  4. Wetterstation WS980WiFi von ELV (Neuer Adapter)
    6.4k
sainlogicwetterstationws980wifielv
151 Beiträge 12 Kommentatoren 33.2k Aufrufe 16 Beobachtet
    @Fogg
    vielen Dank für den Adapter, der Scheduler funktioniert bei mir leider nicht, aber der Listener, leider kann er da was nicht ab:
    host.iobroker	2020-04-28 09:47:09.980	info	Restart adapter system.adapter.sainlogic.0 because enabled
    host.iobroker	2020-04-28 09:47:09.979	info	instance system.adapter.sainlogic.0 terminated with code 0 (NO_ERROR)
    sainlogic.0	2020-04-28 09:47:09.461	info	(6328) Terminated (NO_ERROR): Without reason
    sainlogic.0	2020-04-28 09:47:09.461	info	(6328) terminating
    sainlogic.0	2020-04-28 09:47:09.412	info	(6328) cleaned everything up...
    sainlogic.0	2020-04-28 09:47:09.412	error	at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)
    sainlogic.0	2020-04-28 09:47:09.412	error	at parserOnIncoming (_http_server.js:784:12)
    sainlogic.0	2020-04-28 09:47:09.412	error	at Server.emit (events.js:310:20)
    sainlogic.0	2020-04-28 09:47:09.412	error	at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:86:26)
    sainlogic.0	2020-04-28 09:47:09.412	error	at Sainlogic.parse_response (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:210:37)
    sainlogic.0	2020-04-28 09:47:09.412	error	(6328) TypeError: Cannot read property 'dateutc' of null
    sainlogic.0	2020-04-28 09:47:09.411	error	(6328) uncaught exception: Cannot read property 'dateutc' of null
    sainlogic.0	2020-04-28 09:47:09.409	info	(6328) JSON Query string: {"ID":"Zuhause","PASSWORD":"kennstdunicht","indoortempf":"73.4","tempf":"59.9","dewptf":"45.5","windchillf":"59.9","indoorhumidity":"34","humidity":"59","windspeedmph":"5.4","win
    sainlogic.0	2020-04-28 09:47:09.409	info	(6328) Received path: /weatherstation/updateweatherstation.php
    sainlogic.0	2020-04-28 09:47:02.518	info	(6328) Starting Listener
    sainlogic.0	2020-04-28 09:47:02.517	info	(6328) WS Frequency: 45
    sainlogic.0	2020-04-28 09:47:02.517	info	(6328) WS Port: 45000
    sainlogic.0	2020-04-28 09:47:02.517	info	(6328) WS IP: 192.168.0.123
    sainlogic.0	2020-04-28 09:47:02.517	info	(6328) Scheduler active: false
    sainlogic.0	2020-04-28 09:47:02.516	info	(6328) Config path: /weatherstation/updateweatherstation.php
    sainlogic.0	2020-04-28 09:47:02.516	info	(6328) Config port: 8188
    sainlogic.0	2020-04-28 09:47:02.516	info	(6328) Config IP: 192.168.178.41
    sainlogic.0	2020-04-28 09:47:02.515	info	(6328) Listner active: true
    sainlogic.0	2020-04-28 09:47:02.495	info	(6328) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2, js-controller: 3.0.19
    tr-064.0	2020-04-28 09:47:01.451	debug	(25992) in updateAll
    sainlogic.0	2020-04-28 09:47:01.252	debug	(6328) statesDB connected
    sainlogic.0	2020-04-28 09:47:01.251	debug	(6328) States connected to redis: 0.0.0.0:9000
    sainlogic.0	2020-04-28 09:47:01.231	debug	(6328) States create System PubSub Client
    sainlogic.0	2020-04-28 09:47:01.228	debug	(6328) States create User PubSub Client
    sainlogic.0	2020-04-28 09:47:01.215	debug	(6328) Redis States: Use Redis connection: 0.0.0.0:9000
    sainlogic.0	2020-04-28 09:47:01.213	debug	(6328) objectDB connected
    sainlogic.0	2020-04-28 09:47:01.210	debug	(6328) Objects connected to redis: 0.0.0.0:9001
