  4. Raspberry - USB-Mount - Verzweiflung
raspberry 4
21 Beiträge 5 Kommentatoren 3.8k Aufrufe 4 Beobachtet
  • Mrs-BM Offline
    Mrs-BM Offline
    Mrs-B
    Ich habe den von dir genannen Befehl abgesetzt. Nur kann ich mit der Antwort nix anfangen :(
    May 20 10:14:34 Mrs-Biesly-Pi colord[733]: failed to get session [pid 413]: Keine Daten verfügbar
    May 20 10:14:34 Mrs-Biesly-Pi kernel: [   23.279207] warning: process `colord-sane' used the deprecated s                                    ysctl system call with 8.1.2.
    May 20 11:36:44 Mrs-Biesly-Pi kernel: [ 4939.761209] systemd: 34 output lines suppressed due to ratelimit                                    ing
    May 20 11:36:53 Mrs-Biesly-Pi kernel: [ 4949.098592] Adding 102396k swap on /var/swap.  Priority:-2 exten                                    ts:1 across:102396k SSFS
    May 20 11:36:55 Mrs-Biesly-Pi kernel: [ 4950.524134] fuse init (API version 7.27)
    May 20 11:37:03 Mrs-Biesly-Pi colord[733]: failed to get session [pid 4974]: Keine Daten verfügbar
    May 20 12:03:03 Mrs-Biesly-Pi udisksd[9119]: udisks daemon version 2.8.1 starting
    May 20 12:03:03 Mrs-Biesly-Pi udisksd[9119]: failed to load module mdraid: libbd_mdraid.so.2: cannot open                                     shared object file: No such file or directory
    May 20 12:03:03 Mrs-Biesly-Pi udisksd[9119]: Failed to load the 'mdraid' libblockdev plugin
    May 20 12:03:03 Mrs-Biesly-Pi udisksd[9119]: Acquired the name org.freedesktop.UDisks2 on the system mess                                    age bus
    • Mrs-BM Mrs-B
      @Mrs-B sagte in Raspberry - USB-Mount - Verzweiflung:
      Sind eigentlich die exfat-utils installiert?
      apt policy exfat-utils
      • Mrs-BM Offline
        Mrs-BM Offline
        Mrs-B
        Hier nochmal ... Hab den Stick raus & wieder rein und dann den Befehl abgegeben
        May 20 12:17:40 Mrs-Biesly-Pi mtp-probe: bus: 1, device: 4 was not an MTP device
        May 20 12:17:40 Mrs-Biesly-Pi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
        May 20 12:17:41 Mrs-Biesly-Pi kernel: [ 7396.882073] scsi 0:0:0:0: Direct-Access     VendorCo ProductCode      2.00 PQ: 0 ANSI: 4
        May 20 12:17:41 Mrs-Biesly-Pi kernel: [ 7396.883004] sd 0:0:0:0: [sda] 122880000 512-byte logical blocks: (62.9 GB/58.6 GiB)
        May 20 12:17:41 Mrs-Biesly-Pi kernel: [ 7396.883227] sd 0:0:0:0: [sda] Write Protect is off
        May 20 12:17:41 Mrs-Biesly-Pi kernel: [ 7396.885458] sd 0:0:0:0: Attached scsi generic sg0 type 0
        May 20 12:17:41 Mrs-Biesly-Pi kernel: [ 7396.887427]  sda: sda1
        May 20 12:17:41 Mrs-Biesly-Pi kernel: [ 7396.902585] sd 0:0:0:0: [sda] Attached SCSI removable disk
        May 20 12:17:41 Mrs-Biesly-Pi usbmount[9521]: /dev/sda does not contain a filesystem or disklabel
        • Mrs-BM Mrs-B
          Jan1
          Mit was ist denn der Stick formatiert und wie heißt er?
          Für mich sieht das so aus, als wäre der mit einem nicht Linux konformen Dateisystem formatiert und unbenannt. Wobei ich ebenfalls ein Linux DAU bin ;-)
          • J Jan1
            @Mrs-B Ich würde vermuten der Stick ist nicht korrekt ausgezeichnet.
