  4. Fully Kiosk Browser Akkustand abfragen
45 Beiträge 14 Kommentatoren 10.0k Aufrufe 10 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    Irgendwie scheinbar nicht.
    Wenn ich den
    log ("Batterylevel = " + bat);
    falsch schreibe kommt sofort das im Log:
    javascript.0	2018-09-24 17:00:00.877	warn	at process._tickCallback (internal/process/next_tick.js:181:9)
    javascript.0	2018-09-24 17:00:00.876	warn	at _combinedTickCallback (internal/process/next_tick.js:139:11)
    javascript.0	2018-09-24 17:00:00.876	warn	at endReadableNT (_stream_readable.js:1064:12)
    javascript.0	2018-09-24 17:00:00.876	warn	at IncomingMessage.emit (events.js:208:7)
    javascript.0	2018-09-24 17:00:00.876	warn	at emitNone (events.js:111:20)
    javascript.0	2018-09-24 17:00:00.876	warn	at Object.onceWrapper (events.js:313:30)
    javascript.0	2018-09-24 17:00:00.876	warn	at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12)
    javascript.0	2018-09-24 17:00:00.876	warn	at Request.emit (events.js:211:7)
    javascript.0	2018-09-24 17:00:00.875	warn	at emitOne (events.js:116:13)
    javascript.0	2018-09-24 17:00:00.875	warn	at Request. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10)
    javascript.0	2018-09-24 17:00:00.875	warn	at Request.emit (events.js:214:7)
    javascript.0	2018-09-24 17:00:00.875	warn	at emitTwo (events.js:126:13)
    javascript.0	2018-09-24 17:00:00.875	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
    javascript.0	2018-09-24 17:00:00.874	warn	at Request._callback (script.js.Wandtablet.LadenFully:11:13)
    javascript.0	2018-09-24 17:00:00.873	warn	Wrong type of javascript.0.Allgemein.Akku_Tablet: "undefined". Please fix, while deprecated and will not work in next versions.</anonymous></anonymous>
    ok, ist ja eigentlich egal, weil es ja jetzt funktioniert.
    Danke für deine Umsetzung.
    • 0 0018
      nach einiger Suchzeit und probieren habe ich es glaub ich herausgefunden:
      var request = require('request');
      var link = "http://192.168.0.49:2323/?cmd=deviceInfo&type=json&password=xxxx";
      var state = "javascript.0.Allgemein.Akku_Tablet"/*Akku_Tablet*/;
      function fully() {
          request(link, function(error,response, body) {
              if(error) log('Fehler request: ' + error, 'error');
              else {
                  objects = JSON.parse(body);
                  bat = objects.batteryLevel;
                  setState(state, bat);
      fully();
      schedule('*/10 * * * *', fully);
      Danke für den Denkanstoß :)
      aleks-83
      schrieb am zuletzt editiert von aleks-83
      @0018 sagte in Fully Kiosk Browser Akkustand abfragen:
      function fully() {
              else {
                  log ("batteryLevel = " + bat);
      fully();
      Hat gleich auf Anhieb geklappt! Danke für das Skript.
      Nur eben meine IP und den Datenpunkt angepasst... Läuft!
      Hier eine etwas erweiterte Version:
      var link = "http://10.0.0.59:2323/?cmd=deviceInfo&type=json&password=XXXXXX";
      var Akkustand = "javascript.0.MeinTablet.Akkustand"/*Akkustand*/;
      var Plugged = "javascript.0.MeinTablet.Plugged"/*Plugged*/;
      var Helligkeit = "javascript.0.MeinTablet.Helligkeit"/*Helligkeit*/;
      function fully() {
              if(error) log('### Fehler request: ' + error, 'error');
              else {
                  plug = objects.plugged;
                  bright = objects.screenBrightness;
                  setState(Akkustand, bat);
                  setState(Plugged, plug);
                  setState(Helligkeit, bright);
                  log ("### Tablet Akkustand: " + bat + " %");
                  log ("### Tablet Plugged: " + plug );
                  log ("### Tablet Helligkeit: " + bright );
      fully();
      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
      = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
      Glasfaser 400
      • E Offline
        eve11
        ich möchte gerne das o.g. Script noch um die Info "ScreenOn" true/false erweitern.
