  4. Material Design Widgets: Calendar Widget
    apollon77A
vis
201 Beiträge 46 Kommentatoren 62.0k Aufrufe 53 Beobachtet
  • A
    A
    AndreasHeins
    schrieb am zuletzt editiert von AndreasHeins
    Hallo und danke für den Tip.
    Falls noch jemand, so wie ich mit Events im ical Kalender arbeitet, hier mein angepasstes Script. So prüfe ich bei der Kalenderhintergrundfarbe den Kalender- oder Eventnamen.
    // momentjs is required as dependecies in javascript adapter
    const moment = require("moment");
    var instances = $(`[id=ical.*.data.table]`);
    instances.on(ical2CalendarWidget);
    // remove this, if you know to use your own datapoint
    let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
    createState(datapointId, "[]", {
      read: true,
      write: false,
      desc: "JSON String for Calendar Widget",
      type: "string",
      def: "[]"
    function ical2CalendarWidget() {
        try {
            let calList = [];
            for (var inst = 0; inst <= instances.length - 1; inst++) {
                let icalObj = getState(instances[inst]).val;
                if (icalObj) {
                    for (var i = 0; i <= icalObj.length - 1; i++) {
                        let item = icalObj[i];
                        // extract calendar color
                        let calendarName = item._class.split(' ')[0].replace('ical_', '');
                        let startTime = moment(item._date);
                        let endTime = moment(item._end);
                        let start = startTime.format("YYYY-MM-DD HH:mm");
                        let end = endTime.format("YYYY-MM-DD HH:mm");
                        if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                            // is full-day event
                            if (endTime.diff(startTime, 'hours') === 24) {
                                // full-day event, one day
                                start = startTime.format("YYYY-MM-DD");
                                end = startTime.format("YYYY-MM-DD");
                            } else {
                                // full-day event, multiple days
                                end = endTime.format("YYYY-MM-DD");
                        // create object for calendar widget
                        calList.push({
                            color: getMyCalendarColor(item.event,calendarName),
                            colorText: getMyCalendarTextColor(calendarName),
                            start: start,
                            end: end
                    function getMyCalendarColor(event,calendarName) {
                        // assign colors via the calendar names, use calendar name or Event names as set in ical
                        if (calendarName === 'Hausmüll' || event === 'Hausmüll') {
                            return '#DEB887';
                        if (calendarName === 'Papiertonne' || event === 'Papiertonne') {
                            return '#0080FF';
                        if (calendarName === 'Gelber Sack' || event === 'Gelber Sack') {
                            return '#FFFF00';
                        if (calendarName === 'Geburtstage' || event === 'Geburtstage') {
                            return '#DF01A5';
                        if (calendarName === 'Werder' || event === 'Werder') {
                            return '#01DF01';
                        if (calendarName === 'Bayern' || event === 'Bayern') {
                            return '#FF0000';
                        if (calendarName === 'Ferien' || event === 'Ferien') {
                            return '#2ECCFA';
                        if (calendarName === 'Müllabfuhr' || event === 'Müllabfuhr') {
                            return '#2ECCFA';
                    function getMyCalendarTextColor(calendarName) {
                        // assign colors via the calendar names, use calendar name as set in ical
                        if (calendarName === 'Hausmüll') {
                            return '#000000';
                        if (calendarName === 'Papiertonne') {
                            return '#000000';
                        if (calendarName === 'Gelber Sack') {
                            return '#000000';
                        if (calendarName === 'Geburtstage') {
                            return '#000000';
                        if (calendarName === 'Werder') {
                            return '#000000';
                        if (calendarName === 'Bayern') {
                            return '#000000';
                        if (calendarName === 'Schulferien Niedersachsen') {
                            return '#000000';
                        if (calendarName === 'Müllabfuhr') {
                            return '#000000';
                // Enter the destination data point that is to be used as object ID in the widget
                setState(datapointId, JSON.stringify(calList), true);
        } catch (e) {
            console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
    ical2CalendarWidget();
    Gruß Andreas
    • A
      A
      AndreasHeins
      @Scrounger
      Ich habe schon alle Einstellungen durchsucht (glaube ich).
