  4. Adapter Update Errors nach Node Aktualisierung
iobrokererrornodenode 12
18 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • J Offline
    jlssmt
    ich hab kürzlich aus "Nicht-ioBroker-Gründen" Node von 10 auf 12 LTS geupdated (raspbian Stretch).
    Ich hab mich an folgende Anleitung gehalten: https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
    Leider bekomme ich nun bei jeder Adapter Aktualisierung folgenden Fehler (egal ob über Putty und iobroker upgrade oder über die Web Oberfläche):
    $ ./iobroker upgrade telegram
    Update telegram from @1.4.3 to @1.5.9
    host.raspberrypi Adapter "system.adapter.telegram.0" is stopped.
    host.raspberrypi Adapter "system.adapter.telegram.1" is stopped.
    NPM version: 6.14.5
    npm install iobroker.telegram@1.5.9 --loglevel error --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^
    In file included from ../authenticate_pam.cc:23:0:../../nan/nan.h:1024:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14:0,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../nan/nan.h:54,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67:0,                 from ../../nan/nan.h:54,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14:0,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../nan/nan.h:54,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67:0,                 from ../../nan/nan.h:54,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67:0,                 from ../../nan/nan.h:54,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67:0,                 from ../../nan/nan.h:54,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~In file included from ../../nan/nan.h:54:0,                 from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.66-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.16.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    ╭─────────────────────────────────────────────────────────╮│                                                         ││ Manual installation of ioBroker is no longer supported  ││ on Linux, OSX and FreeBSD!                              ││ Please refer to the documentation on how to install it! ││ https://github.com/ioBroker/ioBroker/wiki/Installation  ││                                                         │╰─────────────────────────────────────────────────────────╯
    npm ERR! code ELIFECYCLEnpm ERR! errno 100
    npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`npm ERR! Exit status 100npm ERR! npm ERR! Failed at the iobroker@2.0.3 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-17T08_05_31_781Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.telegram@1.5.9: 100
    Ein apt full-upgrade und die iobroker/fix.sh hab ich jetzt als error handling auch schon gefahren.
    Kann mir da jemand helfen?
    Danke vorab und Gruß!
    • J jlssmt
      NPM version: 6.14.5
      gyp
       ERR! build error
      @jlssmt
      whoami
      nodejs -v && node -v && npm -V
      which nodejs && which node && which npm
        @jlssmt
        whoami
        jlssmt
        schrieb am zuletzt editiert von jlssmt
        @Thomas-Braun
        pi@raspberrypi:~ $ whoami
        pi
        pi@raspberrypi:~ $ nodejs -v && node -v && npm -v
        v12.16.3
        v12.16.3
        6.14.5
        pi@raspberrypi:~ $ which nodejs && which node && which npm
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        iobroker läuft aber 100% mit dem user "iobroker"
        • J jlssmt
          @Thomas-Braun
          pi
          v12.16.3
          v12.16.3
          6.14.5
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          @jlssmt Passt schon
          iobroker version
            @jlssmt Passt schon
            iobroker version
            jlssmt
            @Thomas-Braun said in Adapter Update Errors nach Node Aktualisierung:
            iobroker version
            2.2.9
            Da steht eben das 10er update aus, das ich nicht installieren kann.
            • J jlssmt
              iobroker version
              2.2.9
              @jlssmt Was meinst du? node10? Du hast doch node 12 laufen.
                jlssmt
                @Thomas-Braun
                Ne das admin adapter 2.2.10 update
                J Thomas BraunT 2 Antworten Letzte Antwort
                • J jlssmt
                  @Thomas-Braun
                  Jan1
                  @jlssmt sagte in Adapter Update Errors nach Node Aktualisierung:
                  @Thomas-Braun
                  Du sprichst in Rätseln.
                  Was willst denn nun updaten, Node oder Admin? Wobei Dein Admin aus der Steinzeit kommt, wir sind bei 4 und Deiner ist 2.
                  • J jlssmt
                    @Thomas-Braun
                    @jlssmt
                    Ist im Ordner /opt/iobroker eine Datei package-lock.json?
                    Ist im Ordner /opt/iobroker/node_modules ein Ordner iobroker ohne führendes @?
                    Zeige bitte den Inhalt der Datei /opt/iobroker/package.json.
                    • J Jan1
                      @Thomas-Braun
                      @Jan1 Das ist wohl der js-Controller in 'default'.
                        Jan1
                        @Thomas-Braun
                        Kommt hin und noch viel Spaß hier, wird bestimmt noch lustig ;-)
                        • J Offline
                          jlssmt
                          @Jan1 @Thomas-Braun
                          Sorry Jungens :-)
                          War n Fehler von mir. Admin ist natürlich 4.0.9 und das Update auf 4.0.10 steht aus.
