  4. Unlogisch, oder?
Unlogisch, oder?
blocklyskript
44 Beiträge 5 Kommentatoren 4.8k Aufrufe 3 Beobachtet
  • Uli977U Uli977
    @paul53 Das habe ich nicht verstanden. Kannst du mir das mal beispielhaft hier einbauen?
     <block type="on_ext" id="vh$1Vf/:fEcxImN2n]k0" x="216" y="158">
       <mutation items="1"></mutation>
       <value name="OID0">
         <shadow type="field_oid" id="tfo!K_/{iAV9vOD,pUJY">
           <field name="oid">hm-rpc.1.JEQ0127504.1.BRIGHTNESS</field>
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="comment" id="3CV12[Y.V7D.=iojL2E8">
           <field name="COMMENT">Hell = Rollos Hoch</field>
           <next>
             <block type="controls_if" id="^$G6+:/WMZ|/WDB2fU#y">
               <value name="IF0">
                 <block type="logic_operation" id="{nDDIm4l*Z:g9].e=6C6" inline="false">
                   <field name="OP">AND</field>
                   <value name="A">
                     <block type="logic_compare" id="KHO9xlj^73pIkb0+b`Wf">
                       <field name="OP">GT</field>
                       <value name="A">
                         <block type="get_value" id="nG{dVB}AuR1/FS{N9@Ip">
                           <field name="OID">hm-rpc.1.JEQ0127504.1.BRIGHTNESS</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="math_number" id="Rl0JN=!80xgl5#n:]M/e">
                           <field name="NUM">125</field>
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="B">
                     <block type="logic_operation" id="jBdHxI2JqKwjN+GmSqz$" inline="false">
                       <field name="OP">OR</field>
                       <value name="A">
                         <block type="logic_operation" id="gb8@[=FK[/8fWlPn98~N" inline="false">
                           <value name="A">
                             <block type="time_compare" id="X3l,9dGhy[#al5e6UK}8">
                               <mutation end_time="false"></mutation>
                               <field name="OPTION">&gt;</field>
                               <field name="START_TIME">06:20</field>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_operation" id="xV*ut;]jRi:[vg}GUzAD">
                               <value name="A">
                                 <block type="logic_compare" id="(!wu7Fe}G_Sp+-Xp#WJ=">
                                   <field name="OP">GTE</field>
                                   <value name="A">
                                     <block type="time_get" id="ZOQ@u!;+UE24u%*!b9_I">
                                       <mutation format="false" language="false"></mutation>
                                       <field name="OPTION">wd</field>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="x#9d(+umIVLR5}fcUI95">
                                       <field name="NUM">1</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id="!H|u[@([;Oi#rKZBj!?1">
                                   <field name="OP">LTE</field>
                                   <value name="A">
                                     <block type="time_get" id="3G_H|t2k7j?@UPrk}sxm">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="Zr.RQ+G+)4!LJw)}%JR*">
                                       <field name="NUM">5</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_operation" id="V9HqfHfSj]+8E`cl5?Lo" inline="false">
                           <value name="A">
                             <block type="time_compare" id="F:Di?ZhZGohui{!i%vjA">
                               <field name="START_TIME">07:20</field>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_operation" id="d)0(f^d.T}j~m()zFclQ">
                               <value name="A">
                                 <block type="logic_compare" id="kwm^uszT!E7p4s/Jnhck">
                                   <value name="A">
                                     <block type="time_get" id="6,;gs.halVW.Y(zJ^a9H">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="05HB+edMRk+*}d3VSPCl">
                                       <field name="NUM">6</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id="X%~Vwv_8^+.TyyQtGJ|z">
                                   <value name="A">
                                     <block type="time_get" id="Qn4jafy(s/td9{FoAAjm">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="@a~*DJG!_+:$9c3;(|TR">
                                       <field name="NUM">7</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <statement name="DO0">
                 <block type="control" id="@?o}Iyi?XW#8ZByV0.rC">
                   <mutation delay_input="false"></mutation>
                   <field name="OID">javascript.0.Eigene_Datenpunkte.Rollos.02_Rollos_Hell</field>
                   <value name="VALUE">
                     <block type="logic_boolean" id="=z?*v!k]E(X!*pR^2okN">
                     </block>
                   </value>
                   <next>
                     <block type="pushover" id="4|k:GHBv8v6oTYjjF68{" disabled="true">
                       <field name="SOUND"></field>
                       <field name="PRIORITY">0</field>
                       <field name="LOG"></field>
                       <value name="MESSAGE">
                         <shadow type="text" id="eyA^I/w3/r9R%9FP{tLH">
                           <field name="TEXT">Rollos Hell AN</field>
                         </shadow>
                       </value>
                     </block>
                   </next>
                 </block>
               </statement>
               <statement name="ELSE">
                 <block type="control" id="l4L?F=?:Rb/sN+:Y7rYD">
                     <block type="logic_boolean" id="IERWc#kn@ijHN!U%Ui[^">
                     </block>
                   </value>
                 </block>
               </statement>
               <next>
                 <block type="comment" id="aDQI.zN@Y0?NS{0`Cl%h">
                   <field name="COMMENT">Dämmerung = Rollos Halb</field>
                   <next>
                     <block type="controls_if" id="WrmUXh.v%WGEhh{7qD=s">
                       <value name="IF0">
                         <block type="logic_operation" id=",t^`Vq%U#ZHsusV_}0T#" inline="false">
                           <value name="A">
                             <block type="logic_operation" id="f%*j_g*W7XIVN#rFCr`d" inline="false">
                               <value name="A">
                                 <block type="logic_compare" id="wBH@cHDAGXQl4t#6[V%$">
                                   <value name="A">
                                     <block type="get_value" id="WA.:D@HD])@WLlSO|Gvx">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="uIx]|)7*Hl=$%Hy]#^]T">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id="c+2VkY,,W-xSGDG,O@eo">
                                   <value name="A">
                                     <block type="get_value" id="?u~RXQ~VYegl44Jkg]X*">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="%avq4Z+Ip?}|GNV?|qiT">
                                       <field name="NUM">105</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_operation" id="-=^Ak@FKNg$j((cX+Z1," inline="false">
                               <value name="A">
                                 <block type="logic_operation" id="E5op(4xW2Dv/z7FRB1ug" inline="false">
                                   <value name="A">
                                     <block type="logic_operation" id="uC1hISQgqpAga62cr+D8">
                                       <value name="A">
                                         <block type="time_compare" id="1uQT`*Amom~*fX#ZB2AS">
                                           <mutation end_time="true"></mutation>
                                           <field name="OPTION">between</field>
                                           <field name="START_TIME">06:15</field>
                                           <field name="END_TIME">10:00</field>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="time_compare" id="=/;Y=.5XI{:=hss+Ed};">
                                           <field name="START_TIME">16:30</field>
                                           <field name="END_TIME">23:00</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_operation" id="dL`fY?M2;UoVsJ_d%!3Z">
                                       <value name="A">
                                         <block type="logic_compare" id="I{?,c%0{-`3tsiJdm]uY">
                                           <value name="A">
                                             <block type="time_get" id="}3Xv%RKs;@iBi~)Vx:Le">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="zl5XW)sp}XS-(8xxJ!S=">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_compare" id="XS:b%JJS)vO}7CR-SiH=">
                                           <value name="A">
                                             <block type="time_get" id="PWCo%By|o/Ft=f_~+$ao">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="5IPDj?4T-x*,{V8f9nXx">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_operation" id="ab$yI6qv2Y+OmXLz`;yP" inline="false">
                                   <value name="A">
                                     <block type="logic_operation" id="1(EUrvh.y5q{!qn@#rFG">
