<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Downgrade iobroker 3.0.20 zurück auf 2.2.9?]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">ich bitte um Hilfe.</p>
<p dir="auto">Wie kann ich auf meinem RPI4 von iobroker 3.0.20 zurück auf 2.2.9 gehen?</p>
<p dir="auto">pi@raspberrypi:~ $ iobroker install js-controller@2.2.9<br />
adapter "js-controller" already installed. Use "upgrade" to upgrade to a newer version.<br />
pi@raspberrypi:~ $ iobroker version<br />
3.0.20</p>
<p dir="auto">Danke</p>
]]></description><link>https://forum.iobroker.net/topic/33160/downgrade-iobroker-3-0-20-zurück-auf-2-2-9</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 00:14:16 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/33160.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 May 2020 11:15:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Downgrade iobroker 3.0.20 zurück auf 2.2.9? on Fri, 08 May 2020 11:40:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/th-g" aria-label="Profile: TH-G">@<bdi>TH-G</bdi></a> Schön. Aber mach dem skript-Kollegen einen issue in git auf. Der muss da ran.</p>
]]></description><link>https://forum.iobroker.net/post/428445</link><guid isPermaLink="true">https://forum.iobroker.net/post/428445</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 08 May 2020 11:40:40 GMT</pubDate></item><item><title><![CDATA[Reply to Downgrade iobroker 3.0.20 zurück auf 2.2.9? on Fri, 08 May 2020 11:37:08 GMT]]></title><description><![CDATA[<p dir="auto">pi@raspberrypi:~ $ cd /opt/iobroker<br />
pi@raspberrypi:/opt/iobroker $ iobroker stop<br />
pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@2.2.9</p>
<blockquote>
<p dir="auto">iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller<br />
node lib/preinstallCheck.js</p>
</blockquote>
<p dir="auto">NPM version: 6.14.4</p>
<blockquote>
<p dir="auto">iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller<br />
node iobroker.js setup first</p>
</blockquote>
<p dir="auto">The following notifications happened during sync:</p>
<ul>
<li>Ignoring Directory "icons-material-png" because officially not created as meta object. Please remove directory!</li>
<li>Ignoring Directory "icons-material-png.admin" because officially not created as meta object. Please remove directory!</li>
</ul>
<p dir="auto">npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):<br />
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})<br />
npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@&gt;= 5.0.0 but none is installed. You must install peer dependencies yourself.<br />
npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@&gt;= 5.0.0 but none is installed. You must install peer dependencies yourself.<br />
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):<br />
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})</p>
<ul>
<li>iobroker.js-controller@2.2.9<br />
removed 80 packages and updated 4 packages in 25.668s</li>
</ul>
<p dir="auto">4 packages are looking for funding<br />
run <code>npm fund</code> for details</p>
<p dir="auto">pi@raspberrypi:/opt/iobroker $ iobroker version<br />
2.2.9</p>
<p dir="auto">Danke hat geklappt</p>
]]></description><link>https://forum.iobroker.net/post/428439</link><guid isPermaLink="true">https://forum.iobroker.net/post/428439</guid><dc:creator><![CDATA[TH G]]></dc:creator><pubDate>Fri, 08 May 2020 11:37:08 GMT</pubDate></item><item><title><![CDATA[Reply to Downgrade iobroker 3.0.20 zurück auf 2.2.9? on Fri, 08 May 2020 11:21:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/th-g" aria-label="Profile: TH-G">@<bdi>TH-G</bdi></a></p>
<pre><code>npm install iobroker.js-controller@2.2.9
</code></pre>
<p dir="auto">Auszuführen in /opt/iobroker.<br />
Zuvor</p>
<pre><code>iobroker stop
</code></pre>
<p dir="auto">wäre auch keine doofe Idee.</p>
]]></description><link>https://forum.iobroker.net/post/428415</link><guid isPermaLink="true">https://forum.iobroker.net/post/428415</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 08 May 2020 11:21:52 GMT</pubDate></item></channel></rss>
