exception: adapter.stop is not a function
                              2020-07-01 21:42:06.448 - error: dwd.0 (1247) TypeError: adapter.stop is not a function
                              at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.dwd/main.js:241:24)
                              at listOnTimeout (internal/timers.js:549:17)
                              at processTimers (internal/timers.js:492:7)
                              2020-07-01 21:42:07.541 - info: broadlink2.0 (1268) broadlink2.0 started and found 1 devices named 'RM:0x27a9_78:0f:77:63:1e:4c'.
                              2020-07-01 21:42:07.826 - warn: dwd.0 (1247) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2020-07-01 21:42:07.873 - info: dwd.0 (1247) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:42:07.884 - info: backitup.0 (1170) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:42:07.886 - info: cloud.0 (1192) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.18.2, js-controller: 3.1.4
                              2020-07-01 21:42:09.834 - info: backitup.0 (1170) [iobroker] backup was activated at 02:00 every 1 day(s)
                              2020-07-01 21:42:09.857 - error: host.raspberrypi instance system.adapter.dwd.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2020-07-01 21:42:09.966 - info: javascript.0 (1199) Start javascript script.js.JS.Tageszeiten
                              2020-07-01 21:42:10.174 - error: backitup.0 (1170) Error: Command failed: mount :/sharename/backupDir /opt/iobroker/backups
                              mount: only root can do that
                              2020-07-01 21:42:10.193 - warn: javascript.0 (1199) Cannot calculate "night" for 52.482213, 13.285827
                              2020-07-01 21:42:10.196 - warn: javascript.0 (1199) Cannot calculate "nightEnd" for 52.482213, 13.285827
                              2020-07-01 21:42:10.199 - warn: javascript.0 (1199) Cannot calculate "night" for 52.482213, 13.285827
                              2020-07-01 21:42:10.231 - info: javascript.0 (1199) script.js.JS.Tageszeiten: registered 0 subscriptions and 9 schedules
                              2020-07-01 21:42:10.233 - info: javascript.0 (1199) Start javascript script.js.Balkon.Balkon_v2
                              2020-07-01 21:42:10.257 - info: javascript.0 (1199) script.js.Balkon.Balkon_v2: 21:42:10
                              2020-07-01 21:42:10.260 - info: javascript.0 (1199) script.js.Balkon.Balkon_v2: 21:29:20
                              2020-07-01 21:42:10.267 - info: javascript.0 (1199) script.js.Balkon.Balkon_v2: registered 1 subscription and 1 schedule
                              2020-07-01 21:42:11.101 - warn: cloud.0 (1192) Pleas use ioBroker.iot for alexa control
                              2020-07-01 21:42:11.108 - info: cloud.0 (1192) Connecting with https://iobroker.net:10555 with "dschob@gmx.net_41333930-a5ae-11ea-8844-77957c72f20a"
                              Das ist die Ausgabe vom Log-File.
                              • d S.D d S.
                                @Thomas-Braun
                                @d-S Soweit nix auffälliges bezüglich der Performance.
                                Nutzt du noch den cloud Adapter? Der ist eigentlich obsolet.
                                Beim Backitup scheint es Probleme mit dem mounten des NAS zu geben.
                                metaxaM HomoranH 2 Antworten Letzte Antwort
                                  metaxaM Online
                                  metaxaM Online
                                  metaxa
                                  schrieb am zuletzt editiert von metaxa
                                  @Thomas-Braun sagte in Iobroker startet nicht mehr im webbrowser:
                                  Ich mus du kurz reingrätschen ... wieso obsolet? Ich nutze diesen um von extern auf meinen admin oder float oder iQontrol zuzugreifen. Habe ich da etwas verschlafen?
                                  • metaxaM metaxa
                                    @metaxa Soll ja vom iot übernommen werden, soweit ich das weiß. Für Alexa ist das ja z. B schon so umgesetzt worden. Deswegen ja meine Frage, ob der noch für ggf. andere Dinge genutzt wird.
                                    metaxaM 1 Antwort Letzte Antwort
                                      metaxaM Online
                                      metaxaM Online
                                      metaxa
                                      @Thomas-Braun iot --> sehe ich nicht als Grundlage von "bezahlten Fernzugriff" meiner Applikationen. Alexa & Co vermeide ich wo geht. Drehe ich den bezahlten cloud pro ab, komm ich nicht mehr einfach (ohne extra vpn zu öffnen) auf meine Websides. So gesehen, alles gut :-)
                                      Schönen Abend aus dem gewittrigen Wien
                                      mxa
                                      • metaxaM metaxa
                                        mxa
                                        @metaxa Jo, alles gut.
                                          Stimmt so nicht!
                                          iot für Assistenten
                                          Cloud für fernzugriff