                                       <value name="A">
                                         <block type="time_compare" id="vGV1fZfc+zYt(ewXxvY!">
                                           <field name="START_TIME">07:15</field>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="time_compare" id="3vD:`(5CWOI?jo_9PRQx">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_operation" id="mx7L(A+HHRyY{2%wYPlY">
                                       <value name="A">
                                         <block type="logic_compare" id="}V/RE1JlSG|NP=S?Sv=e">
                                           <value name="A">
                                             <block type="time_get" id="b86gLl[+s)zcK`BWixG:">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="^T(C=9D[[vk!~Ss|4%~Z">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_compare" id=")l[}Vin`Q5a3~V47Fh1{">
                                           <value name="A">
                                             <block type="time_get" id="y}/}cS`o?HUzlc,$v5vK">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="J+9O;KtBdj,76TIFI1Yo">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                         <block type="control" id="AOBDiRl;jYW=Z[WG++%%">
                           <field name="OID">javascript.0.Eigene_Datenpunkte.Rollos.01_Rollos_Dämmerung</field>
                             <block type="logic_boolean" id="5L6AyjyC`8.:~^1yeaSF">
                             </block>
                           </value>
                           <next>
                             <block type="pushover" id="FN?%|roNq:pU5Qs:]@YW" disabled="true">
                                 <shadow type="text" id="|0lN~.oJ_)-x*4tsx5Jb">
                                   <field name="TEXT">Rollos Dämmerung AN</field>
                                 </shadow>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                         <block type="control" id="e{scLL_Wuw/CcL~e2)+S">
                             <block type="logic_boolean" id="Kb]^cEoW[{YGkajitBgs">
                             </block>
                           </value>
                         </block>
                       </statement>
                       <next>
                         <block type="comment" id="yaPNb~E7!a9neR5)(UWz">
                           <field name="COMMENT">Dunkel = Rollos Runter</field>
                           <next>
                             <block type="controls_if" id="5eP+!pNjWSP96Fvjo+RY">
                               <value name="IF0">
                                 <block type="logic_operation" id="@2~EQb?HpAQ01wtII]-c" inline="false">
                                   <value name="A">
                                     <block type="logic_compare" id="{_h@TGUJY`dUfb9gj:M(">
                                       <field name="OP">LT</field>
                                       <value name="A">
                                         <block type="get_value" id=")HNSRuOfojP_tERH5/N[">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="%)wvV|;NkUVh@}KH-9s%">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="time_compare" id="4`I:O+}-mE2{$1vvtwie">
                                       <field name="START_TIME">20:00</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="control" id="dJztT|k(pQoHksax)7?c">
                                   <field name="OID">javascript.0.Eigene_Datenpunkte.Rollos.03_Rollos_Dunkel</field>
                                     <block type="logic_boolean" id="!3z,F)E`F9!i@kmg!5h)">
                                     </block>
                                   </value>
                                   <next>
                                     <block type="pushover" id="9JZnsogK$rZpG5yR3pXv" disabled="true">
                                         <shadow type="text" id="]],9cSQ(!f$?^|{*vO=1">
                                           <field name="TEXT">Rollos Dunkel AN</field>
                                         </shadow>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                                 <block type="control" id="5Rz4mw9U6{CsvH[f^/(A">
                                     <block type="logic_boolean" id="6YMgu6^Ql$XG@lV0l/dF">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    Eigentlich will ich nur hier sehen können, wann sich der Status zuletzt geändert hat. Aber er zeigt hier immer die letzte Aktualisierung.
    @Uli977 sagte:
     <variables>
       <variable type="" id="syU,#JZP%PfjRY~TR}y}">an</variable>
     </variables>
     <block type="procedures_defnoreturn" id="i,rn}%)D74@At@*q%T*J" x="1063" y="162">
       <mutation>
         <arg name="an" varid="syU,#JZP%PfjRY~TR}y}"></arg>
       </mutation>
       <field name="NAME">Rolloshoch</field>
       <statement name="STACK">
         <block type="controls_if" id="oDVP[wHj1?nE{Y65Xlg#">
           <value name="IF0">
             <block type="logic_compare" id="S0k]xJj^92IX/=426Mgo">
               <field name="OP">NEQ</field>
               <value name="A">
                 <block type="variables_get" id="n@{0}l7?wIrv}=6zB_oM">
                   <field name="VAR" id="syU,#JZP%PfjRY~TR}y}" variabletype="">an</field>
                 </block>
               </value>
               <value name="B">
                 <block type="get_value_var" id="sX|w;aWHBY-^Ebp1!ibN">
                   <value name="OID">
                     <shadow type="text" id="-z6%VF@:8i}(gJ*!{MvX">
                       <field name="TEXT">javascript.0.Eigene_Datenpunkte.Rollos.02_Rollos_Hell</field>
                     </shadow>
                   </value>
                 </block>
               </value>
             </block>
           </value>
                 <block type="variables_get" id="OX_Gy~4*UQq:kRzx!~x1">
                 </block>
               </value>
               <next>
                 <block type="controls_if" id="5lvLDb0fo_q^x82|G}[X">
                   <value name="IF0">
                     <block type="variables_get" id="LoO`b~q20.~Sv_x5ah{/">
                     </block>
                   </value>
                         </shadow>
                       </value>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </statement>
     </block>
     <block type="on_ext" id="vh$1Vf/:fEcxImN2n]k0" x="284" y="206">
       <value name="OID0">
         </shadow>
       </value>
           <next>
               <value name="IF0">
                   <value name="A">
                       <value name="A">
                         <block type="on_source" id="U28dcR#%rb0P{r$L?D[;">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="B">
                       <value name="A">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
                 <block type="procedures_callnoreturn" id="+5L;V(0vm?h,DsB~iaS3" inline="true">
                   <mutation name="Rolloshoch">
                     <arg name="an"></arg>
                   </mutation>
                   <value name="ARG0">
                     <block type="logic_boolean" id="+dU!,!j2jGU0yZ+M-YPi">
                     </block>
                   </value>
                 </block>
               </statement>
                 <block type="procedures_callnoreturn" id="vjE6CT#1x)R}-=KP`r~+" inline="true">
                   </mutation>
                   <value name="ARG0">
                     <block type="logic_boolean" id="[=d$DBB)cY4-dXc]MwN=">
                     </block>
                   </value>
                 </block>
               </statement>
               <next>
                   <next>
                       <value name="IF0">
                           <value name="A">
                               <value name="A">
                                   <value name="A">
                                     <block type="on_source" id="v~uZ/~lo5=*.H,XT!ZVm">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id="o-ybV|H#h}4}3W+uCrUM">
                                   <value name="A">
                                     <block type="on_source" id="aSc1qCZ5eXSW5#*w:;Q0">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="`pZQ|SN8^=8T4l~3aht[">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                               <value name="A">
                                   <value name="A">
                                     <block type="logic_operation" id="uC1hISQgqpAga62cr+D8" inline="false">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                     <block type="logic_operation" id="1(EUrvh.y5q{!qn@#rFG" inline="false">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                         <block type="procedures_callnoreturn" id=")ZDU?[tm5IuV3-HBHp)M" inline="true">
                           <mutation name="Rolloshalb">
                           </mutation>
                           <value name="ARG0">
                             <block type="logic_boolean" id="^yyi2(r3h88M(`MFzoR=">
                             </block>
                           </value>
                         </block>
                       </statement>
                         <block type="procedures_callnoreturn" id="{3.l=+PQz0tDR-rvR_5$" inline="true">
