  4. Projekt WetterView von sigi234
    6.6k
wetter wetterview sigi234
497 Beiträge 60 Kommentatoren 195.7k Aufrufe 83 Beobachtet
  • D drapo
    @Oli hab jetzt einen downgrade des adapters gemacht. Da funktioniert es ja noch
    O Offline
    O Offline
    Oli
    #409
    @drapo
    ich habe eine Lösung gefunden, versuche mal folgendes Widget:
    [{"tpl":"tplTimeValue","data":{"oid":"dwd.0.warning.begin","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"format_date":"DD.MM.YYYY hh:mm:ss","html_prepend":"Beginn: ","html_append":" Uhr","visibility-oid":"dwd.0.warning.severity"},"style":{"left":"15px","top":"136px","width":"177px","height":"15px","z-index":"1","color":"#8f8f8f","text-align":"center","font-size":"x-small"},"widgetSet":"basic"}]
    Oliver
    • O Oli
      @drapo
      drapo
      #410
      @Oli du hast es neu eingefügt? Das bestehende kann man nicht anpassen??
      O 1 Antwort Letzte Antwort
      • D drapo
        O Offline
        O Offline
        Oli
        #411
        @drapo
        nein, das ist TimestampValue Widget
        Oliver
        • sigi234S sigi234
          @rehmosch
          Die DP kommen vom Adapter,wenn du neue anlegst wird es nix bringen das sie nicht befüllt werden.
          gerald123
          #412
          @sigi234
          Hallo sigi234,
          Ich benutze die WetterView von dir im Projekt als Main View.
          Jetzt ist mir aufgefallen, wenn ich am Tablett auf eine andere View wechsle und dort die Anzeige verschiebe, es immer wieder auf die Main zurück spring.
          Ist da im Hintergrund etwas eingestellt?
          Kann ich das irgendwo ausschalten oder die Zeit verlängern bis das es wieder auf die Main View spring.
          Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
          • G gerald123
            @sigi234
            Hallo sigi234,
            sigi234S Online
            sigi234S Online
            #413
            @gerald123
            Schau mal unter Tools ob da ein Haken ist bei Default. Dieser Effekt kommt auch vor wenn bei den Views mehrere auf default gestellt sind.
            G 1 Antwort Letzte Antwort
            • sigi234S sigi234
              @gerald123
              gerald123
              #414
              @sigi234 Darf da nur bei Main ein Haken sein?
              Kann man irgendwo einstellen ob nach einer eingestellten Zeit wieder auf Main zurückgesprungen wird
              • G gerald123
                sigi234S Online
                sigi234S Online
                #415
                @gerald123 sagte in Projekt WetterView von sigi234:
                https://www.iobroker.net/#de/documentation/viz/vis.md
                Unter Visualisierung und Punkt 7
                • sigi234S sigi234
                  gerald123
                  #416
                  @sigi234 Hab mal die Haken raus gegeben, hat leider nichts verändert.
                  Sobald ich die View verschiebe dann spring er auf Main zurück
                  • G gerald123
                    sigi234S Online
                    sigi234S Online
                    #417
                    Noch immer?
                    • sigi234S sigi234
                      Noch immer?
                      gerald123
                      #418
                      @sigi234 ja, leider immer noch
                        bullemausberlin
                        #419
                        Ein Hallo in die Runde.
                        Als blutiger Anfänger, des sich erst seit rund vier Wochen mkt ioBroker befasst, habe ich mich dann auch an eine Visualisierung gewagt und bin dabei auch auf dieses Projekt gestossen. Dafür ers einmal BESTEN DANK an sigi234 und all' die anderen die an dem Projekt mitgearbeitet haben. Ich habe das Projekt importiert und dann nach der Anleitung Schritt für Schritt eingerichtet. Aber ein ein paar Stellen komme ich nicht weiter. Vielleicht habe ich auch etwas übersehen und es kann mir hier jemand einen Tipp geben.
                        1. Wetterwarnungen DWD: Hier werden als Beginn und Ende irgendwelche Zahlenreihen angezeigt (siehe Screenshot). Muss ich da im Script noch etwas anpassen? Dann erscheint für eine zweite Warnung in den entsprechenden Feldern der Wert "null". Kann man das ausblenden?
                        2. Den Balkenverlauf für die Zeit im Feld neben der Wetterwanung DWD (unterhalb der Regenmengen) habe ich nicht "zum laufen" gebracht. Habe ich da einen Adapter vergessen?
                        3. Wetterwarnungen UWZ: Hier habe ich bisher nichts angezeigt bekommen. Muss ich da im Script etwas anpassen? Oder gab es evtl. keine Warnung der UWZ, weil Frost (siehe DWD) nicht genung Unwetter war?!
                        4. Was ich überhaupt hinbekommen habe, ist Daten von Weatherunderground abzurufen. Eigentlich habe ich alle Einstellungen im Adapter "durchgespielt". Als Ort habe ich auf dem Screenshot eine nahegelegene Station ausgewählt. Ich habe dort auch die Koordinaten als Alternative probiert. Auch habe ich einen API-Key generiert und es sowohl mit, als auch ohne API probiert. Alles ohne Erfolg. Ich habe da jetzt keine Idee mehr bzw. für die korrekte Auswertung der Fehlermeldung in den log's fehlt mir das Wissen.
