  4. [Tablet Control] Tablet Steuerung möchte getestet werden
    6.5k
adapterfully kiosk browserfullybrowsertablettablet-controltesttesten
512 Beiträge 50 Kommentatoren 128.0k Aufrufe 71 Beobachtet
  • ChaotC Chaot
    @Issi
    Leider mit ein paar Fehlermeldungen:
    fully-tablet-control.0	2020-05-13 08:41:57.584	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    fully-tablet-control.0	2020-05-13 08:41:57.584	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:34)
    fully-tablet-control.0	2020-05-13 08:41:57.584	error	at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:669:16)
    fully-tablet-control.0	2020-05-13 08:41:57.584	error	at JSON.parse (<anonymous>)
    fully-tablet-control.0	2020-05-13 08:41:57.584	error	(27245) [dayBri] : Unexpected token u in JSON at position 0, stack: SyntaxError: Unexpected token u in JSON at position 0
    fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:3)
    fully-tablet-control.0	2020-05-13 08:41:57.582	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.create_state (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:1322:9)
    fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.manualStates (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:623:15)
    fully-tablet-control.0	2020-05-13 08:41:57.582	error	at JSON.parse (<anonymous>)
    fully-tablet-control.0	2020-05-13 08:41:57.582	error	(27245) [manualStates] : Unexpected token u in JSON at position 0, stack: SyntaxError: Unexpected token u in JSON at position 0
    fully-tablet-control.0	2020-05-13 08:41:56.662	info	(27245) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.fully-tablet-control, node: v12.16.3, js-controller: 3.1.4
    Hast du auch noch aufgeschlüsselt wie die State_of_charge jetzt aussehen?
    Edit:
    Die Fehlermeldung kam wenn bei beiden Helligkeitseinstellungen kein Haken gesetzt war.
    Sind beide aktiv kommt kein Fehler.
    IssiI Offline
    IssiI Offline
    Issi
    schrieb am zuletzt editiert von Issi
    @Chaot sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
    @Issi
    das passiert nur dann wen du bereits Geräte angelegt hast und das update drüber installierst da wird die spalte erstellt in der Tabelle aber kein state drin da einfach bei beiden den haken rein und dann speichern dann kommt das nicht mehr wen du eine Geräte anlegst ist da ein Default wert drin
    die Beschreibung habe ich noch nicht gemacht war gestern schon spät werde noch die README ergänzen in den state kann man das auch schnell erkennen da er ein mal eine normale zahl 55% und einmal ein charge 55% gibt charge kommt immer dann wen geladen wird
    • jackblacksonJ jackblackson
      @Issi Ich bin grad mit der Helligkeitssteuerung am Tablet am spielen. Hier hast du ja einen Tag und einen Nachtmodus. Meinst du, du könntest hier statt der Uhrzeit auch Sonnenaufgang sowie Sonnenuntergang anbieten? Die Datenpunkte solltest du bekommen können (getAstroDate). Glaub das würde Sinn machen, nicht? Weil sonst muss man es ja je nach Jahreszeit anpassen.
      IssiI Offline
      IssiI Offline
      Issi
      @jackblackson werde ich mal schauen wie ich das am besten einbauen kann da ich z.B. nicht bei Sonnenaufgang und Sonnenuntergang die zeit eingestellt habe. Ich werde das auch mal auf die liste setzen.
      IssiI 1 Antwort Letzte Antwort
      • ChaotC Chaot
        @Issi
        Die letzte Frage hat sich erledigt. Ich habe für das View 8 die Zustände des Akkus zum Laden selbst gefunden.
        0= 0%
        1= 10%
        2= 10% laden an
        3= 20%
        4= 20% laden an
        5= 30%
        6= 30% laden an
        7= 40%
        8= 40% laden an
        9= 50%
        10= 50% laden an
        11= 60%
        12= 60% laden an
        13= 70%
        14= 70% laden an
        15= 80%
        16= 80% laden an
        17= 90%
        18= 90% laden an
        19= 100%
        20= 100% laden an
        Danke für die Änderung. Klappt perfekt!
