  4. Downgrade iobroker 3.0.20 zurück auf 2.2.9?
downgradeiobroker3.0.202.2.9
4 Beiträge 2 Kommentatoren 367 Aufrufe 2 Beobachtet
  • ? Offline
    ich bitte um Hilfe.
    Wie kann ich auf meinem RPI4 von iobroker 3.0.20 zurück auf 2.2.9 gehen?
    pi@raspberrypi:~ $ iobroker install js-controller@2.2.9
    adapter "js-controller" already installed. Use "upgrade" to upgrade to a newer version.
    pi@raspberrypi:~ $ iobroker version
    3.0.20
      ich bitte um Hilfe.
      3.0.20
      @TH-G
      npm install iobroker.js-controller@2.2.9
      Auszuführen in /opt/iobroker.
      Zuvor
      iobroker stop
      wäre auch keine doofe Idee.
      • ? Offline
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ iobroker stop
        pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@2.2.9
        iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        node lib/preinstallCheck.js
        NPM version: 6.14.4
        iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
        node iobroker.js setup first
        The following notifications happened during sync:
        • Ignoring Directory "icons-material-png" because officially not created as meta object. Please remove directory!
        • Ignoring Directory "icons-material-png.admin" because officially not created as meta object. Please remove directory!
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        • iobroker.js-controller@2.2.9
          removed 80 packages and updated 4 packages in 25.668s
        4 packages are looking for funding
        run npm fund for details
        pi@raspberrypi:/opt/iobroker $ iobroker version
        2.2.9
        Danke hat geklappt
          NPM version: 6.14.4
          2.2.9
          Danke hat geklappt
          @TH-G Schön. Aber mach dem skript-Kollegen einen issue in git auf. Der muss da ran.