        Ich habe mir dementsprechend es nun so zusammen gebastelt:
        var link = "http://192.168.178.23:2323/?cmd=deviceInfo&type=json&password=xxxxxx";
        var Akkustand = "NeueObjekte.0.AkkuTabletFully_"/*Akkustand*/;
        var Plugged = "NeueObjekte.0.PluggedTabletFully_"/*Plugged*/;
        var Helligkeit = "NeueObjekte.0.HelligkeitTabletFully_"/*Helligkeit*/;
        var ScreenOn = "NeueObjekte.0.ScreenTabletFully_"/*ScreenOn*/;
        function fully() {
                else {
        			screen = objects.screenOn;
        			setState(ScreenOn, screen );
        	    log ("### Tablet ScreenOn: " + screen );
        fully();
        Aber Natürlich funktioniert dies aber nicht. Leider keine Ahnung warum. Nach Fully docu sollte "ScreenOn" aber der richtige Parameter sein, wenn ich sehen möchte ob der Bildschirm an oder aus ist.
        11:00:15.697	warn	javascript.0 at Request._callback (script.js.Tablet.ScreenOn:22:4)
        11:00:15.697	info	javascript.0 script.js.Tablet.ScreenOn: ### Tablet Akkustand: 78 %
        11:00:15.697	info	javascript.0 script.js.Tablet.ScreenOn: ### Tablet Plugged: true
        11:00:15.697	info	javascript.0 script.js.Tablet.ScreenOn: ### Tablet Helligkeit: 110
        11:00:15.697	info	javascript.0 script.js.Tablet.ScreenOn: ### Tablet ScreenOn: undefined
        Vielen Dank
        eve11
        IssiI 1 Antwort Letzte Antwort
        • E eve11
          function fully() {
                  else {
          fully();
          Vielen Dank
          eve11
          IssiI Online
          IssiI Online
          Issi
          @eve11 sagte in Fully Kiosk Browser Akkustand abfragen:
          function fully() {
                  else {
          fully();
          Vielen Dank
          eve11
          Hallo eve11
          es sollte so aussehen
                      screen = objects.isScreenOn;
          also nur screenOn in isScreenOn ändern dann sollte es gehen
          • E Offline
            eve11
            Super, vielen Dank. Funktioniert.
            Noch eine Frage. Wo kann ich alle Parameter einsehen ?
            eve11
            • E eve11
              eve11
              IssiI Online
              IssiI Online
              Issi
              eve11
              wen du z.B. das hier log(body); in das script schreibst bekommst du den komplette Inhalt von deviceInfo
                      else {
                      	log(body);
                Andre R.
                Hallo
                ist der Port 2323 immer gleich?
                • A acramatic
                  Ich mache das mit Tasker. Tasker schreibt den Akkustand alle 15 min. in ein Objekt. Mit einem Skript steuere ich dann einen Sonoff Basic. Läuft ohne Probleme.
                  aleks-83
                  @acramatic sagte in Fully Kiosk Browser Akkustand abfragen:
                  Ich möchte auch evtl Tasker verwenden.
                  Weil mein FullyBrowser irgendwie mehrmals pro Minute den "alive" Status wechselt und somit nicht ganz zuverlässig ist.
                  Mit PAW bin ich bisher nicht warm geworden. Werde ich vllt auch nochmal probieren.
                  Wo finde ich Anleitungen oder Beispiele wie man Tasker mit ioBroker verbindet?
                  Geht das nur über die ioBroker Cloud?
                  Glasfaser 400
                  • arteckA arteck
                    korrektur
                    Fully kann das doch in der gekauften Version..
                    mit
                    http://ip:port/?cmd=deviceInfo&type=json
                    im Knoten batteryLevel
                    kannst du dir die Device Infos holen dann im script parsen..
                    StM47S Offline
                    StM47S Offline
                    StM47
                    @arteck
                    Kannst du m ir das kurz erklären?