    sainlogic.0	2020-04-28 09:47:01.178	debug	(6328) Objects client initialize lua scripts
    sainlogic.0	2020-04-28 09:47:01.177	debug	(6328) Objects create User PubSub Client
    sainlogic.0	2020-04-28 09:47:01.177	debug	(6328) Objects create System PubSub Client
    sainlogic.0	2020-04-28 09:47:01.175	debug	(6328) Objects client ready ... initialize now
    sainlogic.0	2020-04-28 09:47:01.144	debug	(6328) Redis Objects: Use Redis connection: 0.0.0.0:9001
    host.iobroker	2020-04-28 09:47:00.588	info	instance system.adapter.sainlogic.0 started with pid 6328
    host.iobroker	2020-04-28 09:46:58.077	info	instance system.adapter.sainlogic.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    sainlogic.0	2020-04-28 09:46:57.594	debug	(6298) system.adapter.admin.0: logging true
    tr-064.0	2020-04-28 09:46:57.593	debug	(25992) system.adapter.admin.0: logging true
    FoggF Offline
    FoggF Offline
    Fogg
    @ilovegym super, danke. Das mit dem Datum ist mir schon klar, korrigiere ich nachher.
    • LatziL Latzi
      @Fogg
      bei Einstellung Listener bekomme ich folgende Fehlermeldung:
      2020-04-28 06:31:29.540 - info: sainlogic.0 (18842) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2
      2020-04-28 06:31:29.588 - info: sainlogic.0 (18842) Listner active: true
      2020-04-28 06:31:29.589 - info: sainlogic.0 (18842) Config IP: 0.0.0.0
      2020-04-28 06:31:29.590 - info: sainlogic.0 (18842) Config port: 17551
      2020-04-28 06:31:29.591 - info: sainlogic.0 (18842) Config path: /weatherstation/updateweatherstation.php
      2020-04-28 06:31:29.592 - info: sainlogic.0 (18842) Scheduler active: false
      2020-04-28 06:31:29.593 - info: sainlogic.0 (18842) WS IP: 10.0.0.35
      2020-04-28 06:31:29.594 - info: sainlogic.0 (18842) WS Port: 45000
      2020-04-28 06:31:29.595 - info: sainlogic.0 (18842) WS Frequency: 30
      2020-04-28 06:31:29.596 - info: sainlogic.0 (18842) Starting Listener
      2020-04-28 06:31:56.764 - info: robonect.0 (2157) Polling done
      2020-04-28 06:32:00.067 - info: javascript.0 (10328) script.js.common.FB_Anwesenheiten: Ausloeser: ProgramInitialisierung
      2020-04-28 06:32:24.662 - info: nut.0 (3620) Start NUT update
      2020-04-28 06:32:24.701 - info: nut.0 (3620) All Nut values set
      2020-04-28 06:32:29.597 - info: robonect.0 (2157) Polling done
      2020-04-28 06:32:32.126 - info: sainlogic.0 (18842) Received path: /weatherstation/updateweatherstation.php
      2020-04-28 06:32:32.127 - info: sainlogic.0 (18842) JSON Query string: {"ID":"ITRAGW1","PASSWORD":"LATZI","indoortempf":"71.2","tempf":"41.7","dewptf":"38.7","windchillf":"41.7","indoorhumidity":"37","humidity":"89","windspeedmph":"0.9","windgustmph":"1.1","winddir":"57","absbaromin":"28.175","baromin":"29.962","rainin":"0.000","dailyrainin":"0.000","weeklyrainin":"0.008","monthlyrainin":"0.287","solarradiation":"25.07","UV":"0","dateutc":"2020-04-28 04:32:29","softwaretype":"EasyWeatherV1.4.9","action":"updateraw","realtime":"1","rtfreq":"5"}
      2020-04-28 06:32:32.137 - error: sainlogic.0 (18842) uncaught exception: Cannot read property 'dateutc' of null
      2020-04-28 06:32:32.137 - error: sainlogic.0 (18842) TypeError: Cannot read property 'dateutc' of null
      at Server. (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:86:26)
      2020-04-28 06:32:32.139 - info: sainlogic.0 (18842) cleaned everything up...
