  4. Zigbee Adapter Failed to start
    6.4k
zigbee adapter cc2531
48 Beiträge 10 Kommentatoren 7.1k Aufrufe 12 Beobachtet
  • hg6806H Offline
    hg6806H Offline
    hg6806
    Bin leider noch nicht weitergekommen.
    Folgendes habe ich probiert:
    root@raspberrypi:~# hciconfig
    hci1:   Type: Primary  Bus: UART
            BD Address: DC:A6:32:0A:73:B3  ACL MTU: 1021:8  SCO MTU: 64:1
            UP RUNNING
            RX bytes:8525625 acl:0 sco:0 events:234932 errors:0
            TX bytes:1374 acl:0 sco:0 commands:59 errors:0
    hci0:   Type: Primary  Bus: USB
            BD Address: 00:1A:7D:DA:71:11  ACL MTU: 679:9  SCO MTU: 48:16
            DOWN
            RX bytes:1148 acl:0 sco:0 events:60 errors:0
            TX bytes:736 acl:0 sco:0 commands:60 errors:0
    root@raspberrypi:~# lsusb
    Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s bridge
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
    Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
    Bus 001 Device 007: ID 0451:16a8 Texas Instruments, Inc.
    Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
    Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub
    Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
    root@raspberrypi:~# bluetoothctl
    Agent registered
    [bluetooth]# scan on
    Discovery started
    [CHG] Controller DC:A6:32:0A:73:B3 Discovering: yes
    [NEW] Device E7:2E:00:D3:20:42 LYWSD02
    Dann den BLE Stick entfernt, BLE Adapter gestoppt und den Pi neu gestartet.
    Zigbee bleibt gelb, Debug-Log:
    zigbee.0	2020-04-12 10:12:53.178	error	(2063) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
    zigbee.0	2020-04-12 10:12:53.176	error	(2063) Failed to start Zigbee
    zigbee.0	2020-04-12 10:12:52.979	debug	(2063) Starting zigbee-herdsman...
    zigbee.0	2020-04-12 10:12:52.979	info	(2063) Starting Zigbee...
    zigbee.0	2020-04-12 10:12:52.978	info	(2063) Try to reconnect. 1 attempts left
    zigbee.0	2020-04-12 10:12:42.977	error	(2063) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
    zigbee.0	2020-04-12 10:12:42.974	error	(2063) Failed to start Zigbee
    zigbee.0	2020-04-12 10:12:35.663	debug	(2063) Starting zigbee-herdsman...
    zigbee.0	2020-04-12 10:12:35.661	info	(2063) Starting Zigbee...
    zigbee.0	2020-04-12 10:12:35.627	info	(2063) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
    zigbee.0	2020-04-12 10:12:13.440	info	(1823) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0	2020-04-12 10:12:13.439	info	(1823) terminating
    zigbee.0	2020-04-12 10:12:13.438	error	at process._tickCallback (internal/process/next_tick.js:68:7))
    zigbee.0	2020-04-12 10:12:13.438	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
    zigbee.0	2020-04-12 10:12:13.438	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
    zigbee.0	2020-04-12 10:12:13.438	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
    zigbee.0	2020-04-12 10:12:13.438	error	at new Promise (<anonymous>)
    zigbee.0	2020-04-12 10:12:13.438	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
    zigbee.0	2020-04-12 10:12:13.438	error	at Generator.next (<anonymous>)
    zigbee.0	2020-04-12 10:12:13.438	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
    zigbee.0	2020-04-12 10:12:13.438	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
    zigbee.0	2020-04-12 10:12:13.438	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
    zigbee.0	2020-04-12 10:12:13.438	error	(1823) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-04-12 10:12:13.434	info	(1823) Zigbee: disabling joining new devices.
    zigbee.0	2020-04-12 10:12:13.417	info	(1823) cleaned everything up...
    zigbee.0	2020-04-12 10:12:13.415	info	(1823) Got terminate signal TERMINATE_YOURSELF
    Hier noch weitere Konsolenbefehle:
    root@raspberrypi:~# ls -l /dev/serial/by-id
    insgesamt 0
    lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAA-if00-port0 -> ../../ttyUSB1
    lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAE-if00-port0 -> ../../ttyUSB0
    lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194AD7E3-if00 -> ../../ttyACM0
    Bus 001 Device 005: ID 0451:16a8 Texas Instruments, Inc.
    root@raspberrypi:~#
    Was kann ich noch tun?
