  4. [Gelöst] Fehlermeldungen in Log-Datei
errorerror im logerror logerrorproblemproblem
28 Beiträge 4 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    Kannst du das log bzw. den teil mit dem Error mal als TXT hier in Code Tags Posten.
    Im Bild fehlt scheinbar die rechte Seite abgeschnitten.
      megaron
      schrieb am zuletzt editiert von megaron
      Hallo wendy2702,
      anbei der Log Auszug.
      host.raspberrypi
      2020-04-08 07:45:44.563
      info
      Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      host.raspberrypi
      2020-04-08 07:45:42.973
      info
      Restart adapter system.adapter.info.0 because enabled
      host.raspberrypi
      info
      instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi
      error
      Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.raspberrypi
      error
      Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:103452)
      host.raspberrypi
      error
      Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
      host.raspberrypi
      error
      Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
      host.raspberrypi
      error
      Caught by controller[0]: at Array.forEach (<anonymous>)
      host.raspberrypi
      2020-04-08 07:45:42.972
      error
      Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
      host.raspberrypi
      error
      host.raspberrypi
      error
      Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
      host.raspberrypi
      error
      Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
      host.raspberrypi
      error
      Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
      host.raspberrypi
      2020-04-08 07:45:42.971
      error
      Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      info.0
      2020-04-08 07:45:42.453
      info
      (21262) Terminated (NO_ERROR): Without reason
      info.0
      2020-04-08 07:45:42.452
      info
      (21262) terminating
      info.0
      2020-04-08 07:45:42.441
      info
      (21262) Reading process data every 120 seconds.
      info.0
      2020-04-08 07:45:42.414
      info
      (21262) cleaned everything up...
      info.0
      2020-04-08 07:45:42.413
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      info.0
      error
      (21262) TypeError: Cannot read property 'split' of undefined
      info.0
      2020-04-08 07:45:42.412
      error
      (21262) uncaught exception: Cannot read property 'split' of undefined
      info.0
      2020-04-08 07:45:42.302
      info
      (21262) Popup news was read...
      info.0
      2020-04-08 07:45:42.165
      info
      (21262) Reading CPU temp data every 60 seconds.
      info.0
      2020-04-08 07:45:42.162
      info
      (21262) Reading battery data every 120 seconds.
      info.0
      2020-04-08 07:45:42.061
      info
      (21262) Reading user data every 120 seconds.
      info.0
      2020-04-08 07:45:41.889
      info
      (21262) Reading memory data every 60 seconds.
      info.0
      2020-04-08 07:45:41.785
      info
      (21262) Reading disk data every 120 seconds.
      info.0
      2020-04-08 07:45:41.642
      info
      (21262) Reading CPU data every 60 seconds.
      info.0
      2020-04-08 07:45:41.619
      info
      (21262) Reading CPU current speed every 60 seconds.
      info.0
      2020-04-08 07:45:40.990
      info
      (21262) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.19.0
      Viele Grüße megaron
      • wendy2702W Online
        wendy2702W Online
        @megaron sagte in Fehlermeldungen in Log-Datei:
        Bedeutet wenn du den Info deaktivierst kommt der Fehler nicht mehr ?
        Welche Version Info Adapter, JS-Controller hast du installiert?
          megaron
          Richtig. Fehler tritt nur im aktivierten Zustand auf. (Ampel ist zudem auf rot)
          Node.js: v10.19.0
          Info.: 1.5.6 (aktuell)
          Viele Grüße megaron
          • wendy2702W Online
            wendy2702W Online
            Der JS Controller ist zu alt denke ich.
            • wendy2702W wendy2702
              megaron
              @wendy2702
              Ich hab das aktuelle Image auf der Homepage von IoBroker Zur Installation benutzt. Waren keinerlei Hinweise die Node.js zu aktualisieren. Hab mal ein bisschen gegoogelt und eine Version 2.2.9 gefunden (passt von der Logik nicht ganz zu der installierten 10.19.0). https://www.npmjs.com/package/iobroker.js-controller.
              Was wäre deine Empfehlung.
              Viele Grüße
              Viele Grüße megaron
              • wendy2702W Online
                wendy2702W Online
                Du verwechselst da etwas.
                Node/Node Js
                Ist etwas anderes als der JS Controller.
                Node/NodeJS ist in Version 10.x ok.
                JS Controller kann upgedatet werden.