      2020-04-28 06:32:32.722 - info: sainlogic.0 (18842) terminating
      2020-04-28 06:32:32.724 - info: sainlogic.0 (18842) Terminated (NO_ERROR): Without reason
      2020-04-28 06:32:32.853 - info: sainlogic.0 (18842) terminating
      2020-04-28 06:32:33.253 - error: host.Pi4-Server Caught by controller[0]: TypeError: Cannot read property 'dateutc' of null
      2020-04-28 06:32:33.258 - error: host.Pi4-Server Caught by controller[0]: at Sainlogic.parse_response (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:210:37)
      2020-04-28 06:32:33.258 - error: host.Pi4-Server Caught by controller[0]: at Server. (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:86:26)
      2020-04-28 06:32:33.258 - error: host.Pi4-Server Caught by controller[0]: at Server.emit (events.js:310:20)
      2020-04-28 06:32:33.259 - error: host.Pi4-Server Caught by controller[0]: at parserOnIncoming (_http_server.js:784:12)
      2020-04-28 06:32:33.259 - error: host.Pi4-Server Caught by controller[0]: at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)
      2020-04-28 06:32:33.259 - info: host.Pi4-Server instance system.adapter.sainlogic.0 terminated with code 0 (NO_ERROR)
      2020-04-28 06:32:33.259 - info: host.Pi4-Server Restart adapter system.adapter.sainlogic.0 because enabled
      2020-04-28 06:32:44.151 - info: host.Pi4-Server "system.adapter.sainlogic.0" disabled
      2020-04-28 06:32:53.335 - info: host.Pi4-Server "system.adapter.sainlogic.0" enabled
      Bei Einstellung Scheduler läuft der Adapter, es werden aber keine Daten aktualisiert und in WSView sind die Einstellungen nicht konfigurierbar, solange der Adapter mit "sheduler" läuft
      FoggF Offline
      FoggF Offline
      Fogg
      @Latzi der scheduler läuft erst nach dem ersten intervall los. Sprich wenn du 25 Sekunden eingestellt hast kommen erste Daten nach 25 Sekunden.
      LatziL 1 Antwort Letzte Antwort
      • FoggF Fogg
        LatziL Online
        LatziL Online
        Latzi
        @Fogg sagte in Wetterstation WS980WiFi von ELV (Neuer Adapter):
        Das ist mir klar, ich hab 5 Minuten gewartet (60 Sekunden eingestellt) und in log schrieb er auch die Version EasyWeatherV1.4.9 und weitere Dinge raus, Werte kamen aber keine neuen in die Datenpunkte.
        Benötigst du das log vom scheduler? Hilft es, wenn ich auf debug beim Adapter umstelle?
        FoggF 1 Antwort Letzte Antwort
        • LatziL Latzi
          FoggF Offline
          FoggF Offline
          Fogg
          @Latzi ja, Log wäre gut. Gern auf Debug. Hier muss ich noch etwas Hand anlegen und die Log Meldungen ordentlich auf die Level verteilen....
          • FoggF Fogg
            LatziL Online
            LatziL Online
            Latzi
            @Fogg
            bitte sehr, hier der Log mit Einstellung "scheduler":
            2020-04-28 11:59:23.147 - info: host.Pi4-Server "system.adapter.sainlogic.0" enabled
            2020-04-28 11:59:23.200 - info: host.Pi4-Server instance system.adapter.sainlogic.0 started with pid 20639
            2020-04-28 11:59:23.948 - debug: sainlogic.0 (20639) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-04-28 11:59:24.000 - debug: sainlogic.0 (20639) Objects client ready ... initialize now
            2020-04-28 11:59:24.009 - debug: sainlogic.0 (20639) Objects create System PubSub Client
            2020-04-28 11:59:24.011 - debug: sainlogic.0 (20639) Objects create User PubSub Client
            2020-04-28 11:59:24.012 - debug: sainlogic.0 (20639) Objects client initialize lua scripts
            2020-04-28 11:59:24.070 - debug: sainlogic.0 (20639) Objects connected to redis: 127.0.0.1:9001
            2020-04-28 11:59:24.075 - debug: sainlogic.0 (20639) objectDB connected
            2020-04-28 11:59:24.078 - debug: sainlogic.0 (20639) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-04-28 11:59:24.089 - debug: sainlogic.0 (20639) States create User PubSub Client
            2020-04-28 11:59:24.092 - debug: sainlogic.0 (20639) States create System PubSub Client
            2020-04-28 11:59:24.110 - debug: sainlogic.0 (20639) States connected to redis: 127.0.0.1:9000
            2020-04-28 11:59:24.111 - debug: sainlogic.0 (20639) statesDB connected
            2020-04-28 11:59:25.773 - info: sainlogic.0 (20639) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2
            2020-04-28 11:59:25.810 - info: sainlogic.0 (20639) Listner active: false
            2020-04-28 11:59:25.812 - info: sainlogic.0 (20639) Config IP: 0.0.0.0
            2020-04-28 11:59:25.813 - info: sainlogic.0 (20639) Config port: 17551
            2020-04-28 11:59:25.813 - info: sainlogic.0 (20639) Config path: /weatherstation/updateweatherstation.php
            2020-04-28 11:59:25.814 - info: sainlogic.0 (20639) Scheduler active: true
            2020-04-28 11:59:25.814 - info: sainlogic.0 (20639) WS IP: 10.0.0.35
            2020-04-28 11:59:25.815 - info: sainlogic.0 (20639) WS Port: 45000
            2020-04-28 11:59:25.815 - info: sainlogic.0 (20639) WS Frequency: 60
            2020-04-28 11:59:25.816 - info: sainlogic.0 (20639) Starting Scheduler
            2020-04-28 12:00:25.895 - info: sainlogic.0 (20639) FW Scheduler connected to weather station
            2020-04-28 12:00:25.899 - debug: sainlogic.0 (20639) FW Scheduler Received (length): 22
            2020-04-28 12:00:25.900 - debug: sainlogic.0 (20639) FW Scheduler Received data string: ffff501511456173795765617468657256312e342e39
            2020-04-28 12:00:25.900 - info: sainlogic.0 (20639) FW Scheduler received raw: EasyWeatherV1.4.9
            2020-04-28 12:00:25.903 - info: sainlogic.0 (20639) FW Scheduler Connection closed
            2020-04-28 12:00:25.906 - info: sainlogic.0 (20639) Data Scheduler connected to weather station
            2020-04-28 12:01:25.902 - info: sainlogic.0 (20639) FW Scheduler connected to weather station
            2020-04-28 12:01:25.905 - debug: sainlogic.0 (20639) FW Scheduler Received (length): 22
            2020-04-28 12:01:25.906 - debug: sainlogic.0 (20639) FW Scheduler Received data string: ffff501511456173795765617468657256312e342e39
            2020-04-28 12:01:25.907 - info: sainlogic.0 (20639) FW Scheduler received raw: EasyWeatherV1.4.9
            2020-04-28 12:01:25.910 - info: sainlogic.0 (20639) FW Scheduler Connection closed
            2020-04-28 12:01:25.914 - info: sainlogic.0 (20639) Data Scheduler connected to weather station
            2020-04-28 12:02:25.862 - info: sainlogic.0 (20639) FW Scheduler connected to weather station
            2020-04-28 12:02:25.865 - debug: sainlogic.0 (20639) FW Scheduler Received (length): 22
            2020-04-28 12:02:25.865 - debug: sainlogic.0 (20639) FW Scheduler Received data string: ffff501511456173795765617468657256312e342e39
            2020-04-28 12:02:25.866 - info: sainlogic.0 (20639) FW Scheduler received raw: EasyWeatherV1.4.9
            2020-04-28 12:02:25.868 - info: sainlogic.0 (20639) FW Scheduler Connection closed
            2020-04-28 12:02:25.870 - info: sainlogic.0 (20639) Data Scheduler connected to weather station
            So wie es aussieht funktioniert die Kommunikation (es wird ein 22 Zeichen langer String empfangen) doch es wird nichts in die Datenpunkte geschrieben.
