  4. Wetterstation WS980WiFi von ELV (Neuer Adapter)
    6.4k
sainlogicwetterstationws980wifielv
151 Beiträge 12 Kommentatoren 33.2k Aufrufe 16 Beobachtet
  • LatziL Latzi
    @Fogg
    bei mir läuft´s leider nicht, anbei die Meldungen:
    2020-04-26 16:23:02.371 - info: host.Pi4-Server "system.adapter.sainlogic.0" enabled
    2020-04-26 16:23:02.412 - info: host.Pi4-Server instance system.adapter.sainlogic.0 started with pid 2705
    2020-04-26 16:23:04.783 - info: sainlogic.0 (2705) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2
    2020-04-26 16:23:04.810 - info: sainlogic.0 (2705) Listner active: true
    2020-04-26 16:23:04.811 - info: sainlogic.0 (2705) Config IP: 0.0.0.0
    2020-04-26 16:23:04.812 - info: sainlogic.0 (2705) Config port: 17551
    2020-04-26 16:23:04.812 - info: sainlogic.0 (2705) Config path: /weatherstation/updateweatherstation.php
    2020-04-26 16:23:04.813 - info: sainlogic.0 (2705) Scheduler active: true
    2020-04-26 16:23:04.813 - info: sainlogic.0 (2705) WS IP: 10.0.0.35
    2020-04-26 16:23:04.814 - info: sainlogic.0 (2705) WS Port: 17551
    2020-04-26 16:23:04.814 - info: sainlogic.0 (2705) Starting Scheduler
    2020-04-26 16:23:04.815 - info: sainlogic.0 (2705) Starting Listener
    2020-04-26 16:23:04.856 - error: sainlogic.0 (2705) uncaught exception: connect ECONNREFUSED 10.0.0.35:17551
    2020-04-26 16:23:04.858 - error: sainlogic.0 (2705) Error: connect ECONNREFUSED 10.0.0.35:17551
    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16)
    2020-04-26 16:23:04.863 - info: sainlogic.0 (2705) Scheduler Connection closed
    2020-04-26 16:23:04.880 - info: sainlogic.0 (2705) terminating
    2020-04-26 16:23:04.881 - info: sainlogic.0 (2705) Terminated (NO_ERROR): Without reason
    2020-04-26 16:23:05.458 - error: host.Pi4-Server Caught by controller[0]: Error: connect ECONNREFUSED 10.0.0.35:17551
    2020-04-26 16:23:05.459 - error: host.Pi4-Server Caught by controller[0]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16) {
    2020-04-26 16:23:05.459 - error: host.Pi4-Server Caught by controller[0]: errno: 'ECONNREFUSED',
    2020-04-26 16:23:05.460 - error: host.Pi4-Server Caught by controller[0]: code: 'ECONNREFUSED',
    2020-04-26 16:23:05.460 - error: host.Pi4-Server Caught by controller[0]: syscall: 'connect',
    2020-04-26 16:23:05.460 - error: host.Pi4-Server Caught by controller[0]: address: '10.0.0.35',
    2020-04-26 16:23:05.461 - error: host.Pi4-Server Caught by controller[0]: port: 17551
    2020-04-26 16:23:05.461 - error: host.Pi4-Server Caught by controller[0]: }
    2020-04-26 16:23:05.461 - info: host.Pi4-Server instance system.adapter.sainlogic.0 terminated with code 0 (NO_ERROR)
    2020-04-26 16:23:05.462 - info: host.Pi4-Server Restart adapter system.adapter.sainlogic.0 because enabled
    2020-04-26 16:23:29.765 - info: host.Pi4-Server "system.adapter.sainlogic.0" disabled
    2020-04-26 16:23:38.002 - error: sainlogic.0 (3515) adapter disabled
    2020-04-26 16:23:38.013 - warn: sainlogic.0 (3515) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2020-04-26 16:23:38.554 - error: host.Pi4-Server instance system.adapter.sainlogic.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2020-04-26 16:23:38.556 - info: host.Pi4-Server Do not restart adapter system.adapter.sainlogic.0 because disabled or deleted
    Hast du eine Idee?
    FoggF Offline
    FoggF Offline
    Fogg
    @Latzi said in Wetterstation WS980WiFi von ELV (Neuer Adapter):
    Ist die 10.0.0.35 deoione Wetterstation?
