  4. [Gelöst] Fehlermeldungen in Log-Datei
errorerror im logerror logerrorproblemproblem
28 Beiträge 4 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    Was kommt bei
    iobroker -v
    • M megaron
      Hallo wendy2702,
      anbei der Log Auszug.
      host.raspberrypi
      2020-04-08 07:45:44.563
      info
      Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      host.raspberrypi
      2020-04-08 07:45:42.973
      info
      Restart adapter system.adapter.info.0 because enabled
      host.raspberrypi
      info
      instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi
      error
      Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.raspberrypi
      error
      Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:103452)
      host.raspberrypi
      error
      Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
      host.raspberrypi
      error
      Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
      host.raspberrypi
      error
      Caught by controller[0]: at Array.forEach (<anonymous>)
      host.raspberrypi
      2020-04-08 07:45:42.972
      error
      Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
      host.raspberrypi
      error
      host.raspberrypi
      error
      Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
      host.raspberrypi
      error
      Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
      host.raspberrypi
      error
      Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
      host.raspberrypi
      2020-04-08 07:45:42.971
      error
      Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      info.0
      2020-04-08 07:45:42.453
      info
      (21262) Terminated (NO_ERROR): Without reason
      info.0
      2020-04-08 07:45:42.452
      info
      (21262) terminating
      info.0
      2020-04-08 07:45:42.441
      info
      (21262) Reading process data every 120 seconds.
      info.0
      2020-04-08 07:45:42.414
      info
      (21262) cleaned everything up...
      info.0
      2020-04-08 07:45:42.413
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      (21262) TypeError: Cannot read property 'split' of undefined
      info.0
      2020-04-08 07:45:42.412
      error
      (21262) uncaught exception: Cannot read property 'split' of undefined
      info.0
      2020-04-08 07:45:42.302
      info
      (21262) Popup news was read...
      info.0
      2020-04-08 07:45:42.165
      info
      (21262) Reading CPU temp data every 60 seconds.
      info.0
      2020-04-08 07:45:42.162
      info
      (21262) Reading battery data every 120 seconds.
      info.0
      2020-04-08 07:45:42.061
      info
      (21262) Reading user data every 120 seconds.
      info.0
      2020-04-08 07:45:41.889
      info
      (21262) Reading memory data every 60 seconds.
      info.0
      2020-04-08 07:45:41.785
      info
      (21262) Reading disk data every 120 seconds.
      info.0
      2020-04-08 07:45:41.642
      info
      (21262) Reading CPU data every 60 seconds.
      info.0
      2020-04-08 07:45:41.619
      info
      (21262) Reading CPU current speed every 60 seconds.
      info.0
      2020-04-08 07:45:40.990
      info
      (21262) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.19.0
      megaron
      @megaron
      Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l
      permitted by applicable law.
      Last login: Wed Apr  8 18:29:29 2020 from 192.168.178.37
      pi@raspberrypi:~ $ Iobroker -v
      -bash: Iobroker: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      Viele Grüße megaron
      • M megaron
        @megaron
        pi@raspberrypi:~ $
        wendy2702W Online
        wendy2702W Online
        @megaron kleines „i“ bei iobroker.
        Habe es oben korrigiert
        • wendy2702W wendy2702
          megaron
          @wendy2702
          2.2.9
          Viele Grüße megaron
          • M megaron
            Richtig. Fehler tritt nur im aktivierten Zustand auf. (Ampel ist zudem auf rot)
            Node.js: v10.19.0
            Info.: 1.5.6 (aktuell)
            wendy2702W Online
            wendy2702W Online
            @megaron sagte in Fehlermeldungen in Log-Datei:
            Node.js: v10.19.0
            Also hast du schon die neueste JS Controller Version.
            Woher hast du dann die 1.5.6 ?
              Node.js: v10.19.0
              megaron
              schrieb am zuletzt editiert von megaron
              @wendy2702
              1.5.6 ist die Version des Info Adapters (Information tab)
              Viele Grüße megaron
              • wendy2702W Online
                wendy2702W Online
                Also dann mal schauen ob hier etwas für doch dabei ist:
                Such Ergebnisse
                Oder mal auf Version 1.5.7 upgraden (ist im Latest)
                Oder Instanz und Adapter löschen und neu installieren.
                Wäre das was ich machen würde.
                  Such Ergebnisse
                  megaron
                  @wendy2702
                  Hab die Instanz gelöscht. Muss ich den Adapter auch löschen? Und wie komme ich an die latest 1.5.7. ?
