  4. javascript fehler nach update
velux-klf200-apijs controller
3 Beiträge 2 Kommentatoren 430 Aufrufe 3 Beobachtet
  • Z Offline
    Z Offline
    Zeiss
    schrieb am zuletzt editiert von Zeiss
    ich steuere meine Velux Rollos mit der velux-klf-api,
    gestern habe ich meinem iobroker mal allen updates gegönnt
    und erhalte folgende Fehlermeldungen.
    javascript.0	2020-06-10 13:13:05.204	error	(29393) Error: timeout GW_STATUS_REQUEST_CFM
    javascript.0	2020-06-10 13:13:05.203	error	(29393) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0	2020-06-10 13:12:05.141	error	at processTimers (internal/timers.js:492:7)
    javascript.0	2020-06-10 13:12:05.141	error	at listOnTimeout (internal/timers.js:549:17)
    javascript.0	2020-06-10 13:12:05.141	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/velux-klf200-api/lib/net.js:169:19)
    javascript.0	2020-06-10 13:12:05.141	error	(29393) Error: timeout GW_STATUS_REQUEST_CFM
    javascript.0	2020-06-10 13:12:05.140	error	(29393) Error: timeout GW_STATUS_REQUEST_CFM
    javascript.0	2020-06-10 13:12:05.140	error	(29393) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0	2020-06-10 13:11:14.308	error	at processTimers (internal/timers.js:492:7)
    javascript.0	2020-06-10 13:11:14.308	error	at listOnTimeout (internal/timers.js:549:17)
    javascript.0	2020-06-10 13:11:14.308	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/velux-klf200-api/lib/net.js:169:19)
    javascript.0	2020-06-10 13:11:14.308	error	(29393) Error: timeout GW_STATUS_REQUEST_CFM
    javascript.0	2020-06-10 13:11:14.307	error	(29393) Error: timeout GW_STATUS_REQUEST_CFM
    javascript.0	2020-06-10 13:11:14.306	error	(29393) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0	2020-06-10 13:11:09.300	info	(29393) script.js.Velux: Klf connected!
    leider habe ich zu wenig Ahnung, aber vielleicht weiß jemand wie ich das beheben kann.
    Das Script selbst funktioniert, ich kann meine Rollos steuern.
    Danke im voraus
    • Z Zeiss
      Danke im voraus
      arteckA Offline
      arteckA Offline
      arteck
      @Zeiss sagte in javascript fehler nach update:
      velux-klf-api
      zeigmal das script
      Z 1 Antwort Letzte Antwort
      • arteckA arteck
        velux-klf-api
        zeigmal das script
        Z Offline
        Z Offline
        Zeiss
        @arteck said in javascript fehler nach update:
        velux-klf-api
        zeigmal das script
        'use strict' ;
        // Netzwerk
        const Ip       = '192.168.2.89'
        const Passwort = '*************italicised text*' // WLAN Passwort
        const baseObjectPath = 'javascript.0.Velux.'
        const harmony = '1'
        const Rollos = {
            RolladenBuero: 0,
            RolladenWohnzimmer: 1,
            RolladenKueche: 2,
            RolladenEsszimmer: 3,
            RolladenSchlafzimmer: 4,
            RolladenGaestezimmer: 5,
            RolladenJulian: 6
        // Gruppen. All, SZ, .. are then names of states. Add new properties for more groups
        const groups = {
            All   : Object.values(Rollos), // all IDs of shutters
            hinten: [Rollos.RolladenBuero, Rollos.RolladenKueche, Rollos.RolladenEsszimmer, Rollos.RolladenSchlafzimmer], // Hofseite
            vorne : [Rollos.RolladenWohnzimmer, Rollos.RolladenGaestezimmer],                                                   // Strasse
        const All = Object.keys(Rollos)
        for(let shutter of All) {
            createState(baseObjectPath + 'shutter.' + shutter, 0, { name: 'shutter ' + shutter, type: 'number', min: 0, max: 100, unit: '%'})
        for(let key of Object.keys(groups)) {
            createState(baseObjectPath + 'groups.' + key, 0, { name: 'group ' + key, type: 'number', min: 0, max: 100, unit: '%'})
        const MaxNodeIdx = All.length;  // 5 Rollos..