                        Für Tipps und Hilfe bendake ich mich schon einmal.
                        • B bullemausberlin
                          sigi234S Online
                          sigi234S Online
                          #420
                          @bullemausberlin
                          Dieses Projekt ist nicht mehr aktuell.
                          Schau dir die Neue Version an, bei meinen alten Projekt wurde zu viel geändert.
                          Übrigens Weatherunderground geht nicht mehr! Nimm den DasWetter Adapter.
                          Für die Wetterwarungen gibt es ein neues Skript:
                          https://forum.iobroker.net/topic/30616/script-dwd-uwz-nina-warnungen-als-push-sprachnachrichten
                          • sigi234S sigi234
                            @bullemausberlin
                            bullemausberlin
                            #421
                            @sigi234 uups. Habe ich auf die falsche Seite gestellt.
                            Habe m.E. das aktuelle Projekt von der "neuen" Seite gedownloadet und genutzt.
                            Weatherunderground - habe ich mir schon gedacht.
                            Nur das mit dem Zeitbalken habe ich dann noch nicht kapiert.
                            • B bullemausberlin
                              sigi234S Online
                              sigi234S Online
                              #422
                              @bullemausberlin sagte in Projekt WetterView von sigi234:
                              Der Balken läuft einfach mit der aktuellen Zeit mit.
                              Das Skript dafür:
                              createState("Zeitplanung.Uhrzeit.Minuten", 0);
                              schedule('*/1 * * * *', function TimeToMinutes() {
                                  var a = new Date();
                                  var h = a.getHours();
                                  var m = a.getMinutes();
                                  var timeInMinutes= h*60+m;
                                  setState("Zeitplanung.Uhrzeit.Minuten", timeInMinutes);
                              • H Offline
                                Hausbaer
                                #423
                                Guten Morgen,
                                ich kämpfe als Newbie iimmer noch mit den HD BIldern.
                                ![Bild Text](b0d57ebe-69c5-42c9-b45e-e64641bf29e7-grafik.png Bild Link)
                                Die Links im Adapter sollten eigentlich passen
                                ![Bild Text](351dc612-0946-42c1-a438-d43915901016-grafik.png Bild Link)
                                Natürlich hab ich dieses ganze Thema schon durchgelesen und bin darauf gestoßen:
                                Bild Text
                                Nur: Wie bekomme ich die Auswahlliste auf der rechten Seite? Ich krieg das nicht gebacken.
                                Kann mir das jemand erklären?
                                • H Hausbaer
                                  Guten Morgen,
                                  Bild Text
                                  sigi234S Online
                                  sigi234S Online
                                  #424
                                  @Hausbaer sagte in Projekt WetterView von sigi234:
                                  Das ist alt
                                  Nimm das Widget( Tag 1):
                                  [{"tpl":"tplValueStringImg","data":{"oid":"daswetter.0.NextDays.Location_1.Day_1.iconURL","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Wetter_Sigi/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Wetter_Sigi/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Wetter_Sigi/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Bild Tag 1","filterkey":"Bilder","comment":"DasWetter"},"style":{"left":"38px","top":"152px","width":"146px","height":"100px","z-index":"7"},"widgetSet":"basic"}]
                                  Mond:
                                  [{"tpl":"tplValueStringImg","data":{"oid":"daswetter.0.NextHours.Location_1.Day_1.moonIconURL","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Wetter_Sigi/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Wetter_Sigi/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Wetter_Sigi/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Bild Mond","filterkey":"Bilder","comment":"DasWetter"},"style":{"left":"1071px","top":"154px","width":"115px","height":"109px","z-index":"7"},"widgetSet":"basic"}]
                                  H 1 Antwort Letzte Antwort
                                    klausiob
                                    #425
                                    Hallo @sigi234 Ich benutze ja schon sehr lange deine tolles WetterView. Bin aber jetzt dabei eine VIS-View fürs Handy zu machen. Gibt es da etwas ähnliches tolles?
                                    Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                                    node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                                    • K klausiob
                                      sigi234S Online
                                      sigi234S Online
                                      #426
                                      @klausiob sagte in Projekt WetterView von sigi234:
                                      Nein, aber das basiert auf meiner View:
                                      https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view
                                      • sigi234S sigi234
                                        Das ist alt
                                        Mond:
                                        Hausbaer
                                        #427
                                        @sigi234 Danke für den Hinweis.
                                        Läuft aber trotzdem nicht 😢
                                        • H Hausbaer
                                          sigi234S Online
                                          sigi234S Online
                                          #428
                                          Du hast beim Wetter Adapter ein LEERZEICHEN drinnen. Auch bei Mond!
                                          Adapter Neu starten, bis das Verzeichnis Richtig kommt. Dauert einen Weile.
                                          Falsch:
                                          /vis. 0
                                          Richtig:
                                          /vis.0