                  Auf IoBroker.info hab ich die 1.6.0 gefunden.
                  Viele Grüße megaron
                  • wendy2702W Online
                    wendy2702W Online
                    Mir wird bei einstellen von "Latest" als Verwahrungsort die 1.5.7 angeboten.
                    1.6.0 kann man wahrscheinlich direkt aus Github installieren.
                      megaron
                      @wendy2702
                      Wo kann man denn latest einstellen. Sorry vielleicht für die blöde Frage aber ich hab den IoBroker erst ist seit einer Woche und von Linux habe ich noch weniger Ahnung.
                      Hab jetzt die 1.6.0 drauf. Gleiche Fehlermeldungen:
                      host.raspberrypi	2020-04-08 19:24:56.118	info	Restart adapter system.adapter.info.0 because enabled
                      host.raspberrypi	2020-04-08 19:24:56.118	info	instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                      host.raspberrypi	2020-04-08 19:24:56.118	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:103452)
                      host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
                      host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
                      host.raspberrypi	2020-04-08 19:24:56.116	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                      host.raspberrypi	2020-04-08 19:24:56.116	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
                      host.raspberrypi	2020-04-08 19:24:56.115	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
                      host.raspberrypi	2020-04-08 19:24:56.115	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
                      host.raspberrypi	2020-04-08 19:24:56.114	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
                      host.raspberrypi	2020-04-08 19:24:56.111	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
                      info.0	2020-04-08 19:24:55.579	info	(23189) Terminated (NO_ERROR): Without reason
                      info.0	2020-04-08 19:24:55.578	info	(23189) terminating
                      info.0	2020-04-08 19:24:55.531	info	(23189) cleaned everything up...
                      info.0	2020-04-08 19:24:55.530	error	(23189) TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23) at checkConditions (/opt/iobroker/node_modules/iobroker.i
                      info.0	2020-04-08 19:24:55.529	error	(23189) uncaught exception: Cannot read property 'split' of undefined
                      info.0	2020-04-08 19:24:55.407	info	(23189) Popup news was read...
                      info.0	2020-04-08 19:24:53.538	info	(23189) starting. Version 1.6.0 in /opt/iobroker/node
                      Viele Grüße megaron
                      • wendy2702W Online
                        wendy2702W Online
                        OK.
                        Dann hast du wohl auch noch nicht viel eingerichtet, oder?
                        Wie hast du den PI installiert? Image oder Manuell?
                        Wenn manuell, welche SW ?
                        Debian oder was?
                          OK.
                          Debian oder was?
                          megaron
                          @wendy2702
                          Hallo, die Installation ist über Image erfolgt.
                          „IoBroker Image für Raspberry Pi2/3/4 Buster 20191127“ Von der IoBroker.net page.
                          Ca. 10 Adapter eingerichtet.
                          Viele Grüße megaron
                          • wendy2702W Online
                            wendy2702W Online
                            Mach ein Backup.
                            Installiere ein leeres Debian Buster auf der SD Karte und Installiere ioBroker selber.
                            Richte entweder deine Adapter neu ein oder stelle das Backup wieder her.
                            Ich denke dann hast du alle Probleme erschlagen und hast eine saubere installation.
                            So zumindest würde ich es machen.
                            • M megaron
                              @wendy2702
                              crunchipC Offline
                              crunchipC Offline
                              @megaron du hast den neuen js-controller schon, aber noch den alten admin.
                                megaron
                                @crunchip : was konkret meinst du mit einem alten Admin?
                                Viele Grüße megaron
                                • M megaron
                                  @wendy2702
                                  Hab gerade ein IoBroker Update/Upgrade gemacht. Js.controller ist aktuell (2.2.9). Problem ist weiterhin vorhanden. Hier auch noch das Protokoll.
