  4. Javaskript Adapter fehler
javaskript
3 Beiträge 2 Kommentatoren 208 Aufrufe 2 Beobachtet
    Malz1902
    Hallo, habe seit heute das Problem wen ich den Javaskript Adapter starte kommt folgendes:
    host.raspberrypi	2020-06-10 18:55:34.774	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-06-10 18:55:34.774	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    host.raspberrypi	2020-06-10 18:55:34.774	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.raspberrypi	2020-06-10 18:55:34.774	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    host.raspberrypi	2020-06-10 18:55:34.773	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-06-10 18:55:34.773	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-06-10 18:55:34.773	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-06-10 18:55:34.773	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-06-10 18:55:34.773	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-06-10 18:55:34.773	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.raspberrypi	2020-06-10 18:55:34.773	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
    host.raspberrypi	2020-06-10 18:55:34.772	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2020-06-10 18:55:34.771	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2020-06-10 18:55:34.771	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-06-10 18:55:34.771	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-06-10 18:55:34.771	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-06-10 18:55:34.771	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-06-10 18:55:34.771	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-06-10 18:55:34.770	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
    host.raspberrypi	2020-06-10 18:55:34.770	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2020-06-10 18:55:34.770	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2020-06-10 18:55:34.770	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    host.raspberrypi	2020-06-10 18:55:34.770	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    host.raspberrypi	2020-06-10 18:55:34.770	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    host.raspberrypi	2020-06-10 18:55:34.770	error	Caught by controller[0]: ^
    host.raspberrypi	2020-06-10 18:55:34.769	error	Caught by controller[0]: throw err;
    host.raspberrypi	2020-06-10 18:55:34.769	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
    Heute morgen ging es noch so gegen Mittag dann nicht mehr. Kann das sagen weil ich nen JS habe weches mir Push Nachrichten auf mein Handy schickt wenn ein Fenster auf geht das passiert nun nicht mehr. Testnachricht via Pushover ADAPTER KAM SOFORT AN
    Sowohl bei JS Controller 3.1.4 als auch jetzt bei 3.1.5
    • M Malz1902
      arteckA Offline
      arteckA Offline
      arteck
      @Malz1902 sagte in Javaskript Adapter fehler:
      typescript
      welche version den javascript ?
        Malz1902
        War die neuste 4.6.17 habe wieder auf 4.6.4 downgegraded, da klappt alles
