  4. JavaScript
  5. Script fürTabelle der Batterie Zustände
javascriptmonitoringtemplate
1.4k Beiträge 67 Kommentatoren 885.3k Aufrufe 86 Beobachtet
  • N Nordischerjung
    @liv-in-sky
    Moin,
    ich hab das Script ja nun schon ne weile laufen. bisher ohne Probleme. Nun habe ich einen neuen Hue Outdoor Bewegungsmelder. Seid ich diesen intergriert habe, kommen folgende Fehler im Log
    javascript.1	2020-05-22 22:49:40.023	error	(8655) at tryOnTimeout (timers.js:300:5)
    javascript.1	2020-05-22 22:49:40.022	error	(8655) at ontimeout (timers.js:436:11)
    javascript.1	2020-05-22 22:49:40.022	error	(8655) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.1	2020-05-22 22:49:40.021	error	(8655) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.1	2020-05-22 22:49:40.021	error	(8655) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.1	2020-05-22 22:49:40.021	error	(8655) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1270:34)
    javascript.1	2020-05-22 22:49:40.020	error	(8655) at Object.<anonymous> (script.js.Battery_Anzeige_VIS:1187:1)
    javascript.1	2020-05-22 22:49:40.020	error	(8655) at writeHTML (script.js.Battery_Anzeige_VIS:399:22)
    javascript.1	2020-05-22 22:49:40.019	error	(8655) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:796:29)
    javascript.1	2020-05-22 22:49:40.018	error	(8655) at script.js.Battery_Anzeige_VIS:406:67
    javascript.1	2020-05-22 22:49:40.017	error	(8655) Error in callback: TypeError: Cannot read property 'common' of null
    javascript.1	2020-05-22 22:49:40.015	warn	(8655) Object "hue.0.Philips_hue.Hue_outdoor_temp" does not exist
    javascript.1	2020-05-22 22:49:25.636	error	(8655) at Script.runInContext (vm.js:133:20)
    javascript.1	2020-05-22 22:49:25.636	error	(8655) at script.js.Battery_Anzeige_VIS:1190:1
    javascript.1	2020-05-22 22:49:25.635	error	(8655) at writeHTML (script.js.Battery_Anzeige_VIS:399:22)
    javascript.1	2020-05-22 22:49:25.635	error	(8655) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:796:29)
    javascript.1	2020-05-22 22:49:25.635	error	(8655) at script.js.Battery_Anzeige_VIS:406:67
    javascript.1	2020-05-22 22:49:25.635	error	(8655) TypeError: Cannot read property 'common' of null
    javascript.1	2020-05-22 22:49:25.635	error	(8655) ^
    javascript.1	2020-05-22 22:49:25.635	error	(8655) val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ; val0=val0.replace(/.battery$/,""); val0=val0.replace("Philips_hue.",""); val0=val0.replace(/_/g," ");
    javascript.1	2020-05-22 22:49:25.634	error	(8655) script.js.Battery_Anzeige_VIS: script.js.Battery_Anzeige_VIS:406
    javascript.1	2020-05-22 22:49:25.633	warn	(8655) Object "hue.0.Philips_hue.Hue_outdoor_temp" does not exist
    javascript.1	2020-05-22 22:49:25.612	info	(8655) Start javascript script.js.Battery_Anzeige_VIS
    Warum ist das so? Das geht erst weg, wenn ich hue au false im script setze
    edit: setze ich hueext true, dann geht es. Da wird der BWM auch angezeigt. Dann mache ich es halt über den Weg.
    liv-in-skyL
    liv-in-skyL
    #1006
    @Nordischerjung hab das nochmal bei mir angesehen - ein normale hue sensor kann eigentlich nicht als hue-ext sensor im script erkannt werden. die datenpunkte sind völlig anders aufgebaut
    hue-ext:
    hue-extended.0.sensors.012-hue_temperature_sensor_1.config.battery
    hue:
    hue.0.Philips_hue.BueroTaster.battery
    kann es sein, dass entweder der battery wert keinen inhalt hat oder das deine datenpunkte anders aufgebaut sind ?hast du hue und hue-ext sensoren ? am besten mache einen json export von allen deinen hue und/oder hue-ext. datenpunkten
    N 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      hue-ext:
      hue:
      N
      N
      Nordischerjung
      #1007
      @liv-in-sky sagte in Script fürTabelle der Batterie Zustände:
      hue-ext:
      hue:
      Moin, der hue-ext adapter ist doch wie der hue adapter, Da gibt es doch keine extra Sensoren für, oder hab ich das falsch verstanden? Ich hatte den damals installiert, da ich damit die Szenen auslesen und steuern konnte ( kann auch sein, dass es beim hue auch möglich war hatte ich nicht gesehen, egal). Es steht bei beiden Adaptern in battery 100% drin. JSON kann ich erst heute abend machen, bin unterwegs.
      Gruß Nordischerjung
      sonnige Grüße von der Ostsee
      • Stephan SchleichS
        Stephan SchleichS
        Stephan Schleich
        #1008
        @liv-in-sky wäre es noch möglich eine HTML Tabelle mit zur Verfügung zu stellen? Damit könnte man dann die Werte via Telegram anzeigen lassen
        • Stephan SchleichS Stephan Schleich
          liv-in-skyL
          liv-in-skyL
          #1009
          @Stephan-Schleich
          das ganze ist eine html tabelle bzw html code - aber leider kann telegram sowas nicht anzeigen - braucht wohl ein eigenes bzw spezielles format
          bin nicht so in telegram eingearbeitet - aber es gibt zumindest einen datenpunkt mit den devices, welche einen batteriewechsel brauchen - dies kann man an telegram senden (über eigenes script) - oder wenn du dir eine datei erzeugen läßt (script setting) könnte diese an das handy via telegram gesendet werden und somit auf dem handy angezeigt werden
          selbst wenn ich wüßte, wie genau so eine telegram-tabelle erzeugt werden müßte, würde ich es nicht einbinden - dazu gibt es die vis oder iqontrol oder ...
          ich persönlich sehe telegram eher als alarm system und nicht als vis ersatz - es würde mir keinen nutzen bringen, die ganze tabelle in telegram zu haben - nur ein alarm bzw welche geräte brauchen eine neue batt, sollte als meldung doch ausreichend sein
          • Christoph1337C
            Christoph1337C
            Christoph1337
            #1010
            Ich bekomme immer folgende Meldung:
            16:59:25.540	info	javascript.0 (1208) script.js._TEST.BatteryMonitor: registered 0 subscriptions and 1 schedule
            16:59:40.013	warn	javascript.0 (1208) at writeHTML (script.js._TEST.BatteryMonitor:1176:5)
            16:59:40.013	warn	javascript.0 (1208) at Object.<anonymous> (script.js._TEST.BatteryMonitor:1187:1)
            16:59:40.015	warn	javascript.0 (1208) at writeHTML (script.js._TEST.BatteryMonitor:1177:5)
            16:59:40.015	warn	javascript.0 (1208) at Object.<anonymous> (script.js._TEST.BatteryMonitor:1187:1)
            • Christoph1337C Christoph1337
              liv-in-skyL
              liv-in-skyL
              #1011
              @Christoph-Bubeck wieviele zeilen hat dein script? über 1390 ?
                liv-in-skyL
                liv-in-skyL
                #1012
                @Christoph-Bubeck und hast du die datenpunkte dpAlarm und dpAlarmMessage angelegt und im script eingetragen ?
