  4. Iobroker nach update nict erreichbar
iobroker startet nicht mehr
68 Beiträge 4 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • ShootgunS Offline
    ShootgunS Offline
    Shootgun
    schrieb am zuletzt editiert von Shootgun
    ich glaube ich habe es kaputt gemacht
    habe den update durchgefühtr
    iobroker stop
    iobroker update
    iobroker upgrade self
    iobroker start
    geht auch soweit ih gesehen habe alles normal
    dann war die weboberfläche nicht mehr erreichbar
    habe dann paar mal gerät neugestartet und ging nix mehr
    dann habe ich das hier versucht:
    pi@iobroker:~ $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN checkPermissions Missing write access to /home/pi
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! path /home/pi
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/home/pi'
    npm ERR!  { Error: EACCES: permission denied, access '/home/pi'
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/home/pi\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/home/pi' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR!     /home/iobroker/.npm/_logs/2020-04-26T17_07_21_284Z-debug.log
    jetzt geht nix mehr
    jemand eine idee was ich machen könnte? wäre schön wenn ich nicht alles neu machen müsste ;)
    BBTownB 1 Antwort Letzte Antwort
    • ShootgunS Shootgun
      iobroker stop
      iobroker update
      iobroker start
      npm ERR! errno -13
      npm ERR!
      npm ERR!
      jetzt geht nix mehr
      BBTownB Offline
      BBTownB Offline
      BBTown
      schrieb am zuletzt editiert von BBTown
      @Shootgun
      Logs und code sind immer in die dafür vorgesehen Tags zu packen, das kann sons kein Mensch lesen!!
      Bearbeite daher deinen Text noch einmal !!
      • ShootgunS Offline
        ShootgunS Offline
        Shootgun
        danke für die erste hilfe
        bin neu im forum
        sry
        hier der code ;)
        hoffe jetzt kann jemand helfen ;)
        code_textpi@iobroker:~ $ sudo -H -u iobroker npm install iobroker.js-controller
        npm ERR! errno -13
        npm ERR! stack: 'Error: EACCES: permission denied, access '/home/pi'',
        npm ERR!
        npm ERR!
        übrigens teste ich grade herum und mehr und mehr ist mir unerklärlich
        code_textpi@iobroker:/opt/iobroker $ iobroker status
        module.js:550
            throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (module.js:548:15)
            at Function.Module._load (module.js:475:25)
            at Function.Module.runMain (module.js:694:10)
            at startup (bootstrap_node.js:204:16)
            at bootstrap_node.js:625:3
        Housten we have a Problem
        BBTownB 2 Antworten Letzte Antwort
          bin neu im forum
          sry
          hier der code ;)
          npm ERR! errno -13
          npm ERR!
          npm ERR!
          module.js:550
              throw err;
          BBTownB Offline
          BBTownB Offline
          BBTown
          @Shootgun jetzt sieht der erste Beitrag aber immer noch aus wie zuvor ....
          • ShootgunS Offline
            ShootgunS Offline
            Shootgun
            hast recht
            vergessen
            stöbere grade im forum ob ich einen weg fnde der das wieder zum laufen brint ohne neuinstalation
            aber bisher nichts passendes gefunden
            habe jetzt den ersten post editiert
              hast recht
              vergessen
              haselchenH Offline
              haselchenH Offline
              haselchen
              @Shootgun
              Du warst bei der Installation im Homeverzeichnis
              Installationen immer in /opt/iobroker
                bin neu im forum
                sry
                hier der code ;)
                npm ERR! errno -13
                npm ERR!
                npm ERR!
                module.js:550
                    throw err;
                BBTownB Offline
                BBTownB Offline
                BBTown
                @Shootgun sagte in Iobroker nach update nict erreichbar:
                Der Hinweis in Zeile 3 läßt darauf schließen, das der User keine Schreibberechtigungen auf das Verzeichnis hat.
                Kann es darüber hinaus sein das Du vorher nicht erst in cd /opt/iobroker gewechselt hast bevor Du den Befehl zur Aktualisierung des js-controllers eingegeben hast?
                Wurde zudem iobroker stop zuvor ausgeführt?
