  4. Fehler bei Update diverser Adapter.
install adapter update
71 Beiträge 5 Kommentatoren 8.5k Aufrufe 5 Beobachtet
  • L Landmilch
    Habe vorgestern meine Node.js auf v12.16.3 "erfolgreich" upgedatet. Folgend lassen sich nun einige Adapter nicht mehr updaten. Hat jemand eine Idee, was man da machen kann?
    Folgende Info stand im Log.
    $ ./iobroker upgrade web
    Update web from @3.0.7 to @3.0.8
    NPM version: 6.14.4
    npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    ╭─────────────────────────────────────────────────────────╮│ ││ Manual installation of ioBroker is no longer supported ││ on Linux, OSX and FreeBSD! ││ Please refer to the documentation on how to install it! ││ https://github.com/ioBroker/ioBroker/wiki/Installation ││ │╰─────────────────────────────────────────────────────────╯
    npm
    ERR! code ELIFECYCLEnpm ERR! errno 100npm ERR! iobroker@2.0.3 postinstall: node lib/install.jsnpm ERR! Exit status 100npm ERR! npm
    ERR! Failed at the iobroker@2.0.3 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-06T13_36_33_207Z-debug.log
    ERROR: host.iobroker Cannot install iobroker.web@3.0.8: 100
    @Landmilch
    node -v
    nodejs -v
    npm -v
    lsb_release -a
    iobroker version
    L 1 Antwort Letzte Antwort
    • L Landmilch
      NPM version: 6.14.4
      npm
      @Landmilch sagte:
      Web 3.0.8 verlangt adapter-core ab Version 2.4.0 ?
        @Landmilch
        node -v
        nodejs -v
        npm -v
        lsb_release -a
        iobroker version
        Landmilch
        @Thomas-Braun said in Fehler bei Update diverser Adapter.:
        iobroker version
        Sorry. Anbei die installierten Versionen
        node -v
        v12.16.3
        nodejs -v
        v12.16.3
        npm -v
        6.14.4
        lsb_release -a
        No LSB modules are available.
        Distributor ID: Raspbian
        Description: Raspbian GNU/Linux 10 (buster)
        Release: 10
        Codename: buster
        iobroker version
        3.0.20
          @Landmilch sagte:
          Landmilch
          Wie machen ich das Update des adapter-core auf Version 2.4.0?
          • L Landmilch
            @Landmilch
            iobroker version
            Edit: Sorry, ich hab Tomaten auf den Augen.
            • L Landmilch
              iobroker version
              node -v
              v12.16.3
              nodejs -v
              v12.16.3
              npm -v
              6.14.4
              lsb_release -a
              Release: 10
              Codename: buster
              iobroker version
              3.0.20
              @Landmilch sagte:
              iobroker version 3.0.20
              Hast Du damit wieder ein Update auf Web 3.0.8 versucht ?
              • L Offline
                Landmilch
                Ist der iobroker veraltet?
                  @Landmilch sagte:
                  Landmilch
                  In meiner Konsole steht:
                  ioBroker.admin 4.1.1
                  • L Landmilch
                    @Landmilch Der ist eigentlich akutell.
                    js-controller != admin
                    • L Landmilch
                      @Landmilch
                      iobroker fix
                      whoami
                      • L Offline
                        Landmilch
                        Super. Jetzt hab ich mich selbst ausgesperrt. Hab den admin in der Weboberfläche angehalten. Nun komme ich per Browser nicht mehr drauf.
                        Hat jemand einen Tipp für mich?
                        • L Landmilch
                          @Landmilch Per ssh auf den host gehen?
                            Landmilch
                            @Thomas-Braun
                            Da bin ich. Aber wie lautet der Befehl umd den Prozess zu starten bzw. Ihn zu beenden?
                            Sorry, für diese blöden Fragen.
                            • L Landmilch
                              @Thomas-Braun
                              @Landmilch Mir ist nicht so ganz klar wo du da nun hängst. Und warum der Browser da eine Rolle spielt.
                              iobroker stop
                              iobroker start
                              Dann brauchen wir
                              iobroker list instances
                              • L Offline
                                Landmilch
                                Hallo Thomas,
                                ich habe im SSH-Terminal den Befehl iobroker fix eingegeben.
                                Dann bekam ich die Meldung, dass es noch offenen Prozesse gibt. Hätte wahrscheinlich den ganzen iobroker stoppen sollen. Hab aber in der Weboberfläche den Admin-Prozess gestoppt. Nun läuft nix mehr. Zumindest nicht im Browser. SSH, steht aber.
                                • L Landmilch
                                  Hallo Thomas,
                                  @Landmilch Dann stop den Broker vorher...
                                  iobroker stop
                                  Und du darfst ruhig die Ausgaben hier im vollen reinkopieren (in </> Code-Tags...)
                                  • L Offline
                                    Landmilch
                                    Hab die Kiste jetzt gerade mal für 30sec vom Strom genommen. SSH klappt.
                                    kann den iobroker, starten stoppen und fixen. Mein Browser zeigt leider immer noch nichts an.
                                    • L Landmilch
                                      @Landmilch
                                      iobroker start admin.0
                                      Und du darfst immer noch Ausgaben hier reinkopieren. Oder ist das Geheimsache?
                                      • L Offline
                                        Landmilch
                                        Browser sagt nun:
                                        Die Website ist nicht erreichbar 192.168.178.44 hat die Verbindung abgelehnt.
                                        • L Landmilch
                                          Browser sagt nun:
                                          @Landmilch Mann.... Wie oft noch? Der Browser interessiert NULL! im Moment.
                                          Hoffentlich nicht 'hart' ausgezogen?