                • liv-in-skyL
                  liv-in-skyL
                  #1013
                  @Christoph-Bubeck
                  für die max- werte sollte es reichen, im homematic teile ein oder 2 zeilen zu ändern
                  ich gehe davon aus, du hast den homematic teil geändert - da es anscheinend nur um fulbat geht kannst du in dieem teil den val2 wet ändern
                  valhelp ersetzern mit dem richtigen datenpunkt und val2 anpassen - zeile 757
                  wenn ich die datenpunkt struktur kennen würde, kann man varhelp einfach anpassen
                  • Christoph1337C
                    Christoph1337C
                    Christoph1337
                    #1014
                    Also mit dem Hometic klappt das für MAX.
                    Wie gesagt musste ich nur den Suchstring anpassen. Wenn das auch andere nutzen wollen müsste man nur die hometic funktion im script kopieren und erneut für max ablegen. oder denk ich verkehrt?
                      liv-in-skyL
                      liv-in-skyL
                      #1015
                      @Christoph-Bubeck
                      an dieser stelle kenn ich nur den batterie wert - aber wie heißt der online wert und wo liegt er im verzeichnis ( wird er überhaupt anstndig im adapter angezeigt) - die homematic glaube ich haben da so ihre probleme) - diesen wert muss ich definieren- ich habe aber nur die id von battery_low und von dieser aus muss ich mich zum online vorarbeiten -
                        liv-in-skyL
                        liv-in-skyL
                        #1016
                        @Christoph-Bubeck ist das der initialized wert - alle anderen sind ja false - wird initialized geändert, wenn du das device abschaltest ?
                        • Christoph1337C
                          Christoph1337C
                          Christoph1337
                          schrieb am zuletzt editiert von Christoph1337
                          #1017
                          achsoo.
                          Also für Offline nehme ich
                          state[state.id=maxcube.*.*.*.error]
                          und
                          state[state.id=maxcube.*.*.*.link_error]
                          Wenn = true -> nicht errreichbar
                          für Problem
                          state[state.id=maxcube.*.*.*.working]
                          wenn = false -> Problem vorhanden
                          liv-in-skyL 3 Antworten Letzte Antwort
                            achsoo.
                            und
                            für Problem
                            liv-in-skyL
                            liv-in-skyL
                            #1018
                            @Christoph-Bubeck
                            kannst du mir bite noch die ganzen max datenpunkte in ein json packen - mit deconz geht das "online" schon
                            wenn letzter datenpunkt update länger als 12 stunden - dann time-warn sonst on-bzw offline
                              achsoo.
                              und
                              für Problem
                              liv-in-skyL
                              liv-in-skyL
                              #1019
                              @Christoph-Bubeck und den ganzen teil des scriptes, welchen du für die max geändert hast oder war das nur der selektor
                                achsoo.
                                und
                                für Problem
                                liv-in-skyL
                                liv-in-skyL
                                #1020
                                @Christoph-Bubeck
                                jetzt muss ich nochmal fragen: wie die anzeige sein soll
                                • wenn über 12 stunden kein dp-update (von error und error link) - dann time warn;
                                • sonst wenn unter 12 stunden dann bei error und error link ist false => online
                                • und wenn eines von error und error link ist true => offline
                                dann bekommst du immer offline wenn die error oder link_error "falsch" (also true) sind ein offline angezeigt. da dies aber immer wieder geschieht muss da noch ein zeitfaktor rein! dazu müßte ich wissen, wie lange diese ´"fehlanzeige" länstens sein kann (vorher hatten wir mal eine halbe stunde) - also wie lange soll das online bleiben bevor da offline daraus wird
                                hoffe ich konnte es richtig erklären
                                dazu kommt noch dieser working datenpunkt - ist der verlässlich oder hat der auch aussetzer
                                • Christoph1337C
                                  Christoph1337C
                                  Christoph1337
                                  #1021
                                  Moin moin,
                                  ich meine die Infos zu den DPs hast du genau richtig dargestellt.
                                  Als Timer sollte man mindestens 60 Minuten nehmen, da durch z.B. DutyCycle das Gerät für diesen Zeitraum nicht erreichbar sein könnte.
                                  Aktuell hatte ich das Gefühl das der Working-DP korrekt funktioniert. Wahrscheinlich wird man das erst merken, wenn man eine längere Analyse darüber fährt.
                                    Moin moin,
                                    liv-in-skyL
                                    liv-in-skyL
                                    #1022
                                    @Christoph-Bubeck
                                    60 minuten habe ich auch gedacht - werd dir dann bald ein testscript geben
                                      Moin moin,
                                      liv-in-skyL
                                      liv-in-skyL
                                      #1023
                                      @Christoph1337
                                      ok - erster test - ganz happy bin ich noch nicht:
                                      du kannst die settings - ganz oben - übernehmen und in dieses script kopieren - wegen datenpunkten, ..
