  4. iobroker + Docker + Synology: Problem mit Admin-Oberfläche
adminiobrokerdockersynologyredis
18 Beiträge 4 Kommentatoren 2.2k Aufrufe 4 Beobachtet
  • M McD_HRTS
    Folgende Infos wären sinnvoll:
    • Das Log vom Container
    • Was willst du denn nachträglich im Portainer am Container ändern und wieso nachträglich?
    @McD_HRTS Log vom Container:
    stdout
    13:13:05
    stdout
    13:13:05
    ---------------     2020-06-07 15:13:05      ---------------
    stdout
    13:13:05
    stdout
    13:13:05
    stdout
    13:13:05
    stdout
    13:13:05
    -----       Welcome to your ioBroker-container!        -----
    stdout
    13:13:05
    -----          Startupscript is now running.           -----
    stdout
    13:13:05
    -----                Please be patient!                -----
    stdout
    13:13:05
    stdout
    13:13:05
    stdout
    13:13:05
    stdout
    13:13:05
    -----              Debugging information               -----
    stdout
    13:13:05
    stdout
    13:13:05
    -----                      System                      -----
    stdout
    13:13:05
    -----               arch:      x86_64                  -----
    stdout
    13:13:05
    stdout
    13:13:05
    -----                     Versions                     -----
    stdout
    13:13:05
    -----               image:     v4.2.0                  -----
    stdout
    13:13:06
    -----               node:      v10.20.1                -----
    stdout
    13:13:07
    -----               npm:       6.14.4                  -----
    stdout
    13:13:08
    stdout
    13:13:08
    -----                       ENV                        -----
    stdout
    13:13:08
    -----               PACKAGES:  vi                      -----
    stdout
    13:13:08
    -----               SETGID:    1000                    -----
    stdout
    13:13:08
    -----               SETUID:    1000                    -----
    stdout
    13:13:08
    -----               USBDEVICES: /dev/ttyUSB0            -----
    stdout
    13:13:08
    stdout
    13:13:08
    stdout
    13:13:08
    stdout
    13:13:08
    -----         Step 1 of 5: Preparing container         -----
    stdout
    13:13:08
    stdout
    13:13:08
    stdout
    13:13:08
    Installing additional packages is set by ENV.
    stdout
    13:13:08
    The following packages will be installed: vi...
    stdout
    13:13:16
    E: Paket vi kann nicht gefunden werden.
    stderr
    13:13:16
    Done.
    stdout
    13:13:16
    stdout
    13:13:16
    stdout
    13:13:16
    -----   Step 2 of 5: Detecting ioBroker installation   -----
    stdout
    13:13:16
    stdout
    13:13:16
    stdout
    13:13:17
    Existing installation of ioBroker detected in /opt/iobroker.
    stdout
    13:13:17
    stdout
    13:13:17
    stdout
    13:13:17
    -----   Step 3 of 5: Checking ioBroker installation    -----
    stdout
    13:13:17
    stdout
    13:13:17
    stdout
    13:13:17
    (Re)Setting folder permissions (This might take a while! Please be patient!)...
    stdout
    13:13:18
    Done.
    stdout
    13:13:18
    stdout
    13:13:18
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    stdout
    13:13:18
    Done.
    stdout
    13:13:18
    stdout
    13:13:22
    /opt/scripts/iobroker_startup.sh: Zeile 173: [: !=: Einstelliger (unärer) Operator erwartet.
    stderr
    13:13:22
    stdout
    13:13:22
    -----      Step 4 of 5: Applying special settings      -----
    stdout
    13:13:22
    stdout
    13:13:22
    stdout
    13:13:22
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    stdout
    13:13:22
    For more information take a look at readme.md on Github!
    stdout
    13:13:22
    stdout
    13:13:22
    Usb-device-support is activated by ENV.
    stdout
    13:13:22
    Setting permissions for /dev/ttyUSB0...
    stdout
    13:13:22
    Done.
    stdout
    13:13:22
    stdout
    13:13:27
    stdout
    13:13:27
    -----          Step 5 of 5: ioBroker startup           -----
    stdout
    13:13:27
    stdout
    13:13:27
    stdout
    Die nachträglichen Änderungen habe ich gemacht, um das durchreichen des Stick zu ermöglichen. Ohne Portainer war es mir nur möglich durch --privileged den Stick durchzureichen. Mit Portainer gibt es die Möglichkeit, das Durchreichen des USB-Ports zu konfigurieren und nicht eben alles pauschal durchzureichen, was ja ein Sicherheitsrisiko ist. Nachträglich, weil ich eben den Container ohne Portainer angelegt hatte.
