  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 606.4k Aufrufe 89 Beobachtet
  • D3ltoroxpD D3ltoroxp
    @Thomas-Braun Also ich kenne es mit strg-alt-q.
    Da lief ganz schön was durch, normal ? Kleiner ausschnitt !! Davor auch noch jede Menge anderes, mit türkiser, lila, gelber Schrift, aber das hats mir abgeschnitten.
    cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
    greenlock-store-fs@3.2.2 /opt/iobroker/node_modules/greenlock-store-fs
    safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
    le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
    le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
    le-store-certbot@2.2.3 /opt/iobroker/node_modules/le-store-certbot
    pyconf@1.1.7 /opt/iobroker/node_modules/pyconf
    js2xmlparser@4.0.1 /opt/iobroker/node_modules/js2xmlparser
    xmlcreate@2.0.3 /opt/iobroker/node_modules/xmlcreate
    luxon@1.22.2 /opt/iobroker/node_modules/luxon
    memory-pager@1.5.0 /opt/iobroker/node_modules/memory-pager
    node-addon-api@2.0.0 /opt/iobroker/node_modules/node-addon-api
    saslprep@1.0.3 /opt/iobroker/node_modules/saslprep
    sparse-bitfield@3.0.3 /opt/iobroker/node_modules/sparse-bitfield
    unix-dgram@2.0.3 /opt/iobroker/node_modules/unix-dgram
    ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
    winston-syslog@2.4.4 /opt/iobroker/node_modules/winston-syslog
    vm2@3.9.2 /opt/iobroker/node_modules/vm2
    bcrypt@3.0.6 /opt/iobroker/node_modules/bcrypt
    nan@2.13.2 /opt/iobroker/node_modules/bcrypt/node_modules/nan
    node-pre-gyp@0.12.0 /opt/iobroker/node_modules/node-pre-gyp
    tar@4.4.13 /opt/iobroker/node_modules/node-pre-gyp/node_modules/tar
    fs-minipass@1.2.7 /opt/iobroker/node_modules/node-pre-gyp/node_modules/fs-minipa                                     ss
    minipass@2.9.0 /opt/iobroker/node_modules/node-pre-gyp/node_modules/minipass
    yallist@3.1.1 /opt/iobroker/node_modules/node-pre-gyp/node_modules/yallist
    minizlib@1.3.3 /opt/iobroker/node_modules/node-pre-gyp/node_modules/minizlib
    mdns@2.5.1 /opt/iobroker/node_modules/mdns
    bindings@1.2.1 /opt/iobroker/node_modules/mdns/node_modules/bindings
    mongodb@3.5.7 /opt/iobroker/node_modules/mongodb
    bl@2.2.0 /opt/iobroker/node_modules/mongodb/node_modules/bl
    require_optional@1.0.1 /opt/iobroker/node_modules/require_optional
    resolve-from@2.0.0 /opt/iobroker/node_modules/require_optional/node_modules/reso                                     lve-from
    le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
    rsa-compat@1.9.4 /opt/iobroker/node_modules/le-acme-core/node_modules/rsa-compat
    node-forge@0.7.6 /opt/iobroker/node_modules/le-acme-core/node_modules/node-forge
    sharp@0.25.2 /opt/iobroker/node_modules/sharp
    color@3.1.2 /opt/iobroker/node_modules/sharp/node_modules/color
    semver@7.3.2 /opt/iobroker/node_modules/sharp/node_modules/semver
    smarthome@iobroker:/opt/iobroker/node_modules/@serialport$
    Ist auf jeden Fall durchgelaufen, ich beobachte mal die Log.
    #1154
    @D3ltoroxp
    Da bricht man sich ja die Finger bei...
    Da fehlt die Eingabezeile... Woher soll denn jetzt hier jemand wissen was du da eingegeben hast?
    D3ltoroxpD 1 Antwort Letzte Antwort
      @D3ltoroxp
      D3ltoroxpD Offline
      D3ltoroxpD Offline
      D3ltoroxp
      #1155
      @Thomas-Braun Leider komm ich so nicht mehr zurück.. Habe bis hoch gescrollt. Auf jeden Fall in
      opt/iobroker/node_modules/@serialport$ npm rebuild
        #1156
        @D3ltoroxp Dann hat die Kiste da jetzt rumgebaut.