                          js-controller ist 2.2.9
                          package-lock.json existiert
                          Hier die package.json:
                            "name": "iobroker.inst",
                            "version": "2.0.3",
                            "private": true,
                            "description": "Updated by reinstall.js on 2020-05-14T11:46:29.718Z",
                            "scripts": {
                              "install": "node lib/checkVersions.js",
                              "postinstall": "node lib/install.js",
                              "test": "node node_modules/mocha/bin/mocha --exit"
                            "dependencies": {
                              "colors": "^1.3.3",
                              "fs-extra": "^7.0.1",
                              "iobroker": "2.0.3",
                              "iobroker.admin": "4.0.9",
                              "iobroker.discovery": "2.2.2",
                              "iobroker.flot": "1.9.2",
                              "iobroker.history": "1.8.7",
                              "iobroker.info": "1.7.2",
                              "iobroker.javascript": "4.5.1",
                              "iobroker.js-controller": "2.2.9",
                              "iobroker.material": "0.13.8",
                              "iobroker.scenes": "1.1.0",
                              "iobroker.simple-api": "2.3.2",
                              "iobroker.socketio": "3.0.6",
                              "iobroker.sonoff": "2.3.3",
                              "iobroker.telegram": "1.4.3",
                              "iobroker.terminal": "0.1.2",
                              "iobroker.tr-064": "3.1.4",
                              "iobroker.web": "3.0.7",
                              "iobroker.yeelight-2": "1.0.3",
                              "iobroker.zigbee": "1.0.4",
                              "semver": "^5.6.0",
                              "yargs": "^7.0.2",
                              "iobroker.objects-redis": "2.0.5"
                          • J jlssmt
                            @Jan1 @Thomas-Braun
                            Sorry Jungens :-)
                              "version": "2.0.3",
                              "private": true,
                              "scripts": {
                              "dependencies": {
                                "colors": "^1.3.3",
                                "semver": "^5.6.0",
                                "yargs": "^7.0.2",
                            @jlssmt
                            Lösch mal die Zeile 14 mit
                            raus.
                            Dann
                            iobroker restart
                            iobroker update
                            iobroker upgrade
                              @jlssmt
                              raus.
                              Dann
                              iobroker restart
                              iobroker update
                              iobroker upgrade
                              jlssmt
                              @Thomas-Braun
                              es scheint zu funktionieren. Kann ich dich noch fragen, wie du auf den Fehler bekommen bist? Die node-gyp Error Meldungen scheinen ja irgendwie egal zu sein. Aber wie debugged man sowas?
                              Und wie ist der Fehler entstanden?
                              iobroker upgrade
                              Update admin from @4.0.9 to @4.0.10
                              host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                              NPM version: 6.14.5
                              npm install iobroker.admin@4.0.10 --loglevel error --prefix "/opt/iobroker" (Sys        tem call)
                              gyp ERR! build error
                              gyp ERR! not ok
                              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                              Update "system.adapter.admin.0"
                              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                              Adapter "admin" updated
                              host.raspberrypi Adapter "system.adapter.admin.0" is started
                              • J jlssmt
                                @Thomas-Braun
                                iobroker upgrade
                                NPM version: 6.14.5
                                gyp ERR! not ok
                                @jlssmt Drauf gekommen bin ich durch die Zeilen 21 + 22 in deinem ersten log:
                                Eingehandelt hast du dir das vermutlich hierdurch:
                                Da hast du wohl irgendwas einfach unsauber drüber geknallt, vermute ich.
                                Lass mal ein
                                iobroker rebuild self
                                laufen
                                  Lass mal ein
                                  laufen
                                  jlssmt
                                  @Thomas-Braun
                                  die reinstall.js kommt halt aus der Anleitung (Punkt 4.c) ) hier: https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                                  Die Community hier ist echt Bombe. Aber manchmal sind es leider einfach zu viele (teilweise auch veraltete) Informationen.
                                  Meine Adapter wurden jetzt alle erfolgreich geupdated.
                                  iobroker rebuild self geht leider nicht. rebuild existiert (bei mir) nicht als command.
                                  • J jlssmt
                                    @Thomas-Braun
                                    @jlssmt
                                    Das mit dem reinstall ist aber auch erst Option c)
                                    Mach mal in /opt/iobroker ein
                                    npm rebuild
                                      @jlssmt
                                      npm rebuild
                                      jlssmt
                                      @Thomas-Braun
                                      erledigt. Ich denk es läuft alles wieder. Danke dir auf jeden Fall!