                                      es gibt folgende states(kannst du auch anpassen im script):
                                      • online - alles ok (keine zeit abfrage des dp-updates)
                                      • dp-warn - seit 6 stunden kein dp update
                                      • time-online - bleibt online bis eine stunde letzter dp update obwohl einer der dp false ist
                                      • offline - über eine stunde kein datenpunkt update und einer der dp ist false
                                      //@liv-in-sky Januar 2020 christoph1
                                      // https://forum.iobroker.net/topic/28789/script-fürtabelle-der-batterie-zustände
                                      //HIER WIRD PFAD UND FILENAME DEFINIERT
                                      const path = "/htmlakku.html";                   //FIlenamen definieren
                                      const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                      let   braucheEinFile=true;                          // bei true wird ein file geschrieben - NUR FÜR IQONTROL oder DIRECT BROWSER-Aufruf
                                      let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
                                      let   braucheMaterialDesignWidget=false;             // bei true wird ein json in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
                                      let   braucheMaterialDesignWidgetTable=false;        // bei true wird ein json in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
                                      let dpVIS="controll-own.0.TABELLEN.AKKU" ;           //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget - zeichenkette(string)
                                      let dpAlarm="controll-own.0.TABELLEN.AkkuAlarm";      // muss erstellt werden - datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
                                      let dpAlarmMessage="controll-own.0.TABELLEN.AkkuMeessage";                    // muss erstellt werden -  datenpunkt erstellen vom typ "string" Inhalt - alle devices mit lowbat-alarmen
                                      let dpMaterialWidget="controll-own.0.TABELLEN.AkkuMaterialWidget";            // WICHTIG wenn braucheMaterialDesignWidget auf true MATERIALDESIGN List Widget - datenpunkt anlegen : zeichenkette
                                      let dpMaterialWidgetTable="controll-own.0.TABELLEN.AkkuMaterialWidgetTable";  // WICHTIG wenn braucheMaterialDesignWidgetTable auf true MATERIALDESIGN Table Widget - datenpunkt anlegen: zeichenkette
                                      let pfadBilderMaterialWidget="/vis.0/armin/img/marken/"  ;                     //für materialdesign widgets!!! PFAD zu den bildern, die in die vis geladen wurden
                                      let wantAmessage=false;                                      // dieser message datenpunkt kann hier abgeschalten werden
                                      let htmlColorDeviceUeberschrift="#A0C2A0"             //  Farbe der Geräte Marken
                                      let HTMLbrandSetting="b"                              // style der geräte marken:  möglich b fett; i kursiv; span normal
                                      var battAlarm=25;                                     //alarm batterie wert
                                      var battAlarmWarning=40;                                     //warnungen batterie wert
                                      // ------------------------    hier einstellen, was man für adapter hat - die nicht gebraucht werden auf false setzen !!!
                                      var tradfri=false;
                                      var hue=false;
                                      var hueExt=false;
                                      var homematic=true;
                                      var homematicIp=false;
                                      var xiaomi=false;                                                // mihome.0
                                      var fritzDect=false;
                                      var netatmo=false;
                                      var homee=false;
                                      var tado=false;
                                      var zigbee=false;
                                      var zwave=false;
                                      var deconz=true;
                                      var iogo=false;                                                 // iogo - adapter - hat batterie abfrage
                                      var fullyBrowser=false;                                         // fullybrowser - adapter - hat batterie abfrage
                                      var handy1=false;                                              // sind einzelne datenpunkte,
                                      var handy2=false;
                                      //f          ür spezialisten bei devices mit über 3 volt batterien
                                      var bigBattAlarm=3.7; var bigBattWarn=4.1; //WICHTIG bei bigAlarm nicht unter 3.3 gehen !!!!!!!!
                                      var symbolOK="✅";  // auch möglich: ="🟢"}
                                      var symbolKO="❌";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz oder : ="🔴"  ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀 ⛔
                                      var symbolWARN="⚠️";    // ="🟡"
                                      var filterArray=["mihome.5.devices.plug_158d0001f24aad.percent"]; //hier den ganzenpfad von ungewünschten LOW_BAT werten eingeben - diese werden dann gefiltert
        // BEISPIEL var filterArray=["hm-rpc.0.LEQ0242145.0.LOWBAT", "hm-rpc.0.LEQ0242152.0.LOWBAT","hm-rpc.1.OEQ0473764.0.LOWBAT"];
                                      let mySchedule=" */20 * * * * * ";
                                      //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                                      var htmlFeld1='Device';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                                      var htmlFeld2='Wert';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                                      var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                                      //------------------------------hier werden die styles für die tabelle definiert
                                      //ÜBERSCHRIFT ÜBER TABELLE
                                      let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                                      let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                      const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
                                      const htmlFarbUber="white";                         // Farbe der Überschrift
                                      const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                                      const htmlÜberFontGroesse="22px";                       // schriftgröße überschrift
                                      //MEHRERE TABELLEN NEBENEINANDER
                                      let   mehrfachTabelle=3;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                                      const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                                      const farbetrennungsLinie="white";
                                      const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                                      const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                                      //ÜBERSCHRIFT SPALTEN
                                      const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                                      const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
                                      const farbeLinieUnterUeberschrift="white";
                                      const groesseUeberschrift=20;
                                      const UeberschriftStyle="normal"                     // möglich "bold"
                                      //GANZE TABELLE
                                      let abstandZelle="3";
                                      let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                      let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                      let weite="auto";                                     //Weite der Tabelle
                                      let zentriert=true;                                   //ganze tabelle zentriert
                                      const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                                      const htmlSchriftart="RobotoCondensed-Regular"  //"Helvetica";
                                      const htmlSchriftgroesse="18px";
                                      //FELDER UND RAHMEN
                                      let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                                      const htmlFarbFelderschrift="#6E6E6E";                  // SchriftFarbe der Felder
                                      const htmlFarbFelderschrift2="#585858";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                      const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                      const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                      const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                      let htmlRahmenLinien="rows";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                      const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                                      // AB HIER NICHTS  ÄNDERN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                                      let borderHelpBottum;
                                      let borderHelpRight;
                                      let htmlcenterHelp;
                                      let htmlcenterHelp2;
                                      if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                                      if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                                      if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                                      if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                                      zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                                      zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                                      const htmlZentriert='<center>'