      Ich würde mir noch folgende Einstellungen wünschen:
      1. Kalenderwoche in der Monatsansicht einblenden
      2. Anzeige Monatsname in der Monatsansicht
      3. Markierung des Tages in der Monatsansicht
      1. Anzeige Monatsname in der Wochen- bzw. Tagesansicht
      Andreas
      ScroungerS 1 Antwort Letzte Antwort
      • A AndreasHeins
        @Scrounger
        Andreas
        ScroungerS
        ScroungerS
        Scrounger
        schrieb am zuletzt editiert von Scrounger
        @AndreasHeins sagte in Material Design Widgets: Calendar Widget:
        Bitte isssue auf git schreiben, evtl. implementiere ich das sofern die api das hergibt.
        1. Markierung des Tages in der Monatsansicht
        geht
        • A
          A
          AndreasHeins
          @Scrounger
          Danke für deine Nachricht.
          1. Die Einstellung habe ich glatt übersehen.
          1,2,4 Issues sind erstellt.
          Andreas
          • Stephan SchleichS
            Stephan SchleichS
            Stephan Schleich
            @Scrounger ist eine Listenansicht auch geplant? Fänd ich toll 🙂
            • Stephan SchleichS Stephan Schleich
              ScroungerS
              ScroungerS
              Scrounger
              @Stephan-Schleich
              Dafür kannst das du das List Widget oder Tablet WIdget nehmen. In der Doku gibt's dafür auch nen beispiel Skript bzw. Link dazu.
              Stephan SchleichS 1 Antwort Letzte Antwort
              • ScroungerS Scrounger
                @Stephan-Schleich
                Stephan SchleichS
                Stephan SchleichS
                Stephan Schleich
                @Scrounger So hab ich's derzeit gelöst.
                Hätte es cool gefunden wenn man das mit im Kalender Widget integriert hätte somit hatte man alles in einem.
                  Calendar Widget
                  Sämtliche Fragen zu Einstellungen (VIS Editor, Bedienung, JSON strings, etc.) des Widgets hier stellen
                  Das ist sicher besser für die Übersichtlichkeit und Dokumentation.
                  • Dokumentation
                  • Online Beispiel
                  Themen zu anderen Widgets findest du hier!
                  S
                  S
                  stefande
                  @Scrounger
                  Mal eine blöde Frage.
                  Ich hab jetzt auch mal das Calendar Widget installiert und es scheint soweit auch zu funktionieren.
                  Was ich jedoch nicht hinbekomme ist die vernünftige Darstellung eines Termins der über mehrere Tage geht.
                  So ein Termin ist am ersten Tag oben sichtbar aber an den folgenden Tagen nicht. Klicke ich mit der Maus auf den Termin werden die folgenden Tage auch mit der Farbe markiert, die ich unter "Farbe selektiert / Hover" unter Layout der Kalendertasten eingetragen habe.
                  Wie bekomme ich es hin, dass ich einen Termin der über mehrere Tage geht auch dauerhaft farblich markiert wird?
                  • S stefande
                    @Scrounger
                    ScroungerS
                    ScroungerS
                    Scrounger
                    @stefande
                    Welche Version verwendest du?
                    Sollte seit 0.3.6 behoben sein.
                      @stefande
                      S
                      S
                      stefande
                      @Scrounger
                      Danke. Hat sich erledigt.
                      Hatte einen Fehler im Javascript
                        @sigi234 @sveni_lee @Adnim
                        Hab das Skript nochmal bissle optimiert:
                        • nun werden alle ical instanzen berücksichtigt
                        • die Uhrzeiten werden korrekt verwendet
                        • skript wird direkt beim start einmal ausgeführt
                            try {
                                let calList = [];
                                    if (icalObj) {
                                            calList.push({
                                                color: getMyCalendarColor(calendarName),
                                                start: moment(item._date).format("YYYY-MM-DD HH:mm"),
                                                end: moment(item._end).format("YYYY-MM-DD HH:mm")
                                        function getMyCalendarColor(calendarName) {
                                            if (calendarName === 'calendar1') {
                                                return '#FF0000';
                                            } else if (calendarName === 'calendar2') {
                                                return '#44739e'
                                            } else if (calendarName === 'calendar3') {
                                                return '#32a852'
                                                return '#FFFFFF';
                                                return '#FFFFFF'
                                                return '#FFFFFF'
                                    setState('0_userdata.0.materialdesignwidgets.ical2Calendar', JSON.stringify(calList), true);
                            } catch (e) {
                                console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: {e.stack}`);
                        PeoplesP
                        PeoplesP
                        Peoples
                        schrieb am zuletzt editiert von Peoples
                        Hi mal ne blöde Frage aber bin ich der Einzige bei dem mehrtägige Ereignisse wie bspw. Urlaub einen Tag zu lange im Kalender dargestellt werden?
