  4. Fehler bei Update diverser Adapter.
    2.9k
    3.0k
install adapter update
71 Beiträge 5 Kommentatoren 8.0k Aufrufe 5 Beobachtet
  • L Offline
    Landmilch
    Habe vorgestern meine Node.js auf v12.16.3 "erfolgreich" upgedatet. Folgend lassen sich nun einige Adapter nicht mehr updaten. Hat jemand eine Idee, was man da machen kann?
    Folgende Info stand im Log.
    $ ./iobroker upgrade web
    Update web from @3.0.7 to @3.0.8
    NPM version: 6.14.4
    npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    ╭─────────────────────────────────────────────────────────╮│ ││ Manual installation of ioBroker is no longer supported ││ on Linux, OSX and FreeBSD! ││ Please refer to the documentation on how to install it! ││ https://github.com/ioBroker/ioBroker/wiki/Installation ││ │╰─────────────────────────────────────────────────────────╯
    npm
    ERR! code ELIFECYCLEnpm ERR! errno 100npm ERR! iobroker@2.0.3 postinstall: node lib/install.jsnpm ERR! Exit status 100npm ERR! npm
    ERR! Failed at the iobroker@2.0.3 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-06T13_36_33_207Z-debug.log
    ERROR: host.iobroker Cannot install iobroker.web@3.0.8: 100
    Thomas BraunT paul53P 2 Antworten Letzte Antwort
    • L Landmilch
      NPM version: 6.14.4
      npm
      @Landmilch
      node -v
      nodejs -v
      npm -v
      lsb_release -a
      iobroker version
      L 1 Antwort Letzte Antwort
      • L Landmilch
        NPM version: 6.14.4
        npm
        @Landmilch sagte:
        Web 3.0.8 verlangt adapter-core ab Version 2.4.0 ?
          @Landmilch
          node -v
          nodejs -v
          npm -v
          lsb_release -a
          iobroker version
          Landmilch
          @Thomas-Braun said in Fehler bei Update diverser Adapter.:
          iobroker version
          Sorry. Anbei die installierten Versionen
          node -v
          v12.16.3
          nodejs -v
          v12.16.3
          npm -v
          6.14.4
          lsb_release -a
          No LSB modules are available.
          Distributor ID: Raspbian
          Description: Raspbian GNU/Linux 10 (buster)
          Release: 10
          Codename: buster
          iobroker version
          3.0.20
            @Landmilch sagte:
            Landmilch
            Wie machen ich das Update des adapter-core auf Version 2.4.0?
            • L Landmilch
              @Landmilch
              iobroker version
              Edit: Sorry, ich hab Tomaten auf den Augen.
              • L Landmilch
                iobroker version
                node -v
                v12.16.3
                nodejs -v
                v12.16.3
                npm -v
                6.14.4
                lsb_release -a
                Release: 10
                Codename: buster
                iobroker version
                3.0.20
                @Landmilch sagte:
                iobroker version 3.0.20
                Hast Du damit wieder ein Update auf Web 3.0.8 versucht ?
                • L Offline
                  Landmilch
                  Ist der iobroker veraltet?
                    @Landmilch sagte:
                    Landmilch
                    In meiner Konsole steht:
                    ioBroker.admin 4.1.1
                    • L Landmilch
                      @Landmilch Der ist eigentlich akutell.
                      js-controller != admin
                      • L Landmilch
                        @Landmilch
                        iobroker fix
                        whoami
                        • L Offline
                          Landmilch
                          Super. Jetzt hab ich mich selbst ausgesperrt. Hab den admin in der Weboberfläche angehalten. Nun komme ich per Browser nicht mehr drauf.
                          Hat jemand einen Tipp für mich?
                          • L Landmilch
                            @Landmilch Per ssh auf den host gehen?
                              Landmilch
                              @Thomas-Braun
                              Da bin ich. Aber wie lautet der Befehl umd den Prozess zu starten bzw. Ihn zu beenden?
                              Sorry, für diese blöden Fragen.
                              • L Landmilch
                                @Thomas-Braun
                                @Landmilch Mir ist nicht so ganz klar wo du da nun hängst. Und warum der Browser da eine Rolle spielt.
                                iobroker stop
                                iobroker start
                                Dann brauchen wir
                                iobroker list instances
                                • L Offline
                                  Landmilch
                                  Hallo Thomas,
                                  ich habe im SSH-Terminal den Befehl iobroker fix eingegeben.
                                  Dann bekam ich die Meldung, dass es noch offenen Prozesse gibt. Hätte wahrscheinlich den ganzen iobroker stoppen sollen. Hab aber in der Weboberfläche den Admin-Prozess gestoppt. Nun läuft nix mehr. Zumindest nicht im Browser. SSH, steht aber.
                                  • L Landmilch
                                    Hallo Thomas,
                                    @Landmilch Dann stop den Broker vorher...
                                    iobroker stop
                                    Und du darfst ruhig die Ausgaben hier im vollen reinkopieren (in </> Code-Tags...)
                                    • L Offline
                                      Landmilch
                                      Hab die Kiste jetzt gerade mal für 30sec vom Strom genommen. SSH klappt.
                                      kann den iobroker, starten stoppen und fixen. Mein Browser zeigt leider immer noch nichts an.
                                      • L Landmilch
                                        @Landmilch
                                        iobroker start admin.0
                                        Und du darfst immer noch Ausgaben hier reinkopieren. Oder ist das Geheimsache?
                                        • L Offline
                                          Landmilch
                                          Browser sagt nun:
                                          Die Website ist nicht erreichbar 192.168.178.44 hat die Verbindung abgelehnt.
