  4. Badradio
    5.4k
Badradio
blockly
75 Beiträge 10 Kommentatoren 7.1k Aufrufe 7 Beobachtet
  • L Offline
    lustig29
    Schon mal vielen Dank
    • L lustig29
      Jan1
      @lustig29
      So, leg mal ein neues Script an und importiere das:
       <block type="on" id="{!Ow5W{xI=1u8E[NnSUK" x="-462" y="-837">
         <field name="OID">zigbee.0.00158d0003d01800.occupancy</field>
         <statement name="STATEMENT">
           <block type="controls_if" id="Kx3vNe=R:}qK8)0gWt@">
             <value name="IF0">
               <block type="logic_operation" id="mQ/dx2,-_w5IG$iE;)@J" inline="false">
                 <field name="OP">AND</field>
                 <value name="A">
                   <block type="time_compare_ex" id="Tt0_xmUcA.@q=R^6c?K">
                     <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                     <field name="USE_ACTUAL_TIME">TRUE</field>
                     <field name="OPTION">between</field>
                     <value name="START_TIME">
                       <shadow type="text" id="Ds2^t-6oqCLq{#P9fh(/">
                         <field name="TEXT">4:30</field>
                       </shadow>
                     </value>
                     <value name="END_TIME">
                       <shadow type="text" id="gu#LKi_N|YJrLy[.i6XR">
                         <field name="TEXT">22:00</field>
                       </shadow>
                     </value>
                   </block>
                 </value>
                 <value name="B">
                   <block type="on_source" id="9crFy+ImY/x|/4%_|Iuh">
                   </block>
                 </value>
               </block>
             </value>
             <statement name="DO0">
               <block type="control" id="TRm-bdzi{$v{QvI#@fS">
                 <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Music-Provider.TuneIn</field>
                 <value name="VALUE">
                   <block type="text" id="{@B(Gr@ct{NE%}(eE:bA">
                     <field name="TEXT">HR 3</field>
                   </block>
                 </value>
                 <next>
                   <block type="control" id="-K*]=!?T(x=t3aH]yXB">
                     <field name="OID">javascript.0.scriptEnabled.Alexa.Musik_an</field>
                       <block type="logic_boolean" id="R4Lwk@QMSU7wLUUR_{)">
                       </block>
                     </value>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </statement>
         <next>
           <block type="on" id="sM:.Y~^%@f(]1=[;xCd]">
             <field name="OID">zigbee.0.00158d0003cd921c.opened</field>
               <block type="controls_if" id="5cj)P381Yi%K(%Q6B4l">
                 <value name="IF0">
                   <block type="logic_operation" id="xRm)qTm9{hP%Om6X$S" inline="false">
                     <value name="A">
                       <block type="on_source" id="FQBb^YFSsXxvNU,7?;g7">
                       </block>
                     </value>
                     <value name="B">
                       <block type="get_value" id="I,5DN_vB(m]L_X%%l0C">
                       </block>
                     </value>
                   </block>
                 </value>
                   <block type="control" id="-YhxQx;-Ohq38S3jpH,F">
                     <field name="OID">alexa2.0.Echo-Devices.G2A0QU0574740N2B.Player.controlPause</field>
                       <block type="logic_boolean" id=".=Zr.OXX+3jD[5g4N84O">
                       </block>
                     </value>
                     <next>
                       <block type="control" id="z.h$,n|N2GUp46ne8_SS">
                           <block type="logic_boolean" id="#Lz~5_ooORwjdqU#Xd|]">
                           </block>
                         </value>
                         <next>
                           <block type="control" id="oQu-RS?b?*%VTU/wm#PF">
                               <block type="logic_boolean" id="J5VYYL98Ib}qaE`GTXmi">
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </statement>
           </block>
         </next>
       </block>
      </xml>
      Dann kannst Deins einfach ausschalten und schauen, welches besser läuft.
      Siehst ja schon, dass das deutlich weniger Code ist :-)
      L 1 Antwort Letzte Antwort
      • L Offline
        lustig29
        Danke dir
        • J Jan1
          @lustig29
                 <value name="IF0">
                     <value name="A">
                           </shadow>
                         </value>
                           </shadow>
                         </value>
                       </block>
                     </value>
                     <value name="B">
                       </block>
                     </value>
                   </block>
                 </value>
                       </block>
                     </value>
                     <next>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </statement>
             <next>
                     <value name="IF0">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                             <next>
                                   </block>
                                 </value>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
          </xml>
          lustig29
          @Jan1 Dein Skript funktioniert super. Nochmals vielen Dank. Nur leider scheint wohl immer noch ein Fehler in meinem System zu sein. Immer wenn ich auf einem anderen Echo Gerät eine Wiedergabe laufen habe, z.B.: Bluetooth oder ein andere Tunein Sender und ich gehe dann ins Bad, springt die Wiedergabe auf dem entsprechenden Gerät um auf Hr 3, dem eingestelltem Sender in meinem Skript
          A J 2 Antworten Letzte Antwort
          • L lustig29
            Adnim
            @lustig29
            Würde empfehlen mitabzufragen ob die Alexa bereits spielt und dann nicht jedes mal neu HR3 abzuspielen, dann kannste manuell an dem Echo nix mehr machen weils immer übersteuert wird...
            Das Phrase to play with tune in ist das im Objektbaum unter dem Echo welchen du ansteuern willst?
