  4. Webinterface nach Update nicht erreichbar
update error
30 Beiträge 2 Kommentatoren 2.1k Aufrufe 2 Beobachtet
    krriel
    Last login: Fri May 29 21:11:03 2020 from 192.168.178.47
    user@server:~$ iobroker status
    module.js:550
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (module.js:548:15)
        at Function.Module._load (module.js:475:25)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
        at bootstrap_node.js:625:3
    user@server:~$ iobroker list adapters
    module.js:550
        throw err;
    user@server:~$ iobroker list instances
    module.js:550
        throw err;
    user@server:~$
    Der "user" Benutzer hat root Rechte
    • K krriel
      module.js:550
          throw err;
      module.js:550
          throw err;
      module.js:550
          throw err;
      user@server:~$
      @krriel
      lsb_release -a
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v
        krriel
        user@server:~$ lsb_release -a
        No LSB modules are available.
        Distributor ID: Ubuntu
        Description:    Ubuntu 18.04.4 LTS
        Release:        18.04
        Codename:       bionic
        user@server:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v
        /usr/bin/nodejs
        v8.17.0
        /usr/bin/node
        v8.17.0
        /usr/bin/npm
        6.13.4
        user@server:~$
        • K krriel
          Release:        18.04
          Codename:       bionic
          /usr/bin/nodejs
          v8.17.0
          /usr/bin/node
          v8.17.0
          /usr/bin/npm
          6.13.4
          user@server:~$
          @krriel
          node 12 installieren.
            krriel
            so habe ich getan, jetzt bekomme ich den Fehler bei einer anderen Zeile:
            root@server:/home/user# lsb_release -a
            Release:        18.04
            Codename:       bionic
            root@server:/home/user# which nodejs && nodejs -v && which node && node -v && which npm && npm -v
            /usr/bin/nodejs
            v12.17.0
            /usr/bin/node
            v12.17.0
            /usr/bin/npm
            6.14.4
            und
            root@server:/home/user# iobroker status
            internal/modules/cjs/loader.js:969
              throw err;
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                at internal/main/run_main_module.js:17:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            • K krriel
              Release:        18.04
              Codename:       bionic
              /usr/bin/nodejs
              v12.17.0
              /usr/bin/node
              v12.17.0
              /usr/bin/npm
              6.14.4
              und
                throw err;
                requireStack: []
              @krriel Du solltest dich nicht als root einloggen.
              Als USER:
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
              iobroker fix
                krriel
                oh wow, läuft wieder, danke dir :)
                Wo lag denn jetzt mein Fehler? Ich kann doch nicht ahnen dass das Update eine neue Version von node benötigt, da sollte doch dann ein Hinweis kommen oder das er selber ein Update auf die neue Version macht.
                Aber vielen Dank für die schnelle Hilfe 😊
                user@server:~$ cd /opt/iobroker
                user@server:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                > iobroker.js-controller@3.1.4 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                NPM version: 6.14.4
                > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                > node-gyp rebuild
                make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                  CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                  COPY Release/unix_dgram.node
                make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                > node rebuild.js
                ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                > node-gyp rebuild
                make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                  CXX(target) Release/obj.target/diskusage/src/main.o
                  CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                  SOLINK_MODULE(target) Release/obj.target/diskusage.node
                  COPY Release/diskusage.node
                make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                > iobroker.js-controller@3.1.4 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                object system.certificates updated
                object 0_userdata.0.example_state created
                object 0_userdata.0 created
                object alias.0 created
                ACHTUNG: Die Fehlerberichterstattung über Sentry wird beim nächsten Start von ioBroker aktiviert
                Wir von ioBroker wollen das stabilste Smart-Home-System bereitstellen.
                Um dies zu ermöglichen, haben wir uns entschlossen, eine automatische Fehler- und Crash-Reporting-Lösung in den js-Controller und auch in Adapter zu implementieren.
                DIESE BERICHTERSTATTUNG WIRD MIT DEM NÄCHSTEN START IHRES IOBROKERS AKTIVIERT!