            • LatziL Latzi
              @Fogg
              FoggF Offline
              FoggF Offline
              Fogg
              schrieb am zuletzt editiert von Fogg
              @Latzi Das ist leider nur die Hälfte der Info. Der 22-zeichige beinhaltet die Softwareversion. Es müsste noch ein zweiter String mit 82 Zeichen kommen :/
              Dazu gibt es quasi zwei Jobs, den FW (Firmware) und Data (Data). Der zweite läuft wohl an und kriegt die Verbindung, aber kriegt keine Antwort. Hast Du ein Linux-System zur Hand? Dann könnte ich Dir eine Kommandozeile schicken zum testen ob/was Deine Wetterstation zurück liefert.
              Kannst du noch den System-teil des Logs schicken? Ggf. schmiert das Skript ab und die Fehlermeldung fehlt dann.
              • FoggF Fogg
                LatziL Online
                LatziL Online
                Latzi
                @Fogg
                Ja, ich hab ein Ubuntu-Sytem oder den Raspi-iobroker bei der Hand (in etwa einer Stunde).
                Welcher System-Log meinst du?(das war alles aus dem log)??
                • LatziL Latzi
                  @Fogg
                  FoggF Offline
                  FoggF Offline
                  Fogg
                  @Latzi Du scheinst auf sainlogic gefilter zu haben.
                  Der Befehl wäre der hier:
                  socat open:weather.hexin,ignoreeof!!create:weather.hexout TCP:<ip_der_wetterstation>:45000,readbytes=82,connect-timeout=3
                  Du braucht die angehängte Datei dafür.
                  weather.hexin
                  Anschliessend erzeigt das Ding ein weather.hexout. Das könntest mir schicken.
                  • FoggF Fogg
                    weather.hexin
                    LatziL Online
                    LatziL Online
                    Latzi
                    Da stimmt was nicht, wenn ich
                    sudo socat open:weather.hexin,ignoreeofcd /opt/testcreate:weather.hexout TCP:10.0.0.35:45000,readbytes=82,connect-timeout=3
                    ausführe, erhalte ich
                    2020/04/28 20:48:57 socat[2045] E exactly 2 addresses required (there are 3); use option "-h" for help
                    Was mach ich da falsch? Ich hab das file in /opt/test kopiert, ist das Verzeichnis beim Aufruf oben zu berücksichtigen (ist das /opt/testcreate oben?)
                    • FoggF Offline
                      FoggF Offline
                      Fogg
                      Die Ausrufezeichen fehlen nach ignoreeof :D Dafür steht das 'cd /opt/test'.
                      Versuche mach den kompletten Parameter ab open bis ende mit Quote (") zu setzen. Oder die Ausrufezeichen zu 'quoten'. Also mit backslash-vornedran.
                      • FoggF Offline
                        FoggF Offline
                        Fogg
                        Bugfix für den Listener ist online, war das dateutc Ding.
                        • FoggF Fogg
                          LatziL Online
                          LatziL Online
                          Latzi
                          Mit
                          sudo socat 'open:weather.hexin,ignoreeof!!create:weather.hexout' TCP:10.0.0.35:45000,readbytes=82,connect-timeout=3
                          läuft´s endlos, file wird keiner erzeugt. Ist das ignoreeof wirklich richtig, nicht ignoreof?