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      -----                      System                      -----
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:05
      stdout
      13:13:06
      stdout
      13:13:07
      stdout
      13:13:08
      stdout
      13:13:08
      -----                       ENV                        -----
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:08
      stdout
      13:13:16
      stderr
      13:13:16
      Done.
      stdout
      13:13:16
      stdout
      13:13:16
      stdout
      13:13:16
      stdout
      13:13:16
      stdout
      13:13:16
      stdout
      13:13:17
      stdout
      13:13:17
      stdout
      13:13:17
      stdout
      13:13:17
      stdout
      13:13:17
      stdout
      13:13:17
      stdout
      13:13:17
      stdout
      13:13:18
      Done.
      stdout
      13:13:18
      stdout
      13:13:18
      stdout
      13:13:18
      Done.
      stdout
      13:13:18
      stdout
      13:13:22
      stderr
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      stdout
      13:13:22
      Done.
      stdout
      13:13:22
      stdout
      13:13:27
      stdout
      13:13:27
      stdout
      13:13:27
      stdout
      13:13:27
      stdout
      arteckA Offline
      arteckA Offline
      arteck
      @moongringo
      pkill io
      so stoppt man den iobroker im doker
      und mit
      node node_modules/iobroker.js-controller/controller.js >/opt/scripts/docker_iobroker_log.txt 2>&1 &
      startest du den wieder
      nicht mit iobroker start/stop
      • ? Offline
        @arteck said in iobroker + Docker + Synology: Problem mit Admin-Oberfläche:
        Hi und danke für die Antwort. Ich habe deine Befehle ausprobiert, ohne Ergebnis:
        root@3eaae20aff9c:/opt/iobroker# pkill io
        root@3eaae20aff9c:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js >/opt/scripts/docker_iobroker_log.txt 2>&1 &
        [1] 550
          [1] 550
          arteckA Offline
          arteckA Offline
          arteck
          @moongringo was heisst ohne Ergebniss ?? wie kommst du dadrauf ??
          der js-controller wurde gestartet mit der pid 550
          • arteckA arteck
            @arteck Wie in dem Codeschnipsel im vorherigen Post angegeben wurde "[1] 550" ausgegeben, auf die Admin-Oberfläche komme ich aber weiterhin nicht.
              arteckA Offline
              arteckA Offline
              arteck
              @moongringo dann schau mal ins log vom iobroker.. ob der admin gestartet wird ..
              • arteckA arteck
                @arteck Nein, offenbar werden die Instanzen wie Admin nicht gestartet. Die wurden zuvor immer unter "Starting ioBroker..." aufgelistet. Das Log zeigt dasselbe Startverhalten wie vorher:
                ---------------     2020-06-07 21:20:18      ---------------
                -----                      System                      -----
                -----                       ENV                        -----
                Done.
                Done.
                Done.
                Done.
                Starting ioBroker...```
                  -----                      System                      -----
                  -----                       ENV                        -----
                  Done.
                  Done.
                  Done.
                  Done.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @moongringo
                  zeige mal :
                  iobroker list instances
                  iobroker list adapters
                  • ? Offline
                    @Glasfaser said in iobroker + Docker + Synology: Problem mit Admin-Oberfläche:
                    Gern, dann erhalte ich die Redis-Fehlermeldung:
                    root@3eaae20aff9c:/opt/iobroker# iobroker list instances
                    No connection to states 192.168.0.3:6379[redis]
                    root@3eaae20aff9c:/opt/iobroker# iobroker list adapters
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @moongringo
                      Dein Log sieht mir am Anfang sehr kurz aus .
                      Hast du die anderen Einstellungen auch entfernt !?
