  4. Test Adapter deConz v1.3.x Github/npm
deconzphoscon appconbee
160 Beiträge 33 Kommentatoren 32.1k Aufrufe 31 Beobachtet
  • Jey CeeJ Jey Cee
    @MarkusMac Standard ist Port 80 wenn man ihn nicht geändert hat.
    MarkusMac
    #137
    @Jey-Cee Super, das funktioniert! Besten Dank!
    • UweRLPU Offline
      UweRLPU Offline
      UweRLP
      #138
      Kann es sein, dass das Objekt Action noch Probleme macht?
      Ich habe versucht unter Objecte Action folgende Parameter zu übergeben
      "on":true,"colorspeed":0,"colormode":"xy","xy":0.349,0.1649 und auch
      "on":true,"colorspeed":0,"colormode":"xy","xy":"0.349,0.1649"
      also xy Wert mit oder ohne " .
      deconz.0	2020-06-03 07:55:47.415	debug	(14260) Subscribed to updates...
      deconz.0	2020-06-03 07:55:47.413	debug	(14260) Websocket connection closed
      deconz.0	2020-06-03 07:55:46.334	debug	(14260) system.adapter.admin.0: logging true
      deconz.0	2020-06-03 07:55:41.497	warn	(14260) Code 400: Bad request set light state 17: [{"error":{"address":"/lights/17/state","description":"body contains invalid JSON","type":2}}]
      deconz.0	2020-06-03 07:55:41.493	debug	(14260) dp: action; id:Lights.17 tmp: deconz,0,Lights,17
      deconz.0	2020-06-03 07:55:41.493	debug	(14260) stateChange Lights.17 {"val":"\"on\":true,\"colorspeed\":0,\"colormode\":\"xy\",\"xy\":0.349,0.1649","ack":false,"ts":1591163741492,"q":0,"from":"system.adapter.admin.0","user":"system.user.a
      deconz.0	2020-06-03 07:55:38.097	debug	(14260) system.adapter.admin.0: logging false
      deconz.0	2020-06-03 07:54:47.412	debug	(14260) Subscribed to updates...
      deconz.0	2020-06-03 07:54:47.406	debug	(14260) Websocket connection closed
      deconz.0	2020-06-03 07:54:20.886	warn	(14260) Code 400: Bad request set light state 17: [{"success":{"/lights/17/state/on":true}},{"error":{"address":"/lights/17/state/xy","description":"invalid value, 0.349,0.1649, for parameter, xy","t
      deconz.0	2020-06-03 07:54:20.869	debug	(14260) dp: action; id:Lights.17 tmp: deconz,0,Lights,17
      deconz.0	2020-06-03 07:54:20.868	debug	(14260) stateChange Lights.17 {"val":"\"on\":true,\"colorspeed\":0,\"colormode\":\"xy\",\"xy\":\"0.349,0.1649\"","ack":false,"ts":1591163660865,"q":0,"from":"system.adapter.admin.0","user":"system.us
      • UweRLPU UweRLP
        Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        #139
        @UweRLP Nein, aber du musst xy als Array übergeben.
        So:
        "xy":[0.349,0.1649]
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        UweRLPU 1 Antwort Letzte Antwort
        • Jey CeeJ Jey Cee
          So:
          "xy":[0.349,0.1649]
          UweRLPU Offline
          UweRLPU Offline
          UweRLP
          #140
          @Jey-Cee Danke, das wars, geht jetzt 👍
          • Jey CeeJ Jey Cee
            @WilliamTRiker sagte in Test Adapter deConz v1.3.x Github/npm:
            Habe gerade die Version 1.3.8 installiert, leider schalten meine OSRAM Lampen und Steckdosen nicht mehr, bin wieder zurück auf 1.3.7, danach geht es wieder
            Nur an/aus nicht oder auch brightness und die anderen sachen?
            Kein Port in der Konfiguration angegeben?
            W Offline
            W Offline
            WilliamTRiker
            #141
            @Jey-Cee es lag am fehlenden Port, danke für die schnelle Hilfe
              @Jey-Cee Grad die 1.3.3 installiert!
              hallo.amtH Offline
              hallo.amtH Offline
              hallo.amt
              schrieb am zuletzt editiert von hallo.amt
              #142
              @Beliar_666 said in Test Adapter deConz v1.3.x Github/npm:
              Inzwischen wird das .scene Attribut in einer Lichtgruppe korrekt aktualisiert. Ein Szenenwechsel kann damit aber nicht vorgenommen werden. Ist das so vorgesehen?
              du kannst auf jeden Fall einen Szenenwechsel durchführen, ich musste aber nach dem gestrigen Update von 1.1.irgendwas auf die 1.3.7 meine Flows aktualisieren und ein true als Wert an den Button schicken.
              die Szenen habe ich in einer 0.* Version eingbaut, ich nutze die bei mir recht gerne. Die Szene kannst du nicht mit einem Attribut wechseln, es gibt den Button recall. Der ruft die passende Szene auf.