                                      const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                                       "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                                       " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                                      // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                                       " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                                       " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                                       "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                                       " </style></head><body> <div>";
                                      //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                                      const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                          "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                                      const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                                      const htmlTabUeber3="</tr>";
                                      //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                                       	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                                      var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                                       "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                                      var myJsonWidget=[];
                                      var myJsonWidget2=[];
                                      var htmlTabUeber="";
                                      var htmlOut="";
                                      var mix;
                                      var counter;
                                      var AkkuAlarm=[];
                                      var alarmMessage=[];
                                      let AkkuMessageLengthAlt=0;
                                      var arrDoppelt=[];
                                      //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                                      var val1; var val0; var val2;
                                      var json1; var json2; var json3; var json4; var json5; var json6; var json3_1=0;
                                      function writeHTML(){
                                       AkkuAlarm=[];
                                      htmlOut="";
                                      counter=-1;
                                      htmlTabUeber="";
                                      switch (mehrfachTabelle) {
                                       case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                                       case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                       case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                                       case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                      if (!UeberschriftSpalten) {htmlTabUeber=""}
                                      //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                                      //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                                      var myColl=[];
                                      var myObjF=[];
                                      var val1help;
                                        if (fritzDect){
                                                  counter=-1;
                                                   for(var i=0;i<mehrfachTabelle;i++ ) {
                                                     val0=""; val1=""; val2="";counter++;tabelleBind();
                                                 //  tabelleMachSchoen()
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">FRITZDECT THERMOSTATE</b>";} else{val0=""; }
                                      counter=-1;
                                      myObjF=[];
                                       $('fritzdect.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                          if (!filterArray.includes(id)){
                                              var ida = id.split('.');
                                              //  counter++;
                                              //  val0=ida[2]+"."+ida[3];
                                                val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                                                json1=val0;
                                                json3_1=val1help=parseFloat((getState(id).val));
                                                if (val1help<=battAlarm) {val1=(" <font color=\"red\"> ")+val1help.toString()+" %";json2=val1help.toString()+" %";json5="red"} else{val1=(" <font color=\"lightgreen\"> ")+val1help.toString()+" %";json2=val1help.toString()+" %",json5="green"}
                                                if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()+" %";json2=val1help.toString()+" %";json5="yellow"}
                                                if (getState(id).val==null) {val2="never used"}; //log(id)};
                                                if (val1help<=battAlarm) {val2=symbolKO} else{val2=symbolOK}
                                                if (val1help>battAlarm && val1help<=battAlarmWarning) val2=symbolWARN;
                                                if (val1help<=battAlarm) AkkuAlarm.push(1);
                                                if (val1help<=battAlarm)  alarmMessage.push(val0);
                                                 json3=val2;
                                                 json6="AVM"
                                                if (braucheMaterialDesignWidget || braucheMaterialDesignWidgetTable) {
                                                   json4=json4=pfadBilderMaterialWidget+"fritzk.png"
                                                   makeJsonWidget(json1,json2,json3,json4,json5,json6,json3_1);}
                                                let help=[val0,val1,val2]; myObjF.push(help);
                                          // tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                                         }  }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                         sortierMal(myObjF);
                                      } //ende fritzdect
                                         if (homee){
                                             tabelleMachSchoen()
                                             counter=-1;
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">HOMEE DEVICES</b>";} else{val0=""; }
                                      myObjF=[];
                                       $('homee.0.*.BatteryLevel*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                             //   counter++;
                                                json1=val0;
                                               //    var val2_1;
                                              //   if (parseInt((new Date().getTime())) - val2_2help < 120000) {val2_1=true} else {val2_1=false;}
                                              //  var val2_2help=Date.parse(getState(id.replace("BatteryStatus","LastUpdate")).val);
                                              //  if (val2_1) {val2=symbolOK} else{val2=symbolKO}
                                                json3=val2;
                                                 json6="HOMEE"
                                                   json4=json4=pfadBilderMaterialWidget+"homeek.png"
                                        sortierMal(myObjF);
                                      } //ende fritzdect
                                         if (netatmo){
                                                   tabelleMachSchoen()
                                                       counter=-1;
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">NETATMO DEVICES</b>";} else{val0=""; }
                                      myObjF=[];
                                       $('netatmo.*.*.*.BatteryStatus').each(function(id, i) {           // netatmo.0.Hinxxxer.Außenmodul-Carport.BatteryStatus
                                      //  if (!filterArray.includes(id)){
                                            //    counter++;
                                                       json1=val0;
                                                //   var val2_1;
                                                      json3=val2;  json6="NETATMO";
                                                   json4=json4=pfadBilderMaterialWidget+"netatmok.png"
                                         /* }*/   }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                         sortierMal(myObjF);
                                      } //ende fritzdect
                                       if (xiaomi){
                                                 tabelleMachSchoen()
                                                 counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">XIAOMI DEVICES</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('mihome.*.devices.*.percent').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                            // log (id)
                                             //   counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                              //  val0=ida[3];
                                            json1=val0;
                                              // log(val0+"   "+id);
                                                if (val1help>battAlarm && val1help<=battAlarmWarning) {json2=val1help.toString()+" %"}
                                                json3=val2; json6="MIHOME/XIAOMI"; //json2="dd"
                                                   json4=json4=pfadBilderMaterialWidget+"xiaomki.png"
                                         sortierMal(myObjF);
                                       } //ende xiaomi
                                      if (hue){
                                                   tabelleMachSchoen()
                                                   counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">HUE DEVICES</b>";} else{val0=""; }
                                         myObjF=[];
                                      $('hue.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                              // counter++;
                                                val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ;   val0=val0.replace(/.battery$/,""); val0=val0.replace("Philips_hue.",""); val0=val0.replace(/_/g," ");                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                                json1=val0;
                                                json3=val2;