    Bei mir muss es Port 45000 sein dass es funktioniert.
    LatziL 1 Antwort Letzte Antwort
    • LatziL Latzi
      @Fogg
      mir ist noch nicht ganz klar, was in dem neuen Reiter eingegeben werden soll:
      Wirklich die IP-Adresse der Wetterstation (in WS View wird doch die IP-Adresse des iobroker angegeben)? Welcher Port ist zu verwenden (falls es um die Wetterstation direkt geht)?
      FoggF Offline
      FoggF Offline
      Fogg
      @Latzi Ja, die Wetterstation. Der Scheduler Part funktioniert - wenn er denn geht - eben genau umgekehrt. Da wird der IOBroker bei der Wetterstation nach den Werten fragen. Bei der WS980 geht das über port 45000. Ich kriege auch schon Daten zurück, nur das zerlegen der Daten bereitet mir noch etwas Kopfzerbrechen...
      • LatziL Latzi
        @Glasfaser
        Nein, ich hab aber noch den "alten" JS Controller 2.2.9, verwendest du schon 3.0.18?
        @Fogg
        ist der Adapter für JS Controller 3.x geeignet?
        FoggF Offline
        FoggF Offline
        Fogg
        @Latzi JS Controller... hae? Wo was? Sagt mir leider noch nichts.
        • FoggF Fogg
          LatziL Offline
          LatziL Offline
          Latzi
          @Fogg sagte in Wetterstation WS980WiFi von ELV (Neuer Adapter):
          Bingo! Das war´s, läuft! 👏
          2020-04-26 22:23:17.903 - info: host.Pi4-Server instance system.adapter.sainlogic.0 started with pid 23115
          2020-04-26 22:23:19.211 - info: sainlogic.0 (23115) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2
          2020-04-26 22:23:19.238 - info: sainlogic.0 (23115) Listner active: true
          2020-04-26 22:23:19.239 - info: sainlogic.0 (23115) Config IP: 0.0.0.0
          2020-04-26 22:23:19.239 - info: sainlogic.0 (23115) Config port: 17551
          2020-04-26 22:23:19.239 - info: sainlogic.0 (23115) Config path: /weatherstation/updateweatherstation.php
          2020-04-26 22:23:19.240 - info: sainlogic.0 (23115) Scheduler active: true
          2020-04-26 22:23:19.240 - info: sainlogic.0 (23115) WS IP: 10.0.0.35
          2020-04-26 22:23:19.241 - info: sainlogic.0 (23115) WS Port: 45000
          2020-04-26 22:23:19.241 - info: sainlogic.0 (23115) Starting Scheduler
          2020-04-26 22:23:19.244 - info: sainlogic.0 (23115) Starting Listener
          2020-04-26 22:23:19.269 - info: sainlogic.0 (23115) Scheduler connected to weather station
          2020-04-26 22:23:19.288 - info: sainlogic.0 (23115) Scheduler received version: EasyWeatherV1.4.9
          2020-04-26 22:23:19.296 - info: sainlogic.0 (23115) Scheduler Connection closed
          Kenn´s auch nur so vom mitlesen, offenbar gibt es gewisse Richtlinien für Adapter bei Verwendung des JS-controller Version 3.x
          • FoggF Offline
            FoggF Offline
            Fogg
            Super, freut mich.
            Jetzt habe ich auch endlich im DEV Zweig geschafft weitere Parameter aus dem HEX String auszulesen. Pff... muss mal einer drauf kommen dass hier Europäische Werte (Celsius) angeliefert werden und nicht wie auf dem Listener in US (Fahrenheit)...
            Mache jetzt mal Feierabend, mit dem Wissen sollte es jetzt morgen oder so schneller gehen.
            • FoggF Offline
              FoggF Offline
              Fogg
              Update... :)
              Version 0.1.2 ist parat. Funktionsumfang ist nun:
              1. Listener
                Bei Aktivierung kann die Wetterstation der der Custom Server Funktion ihre Daten im Format WeatherUndergrund anliefern.