              Das Attribut die Szene aufrufen lassen klingt spannend, da habe ich aber ehrlich gesagt keine Ahnung, wie ich das machen würde. Ich schaue es mir an, aber dann würde ich es in der 2er einbauen, neue Konfortfeatures in der 1er wären unnötige Arbeit.
              P.S.: Noch nicht alles gelesen, war gerade ein paar Monate unterwegs.
              • hallo.amtH Offline
                hallo.amtH Offline
                hallo.amt
                #143
                @Jey-Cee Danke für die viele Arbeit, so langsam merke ich, wie mein Zuhause komfortabler wird. Wahrscheinlich stecke ich mehr Arbeit in die Einrichtung des Systems rein, als ich spare, aber schon daß das Licht automatisch dimmt, wenn es draußen dunkler wird ist klasse.
                Ein kleiner Fehler kommt bei mir, auch nachdem ich einen neuen APi-Key erstellt habe. Beim starten wirft er mir immer die Meldung, daß er die Geräte nicht abrufen könne.
                 (30202) Code 404: Ressource not found get devices: []
                Deshalb hat er mir auch keine neuen Geräte angelegt, die alten funktionieren aber noch. deConz ist auf Version 2.05.77, die scheint laut apt die aktuelle zu sein. Der Adapter hat Version 1.3.7, ich habe ihn auf localhost mit Port 80 eingestellt. Die Verbindung sonst klappt hervorragend.
                • hallo.amtH hallo.amt
                  Seraphis
                  schrieb am zuletzt editiert von Seraphis
                  #144
                  Gleiche Meldung bei mir mit deconz auf 2.5.77 und Adapter auf 1.3.8.
                  Habe eben mal im log nachgeschaut, vor 2 Tagen mit deconz 2.5.75 und Adapter 1.3.7 kam die Meldung auch schon. Damals hatte ich in der Konfig auch noch keinen Port eingetragen, weshalb 1.3.8 erst nicht lief. Jetzt mit Port 80 klappts.
                  js-controller 3.0.20, admin usw. auf aktuellem latest-Stand, node 10.18.0, npm 6.13.4
                    mest
                    schrieb am zuletzt editiert von mest
                    #145
                    ich habe heute alles auf "stable" bzw. "empfohlen" upgedatet.
                    Jetzt hänge ich dran das eine LED Lichterkette keine Farben mehr zeigt.
                    Dürfte das hier erwähnte Problem mit xy sein.
                    Habe nun per Github auf die Deconz 1.3.8 upgedatet, es geht aber noch immer nicht.
                    Ich änderte die ganze Zeit den Wert in XY und setzte dann on auf true.
                    Port 80 steht drinne.
                    Jemand ne Idee ?
                    Lösung selbst gefunden. Habe das Feld von array auf string gestellt.
                    Scheint zu funktionieren.
                    Hätte den Beitrag gerne gelöscht, fehlen mir aber die Rechte dazu.
                    Bis denne!
                    • Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      #146
                      Die Version 1.3.9 soll das Ende der Version 1 sein. Deswegen hier jetzt nochmal die Frage, hat noch jemand einen Fehler gefunden der in der Version 1.3.8 besteht und mit 1.3.9 gefixt werden sollte?
                      Desweiteren kann sich wer Mutig ist schon das erste Release der Version 2 anschauen -> Hier
                      M K 2 Antworten Letzte Antwort
                      • Jey CeeJ Jey Cee
                        mayokleckz
                        schrieb am zuletzt editiert von mayokleckz
                        #147
                        @Jey-Cee bei mir kommt im logfile die Meldung (12368) Websocket connection closed
                        Teilweise schaltet es dann meine Osram LED ein. Auszug aus dem log. Um 11:01:42.139 zeigt der history log den LED Status true und die LEDs gehn an.
                        2020-06-09 10:53:38.653 - debug: deconz.0 (12368) Subscribed to updates...
                        2020-06-09 10:54:38.655 - debug: deconz.0 (12368) Websocket connection closed
                        2020-06-09 10:54:38.657 - debug: deconz.0 (12368) Subscribed to updates...
                        2020-06-09 10:54:42.439 - debug: deconz.0 (12368) Websocket message: {"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"e":"changed","id":"13","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:56:b7:f5-01-0500"}
                        2020-06-09 10:55:40.397 - debug: deconz.0 (12368) Websocket message: {"config":{"battery":95,"on":true,"reachable":true,"temperature":2800},"e":"changed","id":"22","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:40:12:77-01-0500"}
                        2020-06-09 10:55:40.401 - debug: deconz.0 (12368) Websocket message: {"e":"changed","id":"22","r":"sensors","state":{"lastupdated":"2020-06-09T08:55:40.395","lowbattery":false,"tampered":false,"water":false},"t":"event","uniqueid":"00:15:8d:00:02:40:12:77-01-0500"}
                        2020-06-09 10:56:08.576 - info: info.0 (1066) Popup news was read...
                        2020-06-09 10:56:08.622 - warn: info.0 (1066) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                        2020-06-09 10:56:40.401 - debug: deconz.0 (12368) Websocket connection closed
                        2020-06-09 10:56:40.404 - debug: deconz.0 (12368) Subscribed to updates...
                        2020-06-09 10:57:40.406 - debug: deconz.0 (12368) Websocket connection closed
                        2020-06-09 10:57:40.411 - debug: deconz.0 (12368) Subscribed to updates...
                        2020-06-09 10:58:16.317 - debug: deconz.0 (12368) Websocket message: {"e":"changed","id":"4","r":"lights","state":{"alert":null,"bri":254,"colormode":"ct","ct":370,"hue":0,"on":false,"reachable":false,"sat":0,"xy":[0.3805,0.3769]},"t":"event","uniqueid":"7c:b0:3e:aa:0a:07:7d:fd-03"}
                        2020-06-09 10:58:16.321 - debug: deconz.0 (12368) Code 200: Request succeded get light state 4: {"ctmax":666,"ctmin":125,"etag":"d5f766f20480b5e4f31ff61e7bd1d097","hascolor":true,"lastseen":"2020-06-09T08:54:05.053","manufacturername":"OSRAM","modelid":"Gardenpole RGBW-Lightify","name":"Extended color light 4","state":{"alert":"none","bri":254,"colormode":"ct","ct":370,"effect":"none","hue":0,"on":false,"reachable":false,"sat":0,"xy":[0.3805,0.3769]},"swversion":"V1.04.93","type":"Extended color light","uniqueid":"7c:b0:3e:aa:0a:07:7d:fd-03"}
                        2020-06-09 10:59:16.317 - debug: deconz.0 (12368) Websocket connection closed
                        2020-06-09 10:59:16.321 - debug: deconz.0 (12368) Subscribed to updates...
                        2020-06-09 11:00:00.055 - info: javascript.0 (2243) script.js.Sensors.GasoMeter: Logeintrag --> Energie/h 0 kWh
                        2020-06-09 11:00:16.322 - debug: deconz.0 (12368) Websocket connection closed
                        2020-06-09 11:00:16.324 - debug: deconz.0 (12368) Subscribed to updates...
                        2020-06-09 11:01:16.325 - debug: deconz.0 (12368) Websocket connection closed
                        2020-06-09 11:01:16.328 - debug: deconz.0 (12368) Subscribed to updates...
                        2020-06-09 11:01:41.943 - debug: deconz.0 (12368) Websocket message: {"e":"changed","id":"4","r":"lights","state":{"alert":null,"bri":254,"colormode":"ct","ct":370,"hue":0,"on":false,"reachable":true,"sat":0,"xy":[0.3805,0.3769]},"t":"event","uniqueid":"7c:b0:3e:aa:0a:07:7d:fd-03"}
                        2020-06-09 11:01:41.946 - debug: deconz.0 (12368) Code 200: Request succeded get light state 4: {"ctmax":666,"ctmin":125,"etag":"645e2796336240eedd07483323ef2a09","hascolor":true,"lastseen":"2020-06-09T09:01:41.940","manufacturername":"OSRAM","modelid":"Gardenpole RGBW-Lightify","name":"Extended color light 4","state":{"alert":"none","bri":254,"colormode":"ct","ct":370,"effect":"none","hue":0,"on":false,"reachable":true,"sat":0,"xy":[0.3805,0.3769]},"swversion":"V1.04.93","type":"Extended color light","uniqueid":"7c:b0:3e:aa:0a:07:7d:fd-03"}
                        2020-06-09 11:01:42.121 - debug: deconz.0 (12368) Websocket message: {"e":"changed","id":"4","r":"lights","state":{"alert":null,"bri":254,"colormode":"ct","ct":370,"hue":0,"on":true,"reachable":true,"sat":0,"xy":[0.3805,0.3769]},"t":"event","uniqueid":"7c:b0:3e:aa:0a:07:7d:fd-03"}
                        2020-06-09 11:01:42.124 - debug: deconz.0 (12368) Websocket message: {"e":"changed","id":"65520","r":"groups","state":{"all_on":false,"any_on":true},"t":"event"}
                        2020-06-09 11:01:42.127 - debug: deconz.0 (12368) Code 200: Request succeded get light state 4: {"ctmax":666,"ctmin":125,"etag":"35b5cd7d64547d6265894dae496510b6","hascolor":true,"lastseen":"2020-06-09T09:01:42.119","manufacturername":"OSRAM","modelid":"Gardenpole RGBW-Lightify","name":"Extended color light 4","state":{"alert":"none","bri":254,"colormode":"ct","ct":370,"effect":"none","hue":0,"on":true,"reachable":true,"sat":0,"xy":[0.3805,0.3769]},"swversion":"V1.04.93","type":"Extended color light","uniqueid":"7c:b0:3e:aa:0a:07:7d:fd-03"}