                                  Last login: Wed Apr  8 10:50:38 2020 from 192.168.178.34
                                  pi@raspberrypi:~ $ cd /opt/iobroker
                                  pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
                                  pi@raspberrypi:/opt/iobroker $ sudo iobroker update
                                  Used repository: default
                                  hash unchanged, use cached sources
                                  update done
                                  Adapter    "admin"         : 3.7.8    , installed 3.7.8
                                  Adapter    "alexa2"        : 3.0.5
                                  Adapter    "alpha2"        : 1.0.0
                                  Adapter    "amazon-dash"   : 1.1.0
                                  Adapter    "artnet"        : 1.0.0
                                  Adapter    "asterisk"      : 1.0.6
                                  Adapter    "asuswrt"       : 1.0.1
                                  Adapter    "b-control-em"  : 0.2.1
                                  Adapter    "backitup"      : 1.4.5    , installed 1.4.5
                                  Adapter    "beckhoff"      : 1.2.0
                                  Adapter    "benq"          : 0.2.0
                                  Adapter    "ble"           : 0.10.1
                                  Adapter    "bmw"           : 1.3.3    , installed 1.3.3
                                  Adapter    "bosesoundtouch": 0.2.4
                                  Adapter    "botvac"        : 1.0.0
                                  Adapter    "bring"         : 1.7.1
                                  Adapter    "broadlink2"    : 2.0.2
                                  Adapter    "bsblan"        : 0.0.6
                                  Adapter    "bshb"          : 0.1.8
                                  Adapter    "chromecast"    : 2.3.1
                                  Adapter    "cloud"         : 3.0.2    , installed 3.0.2
                                  Adapter    "comfoair"      : 0.3.2
                                  Adapter    "contactid"     : 1.0.0
                                  Adapter    "coronavirus-statistics": 0.5.5
                                  Adapter    "countdown"     : 1.1.0
                                  Adapter    "cul"           : 1.2.1
                                  Adapter    "daikin"        : 1.0.5
                                  Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                                  Adapter    "deconz"        : 1.2.6
                                  Adapter    "denon"         : 1.7.2    , installed 1.7.2
                                  Adapter    "digitalstrom"  : 0.5.5
                                  Adapter    "discovergy"    : 0.5.0
                                  Adapter    "discovery"     : 2.2.2    , installed 2.2.2
                                  Adapter    "ds18b20"       : 1.1.4
                                  Adapter    "dwd"           : 2.4.6
                                  Adapter    "ebus"          : 1.0.0
                                  Adapter    "egigeozone"    : 0.1.2
                                  Adapter    "ekey"          : 1.1.0
                                  Adapter    "email"         : 1.0.6
                                  Adapter    "emby"          : 1.0.2
                                  Adapter    "energymanager" : 1.2.2
                                  Adapter    "enet"          : 1.0.1
                                  Adapter    "epson_stylus_px830": 0.2.1
                                  Adapter    "fakeroku"      : 0.2.1
                                  Adapter    "fb-checkpresence": 0.3.0   , installed 0.3.0
                                  Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                                  Adapter    "fhem"          : 1.3.0
                                  Adapter    "find-my-iphone": 0.2.15
                                  Adapter    "firetv"        : 0.0.27
                                  Adapter    "flot"          : 1.9.2    , installed 1.9.2
                                  Adapter    "foobar2000"    : 1.0.0
                                  Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
                                  Adapter    "fritzdect"     : 0.2.4    , installed 0.2.4
                                  Adapter    "fronius"       : 1.0.5
                                  Adapter    "fullcalendar"  : 1.1.0
                                  Adapter    "fullybrowser"  : 1.0.0
                                  Adapter    "g-homa"        : 0.5.1
                                  Adapter    "geofency"      : 0.3.2
                                  Adapter    "gruenbeck"     : 0.0.18
                                  Adapter    "habpanel"      : 0.3.4
                                  Adapter    "haier"         : 1.0.2
                                  Adapter    "ham"           : 1.1.2
                                  Adapter    "ham-wemo"      : 1.0.1
                                  Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                                  Adapter    "heatingcontrol": 0.3.19
                                  Adapter    "heytech"       : 0.2.0
                                  Adapter    "hid"           : 0.1.17
                                  Adapter    "history"       : 1.8.7    , installed 1.8.7
                                  Adapter    "hm-rega"       : 2.5.5    , installed 2.5.5