              2. Scheduler
                Bei Aktivierung holt ioBroker sich von der Wetterstation regelmässig Daten ab
              Kurz zur Konfiguration, ich würde empfehlen nur entweder oder zu verwenden. :)
              Listener Konfiguration
              • Bei IP ist am besten das 0.0.0.0 - Listen on all IP's zu wählen. Diese Konfig macht nur Sinn wenn Euer ioBroker mehrere IP's hat und ihr nur auf einer hören wollt (z.b. internes LAN vs. extern)
              • Port: Default ist 45000, es geht quasi jeder Port über 1024 der noch nicht auf dem Host des ioBroker belegt ist. In der Wetterstation müsst ihr den gleichen Port eintragen
              • Path: Ist die URL welche von der Wetterstation aufgerufen wird. Spielt technisch keine Rolle, ich prüfe darauf nur damit nicht irgendwas aufgerufen werden kann
              Scheduler Konfiguration
              • Weatherstation IP: Hier die IP Adresse Eurer Wetterstation eintragen. Hoffentlich könnt ihr der in Eurem Netzwerk eine fixe IP geben. GGf. kann ich hier später auch die Wetterstation dynamisch finden...
              • Port: Der Port, diesmal auf der Wetterstation. Bei meiner ELV ist das 45000
              • Interval: Hier in Sekunden wie oft die Wetterstation abgefragt werden soll. Bitte nicht '0' (muss ich noch abfangen) sonst kracht es. Ich habe mit 15 Sekunden angefangen, das scheint gut zu laufen
              Das war's erstmal, die Werte sollen dann ankommen auf beiden Wegen. Auch das dokumentiere ich noch im git, per Scheduler gibt es ein oder zwei zusätzliche Werte.... Aber nichts dramatisches soweit ich das gesehen habe.
              LatziL ? 2 Antworten Letzte Antwort
              • FoggF Fogg
                Update... :)
                1. Listener
                2. Scheduler
                LatziL Offline
                LatziL Offline
                Latzi
                @Fogg
                bei Einstellung Listener bekomme ich folgende Fehlermeldung:
                2020-04-28 06:31:29.540 - info: sainlogic.0 (18842) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2
                2020-04-28 06:31:29.588 - info: sainlogic.0 (18842) Listner active: true
                2020-04-28 06:31:29.589 - info: sainlogic.0 (18842) Config IP: 0.0.0.0
                2020-04-28 06:31:29.590 - info: sainlogic.0 (18842) Config port: 17551
                2020-04-28 06:31:29.591 - info: sainlogic.0 (18842) Config path: /weatherstation/updateweatherstation.php
                2020-04-28 06:31:29.592 - info: sainlogic.0 (18842) Scheduler active: false
                2020-04-28 06:31:29.593 - info: sainlogic.0 (18842) WS IP: 10.0.0.35
                2020-04-28 06:31:29.594 - info: sainlogic.0 (18842) WS Port: 45000
                2020-04-28 06:31:29.595 - info: sainlogic.0 (18842) WS Frequency: 30
                2020-04-28 06:31:29.596 - info: sainlogic.0 (18842) Starting Listener
                2020-04-28 06:31:56.764 - info: robonect.0 (2157) Polling done
                2020-04-28 06:32:00.067 - info: javascript.0 (10328) script.js.common.FB_Anwesenheiten: Ausloeser: ProgramInitialisierung
                2020-04-28 06:32:24.662 - info: nut.0 (3620) Start NUT update
                2020-04-28 06:32:24.701 - info: nut.0 (3620) All Nut values set
                2020-04-28 06:32:29.597 - info: robonect.0 (2157) Polling done
                2020-04-28 06:32:32.126 - info: sainlogic.0 (18842) Received path: /weatherstation/updateweatherstation.php
                2020-04-28 06:32:32.127 - info: sainlogic.0 (18842) JSON Query string: {"ID":"ITRAGW1","PASSWORD":"LATZI","indoortempf":"71.2","tempf":"41.7","dewptf":"38.7","windchillf":"41.7","indoorhumidity":"37","humidity":"89","windspeedmph":"0.9","windgustmph":"1.1","winddir":"57","absbaromin":"28.175","baromin":"29.962","rainin":"0.000","dailyrainin":"0.000","weeklyrainin":"0.008","monthlyrainin":"0.287","solarradiation":"25.07","UV":"0","dateutc":"2020-04-28 04:32:29","softwaretype":"EasyWeatherV1.4.9","action":"updateraw","realtime":"1","rtfreq":"5"}
                2020-04-28 06:32:32.137 - error: sainlogic.0 (18842) uncaught exception: Cannot read property 'dateutc' of null
                2020-04-28 06:32:32.137 - error: sainlogic.0 (18842) TypeError: Cannot read property 'dateutc' of null
                at Sainlogic.parse_response (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:210:37)
                at Server. (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:86:26)
                at Server.emit (events.js:310:20)
                at parserOnIncoming (_http_server.js:784:12)
                at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)
                2020-04-28 06:32:32.139 - info: sainlogic.0 (18842) cleaned everything up...
