  4. Hue wird nicht erkannt.
hue connection verbindung nichnicht erkannthue
79 Beiträge 5 Kommentatoren 5.2k Aufrufe 4 Beobachtet
  • R Offline
    relaxz
    @Thomas-Braun said in Hue wird nicht erkannt.:
    iobroker restart
    pi@ioBroker-RasPi4:/opt/iobroker $ iobroker add socketio
    host.ioBroker-RasPi4 install adapter socketio
    upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
    upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
    upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
    upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
    host.ioBroker-RasPi4 object system.adapter.socketio created/updated
    host.ioBroker-RasPi4 object connected created/updated
    host.ioBroker-RasPi4 create instance socketio
    host.ioBroker-RasPi4 object system.adapter.socketio.0.sigKill created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.eventLoopLag created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.outputCount created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.inputCount created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.uptime created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.memRss created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.memHeapTotal created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.memHeapUsed created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.cputime created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.cpu created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.compactMode created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.connected created
    host.ioBroker-RasPi4 object system.adapter.socketio.0.alive created
    host.ioBroker-RasPi4 object system.adapter.socketio.0 created
    pi@ioBroker-RasPi4:/opt/iobroker $ iobroker restart
    • R Offline
      relaxz
      Geht immer noch nicht
      • R relaxz
        @relaxz
        Jag den Fixer mal drüber:
        iobroker stop
        iobroker fix
        • R Offline
          relaxz
          iobroker fix
          Ist mir echt arg... Super Hilfe, aber das Webdingens springt nicht an
          pi@ioBroker-RasPi4:/opt/iobroker $ iobroker fix
          library: loaded
          Library version=2020-04-12
              Welcome to the ioBroker installation fixer!
              Script version: 2020-04-12
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          OK:1 http://archive.raspberrypi.org/debian buster InRelease
          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          OK:3 https://deb.nodesource.com/node_12.x buster InRelease
          N: Datei »nodesource.list.save.1« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          • R relaxz
            iobroker fix
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            @relaxz Starte die Kiste mal komplett durch.
            • R Offline
              relaxz
              10 Sekunden vom Netz genommen und danach neu gebootet, aber keine Besserung
              Ahja, Cache hab ich auch geleert
              • R relaxz
                @relaxz
                iobroker status
                iobroker list instances
                • R Offline
                  relaxz
                  pi@ioBroker-RasPi4:~ $ iobroker status
                  At least one iobroker host is running.
                  Objects type: file
                  States  type: file
                  pi@ioBroker-RasPi4:~ $ iobroker list instances
                    system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.discovery.0             : discovery             -  enabled
                    system.adapter.find-my-iphone.0        : find-my-iphone        -  enabled
                    system.adapter.harmony.0               : harmony               -  enabled
                    system.adapter.hmip.0                  : hmip                  -  enabled
                  + system.adapter.hue.0                   : hue                   -  enabled, port: 80
                  + system.adapter.ping.0                  : ping                  -  enabled
                    system.adapter.shuttercontrol.0        : shuttercontrol        -  enabled
                  + system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  • R Offline
                    relaxz
                    Aber:
                    Wenn ich im Browser 192.168.178.121:8082 eingebe kommt die Abfrage zum Admin.
                    Klicke ich da drauf springt er auf die 192.168.178.121:8081 und damit ins leere
                    • R relaxz
                      Objects type: file
                      States  type: file
                      + instance is alive
                      @relaxz
                      iobroker start admin
                      • R Offline
                        relaxz
                        schrieb am zuletzt editiert von relaxz
                        Geht immer noch nicht !