            • Mrs-BM Offline
              Mrs-BM Offline
              Mrs-B
              schrieb am zuletzt editiert von Mrs-B
              Das mit dem Stick könnte schon sein..
              Ich hab ihn vorher an einem Windows Rechner genutzt.
              @Thomas-Braun Was meinst du mit "nicht korrekt ausgezeichnet"
              Was muss ich tun um dieses blöde Ding endlich nutzen zu können?
              pi@Mrs-Biesly-Pi:~ $ sudo blkid -o list -w /dev/null
              device                             fs_type       label          mount point                            UUID
              /dev/mmcblk0p1                     vfat          boot           /boot                                  5203-DB74
              /dev/mmcblk0p2                     ext4          rootfs         /                                      2ab3f8e1-7dc6-43f5-b0db-dd5759d51d4e
              /dev/sda1                          exfat                        (not mounted)                          BEB2-6976
              /dev/mmcblk0
              So wird der mir angezeigt...
              • Mrs-BM Mrs-B
                /dev/mmcblk0
                @Mrs-B Lass mich raten: Stick einfach ohne 'Abmeldung' unter Windows aus dem Rechner gerupft?
                Du kannst mal probieren den Stick unter Windows sauber auszuwerfen, dann werden da noch gewisse Dinge draufgeschrieben.
                • Mrs-BM Offline
                  Mrs-BM Offline
                  Mrs-B
                  Nee nee!!
                  Unter Windows ordnungsgemäß abgemeldet vor dem ausstöpseln..
                  Aber habe den Stick nochmal ins Windows gehängt. Dort funktioniert er. Dann ausgeworfen und wieder in den Pi.
                  Erneut versucht zu mounten ... nix...
                  sudo mount -t exfat -o utf8,uid=pi,gid=pi,noatime /dev/sda1/media/usbmedium
                  mount: /dev/sda1/media/usbmedium: can't find in /etc/fstab.
                  • Ralla66R Offline
                    Ralla66R Offline
                    Ralla66
                    @Mrs-B
                    Das wird nicht gehen. da der jetzt Windows Stick ist.
                    Formatiere den mal mit Fat 32 neu.
                    • Mrs-BM Mrs-B
                      Nee nee!!
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @Mrs-B
                      Gehe mal nach dieser Anleitung vor ..
                      https://jankarres.de/2013/01/raspberry-pi-usb-stick-und-usb-festplatte-einbinden/
                      • Besuche meine Github Seite
                      • HowTo Restore ioBroker
                      • simatecS simatec
                        @Mrs-B
                        Ich würde erstmal versuchen ein Label zu setzen.
                        exfatlabel /dev/sda1 LABEL_BEZEICHNUNG
                        ggf. mit 'sudo'
                          ggf. mit 'sudo'
                          Jan1
                          @Thomas-Braun
                          Das kann er aber auch unter Windows tun, da bei mir die in Windows formatierten und gelabelten Sticks auch im Linux so gefunden werden.
                          Nur so wie ich oben schon vermute hat der ein Filesystem drauf, das sein Linux (noch)nicht kennt und der Stick kein Lable.
                          • J Jan1
                            @Thomas-Braun
                            @Jan1 Klar, kann man machen. Unter welchem System man das macht ist ja auch wurscht.
                            Deswegen ist mir auch schleierhaft, wass @Ralla66 damit meint:
                            • J Jan1
                              @Thomas-Braun
                              @Jan1 sagte in Raspberry - USB-Mount - Verzweiflung:
                              Kein Label. Sieht man ja auch hier:
                              /dev/sda1                          exfat           LABELFEHLT             (not mounted)                          BEB2-6976
                              • Mrs-BM Offline
                                Mrs-BM Offline
                                Mrs-B
                                Hey Leute!
                                Ich danke euch sehr für eure tolle Hilfe!
                                Es lag wie immer am dummen User vor der Console 😬
                                Beim Befehl
                                sudo mount -t exfat -o utf8,uid=pi,gid=pi,noatime /dev/sda1 /media/usb0
                                Hatte ich schlicht das Leerzeichen nach dem sda1 vergessen ....
                                Jetzt funktioniert es!!