                2020-04-28 06:32:32.722 - info: sainlogic.0 (18842) terminating
                2020-04-28 06:32:32.724 - info: sainlogic.0 (18842) Terminated (NO_ERROR): Without reason
                2020-04-28 06:32:32.853 - info: sainlogic.0 (18842) terminating
                2020-04-28 06:32:33.253 - error: host.Pi4-Server Caught by controller[0]: TypeError: Cannot read property 'dateutc' of null
                2020-04-28 06:32:33.258 - error: host.Pi4-Server Caught by controller[0]: at Sainlogic.parse_response (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:210:37)
                2020-04-28 06:32:33.258 - error: host.Pi4-Server Caught by controller[0]: at Server. (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:86:26)
                2020-04-28 06:32:33.258 - error: host.Pi4-Server Caught by controller[0]: at Server.emit (events.js:310:20)
                2020-04-28 06:32:33.259 - error: host.Pi4-Server Caught by controller[0]: at parserOnIncoming (_http_server.js:784:12)
                2020-04-28 06:32:33.259 - error: host.Pi4-Server Caught by controller[0]: at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)
                2020-04-28 06:32:33.259 - info: host.Pi4-Server instance system.adapter.sainlogic.0 terminated with code 0 (NO_ERROR)
                2020-04-28 06:32:33.259 - info: host.Pi4-Server Restart adapter system.adapter.sainlogic.0 because enabled
                2020-04-28 06:32:44.151 - info: host.Pi4-Server "system.adapter.sainlogic.0" disabled
                2020-04-28 06:32:53.335 - info: host.Pi4-Server "system.adapter.sainlogic.0" enabled
                Bei Einstellung Scheduler läuft der Adapter, es werden aber keine Daten aktualisiert und in WSView sind die Einstellungen nicht konfigurierbar, solange der Adapter mit "sheduler" läuft
                FoggF 1 Antwort Letzte Antwort
                • FoggF Fogg
                  Update... :)
                  1. Listener
                  2. Scheduler
                  @Fogg
                  vielen Dank für den Adapter, der Scheduler funktioniert bei mir leider nicht, aber der Listener, leider kann er da was nicht ab:
                  host.iobroker	2020-04-28 09:47:09.980	info	Restart adapter system.adapter.sainlogic.0 because enabled
                  host.iobroker	2020-04-28 09:47:09.979	info	instance system.adapter.sainlogic.0 terminated with code 0 (NO_ERROR)
                  sainlogic.0	2020-04-28 09:47:09.461	info	(6328) Terminated (NO_ERROR): Without reason
                  sainlogic.0	2020-04-28 09:47:09.461	info	(6328) terminating
                  sainlogic.0	2020-04-28 09:47:09.412	info	(6328) cleaned everything up...