                                  Adapter    "hm-rpc"        : 1.12.10  , installed 1.12.10
                                  Adapter    "hmip"          : 0.0.11
                                  Adapter    "homeconnect"   : 0.0.26
                                  Adapter    "homee"         : 0.3.1
                                  Adapter    "homepilot"     : 1.0.3
                                  Adapter    "hp-ilo"        : 1.0.5
                                  Adapter    "hs100"         : 1.0.10
                                  Adapter    "hue"           : 3.2.3
                                  Adapter    "hue-extended"  : 1.2.3
                                  Adapter    "ical"          : 1.7.0    , installed 1.7.0
                                  Adapter    "icons-addictive-flavour-png": 0.1.0
                                  Adapter    "icons-fatcow-hosting": 0.1.0
                                  Adapter    "icons-icons8"  : 0.0.1
                                  Adapter    "icons-material-png": 0.1.0
                                  Adapter    "icons-material-svg": 0.1.0
                                  Adapter    "icons-mfd-png" : 1.0.2
                                  Adapter    "icons-mfd-svg" : 1.0.2
                                  Adapter    "icons-open-icon-library-png": 0.1.2
                                  Adapter    "icons-ultimate-png": 1.0.1
                                  Adapter    "influxdb"      : 1.7.0
                                  Adapter    "info"          : 1.5.6    , installed 1.5.6
                                  Adapter    "innogy-smarthome": 0.3.3
                                  Adapter    "iogo"          : 0.5.7
                                  Adapter    "iot"           : 1.1.8
                                  Adapter    "iqontrol"      : 0.2.16
                                  Adapter    "javascript"    : 4.3.4    , installed 4.3.4
                                  Adapter    "jeelink"       : 0.1.0
                                  Controller "js-controller" : 2.2.9    , installed 2.2.9
                                  Adapter    "kecontact"     : 0.1.0
                                  Adapter    "klf200"        : 0.9.5
                                  Adapter    "km200"         : 1.1.6
                                  Adapter    "knmi-weather"  : 0.2.0
                                  Adapter    "knx"           : 1.0.39   , installed 1.0.39
                                  Adapter    "kodi"          : 1.0.0
                                  Adapter    "kress"         : 2.5.5
                                  Adapter    "lametric"      : 0.0.7
                                  Adapter    "landroid"      : 1.0.3
                                  Adapter    "lcn"           : 0.3.2
                                  Adapter    "lgtv"          : 1.1.5
                                  Adapter    "lgtv-rs"       : 0.0.4
                                  Adapter    "lgtv11"        : 1.0.5
                                  Adapter    "lifx"          : 0.1.0
                                  Adapter    "lightify"      : 0.2.16
                                  Adapter    "link"          : 0.5.9
                                  Adapter    "linkeddevices" : 1.1.1
                                  Adapter    "lovelace"      : 0.2.3
                                  Adapter    "loxone"        : 1.0.0
                                  Adapter    "luftdaten"     : 0.0.11
                                  Adapter    "lupusec"       : 1.2.3
                                  Adapter    "luxtronik1"    : 0.2.2
                                  Adapter    "material"      : 0.12.1
                                  Adapter    "maxcube"       : 0.1.2
                                  Adapter    "maxcul"        : 1.1.2
                                  Adapter    "mbus"          : 2.1.4
                                  Adapter    "megad"         : 1.2.1
                                  Adapter    "megadd"        : 0.2.0
                                  Adapter    "megaesp"       : 0.1.0
                                  Adapter    "mercedesme"    : 0.0.21
                                  Adapter    "mercury"       : 0.1.0
                                  Adapter    "meross"        : 1.3.11
                                  Adapter    "meteoalarm"    : 1.0.9
                                  Adapter    "miele"         : 0.1.5
                                  Adapter    "mielecloudservice": 1.1.0
                                  Adapter    "mihome"        : 1.3.0    , installed 1.3.0
                                  Adapter    "mihome-lamp"   : 1.1.0
                                  Adapter    "mihome-plug"   : 0.2.0
                                  Adapter    "mihome-vacuum" : 1.1.5    , installed 1.1.5
                                  Adapter    "mikrotik"      : 1.0.11
                                  Adapter    "milight"       : 0.3.6
                                  Adapter    "milight-smart-light": 0.2.7
                                  Adapter    "mobile"        : 0.5.0    , installed 0.5.0
                                  Adapter    "modbus"        : 3.0.0
                                  Adapter    "moma"          : 1.2.3
                                  Adapter    "mpd"           : 1.0.0
                                  Adapter    "mqtt"          : 2.1.1
                                  Adapter    "mqtt-client"   : 1.3.1
