  4. Zigbee Adapter Failed to start
    6.4k
zigbee adapter cc2531
48 Beiträge 10 Kommentatoren 7.1k Aufrufe 12 Beobachtet
  • hg6806H hg6806
    ich hänge mich mal hier dran, denn mein Zigbee läuft an einem USB-Hub auch nur ganz selten.
    Hier das Debug-Log.
    Vielleicht kann ja jemand ein paar Tipps geben.
    zigbee.0	2020-04-07 20:32:06.553	error	(8457) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
    zigbee.0	2020-04-07 20:32:06.552	error	(8457) Failed to start Zigbee
    zigbee.0	2020-04-07 20:32:06.360	debug	(8457) Starting zigbee-herdsman...
    zigbee.0	2020-04-07 20:32:06.360	info	(8457) Starting Zigbee...
    zigbee.0	2020-04-07 20:32:06.359	info	(8457) Try to reconnect. 1 attempts left
    zigbee.0	2020-04-07 20:31:56.356	error	(8457) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
    zigbee.0	2020-04-07 20:31:56.355	error	(8457) Failed to start Zigbee
    zigbee.0	2020-04-07 20:31:49.037	debug	(8457) Starting zigbee-herdsman...
    zigbee.0	2020-04-07 20:31:49.036	info	(8457) Starting Zigbee...
    zigbee.0	2020-04-07 20:31:48.999	info	(8457) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
    zigbee.0	2020-04-07 20:31:42.743	info	(7714) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0	2020-04-07 20:31:42.741	info	(7714) terminating
    zigbee.0	2020-04-07 20:31:42.740	error	at process._tickCallback (internal/process/next_tick.js:68:7))
    zigbee.0	2020-04-07 20:31:42.740	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
    zigbee.0	2020-04-07 20:31:42.740	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
    zigbee.0	2020-04-07 20:31:42.740	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
    zigbee.0	2020-04-07 20:31:42.740	error	at new Promise (<anonymous>)
    zigbee.0	2020-04-07 20:31:42.740	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
    zigbee.0	2020-04-07 20:31:42.740	error	at Generator.next (<anonymous>)
    zigbee.0	2020-04-07 20:31:42.740	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
    zigbee.0	2020-04-07 20:31:42.740	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
    zigbee.0	2020-04-07 20:31:42.740	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
    zigbee.0	2020-04-07 20:31:42.740	error	(7714) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-04-07 20:31:42.730	info	(7714) Zigbee: disabling joining new devices.
    zigbee.0	2020-04-07 20:31:42.724	info	(7714) cleaned everything up...
    zigbee.0	2020-04-07 20:31:42.721	info	(7714) Got terminate signal TERMINATE_YOURSELF
    arteckA Offline
    arteckA Offline
    arteck
    @hg6806 sagte in Zigbee Adapter Failed to start:
    • hg6806H Offline
      hg6806H Offline
      hg6806
      OK, was heißt das? Er kann den Stick nicht finden?
      • hg6806H hg6806
        arteckA Offline
        arteckA Offline
        arteck
        @hg6806 der seriall port ist besetzt.. starte mal die kiste neu .. was läuft da sonst noch druff?
        hg6806H 1 Antwort Letzte Antwort
        • arteckA arteck
          hg6806H Offline
          hg6806H Offline
          hg6806
          @arteck
          COM Ports? Ich kenne das unter Windows, diese sind oft blockiert, kann man aber irgdndwie "freischaufeln".
          Habe den Pi4 mal neu gestartet, wirft aber den gleichen Fehler aus.
          An dem Pi hängen 2 IR-Smartmeter, eine USB3-SSD und ein 4-fach-USB-Hub woran dann ein BLE5.0 Stick und der CC2531 Zigbee Stick dran ist.