            • L lustig29
              Jan1
              @lustig29
              Ich vermute auch , dass Du noch den falschen DP verwendest um den Radio zu starten, da das bei mir egal ist wenn in einem andern Zimmer ein Sender läuft. Du musst eben nur den DP des betreffend Dot setzten. Ansonsten das was @Adnim geschrieben hat, kann nie schaden.
              • J Jan1
                @lustig29
                lustig29
                @Jan1 welcher Datenpunkt ist denn richtig? Ich habe jetzt nochmal einem im Alexa/Player Ordner erstellt. Aber leider bleibt es noch dabei, wenn ich auf einem anderen Gerät eine Musikwiedergabe starten will kommt auf dem angesprochenem Echo nichts, und im Bad stoppt Hr3 und die angeforderte Wiedergabe startet dort
                • L lustig29
                  Jan1
                  @lustig29
                  Ich verwende diesen
                  Den DP den Du in den Screenshots drin hast kenne ich nicht und würde mich mal interessieren wo Du den her hast. Im Alexa Adapter finde ich den nicht.
                  • J Jan1
                    @lustig29
                    Ich verwende diesen
                    lustig29
                    @Jan1 na den hab ich selber erstellt. Verstehe halt nur nicht, wie ich da festlegen kann, dass nur der Echo im Bad läuft und die Wiedergabe nicht gestoppt wird wenn ich einen anderen Echo anspreche und eine Wiedergabe starte
                    • L lustig29
                      crunchipC Offline
                      crunchipC Offline
                      @lustig29 du öffnest alexa2.0.Echo-Devices darin befinden sich all deine Geräte, dort öffnest du deinen entsprechenden Dot/Echo.
                      unter Music Provider sind deine drei "Anbieter" Amazon/Spotify/Tuneln gelistet
                      darunter im Menüpunkt Player, öffnest du die control buttons
                        lustig29
                        @crunchip genauso habe ich es gemacht. Aber es funktioniert leider nur so wie oben beschrieben
                        crunchipC J 2 Antworten Letzte Antwort
                        • L lustig29
                          crunchipC Offline
                          crunchipC Offline
                          @lustig29 sagte in Badradio:
                          kann nicht sein, dann hast du irgendwo was durcheinander gebracht, oder läuft irgendwo noch ein zweites script und vllt vergessen zu deaktivieren?
                          dort erstellt man nichts, das wird alles automatisch angelegt
                          • L lustig29
                            Jan1
                            @lustig29
                            So langsam versteh ich Dich nicht mehr. Ich schreib Dir schon von Anfang an, dass Du eventuell den falschen DP verwendest und mit welchem ich das mache und anstatt Du endlich mal den DP verwendest, den jeder andere der Dein Problem nicht hat auch verwendet, verwendest Du einen selbst erstellten und verrätst nicht mal was der genau macht oder was der überhaupt steuert, wunderst Dich aber immer noch, dass Du Dein altes Problem hast. Im Alexa Adapter wird für jedes Gerät ein passender DP zur Verfügung gestellt, der exakt das macht was Du haben möchtest. Nimm endlich diese und es läuft.
                            Ich bin dann raus hier.
                            • J Jan1
                              @lustig29
                              lustig29
                              @Jan1 sorry,wollte dich nicht verärgern, aber vielleicht bin ich ja nur zu blöd dazu.
                              Anbei mein aktuell laufendes Skript. Mit dem aktivierten Datenpunkt des Alexa2 Adapters.
                              Ich gehe ins Bad, Hr3 startet. Gehe dann in die Küche sage, Alexa: " Alexa starte Antenne Bayern auf Tunein" Echo im Bad wechselt den Sender auf Antenne Bayern, in der Küche kommt nichts...Jan1.png Jan2.png
                              • L lustig29
                                Jan1
                                @lustig29
                                Und das ist eben der allgemeine DP und somit der falsche. Schau mal was unter Player drin steht, da ist nämlich genau der den ich die ganze Zeit poste und Du das fleißig ignorierst ;-)
                                Somit ist meine Aussage, dass Du den falschen DP verwendest von Beginn an richtig.
                                • J Jan1
                                  @lustig29
                                  lustig29
                                  @Jan1 habe den Datenpunkt unter Player genommen. Ist aber leider immer noch so, dass der Sender umgeschaltet wird. Kann es vielleicht mit der Multiroomgruppe Bad/Küche zu tun haben?
                                  • L lustig29
                                    Jan1
                                    @lustig29
                                    na daran kann es auch liegen, da das ne Gruppe ist und somit verbunden. Ein Grund warum ich das bei mir nicht mehr verwende, da das etwas seltsam reagiert.
                                    • J Jan1
                                      @lustig29
                                      lustig29
                                      @Jan1 habe alle Multiroomgruppen in der Alexa App gelöscht und siehe da, jetzt läuft es. 😊
                                      Wenn ich nun Multiroom nutzen möchte kann ich das doch bestimmt auch mit Hilfe eines Skriptes oder? Ich meine, wenn ich zum Beispiel zu Alexa sage: " Starte Multiroom, dass ein Skript gestartet wird, dass die Musikwiedergabe auf mehreren Echo´s gleichzeitig startet.
                                      • L lustig29
                                        Jan1
                                        @lustig29
                                        musst probieren
                                        L 2 Antworten Letzte Antwort
                                        • J Jan1
                                          @lustig29
                                          musst probieren
                                          lustig29
                                          @Jan1 ok, danke nochmal:man-raising-hand:
