(gelöst) google-sharedlocations Alternative?
Ich versteh es einfach nicht. Jetzt aktualisiert er sich schon wieder nicht mehr:
die untere Zeile ist die poll Funktion und wie man sieht wurde um 8:41 gepollt und die andern DPs blieben einfach stehen.Das Log dazu:
google-sharedlocations.0 2020-06-03 08:43:20.601 debug (829881) system.adapter.admin.0: logging true google-sharedlocations.0 2020-06-03 08:42:51.546 debug (829881) stateChange google-sharedlocations.0.info.connection {"val":true,"ack":true,"ts":1591166571540,"q":0,"from":"system.adapter.google-sharedlocations.0","user":"system.user.admin","lc":15911662 google-sharedlocations.0 2020-06-03 08:42:51.537 info (829881) Checking fences. google-sharedlocations.0 2020-06-03 08:42:51.536 debug (829881) Response: OK google-sharedlocations.0 2020-06-03 08:42:51.404 info (829881) Polling locations. google-sharedlocations.0 2020-06-03 08:41:51.579 debug (829881) stateChange google-sharedlocations.0.info.connection {"val":true,"ack":true,"ts":1591166511575,"q":0,"from":"system.adapter.google-sharedlocations.0","user":"system.user.admin","lc":15911662 google-sharedlocations.0 2020-06-03 08:41:51.571 info (829881) Checking fences. google-sharedlocations.0 2020-06-03 08:41:51.570 debug (829881) Response: OK google-sharedlocations.0 2020-06-03 08:41:51.404 info (829881) Polling locations. google-sharedlocations.0 2020-06-03 08:41:10.596 debug (829881) system.adapter.admin.0: logging false google-sharedlocations.0 2020-06-03 08:41:05.578 debug (829881) stateChange google-sharedlocations.0.info.connection {"val":true,"ack":true,"ts":1591166465570,"q":0,"from":"system.adapter.google-sharedlocations.0","user":"system.user.admin","lc":15911662 google-sharedlocations.0 2020-06-03 08:41:05.566 info (829881) Checking fences. google-sharedlocations.0 2020-06-03 08:41:05.565 debug (829881) Response: OK google-sharedlocations.0 2020-06-03 08:41:05.443 debug (829881) stateChange google-sharedlocations.0.trigger_poll {"val":false,"ack":false,"ts":1591166465438,"q":0,"from":"system.adapter.google-sharedlocations.0","user":"system.user.admin","lc":159116646 google-sharedlocations.0 2020-06-03 08:41:05.437 debug (829881) ack is not set!Adapter ist grün
Was mir eben aufgefallen ist, die eingetragenen User sind nicht mehr da und deshalb wird auch nichts aktualisiert. Problem, der Adapter ist verbunden, kann aber keine User Auswählen.
Edit:
Adapter neu installiert und läuft wieder, mal gespannt wie lange diesmal. Hab die poll time auf 300 gestellt, da 600 viel zu hoch ist um den Adapter sinnvoll nutzen zu können. Eigentlich lief der ja auch schon zuverlässig mit 30 :-)Edit2:
Ich glaub ich habs, der Adapter läuft so lange, wie ich am PC auch bei Google mit meinem IOBroker Account angemeldet bin, sobald ich mich abmelde, wird nichts mehr aktualisiert.
Ja das ist mein Problem. Eben noch mal frisch angemeldet und Cookie ersetzt, kann pollen so oft ich will, der Adapter aktualisiert jedes mal sofort alle DPs. Melde ich mich bei Google ab, ist auch sofort Schluss damit. -
Edit:
Ja das ist mein Problem. Eben noch mal frisch angemeldet und Cookie ersetzt, kann pollen so oft ich will, der Adapter aktualisiert jedes mal sofort alle DPs. Melde ich mich bei Google ab, ist auch sofort Schluss damit.@Jan1 said in (gelöst) google-sharedlocations Alternative?:
Oh ja, das macht Sinn. Du hast ja das Cookie von der Session, wenn du die im Browser beendest, kann der Adapter sie nicht weiter nutzen.
Das wird mit dem Proxy behoben werden (wird aber noch etwas dauern). Bis dahin ggf. einen "ungenutzten" Browser verwenden oder ein "Privates Fenster", da müsste man sich auch mit dem ioBroker-Account einloggen können und das Fenster einfach schließen, so dass man sich im Browser wieder mit dem eigenen Account einloggen kann (bzw. gar nicht ausloggen muss).