    • mickymM Offline
      mickymM Offline
      mickym
      Ich glaube - dass wir das gleiche Problem haben: https://forum.iobroker.net/topic/32137/zigbee-cc2531-stick-beim-hochfahren-des-adapters-disabled
      Allerdings passiert es nicht immer, wenn auch mit der neuen Version gefühlt häufiger.
      Bei mir läuft der Adapter jedoch IMMER, wenn ich den Stick im laufenden Betrieb einfach abziehe, dann wieder anstecke und NUR den Adapter neu starte.
        toki1973
        @mickym Danke für deine Rückmeldung im anderen Thread. Inzwischen ist der Status wieder grün. Allerdings bekomme ich keine Werte mehr von den Sensoren.
        NUC, PROXMOX, Grafana, Influx, Unify
        • T toki1973
          mickymM Offline
          mickymM Offline
          mickym
          @toki1973 Hmm - bei mir funktionieren die Sensoren, es ist alles Bestens. Ist denn bei Dir der Adapter alleine auf grün gegangen oder hast Du wie ich mal den Stick abgezogen und wieder angesteckt und dann den Adapter neu gestartet?
          • hg6806H Offline
            hg6806H Offline
            hg6806
            @mickym So läuft es! Danke!
            Also immer erst Stick neu anstecken und Adapter neu starten. Dann wird es grün.
            Auch zusammen mit dem BLE.
            Wenn man aber den Pi neu startet bleibt Zigbee gelb.
            Ich habe das mit BLE mal ausprobiert, der BRAUCHT unbedingt ein Pi Neustart.
            Die Frage ist wie kann man das fixen?
            Kann man den Zigbee Stick oder den ganzen USB Bus resetten?
            • hg6806H Offline
              hg6806H Offline
              hg6806
              schrieb am zuletzt editiert von hg6806
              Hier gibt es wohl die Möglichkeit:
              Eine Datei usbreset erstellen und dann aufrufen
              Link Text
              Hab's noch nicht ausprobiert und hoffe es heute Abend mal zu schaffen.
              • hg6806H hg6806
                mickymM Offline
                mickymM Offline
                mickym
                @hg6806 said in Zigbee Adapter Failed to start:
                Meines Erachtens wird der Zigbee-Stick ja beim Adapterstart resettet und das ist aber das Problem. Wenn ich die Maschine neu boote wird der Stick resettet und die LED leuchtet. Startet der Adapter geht die LED auf dem Stick aus und dann scheint es bei mir Glücksache zu sein, ob der Adapter den wieder findet oder einen Time-Out bekommt. Jedenfalls geht die LED im Fehlerfall nicht mehr an, bis ich den Adapter physisch neu verbinde.
                • hg6806H Offline
                  hg6806H Offline
                  hg6806
                  Ja, so ist es wohl.
                  Habe mal usbreset nach der Anleitung erstellt und ausgeführt.
                  Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s brid        ge
                  Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (        HCI mode)
                  root@raspberrypi:~# usbreset /dev/bus/usb/001/007
                  Resetting USB device /dev/bus/usb/001/007
                  Reset successful
                  Stick wurde resettet aber zeigt nach Adapter-Neustart doch noch immer gelb an.
                    toki1973
                    Nach entfernen des USB Sticks und Neustart der VM auf dem NUC habe ich zumindest wieder die Instanz grün. Aber die Aktualität der Sensoren wurde nur beim Neustart aktualisiert.
                    @arteck Wie kann ich denn den Fehler eingrenzen?