                Bei Fehlern, die zum Absturz des js-Controllers oder eines der relevanten Adapter führen, werden die Fehlerdetails an einen Server gesendet. Für den js-controller und die Haupt-Adapter befindet sich dieser Server in Deutschland. Informationen zu Community-Adaptern sind in der Github-Readme-Datei des betroffenen Adapters zu finden. Dort steht welcher Sentry-Server verwendet wird.
                Die Fehlerberichterstattung kann, falls gewünscht, über den Befehl
                'iobroker plugin disable sentry'
                deaktiviert werden. Dieser Befehl stellt auch sicher, dass kein Adapter, der auf diesem Host ausgeführt wird, Absturzberichtsdaten an den Sentry-Server sendet.
                ioBroker configuration updated
                > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
                > node scripts/postinstall
                Greenlock and ACME.js v3 are on the way!
                Watch for updates at https://indiegogo.com/at/greenlock
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                + iobroker.js-controller@3.1.4
                added 142 packages from 150 contributors in 53.954s
                18 packages are looking for funding
                  run `npm fund` for details
                user@server:/opt/iobroker$ iobroker fix
                library: loaded
                Library version=2020-04-12
                    Welcome to the ioBroker installation fixer!
                    Script version: 2020-04-12
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/3)
                OK:1 http://de.archive.ubuntu.com/ubuntu bionic InRelease
                OK:2 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease
                OK:3 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease
                OK:4 http://security.ubuntu.com/ubuntu bionic-security InRelease
                OK:5 https://deb.nodesource.com/node_12.x bionic InRelease
                Installed gcc-c++
                    Checking ioBroker user and directory permissions (2/3)
                    Checking autostart (3/3)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                user@server:/opt/iobroker$ iobroker start
                • K krriel
                  NPM version: 6.14.4
                  > node-gyp rebuild
                  > node rebuild.js
                  > node-gyp rebuild
                  library: loaded
                  Installed gcc-c++
                  Autostart enabled!
                  @krriel sagte in Webinterface nach Update nicht erreichbar:
                  Kann man nachlesen. Sollte man als 'admin' auf einem System auch. Zum Beispiel hier:
                  https://forum.iobroker.net/topic/33904/js-controller-3-1-jetzt-im-stable
                    krriel
                    Hmm ok verständlich, aber wenn ich das update per Webinterface mache lese ich mir vorher keine release nodes durch. Da erwarte ich einfach das es funktioniert oder er mir sagt das yx fehlt.
                    Vielleicht kann man in dem install-script eine entsprechende Überprüfung hinzufügen :man-shrugging:
                    Aber trotzdem danke für die Hilfe, nächstes mal werde ich mir vorher die release nodes angucken :)
                    • K krriel
                      Falsche Erwartungshaltung. Ein upgrade des js-controllers kann man auch nicht über das webinterface initiieren. Und Release Notes sind immer lesenswert.
                      Und das node 8 schon seit November abgekündigt ist und node 12 mittlerweile die empfohlene Version ist kann man auch mitbekommen haben. Steht im Info-Adapter z. B. drin.
                        krriel
                        @Thomas-Braun ich habe unter "Adapter" auf "alle Adapter upgraden" geklickt, danach hat er diverse Adapter upgedatet und das Webinterface war nicht mehr erreichbar. Daher hätte ich erwartet das diese einfache Updatefunktion "Idiotensicher" ist ;)
                        Anscheinend ist node nicht in meinen source-list drin, sonst sollte sich das ja selber auf die aktuelle Version upgraden und es gäbe dieses Problem gar nicht, muss ich mir morgen mal in Ruhe angucken.
                        Grundsätzlich bin ich mit iobroker sehr zufrieden und gerade selber am Programmieren von einem Adapter um meinen eigenen RS485 "Hausbus" einzubinden. Aber solche Probleme wie "mal eben ein Update machen" und danach geht nichts mehr hasse ich 🙄
                        Wird Zeit das iobroker auf nem Proxmox mit "snapshot" Funktion installiert wird :)
                        • K krriel
                          Vermutlich schon. Aber nur der 8er-Zweig.