                           </mutation>
                           <value name="ARG0">
                             <block type="logic_boolean" id="x*jp(J`FNtaz/31,WtC;">
                             </block>
                           </value>
                         </block>
                       </statement>
                       <next>
                           <next>
                               <value name="IF0">
                                   <value name="A">
                                     <block type="logic_compare" id="X+:5g/m#RW[KQqU4@Y~r">
                                       <value name="A">
                                         <block type="on_source" id="n}(_%2FfNuZI;@=GvCjk">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="|P1bNP1=9XyI+uRyu7w8">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="procedures_callnoreturn" id="{mTzcgJ1y?:0EBJr^uhu" inline="true">
                                   <mutation name="Rollosrunter">
                                   </mutation>
                                   <value name="ARG0">
                                     <block type="logic_boolean" id="rq0$ip*SepuSuxr9ROUM">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                                 <block type="procedures_callnoreturn" id="l]2N6^!^Lp!kuYJ]Vh~^" inline="true">
                                   </mutation>
                                   <value name="ARG0">
                                     <block type="logic_boolean" id="]X^,TmLrJA@zy1~L+c{o">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
     <block type="procedures_defnoreturn" id="EZPCn)sFX=wvr||6@`N]" x="1063" y="613">
       <mutation>
       </mutation>
       <field name="NAME">Rolloshalb</field>
         <block type="controls_if" id=",tJPZL9nsKcYblR3ZYM}">
           <value name="IF0">
             <block type="logic_compare" id="YvO]|7|4yC]LOA?/7%y6">
               <value name="A">
                 <block type="variables_get" id="?:Y}fvg%qAA%,umbH6b+">
                 </block>
               </value>
               <value name="B">
                 <block type="get_value_var" id="0iyM=(vCxl|W*B#?W2]/">
                   <value name="OID">
                     <shadow type="text" id="}7N4;uCFL~-sXMaRPP*.">
                       <field name="TEXT">javascript.0.Eigene_Datenpunkte.Rollos.01_Rollos_Dämmerung</field>
                     </shadow>
                   </value>
                 </block>
               </value>
             </block>
           </value>
                 <block type="variables_get" id="7us_@%rno](p6n.os@sD">
                 </block>
               </value>
               <next>
                 <block type="controls_if" id="}=h/OyQo)py$p(a+L(kb">
                   <value name="IF0">
                     <block type="variables_get" id="),7@/tYeO:F%m%1T)YD[">
                     </block>
                   </value>
                     <block type="pushover" id="5d/)EMjg|zN.zk*?7D{d" disabled="true">
                         <shadow type="text" id="Rgyur-G.g_VEyu,1}|CP">
                         </shadow>
                       </value>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </statement>
     </block>
     <block type="procedures_defnoreturn" id="?:2Ew^*p60OIplI^w/C," x="1062" y="1062">
       <mutation>
       </mutation>
       <field name="NAME">Rollosrunter</field>
         <block type="controls_if" id="GAw}e}1td~5_z)7I[|08">
           <value name="IF0">
             <block type="logic_compare" id="-vt#p/Z7!Brn(p)*8Nxd">
               <value name="A">
                 <block type="variables_get" id="zY|1B;mugpM=rGhRol)M">
                 </block>
               </value>
               <value name="B">
                 <block type="get_value_var" id="pbm8lyIl{5uUWHyKLf!S">
                   <value name="OID">
                     <shadow type="text" id="yv0X(!B|o6X]@E%~D07P">
                       <field name="TEXT">javascript.0.Eigene_Datenpunkte.Rollos.03_Rollos_Dunkel</field>
                     </shadow>
                   </value>
                 </block>
               </value>
             </block>
           </value>
                 <block type="variables_get" id="-b^j0g(pAGL#|s-Zh:;q">
                 </block>
               </value>
               <next>
                 <block type="controls_if" id="q#K}}wW[30SNdO$Kp7!Z">
                   <value name="IF0">
                     <block type="variables_get" id="{)2(L6c1c%QN|E@)*.gA">
                     </block>
                   </value>
                         </shadow>
                       </value>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </statement>
     </block>
    </xml>
    Uli977U 1 Antwort Letzte Antwort
      @Uli977 sagte:
       <variables>
       </variables>
         <mutation>
         </mutation>
             <value name="IF0">
                 <value name="A">
                   </block>
                 </value>
                 <value name="B">
                     <value name="OID">
                       </shadow>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
                   </block>
                 </value>
                 <next>
                     <value name="IF0">
                       </block>
                     </value>
                           </shadow>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </statement>
       </block>
         <value name="OID0">
           </shadow>
         </value>
             <next>
                 <value name="IF0">
                     <value name="A">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                     <value name="B">
                         <value name="A">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </value>
                     </mutation>
                     <value name="ARG0">
                       </block>
                     </value>
                   </block>
                 </statement>
                     </mutation>
                     <value name="ARG0">
                       </block>
                     </value>
                   </block>
                 </statement>
                 <next>
                     <next>
                         <value name="IF0">
                             <value name="A">
                                 <value name="A">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                     <value name="A">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                             </mutation>
                             <value name="ARG0">
                               </block>
                             </value>
                           </block>
                         </statement>
                             </mutation>
                             <value name="ARG0">
                               </block>
                             </value>
                           </block>
                         </statement>
                         <next>
                             <next>
                                 <value name="IF0">
                                     <value name="A">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                     </mutation>
                                     <value name="ARG0">
                                       </block>
                                     </value>
                                   </block>
                                 </statement>
                                     </mutation>
                                     <value name="ARG0">
                                       </block>
                                     </value>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </statement>
       </block>
         <mutation>
         </mutation>
             <value name="IF0">
                 <value name="A">
                   </block>
                 </value>
                 <value name="B">
                     <value name="OID">
                       </shadow>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
                   </block>
                 </value>
                 <next>
                     <value name="IF0">
                       </block>
                     </value>
                           </shadow>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </statement>
       </block>
         <mutation>
         </mutation>
             <value name="IF0">
                 <value name="A">
                   </block>
                 </value>
                 <value name="B">
                     <value name="OID">
                       </shadow>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
                   </block>
                 </value>
                 <next>
                     <value name="IF0">
                       </block>
                     </value>
                           </shadow>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </statement>
       </block>
      </xml>
      Uli977U Offline
      Uli977U Offline
      Uli977
      @paul53 Uff...... das ist ja was! Kleines Thema, kompliziertes Programm.