                    Ein direktes ansprechen der Adapter über die Erweiterten Einstellungen hat auch keine Antwort von einem Sensor gebracht.
                    • T toki1973
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @toki1973
                      Nicht die VM neu starten. Nur Stick rausziehen und wieder rein und die Adapterinstanz Neustarten, nicht die ganze Maschine
                      • nerd68N Offline
                        nerd68N Offline
                        nerd68
                        schrieb am zuletzt editiert von nerd68
                        ich stoß mal ins gleiche Horn.
                        • ich habe meinen cc2531 auf die aktuelle Firmware geflasht.
                        • Neustart, Adapter gelb.
                        • Adapter auf 1.1.0 geupdated.
                        • selber Fehler, Adpater bleibt gelb.
                        • Adapter neu installiert, selber Fehler Adapter bleibt gelb.
                        Z-Stack ist sauber geflasht, wir und Serial Belegung zeigt:
                        drwxr-xr-x 2 root root 60 Apr 13 19:05 .
                        drwxr-xr-x 4 root root 80 Apr 13 19:05 ..
                        lrwxrwxrwx 1 root root 13 Apr 13 19:05 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019387353-if00 -> ../../ttyACM0
                        • keine weiteren USB Geräte angeschlossen, kann also kein Konflikt sein, dass der Port nicht frei ist.
                        Fehlercode:
                        zigbee.0	2020-04-13 19:05:48.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                        zigbee.0	2020-04-13 19:05:48.110	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                        zigbee.0	2020-04-13 19:05:48.110	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                        zigbee.0	2020-04-13 19:05:48.110	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                        zigbee.0	2020-04-13 19:05:48.110	error	at new Promise (<anonymous>)
                        zigbee.0	2020-04-13 19:05:48.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                        zigbee.0	2020-04-13 19:05:48.110	error	at Generator.next (<anonymous>)
                        zigbee.0	2020-04-13 19:05:48.110	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                        zigbee.0	2020-04-13 19:05:48.110	error	(2581) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                        zigbee.0	2020-04-13 19:05:48.109	error	(2581) Failed to start Zigbee
                        zigbee.0	2020-04-13 19:05:47.714	info	(2581) Starting Zigbee...
                        zigbee.0	2020-04-13 19:05:47.711	info	(2581) Try to reconnect. 1 attempts left
                        zigbee.0	2020-04-13 19:05:37.707	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:5:58)
                        zigbee.0	2020-04-13 19:05:37.707	error	at Generator.next (<anonymous>)
                        zigbee.0	2020-04-13 19:05:37.707	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:246:27)
                        zigbee.0	2020-04-13 19:05:37.707	error	(2581) Error: SREQ '--> SYS - osalNvRead - {"id":3840,"offset":0,"len":1,"value":{"type":"Buffer","data":[85]}}' failed with status '2' (expected '0')
                        zigbee.0	2020-04-13 19:05:37.705	error	(2581) Failed to start Zigbee
                        zigbee.0	2020-04-13 19:05:35.981	info	(2581) Starting Zigbee...
                        zigbee.0	2020-04-13 19:05:35.941	info	(2581) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                        BTW lief vorher komplett und reibungslos.
                        Das mit dem rein raus und Instanz Neustart hat nichts gebracht.
                        Vielleicht hat jemand noch einen Tipp.
                        VG,
                        Didier
                        Ubuntu 18.04 LTS
                        NUC Celeron 8GB, 500GB SSD
                        Node.js v12.16.2
                        NPM v6.14.4
                        Platform: linux
                        operating system: ubuntu 23.04 LTS
                        RAM: 7.6 GB
                        Node.js: v18.17.1
                        NPM: 9.6.7
                        • C Offline
                          chrisweber
                          Hallo Zusammen,
                          ich habe seit einiger Zeit ähnliche Probleme mit zigbee und komme einfach nicht weiter.
                          Mein Stick cc2531 arbeitet nach kurzer Zeit ( 1 Tag bis max. 1 Woche) nicht mehr.
