  5. Homematic Ip Thermostate und Xiaomi ( Gelöst )
45 Beiträge 5 Kommentatoren 6.2k Aufrufe 4 Beobachtet
    @lustig29
    Dann kann man wohl nur auf den Sollwert "setPointTemperature" zugreifen. Den Wert beim Fenster öffnen muss man sich merken. Etwa so:
     <variables>
       <variable id="aSl3f7TruC_Po_}txm4O">sollwert</variable>
       <variable id="u7,EdZFI-Ulk;Cs]RhdS">autosoll</variable>
     </variables>
     <block type="schedule" id="{0i,eaDfitncGslhKiJj" x="113" y="87">
       <field name="SCHEDULE">55 59 23 * * *</field>
       <statement name="STATEMENT">
         <block type="controls_if" id="XY@JJv4S]x:{[}Ggp5B_">
           <value name="IF0">
             <block type="logic_compare" id="5}gu6Zs?RTS%pJ.J8CC:">
               <field name="OP">EQ</field>
               <value name="A">
                 <block type="convert_from_date" id="%q(HLDIdq,?IYhh,H1)R">
                   <field name="OPTION">d</field>
                   <value name="VALUE">
                     <block type="math_arithmetic" id="}!-iDpBDWwk;eQ4L}:mL">
                       <field name="OP">ADD</field>
                       <value name="A">
                         <shadow type="math_number" id="}BeJE2ELYjda#b9v^FP]">
                           <field name="NUM">1</field>
                         </shadow>
                         <block type="time_get" id="Y|WVp?4$ui]2Iw]DZ.3e">
                           <field name="OPTION">object</field>
                         </block>
                       </value>
                       <value name="B">
                         <shadow type="math_number" id="Cn)Bn9Ebs6j?5H@+]@Z3">
                           <field name="NUM">10000</field>
                         </shadow>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <value name="B">
                 <block type="math_number" id="ICc-C/-4x/KSc%p9,9AC">
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO0">
             <block type="comment" id="m{)?{0N|vP~Ax]E-p*2h">
               <field name="COMMENT">Aktion</field>
             </block>
           </statement>
         </block>
       </statement>
     </block>
     <block type="on_ext" id="|5#M+zpd0zG4$IO^.J/m" x="113" y="338">
       <value name="OID0">
         <shadow type="field_oid" id="JiS%IRKbWF:LYicRXtO1">
           <field name="oid">zigbee.0.00158d0002c8d185.open</field>
         </shadow>
       </value>
         <block type="variables_set" id="@%we,L7Ca6=?rlzB`4G|">
           <field name="VAR" id="aSl3f7TruC_Po_}txm4O">sollwert</field>
             <block type="get_value" id="]Zv!_f/w8D29(?Eeo76:">
               <field name="OID">ID auswählen</field>
             </block>
           </value>
           <next>
             <block type="controls_if" id="Ao,T8kt-uX(^nY`F~!3S">
               <value name="IF0">
                 <block type="on_source" id="M(2Aj^Crf#a_Oo;_41;H">
                 </block>
               </value>
                 <block type="controls_if" id="[Ype(P$`6J~s@g)p/$8E">
                   <value name="IF0">
                     <block type="logic_compare" id="mmIN_AfL;xQdb}e5[yIu">
                       <field name="OP">GT</field>
                       <value name="A">
                         <block type="variables_get" id="1ELMD+6q9QQ4L={}a[W5">
                         </block>
                       </value>
                       <value name="B">
                         <block type="math_number" id=";PkPG%r.oJbkCb4pZg^R">
                           <field name="NUM">5</field>
                         </block>
                       </value>
                     </block>
                   </value>
                     <block type="variables_set" id="e?zPV=Trf-*N%Qya|ns;">
                       <field name="VAR" id="u7,EdZFI-Ulk;Cs]RhdS">autosoll</field>
                         <block type="variables_get" id="u#mhQ_@9w)8sHsgN@Jgb">
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="@T]M?1/i.bVto*%nc3%l">
                             <block type="math_number" id="gqk(Ni_n=NTPjA4h+vEV">
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </statement>
               <statement name="ELSE">
                 <block type="variables_set" id="QQ/H32^zdOT^1.8:Sabu">
                     <block type="variables_get" id="/_!d#v1EH5JcC6Ga9=sy">
                     </block>
                   </value>
                 </block>
               </statement>
               <next>
                 <block type="control" id="nRd}V:34TfPWMY}z|P,!">
                     <block type="variables_get" id="lBwHNp=C((gvksG1K$c.">
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    lustig29
    Irgendwas scheint noch nicht zu stimmen. Ich habe meine Werte mal eingetragen.Heizungtest.png
    • L lustig29
      @lustig29
      Ich sehe, dass die Variable autosoll initialisiert werden muss.