                • BBTownB BBTown
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @BBTown
                  Hahahahahaha, 2 Blöde 1 Gedanke :)
                  • haselchenH haselchen
                    @BBTown
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    @haselchen
                    ist mir ja auch schon passiert 😎
                    • ShootgunS Offline
                      ShootgunS Offline
                      Shootgun
                      ich habe das verzeichniss gewechselt und auch den stop vorher gemacht
                      mitlerweile habe ich ncohmal versucht das update zu machen
                      dabei kommtdas heraus:
                      pi@iobroker:/opt/iobroker $ iobroker update
                      module.js:550
                          throw err;
                        module.js:550
                            throw err;
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @Shootgun
                        Musste vermutlich den Fixer laufen lassen
                        curl -sL https://iobroker.net/fix.sh | bash -
                        • ShootgunS Offline
                          ShootgunS Offline
                          Shootgun
                          pi@iobroker:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                          library: loaded
                          Library version=2020-04-12
                          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                          bin für weitere hilfen dankbar
                          • ShootgunS Offline
                            ShootgunS Offline
                            Shootgun
                            wieso nicht installd ist die frage
                            was ist denn da explodiert?
                            wenn ich jetzt neu instaliere sind alle einstellungen von alexa und homematic usw weg oder kann ich das irgendwie vorher backuppen
                              @Shootgun
                               ls -la /opt/iobroker/
                              • ShootgunS Offline
                                ShootgunS Offline
                                Shootgun
                                ODER (was mir lieber wäre) kann ich das irgendwie wieder zum laufen bringen ?
                                heute mittag lief allesnoch normal
                                • ShootgunS Offline
                                  ShootgunS Offline
                                  Shootgun
                                  pi@iobroker:/opt/iobroker $ ls -la /opt/iobroker/
                                  insgesamt 256
                                  drwxrwxrwx+   7 iobroker iobroker   4096 Apr 26 14:13 .
                                  drwxr-xr-x    4 root     root       4096 Apr 17  2019 ..
                                  -rwxrwxrwx+   1 iobroker iobroker   1474 Apr 17  2019 CHANGELOG_INSTALLER_LINUX.md
                                  drwxrwxrwx+   3 iobroker iobroker   4096 Apr 17  2019 install
                                  -rwxrwxrwx+   1 iobroker iobroker    163 Apr 17  2019 INSTALLER_INFO.txt
                                  lrwxrwxrwx    1 iobroker iobroker     22 Apr 17  2019 iob -> /opt/iobroker/iobroker
                                  -rwxrwxrwx+   1 iobroker iobroker    229 Apr 17  2019 iobroker
                                  drwxrwxrwx+   4 iobroker iobroker   4096 Apr 17  2019 iobroker-data
                                  -rwxrwxrwx+   1 iobroker iobroker     92 Apr 17  2019 killall.sh
                                  drwxrwxrwx+   2 iobroker iobroker   4096 Apr 17  2019 lib
                                  -rwxrwxrwx+   1 iobroker iobroker   1137 Apr 17  2019 LICENSE
                                  drwxrwxrwx+   2 iobroker iobroker   4096 Apr 26 14:13 log
                                  drwxrwxrwx+ 631 iobroker iobroker  20480 Apr 26 14:15 node_modules
                                  -rwxrwxrwx+   1 iobroker iobroker     19 Sep 21  2019 .npmrc
                                  -rwxrwxrwx+   1 iobroker iobroker    866 Apr 26 14:13 package.json
                                  -rwxrwxrwx+   1 iobroker iobroker 166392 Apr 17  2019 package-lock.json
                                  -rwxrwxrwx+   1 iobroker iobroker   6101 Apr 17  2019 README.md
                                  -rwxrwxrwx+   1 iobroker iobroker   5728 Apr 26 14:15 reinstall.js
                                  -rwxrwxrwx+   1 iobroker iobroker    709 Apr 17  2019 reinstall.sh
                                    insgesamt 256
                                    @Shootgun
                                    Die Dateien sind aber alle recht alt (von 2019).
                                    Da müsste bei einem aktuellen Update was von 2020 drin sein. Keine Ahnung was du da gemacht hast.
                                    • ShootgunS Offline
                                      ShootgunS Offline
                                      Shootgun
                                      ich habe das update für den js controler durchgeführt
                                      also einloggen per ssh
                                      iobroker stop
                                      iobroker update
                                      iobroker start
                                      und dann war das webinterface weg
                                      jetzt weiß ich nicht warum
                                      hast du ne idee wie ich das webinterface wieder bekomme ?
                                      haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                                        iobroker stop
                                        iobroker update
                                        iobroker start
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @Shootgun
                                        Hast du noch nen anderen Iobroker Ordner?
                                        Unter Home/pi?
                                          iobroker stop
                                          iobroker update
                                          iobroker start
                                          @Shootgun
                                          which iobroker