                          Das Log zeigt dann Fehler an. Dieser Zustand ändert sich plötzlich, ohne dass am System irgendetwas verändert wird. Z.B. das Licht, dass mit Bewegungsmelder angeschaltet wird, wird nicht mehr ausgeschaltet. Innerhalb dieser 5 Minutenfrist, ist das System bzw. alles was mit Zigbee läuft, nicht mehr einsatzbereit. Auch hier der Port kann nicht gelockt werden
                          Fehler im Log:
                          2020-04-14 09:01:55.401  - error: zigbee.0 (1746) Error on send command to 0x680ae2fffe38cc37. Error: Error: Command 0x680ae2fffe38cc37/1 genOnOff.on({}, {"timeout":6000,"manufacturerCode":null,"disableDefaultResponse":false}) failed (Error: Data request failed with error: 'No network route' (205))
                              at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:339:23)
                              at Generator.throw (<anonymous>)
                              at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
                          Das System ist eine VM in Proxmox (habe aber zum Test auch einen Pi4 ausprobiert, mit eigenem cc2531, da ist es das Gleiche)
                          Ubuntu 16.04.6 LTS
                          RAM 3.86 GB
                          Node.js v10.20.0
                          NPM 6.14.4
                          Festplatte Größe 30.39 GB, Festplatte frei 27.16 GB
                          Aktive Instanzen 5
                          Sonst keine USB Sticks am Rechner
                          Ich habe auch schon mehrfach alles neu installiert. Jetzt sind nur die Adapter
                          admin.0 (3.7.8), javascript.0 (4.3.4) , mqtt.0 (2.1.1), web.0 (2.4.10) und zigbee.0 (1.0.4) installiert bzw. aktiv. Die kommen aus dem "default" repo, das "latest" habe ich auch schon probiert. MQTT läuft auf anderem Rechner
                          Folgendes habe ich schon probiert, leider erfolglos:
                          Suche im Forum und auhc sonst überall, leider keine wirkliche Lösung gefunden
                          cc2531 ab und anstecken, mit und ohne Rechner Neustart, mit und ohne Drücken auf Taster neben LED
                          Anderen cc2531 geflashed (CC2531_DEFAULT_20190608.zip - CC2531ZNP-Prod.hex) angesteckt. Dabei werden die bereits angelernten Zigbee Geräte erkannt (aus der DB?) und angezeigt in der Adapter Geräte Einstellung. Jedoch gleiche Fehlermeldungen "no network route"
                          Anlernen der bisherigen Geräte am "neuen" oder "neu geflasheten" Stick geht, aber nach kurzer Zeit gleiches Problem.
                          Reichweite ist kein Problem, ich habe 4 Router in Form von 2 Steckdosen und 2 Birnen von Ikea. Wenn die Networkmap mal etwas anzeigt, sind damit teilwiese auch Geräte verbunden. Jetzt gerade sind aber zuerst 2 Router (Glühbirnen) ausgefallen. Verstehen tue ich das jetzt nicht mehr,vielleicht kann mir jemand aus dem Forum einen Tip geben, wie ich das System stabil zum laufen bekomme?
                          liebe grüsse
                          nerd68N arteckA 2 Antworten Letzte Antwort
                          • C chrisweber
                            Hallo Zusammen,
                            Fehler im Log:
                            Ubuntu 16.04.6 LTS
                            RAM 3.86 GB
                            Node.js v10.20.0
                            NPM 6.14.4
                            Aktive Instanzen 5
                            liebe grüsse
                            nerd68N Offline
                            nerd68N Offline
                            nerd68
                            [GELÖST] @chrisweber @skylike Nachtrag: ich habe es jetzt wie folgt gelöst.
                            Adapter gelöscht
                            • Adapter 1.1.0 gelöscht
                            • im node-modules Verzeichnis zigbee-herdsman und zigbee-herdsman-converters gelöscht (warum die auch immer bei der Adapter Deinstallation nicht mit verschwunden sind...)