                                                 json6="HUE"
                                                   json4=json4=pfadBilderMaterialWidget+"huek.png"
                                          //tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                                      } }); sortierMal(myObjF);
                                       }  //ende hue
                                      if (hueExt){
                                             tabelleMachSchoen()
                                                 counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">HUE EXTENDED</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('hue-extended.*.*.*.config.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                 val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ;   val0=val0.replace("Philips_hue.",""); val0=val0.replace(/_/g," ");                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                                json1=val0;
                                                json3=val2;
                                                 json6="HUE-Extended"
                                       sortierMal(myObjF);
                                        } //ende hue-extended
                                      if (deconz){
                                                  tabelleMachSchoen()
                                                  counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">DECONZ DEVICES</b>";} else{val0=""; }
                                      myObjF=[];
                                      let mydeconzArr=[];
                                      $('deconz.*.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                            if (!filterArray.includes(id)  ){
                                              if (!mydeconzArr.includes(val0)) {
                                              mydeconzArr.push(val0);
                                              json1=val0;
                                             // val1help=getState(id).val;
                                             // if (val1help<=battAlarm) {val2=symbolKO} else{val2=symbolOK}
                                             var jetzt=new Date().getTime();
                                             if(jetzt-getState(id.replace("battery","reachable")).lc>21600000) {  val2="<font color=\"yellow\">dp-warn"} else{
                                              if (getState(id.replace("battery","reachable")).val ) {  val2="<font color=\"lightgreen\"> online"}
                                                   else{ if (jetzt-getState(id.replace("battery","reachable")).lc<3600000) {val2="<font color=\"lightgreen\"> time-online"} else {val2="<font color=\"red\"> offline"}}  }  //{val2=symbolKO} else{val2=symbolOK};
                                            //  log(getState(id.replace("battery","reachable")).lc.toString()+"   "+id +"    " + (jetzt-getState(id.replace("battery","reachable")).lc).toString())          //getState(id.replace("battery","reachable")))
                                               json3=val2; json6="DECONZ"; //json2="dd"
                                              if (val1help>battAlarm && val1help<=battAlarmWarning) //val2=symbolWARN;
                                              json4=pfadBilderMaterialWidget+"deconzk.png"
                                              } // doppelter name
                                      sortierMal(myObjF);
                                         if (zigbee){
                                                  tabelleMachSchoen()
                                                  counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">ZIGBEE DEVICES</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('zigbee.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                              json1=val0;
                                               json3=val2;
                                                 json6="ZIGBEE"
                                                   json4=json4=pfadBilderMaterialWidget+"zigbeek.png"
                                      sortierMal(myObjF);
                                      if (tradfri){
                                            tabelleMachSchoen()
                                                   counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">IKEA TRADFRI</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('tradfri.*.*.batteryPercentage').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                               json1=val0;
                                               json3=val2;
                                                 json6="IKEA"
                                                   json4=json4=pfadBilderMaterialWidget+"tradfrik.png"
                                      sortierMal(myObjF);
                                       if (tado){
                                           tabelleMachSchoen()
                                                  counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">TADO DEVICES</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('tado.*.*.*.*.*.*.info.batteryState').each(function(id, i) {
                                             val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+"."+ida[4]).common.name
                                              json1=val0;
                                             //log(val0+"   "+id);
                                            if (val1help=="LOW") {val1=(" <font color=\"red\"> ")+"low bat"; json2="low";json5="red";json3_1=-1} else{val1=(" <font color=\"lightgreen\"> ")+"full bat";json2="high";json5="green";json3_1=101}
                                            //if (val1help<=battAlarm) {val2="<font color=\"red\"><b>X</b>"} else{val2=symbolOK}
                                            if (val1help=="LOW") {val2="<font color=\"red\">"+symbolKO;json3=symbolKO} else{val2=symbolOK;json3=symbolKO}
                                            //if (val1help) {val2=<font color=\"red\"><b>X</b>} else{val2="✔"}
                                            if (val1help=="LOW") AkkuAlarm.push(1);
                                            if (val1help=="LOW")  alarmMessage.push(val0);
                                                 json6="TADO"
                                                   json4=json4=pfadBilderMaterialWidget+"tadok.png"
                                           } // ende filterArr
                                      sortierMal(myObjF);
                                        }  //ende tado
                                      if (homematic){
                                         tabelleMachSchoen()
                                                  counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">MAX</b>";} else{val0=""; }
                                          arrDoppelt=[];
                                          myObjF=[];
                                      $('maxcube.*.devices.*.battery_low').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                          var arrFilt=[];
                                              $(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+".*").each(function(id, i) {   // kontrolliere ob OPERATING_VOLTAGE vorhanden
                                                  var idc = id.split('.');
                                               arrFilt.push(idc[4])
                                            arrDoppelt.push(ida[0]+"."+ida[1]+"."+ida[2]);
                                         if (arrFilt.includes("BATTERY_STATE")) {
                                                     val0=getObject(id).common.name ;
                                                     var ida = val0.split('.');
                                                     val0=ida[0].replace(/:.+/g,"");
                                                     json1=val0;
                                                     var  val1helper=getState(id.replace("LOW_BAT","BATTERY_STATUS")).val;
                                                     //bigBatterien
                                                     //log (val1helper.toFixed(1))
                                                     if (val1helper>3.2){
                                                            if (val1helper<=bigBattAlarm) {val2=symbolKO;json3=symbolKO} else if (val1helper<=bigBattWarn && val1helper>bigBattAlarm)
                                                               {val2=symbolWARN;json3=symbolWARN} else{val2=symbolOK;json3=symbolOK};
                                                            if (val1helper<=bigBattAlarm) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V";json5="red";json2=val1helper.toFixed(1)+" V"} else if (val1helper<=bigBattWarn && val1helper>bigBattAlarm)
                                                               {val1=(" <font color=\"yellow\"> ")+val1helper.toFixed(1)+" V";json5="Yellow";json2=val1helper.toFixed(1)+" V"} else{val1=(" <font color=\"lightgreen\"> ")+(val1helper.toFixed(1))+" V";json5="lightgreen";json2=val1helper.toFixed(1)+" V"};
                                                            json3_1=Math.abs((val1helper-bigBattAlarm)/((5-bigBattAlarm))*100)
                                                            if (val1helper<bigBattAlarm) AkkuAlarm.push(1);
                                                            if (val1helper<=bigBattAlarm)  alarmMessage.push(val0);
                                                     else {
                                                           if (val1helper<=1.5){
                                                              if (val1helper<1.1) {val2=symbolKO;json3=symbolKO} else if (val1helper<=1.2 && val1helper>=1.1)
                                                              if (val1helper<1.1) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V";json5="red";json2=val1helper.toFixed(1)+" V"} else if (val1helper<=1.2 && val1helper>=1.1)
        {val1=(" <font color=\"yellow\"> ")+val1helper.toFixed(1)+" V";json5="yellow";json2=val1helper.toFixed(1)+" V"} else{val1=(" <font color=\"lightgreen\"> ")+val1helper.toFixed(1)+" V";json5="lightgreen";json2=val1helper.toFixed(1)+" V"};
                                                               json3_1=Math.abs((val1helper-1.1)/((1.5-1.1))*100)
                                                              if (val1helper<1.1) AkkuAlarm.push(1);
                                                              if (val1helper<1.1)  alarmMessage.push(val0)
                                                           } else {
                                                              if (val1helper<2.4) {val2=symbolKO;json3=symbolKO} else if (val1helper<=2.5 && val1helper>=2.2)