      Danke dir!
      • Uli977U Uli977
        Danke dir!
        @Uli977
        Wenn man noch die Datenpunkt-ID und den Pushover-Text an die Funktion übergibt, kommt man mit einer Funktion aus.
         <variables>
           <variable type="" id="xg+w6vJ%Q(GS7z~M+Yx7">id</variable>
           <variable type="" id="3U:fR:NTK]((S%BF:qKU">text</variable>
         </variables>
           <value name="OID0">
             </shadow>
           </value>
               <next>
                   <value name="IF0">
                       <value name="A">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                           <value name="A">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                     <block type="procedures_callnoreturn" id="+5L;V(0vm?h,DsB~iaS3" inline="false">
                       <mutation name="Rollos">
                         <arg name="id"></arg>
                         <arg name="text"></arg>
                       </mutation>
                       <value name="ARG0">
                         <block type="text" id="E_vbv1WsYGPy@e8h5Rot">
                         </block>
                       </value>
                       <value name="ARG1">
                         </block>
                       </value>
                       <value name="ARG2">
                         <block type="text" id="u:.LP3Y|dT3)VQtY3T4^">
                         </block>
                       </value>
                     </block>
                   </statement>
                     <block type="procedures_callnoreturn" id="vjE6CT#1x)R}-=KP`r~+" inline="false">
                       </mutation>
                       <value name="ARG0">
                         <block type="text" id="`QDlCvb_6oa_n@{vMwaV">
                         </block>
                       </value>
                       <value name="ARG1">
                         </block>
                       </value>
                     </block>
                   </statement>
                   <next>
                       <next>
                           <value name="IF0">
                               <value name="A">
                                   <value name="A">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                       <value name="A">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="procedures_callnoreturn" id="bWmLO.%/G~Zo$Ap`T5kG" inline="false">
                               </mutation>
                               <value name="ARG0">
                                 <block type="text" id="lTzB5sZ|nM;b(;g=ijw}">
                                 </block>
                               </value>
                               <value name="ARG1">
                                 <block type="logic_boolean" id="O+_q6EoiWn|QvL=mQT}}">
                                 </block>
                               </value>
                               <value name="ARG2">
                                 <block type="text" id="s6di?Zk#|3ttJ%7}g7fD">
                                 </block>
                               </value>
                             </block>
                           </statement>
                             <block type="procedures_callnoreturn" id="b=V,5lRSm)bm2RHF%Ihj" inline="false">
                               </mutation>
                               <value name="ARG0">
                                 <block type="text" id="KyneViF}gMi;A::{HA$N">
                                 </block>
                               </value>
                               <value name="ARG1">
                                 <block type="logic_boolean" id="G(i=#_HON{Lv#.+UWhGu">
                                 </block>
                               </value>
                             </block>
                           </statement>
                           <next>
                               <next>
                                   <value name="IF0">
                                       <value name="A">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                     <block type="procedures_callnoreturn" id="#i_1$6}ezl$#/4F8o]Y1" inline="false">
                                       </mutation>
                                       <value name="ARG0">
                                         <block type="text" id="p1Bz5Pw1_LgyA3-P9;Or">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         <block type="logic_boolean" id="m-b0vNWg7%rAxoc0R/kl">
                                         </block>
                                       </value>
                                       <value name="ARG2">
                                         <block type="text" id="K#)Gl0No3R0h,!re0A4{">
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                     <block type="procedures_callnoreturn" id="(c`327xh[N8ed!d6U!kl" inline="false">
                                       </mutation>
                                       <value name="ARG0">
                                         <block type="text" id="$wvBb9km^@k:k3RQnDfT">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         <block type="logic_boolean" id="+7((+Vo%_wga7FxKJL_Y">
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
         <block type="procedures_defnoreturn" id="i,rn}%)D74@At@*q%T*J" x="912" y="1038">
           <mutation>
             <arg name="id" varid="xg+w6vJ%Q(GS7z~M+Yx7"></arg>
             <arg name="text" varid="3U:fR:NTK]((S%BF:qKU"></arg>
           </mutation>
           <field name="NAME">Rollos</field>
               <value name="IF0">
                   <value name="A">
                     </block>
                   </value>
                   <value name="B">
                       <value name="OID">
                         </shadow>
                         <block type="variables_get" id="k[3+0un*MG@|x!)Gv$[$">
                           <field name="VAR" id="xg+w6vJ%Q(GS7z~M+Yx7" variabletype="">id</field>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
                 <block type="control_ex" id="nQNoF|lS6ca^`4v8#JBj" inline="true">
                   <field name="TYPE">true</field>
                   <value name="OID">
                     <shadow type="field_oid" id="V*`k!$zP/XOwU}470*!R">
                       <field name="oid">Object ID</field>
                     </shadow>
                     <block type="variables_get" id="Rn0EETx*IGvA+AmM8t$t">
                     </block>
                   </value>
                     <shadow type="logic_boolean" id="AJ#yt*m6@rS?;X5!U=v;">
                     </shadow>
                     </block>
                   </value>
                   <value name="DELAY_MS">
                     <shadow type="math_number" id="i.j,FDpkCoigAop}F]GD">
                       <field name="NUM">0</field>
                     </shadow>
                   </value>
                   <next>
                       <value name="IF0">
                         </block>
                       </value>
                             </shadow>
                             <block type="variables_get" id="q}4rjh,i-~BwSB_!;^lp">
                               <field name="VAR" id="3U:fR:NTK]((S%BF:qKU" variabletype="">text</field>
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </statement>
         </block>
        </xml>
          @Uli977
           <variables>
           </variables>
             <value name="OID0">
               </shadow>
             </value>
                 <next>
                     <value name="IF0">
                         <value name="A">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                         </mutation>
                         <value name="ARG0">
                           </block>
                         </value>
                         <value name="ARG1">
                           </block>
                         </value>
                         <value name="ARG2">
                           </block>
                         </value>
                       </block>
                     </statement>
                         </mutation>
                         <value name="ARG0">
                           </block>
                         </value>
                         <value name="ARG1">
                           </block>
                         </value>
                       </block>
                     </statement>
                     <next>
                         <next>
                             <value name="IF0">
                                 <value name="A">
                                     <value name="A">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                         <value name="A">
                                             <value name="A">
                                               </block>
                                             </value>
                                             <value name="B">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <value name="B">
                                             <value name="A">
                                               </block>
                                             </value>
                                             <value name="B">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                         <value name="A">