                        Browser:
                        ![alt text](353adb39-a87f-4266-9e51-d0b1ea5f7c04-image.png image url)
                        dann springt er auf
                        ![alt text](ea88ffa9-bb3b-47cf-9cf9-571b8575936c-image.png image url)
                        • R relaxz
                          Browser:
                          dann springt er auf
                          @relaxz
                          iobroker add javascript
                          iobroker start javascript
                          • R Offline
                            relaxz
                            pi@ioBroker-RasPi4:~ $ iobroker add javascript
                            NPM version: 6.14.4
                            npm install iobroker.javascript@4.6.17 --loglevel error --prefix "/opt/iobroker" (System call)
                            host.ioBroker-RasPi4 install adapter javascript
                            upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/php/php.js vs/basic-languages/php/php.js application/javascript
                            upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                            upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/bat/bat.js vs/basic-languages/bat/bat.js application/javascript
                            upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/2.df84d04d.chunk.js.LICENSE.txt static/js/2.df84d04d.chunk.js.LICENSE.txt text/plain
                            upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
                            upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
                            upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
                            upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
                            upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
                            upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
                            upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
                            upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
                            upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                            upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                            upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                            upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                            upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                            upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                            upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                            upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                            upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                            upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                            upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                            upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                            upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                            upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                            upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                            upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                            upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                            host.ioBroker-RasPi4 object system.adapter.javascript created/updated
                            host.ioBroker-RasPi4 object variables.dayTime created/updated
                            host.ioBroker-RasPi4 object variables.isDayTime created/updated
                            host.ioBroker-RasPi4 object variables created/updated
                            host.ioBroker-RasPi4 object script.js.global created/updated
                            host.ioBroker-RasPi4 object script.js.common created/updated
                            host.ioBroker-RasPi4 object script.js created/updated
                            host.ioBroker-RasPi4 object _design/script created/updated
                            host.ioBroker-RasPi4 create instance javascript
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.sigKill created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.eventLoopLag created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.outputCount created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.inputCount created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.uptime created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.memRss created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.memHeapTotal created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.memHeapUsed created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.cputime created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.cpu created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.compactMode created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.connected created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0.alive created
                            host.ioBroker-RasPi4 object system.adapter.javascript.0 created
                            pi@ioBroker-RasPi4:~ $ iobroker start javascript
                            pi@ioBroker-RasPi4:~ $ sudo reboot
                            Connection to 192.168.178.121 closed by remote host.
                            Connection to 192.168.178.121 closed.
                            • R Offline
                              relaxz
                              Leider komm ich jetzt nicht mehr auf den Pi... Kaputt... Drehe noch durch 😲
                              [Befehl nicht gefunden: ftp]
                              [Konnte keinen neuen Prozess erstellen und ein Pseudo-TTY öffnen.]
                              • R relaxz
                                @relaxz ftp?
                                Was machst du mit ftp da? Per ssh auf den Pi drauf.
                                • R Offline
                                  relaxz
                                  vertippt... Bin schon ganz meschugge!
                                  • R Offline
                                    relaxz
                                    Allerdings gibts immer noch keine Besserung zu vermelden
                                    • R relaxz
                                      @relaxz
                                      iobroker status
                                      iobroker list adapters
                                      • R Offline
                                        relaxz
                                        Zäh! Danke das du mir dran bleibst!
                                        Objects type: file
                                        States  type: file
                                        pi@ioBroker-RasPi4:~ $ iobroker list adapters
                                        system.adapter.admin                   : admin          - v3.6.2
                                        system.adapter.discovery               : discovery      - v1.3.0
                                        system.adapter.find-my-iphone          : find-my-iphone - v0.2.15
                                        system.adapter.harmony                 : harmony        - v1.2.2
                                        system.adapter.hmip                    : hmip           - v0.0.11
                                        system.adapter.hue                     : hue            - v3.2.4
                                        system.adapter.hue-extended            : hue-extended   - v1.2.3
                                        system.adapter.javascript              : javascript     - v4.6.17
                                        system.adapter.ping                    : ping           - v1.4.7
                                        system.adapter.shuttercontrol          : shuttercontrol - v0.4.3
                                        system.adapter.socketio                : socketio       - v3.0.7
                                        system.adapter.web                     : web            - v3.0.8
                                        + system.adapter.javascript.0            : javascript            -  enabled
                                        + instance is alive
                                        • R relaxz
                                          Objects type: file
                                          States  type: file
                                          + instance is alive
                                          @relaxz