                                                              if (val1helper<2.2) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V";json5="red";json2=val1helper.toFixed(1)+" V"} else if (val1helper<=2.5 && val1helper>=2.2)
                                                              json3_1=Math.abs((val1helper-2.2)/((3-2.2))*100)
                                                              if (val1helper<2.2) AkkuAlarm.push(1);
                                                              if (val1helper<2.2)  alarmMessage.push(val0);}}
                                           } else {
                                                    json1=val0;
                                                    if (val1help) {val1=(" <font color=\"red\"> ")+"low bat"; json2="low";json5="red";json3_1=0} else{val1=(" <font color=\"lightgreen\"> ")+"full bat";json2="high";json5="green";json3_1=100}
                                                    if (val1help) {val2=symbolKO;json3=symbolKO} else{val2=symbolOK;json3=symbolKO}
                                                   let jetzt=new Date().getTime(); let working=true ;
                                                   if (existsState(id.replace("battery_low","working"))) {if( !getState(id.replace("battery_low","working")).val ){working=false}}
                                                 if(jetzt-getState(id.replace("battery_low","error")).lc>21600000 || jetzt-getState(id.replace("battery_low","link_error")).lc>21600000 ) {  val2="<font color=\"yellow\">dp-warn"} else{     //43200000
                                                 if (!getState(id.replace("battery_low","error")).val && !getState(id.replace("battery_low","link_error")).val && working) {  val2="<font color=\"lightgreen\"> online"}
                                                         else {if (jetzt-getState(id.replace("battery_low","error")).lc<3600000 || jetzt-getState(id.replace("battery_low","link_error")).lc<3600000)
        {val2="<font color=\"lightgreen\"> time-online"} else {val2="<font color=\"red\"> offline"} } } //{val2=symbolKO} else{val2=symbolOK};
                                               // log(getState(id.replace("battery_low","link_error")).lc.toString()+"   "+getState(id.replace("battery_low","error")).lc.toString()+"   "+id +"    " + (jetzt-getState(id.replace("battery_low","error")).lc).toString())
                                                    if (val1help) AkkuAlarm.push(1);
                                                    if (val1help)  alarmMessage.push(val0);
                                                 json3=val2;
                                                 json6="HOMEMATIC"
                                                   json4=pfadBilderMaterialWidget+"homematick.png"
                                      //sortierMal(myObjF);
                                      //log(arrDoppelt.toString())
                                      //myObjF=[];
                                      $('hm-rpc.*.*.0.LOWBAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                        //  log(id)
                                       //    if (!filterArray.includes(id) && !arrDoppelt.includes(ida[0]+"."+ida[1]+"."+ida[2]+".*.BATTERY_STATE") ) {
                                                   if (!filterArray.includes(id) && !arrDoppelt.includes(ida[0]+"."+ida[1]+"."+ida[2]) ) {
                                             json1=val0;
                                             //log(val0+"   "+id);
                                            val1help=getState(id).val; //log(typeof getState(id).val)
                                      // if(val1help!=null){
                                         if(typeof getState(id).val!="number"){
                                            if (val1help) {val2="<font color=\"red\">"+symbolKO;json3=symbolKO} else{val2=symbolOK;json3=symbolKO}
                                         } else {val1=(" <font color=\"yellow\"> ")+"no bat val"; json2="no bat val";json5="yellow";json3_1=0;val2="<font color=\"yellow\">"+symbolWARN;json3=symbolWARN; }
                                                 json6="HOMEMATIC"
                                                   json4=json4=pfadBilderMaterialWidget+"homematick.png"
                                      sortierMal(myObjF);
                                        } //ende hm
                                      if (homematicIp ){
                                          tabelleMachSchoen()
                                                     counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">HOMEMATIC IP</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('hm-rpc.*.*.0.LOW_BAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                            var arrFilt=[];
                                            // log(arrFilt.toString());
                                           if (arrFilt.includes("OPERATING_VOLTAGE")) {
                                                     //  val0=getObject(id).common.name ;
                                                       json1=val0;
                                                       var  val1helper=getState(id.replace("LOW_BAT","OPERATING_VOLTAGE")).val;
                                                       //bigBatterien
                                                            json3_1=(val1helper-bigBattAlarm)/((5-bigBattAlarm))*100
                                                     else {
                                                              json3_1=(val1helper-1.1)/((1.5-1.1))*100
                                                           } else {
                                                              if (val1helper<2.4) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V";json5="red";json2=val1helper.toFixed(1)+" V"} else if (val1helper<=2.5 && val1helper>=2.2)
                                                              json3_1=(val1helper-2.4)/((3-2.4))*100
                                                              if (val1helper<2.4) AkkuAlarm.push(1);
                                                              if (val1helper<2.4)  alarmMessage.push(val0);}}
                                             } else {
                                                    json1=val0;
                                                 json3=val2;
                                                 json6="HOMEMATIC-IP"
                                             $('hmip.*.*.0.lowBat').each(function(id, i) {
                                                    json1=val0;
                                                    if (val1help=="true") {val1=(" <font color=\"red\"> ")+"low bat"; json2="low";json5="red";json3_1=0} else{val1=(" <font color=\"lightgreen\"> ")+"full bat";json2="high";json5="green";json3_1=100}
                                                    if (val1help=="true") {val2=symbolKO;json3=symbolKO} else{val2=symbolOK;json3=symbolKO}
                                                    if (val1help=="true") AkkuAlarm.push(1);
                                                    if (val1help=="true")  alarmMessage.push(val0);
                                                 json3=val2;
                                      sortierMal(myObjF);
                                       }  //ende hm-ip
                                           if (zwave){
                                               tabelleMachSchoen()
                                                       counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">ZWAVE DEVICES</b>";} else{val0=""; }
                                        myObjF=[];
                                       $('zwave.*.*.BATTERY.Battery_Level*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                              //  counter++;
                                                json1=val0;
                                               //    var val2_1;
                                                json3=val2;
                                                 json6="ZWAVE"
                                                   json4=json4=pfadBilderMaterialWidget+"zwavek.png"
                                        sortierMal(myObjF);
                                      } //ende fritzdect
                                       if (fullyBrowser){
                                           tabelleMachSchoen()
                                                   counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">FULLYBROWSER</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('fullybrowser.*.*.Info.batteryLevel').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                val0=getState(id.replace("batteryLevel","deviceName")).val;
                                                json1=val0;
                                                json3=val2;
                                                 json6="FULLY BROWSER"
                                                   json4=json4=pfadBilderMaterialWidget+"fullyk.png"
                                       sortierMal(myObjF);
                                       } //ende fullybrowser
                                       if (iogo){
                                                 tabelleMachSchoen()
                                                   counter=-1
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">>HANDY über IOGO</b>";} else{val0=""; }
                                      myObjF=[];
                                      $('iogo.*.*.battery.level').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                             //   val0=ida[3];
                                                json1=val0;
                                                json3=val2;
                                                 json6="IOGO"
                                                   json4=json4=pfadBilderMaterialWidget+"iogok.png"
                                      sortierMal(myObjF);
                                       } //ende iogo
                                        if (handy1){
                                            tabelleMachSchoen()
                                                      counter=-1
                                                     tabelleMachSchoen()
                                                       if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">HANDYs</b>";} else{val0=""; }
                                             myObjF=[];
                                             $('controll-own.0.HANDY.*batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                              val0=ida[3];
                                              json1=val0;
                                              json3=val2;
                                                 json6="HANDYs"
