  4. Gelöst: Integration eine HM-IP Wettersensors
rpc-ip
26 Beiträge 3 Kommentatoren 1.5k Aufrufe 2 Beobachtet
  • M michihorn
    Ich habe gerade im Forum "HomeMatic-Forum / FHZ-Forum" gelesen, dass es diese Daten wie Sonnenscheindauer usw. in 3 Systeminternen Programmen der RM gebildet werden. Ich hatte gehofft das die DP dann in der Rega-Struktur zu finden sind.
    Vielleicht sind die DP als Hidden deklariert?!
    So sieht das Programm RainCounter in der RM aus:
    object chn = dom.GetObject('41266');
    object oOverflow = chn.DPByControl('WEATHER_TRANSMIT.RAIN_COUNTER_OVERFLOW');
    object oRainCounter = chn.DPByControl('WEATHER_TRANSMIT.RAIN_COUNTER');
    object oSysVarRain = dom.GetObject('svHmIPRainCounter_41266_00181BE98B3E3E:1');
    object oSysVarRainOldVal = dom.GetObject('svHmIPRainCounterOldVal_41266');
    object oSysVarCounterToday =  dom.GetObject('svHmIPRainCounterToday_41266');
    object oSysVarCounterYesterday =  dom.GetObject('svHmIPRainCounterYesterday_41266');
    boolean overFlowFlag = oOverflow.Value();
    real devVal = oRainCounter.Value();
    real devValMax = oRainCounter.ValueMax();
    real oldDevVal = oSysVarRainOldVal.Value();
    real diffVal = 0.0;
    real sysVarVal = oSysVarRain.Value();
    real sysVarTodayVal = oSysVarCounterToday.Value();
    real todayTotal = 0.0;
    integer tmp_devVal = (devVal.ToString().ToFloat() * 1000).ToInteger();
    integer tmp_oldDevVal = (oldDevVal.ToString().ToFloat() * 1000).ToInteger();
    if (overFlowFlag == false) {
    ! Normal conditions
    if (tmp_oldDevVal <= tmp_devVal) {
    diffVal = devVal - oldDevVal;
    ! Device has rebooted
    if (tmp_oldDevVal > tmp_devVal) {
    diffVal = devVal;
    } else {
    !overFlow is true
    ! An device overflow has occured
    diffVal = (devVal + devValMax) - oldDevVal;
    } else {
    ! Once the overflow flag has been set it will only be false when the device reboots
    ! Therefore this is the normal condition after an device overflow
    if (tmp_devVal != 0) {
    oSysVarRainOldVal.State(devVal);
    oSysVarRain.State(sysVarVal + diffVal);
    todayTotal = sysVarTodayVal + diffVal;
    if (todayTotal >= 1440.0) {todayTotal = 0.0;}
    oSysVarCounterToday.State(todayTotal);
    Michael
    @michihorn sagte in Integration eine HM-IP Wettersensors:
    sollten sie auch, deswegen warte ich noch auf die Screenshots
      michihorn
      schrieb am zuletzt editiert von michihorn
      @Homoran Im Rega Adapter hab ich "unsichtbare Variablen" angehackt, dass wars.
      Danke Euch beiden und schöne Pfingsten
      Michael
      • M michihorn
        Michael
        @michihorn sagte in Gelöst: Integration eine HM-IP Wettersensors:
        ggf. auch nur der darauffolgende restart des rega-Adapters.
        Bei mir (nonIP!!!) geht es auch ohne versteckte Variablen
        M 2 Antworten Letzte Antwort
          michihorn
          @Homoran Ich bekomme allerdings Fehlermeldungen im LOG
          Was kann das sein?
          Michael
          • M michihorn
            Was kann das sein?
            Michael
            Was kann das sein?
            Du willst doch nicht etwa da hineinschreiben?
              Was kann das sein?
              michihorn
              @Homoran Nein, wie kommst du dadrauf?
              Ich will lediglich den State abfragen:
              createState("javascript.0.test.Restzeit");
              schedule("*/1 * * * *", function () {
                  let SD = getState("hm-rega.0.41291").val;
                  log(SD);
                  let h = Math.floor(SD / 60);
                  let m = SD - h * 60;
                  let restzeit = (h + " Stunden, " + m + " Minuten");
                  log(restzeit);
                  setState("javascript.0.test.Restzeit", restzeit)
                michihorn
                @Homoran Ich habs gerade nochmal ausprobiert, Adapter neustarten ohne die Option Unsichtbare Variablen syncen, zeigt dann auch nicht mehr die Variablen. Es muss also, zumindest bei die Option angehackt sein.
                Ohne Hacken kommen auch keine Fehlermeldungen.
                Mit Syncen sind die Fehler sofort wieder da
                Michael
                • M michihorn
                      log(SD);
                      log(restzeit);
                  das lese ich aus dem Log, das du leider als screenshot gepostet hast
                    michihorn
                    @Homoran Ich habe den IoBroker neu gestartet, z.Zt kommt keine Fehlermeldung mehr. Das kleine Programm liefert seine Daten. Ich beobachte mal und melde mich später nochmal.
                    Ein Reboot tut immer gut ;-)
                    Micha
                      michihorn
                      @Homoran sagte in Gelöst: Integration eine HM-IP Wettersensors:
                      Nöö ich habe nichts in die DP geschrieben. Das SetValue bin ich nicht gewesen, dass muss vom rpc kommen
                      • M michihorn
                        Ich kann es dir immer noch nicht kopieren.
                        da steht was von setValue
                          michihorn
                          @Homoran sagte in Integration eine HM-IP Wettersensors:
                          Ich denke das setValue macht der RPC, schau mal den Screen
                          • M michihorn
                            richtig!
                            Und schreibst du in diesen Datenpunkt vom rpc?
                              richtig!
                              michihorn
                              richtig!
                              NEIN, warum sollte ich was in einen DP schreiben, den ich auslesen will. Die Fehlermeldung sagt nach meiner Auffassung das RPC etwas in den DP schreibt. Schau mal "xmlrpc-->" bedeutet für mich das der Adapter etwas "schreibt".
                              Mein Code den ich gepostet habe "liest".
                              Was das LOG schreibt, da habe ich keinen Bezug zu.
                              Vielleicht kann einer der Entwickler etwas zu der Fehlermeldung sagen. Bitte frage mal nach, du kennst die Jungs doch. Danke dir ;-) Über ein Feedback freue ich mich. LG Micha
