  4. Wetterstation WS980WiFi von ELV (Neuer Adapter)
    6.4k
sainlogicwetterstationws980wifielv
151 Beiträge 12 Kommentatoren 33.2k Aufrufe 16 Beobachtet
  • FoggF Fogg
    Du bist ein klasse Tester :) (Oder ich ein lausiger....)
    Ist nun auch behoben, danke!
    GlasfaserG Offline
    GlasfaserG Offline
    #118
    @Fogg
    Update durchgeführt ..
    Soweit sind jetzt alle da ...
    Außer der Lux Wert stimmt nicht !?
    Aktuell von der Zentrale :
    Hier der Log:
    sainlogic.0	2020-05-04 13:48:32.514	debug	(15809) FW Scheduler Connection closed
    sainlogic.0	2020-05-04 13:48:32.508	info	(15809) Scheduler updating IOBroker states
    sainlogic.0	2020-05-04 13:48:32.508	debug	(15809) Data object: {"indoortempdailymin":202,"indoortempdailymintime":2845,"tempdailymin":101,"tempdailymintime":1832,"dewptdailymin":85,"dewptdailymintime":271,"windchilldailymin":101,"windchilldai
    sainlogic.0	2020-05-04 13:48:32.507	debug	(15809) Data Command received: 11 subcommand 8
    sainlogic.0	2020-05-04 13:48:32.506	debug	(15809) FW Scheduler Received data string: ffff0b002c084100ca0b1d4200650728430055010f44006507284630091347390d0c48279405074927940507dbed
    sainlogic.0	2020-05-04 13:48:32.496	debug	(15809) Scheduler connected to weather station run 255,255,11,0,6,8,8,33
    sainlogic.0	2020-05-04 13:48:32.496	debug	(15809) Data object: {"indoortempdailymax":209,"indoortempdailymaxtime":3,"tempdailymax":186,"tempdailymaxtime":3339,"dewptdailymax":113,"dewptdailymaytime":3336,"windchilldailymax":186,"windchilldail
    sainlogic.0	2020-05-04 13:48:32.495	debug	(15809) Data Command received: 11 subcommand 7
    sainlogic.0	2020-05-04 13:48:32.495	debug	(15809) FW Scheduler Received data string: ffff0b004d074100d100034200ba0d0b4300710d084500ba0d0b46320000475f07334827b50d094927b50d094b000e0b2a4c00140b2a4e0000001207245500156b200c3a5600010c39570a0c39086
    sainlogic.0	2020-05-04 13:48:32.484	debug	(15809) Scheduler connected to weather station run 255,255,11,0,6,7,7,31
    sainlogic.0	2020-05-04 13:48:32.484	debug	(15809) Data object: {"indoortempmin":136,"tempmin":-43,"dewptmin":-119,"windchillmin":-43,"indoorhumiditymin":19,"humiditymin":16,"absbarommin":9830,"barommin":9830}
    sainlogic.0	2020-05-04 13:48:32.483	debug	(15809) Data Command received: 11 subcommand 6
    sainlogic.0	2020-05-04 13:48:32.483	debug	(15809) FW Scheduler Received data string: ffff0b001c0601008802ffd503ff8904ffd5061307100826660926662169
    sainlogic.0	2020-05-04 13:48:32.477	debug	(15809) Scheduler connected to weather station run 255,255,11,0,6,6,6,29
    sainlogic.0	2020-05-04 13:48:32.476	debug	(15809) Data object: {"indoortempmax":289,"tempmax":296,"dewptmax":248,"heatindexmax":348,"indoorhumiditymax":79,"humiditymax":99,"absbarommax":10353,"barommax":10353,"windspeedmax":292,"windgustmax":
    sainlogic.0	2020-05-04 13:48:32.476	debug	(15809) Data Command received: 11 subcommand 5
    sainlogic.0	2020-05-04 13:48:32.476	debug	(15809) FW Scheduler Received data string: ffff0b0045050101210201280300f805015c064f07630828710928710b01240c01510e000001321000000101110000026712000004aa13000008c815002dc6c016ffff170fb2b4
    sainlogic.0	2020-05-04 13:48:32.466	debug	(15809) Scheduler connected to weather station run 255,255,11,0,6,5,5,27
    sainlogic.0	2020-05-04 13:48:32.465	debug	(15809) Data object: {"indoortemp":205,"temp":179,"dewpt":98,"windchill":179,"heatindex":179,"indoorhumidity":48,"humidity":59,"absbarom":10163,"barom":10163,"winddir":319,"windspeed":3,"windgust":5,"
    sainlogic.0	2020-05-04 13:48:32.464	debug	(15809) Data Command received: 11 subcommand 4
    sainlogic.0	2020-05-04 13:48:32.464	debug	(15809) FW Scheduler Received data string: ffff0b0050040100cd0200b30300620400b30500b30630073b0827b30927b30a013f0b00030c00050e0000000010000000051100000005120000003513000008c814000008c815000c06ca1609061
    sainlogic.0	2020-05-04 13:48:32.218	debug	(15809) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
    sainlogic.0	2020-05-04 13:48:32.217	debug	(15809) Data object: {"softwaretype":"EasyWeatherV1.4.9"}
    sainlogic.0	2020-05-04 13:48:32.217	debug	(15809) Data Command received: 80 subcommand 69
    sainlogic.0	2020-05-04 13:48:32.216	debug	(15809) FW Scheduler Received data string: ffff501511456173795765617468657256312e342e39
    sainlogic.0	2020-05-04 13:48:32.212	debug	(15809) Scheduler connected to weather station run 255,255,80,3,83
    sainlogic.0	2020-05-04 13:48:32.208	info	(15809) Scheduler pulling for new data
    sainlogic.0	2020-05-04 13:48:12.440	debug	(15809) FW Scheduler Connection closed
    FoggF 1 Antwort Letzte Antwort
    • Ralla66R Offline
      Ralla66R Offline
      Ralla66
      #119
      @Fogg
      Ich denke dein NodeJS ist zu alt. Ich benutze Funktionen die erst mit NodeJS 12 vorhanden sind wenn ich mich nicht irre.