        • apollon77A apollon77
          @D3ltoroxp
          Also scheinbar hat es das serialport zerhauen irgendwie. Geh mal in /opt/iobroker/node_modules/@serialport/ und ruf dort "npm rebuild" auf
          D3ltoroxpD Offline
          D3ltoroxpD Offline
          D3ltoroxp
          #1157
          @apollon77 said in js-controller 3.0/3.1 jetzt im Latest!:
          Sollte ich ja so machen. Also passt das dann, wenn er dort jede menge umgebaut hat ? Hätte mit 2-3 Zeilen gerechnet. Aber das das soviel wurde.
          Kann dabei was schief gehen, oder sollte das alles noch passen ? Da war ja irgendwie alles Dabei, zigbee, tr064 usw.
          Thomas BraunT GarfonsoG 2 Antworten Letzte Antwort
            #1158
            @D3ltoroxp Siehst du ja, wenn der entsprechende Adapter startet.
              GarfonsoG Offline
              GarfonsoG Offline
              Garfonso
              #1159
              @D3ltoroxp
              npm rebuild kann (eigentlich) nichts kaputt machen. Bei den meisten Paketen wird er vermutlich einfach gemerkt haben, dass es nichts zu bauen gibt. Ich glaube das gezieltere Kommando wäre npm rebuild @serialport gewesen in /opt/iobroker ausgeführt. Aber am Ende ist es egal. ;-)
              Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
              Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
              • GarfonsoG Garfonso
                @D3ltoroxp
                #1160
                @Garfonso Naja ich hab ja gesagt in welches Verzeichnis er soll ... dann wird an sich nur "Lokal" rebuild gemacht :-)
                  steimi
                  schrieb am zuletzt editiert von steimi
                  #1161
                  ich weiss nicht ob der Fehler zum js-Controller gehört...
                  er kommt regelmäßig jeden Tag um 02:00 Uhr
                  2020-05-25 02:00:22.221 - warn: host.iobroker-01 Objects 127.0.0.1:50160 Error from InMemDB: Error: ERROR readDir id=0_userdata.0: Not exists
                  2020-05-25 02:00:22.222 - warn: host.iobroker-01 Objects 127.0.0.1:50160 Error from InMemDB: Error: ERROR readDir id=admin.0: Not exists
                  2020-05-25 02:00:22.223 - warn: host.iobroker-01 Objects 127.0.0.1:50160 Error from InMemDB: Error: ERROR readDir id=material.0: Not exists
                  2020-05-25 02:00:22.223 - warn: host.iobroker-01 Objects 127.0.0.1:50160 Error from InMemDB: Error: ERROR readDir id=web.0: Not exists
                  • S steimi
                    #1162
                    @steimi Such mal hier in diesem Thread, wurde schon mehrfach behandelt
                      @Marty56 & @crunchip: Das wurde weiter oben schon behandelt. Kommt beim Backup. Einfach die bemängelten fehlenden Ordner in '/opt/iobroker/iobroker-data/files/' (bei Standardinstallation) erstellen und die Warnungen sind weg.
                      steimi
                      #1163
                      @apollon77 sorry und Danke, habs gefunden
                        @D3ltoroxp
                        D3ltoroxpD Offline
                        D3ltoroxpD Offline
                        D3ltoroxp
                        schrieb am zuletzt editiert von D3ltoroxp
                        #1164
                        @D3ltoroxp
                        Vielen Dank, scheint wieder sauber zu laufen, keine Fehler in der Log mehr gesehen !!
                        EDIT::
                        Hätte ich mal lieber nichts geschrieben.
                        maxcul.0	2020-05-26 19:31:20.538	info	(24590) Terminated (NO_ERROR): Without reason
                        maxcul.0	2020-05-26 19:31:20.536	info	(24590) terminating
                        maxcul.0	2020-05-26 19:31:20.516	error	(24590) unhandled promise rejection: undefined
                        maxcul.0	2020-05-26 19:31:08.492	info	(24590) checkTimeIntervalFired
                        Stand eben in der Log.