                  sainlogic.0	2020-04-28 09:47:09.412	error	at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)
                  sainlogic.0	2020-04-28 09:47:09.412	error	at parserOnIncoming (_http_server.js:784:12)
                  sainlogic.0	2020-04-28 09:47:09.412	error	at Server.emit (events.js:310:20)
                  sainlogic.0	2020-04-28 09:47:09.412	error	at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:86:26)
                  sainlogic.0	2020-04-28 09:47:09.412	error	at Sainlogic.parse_response (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:210:37)
                  sainlogic.0	2020-04-28 09:47:09.412	error	(6328) TypeError: Cannot read property 'dateutc' of null
                  sainlogic.0	2020-04-28 09:47:09.411	error	(6328) uncaught exception: Cannot read property 'dateutc' of null
                  sainlogic.0	2020-04-28 09:47:09.409	info	(6328) JSON Query string: {"ID":"Zuhause","PASSWORD":"kennstdunicht","indoortempf":"73.4","tempf":"59.9","dewptf":"45.5","windchillf":"59.9","indoorhumidity":"34","humidity":"59","windspeedmph":"5.4","win
                  sainlogic.0	2020-04-28 09:47:09.409	info	(6328) Received path: /weatherstation/updateweatherstation.php
                  sainlogic.0	2020-04-28 09:47:02.518	info	(6328) Starting Listener
                  sainlogic.0	2020-04-28 09:47:02.517	info	(6328) WS Frequency: 45
                  sainlogic.0	2020-04-28 09:47:02.517	info	(6328) WS Port: 45000
                  sainlogic.0	2020-04-28 09:47:02.517	info	(6328) WS IP: 192.168.0.123
                  sainlogic.0	2020-04-28 09:47:02.517	info	(6328) Scheduler active: false
                  sainlogic.0	2020-04-28 09:47:02.516	info	(6328) Config path: /weatherstation/updateweatherstation.php
                  sainlogic.0	2020-04-28 09:47:02.516	info	(6328) Config port: 8188
                  sainlogic.0	2020-04-28 09:47:02.516	info	(6328) Config IP: 192.168.178.41
                  sainlogic.0	2020-04-28 09:47:02.515	info	(6328) Listner active: true
                  sainlogic.0	2020-04-28 09:47:02.495	info	(6328) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2, js-controller: 3.0.19
                  tr-064.0	2020-04-28 09:47:01.451	debug	(25992) in updateAll
                  sainlogic.0	2020-04-28 09:47:01.252	debug	(6328) statesDB connected
                  sainlogic.0	2020-04-28 09:47:01.251	debug	(6328) States connected to redis: 0.0.0.0:9000
                  sainlogic.0	2020-04-28 09:47:01.231	debug	(6328) States create System PubSub Client
                  sainlogic.0	2020-04-28 09:47:01.228	debug	(6328) States create User PubSub Client
                  sainlogic.0	2020-04-28 09:47:01.215	debug	(6328) Redis States: Use Redis connection: 0.0.0.0:9000
                  sainlogic.0	2020-04-28 09:47:01.213	debug	(6328) objectDB connected
                  sainlogic.0	2020-04-28 09:47:01.210	debug	(6328) Objects connected to redis: 0.0.0.0:9001
                  sainlogic.0	2020-04-28 09:47:01.178	debug	(6328) Objects client initialize lua scripts
                  sainlogic.0	2020-04-28 09:47:01.177	debug	(6328) Objects create User PubSub Client
                  sainlogic.0	2020-04-28 09:47:01.177	debug	(6328) Objects create System PubSub Client
                  sainlogic.0	2020-04-28 09:47:01.175	debug	(6328) Objects client ready ... initialize now
                  sainlogic.0	2020-04-28 09:47:01.144	debug	(6328) Redis Objects: Use Redis connection: 0.0.0.0:9001
                  host.iobroker	2020-04-28 09:47:00.588	info	instance system.adapter.sainlogic.0 started with pid 6328
                  host.iobroker	2020-04-28 09:46:58.077	info	instance system.adapter.sainlogic.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  sainlogic.0	2020-04-28 09:46:57.594	debug	(6298) system.adapter.admin.0: logging true
                  tr-064.0	2020-04-28 09:46:57.593	debug	(25992) system.adapter.admin.0: logging true
                    @Fogg
                    FoggF Offline
                    FoggF Offline
                    Fogg
                    @ilovegym super, danke. Das mit dem Datum ist mir schon klar, korrigiere ich nachher.
                    • LatziL Latzi
                      @Fogg
                      FoggF Offline
                      FoggF Offline
                      Fogg
                      @Latzi der scheduler läuft erst nach dem ersten intervall los. Sprich wenn du 25 Sekunden eingestellt hast kommen erste Daten nach 25 Sekunden.
                      • FoggF Fogg
                        LatziL Offline
                        LatziL Offline
                        Latzi
                        Das ist mir klar, ich hab 5 Minuten gewartet (60 Sekunden eingestellt) und in log schrieb er auch die Version EasyWeatherV1.4.9 und weitere Dinge raus, Werte kamen aber keine neuen in die Datenpunkte.
                        Benötigst du das log vom scheduler? Hilft es, wenn ich auf debug beim Adapter umstelle?
                        • LatziL Latzi
                          FoggF Offline
                          FoggF Offline
                          Fogg
                          @Latzi ja, Log wäre gut. Gern auf Debug. Hier muss ich noch etwas Hand anlegen und die Log Meldungen ordentlich auf die Level verteilen....