      L 1 Antwort Letzte Antwort
        @lustig29
        lustig29
        21.6.2020, 16:53:16.769 [info ]: javascript.0 (1780) Start javascript script.js.Heizung_Balkontür
        21.6.2020, 16:53:16.903 [info ]: javascript.0 (1780) script.js.Heizung_Balkontür: registered 1 subscription and 0 schedules
        21.6.2020, 16:54:15.337 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:15.341 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:21.129 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:21.139 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:23.581 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:23.584 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:27.226 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:27.231 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:28.907 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:28.912 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:31.743 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:31.747 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:34.405 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:34.410 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:35.068 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:35.071 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:36.214 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:36.218 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:37.129 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:37.132 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:38.183 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:38.185 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:39.711 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:39.715 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:43.045 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:43.047 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:44.378 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:44.381 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:45.785 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:45.789 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:46.867 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:46.869 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:54:54.198 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:54:54.200 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:55:00.642 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:55:00.645 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:55:01.844 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:55:01.847 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:55:31.725 [info ]: javascript.0 (1780) Stop script script.js.Heizung_Balkontür
        21.6.2020, 16:57:08.217 [info ]: javascript.0 (1780) Stop script script.js.Heizung_Balkontür
        21.6.2020, 16:57:21.589 [info ]: javascript.0 (1780) Start javascript script.js.Heizung_Balkontür
        21.6.2020, 16:57:21.603 [info ]: javascript.0 (1780) script.js.Heizung_Balkontür: registered 1 subscription and 0 schedules
        21.6.2020, 16:58:47.100 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:58:47.102 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:58:49.608 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:58:49.611 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:58:52.442 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:58:52.447 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:58:54.665 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:58:54.671 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:58:55.979 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:58:55.981 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:58:57.208 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:58:57.217 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:59:02.869 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:59:02.871 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:59:03.705 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:59:03.709 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:59:07.993 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:59:08.000 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:59:12.693 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:59:12.697 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        21.6.2020, 16:59:12.821 [warn ]: javascript.0 (1780) at Object.<anonymous> (script.js.Heizung_Balkontür:16:3)
        21.6.2020, 16:59:12.828 [error]: javascript.0 (1780) script.js.Heizung_Balkontür: setForeignState: undefined is not a valid state value
        So?
        • L lustig29
          So?
          @lustig29 sagte:
          So?
          Nein, rechts oben kann man mit blockly/JS in die Javascript-Ansicht umschalten. Dann mit copy & paste den Code in das Forum kopieren: Code tags oben: </>
          Ich habe den Grund wahrscheinlich gefunden (siehe oben).
            @lustig29 sagte:
            So?
            lustig29
            @paul53 Ok, also lösche ich die Variablen jetzt am besten und erstelle sie selber neu?
            • L lustig29
              @lustig29 sagte:
              Nein, füge über dem Trigger-Block die Initialisierung der Variable autosoll ein:
              setze autosoll auf Wert vom Objekt ID setPointTemperature.
                @lustig29 sagte:
                lustig29
                schrieb am zuletzt editiert von lustig29
                @paul53 leider funktioniert es immer noch nicht
                Das steht im Log:
                27641) state change - setPointTemperature - id 73137e60-2021-42bd-9d0e-e048643e315f - value 5
                • L lustig29
                  Das steht im Log:
                  @lustig29 sagte:
                  Welche Fehlermeldung ?
                  • L lustig29
                    Das steht im Log:
                    @lustig29 sagte:
                    Das steht im Log:
                    Der Wert 5 wird geschrieben, weil vermutlich der Sollwert auf 5 °C eingestellt war. Siehe hier. Es funktioniert nur mit einem Sollwert > 12 °C bei geschlossenem Fenster.
                    Es kann übrigens einige Minuten dauern, bis der neue Sollwert im Thermostaten ankommt.
                      @lustig29 sagte:
                      Das steht im Log:
                      lustig29
                      @paul53 es liegt an meinem Homematic Acesspoint. Der bekommt keine Verbindung mehr 😉
                      • L Offline
                        lustig29
                        Habe mein Acesspoint wieder zum laufen gebracht. Leider funktioniert das Skript nur teilweise und wirft jetzt Fehler vom Hmip Adapter im Log aus.