                        EDIT 2 ::
                        Hm kommt jetzt leider immer wieder ...
                        maxcul.0	2020-05-26 21:32:50.781	error	(25994) unhandled promise rejection: undefined
                        Unhandled	2020-05-26 21:32:50.780	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          @D3ltoroxp
                          EDIT::
                          EDIT 2 ::
                          #1165
                          @D3ltoroxp Es gibt schon ein Issue bei maxcul dazu ... muss ich reinschauen was da ist. STell ischer das diu die aktuellste verison nutzt
                            Hallo ioBroker-Community,
                            wie im neuen Release-Cycle für den js-controller geplant, kommt heute der neuen js-controller 3.0 (Releasename "Elena") bzw. inzwischen 3.1 (Releasename "Francesca") ins Latest Repository (sollte im laufe des Tages bei allen auftauchen). Ein großer Dank geht an alle User die bereits in den Letzten Tagen diese Version im beta test getestet und Probleme und Fehler zur Behebung gemeldet haben!
                            Node.js Versions-Anforderungen
                            Nach dem frühzeitigen aus für Node.js 8 bereits letzten November setzt diese neue Version nun Node.js 10.x voraus und funktioniert ebenso mit Node.js 12.x und, nach aktuellem Stand, auch mit der in den nächsten Tagen kommenden Node.js 14.x. Wir werden mit diesem Release auch die empfohlene Node.js Version für ioBroker auf 12.x anheben.
                            Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/post/266625
                            Error/Crash-Reporting mittels Sentry
                            Der js-controller hat jetzt standardmässig Sentry als Fehler-Reporting eingebaut und aktiviert. Der js-controller weisst bei der Erstinstallation einer Version >3.1 beim Upgrade gesondert darauf hin! Wenn also der js-controller mit einer Fehlermeldung abstürzt (und nur dann!) werden die Fehlerdetails anonymisiert an einen von uns selbst in Deutschland betriebenen Sentry-Server gemeldet. IPs o.ä. personalisierte Daten werden nicht gespeichert. Dieses Fehler-Reporting hilft uns bei Crashes schneller und genauer zu sehen was los ist und solche Fehler noch schneller beheben zu können. Bitte legt für Crashes die Ihr seht bitte trotzdem weiterhin GitHub-Issues an und unterstützt uns indem Ihr das Fehler-Reporting aktiviert lasst. Weitere Details und wie es deaktivierbar ist findet Ihr unter https://github.com/ioBroker/plugin-sentry#what-is-sentrysentryio .
                            Auch immer mehr Adapter nutzen diese Form des Fehler-Reportings.
                            Informationen zur Version
                            Diese Version bringt einige Features mit, ist aber ebenso der Beginn um "unter der Haube" einiges zu vereinheitlichen und Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen. Es gibt allerdings auch neue Features mit die die Adapter-Entwicklung vereinfachen und Hürden abbauen. Aus diesem Grund ist auch die Liste der Themen welche vor allem für Entwickler relevant sind diesmal recht lang.
                            Allerdings werden Aktionen von Adaptern die eigentlich den Regeln widersprechen jetzt über Logging sichtbar gemacht. Bitte unterstützt hier und legt bei den relevanten Adaptern Issues an das diese Dinge gefixt werden können. Für den js-controller 3.2 (ca. September 2020) ist es geplant einige dieser "verbotenen Aktionen" auch wirklich zu verhindern. Dazu dann zu gegebener Zeit mehr.
                            Darüber hinaus gibt es natürlich viele Optimierungen und Fixes. Mehr dazu weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei der 2.2!
                            Ich bedenke mich diesmal besonders bei @foxriver76, @AlCalzone und natürlich @Bluefox für die aktive Mitarbeit an dieser Version!