                        Hab das jetzt mal mit einem Workaround gelöst in dem ich eine Minute abziehe:
                                                else{
                                                    if(endTime.format('HH:mm') === '00:00'){
                                                        // Ergänzungen wegen falschem ende
                                                        let wishdate = new Date(end);
                                                        let newdate = (wishdate.getTime() -60000);
                                                        end = moment(newdate).format("YYYY-MM-DD")
                                                        //log(moment(newdate).format("YYYY-MM-DD  HH:mm"))
                        Wie ist das bei euch?
                        • N
                          N
                          nousefor82
                          @Scrounger
                          Servus, ist es möglich, die Hintergrundfarbe auf "transparent" zu setzen?
                          Wenn ich "transparent" eingebe, passiert genau nichts.
                          Danke!
                          • N nousefor82
                            @Scrounger
                            Danke!
                            ScroungerS
                            ScroungerS
                            Scrounger
                            @nousefor82 sagte in Material Design Widgets: Calendar Widget:
                            Geht aktuell noch nicht, in der kommenden Version geht es dann.
                            N 1 Antwort Letzte Antwort
                              N
                              N
                              nousefor82
                              @Scrounger
                              Super, danke!
                              • D
                                D
                                danreh23
                                schrieb am zuletzt editiert von danreh23
                                habe seit neuestem das Problem das der Wochentag nicht mehr zum Datum passt.
                                Jemand eine Idee?
                                Habe schon alles kontrolliert, kann aber nichts finden.
                                Danke!
                                @Scrounger : Kannst du mir hier weiterhelfen? Der Fehler tritt auch bei neu eingefügten Kalendern auf.
                                • D danreh23
                                  Jemand eine Idee?
                                  Danke!
                                  ScroungerS
                                  ScroungerS
                                  Scrounger
                                  @danreh23 sagte in Material Design Widgets: Calendar Widget:
                                  Hast du zufällig eine Version direkt von github installiert?
                                  Wenn nein was steht in der console des browsers (F12)?
                                    D
                                    D
                                    danreh23
                                    @Scrounger Ja habe direkt über Github installiert.
                                    hier der Auszug aus der Konsole, meinst du das?
                                    <div class="v-calendar-daily_head-weekday">Sonntag</div>
                                    • D danreh23
                                      ScroungerS
                                      ScroungerS
                                      Scrounger
                                      @danreh23
                                      OK dann liegt's an der GitHub Version hatte da Mal nen Fehler drin, der aber schon lange behoben ist. Immer bedenken GitHub Version sind Alpha!
                                      Installier aus latest, die sind entsprechens getestet.
                                      • D3ltoroxpD
                                        D3ltoroxpD
                                        D3ltoroxp
                                        schrieb am zuletzt editiert von D3ltoroxp
                                        Dieses Calender Widget funktioniert momentan nur mit dem ical Adapter und deinem Umwandlungsscript ?
                                        Muss ich in dem Script noch was einstellen ? Hab das jetzt laufen und dem Calender Widget den Datenpunkt gegeben aus deinem Script, aber ich sehe dort nichts.
                                        • N
                                          N
                                          nerg
                                          schrieb am zuletzt editiert von nerg
                                          @Scrounger : Schon jetzt vielen dank für die geilen Widgets. Ich baue grad meine ganze VIS um.
                                          Eine Frage zum Kalender Widget: Kann man auch die Terminübersicht nachbauen? Die finde ich immer am übersichtlichsten. Kann ich ggf. helfen?
                                          84.1k