                          • FoggF Fogg
                            LatziL Offline
                            LatziL Offline
                            Latzi
                            @Fogg
                            bitte sehr, hier der Log mit Einstellung "scheduler":
                            2020-04-28 11:59:23.147 - info: host.Pi4-Server "system.adapter.sainlogic.0" enabled
                            2020-04-28 11:59:23.200 - info: host.Pi4-Server instance system.adapter.sainlogic.0 started with pid 20639
                            2020-04-28 11:59:23.948 - debug: sainlogic.0 (20639) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2020-04-28 11:59:24.000 - debug: sainlogic.0 (20639) Objects client ready ... initialize now
                            2020-04-28 11:59:24.009 - debug: sainlogic.0 (20639) Objects create System PubSub Client
                            2020-04-28 11:59:24.011 - debug: sainlogic.0 (20639) Objects create User PubSub Client
                            2020-04-28 11:59:24.012 - debug: sainlogic.0 (20639) Objects client initialize lua scripts
                            2020-04-28 11:59:24.070 - debug: sainlogic.0 (20639) Objects connected to redis: 127.0.0.1:9001
                            2020-04-28 11:59:24.075 - debug: sainlogic.0 (20639) objectDB connected
                            2020-04-28 11:59:24.078 - debug: sainlogic.0 (20639) Redis States: Use Redis connection: 127.0.0.1:9000
                            2020-04-28 11:59:24.089 - debug: sainlogic.0 (20639) States create User PubSub Client
                            2020-04-28 11:59:24.092 - debug: sainlogic.0 (20639) States create System PubSub Client
                            2020-04-28 11:59:24.110 - debug: sainlogic.0 (20639) States connected to redis: 127.0.0.1:9000
                            2020-04-28 11:59:24.111 - debug: sainlogic.0 (20639) statesDB connected
                            2020-04-28 11:59:25.773 - info: sainlogic.0 (20639) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2
                            2020-04-28 11:59:25.810 - info: sainlogic.0 (20639) Listner active: false
                            2020-04-28 11:59:25.812 - info: sainlogic.0 (20639) Config IP: 0.0.0.0
                            2020-04-28 11:59:25.813 - info: sainlogic.0 (20639) Config port: 17551
                            2020-04-28 11:59:25.813 - info: sainlogic.0 (20639) Config path: /weatherstation/updateweatherstation.php
                            2020-04-28 11:59:25.814 - info: sainlogic.0 (20639) Scheduler active: true
                            2020-04-28 11:59:25.814 - info: sainlogic.0 (20639) WS IP: 10.0.0.35
                            2020-04-28 11:59:25.815 - info: sainlogic.0 (20639) WS Port: 45000
                            2020-04-28 11:59:25.815 - info: sainlogic.0 (20639) WS Frequency: 60
                            2020-04-28 11:59:25.816 - info: sainlogic.0 (20639) Starting Scheduler
                            2020-04-28 12:00:25.895 - info: sainlogic.0 (20639) FW Scheduler connected to weather station
                            2020-04-28 12:00:25.899 - debug: sainlogic.0 (20639) FW Scheduler Received (length): 22
                            2020-04-28 12:00:25.900 - debug: sainlogic.0 (20639) FW Scheduler Received data string: ffff501511456173795765617468657256312e342e39
                            2020-04-28 12:00:25.900 - info: sainlogic.0 (20639) FW Scheduler received raw: EasyWeatherV1.4.9
                            2020-04-28 12:00:25.903 - info: sainlogic.0 (20639) FW Scheduler Connection closed
                            2020-04-28 12:00:25.906 - info: sainlogic.0 (20639) Data Scheduler connected to weather station
                            2020-04-28 12:01:25.902 - info: sainlogic.0 (20639) FW Scheduler connected to weather station
                            2020-04-28 12:01:25.905 - debug: sainlogic.0 (20639) FW Scheduler Received (length): 22
                            2020-04-28 12:01:25.906 - debug: sainlogic.0 (20639) FW Scheduler Received data string: ffff501511456173795765617468657256312e342e39
                            2020-04-28 12:01:25.907 - info: sainlogic.0 (20639) FW Scheduler received raw: EasyWeatherV1.4.9
                            2020-04-28 12:01:25.910 - info: sainlogic.0 (20639) FW Scheduler Connection closed
                            2020-04-28 12:01:25.914 - info: sainlogic.0 (20639) Data Scheduler connected to weather station
                            2020-04-28 12:02:25.862 - info: sainlogic.0 (20639) FW Scheduler connected to weather station
                            2020-04-28 12:02:25.865 - debug: sainlogic.0 (20639) FW Scheduler Received (length): 22
                            2020-04-28 12:02:25.865 - debug: sainlogic.0 (20639) FW Scheduler Received data string: ffff501511456173795765617468657256312e342e39
                            2020-04-28 12:02:25.866 - info: sainlogic.0 (20639) FW Scheduler received raw: EasyWeatherV1.4.9
                            2020-04-28 12:02:25.868 - info: sainlogic.0 (20639) FW Scheduler Connection closed
                            2020-04-28 12:02:25.870 - info: sainlogic.0 (20639) Data Scheduler connected to weather station
                            So wie es aussieht funktioniert die Kommunikation (es wird ein 22 Zeichen langer String empfangen) doch es wird nichts in die Datenpunkte geschrieben.