                            Der js-controller 3.0/3.1 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2 ist problemlos möglich. Nur die Node.js Version muss jetzt mindestens 10.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
                            Es gibt diesmal zwei Adapter die Aktualisiert werden müssen und einige weitere die aktualisiert werden sollten um die oben genannten Warnungen zu vermeiden! Mehr dazu im nächsten Abschnitt!
                            Installation
                            VOR der Installation
                            Wie bei jedem Update dieser Art: Bitte macht ein Backup! iobroker backup, bzw. kopieren des iobroker-data Verzeichnisses reichen an sich im Zweifel auch aus (ioBroker vorher stoppen natürlich). Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt.
                            Nötige Adapter-Aktualisierungen
                            Die folgenden Adapter müssen auf die genannten Minimalversionsnummern aktualisiert werden, da diese sonst nicht mit dem js-controller 3.0/3.1 funktionieren. Diese Updates am besten vorher ausführen, weil alle genannten Versionen auch mit den alten js-controller Versionen funktionieren.
                            • pushover 1.1.x funktioniert, falls 1.2.x im Einsatz ist bitte auf 1.3.x aktualisieren
                            • tr-064 4.0.0
                            • tr-064-community wird nun offiziell nicht mehr funktionieren.
                            • Die soef Adapter firetv und wifilight funktionieren nicht mehr und haben Updates bekommen: Bitte wifilight 1.1.0 bzw firetv 1.0.0 nutzen. Falls jemand "wifilight-community" oder "firetv-community" nutzt bitte wieder zurück auf die anderen wechseln.
                            • Der soef Adapter lightify funktioniert ebenso nicht mehr. Da Lightify als Platform allerdings in ein paar Monaten nicht mehr weiter betrieben wird haben wir entscheiden hier keinen Aufwand mehr reinzustecken. Am besten die Geräte über zigbee direkt anbinden.
                            Es werden aber, wie oben ausgeführt, einige Adapter ggf Warnungen ins Log schreiben. Die wichtigsten Adapter sind mit neuen Versionen im Latest Repository allerdings schon gefixt. Falls ein Adapter "nervt" dann bitte dem Entwickler melden und den Loglevel auf "Error" setzen.
                            Achtung: Slave-Systeme zuerst!
                            Bei einem Multi-Host-System, welches auf js-controller 2.2 läuft ist es beim Update auf Version 3.0/3.1 empfohlen, zuerst die Slave-Systeme zu aktualisieren. Der Master wird als letztes aktualisiert!
                            Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.0 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Die Slaves bleiben nach dem Update offline und werden erst wieder funktionieren wenn auch der Master auf die 3.0/3.1 aktualisiert wurde!
                            Windows
                            Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden, darf der js-controller nicht mit npm aktualisiert werden. Es wird eine neue Version des Windows Installers geben, die das Update des js-controllers mit wenigen Mausklicks ermöglicht. Wir updaten dazu hier im Thread.
                            Für alle "alten manuellen" Installationen gilt
                            • ioBroker muss gestoppt sein.
                            • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
                            • iobroker upgrade self
                            • ioBroker starten
                            Linux
                            • ioBroker stoppen (iobroker stop)
                            • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                            • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
                            • ioBroker starten (iobroker start)
                            Bei Fehlern:
                            Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                            Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                            NACH der Installation
                            Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
                            Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt. Die großen Änderungen sind alle "Unter der Haube" versteckt.
                            Dazu, was Euch jetzt die ganzen Neuerungen bringen, findet Ihr weiter unten in diesem Text Informationen. Neue Funktionen als Basis für Weiterentwicklungen wurden behutsam integriert und einige bestehende Probleme gezielt behoben.
                            Mit iobroker help wird eine Liste der möglichen Kommandozeilen-Kommandos angezeigt, die mit Version 2.0 um einige Befehle länger geworden ist.
                            Was hat sich geändert, was besonders ansehen/beachten?