      Läuft jetzt mit NodeJS 12, musste noch den JS Controller aktuallisieren.
      Top, Geilomat :-)
      • GlasfaserG Glasfaser
        @Fogg
        Hier der Log:
        FoggF Offline
        FoggF Offline
        Fogg
        #120
        @Glasfaser said in Wetterstation WS980WiFi von ELV (Neuer Adapter):
        @Fogg
        Hier der Log:
        Sicher? Lt. Doku muss ich den Wert durch 10'000 teilen....
        • Ralla66R Offline
          Ralla66R Offline
          Ralla66
          #121
          @Fogg
          war doch das hier oder ( Doku RP ) ?
          Obwohl das nur für Aktuell gilt.
          Bei Max ist das Byte ab Position 60 bei RP.
          Habe auch schwankende Werte wie 19 lux oder 120.50 oder 119.27 .
          Bei Sonnenschein !
          Punkt irritiert mich. Entweder mit oder ohne.
          Bin aber kein Progger nur Schlosser. :-)
          Hex in dec : 10 ?
          • FoggF Offline
            FoggF Offline
            Fogg
            #122
            Hmm. richtig. Dann müsste ich 'nur' durch 10 Teilen.
            Bau ich mal um.
            • FoggF Fogg
              Bau ich mal um.
              GlasfaserG Offline
              GlasfaserG Offline
              #123
              @Fogg
              Könntest du noch den Datenpunkt für den Wert W/m² erstellen!?
              Edit :
              Eigentlich ist solarradiation W/m²
                @Fogg
                Edit :
                FoggF Offline
                FoggF Offline
                Fogg
                #124
                @Fogg
                🤦 Vermutlich war das mein Fehler.... der Wert kommt in Mü-Watt.... da wäre das teilen angebracht.....
                Lux ist behoben, den anderen lege ich noch an.
                • Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  #125
                  @Fogg
                  habe die Doku von RP nur angelesen,
                  würde prüfen bei Aktuell und Max wo die 4 Byte stehen.
                  Byte 3 im Header ist ein Längenbyte !
                  Durchaus möglich das die letzten Bytes verruscht sind.
                  Schöne Falle.
                  Dann müsstest du prüfen bei Aktuell, Max, Min usw wo die Bytes stehen.
                  • Ralla66R Ralla66
                    @Fogg
                    Schöne Falle.
                    FoggF Offline
                    FoggF Offline
                    Fogg
                    schrieb am zuletzt editiert von Fogg
                    #126
                    @Ralla66 said in Wetterstation WS980WiFi von ELV (Neuer Adapter):
                    @Fogg
                    Schöne Falle.
                    Nee.. das hab ich eigentlich :D Habe einen Wert (UVraw) den ich bisher nicht als Datenpunkt angelegt habe. Das müsste die W/m2 sein.
                    Die Namensgebung kann ggf. noch angepasst werden... Ist eher auf meine Unkenntnis zu schliessen.
                    • Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      #127
                      @Fogg
                      ich sach mal so,
                      Proggerdenken, die sind anders gestrickt.
                      Eure Logic ist anders als bei einem Schlosser wie mir.
                      • FoggF Offline
                        FoggF Offline
                        Fogg
                        #128
                        So, 0.5.5 is im git, hat nun auch den UVraw wert. Schau mal ob der Sinn macht. Achtung, ich habe auf mW/m2 gewandelt. Finde bei W/m2 sind die Zahlen so klein...
                        • FoggF Fogg
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #129
                          @Fogg
                          Du hast die Lux in m Gewandelt
                          Lux 1147 in 1.2 mW/m2
                          der richtige Wert ist so .