                    Ich habe die Kaufversion vom Fully Browser auf meinem Tablett am laufen und möchte den Batterieladezustand auf der VIs anzeigen.
                    ioBroker im Docker auf Synology DiskStation DS 716+II mit DSM 6.2.1
                    • Lightmanager Air / Lupusec XT2 Plus mit div. Fenster- u. Türkontakten, Rauch- u. Bewegungsmelder / Harmony Hub / Fritzbox 7590 OS7
                    • schaltbare Steckdosen / Alexa Echo Dot 3 / Zigbee USB Stick / diverse Xiaomi Produkte / Xiaomi Yeelight Birnen
                    • StM47S StM47
                      @arteck
                      crunchipC Offline
                      crunchipC Offline
                      @StM47 wird unter fullybrowser.0.IP.Info.batteryLevel angezeigt
                      StM47S 1 Antwort Letzte Antwort
                        StM47S Offline
                        StM47S Offline
                        StM47
                        schrieb am zuletzt editiert von StM47
                        Muss ich das auf dem Tablett in den Fully Einstellungen erst freigen?
                        Mehr wird bei mit unter fullybrowser.0 nicht ausgegeben.
                        Edit: Nach Neuinstallation der Fully Adapters werden alle States angezeigt. Danke!
                        R 1 Antwort Letzte Antwort
                        • StM47S StM47
                          RDE
                          @StM47
                          Hallo, habe das gleiche Problem, das im iOBroker unter Fullybrowser die konkreten Werte nicht dargestellt werden.
                          Auch eine Neuinstallation hat nichts gebracht.
                          Könnt ihr mir bitte die erforderlichen Schritte nochmals kurt erläutern? Das wäre Super
                          Albert KA 1 Antwort Letzte Antwort
                          • R RDE
                            @StM47
                            Albert KA Offline
                            Albert KA Offline
                            Albert K
                            @RDE
                            Bei mir hat folgendes geholfen:
                            • Fully Adapter unter Instanzen abschalten
                            • Unter Objekte die Fully Browser Struktur komplett löschen
                            • Fully Browser Instanz wieder einschalten.
                            Es wurde dabei eine neue Objekt Struktur generiert die sich seitdem auch wieder aktualisiert.
                            • Albert KA Albert K
                              @RDE
                              RDE
                              @Albert-K
                              hat leider nicht funktioniert, jetzt habe ich unter Objekte gar keinen Eintrag mehr für Fully....
                              • R RDE
                                @Albert-K
                                Albert KA Offline
                                Albert KA Offline
                                Albert K
                                @RDE
                                Na dann findet aber auch keine Kommunikation statt zwischen Adapter und dem Gerät auf dem Fully läuft.
                                Kannst Du das Gerät denn mit Ping erreichen?
                                  @RDE
                                  RDE
                                  @Albert-K
                                  Kommunikation mit gerät klappt, auch ping
                                  • R RDE
                                    @Albert-K
                                    Albert KA Offline
                                    Albert KA Offline
                                    Albert K
                                    @RDE
                                    und im Adapter Abfrage Intervall 60 /10? Und auch Passwort und den Haken bei der IP gesetzt?
                                      @RDE
                                      abg0002
                                      @albert-k
                                      bei mir aktualisiert er genau 1x die Werte nach dem Restart des Adapters, danach nicht mehr. Aktualisierungsintervall ist auf 60s eingestellt, Timeout auf 10s.
                                      Passwort und IP usw. stimmt alles, denn sonst würde er nach einem Restart des Adapters ja die Werte auch nicht neu laden....
                                      Irgendwas läuft da seit kurzer Zeit nicht mehr rund. Anfangs hat er immer super aktualisiert.
                                      Auch im Log ist absolut keinerlei Eintrag zu finden.
                                      • A abg0002
                                        @albert-k
                                        Albert KA Offline
                                        Albert KA Offline
                                        Albert K
                                        @abg0002
                                        war bei mir plötzlich ebenso im November 2020. Ewig rumgesucht und keine Lösung gefunden. Dann so verfahren wie in meinem Post vom 9. Dezember 2020 und seitdem funktioniert es bei mir wieder.
                                        Bei @RDE hat das aber anscheinend auch nicht geklappt.
                                        • Mike HöselbarthM Offline
                                          Mike Höselbarth
                                          ich weiß das thema ist schon alt. Leider kenn ich mich bis ejtzt noch karnicht damit aus.
                                          Aber wo muss ich diesen Skript dann einfügen?
                                          Würde mich freuen wenn Ihr mir helfen könntet bin am verzweifeln.