                            • cache Verzeichnis geleert
                            • Adapter v1.0.4 installiert
                            Seitdem läuft es bei mir wieder reibungslos. Ich musste zwar alle 40 Sensoren neu anlernen, aber das war das kleinere Übel 😉
                            HTH
                            VG,
                            Didier
                            Platform: linux
                            RAM: 7.6 GB
                            Node.js: v18.17.1
                            NPM: 9.6.7
                            • C chrisweber
                              Hallo Zusammen,
                              Fehler im Log:
                              Ubuntu 16.04.6 LTS
                              RAM 3.86 GB
                              Node.js v10.20.0
                              NPM 6.14.4
                              Aktive Instanzen 5
                              liebe grüsse
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @chrisweber sagte in Zigbee Adapter Failed to start:
                              ganz einfach ..schmeiss den cc2531 raus und nimm was ordentliches
                              C 1 Antwort Letzte Antwort
                              • hg6806H Offline
                                hg6806H Offline
                                hg6806
                                @arteck
                                Und das wäre?
                                Heute morgen ist mir der Pi4 abgestürzt. Keine Ahnung wieso. War auf jeden Fall weg.
                                Habe ihn dann aus und eingeschaltet. Ab jetzt läuft Zigbee auch nicht mehr. Also auch schon 2x Stick aus- und wieder angesteckt und Adapter neu gestartet.
                                Vielleicht sieht jemand was im Log:
                                host.raspberrypi	2020-04-17 09:17:42.991	error	Caught by controller[1]: (node:2822) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proce
                                host.raspberrypi	2020-04-17 09:17:42.991	error	Caught by controller[1]: (node:2822) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by r
                                host.raspberrypi	2020-04-17 09:17:42.991	error	Caught by controller[0]: at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7226:22)
                                host.raspberrypi	2020-04-17 09:17:42.990	error	Caught by controller[0]: at Zigbee.emit (events.js:198:13)
                                host.raspberrypi	2020-04-17 09:17:42.990	error	Caught by controller[0]: at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:320:41)
                                host.raspberrypi	2020-04-17 09:17:42.990	error	Caught by controller[0]: at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:303:20)
                                host.raspberrypi	2020-04-17 09:17:42.990	error	Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42)
                                host.raspberrypi	2020-04-17 09:17:42.990	error	Caught by controller[0]: at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43)
                                host.raspberrypi	2020-04-17 09:17:42.990	error	Caught by controller[0]: at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49)
                                host.raspberrypi	2020-04-17 09:17:42.990	error	Caught by controller[0]: at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:223:31)
                                host.raspberrypi	2020-04-17 09:17:42.989	error	Caught by controller[0]: at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:16)
                                host.raspberrypi	2020-04-17 09:17:42.989	error	Caught by controller[0]: at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55)
                                host.raspberrypi	2020-04-17 09:17:42.989	error	Caught by controller[0]: (node:2822) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'getEntries' of null
                                zigbee.0	2020-04-17 09:17:42.427	info	(2822) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                zigbee.0	2020-04-17 09:17:42.425	info	(2822) terminating
                                zigbee.0	2020-04-17 09:17:42.424	error	at process._tickCallback (internal/process/next_tick.js:68:7))
                                zigbee.0	2020-04-17 09:17:42.424	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:307:33)
                                zigbee.0	2020-04-17 09:17:42.424	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:174:16)
                                zigbee.0	2020-04-17 09:17:42.424	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
                                zigbee.0	2020-04-17 09:17:42.424	error	at new Promise (<anonymous>)
                                zigbee.0	2020-04-17 09:17:42.424	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
                                zigbee.0	2020-04-17 09:17:42.424	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-04-17 09:17:42.424	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:178:49)
                                zigbee.0	2020-04-17 09:17:42.424	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
                                zigbee.0	2020-04-17 09:17:42.424	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
                                zigbee.0	2020-04-17 09:17:42.424	error	(2822) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                                zigbee.0	2020-04-17 09:17:42.418	info	(2822) Zigbee: disabling joining new devices.