                                                   json4=json4=pfadBilderMaterialWidget+"handyk.png"
                                              sortierMal(myObjF);
                                        } //ende handy1
                                        if (handy2){
                                            myObjF=[];
                                                 $('controll-own.0.HANDY.*Batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                              val0=ida[3];
                                              json1=val0;
                                              if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()}
                                              json3=val2;
                                                 json6="HANDYs"
                                                  sortierMal(myObjF);
                                        } //ende handy2
                                      //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                          tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                                         setState(dpAlarm,AkkuAlarm.length);
                                         setState(dpAlarmMessage,alarmMessage.toString()); AkkuMessageLengthAlt=AkkuAlarm.length;
                                         alarmMessage=[];
                                      } // function ende
                                      //MAIN:
                                      schedule(mySchedule,  function () {
                                      writeHTML();
                                      if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                      writeHTML();
                                      if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}                                 //     <tdalign style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                       function makeJsonWidget(vax1,vax2,vax3,vax4,vax5,vax6,vax3_1) {
                                      //log(vax3+vax6+htmlFeld1)
                                         if ( braucheMaterialDesignWidgetTable) {
                                         myJsonWidget.push({
                                             Device : vax1,
                                             Wert : vax2,
                                             Status : vax3,
                                             Hersteller : vax4,
                                             helpSort : vax3_1
                                      //	log(myJsonWidget)
                                      if (braucheMaterialDesignWidget) {
                                      let mysubText = `<div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;">
        <div style="flex: 1;">${vax2}</div>
        <div style="color: grey; font-size: 16px; font-family: RobotoCondensed-LightItalic; text-align: right;">${vax6}</div>
        </div>`
                                           myJsonWidget2.push({
                                                     text: vax1,
                                                     subText: mysubText,
                                                     statusBarColor: vax5,
                                                     image: vax4,
                                                     imageColor: "",
                                                     listType: "text",
                                                     showValueLabel: false,
                                                     status: vax3,
                                                     Wert : vax2,
                                                     Hersteller : vax4,
                                                     helpSort : vax3_1
                                       function tabelleBind(){
                                         //  counter=counter+mehrfachTabelle;
                                               case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                                               case 2: if(counter%4==0){
                                                          if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                                            }else{
        if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                                               case 3:if(counter%2==0)   {
                                                          if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        "; \"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
        } break;}else{
                                                          if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        } break;}
                                               case 4:  // counter=counter+8;
                                                         if(counter%8==0)   {
                                                         if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
                                                         if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                                              } //switch ende
                                      function tabelleMachSchoen() {
                                             case 1:    break;
                                             case 2:
                                                        if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                        break;
                                             case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                       if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                       if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                        break;
                                             case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                       if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                       if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                       if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                       break; }
                                      function tabelleFinish() {
                                             case 1:    break;
                                             case 2:
                                                        break;
                                                        break;
                                                       break; }
                                             var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                           var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                            if (!htmlSignature) htmlUnter="";
                                              //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                               var htmlOutVIS="";
                                             //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                                if (htmlUberschrift)
                                                    { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                                  } else {
                                                   zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                                      // log("bin raus aus tabelleBind");
                                               if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                                               //console.log dpVIS;
                                      var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                      var htmlEnd="</table>"+htmlUnter+"</div></body>";
                                      //mit oder ohne überschrift - zentriert oder links
                                      htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                                      //log(htmlOut);
                                             setState(dpMaterialWidget,JSON.stringify(myJsonWidget2));
                                             myJsonWidget2=[];
                                      if (braucheMaterialDesignWidgetTable) {
                                        setState(dpMaterialWidgetTable,JSON.stringify(myJsonWidget));
                                           myJsonWidget=[];
                                      function sortierMal(myObjF) {
                                                  myObjF.sort(function (alpha, beta) {
                                                  if ((alpha[0].toUpperCase()).trim() > (beta[0].toUpperCase()).trim())
                                                     return 1;
                                                  if ((beta[0].toUpperCase()).trim() > (alpha[0].toUpperCase()).trim())
                                                     return -1;
                                                  return 0;
                                                  for(var i=0;i<myObjF.length;i++) {
                                                     counter++
                                                     val0=myObjF[i][0] ;
                                                     val1=myObjF[i][1] ;
                                                     val2=myObjF[i][2] ;
                                                  tabelleBind(); }
                                      • Christoph1337C
                                        Christoph1337C
                                        Christoph1337
                                        #1024
                                        09:43:52.320	info	javascript.0 (1372) Stop script script.js.System.BatteryMonitor
                                        09:43:52.349	info	javascript.0 (1372) Start javascript script.js.System.BatteryMonitor
                                        09:43:52.436	warn	javascript.0 (1372) at writeHTML (script.js.System.BatteryMonitor:1196:4)
                                        09:43:52.436	warn	javascript.0 (1372) at script.js.System.BatteryMonitor:1209:1
                                        09:43:52.437	info	javascript.0 (1372) script.js.System.BatteryMonitor: registered 0 subscriptions and 1 schedule
                                        Hmm entweder mach ich noch was falsch oder das Script hat noch einen Fehler =)
                                          liv-in-skyL
                                          liv-in-skyL
                                          #1025
                                          @Christoph1337 das schaut eher nach einem kopierfehler aus
                                          nutze mal das hier - und ändere bzw. gleiche nur den datenpunkt im script an - dpVIS (von dir)
                                          und natürlich die dpAlarm und DpAlarmMessage datenpunkte !!!