                        • L Offline
                          lustig29
                          code_text
                          ```hmip.0	2020-06-23 18:17:28.124	info	(22803) Terminated (NO_ERROR): Without reason
                          hmip.0	2020-06-23 18:17:28.121	info	(22803) terminating
                          hmip.0	2020-06-23 18:17:28.082	info	(22803) cleaned everything up...
                          hmip.0	2020-06-23 18:17:28.080	error	at IncomingMessage.emit (events.js:327:22)
                          hmip.0	2020-06-23 18:17:28.080	error	at Object.onceWrapper (events.js:421:28)
                          hmip.0	2020-06-23 18:17:28.080	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
                          hmip.0	2020-06-23 18:17:28.080	error	at Request.emit (events.js:315:20)
                          hmip.0	2020-06-23 18:17:28.080	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
                          hmip.0	2020-06-23 18:17:28.080	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                          hmip.0	2020-06-23 18:17:28.080	error	at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
                          hmip.0	2020-06-23 18:17:28.080	error	at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
                          hmip.0	2020-06-23 18:17:28.080	error	at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
                          hmip.0	2020-06-23 18:17:28.080	error	(22803) StatusCodeError: 400 - {"errorCode":"NOT_HEATING_GROUP"}
                          hmip.0	2020-06-23 18:17:28.070	error	(22803) unhandled promise rejection: 400 - {"errorCode":"NOT_HEATING_GROUP"}
                          Unhandled	2020-06-23 18:17:28.069	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          • L Offline
                            lustig29
                            Liegt mien Fehler darin, dass ich das Wandthermosthat ausgewählt habe? Habe dies ausgewählt, weil ich im Wohnzimmer 2 Thermosthate habe die darüber laufen.
                            Fenster auf Temperatur runter klappt in der Regel, nur nicht wieder zurück. Da bleiben die 5 Grad stehen.
                            • L lustig29
                              @lustig29 sagte:
                              War "Fenster offen"-Temperatur nicht 12 °C ?
                              L 2 Antworten Letzte Antwort
                                @lustig29 sagte:
                                lustig29
                                @paul53 Ja, hatte ich wieder auf 5 Grad geändert.
                                  @lustig29 sagte:
                                  lustig29
                                  @paul53 kannst du bitte nochmal kurz drüber schauen und mir sagen, was noch verkehrt läuft? Fenster auf... Temperatur geht auf 5 Grad. Fenster zu... Temperatur bleibt bei 5 Grad stehen.
                                  • L lustig29
                                    @lustig29 sagte:
                                    Wie war der Sollwert vor "Fenster öffnen" ?
                                    Überprüfe die Variablen-Werte mit Debug-Blöcken.
                                      @lustig29 sagte:
                                      lustig29
                                      @paul53 Habe ihn jetzt auch auf 18 gestellt, wie bei dir. Hier der Debug Output:
                                      25.6.2020, 20:19:59.487	[info ]: javascript.0 (27698) Stop script script.js.Heizung_Balkontür
                                      25.6.2020, 20:20:02.766	[info ]: javascript.0 (27698) Start javascript script.js.Heizung_Balkontür
                                      25.6.2020, 20:20:02.789	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: registered 1 subscription and 0 schedules
                                      25.6.2020, 20:21:43.159	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: true
                                      25.6.2020, 20:21:43.161	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: 5
                                      25.6.2020, 20:21:52.100	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: false
                                      25.6.2020, 20:21:52.101	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: 18
                                      25.6.2020, 20:22:20.396	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: true
                                      25.6.2020, 20:22:20.398	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: 5
                                      25.6.2020, 20:22:23.000	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: false
                                      25.6.2020, 20:22:23.002	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: 18
                                      25.6.2020, 20:22:23.986	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: true
                                      25.6.2020, 20:22:23.987	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: 5
                                      25.6.2020, 20:22:26.669	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: false
                                      25.6.2020, 20:22:26.670	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: 18
                                      25.6.2020, 20:22:46.128	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: true
                                      25.6.2020, 20:22:46.130	[info ]: javascript.0 (27698) script.js.Heizung_Balkontür: 5_text
                                      • L lustig29
                                        @lustig29 sagte:
                                        Danach wird der richtige Wert zum HMIP-Adapter geschrieben. Kommt er am Thermostaten nicht an ?
                                        Du hast innerhalb von zwei Minuten mehrmals das Fenster geöffnet und geschlossen. So schnell reagiert das Thermostat nicht.
                                          @lustig29 sagte:
                                          lustig29
                                          @paul53 Also ich trenne den Kontakt, dann springt das Thermostat sofort um auf 5. Nur andersrum geht es nicht.