          • hg6806H hg6806
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            BLE5.0 Stick
            der blockiert den
            aber zeigmal
            ls -l /dev/serial/by-id
            • hg6806H Offline
              hg6806H Offline
              hg6806
              Here it is:
              root@raspberrypi:~# ls -l /dev/serial/by-id
              insgesamt 0
              lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridg            e_Controller_01304FAA-if00-port0 -> ../../ttyUSB1
              lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridg            e_Controller_01304FAE-if00-port0 -> ../../ttyUSB0
              lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Texas_Instruments_TI_CC2531_USB_CDC__            _0X00124B00194AD7E3-if00 -> ../../ttyACM0
              root@raspberrypi:~#
              • hg6806H hg6806
                Here it is:
                insgesamt 0
                root@raspberrypi:~#
                arteckA Offline
                arteckA Offline
                arteck
                @hg6806 wo ist der BLE??
                • hg6806H Offline
                  hg6806H Offline
                  hg6806
                  Das frage ich mich auch. Zumindest ist der BLE Adapter grün und zwei BLE Sensoren liefern aktuelle Daten.
                  • hg6806H Offline
                    hg6806H Offline
                    hg6806
                    Bin leider noch nicht weitergekommen.
                    Folgendes habe ich probiert:
                    root@raspberrypi:~# hciconfig
                    hci1:   Type: Primary  Bus: UART
                            BD Address: DC:A6:32:0A:73:B3  ACL MTU: 1021:8  SCO MTU: 64:1
                            UP RUNNING
                            RX bytes:8525625 acl:0 sco:0 events:234932 errors:0
                            TX bytes:1374 acl:0 sco:0 commands:59 errors:0
                    hci0:   Type: Primary  Bus: USB
                            BD Address: 00:1A:7D:DA:71:11  ACL MTU: 679:9  SCO MTU: 48:16
                            DOWN
                            RX bytes:1148 acl:0 sco:0 events:60 errors:0
                            TX bytes:736 acl:0 sco:0 commands:60 errors:0
                    root@raspberrypi:~# lsusb
                    Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s bridge
                    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                    Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                    Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                    Bus 001 Device 007: ID 0451:16a8 Texas Instruments, Inc.
                    Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
                    Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub
                    Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                    root@raspberrypi:~# bluetoothctl
                    Agent registered
                    [bluetooth]# scan on
                    Discovery started
                    [CHG] Controller DC:A6:32:0A:73:B3 Discovering: yes
                    [NEW] Device E7:2E:00:D3:20:42 LYWSD02
                    Dann den BLE Stick entfernt, BLE Adapter gestoppt und den Pi neu gestartet.
                    Zigbee bleibt gelb, Debug-Log:
                    zigbee.0	2020-04-12 10:12:53.178	error	(2063) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
                    zigbee.0	2020-04-12 10:12:53.176	error	(2063) Failed to start Zigbee
                    zigbee.0	2020-04-12 10:12:52.979	debug	(2063) Starting zigbee-herdsman...
                    zigbee.0	2020-04-12 10:12:52.979	info	(2063) Starting Zigbee...
                    zigbee.0	2020-04-12 10:12:52.978	info	(2063) Try to reconnect. 1 attempts left
                    zigbee.0	2020-04-12 10:12:42.977	error	(2063) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
                    zigbee.0	2020-04-12 10:12:42.974	error	(2063) Failed to start Zigbee
                    zigbee.0	2020-04-12 10:12:35.663	debug	(2063) Starting zigbee-herdsman...
                    zigbee.0	2020-04-12 10:12:35.661	info	(2063) Starting Zigbee...
                    zigbee.0	2020-04-12 10:12:35.627	info	(2063) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
                    zigbee.0	2020-04-12 10:12:13.440	info	(1823) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    zigbee.0	2020-04-12 10:12:13.439	info	(1823) terminating
                    zigbee.0	2020-04-12 10:12:13.438	error	at process._tickCallback (internal/process/next_tick.js:68:7))
                    zigbee.0	2020-04-12 10:12:13.438	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
                    zigbee.0	2020-04-12 10:12:13.438	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
                    zigbee.0	2020-04-12 10:12:13.438	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
                    zigbee.0	2020-04-12 10:12:13.438	error	at new Promise (<anonymous>)
                    zigbee.0	2020-04-12 10:12:13.438	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
                    zigbee.0	2020-04-12 10:12:13.438	error	at Generator.next (<anonymous>)
                    zigbee.0	2020-04-12 10:12:13.438	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
                    zigbee.0	2020-04-12 10:12:13.438	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
                    zigbee.0	2020-04-12 10:12:13.438	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
                    zigbee.0	2020-04-12 10:12:13.438	error	(1823) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                    zigbee.0	2020-04-12 10:12:13.434	info	(1823) Zigbee: disabling joining new devices.
