  4. externes Bild in VIS
viscamera
23 Beiträge 4 Kommentatoren 3.8k Aufrufe 4 Beobachtet
  • NegaleinN Negalein
    @Glasfaser sagte in externes Bild in VIS:
    Ich kann dir höchstens meins anbieten :
    Servus
    Jetzt bin ich endlich dazu gekommen es zu testen.
    Leider haut er mir für Zeile 22 einen Fehler raus.
    Exec ist im JS-Adapter erlaubt.
    javascript.0	2020-04-29 15:13:58.239	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-04-29 15:13:58.239	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-04-29 15:13:58.239	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-04-29 15:13:58.238	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:572:33)
    javascript.0	2020-04-29 15:13:58.238	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1055:17)
    javascript.0	2020-04-29 15:13:58.238	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1464:17)
    javascript.0	2020-04-29 15:13:58.238	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1411:37)
    javascript.0	2020-04-29 15:13:58.238	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1188:28)
    javascript.0	2020-04-29 15:13:58.238	error	(594) at Object.createScript (vm.js:277:10)
    javascript.0	2020-04-29 15:13:58.238	error	(594) at new Script (vm.js:83:7)
    javascript.0	2020-04-29 15:13:58.238	error	(594) SyntaxError: Invalid or unexpected token
    javascript.0	2020-04-29 15:13:58.237	error	(594) ^^^
    javascript.0	2020-04-29 15:13:58.237	error	(594) exec('wget --output-document /_temp/Max/Max.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi'');
    javascript.0	2020-04-29 15:13:58.237	error	at script.js.Doorbird.Doorbird_Bilder_Max:22
    javascript.0	2020-04-29 15:13:58.237	error	(594) script.js.Doorbird.Doorbird_Bilder_Max compile failed:
    const idklingel = ["doorbird.0.Doorbell.101.trigger"];
    var sperre = false;  //verhindert das doppeltes Drücken das Script stoppt
    var timeout1, timeout2, timeout3, timeout4, timeout5, timeout6, timeout7, timeout8, timeout9, timeout10, timeout11;
    var fs = require('fs');
    on({id: idklingel, change: "any"}, function (obj) {
     if(!sperre) {
       sperre = true;
        // Speichert das erste Bild bei Klingeln
        // Nach dem ersten Bild wird nach 2000ms das nächste Bild gespeichert
       timeout1 = setTimeout(function () {
         exec('wget --output-document /_temp/Max/Max2.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi'');
       }, 2000);
        // Nach dem zweiten Bild wird nach 2000ms das nächste Bild gespeichert
       timeout2 = setTimeout(function () {
         exec('wget --output-document /_temp/Max/Max3.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi'');
       }, 4000);
        // Nach dem dritten Bild wird nach 2000ms das nächste Bild gespeichert
       timeout3 = setTimeout(function () {
         exec('wget --output-document /_temp/Max/Max4.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi'');
       }, 6000);
    // Telegram versenden
        timeout4 = setTimeout(function(){
            sendTo('telegram.0', {text: '/_temp/Max/Max1.jpg', caption: 'Jemand klingelt an der Haustür !!!'});
                    //log ('__ Klingel-Bild wurde versendet __');
        }, 10000);
        timeout5 = setTimeout(function(){
            sendTo('telegram.0', {text: '/_temp/Max/Max2.jpg', caption: 'Jemand klingelt an der Haustür !!!'});
        }, 11000);
        timeout6 = setTimeout(function() {
           sperre = false;
        }, 5000); //Zeit für Klingelsperre 1.Zeile
        // Bilder werden nach vis gespeichert
       timeout7 = setTimeout(function () {
            const bild1 = fs.readFileSync('/_temp/Max/Max1.jpg');
            writeFile('vis.0','/_temp/Max/Max1.jpg', bild1);
            const bild2 = fs.readFileSync('/_temp/Max/Max2.jpg');
            writeFile('vis.0','/_temp/Max/Max2.jpg', bild2);
            const bild3 = fs.readFileSync('/_temp/Max/Max3.jpg');
            writeFile('vis.0','/_temp/Max/Max3.jpg', bild3);
            const bild4 = fs.readFileSync('/_temp/Max/Max4.jpg');
            writeFile('vis.0','/_temp/Max/Max4.jpg', bild4);
       }, 20000);
    Hast du einen Tipp für mich?
    Und um Telegram nicht zu verwenden, reicht es Zeile 50-66 auszukommentieren, oder bis Zeile 69?
    GlasfaserG Offline
    GlasfaserG Offline
    @Negalein
    Teste mal :
    nur User / Pass ändern
     if(!sperre) {
       sperre = true;
       exec('wget --output-document /tmp/max1.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi\'');
         exec('wget --output-document /tmp/max2.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi\'');
       }, 2000);
         exec('wget --output-document /tmp/max3.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi\'');
       }, 4000);
         exec('wget --output-document /tmp/max4.jpg \'http://xxxxxx:xxxxxx@10.0.1.84/bha-api/image.cgi\'');
       }, 6000);
           sendTo('telegram.0', {text: '/tmp/max1.jpg', caption: 'Jemand klingelt an der Haustür !!!'});
       }, 10000);
           sendTo('telegram.0', {text: '/tmp/max2.jpg', caption: 'Jemand klingelt an der Haustür !!!'});
       }, 11000);
          sperre = false;
            const bild1 = fs.readFileSync('/tmp/max1.jpg');
            const bild2 = fs.readFileSync('/tmp/max2.jpg');
            const bild3 = fs.readFileSync('/tmp/maxt3.jpg');
            const bild4 = fs.readFileSync('/tmp/max4.jpg');
       }, 20000);
    • GlasfaserG Glasfaser
      @Negalein
      Teste mal :
       if(!sperre) {
         sperre = true;
         }, 2000);
         }, 4000);
         }, 6000);
         }, 10000);
         }, 11000);
            sperre = false;
         }, 20000);
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      Teste mal :
      Danke, kommen keine Fehler mehr. :)
      beim Klingeln speichert er die Bilder in /tmp/max1.jpg und kopiert sie dann in vis.0/_temp/Max/Max1.jpg ?