                                  Adapter    "musiccast"     : 0.1.3
                                  Adapter    "mysensors"     : 2.0.0
                                  Adapter    "nanoleaf-lightpanels": 0.8.1
                                  Adapter    "nello"         : 2.0.6
                                  Adapter    "netatmo"       : 1.3.1    , installed 1.3.1
                                  Adapter    "nibeuplink"    : 0.3.0
                                  Adapter    "nina"          : 0.0.22
                                  Adapter    "node-red"      : 1.13.0
                                  Adapter    "nuki"          : 1.2.0
                                  Adapter    "nuki-extended" : 2.2.5
                                  Adapter    "nut"           : 1.1.3
                                  Adapter    "odl"           : 1.0.5
                                  Adapter    "oilfox"        : 0.0.5
                                  Adapter    "onkyo"         : 2.0.3
                                  Adapter    "onvif"         : 0.0.2
                                  Adapter    "openhab"       : 1.1.0
                                  Adapter    "openligadb"    : 1.0.0
                                  Adapter    "openweathermap": 0.1.0
                                  Adapter    "opi"           : 0.1.1
                                  Adapter    "oppoplayer"    : 0.2.1
                                  Adapter    "owfs"          : 0.6.4
                                  Adapter    "owntracks"     : 0.6.2
                                  Adapter    "panasonic-viera": 1.0.2
                                  Adapter    "parser"        : 1.0.7
                                  Adapter    "paw"           : 0.0.7
                                  Adapter    "phantomjs"     : 1.0.1
                                  Adapter    "pi-hole"       : 1.2.3
                                  Adapter    "piface"        : 1.0.0
                                  Adapter    "pimatic"       : 0.1.5
                                  Adapter    "ping"          : 1.3.2    , installed 1.3.2
                                  Adapter    "places"        : 0.7.0
                                  Adapter    "plex"          : 0.8.9
                                  Adapter    "plexconnect"   : 0.0.7
                                  Adapter    "pollenflug"    : 1.0.4
                                  Adapter    "proxmox"       : 1.0.1
                                  Adapter    "proxy"         : 1.1.1
                                  Adapter    "pushbullet"    : 0.0.11
                                  Adapter    "pushover"      : 1.2.3
                                  Adapter    "pushsafer"     : 0.1.8
                                  Adapter    "radar2"        : 1.0.9
                                  Adapter    "radiohead"     : 1.0.4
                                  Adapter    "rflink"        : 2.0.0
                                  Adapter    "rickshaw"      : 1.0.0
                                  Adapter    "ring"          : 1.0.5
                                  Adapter    "robonect"      : 0.0.12
                                  Adapter    "roomba"        : 1.1.1
                                  Adapter    "rpi2"          : 1.1.1
                                  Adapter    "s7"            : 1.1.7
                                  Adapter    "samsung"       : 0.2.9
                                  Adapter    "sayit"         : 1.8.2
                                  Adapter    "sbfspot"       : 2.4.0
                                  Adapter    "scenes"        : 1.1.0
                                  Adapter    "schoolfree"    : 0.5.0
                                  Adapter    "shelly"        : 3.1.6
                                  Adapter    "shuttercontrol": 0.4.3
                                  Adapter    "sia"           : 1.0.3
                                  Adapter    "siegenia"      : 1.0.0
                                  Adapter    "simple-api"    : 2.3.2    , installed 2.3.2
                                  Adapter    "smappee"       : 0.2.2
                                  Adapter    "smartmeter"    : 3.0.10
                                  Adapter    "snips"         : 1.5.0
                                  Adapter    "snmp"          : 0.5.0
                                  Adapter    "socketio"      : 2.1.2    , installed 3.0.1
                                  Adapter    "solarlog"      : 1.2.4
                                  Adapter    "solarwetter"   : 1.0.0
                                  Adapter    "sonnen"        : 1.3.0
                                  Adapter    "sonoff"        : 2.3.3
                                  Adapter    "sonos"         : 2.0.1
                                  Adapter    "sony-bravia"   : 1.0.1
                                  Adapter    "spotify-premium": 1.0.0
                                  Adapter    "sql"           : 1.9.5
                                  Adapter    "squeezebox"    : 1.0.0
                                  Adapter    "squeezeboxrpc" : 1.0.0
                                  Adapter    "starline"      : 1.0.0
                                  Adapter    "statistics"    : 0.2.2
                                  Adapter    "stiebel-isg"   : 1.4.11
                                  Adapter    "sunnyportal"   : 0.1.3
                                  Adapter    "swiss-weather-api": 0.2.0
                                  Adapter    "systeminfo"    : 0.3.1