                          • FoggF Fogg
                            FoggF Offline
                            FoggF Offline
                            Fogg
                            @Fogg said in Wetterstation WS980WiFi von ELV (Neuer Adapter):
                            Funzt noch nicht :/ grrr..
                            • FoggF Fogg
                              FoggF Offline
                              FoggF Offline
                              Fogg
                              jetzt aber - sollte der listener wieder gehen.
                              • LatziL Latzi
                                Mit
                                FoggF Offline
                                FoggF Offline
                                Fogg
                                @Latzi Das ist schon merkwürdig... würde heissen es kommen keine Daten von Deiner WS. Was für eine hast Du? Ist es eine WS980 oder eine andere?
                                • FoggF Fogg
                                  LatziL Online
                                  LatziL Online
                                  Latzi
                                  @Fogg
                                  Nein, ist eine Eurochron EFWS2900. Warum funktioniert dann die FW-Abfrage?
                                  • FoggF Offline
                                    FoggF Offline
                                    Fogg
                                    Das ist ne gute Frage. Wenn ich in einem anderen Forum richtig sehe sollte die schon baugleich sein. Hat ja auch die gleiche Firmware...
                                    Also der Befehl war der hier:
                                     socat open:weather.hexin,ignoreeof\!\!create:weather.hexout TCP:192.168.1.20:45000,readbytes=82,connect-timeout=3
                                    Wenn da nichts kommt ist vielleicht der Inhalt von hexin nicht korrekt. Geht es mit dem Listener?
                                    ? LatziL 2 Antworten Letzte Antwort
                                    • FoggF Fogg
                                      @Fogg
                                      ich hab die Eurochron EFWS2900 und der Listener funktioniert prima, hier meine Einstellung ( Version 0.1.4 von Git )
                                      Bei der Wetterstation hab ich den Port 8188 in der App zum raussenden gewählt, war einfach frei.
                                      und hier die Datenpunkte, kann man da noch etwas runden, bitte ? :-)
                                      Die Regenmenge stimmt nicht, kann aber auch an der Wetterstation liegen...
                                      js-controller 3.0.20, Node 12.6.2, NPM 6.14.0, LInux Mint Silvia 18.3.
                                      • FoggF Fogg
                                        LatziL Online
                                        LatziL Online
                                        Latzi
                                        Ja, Listener funzt
                                        2020-04-28 21:58:14.447 - info: host.Pi4-Server "system.adapter.sainlogic.0" enabled
                                        2020-04-28 21:58:14.500 - info: host.Pi4-Server instance system.adapter.sainlogic.0 started with pid 12514
                                        2020-04-28 21:58:15.243 - debug: sainlogic.0 (12514) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2020-04-28 21:58:15.333 - debug: sainlogic.0 (12514) Objects client ready ... initialize now
                                        2020-04-28 21:58:15.348 - debug: sainlogic.0 (12514) Objects create System PubSub Client
                                        2020-04-28 21:58:15.350 - debug: sainlogic.0 (12514) Objects create User PubSub Client
                                        2020-04-28 21:58:15.352 - debug: sainlogic.0 (12514) Objects client initialize lua scripts
                                        2020-04-28 21:58:15.391 - debug: sainlogic.0 (12514) Objects connected to redis: 127.0.0.1:9001
                                        2020-04-28 21:58:15.400 - debug: sainlogic.0 (12514) objectDB connected
                                        2020-04-28 21:58:15.404 - debug: sainlogic.0 (12514) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2020-04-28 21:58:15.417 - debug: sainlogic.0 (12514) States create User PubSub Client