      Muss der Ordner _temp/Max/ händisch angelegt werden?
      Weißt du auch noch das wegen Telegram?
      ° Fixer ---> iob fix
        Teste mal :
        GlasfaserG Offline
        GlasfaserG Offline
        @Negalein sagte in externes Bild in VIS:
        Ja ... mit dem Dateimanager ;)
        Telegram kannst du auch löschen , wenn nicht benötigt
          NegaleinN Offline
          NegaleinN Offline
          Negalein
            GlasfaserG Offline
            GlasfaserG Offline
            @Negalein
            Eingentlich ja ... kann gerade nicht testen ... mußt du machen :)
              GlasfaserG Offline
              GlasfaserG Offline
              @Negalein
              Habe auch noch ein Fehler beseitigt ..
               if(!sperre) {
                 sperre = true;
                 }, 2000);
                 }, 4000);
                 }, 6000);
                 }, 10000);
                 }, 11000);
                    sperre = false;
                      const bild3 = fs.readFileSync('/tmp/max3.jpg');
                 }, 20000);
              Edit :
              das {1} kommt durch das Importieren in den Forum Editor
              NegaleinN 2 Antworten Letzte Antwort
                @Negalein
                 if(!sperre) {
                   sperre = true;
                   }, 2000);
                   }, 4000);
                   }, 6000);
                   }, 10000);
                   }, 11000);
                      sperre = false;
                   }, 20000);
                Edit :
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                Danke, habs gleich neu angelegt.
                  @Negalein
                   if(!sperre) {
                     sperre = true;
                     }, 2000);
                     }, 4000);
                     }, 6000);
                     }, 10000);
                     }, 11000);
                        sperre = false;
                     }, 20000);
                  Edit :
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  dieser Ordner muss unter files angelegt werden?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @Negalein
                    Nö ... wird alles automatisch angelegt
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Negalein
                      .... hier nur mit einem Klingelbild
                      if(!sperre) {
                        sperre = true;
                        }, 2000);
                        }, 4000);
                        }, 6000);
                        }, 10000);
                        }, 11000);
                           sperre = false;
                        }, 20000);
                        @Negalein
                        if(!sperre) {
                          sperre = true;
                          }, 2000);
                          }, 4000);
                          }, 6000);
                          }, 10000);
                          }, 11000);
                             sperre = false;
                          }, 20000);
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Muss im anderen Thread nochmal schauen.
                        Ideal wäre es, wenn auch die letzten 3 oder 4 gespeichert bleiben um sie in VIS anzuzeigen.
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Das geht mit dem Script so nicht ,
                          da der Speichername vom Bild nicht Variabel/Zeitstempel gespeichert wird.
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            Ja, leider.
                            Vielleicht finde ich im anderen Thread noch eine Lösung.
                            • Basti97B Offline
                              Basti97B Offline
                              Basti97
                              Ich weiß nicht ob es hier her passt. Ich habe meine Kamerabild auch per Link in meine vis eingefügt. Nun habe ich das Problem das, dass Bild auf Firefox (Win10) funktioniert und angezeigt wird aber auf dem Smartphone (android) per Browser nicht.
                              Die Dateiendung des Links ist .cgi
                              Der vis Baustein nennt sich Basic Image.
                              Weiß jemand eine Lösung.
                              DAnke im vorraus.
                              Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                              R 1 Antwort Letzte Antwort
                              • Basti97B Basti97
                                DAnke im vorraus.
                                RandyAndy
                                schrieb am zuletzt editiert von RandyAndy
                                @Basti97
                                das mit Kamerabildern ist so eine Sache und da kommt schnell auch die basic authentication hinzu das heutige browser nicht mehr wirklich unterstützen.
                                Ich habe mich da ewig mit gespielt und am Ende habe ich es so gemacht das ich mir in regelmäßigen Abständen ein File auf einer RAM-Disk abspeichere. Diese Datei rufe ich dann über einen Web-Server auf den ich auf dem RaspberryPi installiert habe (Anleitung gibt es zu Hauf im Internet).
                                Das funktioniert seit ca. 1 Jahr recht stabil und am Wichtigsten ist ich schreibe keine Daten auf die SD-Karte.
                                Andreas
                                Basti97B 1 Antwort Letzte Antwort
                                • R RandyAndy
                                  @Basti97
                                  Andreas
                                  Basti97B Offline
                                  Basti97B Offline
                                  Basti97
                                  @RandyAndy Danke für deinen Tipp ich probiere es mal. Das komische ist ja das Firefox es unterstützt aber die Mobilen Browser nicht mehr. Wenn gar nichts gegangen wäre hätte ich es ja verstanden aber so.