                            Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                            • Der neue js-controller kann erkennen wenn es ein Node.js Update gab durch welches ggf, Adapter nicht mehr funktionieren und sollte diese automatisch reparieren (rebuilden). Wer also überlegt in dem Zuge des Tests seine Node.js Version anzuheben bitte mal explizit NICHT die übliche Anleitung nach dem Node-js update mit dem Rebuild befolgen sondern ioBroker einfach nach dem Node.js Update starten. Interessant ist ob sich alles selbst "heilt" 🙂
                            • Einige Adapter fangen Probleme mit Modulen ab und loggen dann einen Fehler, der nicht als automatischer Rebuild erkannt wird. Diese können manuell mittels iobroker rebuild adaptername oder falls das nicht funktioniert hat iobroker rebuild adaptername --install neu gebaut werden. Diese Befehle lösen faktisch reinstall.js u.a. ab.
                            • Der js-controller prüft jetzt vor jedem Start eines Adapters wieviel RAM noch frei ist und warnt im Log falls dies zu wenig ist. Die Standard-Limits sind 100MB (Warnung) bzw. 50MB (Fehler) und dies soll verhindern das mehr Adapter-Prozesse genutzt werden als RAM verfügbar ist. Hier sind wir gespannt auf Eure Berichte.
                            • Logfiles sollten jetzt wirklich nach dem täglichen rotieren auf Linux-Systemen als .gz Dateien abgelegt werden.
                            Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                            3.1.2 (2020-05-09) Release Francesca
                            3.0.14 (2020-04-21) Release Elena
                            BREAKING CHANGES
                            • Nodejs 8.x will be no longer officially supported! Supported are nodejs 10.x, 12.x and (most likely) 14.x
                            Features
                            • (Apollon77) Enable zip Archive setting that it is on by default again. All Logs on Linux will be packaged to .gz on rotation. This can be deactivated by configuration (see Documentation)
                            • (Apollon77) Introduce CLI command "iobroker rebuild <adaptername>" or "iobroker rebuild self" (for controller) to execute an npm install/rebuild for the specified adapter
                            • (Apollon77) Detect the need for a rebuild because of a nodejs update by checking adapter crash error message and execute the "iobroker rebuild" command for the affected adapter up to 3 times.
                            • (foxriver76) Add ability to define separate read and write id for aliases, introduce Adapter feature flag ALIAS_SEPARATE_READ_WRITE_ID for this (see Documentation)
                            • (foxriver76) Make file write intervals of objects and state file dbs configurable (see Documentation)
                            • (foxriver76) Check available RAM of the system before a new adapter process is started. If it is below 50/100MB log an error/warn and make it configurable via iobroker.json (see Documentation)
                            • (Apollon77) Add plugin system for js-controller and adapters (see Documentation)
                            • (Apollon77) Add and automatically enable Sentry as plugin for js-controller (see infos in README.md), can be disable per host via system.host.name.plugins.sentry.enabled (see Documentation)
                            • (AlCalzone) add iobroker object extend command
                            • (Apollon77) Add a node.js version check and output special error message if node.js version is not satisfied
                            • (Apollon77) Inform about sentry activation if not configured on "iobroker setup first"
                            • (AlCalzone) Add Plugin CLI commands to enable/disable plugins
                            Optimizations and Fixes
                            • (bluefox) Show options for start/stop/restart if more than one instance exists for the adapter
                            • (AlCalzone) Validate arguments for iobroker del ... CLI command
                            • (bluefox) Log js-controller version by start of adapter too
                            • (Stabilostick) Set default certificate validity to 12 months, according to new Apple rules! Existing certificates will be recreated on controller installation if no custom certificate is used
                            • (bluefox) Also initialize objects with local redis connection details if setup command is called with "useRedis" parameter
                            • (foxriver76) Increase timeout of hostinfo command to prevent errors on systems with low CPU
                            • (foxriver76) The end of schedule adapters is no longer logged as error
                            • (foxriver76) Allow CLI commands to check status of an adapter instance
                            • (foxriver76) Enhancements and fixes for iobroker list files command, allow to specify exact meta folder name as parameter and not only the adapter
                            • (foxriver76) Add forced repository update to help, add logging to show that it is used
                            • (foxriver76) Also delete uploaded vis widgets on adapter deletion