Aber gut, dann weiß ich jetzt, dass da noch Fehlerbehandlung fehlt. (und dann weiß ich jetzt auch, wie ich den Fehler provozieren kann :-) )
Wenn ich hier was poste, dass es nicht geht, dann ist das keine Kritik, sondern einfach nur die Info für Dich, dass bei mir ein Problem besteht und Du bei Zeit und Lust mal danach schauen kannst.
Ne, sehe ich auch nicht so. Ist ja wertvolles Feedback.
Wenn ich darauf so lange antworte, ist das weniger eine Rechtfertigung als "lautes Denken". -
Hi, ich klinke mich ein und teste mit euch. Sagt ihr mir was ich jetzt genau zu machen habe um meinen Adapter wieder zum laufen zu bekommen.
@maxpd
Siehe: https://forum.iobroker.net/post/442647 bzw. auch Readme vom geforkten Adapter. -
Guten Morgen zusammen,
ich habe jetzt auch mal versucht, diesen Adapter zum Laufen zu bringen. Leider ohne Erfolg.
Habe mich bei Google Maps (.com) angemeldet und das Cookie eingetragen.
Prüfe ich im Adapter, ob ich eine Verbundung habe, bekomme ich die Aussage, dass die Verbindung fehlgeschlagen ist.
Im Log steht auch, dass der Cookie nicht akzeptiert wird, bzw. abgelaufen ist.
kann mir vielleicht jemand sagen, wo der Fehler liegt?
@falke69
Bist Du weiter hin über den Browser bei google mit dem selben Konto angemeldet, wie der Adapter und hast User angelegt, die den Standort freigeben?Im Browser bin ich weiterhin angemeldet. Wo lege ich denn einen User an.
Im Adapter scheint es ja nicht zu gehen, da bekomme ich keine Auswahl.
Ich dachte immer, dass zumindest der eine User (Gogglekonto) auftauchen sollte.
Kannst Du mir das weiterhelfen?
@falke69
Wenn Du auf den Pfeil bei Benutzer klickst, sollte ein Auswahl der User erscheinen die auf dem Handy auch mit diesem Account eingeloggt und die Standortfreigabe aktiv haben. Ist das nicht der Fall, ist auf dem Handy die Standortfreigabe nicht aktiv, oder ein andere Google Account am Laufen. -
@falke69
Wenn Du auf den Pfeil bei Benutzer klickst, sollte ein Auswahl der User erscheinen die auf dem Handy auch mit diesem Account eingeloggt und die Standortfreigabe aktiv haben. Ist das nicht der Fall, ist auf dem Handy die Standortfreigabe nicht aktiv, oder ein andere Google Account am Laufen.@Jan1
Die Standortfreigabe auf dem Handy ist aktuell aktiviert. Mit dem Account vom Handy, habe ich mich über Maps eingeloggt und diesen Cookie in den Adapter eingetragen. Der Zugriff auf "Zugriff durch weniger sichere Apps" ist auch deaktiviert. Habe ich etwas übersehen? -
@Jan1
@falke69
das sollte aktiviert sein und nicht deaktiviert ;-)@falke69 sagte in (gelöst) google-sharedlocations Alternative?:
@Jan1
na gut, egal, wie ich die Einstellungen hin und her stelle, es funktioniert leider immer noch nicht?
Soll es den wirklich so schwer sein und ich an dieser Sache scheitern? Andere haben es doch auch ohne Probleme geschafft.
@falke69
Ich weiß auch nicht in wie weit der Adapter das Problem löst, dass nur ältere Google Accounts funktionieren. Der "alte" Adapter lief zum Schluss nur mit alten Google Accounts und dann gar nicht mehr. Da musst wohl auf ne Antwort von @Garfonso warten, was er da alles umgebogen hat, dass der Adapter wieder läuft und welche Voraussetzungen dazu nötig sind.An sonst scheint bei Dir soweit alles richtig zu sein, zumindest sind da die Dinge, die ich bei mir auch gemacht habe um den Adapter wiederzubeleben.
Du schreibst oben, dass Du Dich in Google Maps eingeloggt hast und den Cookie zu erhalten. In der Anleitung steht allerdings google.com. Ich denke es dürfte egal sein ob Maps oder Google direkt, Hauptsache in dem Account der abgerufen werden soll.