                                             <value name="A">
                                               </block>
                                             </value>
                                             <value name="B">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <value name="B">
                                             <value name="A">
                                               </block>
                                             </value>
                                             <value name="B">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                                 </mutation>
                                 <value name="ARG0">
                                   </block>
                                 </value>
                                 <value name="ARG1">
                                   </block>
                                 </value>
                                 <value name="ARG2">
                                   </block>
                                 </value>
                               </block>
                             </statement>
                                 </mutation>
                                 <value name="ARG0">
                                   </block>
                                 </value>
                                 <value name="ARG1">
                                   </block>
                                 </value>
                               </block>
                             </statement>
                             <next>
                                 <next>
                                     <value name="IF0">
                                         <value name="A">
                                             <value name="A">
                                               </block>
                                             </value>
                                             <value name="B">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                         </mutation>
                                         <value name="ARG0">
                                           </block>
                                         </value>
                                         <value name="ARG1">
                                           </block>
                                         </value>
                                         <value name="ARG2">
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                         </mutation>
                                         <value name="ARG0">
                                           </block>
                                         </value>
                                         <value name="ARG1">
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
             <mutation>
             </mutation>
                 <value name="IF0">
                     <value name="A">
                       </block>
                     </value>
                     <value name="B">
                         <value name="OID">
                           </shadow>
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </value>
                     <value name="OID">
                       </shadow>
                       </block>
                     </value>
                       </shadow>
                       </block>
                     </value>
                       </shadow>
                     </value>
                     <next>
                         <value name="IF0">
                           </block>
                         </value>
                               </shadow>
                               </block>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </statement>
           </block>
          </xml>
          Uli977U Offline
          Uli977U Offline
          Uli977
          schrieb am zuletzt editiert von Uli977
          @paul53 .... Danke!
          -->Wenn man noch die Datenpunkt-ID und den Pushover-Text an die Funktion übergibt, kommt man mit einer Funktion aus.
          Liegt aber ausßerhalb meines Horizontes..... leider!
          Ich versuche mal das Erste herzuleiten.
          Du setzt also
          Rolloshoch an = wahr
          sonst
          Rolloshoch an = falsch (also quasi aus)
          nach Rolloshoch an (ist also der Tigger, denke ich)
          Falles Rolloshoch an ist und dies ungleich dem Datenpunkt 02_Rollos_hell ist, dann setzt eben diesen Datenpunkt auf an.
          Habe ich das halbwegs richtig erfasst?
          paul53P 3 Antworten Letzte Antwort
          • Uli977U Uli977
            @paul53 .... Danke!
            Du setzt also
            sonst
            @Uli977 sagte:
            Rolloshoch ist der Name der Funktion.
            @Uli977 sagte in Unlogisch, oder?:
            Falls der Wert von an ungleich dem Wert des Datenpunktes ist, wird der Datenpunkt auf den Wert von an (true oder false) gesetzt.
            Du setzt also
            sonst
            Der Aufruf der Funktion Rolloshoch erfolgt mit Übergabe von wahr bzw. falsch an den Funktionsparameter an.
            • Uli977U Uli977
              @paul53 .... Danke!
              Du setzt also
              sonst
              @Uli977
              Übrigens:
              • Wenn in der Zeit zwischen 20:00 Uhr und 23:00 Uhr die Helligkeit um den Wert von 105 schwankt, fahren die Rollos auf und ab.
              • Rollos in 3 Zustände zu steuern (runter / halb / hoch) ist die typische Anwendung für einen Datenpunkt vom Typ "Werteliste".
              • Uli977U Uli977
                @paul53 .... Danke!
                Du setzt also
                sonst
                @Uli977
                Beispiel mit einem Werteliste-Datenpunkt (0 = runter / 1 = halb / 2 = hoch), der nicht pendeln sollte, wenn die Helligkeit um den Grenzwert schwankt:
                 <variables>
                   <variable type="" id=":zvUsC0|Kab)@w#8FyU*">pos</variable>
                   <variable type="" id="OGmWDgWGPI,X=.mQGeRi">position</variable>
                 </variables>
                   <value name="OID0">
                     </shadow>
                   </value>
                     <block type="variables_set" id="lN5qRzU4D#}GrF6c6rw.">
                       <field name="VAR" id="OGmWDgWGPI,X=.mQGeRi" variabletype="">position</field>
                         <block type="get_value_var" id="EkukU7CWM9Cc|KlL@]((">
                           <value name="OID">
                             <shadow type="text" id="if+bcv~aJm8(_v4!N*Qt">
                               <field name="TEXT">javascript.0.Eigene_Datenpunkte.Rollos.Position</field>
                             </shadow>
                           </value>
                         </block>
                       </value>
                       <next>
                           <value name="IF0">
                               <value name="A">
                                   <value name="A">
                                       <field name="END_TIME">13:00</field>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="controls_if" id="_nvT*^^T/pjRc+Gr-G/,">
                               <value name="IF0">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                     <arg name="pos"></arg>
                                   </mutation>
                                   <value name="ARG0">
                                     <block type="math_number" id="m;Pvd1z0f6aI=)1YUv04">
                                       <field name="NUM">2</field>
                                     </block>
                                   </value>
                                   <value name="ARG1">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                               <value name="IF1">
                                   <value name="A">
                                     <block type="logic_compare" id="t0h#-RxZI7fDK%e(nSz1">
                                       <value name="A">
                                         <block type="on_source" id="g#6,(3P^*]a3Hsg[DkF.">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="P2?W7)Y|z~?CE5o?M/`u">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_compare" id="2Z#Fp+m`%vir/U1+8r9=">
                                       <field name="OP">EQ</field>
                                       <value name="A">
                                         <block type="variables_get" id="~nxV{-pa1}4sNa6=OJ(z">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="Z)r-xEtuX8.A7)Vf?,q[">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <statement name="DO1">
                                   </mutation>
                                   <value name="ARG0">
                                     <block type="math_number" id="NNmycRmhg7mIge|.//eR">
                                     </block>
                                   </value>
                                   <value name="ARG1">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                           <value name="IF1">
                             </block>
                           </value>
                             <block type="controls_if" id="20tMCwFK~z~lsj4W*Ap6">
                               <value name="IF0">