        const Up    = 0      // Rollo oben
        const Down  = 0xc800 // Rollo unten
        const Stop  = 0xD200 // Stopkommando
        // Variable
        var velux  = require('velux-klf200-api')
        var Connected = false
        let Commands = {}
        var SessionId = 0
        // Zustand der Rollos holen
        function GetState(shutters, sessionId)
            if (Connected) {
                shutters = shutters || All
                log('checking shutters ' + JSON.stringify(shutters), 'debug')
                velux.sendCommand({
                    api: velux.API.GW_STATUS_REQUEST_REQ,
                    sessionID: sessionId || 0,
                    indexArrayCount: shutters.length,
                    indexArray : shutters,
                    statusType : 3 // Main Info
        // Callback fuer Positionsrueckmeldung
        velux.on('GW_STATUS_REQUEST_NTF', Status);
        function Status(data) {
            var Target     = Math.round(100 - data.targetPosition.value)
            var Current    = Math.round(100 - data.currentPosition.value) // aktuelle Position
            var Time       = data.remainingTime // Restlaufzeit
            var Index      = data.index         // Node index
            var StatusType = data.statusType    // Status Typ "Main Info" = 3 erwartet
            //console.log(JSON.stringify(data))
            //console.log(Z[data.index] + ': Ziel ' + Target + ' Aktuell: ' + Current + ' Restlaufzeit :' + Time)
            if ( (StatusType === 3) &&
                (Index >= 0) &&
                (Index < MaxNodeIdx))
                var IdStrIst = baseObjectPath + 'shutter.'  + Z[data.index]
                setState(IdStrIst, Current, true)
        // Callback Ende Job
        velux.on('GW_SESSION_FINISHED_NTF', JobFinished);
        function JobFinished(data) {
            log("EndCmd (" + data.sessionID+')', 'debug')
            let sessionKey = 'session_' + data.sessionID
            if (typeof Commands[sessionKey] !== 'undefined') {
                let shutters = Commands[sessionKey].shutters
                // get state after job finished
                GetState(shutters, data.sessionID)
                delete Commands[sessionKey]
        // Verbindung aufbauen
        function ConnectKlf() {
            if (! Connected) {
                Connected = true;
                velux.connect( Ip, {} ).then(()=>{
                    velux.login( Passwort ).then(()=>{
                        log("Klf connected!", 'info')
                        Connected = true
                        GetState();
                .catch((err)=>{
                    log('connect error ' + JSON.stringify(err), 'error')
                    Connected = false
                    velux.end()
        function Rollo( Rollos, Val) {
            if ( Connected )
                return velux.sendCommand({ api: velux.API.GW_COMMAND_SEND_REQ,
                    sessionID : ++SessionId,
                    commandOriginator: 1,
                    priorityLevel:     2,
                    parameterActive:   1,
                    functionalParameterMP:  {rawValue : Val},
                    indexArrayCount: Rollos.length,
                    indexArray : Rollos,
                    priorityLevelLock: false,
                }).then((data)=>{
                    log("StartCmd (" + data.sessionID+')', 'debug')
                    Commands['session_' + data.sessionID] = {
                        shutters: Rollos
                .catch((err)=>{
                    log(err, 'error')
        // Restart einmal pro Tag um 22 Uhr
        schedule('5 20 * * *', function () {
            velux.sendCommand({ api: velux.API.GW_REBOOT_REQ})
            Connected = false
        // zyklisches Senden Idle Telegramm und Rolladenstatus holen
        schedule('*/1 * * * *', function () {
            velux.sendCommand({ api: velux.API.GW_GET_STATE_REQ})
            .then((data) => {
                //Connected = true
                GetState()       // Rolladenpostionen holen
            .catch((err) => {
                Connected = false
                log('Connection lost...' +JSON.stringify(err), 'error')
                ConnectKlf()
        // Verbinden zu klf200
        ConnectKlf()
        // Verbindung abbauen und aufraeumen bei Stop
        onStop(() => {
            Connected = false
            log("Disconnect", 'info')
            velux.off('GW_STATUS_REQUEST_NTF',   Status)
            velux.off('GW_SESSION_FINISHED_NTF', JobFinished)
            velux.end()
        on({id: new RegExp(baseObjectPath.replace('.', '\.') + 'shutter\..*'), change:'any', ack: false}, function (obj) {
            let State = Down - Down / 100 * obj.state.val
            let shutterName = obj.id.split('.').slice(-1)[0]
            let shutterId = Rollos[shutterName]
            log('Moving shutter ' + shutterName + '(' + shutterId + ')' + ' to ' + obj.state.val + '%', 'info')
            Rollo([shutterId], State)
        on({id: new RegExp(baseObjectPath.replace('.', '\.') + 'groups\..*'), change:'any', ack: false}, function (obj) {
            let shutters = groups[shutterName] || []
            if (shutters.length > 0) {
                log('Moving shutter group ' + shutterName + ' to ' + obj.state.val + '%', 'info')
                Rollo(shutters, State)
        //    Mapping fuer Logitech Harmony
        // Dach zu
        subscribe({id: 'fakeroku.0.ioBroker.keys.Up', val : true, ack :true}, function (obj) {
            Rollo(harmony, Up)
        // Dach auf
        subscribe({id: 'fakeroku.0.ioBroker.keys.Down', val : true, ack :true}, function (obj) {
            Rollo(harmony, Down)
        // Dach Stop
        subscribe({id: 'fakeroku.0.ioBroker.keys.Select', val : true, ack :true}, function (obj) {
            Rollo(harmony, Stop)
        82.9k
