  5. Online/Offline Status Endgeräte
    5.5k
13 Beiträge 3 Kommentatoren 640 Aufrufe 1 Beobachtet
    @TG70 sagte:
    Blocky um den Online und Offline Status von Endgeräten zu prüfen... nur alle 30 Sekunden die Abfrage stattfindet.
    Immer nur einen Trigger pro Datenpunkt verwenden.
     <variables>
       <variable type="undefined" id="timeout">timeout</variable>
       <variable type="" id=")5.@%hIcC!N[,4.{gc_W">msg</variable>
     </variables>
     <block type="on_ext" id=").cAyv-tz0},iv=gd#ux" x="62" y="13">
       <mutation items="1"></mutation>
       <value name="OID0">
         <shadow type="field_oid" id="Rs]`U=j^WSiQdM(+IIAo">
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="controls_if" id="R)NE*uvvILb:J~G{S_+(">
           <value name="IF0">
             <block type="logic_negate" id="|h7BbV%j?[/$3yS*cfSd">
               <value name="BOOL">
                 <block type="variables_get" id="I3+*/Hy~/MhccFzyr5yd">
                   <field name="VAR" id="timeout" variabletype="undefined">timeout</field>
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO0">
             <block type="controls_if" id="xK3_5+-+onvFk`DjhuAw">
               <value name="IF0">
                 <block type="on_source" id="9j67ercie#~=+m]B{pR,">
                 </block>
               </value>
                 <block type="variables_set" id="8kzyb5:D;FhGg8z95K1?">
                   <field name="VAR" id=")5.@%hIcC!N[,4.{gc_W" variabletype="">msg</field>
                   <value name="VALUE">
                     <block type="text" id="{*?68*`Uz0^D!?^[sz3d">
                       <field name="TEXT">XYZ online</field>
                     </block>
                   </value>
                 </block>
               </statement>
               <statement name="ELSE">
                 <block type="variables_set" id="0QzGHfSagQsPIli_BjU?">
                     <block type="text" id="{0KO%!gp$LdNMwJO5!i/">
                       <field name="TEXT">XYZ offline</field>
                     </block>
                   </value>
                 </block>
               </statement>
               <next>
                 <block type="pushover" id="924rSSGx/SwO!lUL{fZy">
                   <field name="SOUND"></field>
                   <field name="PRIORITY">0</field>
                   <field name="LOG"></field>
                   <value name="MESSAGE">
                     <shadow type="text" id="Tvy?hU4nfj5jrCYCMZMX">
                     </shadow>
                     <block type="variables_get" id="AJBdB$_}s:_:E]!;RWT`">
                     </block>
                   </value>
                   <value name="TITLE">
                     <block type="variables_get" id="/b3+Dz6Iy]|k5AX50T:P">
                     </block>
                   </value>
                   <next>
                     <block type="timeouts_settimeout" id="aY?YS#,]g%l~l4gLe;Go">
                       <field name="DELAY">30</field>
                         <block type="variables_set" id="eYOYC4yvbOt?fl1U;_/q">
                             <block type="logic_null" id="_Zeb){b,p;AQO7xZB3E1"></block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </statement>
     </block>
    </xml>
    TG70T Offline
    TG70T Offline
    TG70
    Forum Testing
    schrieb am zuletzt editiert von TG70
    Hallo, vielen Dank für deine Rückmeldung.
    Was muss ich außer der Objekt ID noch anpassen?
    Woher nimmer die Blockly sich die "true" bzw. "false" Werte?
    Der TR-064 Adapter reagiert ja ziemlich langsam.
    Ping und Ring waren in letzter Zeit bei mir aber auch alles andere als zuverlässig.
    Was wäre die optimale Variante für eine Online/Offline Meldung bzw. in der Folge auch Statusanzeige?
    ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
    • TG70T TG70
      @TG70 sagte:
      Den Meldungstext.
      @TG70 sagte in Online/Offline Status Endgeräte:
      Was meinst Du ?
      TG70T 1 Antwort Letzte Antwort
        @TG70 sagte:
        Den Meldungstext.
        Was meinst Du ?
        TG70T Offline
        TG70T Offline
        TG70
        Forum Testing
        @paul53 ... ja sorry - genau den Meldungstext sieht man als Selbstverständlich an :)))
        Ich verstehe das Blockly in dem Punkt nicht, wie das Blocky das True/False von dem Datenpunkt erkennt
        bzw. wie das in das Blockly einfließt.
        Was wäre ansich die optimale Online/Offline Abfrage die zuverlässig und schnell ist ???
        • TG70T TG70
          @TG70 sagte:
          falls Wert prüft den Wert des Trigger-Datenpunktes und mache wird bei true, sonst wird bei false ausgeführt.
          Keine Ahnung, verwende solche Abfragen nicht. Das Script reagiert sofort auf die Änderung des Trigger-Datenpunktes und sperrt dann für 30 s (Entprellen).
            @TG70 sagte:
            TG70T Offline
            TG70T Offline
            TG70
            Forum Testing
            @paul53 ... OK verstanden.... wo ist aber definiert das mache = true und sonst = false ist...
            Den Online Status wirft der TR-064 Adapter ziemlich zeitnah aus ... bis der Offline Status ankommt vergehen leider 10 Min. Liegt aber an der Fritzbox selber.
            Vielleicht hat da noch jemand eine Idee, mit welchem Adapter man das effektiver gestalten könnte
            paul53P BBTownB 3 Antworten Letzte Antwort
            • TG70T TG70
              @TG70 sagte:
              In der Definition von Javascript-Bedingungen bzw. deren Umsetzung mit Blockly.
              • TG70T TG70
                BBTownB Offline
                BBTownB Offline
                BBTown
                schrieb am zuletzt editiert von BBTown
                @TG70
                Javascript "erwartet" bei einer Frage dass ein true zurückkommt, daher musst Du nicht "ist wahr" hinterherfragen, das steckt bereits in der Frage selbst drinnen, daher kann man sich die Schreibweise leichter machen.
                Es ist nur ungewohnt am Anfang, dass nicht "Object ist wahr" dort steht wie bei "Object ist falsch"
                • BBTownB BBTown
                  @TG70
                  @BBTown sagte:
                  ... oder wie bei "nicht Wert von Objekt"
                  • TG70T TG70
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    @TG70
                    hier das ganze als Bild:
                    beachte das "nicht" in der letzten Bedingung
                    • BBTownB BBTown
                      @TG70
                      @BBTown
                      Die Aussage "völlig identisch" trifft aber nur für Werte vom Typ "boolean" zu.
                      BBTownB 1 Antwort Letzte Antwort
                        @BBTown
                        BBTownB Offline
                        BBTownB Offline
                        BBTown
                        ja das ist wahr, ich war gefangen in der Annahme dass wir hier über boolsche Werte sprechen 😬