                  Node/Node Js
                  megaron
                  @wendy2702
                  Hab gerade ein IoBroker Update/Upgrade gemacht. Js.controller ist aktuell (2.2.9). Problem ist weiterhin vorhanden. Hier auch noch das Protokoll.
                  Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l
                  permitted by applicable law.
                  Last login: Wed Apr  8 10:50:38 2020 from 192.168.178.34
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
                  pi@raspberrypi:/opt/iobroker $ sudo iobroker update
                  Used repository: default
                  hash unchanged, use cached sources
                  update done
                  Adapter    "admin"         : 3.7.8    , installed 3.7.8
                  Adapter    "alexa2"        : 3.0.5
                  Adapter    "alpha2"        : 1.0.0
                  Adapter    "amazon-dash"   : 1.1.0
                  Adapter    "artnet"        : 1.0.0
                  Adapter    "asterisk"      : 1.0.6
                  Adapter    "asuswrt"       : 1.0.1
                  Adapter    "b-control-em"  : 0.2.1
                  Adapter    "backitup"      : 1.4.5    , installed 1.4.5
                  Adapter    "beckhoff"      : 1.2.0
                  Adapter    "benq"          : 0.2.0
                  Adapter    "ble"           : 0.10.1
                  Adapter    "bmw"           : 1.3.3    , installed 1.3.3
                  Adapter    "bosesoundtouch": 0.2.4
                  Adapter    "botvac"        : 1.0.0
                  Adapter    "bring"         : 1.7.1
                  Adapter    "broadlink2"    : 2.0.2
                  Adapter    "bsblan"        : 0.0.6
                  Adapter    "bshb"          : 0.1.8
                  Adapter    "chromecast"    : 2.3.1
                  Adapter    "cloud"         : 3.0.2    , installed 3.0.2
                  Adapter    "comfoair"      : 0.3.2
                  Adapter    "contactid"     : 1.0.0
                  Adapter    "coronavirus-statistics": 0.5.5
                  Adapter    "countdown"     : 1.1.0
                  Adapter    "cul"           : 1.2.1
                  Adapter    "daikin"        : 1.0.5
                  Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                  Adapter    "deconz"        : 1.2.6
                  Adapter    "denon"         : 1.7.2    , installed 1.7.2
                  Adapter    "digitalstrom"  : 0.5.5
                  Adapter    "discovergy"    : 0.5.0
                  Adapter    "discovery"     : 2.2.2    , installed 2.2.2
                  Adapter    "ds18b20"       : 1.1.4
                  Adapter    "dwd"           : 2.4.6
                  Adapter    "ebus"          : 1.0.0
                  Adapter    "egigeozone"    : 0.1.2
                  Adapter    "ekey"          : 1.1.0
                  Adapter    "email"         : 1.0.6
                  Adapter    "emby"          : 1.0.2
                  Adapter    "energymanager" : 1.2.2
                  Adapter    "enet"          : 1.0.1
                  Adapter    "epson_stylus_px830": 0.2.1
                  Adapter    "fakeroku"      : 0.2.1
                  Adapter    "fb-checkpresence": 0.3.0   , installed 0.3.0
                  Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                  Adapter    "fhem"          : 1.3.0
                  Adapter    "find-my-iphone": 0.2.15
                  Adapter    "firetv"        : 0.0.27
                  Adapter    "flot"          : 1.9.2    , installed 1.9.2
                  Adapter    "foobar2000"    : 1.0.0
                  Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
                  Adapter    "fritzdect"     : 0.2.4    , installed 0.2.4
                  Adapter    "fronius"       : 1.0.5
                  Adapter    "fullcalendar"  : 1.1.0
                  Adapter    "fullybrowser"  : 1.0.0
                  Adapter    "g-homa"        : 0.5.1
                  Adapter    "geofency"      : 0.3.2
                  Adapter    "gruenbeck"     : 0.0.18
                  Adapter    "habpanel"      : 0.3.4
                  Adapter    "haier"         : 1.0.2
                  Adapter    "ham"           : 1.1.2
                  Adapter    "ham-wemo"      : 1.0.1
                  Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                  Adapter    "heatingcontrol": 0.3.19
                  Adapter    "heytech"       : 0.2.0
                  Adapter    "hid"           : 0.1.17
                  Adapter    "history"       : 1.8.7    , installed 1.8.7
                  Adapter    "hm-rega"       : 2.5.5    , installed 2.5.5