                                 <block type="logic_compare" id="kF}oo6q+KDk9.=niG$$;">
                                   <value name="A">
                                     <block type="on_source" id="#iG#-8x{3%T/A^1ZW:f0">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="qUyPku]-h{X_G8bUW]dY">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="procedures_callnoreturn" id="19HUA@=jzzD?E|C.*+Ve" inline="false">
                                   </mutation>
                                   <value name="ARG0">
                                     <block type="math_number" id="HQO5,$*Ku?$8^S2H0v|p">
                                     </block>
                                   </value>
                                   <value name="ARG1">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                               <value name="IF1">
                                 <block type="logic_operation" id="XD(}sOfU8=x%l^2V,dRn" inline="false">
                                   <value name="A">
                                     <block type="logic_compare" id="#BzXE0EML#Jxi$*eTZul">
                                       <value name="A">
                                         <block type="on_source" id="0MVZ{._bY71nK2E4B2-]">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="C@!{A@Nc+r19dvJ_]hDp">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_compare" id="1[.7Pu]|X%R--vf=Pqi7">
                                       <value name="A">
                                         <block type="variables_get" id="J?Kq4?Va0z1O0IRW!Ibg">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="2G3]iiA/3LI(fhP2!|9c">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="procedures_callnoreturn" id="ND.6MMjRv;@lp]@d}`P~" inline="false">
                                   </mutation>
                                   <value name="ARG0">
                                     <block type="math_number" id="Sk1pVsEB-cP~@8%pf.98">
                                     </block>
                                   </value>
                                   <value name="ARG1">
                                     <block type="text" id="-AYd!UVDe(Ie,-f-a6+n">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
                 <block type="procedures_defnoreturn" id="i,rn}%)D74@At@*q%T*J" x="788" y="513">
                   <mutation>
                     <arg name="pos" varid=":zvUsC0|Kab)@w#8FyU*"></arg>
                   </mutation>
                       <value name="IF0">
                           <value name="A">
                               <field name="VAR" id=":zvUsC0|Kab)@w#8FyU*" variabletype="">pos</field>
                             </block>
                           </value>
                           <value name="B">
                               <value name="OID">
                                 </shadow>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                         <block type="control_ex" id="nQNoF|lS6ca^`4v8#JBj">
                           <value name="OID">
                             </shadow>
                             <block type="text" id="Q2XXyS|E~$XT@RS:|^RM">
                             </block>
                           </value>
                             </shadow>
                             </block>
                           </value>
                             </shadow>
                           </value>
                           <next>
                             <block type="pushover" id="4|k:GHBv8v6oTYjjF68{">
                                 </shadow>
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
                </xml>
                  @Uli977 sagte:
                  Du setzt also
                  sonst
                  Uli977U Offline
                  Uli977U Offline
                  Uli977
                  @paul53 Vorab mal eben, bevor ich mir das neue Skript ansehe.
                  Das hatte ich in Anwendung und Rollo_Dämmerung und Rollo_Dunkel sind gleichzeitig bei 121 auf ein gegangen....
                  Ist da was falsch?
                  EDIT: Jetzt (20:33) wo ich nochmal auf die Datenpunkte schaue ist es richtig. Hell = false / Dämmerung = wahr / Dunkel = false (Aktuelle Helligkeit 107)
                    @Uli977
                     <variables>
                     </variables>
                       <value name="OID0">
                         </shadow>
                       </value>
                               <value name="OID">
                                 </shadow>
                               </value>
                             </block>
                           </value>
                           <next>
                               <value name="IF0">
                                   <value name="A">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                   <value name="IF0">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                       </mutation>
                                       <value name="ARG0">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <value name="IF1">
                                       <value name="A">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                       </mutation>
                                       <value name="ARG0">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                               <value name="IF1">
                                 </block>
                               </value>
                                   <value name="IF0">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                       </mutation>
                                       <value name="ARG0">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <value name="IF1">
                                       <value name="A">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                       </mutation>
                                       <value name="ARG0">
                                         </block>
                                       </value>
                                       <value name="ARG1">
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                       <mutation>
                       </mutation>
                           <value name="IF0">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="OID">
                                     </shadow>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                               <value name="OID">
                                 </shadow>
                                 </block>
                               </value>
                                 </shadow>
                                 </block>
                               </value>
                                 </shadow>
                               </value>
                               <next>
                                     </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                    </xml>
                    Uli977U Offline
                    Uli977U Offline
                    Uli977
                    @paul53 Alles klar....
                    Hab es jetzt so umgesetzt, vielleicht kannst du dir das mal ansehen.
                    Das von dir
                    Das entsprechende Programm für das Rollo dazu.
                    • Uli977U Offline
                      Uli977U Offline
                      Uli977
                      @paul53 Ich habe noch eine Frage....
                      Dieses Rollo soll nie auf halb fahren und erst frühestens um 20:30 Uhr komplett zu.
                      Im Sommer natürlich nur wenn Position 0 (runter) gesetzt ist, von mir aus auch erst um 22:30 Uhr.
                      Im Winter aber nicht vor 20:30 Uhr, auch nicht wenn zu diesem Zeitpunkt die 0 bereits um z.B. 17 Uhr erreicht wurde.
                      Wie baue ich das am Besten ein?
                      So?
                      • Uli977U Offline
                        Uli977U Offline
                        Uli977
                        @paul53 Mir ist gerade was eingefallen....
                        Ich habe Rollos welche bei der morgendlichen Dämmerung hoch fahren sollen und ich habe welche die dies nicht tun sollen (Schlafräume).
                        Benötige ich dann nicht sogar 4 Zustände?
                        0 = Dunkel = runter
                        1 = Dämmerung Morgen = halb
                        2 = Dämmerung Abend = halb
                        3 = Hell = hoch
                        Oder mache ich das so?
                        Eine zusätzliche Zeit > 16:30 reinbringen
                        • Uli977U Uli977
                          0 = Dunkel = runter
                          3 = Hell = hoch
                          @Uli977 sagte:
                          Das kann man machen, denn man muss ja nur zwischen morgens und abends unterscheiden. Allerdings sind zu viele Abfragen mehrfach enthalten. Verwende besser geschachtelte falls-Blöcke.
                            @Uli977 sagte:
                            Uli977U Offline
                            Uli977U Offline
                            Uli977
                            @paul53 Was meinst du? Besser einen vierten Zustand, oder besser mit der Zeit arbeiten?