                            • (foxriver76) Restart referenced restart-adapters after uninstall also
                            • (foxriver76) Prevent dot as last char of an object or state id
                            • (foxriver76) Improve performance on filter actions (getObjectView) when redis is used as objects database
                            • (Apollon77) Optimize sigKill handling to prevent restart loops for edge cases and slow system
                            • (Apollon77) Optimize errormessage for invalid protocol on database connection and make easier understandable
                            • (Apollon77) Also catch unhandled promise rejections in adapters and handle like exceptions to allow error detection and automatic restart
                            • (foxriver76) Also remove objects from Enums on object deletion
                            • (foxriver76) Fix adapter exiting with wrong exit codes
                            • (bluefox) Fix restart CLI command
                            • (foxriver) Update cache manifest correctly on visdebug and fix process exit on non existing vis dir
                            • (foxriver76) No longer require restart of instance after alias object changes and other alias optimizations
                            • (foxriver76) Make sure files in internal file storage are always stored with correct path and also automatically fix existing entries
                            • (foxriver76) fix crash of redis setState when undefined is passed and refuse undefined as value in general
                            • (Apollon77) Make sure objects update from/ts/user when extending objects in all cases
                            • (AlCalzone) optimize performance when objects are duplicated and checked internally
                            • (Apollon77) prevent crash if udp membership can not be added (Sentry fix)
                            • (Apollon77) change object type for compact groups to "folder"
                            • (Apollon77) consider the Adapter Stop Timeout also for adapter restarts to give adapters enough time to stop before restarting
                            • (foxriver76) delete adapter and adapter.admin folders even if no corresponding meta objects exist
                            • (Apollon77) display errors on npm uninstall
                            • (Apollon77) prevent logged error from file DB where it ws tried to write meta file for already deleted folders
                            • (Apollon77) catch errors when letsencrypt server can not bind to port 80 (Sentry IOBROKER-WEB-1)
                            • (foxriver76) catch error on alias ids with empty objects
                            • (Apollon77) make sure promise rejections without error are not crashing the controller
                            • (Apollon77) handle edge case where hostName is not a string when sending messages (Sentry IOBROKER-ADMIN-B)
                            • (Apollon77) handle case where letsencrypt directory can not be created (Sentry IOBROKER-ADMIN-C/IOBROKER-WEB-B)
                            • (foxriver76) fix some logging in objects lib
                            • (Apollon77) make sure to catch error when reading log directory (Sentry IOBROKER-JS-CONTROLLER-1F)
                              (Apollon77) make sure command on cmdExec is a string (Sentry IOBROKER-JS-CONTROLLER-1H)
                            • (Apollon77) Check more cases for existence of variables before accessing them (Sentry IOBROKER-JS-CONTROLLER-E)
                            • (AlCalzone) Add missing parameter digest to crypto calls
                            • (Apollon77) make sure Objects/States backup files are deleted correctly according to backup settings
                            • (foxriver76) Make sure default state value is only set if state is not existing also in setObject
                            • (foxriver76) check that alias is of type state when adding subscribing pattern
                            • (Apollon77) Make sure error are checked correctly (Sentry IOBROKER-JS-CONTROLLER-1N)
                            • (bluefox) store for binary states the binary flag in objects
                            • (Apollon77) update Plugin system
                            • (Apollon77) update Sentry plugin to respect all options to disable reporting including new disableDataReporting flag ( will be integrated into Admin later)
                            • (Apollon77) make sure disabling instances while installation is running do not crash the controller (Sentry IOBROKER-JS-CONTROLLER-Z)
                            • (From Forum) prevent error on backup restore
                            • (Apollon77) Make sure error handing do not throw exception
                            • (Apollon77) Catch all errors when trying to store the File DB (Sentry IOBROKER-JS-CONTROLLER-14/15)
                            • (Apollon77) Make sure also edge cases on start adapter are handled correctly (Sentry IOBROKER-JS-CONTROLLER-12)
                            • (Apollon77) make sure to correctly create empty logfile on "delLogs" (Sentry IOBROKER-JS-CONTROLLER-Q)