                  Adapter    "hm-rpc"        : 1.12.10  , installed 1.12.10
                  Adapter    "hmip"          : 0.0.11
                  Adapter    "homeconnect"   : 0.0.26
                  Adapter    "homee"         : 0.3.1
                  Adapter    "homepilot"     : 1.0.3
                  Adapter    "hp-ilo"        : 1.0.5
                  Adapter    "hs100"         : 1.0.10
                  Adapter    "hue"           : 3.2.3
                  Adapter    "hue-extended"  : 1.2.3
                  Adapter    "ical"          : 1.7.0    , installed 1.7.0
                  Adapter    "icons-addictive-flavour-png": 0.1.0
                  Adapter    "icons-fatcow-hosting": 0.1.0
                  Adapter    "icons-icons8"  : 0.0.1
                  Adapter    "icons-material-png": 0.1.0
                  Adapter    "icons-material-svg": 0.1.0
                  Adapter    "icons-mfd-png" : 1.0.2
                  Adapter    "icons-mfd-svg" : 1.0.2
                  Adapter    "icons-open-icon-library-png": 0.1.2
                  Adapter    "icons-ultimate-png": 1.0.1
                  Adapter    "influxdb"      : 1.7.0
                  Adapter    "info"          : 1.5.6    , installed 1.5.6
                  Adapter    "innogy-smarthome": 0.3.3
                  Adapter    "iogo"          : 0.5.7
                  Adapter    "iot"           : 1.1.8
                  Adapter    "iqontrol"      : 0.2.16
                  Adapter    "javascript"    : 4.3.4    , installed 4.3.4
                  Adapter    "jeelink"       : 0.1.0
                  Controller "js-controller" : 2.2.9    , installed 2.2.9
                  Adapter    "kecontact"     : 0.1.0
                  Adapter    "klf200"        : 0.9.5
                  Adapter    "km200"         : 1.1.6
                  Adapter    "knmi-weather"  : 0.2.0
                  Adapter    "knx"           : 1.0.39   , installed 1.0.39
                  Adapter    "kodi"          : 1.0.0
                  Adapter    "kress"         : 2.5.5
                  Adapter    "lametric"      : 0.0.7
                  Adapter    "landroid"      : 1.0.3
                  Adapter    "lcn"           : 0.3.2
                  Adapter    "lgtv"          : 1.1.5
                  Adapter    "lgtv-rs"       : 0.0.4
                  Adapter    "lgtv11"        : 1.0.5
                  Adapter    "lifx"          : 0.1.0
                  Adapter    "lightify"      : 0.2.16
                  Adapter    "link"          : 0.5.9
                  Adapter    "linkeddevices" : 1.1.1
                  Adapter    "lovelace"      : 0.2.3
                  Adapter    "loxone"        : 1.0.0
                  Adapter    "luftdaten"     : 0.0.11
                  Adapter    "lupusec"       : 1.2.3
                  Adapter    "luxtronik1"    : 0.2.2
                  Adapter    "material"      : 0.12.1
                  Adapter    "maxcube"       : 0.1.2
                  Adapter    "maxcul"        : 1.1.2
                  Adapter    "mbus"          : 2.1.4
                  Adapter    "megad"         : 1.2.1
                  Adapter    "megadd"        : 0.2.0
                  Adapter    "megaesp"       : 0.1.0
                  Adapter    "mercedesme"    : 0.0.21
                  Adapter    "mercury"       : 0.1.0
                  Adapter    "meross"        : 1.3.11
                  Adapter    "meteoalarm"    : 1.0.9
                  Adapter    "miele"         : 0.1.5
                  Adapter    "mielecloudservice": 1.1.0
                  Adapter    "mihome"        : 1.3.0    , installed 1.3.0
                  Adapter    "mihome-lamp"   : 1.1.0
                  Adapter    "mihome-plug"   : 0.2.0
                  Adapter    "mihome-vacuum" : 1.1.5    , installed 1.1.5
                  Adapter    "mikrotik"      : 1.0.11
                  Adapter    "milight"       : 0.3.6
                  Adapter    "milight-smart-light": 0.2.7
                  Adapter    "mobile"        : 0.5.0    , installed 0.5.0
                  Adapter    "modbus"        : 3.0.0
                  Adapter    "moma"          : 1.2.3
                  Adapter    "mpd"           : 1.0.0
                  Adapter    "mqtt"          : 2.1.1
                  Adapter    "mqtt-client"   : 1.3.1
                  Adapter    "musiccast"     : 0.1.3
                  Adapter    "mysensors"     : 2.0.0
                  Adapter    "nanoleaf-lightpanels": 0.8.1
                  Adapter    "nello"         : 2.0.6
                  Adapter    "netatmo"       : 1.3.1    , installed 1.3.1
                  Adapter    "nibeuplink"    : 0.3.0
                  Adapter    "nina"          : 0.0.22