                    zigbee.0	2020-04-12 10:12:13.417	info	(1823) cleaned everything up...
                    zigbee.0	2020-04-12 10:12:13.415	info	(1823) Got terminate signal TERMINATE_YOURSELF
                    Hier noch weitere Konsolenbefehle:
                    insgesamt 0
                    lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAA-if00-port0 -> ../../ttyUSB1
                    lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAE-if00-port0 -> ../../ttyUSB0
                    lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194AD7E3-if00 -> ../../ttyACM0
                    Bus 001 Device 005: ID 0451:16a8 Texas Instruments, Inc.
                    root@raspberrypi:~#
                    Was kann ich noch tun?
                    • mickymM Offline
                      mickymM Offline
                      mickym
                      Ich glaube - dass wir das gleiche Problem haben: https://forum.iobroker.net/topic/32137/zigbee-cc2531-stick-beim-hochfahren-des-adapters-disabled
                      Allerdings passiert es nicht immer, wenn auch mit der neuen Version gefühlt häufiger.
                      Bei mir läuft der Adapter jedoch IMMER, wenn ich den Stick im laufenden Betrieb einfach abziehe, dann wieder anstecke und NUR den Adapter neu starte.
                        toki1973
                        @mickym Danke für deine Rückmeldung im anderen Thread. Inzwischen ist der Status wieder grün. Allerdings bekomme ich keine Werte mehr von den Sensoren.
                        NUC, PROXMOX, Grafana, Influx, Unify
                        • T toki1973
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @toki1973 Hmm - bei mir funktionieren die Sensoren, es ist alles Bestens. Ist denn bei Dir der Adapter alleine auf grün gegangen oder hast Du wie ich mal den Stick abgezogen und wieder angesteckt und dann den Adapter neu gestartet?
                          • hg6806H Offline
                            hg6806H Offline
                            hg6806
                            @mickym So läuft es! Danke!
                            Also immer erst Stick neu anstecken und Adapter neu starten. Dann wird es grün.
                            Auch zusammen mit dem BLE.
                            Wenn man aber den Pi neu startet bleibt Zigbee gelb.
                            Ich habe das mit BLE mal ausprobiert, der BRAUCHT unbedingt ein Pi Neustart.
                            Die Frage ist wie kann man das fixen?
                            Kann man den Zigbee Stick oder den ganzen USB Bus resetten?
                            • hg6806H Offline
                              hg6806H Offline
                              hg6806
                              schrieb am zuletzt editiert von hg6806
                              Hier gibt es wohl die Möglichkeit:
                              Eine Datei usbreset erstellen und dann aufrufen
                              Link Text
                              Hab's noch nicht ausprobiert und hoffe es heute Abend mal zu schaffen.
                              • hg6806H hg6806
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @hg6806 said in Zigbee Adapter Failed to start:
                                Meines Erachtens wird der Zigbee-Stick ja beim Adapterstart resettet und das ist aber das Problem. Wenn ich die Maschine neu boote wird der Stick resettet und die LED leuchtet. Startet der Adapter geht die LED auf dem Stick aus und dann scheint es bei mir Glücksache zu sein, ob der Adapter den wieder findet oder einen Time-Out bekommt. Jedenfalls geht die LED im Fehlerfall nicht mehr an, bis ich den Adapter physisch neu verbinde.
                                • hg6806H Offline
                                  hg6806H Offline
                                  hg6806
                                  Ja, so ist es wohl.
                                  Habe mal usbreset nach der Anleitung erstellt und ausgeführt.