                            • (foxriver76) make callback consistent when client has closed connection (Sentry IOBROKER-JS-CONTROLLER-R)
                            • (foxriver76) add missing Error for DB closed, which was used but undefined in tools.js
                            • (foxriver76) if buffer is of type object and not a buffer object log a warning - also bufferFrom null will also result in an error, prevent it (Sentry IOBROKER-JS-CONTROLLER-S)
                            • (foxriver76) in edge cases def can be an object, we also support this on extendObject
                            • (foxriver76) make sure stacktrace is there on validateId
                            • (foxriver76) avoid error on installAdapters function due to downloadyRetry (Sentry IOBROKER-JS-CONTROLLER-V)
                            • (Apollon77) make sure Logfile is rewritten with empty content (Sentry IOBROKER-JS-CONTROLLER-Q)
                            • (foxriver76) ensure backward compatibility with auto decrypt function
                            • (Apollon77) Re-allow states to be set with no val property but check that there is at least one property
                            • (foxriver76) also call enumerateAdapterDocs when deleting all instances
                            • (Apollon77) correct error handling for letsencrypt challenge server
                            • (foxriver76) fix default value of extend*Object
                            • (Apollon77) make sure system.config objects has correct type
                            • (Apollon77) make sure error cases are handled on zip file creation for objects (Sentry IOBROKER-JS-CONTROLLER-J)
                            • (Apollon77) make sure to check id when iterating over it (Sentry IOBROKER-WEB-3)
                            • (Apollon77) Adjust ID checking to allow numbers for non foreign id's for now but log warn
                            • (foxriver76/Apollon77) Adjust extendObject logic and only set state when state was not defined before
                            • (Apollon77) check that path is found before using it on rebuild CLI command (Sentry issue)
                            • (foxriver76) fix error on caught process exceptions
                            • (foxriver76) make sure that procs[id] is not undefined in some cases (Sentry IOBROKER-JS-CONTROLLER-E/G)
                            • (foxriver76/Apollon77) handle weird case where io-package.json from controller is not on normal place when getInstalledInfo is called (Sentry IOBROKER-JS-CONTROLLER-B/C/D/F/H)
                            • (foxriver76) fix bug for some cases where common.def is used on creation of foreign objects
                            • Several additional optimizations and fixes
                            Developer relevant DEPRECATIONS/WARNINGS
                            • (foxriver76) Do not allow access to adapter.states and adapter.objects anymore and add warning logs to deprecate the usage. js-controller 3.1+ will remove these methods. Please adjust your adapters
                            • (foxriver76) Verify that a proper object of type "meta" exists when files are accessed in the internal ioBroker storage and output deprecation logging, these actions will be declined in js-controller 3.1+
                            • (AlCalzone) Validate the object argument to set[Foreign]State[Changed] and log warnings, such invalid set commands will be declined with js-controller 3.1
                            • (Apollon77) Move deprecation of getMessage to next controller version (3.1+)
                            • (foxriver76/Apollon77) Validate that id in several state and object methods is of type string and log warnings
                            • (foxriver76) Add basic checking for obj.common properties including logging. Please check logs and fix them, such invalid objects will be declined with js-controller 3.1
                            Developer relevant new Features
                            • (bluefox/foxriver76) Automatically encrypt all config attributes that are listed in common.encryptedNative in io-package, introduce ADAPTER_AUTO_DECRYPT_NATIVE (see Documentation) Admin support added in Admin 4.0.9!
                            • (bluefox) Introduce new dependency field for io-package called common.globalDependencies to check for global dependencies (see Documentation). Admin support missing as of now!
                            • (AlCalzone) Add command iobroker debug adapter to start Node.js debug sessions for an adapter
                            • (bluefox) Add Controller messages to allow read and write controller base settings (iobroker.json); introduce adapter feature flag CONTROLLER_READWRITE_BASE_SETTINGS
                            • (foxriver76) Make decrypt and encrypt methods available in adapter object for developers. System secret is read automatically so only the value is passed to the function
                            • (AlCalzone) Add adapter exit code 13 (ADAPTER_REQUESTED_REBUILD) to also allow to tell js-controller to rebuild this adapter.
                            • (Apollon77) change logging for invalid readFile actions to debug because ca be triggered also by other cases then planned ones.