                  Adapter    "node-red"      : 1.13.0
                  Adapter    "nuki"          : 1.2.0
                  Adapter    "nuki-extended" : 2.2.5
                  Adapter    "nut"           : 1.1.3
                  Adapter    "odl"           : 1.0.5
                  Adapter    "oilfox"        : 0.0.5
                  Adapter    "onkyo"         : 2.0.3
                  Adapter    "onvif"         : 0.0.2
                  Adapter    "openhab"       : 1.1.0
                  Adapter    "openligadb"    : 1.0.0
                  Adapter    "openweathermap": 0.1.0
                  Adapter    "opi"           : 0.1.1
                  Adapter    "oppoplayer"    : 0.2.1
                  Adapter    "owfs"          : 0.6.4
                  Adapter    "owntracks"     : 0.6.2
                  Adapter    "panasonic-viera": 1.0.2
                  Adapter    "parser"        : 1.0.7
                  Adapter    "paw"           : 0.0.7
                  Adapter    "phantomjs"     : 1.0.1
                  Adapter    "pi-hole"       : 1.2.3
                  Adapter    "piface"        : 1.0.0
                  Adapter    "pimatic"       : 0.1.5
                  Adapter    "ping"          : 1.3.2    , installed 1.3.2
                  Adapter    "places"        : 0.7.0
                  Adapter    "plex"          : 0.8.9
                  Adapter    "plexconnect"   : 0.0.7
                  Adapter    "pollenflug"    : 1.0.4
                  Adapter    "proxmox"       : 1.0.1
                  Adapter    "proxy"         : 1.1.1
                  Adapter    "pushbullet"    : 0.0.11
                  Adapter    "pushover"      : 1.2.3
                  Adapter    "pushsafer"     : 0.1.8
                  Adapter    "radar2"        : 1.0.9
                  Adapter    "radiohead"     : 1.0.4
                  Adapter    "rflink"        : 2.0.0
                  Adapter    "rickshaw"      : 1.0.0
                  Adapter    "ring"          : 1.0.5
                  Adapter    "robonect"      : 0.0.12
                  Adapter    "roomba"        : 1.1.1
                  Adapter    "rpi2"          : 1.1.1
                  Adapter    "s7"            : 1.1.7
                  Adapter    "samsung"       : 0.2.9
                  Adapter    "sayit"         : 1.8.2
                  Adapter    "sbfspot"       : 2.4.0
                  Adapter    "scenes"        : 1.1.0
                  Adapter    "schoolfree"    : 0.5.0
                  Adapter    "shelly"        : 3.1.6
                  Adapter    "shuttercontrol": 0.4.3
                  Adapter    "sia"           : 1.0.3
                  Adapter    "siegenia"      : 1.0.0
                  Adapter    "simple-api"    : 2.3.2    , installed 2.3.2
                  Adapter    "smappee"       : 0.2.2
                  Adapter    "smartmeter"    : 3.0.10
                  Adapter    "snips"         : 1.5.0
                  Adapter    "snmp"          : 0.5.0
                  Adapter    "socketio"      : 2.1.2    , installed 3.0.1
                  Adapter    "solarlog"      : 1.2.4
                  Adapter    "solarwetter"   : 1.0.0
                  Adapter    "sonnen"        : 1.3.0
                  Adapter    "sonoff"        : 2.3.3
                  Adapter    "sonos"         : 2.0.1
                  Adapter    "sony-bravia"   : 1.0.1
                  Adapter    "spotify-premium": 1.0.0
                  Adapter    "sql"           : 1.9.5
                  Adapter    "squeezebox"    : 1.0.0
                  Adapter    "squeezeboxrpc" : 1.0.0
                  Adapter    "starline"      : 1.0.0
                  Adapter    "statistics"    : 0.2.2
                  Adapter    "stiebel-isg"   : 1.4.11
                  Adapter    "sunnyportal"   : 0.1.3
                  Adapter    "swiss-weather-api": 0.2.0
                  Adapter    "systeminfo"    : 0.3.1
                  Adapter    "tahoma"        : 0.3.2
                  Adapter    "tankerkoenig"  : 2.0.5
                  Adapter    "telegram"      : 1.4.3
                  Adapter    "terminal"      : 0.1.2
                  Adapter    "tesla-motors"  : 0.2.3
                  Adapter    "text2command"  : 1.3.0
                  Adapter    "tr-064"        : 0.4.14   , installed 0.4.14
                  Adapter    "tradfri"       : 2.5.2
                  Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                  Adapter    "tuya"          : 3.2.2
                  Adapter    "tvspielfilm"   : 1.0.4
                  Adapter    "unifi"         : 0.3.1
                  Adapter    "upnp"          : 1.0.11