                                  Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s brid        ge
                                  Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (        HCI mode)
                                  root@raspberrypi:~# usbreset /dev/bus/usb/001/007
                                  Resetting USB device /dev/bus/usb/001/007
                                  Reset successful
                                  Stick wurde resettet aber zeigt nach Adapter-Neustart doch noch immer gelb an.
                                    toki1973
                                    Nach entfernen des USB Sticks und Neustart der VM auf dem NUC habe ich zumindest wieder die Instanz grün. Aber die Aktualität der Sensoren wurde nur beim Neustart aktualisiert.
                                    @arteck Wie kann ich denn den Fehler eingrenzen?
                                    Ein direktes ansprechen der Adapter über die Erweiterten Einstellungen hat auch keine Antwort von einem Sensor gebracht.
                                    • T toki1973
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @toki1973
                                      Nicht die VM neu starten. Nur Stick rausziehen und wieder rein und die Adapterinstanz Neustarten, nicht die ganze Maschine
                                      • nerd68N Offline
                                        nerd68N Offline
                                        nerd68
                                        schrieb am zuletzt editiert von nerd68
                                        ich stoß mal ins gleiche Horn.
                                        • ich habe meinen cc2531 auf die aktuelle Firmware geflasht.
                                        • Neustart, Adapter gelb.
                                        • Adapter auf 1.1.0 geupdated.
                                        • selber Fehler, Adpater bleibt gelb.
                                        • Adapter neu installiert, selber Fehler Adapter bleibt gelb.
                                        Z-Stack ist sauber geflasht, wir und Serial Belegung zeigt:
                                        drwxr-xr-x 2 root root 60 Apr 13 19:05 .
                                        drwxr-xr-x 4 root root 80 Apr 13 19:05 ..
                                        lrwxrwxrwx 1 root root 13 Apr 13 19:05 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019387353-if00 -> ../../ttyACM0
                                        • keine weiteren USB Geräte angeschlossen, kann also kein Konflikt sein, dass der Port nicht frei ist.
                                        Fehlercode:
                                        zigbee.0	2020-04-13 19:05:48.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                                        zigbee.0	2020-04-13 19:05:48.110	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                                        zigbee.0	2020-04-13 19:05:48.110	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                                        zigbee.0	2020-04-13 19:05:48.110	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                                        zigbee.0	2020-04-13 19:05:48.110	error	at new Promise (<anonymous>)
                                        zigbee.0	2020-04-13 19:05:48.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                                        zigbee.0	2020-04-13 19:05:48.110	error	at Generator.next (<anonymous>)
                                        zigbee.0	2020-04-13 19:05:48.110	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                                        zigbee.0	2020-04-13 19:05:48.110	error	(2581) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                                        zigbee.0	2020-04-13 19:05:48.109	error	(2581) Failed to start Zigbee
                                        zigbee.0	2020-04-13 19:05:47.714	info	(2581) Starting Zigbee...
                                        zigbee.0	2020-04-13 19:05:47.711	info	(2581) Try to reconnect. 1 attempts left
                                        zigbee.0	2020-04-13 19:05:37.707	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:5:58)
                                        zigbee.0	2020-04-13 19:05:37.707	error	at Generator.next (<anonymous>)
                                        zigbee.0	2020-04-13 19:05:37.707	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:246:27)
                                        zigbee.0	2020-04-13 19:05:37.707	error	(2581) Error: SREQ '--> SYS - osalNvRead - {"id":3840,"offset":0,"len":1,"value":{"type":"Buffer","data":[85]}}' failed with status '2' (expected '0')
                                        zigbee.0	2020-04-13 19:05:37.705	error	(2581) Failed to start Zigbee
                                        zigbee.0	2020-04-13 19:05:35.981	info	(2581) Starting Zigbee...
                                        zigbee.0	2020-04-13 19:05:35.941	info	(2581) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                                        BTW lief vorher komplett und reibungslos.
                                        Das mit dem rein raus und Instanz Neustart hat nichts gebracht.