                      So sieht meins aus :
                      ---------------     2020-06-04 21:17:40      ---------------
                      -----                      System                      -----
                      -----               node:      v12.17.0                -----
                      -----                       ENV                        -----
                      -----               ADMINPORT: 8081                    -----
                      -----               AVAHI:     false                   -----
                      -----               IOB_OBJECTSDB_HOST: 127.0.0.1               -----
                      -----               IOB_OBJECTSDB_PORT: 9001                    -----
                      -----               IOB_OBJECTSDB_TYPE: file                    -----
                      -----               PACKAGES:  nano                    -----
                      -----               IOB_STATESDB_HOST: 127.0.0.1               -----
                      -----               IOB_STATESDB_PORT: 9000                    -----
                      -----               IOB_STATESDB_TYPE: file                    -----
                      -----               USBDEVICES: /dev/ttyACM0;/dev/ttyACM2 -----
                      -----               ZWAVE:     false                   -----
                      ? 2 Antworten Letzte Antwort
                        vorweg: Ich bin verzweifelt und habe nach dem lesen unzähliger Forenbeiträge keine Idee mehr... Es geht sogar so weit, dass ich - ohne anständiges Backup - meinen Biobroker-Container gelöscht und komplett neu aufgesetzt habe - ohne Erfolg.
                        Mein Problem:
                        Seit 2 Tagen komme ich nicht mehr auf meine iobroker Admin-Oberfläche. Ich habe zuvor einen USB-300 Stick zur EnOcean-Integration (erfolgreich) bei iobroker hinzugefügt. Da ich das Device anständig integrieren wollte, habe ich mich mit der Buanet-Portainer-Anleitung Portainer installiert und den Container bearbeitet. Seit dem komme ich nicht mehr auf die Admin-Oberfläche. Ich habe alles mögliche, was ich im Forum gefunden habe, probiert, ohne erfolg. Dann habe ich den Container gelöscht und neu aufgesetzt. Leider hat es weiterhin nicht funktioniert, auch ohne Portainer.
                        Erst als ich einen neunen Admin auf Port 8089 angelegt habe, bin ich kurzzeitig auf die Admin-Oberfläche gekommen. Als ich den Container dann wieder mit Portainer editiert habe, ging wieder nichts. Seit dem habe ich zusätzlich das Problem, dass ich bei fast jeder Komandozeileneingabe eine Redis-Fehlermeldung bekomme, die trotz Redis-Installation weiterhin auftritt:
                        root@3eaae20aff9c:/opt/iobroker# iobroker start
                        Starting iobroker controller daemon...
                        iobroker controller daemon started. PID: 483
                        root@3eaae20aff9c:/opt/iobroker# npm -v
                        6.14.4
                        root@3eaae20aff9c:/opt/iobroker# iobroker version admin
                        4.0.10
                        root@3eaae20aff9c:/opt/iobroker# node -v
                        v10.20.1
                        root@3eaae20aff9c:/opt/iobroker# nodejs -v
                        v10.20.1
                        root@3eaae20aff9c:/opt/iobroker# iobroker list instances --enabled
                        Ich hoffe, ihr habt eine Idee und könnt mir helfen?!
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @moongringo sagte in iobroker + Docker + Synology: Problem mit Admin-Oberfläche:
                        hast du es auch hiermit eingestellt :
                        iobroker setup custom
                        • GlasfaserG Glasfaser
                          @moongringo
                          -----                      System                      -----
                          -----                       ENV                        -----
                          @Glasfaser Ich habe nichts entfernt, nur eine frische Installation vom ioBroker aufgesetzt. Bin nicht einmal danach auf den Admin gekommen und habe nicht eingestellt oder verändert.
                            @Glasfaser Ja, habe ich - nach bestem Wissen und Gewissen - an den Tutorials zu dem Redis-Problem langgehangelt und mit diesem Befehl auch eingestellt. Seit dem steht die IP-Adresse und der Port in der Fehlermeldung. Davor hatte ich die Fehlermeldung ohne IP und Port erhalten.
                              GlasfaserG Offline
                              GlasfaserG Offline
                              dann installiere es neu ... aber erstmal ohne Redis
                              und hier die Seite dazu !
                              Link Text
                                @moongringo
                                -----                      System                      -----
                                -----                       ENV                        -----
                                @Glasfaser Ich habe mal spaßeshalber deine Umgebungsvariablen übernommen. Log sieht jetzt so aus:
                                Unselect
                                -----                       ENV                        -----
                                The following packages will be installed: nano...