                  Adapter    "valloxmv"      : 1.0.3
                  Adapter    "vcard"         : 0.0.9
                  Adapter    "velux"         : 0.0.5
                  Adapter    "viessmann"     : 1.2.4
                  Adapter    "virtualpowermeter": 1.0.0
                  Adapter    "vis"           : 1.2.4    , installed 1.2.4
                  Adapter    "vis-bars"      : 0.1.4
                  Adapter    "vis-canvas-gauges": 0.1.5
                  Adapter    "vis-colorpicker": 1.1.1
                  Adapter    "vis-fancyswitch": 1.1.0
                  Adapter    "vis-google-fonts": 0.1.0
                  Adapter    "vis-history"   : 1.0.0
                  Adapter    "vis-hqwidgets" : 1.1.4
                  Adapter    "vis-inventwo"  : 1.0.0
                  Adapter    "vis-jqui-mfd"  : 1.0.12
                  Adapter    "vis-justgage"  : 1.0.2
                  Adapter    "vis-keyboard"  : 0.0.2
                  Adapter    "vis-lcars"     : 1.0.4
                  Adapter    "vis-map"       : 1.0.4
                  Adapter    "vis-metro"     : 1.1.2
                  Adapter    "vis-players"   : 0.1.5
                  Adapter    "vis-plumb"     : 1.0.2
                  Adapter    "vis-rgraph"    : 0.0.2
                  Adapter    "vis-timeandweather": 1.1.7
                  Adapter    "vis-weather"   : 2.5.2
                  Adapter    "vr200"         : 1.0.0
                  Adapter    "weatherunderground": 3.1.6
                  Adapter    "web"           : 2.4.10   , installed 2.4.10
                  Adapter    "weishaupt-wem" : 0.0.8
                  Adapter    "wetty"         : 0.1.1
                  Adapter    "wiffi-wz"      : 2.2.0
                  Adapter    "wifilight"     : 0.2.0
                  Adapter    "wled"          : 0.5.0
                  Adapter    "wm-bus"        : 0.1.12
                  Adapter    "wolf"          : 0.9.2
                  Adapter    "worx"          : 1.0.0
                  Adapter    "xbox"          : 0.6.1
                  Adapter    "xs1"           : 1.0.2
                  Adapter    "yahka"         : 0.9.2
                  Adapter    "yamaha"        : 0.3.19
                  Adapter    "yeelight-2"    : 1.0.3
                  Adapter    "youtube"       : 0.0.6
                  Adapter    "yr"            : 2.0.3
                  Adapter    "zigbee"        : 1.0.3
                  Adapter    "zont"          : 0.5.3
                  Adapter    "zwave"         : 1.7.3
                  pi@raspberrypi:/opt/iobroker $ sudo iobroker upgrade self
                  Host    "raspberrypi"    is up to date.
                  pi@raspberrypi:/opt/iobroker $ sudo iobroker start
                  Viele Grüße megaron
                  • wendy2702W Online
                    wendy2702W Online
                    Was kommt bei
                    iobroker -v
                    • M megaron
                      Hallo wendy2702,
                      host.raspberrypi
                      info
                      host.raspberrypi
                      info
                      host.raspberrypi
                      info
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      host.raspberrypi
                      error
                      info.0
                      info
                      info.0
                      info
                      (21262) terminating
                      info.0
                      info
                      info.0
                      info
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      error
                      info.0
                      info
                      info.0
                      info
                      info.0
                      info
                      info.0
                      info
                      info.0
                      info
                      info.0
                      info
                      info.0
                      info
                      info.0
                      info
                      info.0
                      info
                      megaron
                      @megaron
                      Last login: Wed Apr  8 18:29:29 2020 from 192.168.178.37
                      pi@raspberrypi:~ $ Iobroker -v
                      -bash: Iobroker: Kommando nicht gefunden.
                      pi@raspberrypi:~ $
                      Viele Grüße megaron
                      • M megaron
                        @megaron
                        pi@raspberrypi:~ $
                        wendy2702W Online
                        wendy2702W Online
                        @megaron kleines „i“ bei iobroker.
