  4. Iobroker nach update nict erreichbar
iobroker startet nicht mehr
68 Beiträge 4 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • ShootgunS Shootgun
    danke für die erste hilfe
    bin neu im forum
    sry
    hier der code ;)
    hoffe jetzt kann jemand helfen ;)
    code_textpi@iobroker:~ $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN checkPermissions Missing write access to /home/pi
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! path /home/pi
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/home/pi'
    npm ERR! { Error: EACCES: permission denied, access '/home/pi'
    npm ERR! stack: 'Error: EACCES: permission denied, access '/home/pi'',
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'access',
    npm ERR! path: '/home/pi' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! /home/iobroker/.npm/_logs/2020-04-26T17_07_21_284Z-debug.log
    übrigens teste ich grade herum und mehr und mehr ist mir unerklärlich
    code_textpi@iobroker:/opt/iobroker $ iobroker status
    module.js:550
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (module.js:548:15)
        at Function.Module._load (module.js:475:25)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
        at bootstrap_node.js:625:3
    Housten we have a Problem
    BBTownB Offline
    BBTownB Offline
    BBTown
    schrieb am zuletzt editiert von BBTown
    @Shootgun sagte in Iobroker nach update nict erreichbar:
    Der Hinweis in Zeile 3 läßt darauf schließen, das der User keine Schreibberechtigungen auf das Verzeichnis hat.
    Kann es darüber hinaus sein das Du vorher nicht erst in cd /opt/iobroker gewechselt hast bevor Du den Befehl zur Aktualisierung des js-controllers eingegeben hast?
    Wurde zudem iobroker stop zuvor ausgeführt?
    • BBTownB BBTown
      haselchenH Offline
      haselchenH Offline
      haselchen
      @BBTown
      Hahahahahaha, 2 Blöde 1 Gedanke :)
      BBTownB 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @BBTown
        BBTownB Offline
        BBTownB Offline
        BBTown
        @haselchen
        ist mir ja auch schon passiert 😎
        • ShootgunS Offline
          ShootgunS Offline
          Shootgun
          ich habe das verzeichniss gewechselt und auch den stop vorher gemacht
          mitlerweile habe ich ncohmal versucht das update zu machen
          dabei kommtdas heraus:
          pi@iobroker:/opt/iobroker $ iobroker update
          module.js:550
              throw err;
            module.js:550
                throw err;
            haselchenH Offline
            haselchenH Offline
            haselchen
            @Shootgun
            Musste vermutlich den Fixer laufen lassen
            curl -sL https://iobroker.net/fix.sh | bash -
            • ShootgunS Offline
              ShootgunS Offline
              Shootgun
              pi@iobroker:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
              library: loaded
              Library version=2020-04-12
              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
              bin für weitere hilfen dankbar
              • ShootgunS Offline
                ShootgunS Offline
                Shootgun
                wieso nicht installd ist die frage
                was ist denn da explodiert?
                wenn ich jetzt neu instaliere sind alle einstellungen von alexa und homematic usw weg oder kann ich das irgendwie vorher backuppen
                  @Shootgun
                   ls -la /opt/iobroker/
                  • ShootgunS Offline
                    ShootgunS Offline
                    Shootgun
                    ODER (was mir lieber wäre) kann ich das irgendwie wieder zum laufen bringen ?
                    heute mittag lief allesnoch normal
                    • ShootgunS Offline
                      ShootgunS Offline
                      Shootgun
                      pi@iobroker:/opt/iobroker $ ls -la /opt/iobroker/
                      insgesamt 256
                      drwxrwxrwx+   7 iobroker iobroker   4096 Apr 26 14:13 .
                      drwxr-xr-x    4 root     root       4096 Apr 17  2019 ..
                      -rwxrwxrwx+   1 iobroker iobroker   1474 Apr 17  2019 CHANGELOG_INSTALLER_LINUX.md
                      drwxrwxrwx+   3 iobroker iobroker   4096 Apr 17  2019 install
                      -rwxrwxrwx+   1 iobroker iobroker    163 Apr 17  2019 INSTALLER_INFO.txt
                      lrwxrwxrwx    1 iobroker iobroker     22 Apr 17  2019 iob -> /opt/iobroker/iobroker
                      -rwxrwxrwx+   1 iobroker iobroker    229 Apr 17  2019 iobroker
                      drwxrwxrwx+   4 iobroker iobroker   4096 Apr 17  2019 iobroker-data
                      -rwxrwxrwx+   1 iobroker iobroker     92 Apr 17  2019 killall.sh
                      drwxrwxrwx+   2 iobroker iobroker   4096 Apr 17  2019 lib
                      -rwxrwxrwx+   1 iobroker iobroker   1137 Apr 17  2019 LICENSE
                      drwxrwxrwx+   2 iobroker iobroker   4096 Apr 26 14:13 log
                      drwxrwxrwx+ 631 iobroker iobroker  20480 Apr 26 14:15 node_modules
                      -rwxrwxrwx+   1 iobroker iobroker     19 Sep 21  2019 .npmrc
                      -rwxrwxrwx+   1 iobroker iobroker    866 Apr 26 14:13 package.json
                      -rwxrwxrwx+   1 iobroker iobroker 166392 Apr 17  2019 package-lock.json
                      -rwxrwxrwx+   1 iobroker iobroker   6101 Apr 17  2019 README.md
                      -rwxrwxrwx+   1 iobroker iobroker   5728 Apr 26 14:15 reinstall.js
                      -rwxrwxrwx+   1 iobroker iobroker    709 Apr 17  2019 reinstall.sh
                        insgesamt 256
                        @Shootgun
                        Die Dateien sind aber alle recht alt (von 2019).
                        Da müsste bei einem aktuellen Update was von 2020 drin sein. Keine Ahnung was du da gemacht hast.
                        • ShootgunS Offline
                          ShootgunS Offline
                          Shootgun
                          ich habe das update für den js controler durchgeführt
                          also einloggen per ssh
                          iobroker stop
                          iobroker update
                          iobroker upgrade self
                          iobroker start
                          und dann war das webinterface weg
                          jetzt weiß ich nicht warum
                          hast du ne idee wie ich das webinterface wieder bekomme ?
                          haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                            iobroker stop
                            iobroker update
                            iobroker start
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @Shootgun
                            Hast du noch nen anderen Iobroker Ordner?
                            Unter Home/pi?
                              iobroker stop
                              iobroker update
                              iobroker start
                              @Shootgun
                              which iobroker
                              • ShootgunS Offline
                                ShootgunS Offline
                                Shootgun
                                den besagten ordner gibt es aber sind nur 2 dateien drin
                                alexaremotecontrol.sh
                                und spechercontertory.sh
                                und auch von 2019
                                • ShootgunS Offline
                                  ShootgunS Offline
                                  Shootgun
                                  @Thomas-Braun said in Iobroker nach update nict erreichbar:
                                  which iobroker
                                  pi@iobroker:/opt/iobroker $ which iobroker
                                  /usr/bin/iobroker
                                  • ShootgunS Offline
                                    ShootgunS Offline
                                    Shootgun
                                    ich habe nen log von heute gefunden
                                    2020-04-26 13:56:28.037  - info: admin.0 (17831) Request actual repository...
                                    2020-04-26 13:56:28.130  - info: host.iobroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                    2020-04-26 13:56:30.135  - info: admin.0 (17831) Repository received successfully.
                                    2020-04-26 13:59:43.849  - info: host.iobroker received SIGTERM
                                    2020-04-26 13:59:43.862  - info: info.0 (17930) cleaned everything up...
                                    2020-04-26 13:59:43.874  - info: hm-rpc.1 (17947) xmlrpc -> 192.168.0.94:2010/ init ["http://192.168.0.200:2010",""]
                                    2020-04-26 13:59:43.863  - info: hm-rpc.0 (17873) xmlrpc -> 192.168.0.94:2001/ init ["http://192.168.0.200:2001",""]
                                    2020-04-26 13:59:43.873  - info: web.0 (17961) terminated http server on port 8082
                                    2020-04-26 13:59:43.882  - info: admin.0 (17831) terminating http server on port 8081
                                    2020-04-26 13:59:43.895  - info: hm-rega.0 (17888) Got terminate signal TERMINATE_YOURSELF
                                    2020-04-26 13:59:43.904  - info: info.0 (17930) Got terminate signal TERMINATE_YOURSELF
                                    2020-04-26 13:59:43.904  - info: hm-rpc.1 (17947) Disconnected
                                    2020-04-26 13:59:43.857  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2020-04-26 13:59:43.859  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2020-04-26 13:59:43.862  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                                    2020-04-26 13:59:43.864  - info: host.iobroker stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                                    2020-04-26 13:59:43.866  - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=true)
                                    2020-04-26 13:59:43.868  - info: host.iobroker stopInstance system.adapter.admin.1 (force=false, process=false)
                                    2020-04-26 13:59:43.870  - info: host.iobroker stopInstance system.adapter.info.0 (force=false, process=true)
                                    2020-04-26 13:59:43.871  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
                                    2020-04-26 13:59:43.873  - info: host.iobroker stopInstance system.adapter.cloud.0 (force=false, process=false)
                                    2020-04-26 13:59:43.875  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
                                    2020-04-26 13:59:43.876  - info: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true)
                                    2020-04-26 13:59:43.879  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                                    2020-04-26 13:59:43.883  - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
                                    2020-04-26 13:59:43.889  - info: host.iobroker stopInstance system.adapter.hm-rega.0 send kill signal
                                    2020-04-26 13:59:43.894  - info: host.iobroker stopInstance system.adapter.alexa2.0 send kill signal
                                    2020-04-26 13:59:43.898  - info: host.iobroker stopInstance system.adapter.info.0 send kill signal
                                    2020-04-26 13:59:43.904  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
                                    2020-04-26 13:59:43.907  - info: host.iobroker stopInstance system.adapter.iot.0 send kill signal
                                    2020-04-26 13:59:43.915  - info: web.0 (17961) Got terminate signal TERMINATE_YOURSELF
                                    2020-04-26 13:59:43.899  - info: alexa2.0 (13053) Got terminate signal TERMINATE_YOURSELF
                                    2020-04-26 13:59:43.890  - info: discovery.0 (17858) Got terminate signal TERMINATE_YOURSELF
                                    2020-04-26 13:59:43.921  - info: admin.0 (17831) Got terminate signal TERMINATE_YOURSELF
                                    2020-04-26 13:59:43.905  - info: iot.0 (18176) Connection changed: disconnect
                                    2020-04-26 13:59:43.926  - info: hm-rpc.0 (17873) Disconnected
                                    2020-04-26 13:59:43.915  - info: iot.0 (18176) Connection lost
                                    2020-04-26 13:59:43.933  - info: iot.0 (18176) Got terminate signal TERMINATE_YOURSELF
                                    2020-04-26 13:59:43.936  - info: info.0 (17930) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.944  - info: alexa2.0 (13053) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.944  - info: hm-rega.0 (17888) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.954  - info: discovery.0 (17858) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.958  - info: admin.0 (17831) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.954  - info: web.0 (17961) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.960  - info: hm-rpc.1 (17947) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.954  - info: iot.0 (18176) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:43.966  - info: hm-rpc.0 (17873) Terminated (NO_ERROR): Without reason
                                    2020-04-26 13:59:44.475  - info: host.iobroker instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.583  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.585  - info: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.586  - info: host.iobroker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.586  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.587  - info: host.iobroker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.589  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.591  - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.592  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
                                    2020-04-26 13:59:44.592  - info: host.iobroker All instances are stopped.
                                    2020-04-26 13:59:44.701  - info: host.iobroker terminated
                                    2020-04-26 14:01:42.781  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:01:42.793  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:01:42.795  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:01:42.800  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:01:45.463  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:01:45.476  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:01:45.477  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:01:45.482  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:01:47.905  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:01:47.918  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:01:47.919  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:01:47.924  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:01:50.402  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:01:50.415  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:01:50.416  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:01:50.421  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:01:52.903  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:01:52.915  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:01:52.917  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:01:52.921  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:01:55.405  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:01:55.417  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:01:55.419  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:01:55.423  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:01:57.905  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:01:57.918  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:01:57.919  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:01:57.924  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:02:00.407  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:02:00.420  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:02:00.421  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:02:00.426  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:02:02.908  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:02:02.921  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:02:02.923  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:02:02.927  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:02:05.401  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:02:05.414  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-04-26 14:02:05.416  - info: host.iobroker hostname: iobroker, node: v8.16.0
                                    2020-04-26 14:02:05.420  - info: host.iobroker ip addresses: 192.168.0.200 fd00::35ea:562e:19f4:862 fe80::5afc:dce0:4c16:30f4
                                    2020-04-26 14:02:07.893  - info: host.iobroker iobroker.js-controller version 3.0.18 js-controller starting
                                    2020-04-26 14:02:07.906  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    das wiederholt sich dann immer weiter
                                    Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                                      @Shootgun Du hast node 8 installiert?
                                      nodejs -v
                                      node -v
                                      npm -v
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @Shootgun
                                        Nunja, erstmal ist deine Nodejs Version zu niedrig für den JS Controller V3
                                        Was Du da jetzt aber zerschossen hast, keine Ahnung.
                                        Erstaunlich das die JS Version 3.0.18 anzeigt.
                                        • ShootgunS Offline
                                          ShootgunS Offline
                                          Shootgun
                                          ich weiß grade grnicht mehr was los ist
                                          sry
                                          also
                                          pi@iobroker:/opt/iobroker $ nodejs -v
                                          v8.16.0
                                          pi@iobroker:/opt/iobroker $ node -v
                                          v8.16.0
                                          pi@iobroker:/opt/iobroker $ npm -v
                                          6.4.1