                             <block type="on_ext" id="RE]*yf?BO+D1I2Q[vtL=" x="1063" y="63">
                               <value name="OID0">
                                 <shadow type="field_oid" id="*Os]pxbYo2/_^AApvlh.">
                                   <field name="oid">javascript.0.Eigene_Datenpunkte.Rollos.01_Rollo_Position</field>
                                 </shadow>
                               </value>
                                 <block type="comment" id="*}1Wyj(wAQb/%8BDX3Q9">
                                   <field name="COMMENT">Dämmerung - Halb hoch (1)</field>
                                   <next>
                                     <block type="comment" id="cU-VqW@Shvwji(qp2=a%">
                                       <field name="COMMENT">Schlafz.Fenster.Links</field>
                                       <next>
                                         <block type="controls_if" id="17VH7cRk;:i$z=`sFFsA">
                                           <value name="IF0">
                                             <block type="logic_operation" id="$*8}tibLROsi(!qV;x`)" inline="false">
                                               <value name="A">
                                                 <block type="logic_operation" id="Y91Q?AZT[,lCf|Dtt3EG" inline="false">
                                                   <value name="A">
                                                     <block type="logic_operation" id="pq,ApZMq?|[|l91R?gdg" inline="false">
                                                       <value name="A">
                                                         <block type="logic_compare" id="9T1TKc9f9._|sPFvao8L">
                                                           <value name="A">
                                                             <block type="get_value" id="z1SjRq;QUcDmtYKge6Yo">
                                                               <field name="OID">hm-rega.0.42948</field>
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="logic_boolean" id="}|O`{[vIo7d[^mn1`/R:">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         <block type="logic_compare" id="*$4n:FsuO0LCEqq$6dPS">
                                                           <value name="A">
                                                             <block type="get_value" id="F,)EkXq;DV%:tD^sKi5U">
                                                               <field name="OID">javascript.0.Eigene_Datenpunkte.Rollos.01_Rollo_Position</field>
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="math_number" id="ZIq^vw#.m:.nG}wXegT;">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="time_compare" id="L@t]G$kl!:apSEp-JX4^">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="logic_compare" id="Lf+Qc^C+``Cs$V2[jP1U">
                                                   <value name="A">
                                                     <block type="get_value" id="@?bW4K4wh3Sa9U6eB=a4">
                                                       <field name="OID">hm-rpc.1.OEQ1971970.1.LEVEL</field>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="math_number" id="|aH~^d7LVBFO320L]q(a">
                                                       <field name="NUM">55</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                             <block type="control" id="9KPYk#V?%PG9fKSbj7(X">
                                               <mutation delay_input="true"></mutation>
                                               <field name="DELAY_MS">6</field>
                                                 <block type="math_number" id="{z),lML{ioh^b2nJ?^5;">
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="comment" id="@d`*vMQ4,!;K.7*4%O`[">
                                               <field name="COMMENT">Schlafz.Fenster.Rechts</field>
                                               <next>
                                                 <block type="controls_if" id=")#]MF=75UZ0~/=(]iTni">
                                                   <value name="IF0">
                                                     <block type="logic_operation" id="`-u1?O$m=dq#7aum3.1w" inline="false">
                                                       <value name="A">
                                                         <block type="logic_operation" id="%QkIV2-}2!:qDTG9(#b[" inline="false">
                                                           <value name="A">
                                                             <block type="logic_operation" id="W59ckgPktK/BxcZnVp@6" inline="false">
                                                               <value name="A">
        <block type="logic_compare" id="X4m%J?93au/u92/;PrrY">
        <value name="A">
        <block type="get_value" id="(;tMmF)0:u7~HlnKoVUl">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="MvE~?qtNE18YQ@$rbMii">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <value name="B">
        <block type="logic_compare" id="?w)Z:!hwc383RX%]-R^+">
        <value name="A">
        <block type="get_value" id="!|[wXeKcrxz-tt{AS#(V">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="QY.@s3}%C@l$C`a|(2uO">
        </block>
        </value>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="time_compare" id=":3BH;V5)lZOAX%4`rm~U">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         <block type="logic_operation" id="hnbc(O:O$p]yUwVus@Z0" inline="false">
                                                           <value name="A">
                                                             <block type="logic_compare" id="ORZCYitd*|X0S:]T,c}b">
                                                               <value name="A">
        <block type="get_value" id="Z30=vxRu3Hc%cf48}@N_">
        <field name="OID">hm-rpc.1.MEQ0951207.1.STATE</field>
        </block>
                                                               </value>
                                                               <value name="B">
        <block type="logic_boolean" id="aOPW`*|DV!`nKAXQhu@D">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="logic_compare" id="NfC5s[HuL$Ep/rlJRK+%">
                                                               <value name="A">
        <block type="get_value" id="w=.J/=wPSfqLxeUn+`W[">
        <field name="OID">hm-rpc.1.OEQ1971956.1.LEVEL</field>
        </block>
                                                               </value>
                                                               <value name="B">
        <block type="math_number" id="B[hes~zQ+2*3qGn9Il.-">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                     <block type="control" id="[OR9bp?*gnQp6.43LJ)R">
                                                       <field name="DELAY_MS">7</field>
                                                         <block type="math_number" id="SKK|-q|UV`Qqo~f+S$#c">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                     <block type="comment" id="6Bo*LLHn~v)D/;i^70t*">
                                                       <field name="COMMENT">Dunkel - Komplett runter (0)</field>
                                                       <next>
                                                         <block type="comment" id="g1]h+rZ?tW.iMGtW@(@/">
                                                           <next>
                                                             <block type="controls_if" id="@~61uCYR@I@Pd1Ur+l5!">
                                                               <value name="IF0">
        <block type="logic_operation" id=",qK:e_V3Sq{Janyn26fx" inline="false">
        <value name="A">
        <block type="logic_operation" id="}DR+mJ1kMAXAFVGSt|+," inline="false">
        <value name="A">
        <block type="logic_compare" id="**a/UcEfJD2VG*v]+f~:">
        <value name="A">
        <block type="get_value" id="(TP-8}-1S1.j!n{ipH-x">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="t=G`W/p0C|:vP-B#;AGX">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="4%[6SC6SLc_8bD_K*QZ|">
        <value name="A">
        <block type="get_value" id="GMdP$m~[t|nHxdo?|oY}">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="[1R/TB]9SLqBOMY9bG[a">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="|U`]UITrUq{09#_7@Fs|">
        <value name="A">
        <block type="get_value" id="?sj,uS~HV3wRtFZz.A]Z">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="BQAGE!l*BZl*BGZJ#]Jw">
        </block>
        </value>
        </block>
        </value>
        </block>
                                                               </value>
        <block type="control" id="`NzZ2B;P59!2|O/^()cL">
        <block type="math_number" id="!@(hgo%5{%=Z2OTe@#*#">
        </block>
        </value>
        </block>
                                                               </statement>
                                                               <next>
        <block type="comment" id=",4m4P1~FFQSsDQL[;%c*">
        <next>
        <block type="controls_if" id="T4yGf4Z59;i2ov$.7p@w">
        <value name="IF0">
        <block type="logic_operation" id="%C7i5H(}!Y0/3Y1@XqN:" inline="false">
        <value name="A">
        <block type="logic_operation" id="GfJ8%xnO6WuI%Gh]`YL;" inline="false">
        <value name="A">
        <block type="logic_compare" id="7FBgyvzGJRNTkn0Mi:++">
        <value name="A">
        <block type="get_value" id=")mi814u;Bsf~pGn0m3Bo">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id=":7P],?l}w4G4PD,#^$2{">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="]zM,qp5ZpV@Tr1V{l5T{">
        <value name="A">
        <block type="get_value" id="=F6Ed2@Lty,cDO]Ke@yo">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="b?w$^S3hu[7:/uIg:3`P">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_operation" id="p*~4-qX?REf{=heDuJAq" inline="false">
        <value name="A">
        <block type="logic_compare" id="DbE~+[lg--DOSU5*@jn3">
        <value name="A">
        <block type="get_value" id="Sl[fICYe(LQxD9d#,$m7">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="H`l*qu-v7.)E%B;UD!,P">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="79P|t8_C(W}j3UAkxoKM">
        <value name="A">
        <block type="get_value" id="3QI8jUOe,$Q)=b=5KObC">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="@D|#t@^]ku+oX_n$1h%n">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="{6Ar^m$Z[8muQR]QzC-Q">
        <block type="math_number" id="W%@a_Xr`qylt;%|I7DJ+">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                            </xml>
                            Falls du noch Lust hast mir das zu zeigen.....