                        Habe es oben korrigiert
                          megaron
                          @wendy2702
                          2.2.9
                          Viele Grüße megaron
                          • M megaron
                            Node.js: v10.19.0
                            wendy2702W Online
                            wendy2702W Online
                            Node.js: v10.19.0
                            Also hast du schon die neueste JS Controller Version.
                            Woher hast du dann die 1.5.6 ?
                              Node.js: v10.19.0
                              megaron
                              @wendy2702
                              1.5.6 ist die Version des Info Adapters (Information tab)
                              Viele Grüße megaron
                              • wendy2702W Online
                                wendy2702W Online
                                Also dann mal schauen ob hier etwas für doch dabei ist:
                                Such Ergebnisse
                                Oder mal auf Version 1.5.7 upgraden (ist im Latest)
                                Oder Instanz und Adapter löschen und neu installieren.
                                Wäre das was ich machen würde.
                                  Such Ergebnisse
                                  megaron
                                  @wendy2702
                                  Hab die Instanz gelöscht. Muss ich den Adapter auch löschen? Und wie komme ich an die latest 1.5.7. ?
                                  Auf IoBroker.info hab ich die 1.6.0 gefunden.
                                  Viele Grüße megaron
                                  • wendy2702W Online
                                    wendy2702W Online
                                    Mir wird bei einstellen von "Latest" als Verwahrungsort die 1.5.7 angeboten.
                                    1.6.0 kann man wahrscheinlich direkt aus Github installieren.
                                      megaron
                                      @wendy2702
                                      Wo kann man denn latest einstellen. Sorry vielleicht für die blöde Frage aber ich hab den IoBroker erst ist seit einer Woche und von Linux habe ich noch weniger Ahnung.
                                      Hab jetzt die 1.6.0 drauf. Gleiche Fehlermeldungen:
                                      host.raspberrypi	2020-04-08 19:24:56.118	info	Restart adapter system.adapter.info.0 because enabled
                                      host.raspberrypi	2020-04-08 19:24:56.118	info	instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                                      host.raspberrypi	2020-04-08 19:24:56.118	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                      host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:103452)
                                      host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
                                      host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
                                      host.raspberrypi	2020-04-08 19:24:56.116	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                                      host.raspberrypi	2020-04-08 19:24:56.116	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
                                      host.raspberrypi	2020-04-08 19:24:56.115	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
                                      host.raspberrypi	2020-04-08 19:24:56.115	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
                                      host.raspberrypi	2020-04-08 19:24:56.114	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
                                      host.raspberrypi	2020-04-08 19:24:56.111	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
                                      info.0	2020-04-08 19:24:55.579	info	(23189) Terminated (NO_ERROR): Without reason
                                      info.0	2020-04-08 19:24:55.578	info	(23189) terminating
                                      info.0	2020-04-08 19:24:55.531	info	(23189) cleaned everything up...
                                      info.0	2020-04-08 19:24:55.530	error	(23189) TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23) at checkConditions (/opt/iobroker/node_modules/iobroker.i
                                      info.0	2020-04-08 19:24:55.529	error	(23189) uncaught exception: Cannot read property 'split' of undefined
                                      info.0	2020-04-08 19:24:55.407	info	(23189) Popup news was read...
                                      info.0	2020-04-08 19:24:53.538	info	(23189) starting. Version 1.6.0 in /opt/iobroker/node
                                      Viele Grüße megaron
                                      • wendy2702W Online
                                        wendy2702W Online
                                        OK.
                                        Dann hast du wohl auch noch nicht viel eingerichtet, oder?
                                        Wie hast du den PI installiert? Image oder Manuell?
                                        Wenn manuell, welche SW ?
                                        Debian oder was?
                                          OK.
                                          Debian oder was?
                                          megaron
                                          @wendy2702
                                          Hallo, die Installation ist über Image erfolgt.
                                          „IoBroker Image für Raspberry Pi2/3/4 Buster 20191127“ Von der IoBroker.net page.
                                          Ca. 10 Adapter eingerichtet.
                                          Viele Grüße megaron