                          Jetzt müsste ja der 12er-Zweig drin sein, wenn du sauber installiert hast.
                          apt policy nodejs
                          macht dich schlauer.
                          Eine Installation in proxmox hilft dir aber auch nix, wenn du die Release Notes nicht liest.
                            krriel
                            schrieb am zuletzt editiert von krriel
                            Jup ist er bzw. die 14.xx Version weil ich die ausgewählt habe, warum ist das update von node auf eine Grundversion beschränkt und installiert nicht einfach die neuste Version? 🙄
                            Bei einer Installation in Proxmox hätte ich aber einfach die alte "funktionierende" Version wieder herstellen können mit einem klick ;)
                            user@server:~$ apt policy nodejs
                            nodejs:
                              Installiert:           14.3.0-1nodesource1
                              Installationskandidat: 14.3.0-1nodesource1
                              Versionstabelle:
                             *** 14.3.0-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x bionic/main amd64 Packages
                                 8.10.0~dfsg-2ubuntu0.4 500
                                    500 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                                 8.10.0~dfsg-2ubuntu0.2 500
                                    500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                                 8.10.0~dfsg-2 500
                                    500 http://de.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                            user@server:~$
                            • K krriel
                              nodejs:
                                Versionstabelle:
                                   8.10.0~dfsg-2 500
                              user@server:~$
                              @krriel 14 ist noch nicht für iobroker vorgesehen. Gibt einige Adapter, die damit noch nicht laufen. Was glaubst du eigentlich, warum 12 empfohlen ist?
                              Und die Trennung in Entwicklungszweige ist bei node auf Grund der schnellen Entwicklung unerlässlich. Du willst nicht plötzlich eine anderen node-Version untergejubelt bekommen.
                              Dann bleibst du aber auch beim proxmox per Klick immer auf der alten Version.
                                krriel
                                Ich kann doch nicht bei jedem Update gucken welche Version von node aktuelle erwünscht ist, das muss mit der aktuellen Version laufen und sich notfalls selber aktualisieren. In den release nodes steht "...setzt diese neue Version nun Node.js 10.x voraus und funktioniert ebenso mit Node.js 12.x und auch mit Node.js 14.x" also nehme ich natürlich die Version 14.
                                Nachher muss ich noch verschiedene Versionen von node für unterschiedliche Programme installieren, kann doch nicht Sinn der Sache sein, Javascript soll einfach sein und laufen ;)
                                Ich prüfe doch auch nicht bei jedem anderen Programm welche Version von gcc oder welcher Kernel benötigt wird, dafür gibt es apt und Scripte die das prüfen.
                                Aber trotzdem Danke für deine Unterstützung am Freitag-Abend :)
                                • K krriel
                                  Bezieht sich auf den js-controller als Herzstück, nicht notwendigerweise auf die Adapter. Gibt sogar noch ein paar wenige Nachzügler, die auch mit node12 nicht laufen, glaube ich.
                                  Die aktuell empfohlene Version steht wie gesagt im Info-Adapter recht prominent drin. Inkl. der bei dir laufenden Version. Das sollte man halt ab und an abgleichen.
                                    krriel
                                    ok, jetzt weiß ich ja bescheid und werde in Zukunft vorher drauf achten, aber vielleicht lässt sich ja trotzdem eine Überprüfung in den install-script einbauen, kann ja nicht schaden.
                                    So...Prost aufs Wochenende 🍺
                                    • K krriel
                                      @krriel
                                      Im Installer-Skript wird eine aktuelle nodejs installiert. Für den Wechsel des Zweiges soll nur admin sorgen.
                                        krriel
                                        hmm komisch ich hatte ja iobroker komplett "überinstalliert" und
                                        und
                                        iobroker fix
                                        ausgeführt aber die haben keine neue Version von node installiert 😶
                                        • K krriel
                                          und
                                          iobroker fix
                                          @krriel Richtig. Sollen die Befehle auch nicht.