                            • Uli977U Uli977
                                 <value name="OID0">
                                   </shadow>
                                 </value>
                                     <next>
                                         <next>
                                             <value name="IF0">
                                                 <value name="A">
                                                     <value name="A">
                                                         <value name="A">
                                                             <value name="A">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                             <value name="A">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </statement>
                                             <next>
                                                 <next>
                                                     <value name="IF0">
                                                         <value name="A">
                                                             <value name="A">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                             <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                         <next>
                                                             <next>
        <value name="IF0">
        <value name="A">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <next>
        <value name="IF0">
        <value name="A">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                               </block>
                              </xml>
                              @Uli977 sagte:
                                @Uli977 sagte:
                                Uli977U Offline
                                Uli977U Offline
                                Uli977
                                @paul53 Schickst du mir das ?
                                • Uli977U Uli977
                                  @Uli977 sagte:
                                   <block type="on_ext" id="_B=],f#1:Sva2,+0gG-}" x="62" y="62">
                                     <value name="OID0">
                                       <shadow type="field_oid" id="t~._%qK0mPtx8u~gs_nf">
                                       </shadow>
                                     </value>
                                       <block type="controls_if" id="apK0_SG78fSuhnMDrU_.">
                                         <value name="IF0">
                                           <block type="get_value" id="Ix#uV$aTN+~E%f#`}zoJ">
                                             <field name="OID">ID auswählen</field>
                                           </block>
                                         </value>
                                           <block type="controls_if" id="KBQ._8.Tc%mVZChv=|a|">
                                             <value name="IF0">
                                               <block type="logic_operation" id="js7G7ZpJ__-kBa#,d~*!" inline="false">
                                                 <value name="A">
                                                   <block type="logic_compare" id="F%?mDp(XL-d,ZE6);U|h">
                                                     <value name="A">
                                                       <block type="on_source" id="n1FiuR-`%#`@l-x]n{^$">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       <block type="math_number" id="Jtj=*i6@Nf1JwFL]X7mx">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   <block type="time_compare" id="P2(C5~6:du=hB6I-oG^[">
                                                     <field name="START_TIME">12:00</field>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                               <block type="control" id="Kyd~nM=zFo%2.;`?Qckb">
                                                   <block type="math_number" id="mt^?FDzsp|dN/M}DX@Dy">
                                                   </block>
                                                 </value>
                                                 <next>
                                                   <block type="controls_if" id="#eY0?3@+NqZn0U9WvG6$">
                                                     <value name="IF0">
                                                       <block type="logic_negate" id="*DDSIqw=lb7JSg$1nbu/">
                                                         <value name="BOOL">
                                                           <block type="get_value" id="C*n,ocvxWPnzol5.n!u%">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                       <block type="control" id="19%L]|Rt%%2gLMn~KeGx">
                                                           <block type="math_number" id="w(XM1h:j.^CP`C~CUV~c">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                               <block type="controls_if" id="Q[hM9}qN{n|b0K4eq%/$">
                                                 <value name="IF0">
                                                   <block type="logic_compare" id="8d9zdX)?Zrp0,]@TVB#6">
                                                     <value name="A">
                                                       <block type="on_source" id="~^U!t66JUGdQe:pp.fDr">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       <block type="math_number" id="HS`9kkLA^68R(#H;5%yT">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                   <block type="control" id="QTdR.o)Xr(|V-j:*~u.d">
                                                       <block type="math_number" id="qd5p12Fi)k@]Y)kIvDA*">
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="controls_if" id="$GB!aRkQzywDAC{mZNHh">
                                                         <value name="IF0">
                                                           <block type="logic_negate" id="l0twpu^Hw~d^eBA=k]4N">
                                                             <value name="BOOL">
                                                               <block type="get_value" id="N4Ge*1TTHFX+qCxG:-=T">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                           <block type="control" id="-han6870cW^8cyY=-4$]">
                                                               <block type="math_number" id="Y}!b=o/8B,_W},PLj[g[">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                   <block type="comment" id="w(dtxDu5Q8`p-7UuDl%i" x="338" y="113">
                                     <field name="COMMENT">Automatic</field>
                                   </block>
                                   <block type="comment" id="N^R,B0d[zyq3R__SlT8X" x="562" y="262">
                                     <field name="COMMENT">Fenster</field>
                                   </block>
                                  </xml>
                                    @Uli977 sagte:
                                       <value name="OID0">
                                         </shadow>
                                       </value>
                                           <value name="IF0">
                                             </block>
                                           </value>
                                               <value name="IF0">
                                                   <value name="A">
                                                       <value name="A">
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                       <value name="IF0">
                                                           <value name="BOOL">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <next>
                                                   <value name="IF0">
                                                       <value name="A">
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                           <value name="IF0">
                                                               <value name="BOOL">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
        </block>
                                                               </value>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                     </block>
                                     </block>
                                    </xml>
                                    Uli977U Offline
                                    Uli977U Offline
                                    Uli977
                                    @paul53 Danke, ich baue das mal ein.
                                    • Uli977U Uli977
                                      Uli977U Offline
                                      Uli977U Offline
                                      Uli977
                                      So?
                                      Was bewirkt dieser Teil?
                                      • Uli977U Uli977
                                        So?
                                        @Uli977 sagte:
                                        Die Abfrage von LEVEL ist falsch, sondern das Fenster muss geschlossen sein (nicht Fenster offen) für das Rollo rechts, so wie in Deinem ursprünglichen Script.
                                        • Uli977U Uli977
                                          So?
                                          @Uli977 sagte:
                                          So?
                                          Was soll der Zeitplan-Trigger ?
                                          Für das Wohnzimmer:
                                          Uli977U 2 Antworten Letzte Antwort