                                • arteckA arteck
                                  chrisweber
                                  @arteck
                                  na ja, ganz so einfach sheint es dann docxh nicht zu sein.
                                  Ich weiss zwar nicht, was Du unter "ordentlich" verstehst, aber ich habe einen
                                  ich habe bei dimaiv einen CC2538+CC2592 ZigBee Stick bestellt, und bin seiner Empfehlung gefogt:
                                  Was ich dir empfehlen kann
                                  wenn du neuen Stick bekommen hast:
                                  Reihenfolge wichtig!!!
                                  Stick noch nicht wechseln! Alle Geräte im Adapter löschen.
                                  Stick Im Adapter Hard Resetten. Stick entfernen.
                                  Instanz Zigbee löschen.
                                  Adapter deinstallieren.
                                  Ordner /opt/iobroker/iobroker-data/zigbee_0 löschen.
                                  Neue Stick verbinden.
                                  Aktuele Adapter installieren.
                                  COM-Port Einstellungen (Adapter) vornehmen (/dev/ttyACM0). Speichern und Schliessen.
                                  Alle Geräte neue pairen.
                                  Läuft seit 2 Tagen und heute morgen hat es begonnen, mit solchen Fehlermeldungen
                                  • error: zigbee.0 (2249) Error on send command to 0x00158d0001922b0b. Error: Error: Read 0x00158d0001922b0b/1 hvacThermostat([16392], {"timeout":6000,"manufacturerCode":4151,"disableDefaultResponse":true}) failed (Error: AREQ- AF - dataConfirm after 3000ms)
                                  Das sind Euronics Heizungsstellmotore. Diesen habe ich eben mit aktivem Pairen im ioBroker neu gestartet (Batterie aus und wieder eingelegt) der Startet auch sien "ins" verbinden und im iobroker sehe ich dass er sich selber gemeldet hat. Leider wir der und auch andere Geräte nicht mehr erreicht. In diesem Fall ist der Abstand sogar unter 100cm Stick zum Aktor.
                                  Gibt es noch andere Ideen, wie das zigbee stabil zu bekommen ist? Wäre für erfolgreichen Tipp sehr dankbar :)
                                  lg
                                  • C chrisweber
                                    @arteck
                                    lg
                                    chrisweber
                                    @chrisweber
                                    Bei mir läuft es jetzt seit 2 Tagen ganz stabil. Aber erst, seit ich auf "unstable" umgestellt habe und der zigbee Adapter von 1.0.4 auf 1.1.1 upgedated ist.
                                    Ich hoffe es bleibt dabei. lg
                                    • hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      Habe mit dem CC2531 als Koordinator auf 1.1.1 upgedated, gleiches Verhalten.
                                      Nach dem Host Neustart muss man immer erst den Stick ziehen und Adapter neu starten.
                                      Ist halt erst einmal eine Notlösung bis es hoffentlich mal einen Workaround gibt.
                                      Welche Sticks könnt ihr empfehlen? Für Koordinator und Router.
                                      Den CC2538 habe ich für schlanke 20,- bei Ali gesehen, jedoch mit Print-F Antenne.
                                      Ich brauche einen USB-Stick mit einer "richtigen" Antenne. Außer dem CC2531 kenne ich da leider nichts.
                                      • hg6806H hg6806
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @hg6806 erstmal schaust dir das video an... wenn du interessiert bist.. um zu verstehen wie Zigbee funktioniert
                                        cc2531 mit Antenne.. die bringt ja auch so viel.. egal...
                                        ansonsten Empfehlung
                                        https://forum.iobroker.net/topic/30609/cc2538-cc2592-pa-zigbee-stick-platine/91
                                        oder das Board cc26x2r kann ich dir auch empfehlen.. alles restliche steht im Forum
                                        • hg6806H Offline
                                          hg6806H Offline
                                          hg6806
                                          ok, welches Video?