                          dann
                          der Wert ist jetzt natürlich jetzt geringer geworden beim Auslesen .... wird ja dunkler
                          solarradiation=6.48&
                            @Fogg
                            dann
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #130
                            @Fogg
                            Hier noch mehr Werte ... fals du nicht weiterkommst .
                            GET /weatherstation/updateweatherstation.php?ID=xxxxxx&PASSWORD=xxxxxx&indoortempf=68.4&tempf=71.1&dewptf=37.2&windchillf=71.1&indoorhumidity=33&humidity=29&windspeedmph=0.7&windgustmph=1.1&winddir=299&absbaromin=30.210&baromin=30.210&rainin=0.000&dailyrainin=0.000&weeklyrainin=0.020&monthlyrainin=0.209&yearlyrainin=8.850&solarradiation=697.56&UV=6&dateutc=2020-05-06%2011:08:54&softwaretype=EasyWeatherV1.4.9&action=updateraw&realtime=1&rtfreq=5 HTTP/1.0
                            • FoggF Offline
                              FoggF Offline
                              Fogg
                              #131
                              Bin gerade geschäftlich etwas unter Strom :/ Am Wochenende hoffe ich wieder weitermachen zu können. Dann sollte ich die Werte machen können. Wobei die lux-werte von Dir auch nicht richig aussehen... das wäre doch recht hoch, nicht?
                              • FoggF Fogg
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #132
                                @Fogg
                                Beide Werte sind schon richtig .
                                Link Text
                                oder wikipedia
                                @Ralla66 sagte in Wetterstation WS980WiFi von ELV (Neuer Adapter):
                                Bei Sonnenschein !
                                Wäre sonst für draußen recht dunkel ;)
                                • FoggF Offline
                                  FoggF Offline
                                  Fogg
                                  #133
                                  jetzt komm ich langsam draus... dachte der eine screenshot oben soll heissen du hättest gerne en wert von 300'000 lux... dass soll eher heissen der ist zu hoch.
                                  • FoggF Fogg
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #134
                                    @Fogg
                                    Der Lux Wert ist richtig ... ich habe nie geschrieben er ist zu hoch.
                                    Habe nur darauf hingewiesen das der Wert mW/m2 nicht richtig ist .
                                    Der Wert sollte schon in W/m2 , aber dann auch richtig .
                                    Ich habe zum Verständnis Screenshot beigefügt , damit du sehen kannst wie der Original Wert der Anlage W/m2 ist .
                                    und habe nach deiner Frage :
                                    dir zurückgeschrieben das der Wert ... Aktuell 89962 nicht zu hoch ist .
                                    • FoggF Offline
                                      FoggF Offline
                                      Fogg
                                      #135
                                      Aha... :) Versuche das gerade am Beispiel meiner Station nachzuvollziehen.
                                      Beleuchtung = Solarradiation - Wert Stimmt
                                      Zusätzlich bekomme ich den UVRaw Wert - was der genau ist ist mir noch etwas unklar. Der soll lt. Doku in uW/M2 sein. Daher meine Angaben. Kann sein dass der die Grundlage von UVI ist... 🤷
                                      Gemäss wikipedia (https://de.wikipedia.org/wiki/UV-Index) gibt es hier zumindest einen Zusammenhang.
                                      Ich glaub ich stand die ganze Zeit massiv auf dem Schlauch. Die Lux stimmen und Du hättest gerne zusätzlich den gleichen Datenpunkt auch in W/m2. Also eine einfache Umrechnung. Ich hatte nach einem weiteren Wert in der Wetterstation gesucht. Da gibt es eben den UVRaw Wert der die gleiche Einheit haben soll, hat aber damit nicht wirklich was zu tun. Lux -> W/m2 ist 'einfach' geteilt durch 10,xxx. Das kann ich natürlich machen wenn es benötigt wird. Wozu benutzt Du das?
                                      • FoggF Fogg
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #136
                                        @Fogg sagte in Wetterstation WS980WiFi von ELV (Neuer Adapter):
                                        Das kann sein kenne es so selber nicht !!
                                        Ich meine das hier ... W/m2
                                        Link Text
                                        Link Text
                                        siehe hier ... ist schon ein wichtiger Punkt
                                        Link Text
                                        Kennst du keine Photovoltaikanlagen !??
                                        • FoggF Offline
                                          FoggF Offline
                                          Fogg
                                          #137
                                          Hehe... Photovoltaik hab ich (noch) nicht.
                                          Ich bin mir wirklich nicht sicher wo die W/m2 her kommen. Wenn ich den UVRaw Wert einfach in W/m2 nehme (wobei er lt. Doku ja MüW/m2 ist), dann bin ich zwar nah dran, aber nicht ganz. Jeweils so 1-3 W Differenz. Könnte natürlich sein da die Abfrage nicht zeitgleich erfolgt...