                                        2020-04-28 21:58:15.420 - debug: sainlogic.0 (12514) States create System PubSub Client
                                        2020-04-28 21:58:15.437 - debug: sainlogic.0 (12514) States connected to redis: 127.0.0.1:9000
                                        2020-04-28 21:58:15.438 - debug: sainlogic.0 (12514) statesDB connected
                                        2020-04-28 21:58:16.636 - info: sainlogic.0 (12514) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v12.16.2
                                        2020-04-28 21:58:16.690 - info: sainlogic.0 (12514) Listner active: true
                                        2020-04-28 21:58:16.691 - info: sainlogic.0 (12514) Config IP: 0.0.0.0
                                        2020-04-28 21:58:16.695 - info: sainlogic.0 (12514) Config port: 17551
                                        2020-04-28 21:58:16.696 - info: sainlogic.0 (12514) Config path: /weatherstation/updateweatherstation.php
                                        2020-04-28 21:58:16.697 - info: sainlogic.0 (12514) Scheduler active: false
                                        2020-04-28 21:58:16.698 - info: sainlogic.0 (12514) WS IP: 10.0.0.35
                                        2020-04-28 21:58:16.699 - info: sainlogic.0 (12514) WS Port: 45000
                                        2020-04-28 21:58:16.700 - info: sainlogic.0 (12514) WS Frequency: 60
                                        2020-04-28 21:58:16.700 - info: sainlogic.0 (12514) Starting Listener
                                        2020-04-28 21:59:07.734 - debug: sainlogic.0 (12514) system.adapter.admin.0: logging false
                                        2020-04-28 21:59:08.597 - debug: sainlogic.0 (12514) system.adapter.admin.0: logging true
                                        2020-04-28 21:59:11.189 - info: sainlogic.0 (12514) Received path: /weatherstation/updateweatherstation.php
                                        2020-04-28 21:59:11.190 - info: sainlogic.0 (12514) JSON Query string: {"ID":"ITRAGW1","PASSWORD":"LATZI","indoortempf":"72.7","tempf":"55.2","dewptf":"51.6","windchillf":"55.2","indoorhumidity":"40","humidity":"88","windspeedmph":"3.8","windgustmph":"5.8","winddir":"210","absbaromin":"28.096","baromin":"29.882","rainin":"0.307","dailyrainin":"0.142","weeklyrainin":"0.150","monthlyrainin":"0.429","solarradiation":"0.00","UV":"0","dateutc":"2020-04-28 19:59:08","softwaretype":"EasyWeatherV1.4.9","action":"updateraw","realtime":"1","rtfreq":"5"}
                                        2020-04-28 22:00:10.708 - debug: sainlogic.0 (12514) system.adapter.admin.0: logging false
                                        2020-04-28 22:00:15.171 - info: sainlogic.0 (12514) Received path: /weatherstation/updateweatherstation.php
                                        2020-04-28 22:00:15.172 - info: sainlogic.0 (12514) JSON Query string: {"ID":"ITRAGW1","PASSWORD":"LATZI","indoortempf":"73.0","tempf":"55.0","dewptf":"51.4","windchillf":"55.0","indoorhumidity":"40","humidity":"88","windspeedmph":"4.0","windgustmph":"5.8","winddir":"198","absbaromin":"28.104","baromin":"29.891","rainin":"0.236","dailyrainin":"0.142","weeklyrainin":"0.150","monthlyrainin":"0.429","solarradiation":"0.00","UV":"0","dateutc":"2020-04-28 20:00:12","softwaretype":"EasyWeatherV1.4.9","action":"updateraw","realtime":"1","rtfreq":"5"}
                                        sainlogic.0.weather.yearlyrain bleibt aber leer (null), kann das der Unterschied sein?
                                          @Fogg
                                          FoggF Offline
                                          FoggF Offline
                                          Fogg
                                          @ilovegym Rounding ist drin, im nächsten Pull Request kommt das mit.
                                          Gut dass schonmal der Listener geht, das ist ja wie das shell skript auch. Müsste man worst-case mal tcpdump oder so mitlaufen lassen um zu schauen was denn z.B. von den WS-View apps da hin geschickt wird.