                                debconf: unable to initialize frontend: Dialog
                                debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
                                debconf: falling back to frontend: Readline
                                debconf: unable to initialize frontend: Readline
                                debconf: (This frontend requires a controlling tty.)
                                debconf: falling back to frontend: Teletype
                                dpkg-preconfigure: unable to re-open stdin:
                                Vormals nicht ausgewähltes Paket nano wird gewählt.
                                (Lese Datenbank ...
                                (Lese Datenbank ... 5%
                                (Lese Datenbank ... 10%
                                (Lese Datenbank ... 15%
                                (Lese Datenbank ... 20%
                                (Lese Datenbank ... 25%
                                (Lese Datenbank ... 30%
                                (Lese Datenbank ... 35%
                                (Lese Datenbank ... 40%
                                (Lese Datenbank ... 45%
                                (Lese Datenbank ... 50%
                                (Lese Datenbank ... 55%
                                (Lese Datenbank ... 60%
                                (Lese Datenbank ... 65%
                                (Lese Datenbank ... 70%
                                (Lese Datenbank ... 75%
                                (Lese Datenbank ... 80%
                                (Lese Datenbank ... 85%
                                (Lese Datenbank ... 90%
                                (Lese Datenbank ... 95%
                                (Lese Datenbank ... 100%
                                (Lese Datenbank ... 25499 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../archives/nano_3.2-3_amd64.deb ...
                                Entpacken von nano (3.2-3) ...
                                nano (3.2-3) wird eingerichtet ...
                                update-alternatives: /bin/nano wird verwendet, um /usr/bin/editor (editor) im automatischen Modus bereitzustellen
                                update-alternatives: /bin/nano wird verwendet, um /usr/bin/pico (pico) im automatischen Modus bereitzustellen
                                Done.
                                Done.
                                Done.
                                /opt/scripts/iobroker_startup.sh: Zeile 199: [: 8081: Einstelliger (unärer) Operator erwartet.
                                Done.
                                ENV IOB_OBJECTSDB_TYPE is set and value is different from detected ioBroker installation.
                                Setting type of objects db to "file"...
                                Done.
                                ENV IOB_OBJECTSDB_HOST is set and value is different from detected ioBroker installation.
                                Setting host of objects db to "127.0.0.1"...
                                Done.
                                ENV IOB_OBJECTSDB_PORT is set and value meets detected ioBroker installation. Nothing to do here.
                                ENV IOB_STATESDB_TYPE is set and value is different from detected ioBroker installation.
                                Setting type of states db to "file"...
                                Done.
                                ENV IOB_STATESDB_HOST is set and value is different from detected ioBroker installation.
                                Setting host of states db to "127.0.0.1"...
                                Done.
                                ENV IOB_STATESDB_PORT is set and value is different from detected ioBroker installation.
                                Setting port of states db to "9000"...
                                Done.
                                host.iobroker check instance "system.adapter.admin.0" for host "a2ea88cc42b7"
                                host.iobroker check instance "system.adapter.discovery.0" for host "a2ea88cc42b7"
                                host.iobroker check instance "system.adapter.info.0" for host "a2ea88cc42b7"
                                Und List liefert auch wieder etwas:
                                  system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.discovery.0             : discovery             -  enabled
                                  system.adapter.info.0                  : info                  -  enabled
                                + instance is alive
                                system.adapter.admin                   : admin          - v4.0.10
                                system.adapter.discovery               : discovery      - v2.3.5
                                system.adapter.info                    : info           - v1.7.2
                                Aber auf die Admin-Oberfläche komme ich weiterhin nicht...
                                  Unselect
                                  -----                       ENV                        -----
                                  (Lese Datenbank ...
                                  Done.
                                  Done.
                                  Done.
                                  Done.
                                  Done.
                                  Done.
                                  Done.
                                  Done.
                                  Done.
                                  + instance is alive
                                  Ich bin mit folgender Anleitung jetzt erst mal wieder drauf gekommen:
                                  cd /opt/iobroker
                                  sudo iobroker stop
                                  sudo iobroker add admin --enabled --port 808X <- X durch eigenen Port ändern
                                  iobroker start
                                  "Admin-Oberfläche über den neuen Port versuchen.
                                  Dann kam ich rein und hab mich erst umgeschaut.
                                  Wenn soweit okay, hab ich beide admin instanzen deinstalliert, und nur eine wieder neu installiert."