                                        Vielleicht hat jemand noch einen Tipp.
                                        VG,
                                        Didier
                                        Ubuntu 18.04 LTS
                                        NUC Celeron 8GB, 500GB SSD
                                        Node.js v12.16.2
                                        NPM v6.14.4
                                        Platform: linux
                                        operating system: ubuntu 23.04 LTS
                                        RAM: 7.6 GB
                                        Node.js: v18.17.1
                                        NPM: 9.6.7
                                        • C Offline
                                          chrisweber
                                          Hallo Zusammen,
                                          ich habe seit einiger Zeit ähnliche Probleme mit zigbee und komme einfach nicht weiter.
                                          Mein Stick cc2531 arbeitet nach kurzer Zeit ( 1 Tag bis max. 1 Woche) nicht mehr.
                                          Das Log zeigt dann Fehler an. Dieser Zustand ändert sich plötzlich, ohne dass am System irgendetwas verändert wird. Z.B. das Licht, dass mit Bewegungsmelder angeschaltet wird, wird nicht mehr ausgeschaltet. Innerhalb dieser 5 Minutenfrist, ist das System bzw. alles was mit Zigbee läuft, nicht mehr einsatzbereit. Auch hier der Port kann nicht gelockt werden
                                          Fehler im Log:
                                          2020-04-14 09:01:55.401  - error: zigbee.0 (1746) Error on send command to 0x680ae2fffe38cc37. Error: Error: Command 0x680ae2fffe38cc37/1 genOnOff.on({}, {"timeout":6000,"manufacturerCode":null,"disableDefaultResponse":false}) failed (Error: Data request failed with error: 'No network route' (205))
                                              at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:339:23)
                                              at Generator.throw (<anonymous>)
                                              at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
                                          Das System ist eine VM in Proxmox (habe aber zum Test auch einen Pi4 ausprobiert, mit eigenem cc2531, da ist es das Gleiche)
                                          Ubuntu 16.04.6 LTS
                                          RAM 3.86 GB
                                          Node.js v10.20.0
                                          NPM 6.14.4
                                          Festplatte Größe 30.39 GB, Festplatte frei 27.16 GB
                                          Aktive Instanzen 5
                                          Sonst keine USB Sticks am Rechner
                                          Ich habe auch schon mehrfach alles neu installiert. Jetzt sind nur die Adapter
                                          admin.0 (3.7.8), javascript.0 (4.3.4) , mqtt.0 (2.1.1), web.0 (2.4.10) und zigbee.0 (1.0.4) installiert bzw. aktiv. Die kommen aus dem "default" repo, das "latest" habe ich auch schon probiert. MQTT läuft auf anderem Rechner
                                          Folgendes habe ich schon probiert, leider erfolglos:
                                          Suche im Forum und auhc sonst überall, leider keine wirkliche Lösung gefunden
                                          cc2531 ab und anstecken, mit und ohne Rechner Neustart, mit und ohne Drücken auf Taster neben LED
                                          Anderen cc2531 geflashed (CC2531_DEFAULT_20190608.zip - CC2531ZNP-Prod.hex) angesteckt. Dabei werden die bereits angelernten Zigbee Geräte erkannt (aus der DB?) und angezeigt in der Adapter Geräte Einstellung. Jedoch gleiche Fehlermeldungen "no network route"
                                          Anlernen der bisherigen Geräte am "neuen" oder "neu geflasheten" Stick geht, aber nach kurzer Zeit gleiches Problem.
                                          Reichweite ist kein Problem, ich habe 4 Router in Form von 2 Steckdosen und 2 Birnen von Ikea. Wenn die Networkmap mal etwas anzeigt, sind damit teilwiese auch Geräte verbunden. Jetzt gerade sind aber zuerst 2 Router (Glühbirnen) ausgefallen. Verstehen tue ich das jetzt nicht mehr,vielleicht kann mir jemand aus dem Forum einen Tip geben, wie ich das System stabil zum laufen bekomme?
                                          liebe grüsse
                                          nerd68N arteckA 2 Antworten Letzte Antwort