                            • (AlCalzone) Allow reverse lookup of exit codes (exit code -> error name)
                            • (bluefox) implement maintenance mode for adapter methods
                            • (AlCalzone) Add 'CONTROLLER_NPM_AUTO_REBUILD' to supported features
                            Developer relevant Optimizations and Fixes
                            • (Apollon77) Make sure that all places in adapters for states and objects that can return "really async" (e.g. because of DB communication) ALWAYS return async! (else callback !--count constructs can fail)
                            • (foxriver76) Also set default values of instanceObjects defined in io-package.json
                            • (bluefox) Improve extension mode for web extensions
                            • (foxriver76) Optimize extendObjects function of adapter.js (use from and ack)
                            • (foxriver76) Use from and ack when creating instanceObjects on installation of an instance
                            • (Apollon77) Fix potential crash where name is no string in some File object operations
                            • (foxriver76) Fix this.stop being undefined on daemon adapters
                            • (foxriver76) Also respect def values of io-package.json on automatic object recreation due to instance start
                            • (foxriver76) Respect state.from if provided on setState
                            • (Apollon77) Enhance checks for getObjectsView response
                            • (bluefox) add IDs to some log messages
                            • general dependency updates
                            • code style optimizations
                            Weitere Details zu den Änderungen und Bugfixes ist im Changelog einzusehen.
                            Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                            Wie Fehler melden?
                            Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                            Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                            Ingo
                            O Offline
                            O Offline
                            Opa75+
                            #1166
                            @apollon77 Hallo
                            Bin Neuling! Habe mich in Thread durchgekämpft und ich bring einfach den JS Controler nicht in eine höhere Version. Meine ist 2.2.9
                            Die Anweisung npm i iobroker@3.1.4 hat nicht geholfen. Nun wollte ich den log kopieren und da muss ich etwas falsch gemacht haben, es kommen lauter Fehlermeldungen.
                            Wie kann ich mein System auf JS Controller 3.x upgraden.
                            JS Controller 2.29
                            node 12.17.0
                            nodejs 12.17.0
                            npm 6.14.4
                            Bitte um Unterstützung
                            • O Opa75+
                              @apollon77 Hallo
                              JS Controller 2.29
                              node 12.17.0
                              nodejs 12.17.0
                              npm 6.14.4
                              Jan1
                              #1167
                              @Opa75
                              das ist eigentlich recht simpel. Du gehst auf das aktualisierungs- Symbol beim Controller und dann seht im Popup genau was zu tun ist.
                              O 1 Antwort Letzte Antwort
                              • J Jan1
                                @Opa75
                                O Offline
                                O Offline
                                Opa75+
                                #1168
                                @Jan1 Danke für die Info.
                                Stehe aber auf der Leitung ?=> Controller. Wo finde ich den? Beim Admin?
                                • O Opa75+
                                  Jan1
                                  #1169
                                  @Opa75
                                  Ok, wenn nicht eingeblendet, dann oben links mal auf das Dreieck, dann Haken bei Host (das ist der Controller). Dann dürfte der Rest selbsterklärend sein. ;-)
                                  • J Jan1
                                    @Opa75
                                    O Offline
                                    O Offline
                                    Opa75+
                                    #1170
                                    @Jan1 Danke und schönes Wochenende
                                    • O Opa75+
                                      Jan1
                                      #1171
                                      @Opa75
                                      Hast es gefunden?
                                      • O Offline
                                        O Offline
                                        Opa75+
                                        #1172
                                        @Jan1 Ja, aber es tut sich nichts. Ich habe mehrere Mal probiert. Es tut sich etwas, dann aus. Restart wieder die selbe Version
                                        J O 2 Antworten Letzte Antwort
                                        • O Opa75+
                                          Jan1
                                          #1173
                                          @Opa75
                                          Dann poste Doch mal das was sich da in der Konsole tut, denn nur so kann man helfen.
                                          Die Ausgabe der Konsole einfach komplett kopieren und hier in Code Tacks im Post einfügen, ist das 5. Symbol oben beim Posten.