        Hier mal ein Widget als Muster mit allen Batterieständen:
        [{"tpl":"tplStatefulImage8","data":{"oid":"fully-tablet-control.0.device.eingang.state_of_charge_vis","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","count":"20","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_11":"/icons-open-icon-library-png/status/battery-060.png","src_10":"/icons-open-icon-library-png/status/battery-charging-050.png","src_9":"/icons-open-icon-library-png/status/battery-050.png","src_8":"/icons-open-icon-library-png/status/battery-charging-040.png","src_7":"/icons-open-icon-library-png/status/battery-040.png","src_6":"/icons-open-icon-library-png/status/battery-charging-030.png","src_5":"/icons-open-icon-library-png/status/battery-030.png","src_4":"/icons-open-icon-library-png/status/battery-charging-020.png","src_3":"/icons-open-icon-library-png/status/battery-020.png","src_2":"/icons-open-icon-library-png/status/battery-charging-010.png","src_1":"/icons-open-icon-library-png/status/battery-010.png","src_0":"/icons-open-icon-library-png/status/battery-000.png","src_13":"/icons-open-icon-library-png/status/battery-070.png","src_15":"/icons-open-icon-library-png/status/battery-080.png","src_17":"/icons-open-icon-library-png/status/battery-090.png","src_19":"/icons-open-icon-library-png/status/battery-100.png","src_20":"/icons-open-icon-library-png/status/battery-charging-100.png","src_18":"/icons-open-icon-library-png/status/battery-charging-090.png","src_16":"/icons-open-icon-library-png/status/battery-charging-080.png","src_14":"/icons-open-icon-library-png/status/battery-charging-070.png","src_12":"/icons-open-icon-library-png/status/battery-charging-060.png"},"style":{"left":"177px","top":"76px","width":"44px","height":"43px"},"widgetSet":"basic"}]
        Verwendet habe ich dabei die open icons library
        IssiI Offline
        IssiI Offline
        Issi
        @Chaot
        danke für das Beispiel Widget werde ich dann auch in die README eintragen.
        • C calliou1234
          @Issi
          Hallo Issi,
          gute Idee mit dem Adapter und mille grazie hierfür. Ich bin gerade dabei meine Scripts durch deinen Adapter zu ersetzen.
          Ich schalte aktuell wenn niemand zu Hause ist das Display des Tablets aus.
          Wäre sowas integrierbar?
          Link auf ein Anwesenheits-Object (Bool), wenn jemand da, dann Display an, wenn niemand da aus.
          Thomas
          IssiI Offline
          IssiI Offline
          Issi
          @calliou1234 in einer späteren Version von den Adapter werden die commands von dem fullybrowser drin sein da kann man dann den Bildschirm ein und ausschalten.
          denn kann man dann per script schalten z.B. Anwesenheits Erkennung script.
          • JohGreJ Offline
            JohGreJ Offline
            JohGre
            Hallo, habe eben den Adapter installiert und bekomme folgende Fehlermeldung:
            Fully läuft auf einem Samsung Galaxy Tab 4 Android 5.02
            2020-05-13 14:23:55.523 - error: fully-tablet-control.0 (5891) [manualStates] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
            at FullyTabletControl.manualStates (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:623:50)
            2020-05-13 14:23:55.524 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
            at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:669:37)
            2020-05-13 14:25:00.006 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
            at CronJob. (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:570:9)
            at CronJob.fireOnTick (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:600:23)
            at Timeout.callbackWrapper [as _onTimeout] (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:667:10)
            at listOnTimeout (internal/timers.js:549:17)
            at processTimers (internal/timers.js:492:7)
            nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
            • JohGreJ JohGre
              IssiI Offline
              IssiI Offline
              Issi
              @JohGre
              hast du vorher schon eine frühere version installiert gehabt ?
              JohGreJ 1 Antwort Letzte Antwort
              • IssiI Issi
                @JohGre
                JohGreJ Offline
                JohGreJ Offline
                JohGre
                @Issi sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
                frühere version
                Hi, von was? Adapter oder Fully Browser
                • JohGreJ JohGre
                  frühere version
                  IssiI Offline
                  IssiI Offline
                  Issi
                  @JohGre den Fully Tablet Control dieser Fehler kommt nur dann wen der Adapter vorher schon mal installiert war und eingerichtet wurde bei einem ganz frischen Installation kommt er nicht hab ich grade getestet
                  • JohGreJ Offline
                    JohGreJ Offline
                    JohGre
                    So, habe nun die Instanz gelöscht und eine neue hinzugefügt. Nun kommt der Fehler nicht mehr.
                    Diese Datenpunkte wurden angelegt, schaut eigentlich ganz gut aus.
                    Eine Änderung des Datenpunkts level.dimmer bewirkt jedoch nichts.
                    • JohGreJ JohGre
                      IssiI Offline
                      IssiI Offline
                      Issi
                      @JohGre Bitte lese die einleitung auf der GitHub seite da ist vieles beschriben wie dises problem von dir auch GitHub link
                      • IssiI Issi
                        JohGreJ Offline
                        JohGreJ Offline
                        JohGre
                        @Issi
                        Danke, wer lesen kann , ist klar im Vorteil ;-)
                        • JohGreJ Offline
                          JohGreJ Offline
                          JohGre
                          @Issi Hätte da einen Featurewunsch:
                          Für mich wäre es super wenn die Umschaltung zwischen Tag- und Nachthelligkeit über entsprechende Astrozeiten zu steuern wären.
                          zB: Tagwert-->bei sunriseEnd, goldenhourEnd,..., Nachtwert --> bei sunsetStart , sunset,...