Dein Screenshot oben zeigt auch nicht wirklich was Du als Cookie dort ausgewählt hast, nicht dass Du zu viel, zu wenig oder ganz was Falsches kopiert hast.
@falke69
Danke für Deine Hilfe. Habe es direkt nochmal bei google.com versucht und mir dort den Cookie geklaut, aber ohne Erfolg. Vieleicht gibt es bald eine komplette Neuaufage des Adapters. :-)
@falke69
der Cookie ist das hier was nach dem : kommt und das geht noch ein gutes Stück weiter, also sehr lang:
Sieht im Adapter dann so aus:
Edit:
lustig, ist mir eben selber erst aufgefallen. Eigentlich sollte auf beiden Screenshots der selbe Cookie zu sehen sein. Im Browser ist aber ein andere zu sehen als im Adapter, somit läuft es wohl sogar noch mit nem abgelaufenen :-) -
@falke69
Edit:
@Jan1
ich habe gerade die Zeichen in meinen Cookie gezahlt. es sich so um die 876 Zeichen. :-)
Könnte passen oder? :-)@falke69
kommt hin, sind sehr viel ;-)Hab eben mal den alten und den neuen Cookie verglichen, die sind unterschiedlich lang, wobei beide über 800 Zeichen haben. Zur Kontrolle hab ich auch gleich mal den neuen rein kopiert und der läuft (Gott sei Dank) auch.
@falke69
Ich hatte damals das Projekt Amazon Alexa Text to Speech nachgebaut, um mir eine Mitteilung auszugeben, wenn es geklingelt hat, oder die Post im Briefkasten war.
Das war noch lange vor iobroker. :-) Da musste man sich eine Cookie.txt runterladen (Addon für Firefox) und auf den Webserver kopieren. Vielleicht wäre das hier auch eine Möglichkeit aus dieser Datei den Cookie zu filtern.Auf jeden Fall warte ich mal ab, was die Zeit hier so bringt.
@falke69
Die Cookie Geschichte hier ist ja erst der Anfang der Wiederbelebung des Adapter und das haut bei einigen ja schon mal hin. Garfonso hat ja bereits angekündigt, dass er das ganze noch optimiert und einfacher lösen wird. Jetzt warte mal was er zu Deinem Problem sagt und was da noch so kommt. -
@Jan1
Es gehen auch neue Accounts so. Meinen ioBroker-Google Account habe ich extra für den Adapter frisch angelegt.
Das mit den "nicht sichere Geräte" ist auch nicht mehr wichtig, dürfte bei meinem neuen Google-Account auch aus sein.@falke69
Ich glaube, du hast noch nicht 100%ig verstanden, was der Adapter macht.
Der Adapter guckt sich die Standorte an, die mit dem Google-User geteilt wurden, mit dem er sich einloggt. Wenn du also auf Handy und im Adapter denselben Google-Account nutzt, wird es nicht gehen (und die Fehlermeldung sagt dann leider nichts über den Cookie aus... passe ich noch an).Das setup sollte so sein:
- Einen Google-Account für ioBroker anlegen. Die Position dieses Accounts wird nicht getrackt, daher ruhig einen neuen anlegen, der auf keinem Handy eingerichtet ist.
- Für jedes Handy, was getrackt werden soll, einen eigenen Google Account, da in Google Maps Standort für den Account aus 1 dauerhaft freigeben
- Mit Account aus 1 im Browser (Privates Fenster oder nicht sonst verwendeter Browser) einloggen. Dabei sicherstellen, dass kein anderer Google-Account mehr eingeloggt ist (man kann sich irgendwie mit mehreren Accounts gleichzeitig anmelden und oben rechts durchwechseln -> das darf nicht passieren -> alle anderen ausloggen, da darf nur dein ioBroker-Google account sein).
Dann Cookie kopieren und eintragen und wichtig nicht abmelden. Daher Privates Fenster -> das kannst du einfach schließen und im Browser bei bedarf deinen "normalen" Google Account nutzen (sonst hat du da deinen ioBroker-Google Account immer mit rumlungern).
Danach zeigt der Adapter dann alles anderen User (die aus 2) auch an. Aber der User, mit dem er eingeloggt ist, taucht nirgendwo auf.