                        2020-06-09 11:01:42.133 - debug: deconz.0 (12368) Code 200: Request succeded get group attributes 65520: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"35b5cd7d64547d6265894dae496510b6","id":"65520","lights":["1","2","4"],"name":"All","scenes":[],"state":{"all_on":false,"any_on":true},"type":"LightGroup"}
                        2020-06-09 11:02:42.125 - debug: deconz.0 (12368) Websocket connection closed
                        2020-06-09 11:02:42.128 - debug: deconz.0 (12368) Subscribed to updates...
                        • Jey CeeJ Jey Cee
                          Kugelkopf
                          #148
                          @Jey-Cee
                          Nur die bereits erwähnte Meldung:
                          2020-06-10 01:10:56.749 - info: deconz.0 (14454) Code 404: Ressource not found get devices: []
                          funktioniert trotzdem alles wunderbar! Vielen Dank für das alles!
                          • K Kugelkopf
                            @Jey-Cee
                            Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            #149
                            @Kugelkopf Danke für die Rückmeldung. Die Meldung mit dem 404 ist in Ordnung.
                            @mayokleckz sagte in Test Adapter deConz v1.3.x Github/npm:
                            Das ist ganz normal. Die Websocket Verbindung wird nur genutzt um Zustandsänderungen von deConz zu bekommen, Befehle werden hier nicht gesendet.
                            Was ich sehe ist das deConz hier die Meldung raus schickt das sich der Status des Lichts geändert hat.
                            Was ich nicht sehe ist ein Befehl der vom Adapter geschickt wird. Daraus lässt sich Schlussfolgern das die Änderung in deConz/Phoscon statt gefunden hat oder du hast noch eine APP/Alexa/etc. mit deConz verbunden die den Befehl auslöst.
                            • Jey CeeJ Jey Cee
                              mayokleckz
                              #150
                              @Jey-Cee
                              Hey danke für die Erklärung. Ich habe schon in Phoscon gesucht, da ist nichts hinterlegt. Ich bekomm einfach nicht raus, woher der Trigger kam.
                              @Jey-Cee said in Test Adapter deConz v1.3.x Github/npm:
                              Ne, dann hab ich keinen weiteren Fehler gefunden.
                              • Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #151
                                Die Version 1.3.9 wird in den nächsten Tagen im Stable Repo auftauchen.
                                Damit ist hier jetzt ENDE
                                Hier gehts zum Test der Version 2
                                • chucky666C Offline
                                  chucky666C Offline
                                  chucky666
                                  #152
                                  Hallo
                                  Hat jemand die Osram Garden Pole Lampen über den Adapter laufen ?
                                  Wenn ja , wie ändert ihr die Farbe ? Welches Widget ?
                                  • Jey CeeJ Jey Cee
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #153
                                    @Jey-Cee
                                    Moin Moin,
                                    ich habe diese Warnung/Error bei jeder Version zwischen 1.3.3 und 1.3.10
                                    Deconz läuft als Container auf einer Synology.
                                    Was ist zu tun?
                                    Jey CeeJ 2 Antworten Letzte Antwort
                                    • haselchenH haselchen
                                      @Jey-Cee
                                      Moin Moin,
                                      Was ist zu tun?
                                      Jey CeeJ Online
                                      Jey CeeJ Online
                                      Jey Cee
                                      #154
                                      @haselchen du musst den port 443 weiterleiten.
                                      • Jey CeeJ Jey Cee
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #155
                                        @Jey-Cee
                                        Ich hab nix geblockt oder dergleichen.
                                        Alles auf standard oder automatisch.
                                          @Jey-Cee
                                          Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          #156
                                          @haselchen soweit ich weiss muss das bei den containern überhaupt erstmal frei gegeben werden. Das problem hatten schon viele.