                            • LatziL Latzi
                              @Fogg
                              FoggF Offline
                              FoggF Offline
                              Fogg
                              schrieb am zuletzt editiert von Fogg
                              @Latzi Das ist leider nur die Hälfte der Info. Der 22-zeichige beinhaltet die Softwareversion. Es müsste noch ein zweiter String mit 82 Zeichen kommen :/
                              Dazu gibt es quasi zwei Jobs, den FW (Firmware) und Data (Data). Der zweite läuft wohl an und kriegt die Verbindung, aber kriegt keine Antwort. Hast Du ein Linux-System zur Hand? Dann könnte ich Dir eine Kommandozeile schicken zum testen ob/was Deine Wetterstation zurück liefert.
                              Kannst du noch den System-teil des Logs schicken? Ggf. schmiert das Skript ab und die Fehlermeldung fehlt dann.
                              • FoggF Fogg
                                LatziL Offline
                                LatziL Offline
                                Latzi
                                @Fogg
                                Ja, ich hab ein Ubuntu-Sytem oder den Raspi-iobroker bei der Hand (in etwa einer Stunde).
                                Welcher System-Log meinst du?(das war alles aus dem log)??
                                • LatziL Latzi
                                  @Fogg
                                  FoggF Offline
                                  FoggF Offline
                                  Fogg
                                  @Latzi Du scheinst auf sainlogic gefilter zu haben.
                                  Der Befehl wäre der hier:
                                  socat open:weather.hexin,ignoreeof!!create:weather.hexout TCP:<ip_der_wetterstation>:45000,readbytes=82,connect-timeout=3
                                  Du braucht die angehängte Datei dafür.
                                  weather.hexin
                                  Anschliessend erzeigt das Ding ein weather.hexout. Das könntest mir schicken.
                                  • FoggF Fogg
                                    weather.hexin
                                    LatziL Offline
                                    LatziL Offline
                                    Latzi
                                    Da stimmt was nicht, wenn ich
                                    sudo socat open:weather.hexin,ignoreeofcd /opt/testcreate:weather.hexout TCP:10.0.0.35:45000,readbytes=82,connect-timeout=3
                                    ausführe, erhalte ich
                                    2020/04/28 20:48:57 socat[2045] E exactly 2 addresses required (there are 3); use option "-h" for help
                                    Was mach ich da falsch? Ich hab das file in /opt/test kopiert, ist das Verzeichnis beim Aufruf oben zu berücksichtigen (ist das /opt/testcreate oben?)
                                    • FoggF Offline
                                      FoggF Offline
                                      Fogg
                                      Die Ausrufezeichen fehlen nach ignoreeof :D Dafür steht das 'cd /opt/test'.
                                      Versuche mach den kompletten Parameter ab open bis ende mit Quote (") zu setzen. Oder die Ausrufezeichen zu 'quoten'. Also mit backslash-vornedran.
                                      • FoggF Offline
                                        FoggF Offline
                                        Fogg
                                        Bugfix für den Listener ist online, war das dateutc Ding.
                                        • FoggF Fogg
                                          LatziL Offline
                                          LatziL Offline
                                          Latzi
                                          Mit
                                          sudo socat 'open:weather.hexin,ignoreeof!!create:weather.hexout' TCP:10.0.0.35:45000,readbytes=82,connect-timeout=3
                                          läuft´s endlos, file wird keiner erzeugt. Ist das ignoreeof wirklich richtig, nicht ignoreof?