                          Natürlich könnte man das auch per Script lösen, aber wenn schon eine Zeitsteuerung eingebaut ist ;-)
                          • IssiI Issi
                            IssiI Offline
                            IssiI Offline
                            Issi
                            @JohGre
                            wie ich schon weiter oben sagte werde ich das auf die liste setzen da ich da erst schauen muss wie genau ich das einbaue da ich z.B. nicht nach der Astrozeiten eingestellt habe
                            • IssiI Offline
                              IssiI Offline
                              Issi
                              so neue Version 0.2.5 ist auf GitHub verfügbar:
                              hab den FullyBrowser Adapter implementiert und paar bugs behoben
                              siggi85S 1 Antwort Letzte Antwort
                              • IssiI Issi
                                siggi85S Offline
                                siggi85S Offline
                                siggi85
                                schrieb am zuletzt editiert von siggi85
                                @Issi Erste Tests sehen gut aus. Durch die Kommandos wäre es mir jetzt wirklich möglich den alten Fully Adapter mit diesem zu ersetzen. Da dieser noch in Entwicklung ist, ware ich aber noch etwas damit. Schon Mal danke für die Arbeit an diesem Adapter! 👍
                                EDIT: Etwas zu früh gefreut. ;) habe ein paar Fehler im Log:
                                fully-tablet-control.0	2020-05-17 08:04:48.267	warn	(20790) Wohnzimmer charger not specified
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:684:17)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6814:25)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7117:22)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.emit (events.js:198:13)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:92:14)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.initialization (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:184:50)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	(20790) [initialization] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
                                Meine Konfiguration ist ganz simpel (Eintrag für Ladegerät habe ich gelöscht, ist das der Fehler?!)
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  ich hab auch ..direkt nach neu installation und start..
                                  es sind nicht alle Datenpunkte gefüllt.. klar logisch. hab ja nur die erste seite gefüllt.. also nur die ip eingetragen
                                  muttu abfangen
                                  das warning würde ich auch abschalten. oder schaltbar machen.. mehr Infos weniger infos.
                                  ich will es nicht nutzen.. und so bekomme ich ständig das warning ..
                                  hier währe eigener Datenpunkt nützlich.. ich stuere meine helligkeit abhängig vom aussen Helligkeitsensor
                                  mit Schwellwert (als Anregung)
                                  ansonsten TOP..
                                  • arteckA arteck
                                    muttu abfangen
                                    ansonsten TOP..
                                    IssiI Offline
                                    IssiI Offline
                                    Issi
                                    @arteck @siggi85
                                    @arteck sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
                                    muttu abfangen
                                    die Ladefunktion kan man ganz abschalten dan kommt auch kein warning im log
                                    das mit dem error hab ich zwar schon was drin zum abfangen und in den test hat es funktioniert aber ich schau es mir noch mal an.
                                    hier währe eigener Datenpunkt nützlich.. ich steure meine helligkeit abhängig vom aussen Helligkeitsensor
                                    dafür gibt es auch ein eigenen Datenpunkt in den objekten
                                    Nr. 1 auf User einstellen und bei 2 kannst du die Helligkeit in 0% bis 100% einstehlen.
                                    dieser Funktion sorgt nur das der Bildschirm nicht ausgeschaltet werden kann über den Knopf am Tablett oder automatisch da manche Tabletts die Wlan Verbindung abschalten wen der Bildschirm länger ausgeschaltet ist.
                                    PS. hab glaub das Problem mit den error gefunden werde es beheben und dann bescheid sagen
                                    • IssiI Offline
                                      IssiI Offline
                                      Issi
                                      so hab nun die Helligkeitssteuerung etwas angepasst jetzt kann man sie komplett auf manuelle Steuerung oder auf zeit + manuell einstellen
                                      wenn sie über Nr.10 die Steuerung auf manuell geschaltet haben braucht man keine Tabelle unten erstellen
                                      wenn sie es auf Konfigurationsseite geschaltet haben MUSS die Tabelle angelegt werden für jedes Tablet das auf der Login Seite erstellt wurde wer bei einem oder mehreren Tabletts die zeit Steuerung nicht nutzen will kann über die Nr. 8 auf manuell Steuerung schalten nur für dieses Tablett.
                                      die Version 0.2.6 ist auf GitHub verfügbar
                                      • IssiI Offline
                                        IssiI Offline
                                        Issi
                                        #66
                                        neue Version 0.2.7 auf GitHub verfügbar:
                                        @JohGre @jackblackson Hab die Astro Funktion nun eingebaut hat etwas gedauert da es nicht so einfach ist wie z.B. über (getAstroDate) da getAstroDate eine unter Funktion vom JavaScript Adapter ist musste ich erst mal schauen wie ich das einbauen kann.
                                        unter Nr. 11 kann man jetzt entscheiden was für eine zeit Steuerung verwendet wird Standard ist Astro Zeit.
                                        unter 12 kommt die Astro Zeit für den Tages beginn rein als wann das Tablett hoch dimmen soll und unter 13 dann wann er ab dimmen soll.
                                        • IssiI Issi
                                          JohGreJ Offline
                                          JohGreJ Offline
                                          JohGre
                                          #67
                                          @Issi Danke dafür, werd ich morgen gleichmal austesten.