                                          let   braucheEinFile=false;                          // bei true wird ein file geschrieben - NUR FÜR IQONTROL oder DIRECT BROWSER-Aufruf
                                          var tradfri=false;
                                          var hue=false;
                                          var hueExt=false;
                                          var homematic=true;
                                          var netatmo=false;
                                          var homee=false;
                                          var tado=false;
                                          var zigbee=false;
                                          var zwave=false;
                                          var deconz=true;
                                          var handy2=false;
                                          //GANZE TABELLE
                                          //FELDER UND RAHMEN
                                          let htmlcenterHelp;
                                          var htmlOut="";
                                          var mix;
                                          var counter;
                                          var AkkuAlarm=[];
                                          var arrDoppelt=[];
                                           AkkuAlarm=[];
                                          htmlOut="";
                                          counter=-1;
                                          htmlTabUeber="";
                                          var myColl=[];
                                          var myObjF=[];
                                          var val1help;
                                            if (fritzDect){
                                                      counter=-1;
                                          counter=-1;
                                          myObjF=[];
                                                  //  counter++;
                                                    json1=val0;
                                                     json3=val2;
                                                     json6="AVM"
                                             sortierMal(myObjF);
                                          } //ende fritzdect
                                             if (homee){
                                                 tabelleMachSchoen()
                                                 counter=-1;
                                          myObjF=[];
                                                 //   counter++;
                                                    json1=val0;
                                                   //    var val2_1;
                                                    json3=val2;
                                                     json6="HOMEE"
                                            sortierMal(myObjF);
                                          } //ende fritzdect
                                             if (netatmo){
                                                       tabelleMachSchoen()
                                                           counter=-1;
                                          myObjF=[];
                                                //    counter++;
                                                           json1=val0;
                                                    //   var val2_1;
                                             sortierMal(myObjF);
                                          } //ende fritzdect
                                           if (xiaomi){
                                                     tabelleMachSchoen()
                                                     counter=-1
                                          myObjF=[];
                                                // log (id)
                                                  //  val0=ida[3];
                                                json1=val0;
                                             sortierMal(myObjF);
                                           } //ende xiaomi
                                          if (hue){
                                                       tabelleMachSchoen()
                                                       counter=-1
                                             myObjF=[];
                                                  // counter++;
                                                    json1=val0;
                                                    json3=val2;
                                                     json6="HUE"
                                           }  //ende hue
                                          if (hueExt){
                                                 tabelleMachSchoen()
                                                     counter=-1
                                          myObjF=[];
                                                    json1=val0;
                                                    json3=val2;
                                           sortierMal(myObjF);
                                          if (deconz){
                                                      tabelleMachSchoen()
                                                      counter=-1
                                          myObjF=[];
                                          let mydeconzArr=[];
                                                  json1=val0;
                                                  } // doppelter name
                                          sortierMal(myObjF);
                                             if (zigbee){
                                                      tabelleMachSchoen()
                                                      counter=-1
                                          myObjF=[];
                                                  json1=val0;
                                                   json3=val2;
                                                     json6="ZIGBEE"
                                          sortierMal(myObjF);
                                          if (tradfri){
                                                tabelleMachSchoen()
                                                       counter=-1
                                          myObjF=[];
                                                   json1=val0;
                                                   json3=val2;
                                                     json6="IKEA"
                                          sortierMal(myObjF);
                                           if (tado){
                                               tabelleMachSchoen()
                                                      counter=-1
                                          myObjF=[];
                                                  json1=val0;
                                                 //log(val0+"   "+id);
                                                     json6="TADO"
                                               } // ende filterArr
                                          sortierMal(myObjF);
                                            }  //ende tado
                                          if (homematic){
                                             tabelleMachSchoen()
                                                      counter=-1
                                              arrDoppelt=[];
                                              myObjF=[];
                                              var arrFilt=[];
                                                         json1=val0;
                                                         //bigBatterien
                                                         else {
                                                               } else {
                                               } else {
                                                        json1=val0;
                                                     json3=val2;
                                                     json6="HOMEMATIC"
                                          //myObjF=[];
                                            //  log(id)
                                                 json1=val0;
                                                 //log(val0+"   "+id);
                                                     json6="HOMEMATIC"
                                          sortierMal(myObjF);
                                            } //ende hm
                                          if (homematicIp ){
                                              tabelleMachSchoen()
                                                         counter=-1
                                          myObjF=[];
                                                var arrFilt=[];
                                                           json1=val0;
                                                           //bigBatterien
                                                         else {
                                                               } else {
                                                 } else {
                                                        json1=val0;
                                                     json3=val2;
                                                        json1=val0;
                                                     json3=val2;
                                          sortierMal(myObjF);
                                           }  //ende hm-ip
                                               if (zwave){
                                                   tabelleMachSchoen()
                                                           counter=-1
                                            myObjF=[];
                                                  //  counter++;
                                                    json1=val0;
                                                   //    var val2_1;
                                                    json3=val2;
                                                     json6="ZWAVE"
                                            sortierMal(myObjF);
                                          } //ende fritzdect
                                           if (fullyBrowser){
                                               tabelleMachSchoen()
                                                       counter=-1
                                          myObjF=[];
                                                    json1=val0;
                                                    json3=val2;
                                           sortierMal(myObjF);
                                           if (iogo){
                                                     tabelleMachSchoen()
                                                       counter=-1
                                          myObjF=[];
                                                 //   val0=ida[3];
                                                    json1=val0;
                                                    json3=val2;
                                                     json6="IOGO"
                                          sortierMal(myObjF);
                                           } //ende iogo
                                            if (handy1){
                                                tabelleMachSchoen()
                                                          counter=-1
                                                         tabelleMachSchoen()
                                                 myObjF=[];
                                                  val0=ida[3];
                                                  json1=val0;
                                                  json3=val2;
                                                     json6="HANDYs"
                                                  sortierMal(myObjF);
                                            } //ende handy1
                                            if (handy2){
                                                myObjF=[];
                                                  val0=ida[3];
                                                  json1=val0;
                                                  json3=val2;
                                                     json6="HANDYs"
                                                      sortierMal(myObjF);
                                            } //ende handy2
                                             alarmMessage=[];
                                          } // function ende
                                          //MAIN:
                                          writeHTML();
                                          writeHTML();
                                             myJsonWidget.push({
                                                 Device : vax1,
                                                 Wert : vax2,
                                                 Status : vax3,
                                                 Hersteller : vax4,
                                                 helpSort : vax3_1
        </div>`
                                                         text: vax1,
                                                         subText: mysubText,
                                                         image: vax4,
                                                         imageColor: "",
                                                         listType: "text",
                                                         status: vax3,
                                                         Wert : vax2,
                                                         Hersteller : vax4,
                                                         helpSort : vax3_1
        }else{
        } break;}else{
        } break;}
                                                             if(counter%8==0)   {
        } break;}else{
        } break;}
                                                  } //switch ende
                                                 case 1:    break;
                                                 case 2:
                                                            break;
                                                            break;
                                                           break; }
                                                 case 1:    break;
                                                 case 2:
                                                            break;
                                                            break;
                                                           break; }
                                                   var htmlOutVIS="";
                                                      } else {
                                          //log(htmlOut);
                                                 myJsonWidget2=[];
                                               myJsonWidget=[];
                                                         return 1;
                                                         return -1;
                                                      return 0;
                                                         counter++
                                                         val0=myObjF[i][0] ;
                                                         val1=myObjF[i][1] ;
                                                         val2=myObjF[i][2] ;
                                                      tabelleBind(); }
                                          Christoph1337C 1 Antwort Letzte Antwort
                                          33.2k
                                          84.3k