                                  Adapter    "tahoma"        : 0.3.2
                                  Adapter    "tankerkoenig"  : 2.0.5
                                  Adapter    "telegram"      : 1.4.3
                                  Adapter    "terminal"      : 0.1.2
                                  Adapter    "tesla-motors"  : 0.2.3
                                  Adapter    "text2command"  : 1.3.0
                                  Adapter    "tr-064"        : 0.4.14   , installed 0.4.14
                                  Adapter    "tradfri"       : 2.5.2
                                  Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                  Adapter    "tuya"          : 3.2.2
                                  Adapter    "tvspielfilm"   : 1.0.4
                                  Adapter    "unifi"         : 0.3.1
                                  Adapter    "upnp"          : 1.0.11
                                  Adapter    "valloxmv"      : 1.0.3
                                  Adapter    "vcard"         : 0.0.9
                                  Adapter    "velux"         : 0.0.5
                                  Adapter    "viessmann"     : 1.2.4
                                  Adapter    "virtualpowermeter": 1.0.0
                                  Adapter    "vis"           : 1.2.4    , installed 1.2.4
                                  Adapter    "vis-bars"      : 0.1.4
                                  Adapter    "vis-canvas-gauges": 0.1.5
                                  Adapter    "vis-colorpicker": 1.1.1
                                  Adapter    "vis-fancyswitch": 1.1.0
                                  Adapter    "vis-google-fonts": 0.1.0
                                  Adapter    "vis-history"   : 1.0.0
                                  Adapter    "vis-hqwidgets" : 1.1.4
                                  Adapter    "vis-inventwo"  : 1.0.0
                                  Adapter    "vis-jqui-mfd"  : 1.0.12
                                  Adapter    "vis-justgage"  : 1.0.2
                                  Adapter    "vis-keyboard"  : 0.0.2
                                  Adapter    "vis-lcars"     : 1.0.4
                                  Adapter    "vis-map"       : 1.0.4
                                  Adapter    "vis-metro"     : 1.1.2
                                  Adapter    "vis-players"   : 0.1.5
                                  Adapter    "vis-plumb"     : 1.0.2
                                  Adapter    "vis-rgraph"    : 0.0.2
                                  Adapter    "vis-timeandweather": 1.1.7
                                  Adapter    "vis-weather"   : 2.5.2
                                  Adapter    "vr200"         : 1.0.0
                                  Adapter    "weatherunderground": 3.1.6
                                  Adapter    "web"           : 2.4.10   , installed 2.4.10
                                  Adapter    "weishaupt-wem" : 0.0.8
                                  Adapter    "wetty"         : 0.1.1
                                  Adapter    "wiffi-wz"      : 2.2.0
                                  Adapter    "wifilight"     : 0.2.0
                                  Adapter    "wled"          : 0.5.0
                                  Adapter    "wm-bus"        : 0.1.12
                                  Adapter    "wolf"          : 0.9.2
                                  Adapter    "worx"          : 1.0.0
                                  Adapter    "xbox"          : 0.6.1
                                  Adapter    "xs1"           : 1.0.2
                                  Adapter    "yahka"         : 0.9.2
                                  Adapter    "yamaha"        : 0.3.19
                                  Adapter    "yeelight-2"    : 1.0.3
                                  Adapter    "youtube"       : 0.0.6
                                  Adapter    "yr"            : 2.0.3
                                  Adapter    "zigbee"        : 1.0.3
                                  Adapter    "zont"          : 0.5.3
                                  Adapter    "zwave"         : 1.7.3
                                  pi@raspberrypi:/opt/iobroker $ sudo iobroker upgrade self
                                  Host    "raspberrypi"    is up to date.
                                  pi@raspberrypi:/opt/iobroker $ sudo iobroker start
                                  wendy2702W Online
                                  wendy2702W Online
                                  Er meinst das deine Version vom Admin zu alt ist.
                                    megaron
                                    @wendy2702
                                    Gibt es da eine neueres als die installierte?
                                    Viele Grüße megaron
                                    • M megaron
                                      @wendy2702
                                      sigi234S Online
                                      sigi234S Online
                                      @wendy2702
                                      Verwahrungsort vorübergehend auf latest stellen
                                      • sigi234S sigi234
                                        @wendy2702
                                        megaron
                                        @sigi234
                                        Das war’s. Jetzt funktioniert der Adapter. Vielen Dank für eure Unterstützung.
                                        Viele Grüße megaron
