  4. Restore funktioniert nicht
101 Beiträge 19 Kommentatoren 21.4k Aufrufe 7 Beobachtet
  • R Offline
    r0b1zZle
    Gibt es irgendwie die Möglichkeit, wenigstens an die Scripte und Blocklys zu kommen?
    • R r0b1zZle
      @simatec Du meinst das was ich oben als bereits gemacht aufgeführt habe?
      curl -sL https://iobroker.net/fix.sh | bash -
      und das howto zum Restore?
      Update:
      pi@raspberrypi4-iob:/opt/iobroker $ sudo apt-get update
      pi@raspberrypi4-iob:/opt/iobroker $ sudo apt-get install redis-server
      pi@raspberrypi4-iob:/opt/iobroker $ sudo usermod -a -G redis iobroker
      pi@raspberrypi4-iob:/opt/iobroker $ sudo reboot now
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker stop
      pi@raspberrypi4-iob:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2020-01-30
          Welcome to the ioBroker installation fixer!
          Script version: 2020-01-25
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_10.x buster InRelease
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi4-iob:/opt/iobroker $ sudo apt-get install htop
      htop ist schon die neueste Version (2.2.0-1).
      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 4 nicht aktualisiert.
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker status
      iobroker is not running on this host.
      No iobroker host is running.
      Objects type: file
      States  type: file
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker restore 2020_02_27-19_30_02_backupiobroker
      host.raspberrypi4-iob Cannot extract from file "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/2020_02_27-19_30_02_backupiobroker.tar.gz"
      host.raspberrypi4-iob Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
      iobroker controller daemon is not running
      host.raspberrypi4-iob OK.
      (node:2349) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
          at Object.openSync (fs.js:443:3)
          at Object.readFileSync (fs.js:343:35)
          at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
          at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:846:22)
          at Daemon.emit (events.js:203:15)
          at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
          at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
          at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:848:20)
      (node:2349) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      (node:2349) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      simatecS Offline
      simatecS Offline
      simatec
      @r0b1zZle
      Lief dein System vorher mit redis? Wenn ja wie genau?
      Object=redis/file=redis?
      Dann muss du zuerst das redis backup wiederherstellen und dann im Anschluss iobroker
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      R 1 Antwort Letzte Antwort
      • simatecS simatec
        @r0b1zZle
        r0b1zZle
        @simatec Nein, es lief ohne redis
        • R r0b1zZle
          simatecS Offline
          simatecS Offline
          simatec
          @r0b1zZle
          hmmm warum installierst du dann redis?
          Mache mal bitte folgendes ...
          Lege das Backup mal in den Ordner Backups und führe folgendes aus
          sudo chmod 777 /opt/iobroker/backups/*
          iobroker restore 0
          iobroker start
          • simatecS simatec
            @r0b1zZle
            iobroker restore 0
            iobroker start
            r0b1zZle
            schrieb am zuletzt editiert von r0b1zZle
            @simatec Weil in der Anleitung folgendes stand:
            *"Steht in Objects type und/oder States type "redis", müsst ihr zwingend auf dem neuen System den Redis Server installieren.
            Steht hingehen bei beiden Typen "file", wird der Redis Server nicht benötigt.
            Solltet ihr keinen Zugriff mehr auf das alte System haben und ihr wisst nicht, was da vorher genau konfiguriert war, dann installiert auf jeden Fall den Redis-Server im Vorfeld."*
            Das hatte ich auch bereits getestet, gleiches Problem:
            pi@raspberrypi4-iob:~ $ iobroker stop
            pi@raspberrypi4-iob:~ $ sudo chmod 777 /opt/iobroker/backups/*
            pi@raspberrypi4-iob:~ $ iobroker restore 0
            host.raspberrypi4-iob Using backup file 2020_03_29-14_00_46_backupiobroker.tar.gz
            host.raspberrypi4-iob Cannot extract from file "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/2020_03_29-14_00_46_backupiobroker.tar.gz"
            (node:7864) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
            (node:7864) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
            (node:7864) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            • R r0b1zZle
              Update:
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              Objects type: file
              States  type: file
              Jan1
              @r0b1zZle sagte in Restore funktioniert nicht:
              Objects type: file
              States type: file
              Ja lesen und auch das machen was da steht und bei DIr im LOg steht eben sehr deutlich 2x file ;-)
              • R r0b1zZle
                simatecS Offline
                simatecS Offline
                simatec
                Du sagtest aber du hast vorher keinen Redis Server gehabt ...
                Mal ne ganz andere Frage. Wie hast du iobroker installiert?
                Das sieht nach einem generellen Problem aus, was durch eine falsche Installation auftreten kann.
                • J Jan1
                  Objects type: file
                  States type: file
                  r0b1zZle
                  @Jan1 Ist richtig, das bezieht sich aber auf die aktuelle Installation von Iobroker. Wie gesagt, habe ich den Raspy gestern geplättet und war mir nicht mehr sicher, ob ich redis überhaupt installiert hatte oder nicht (und das habe ich soweit ich weiß, nicht gemacht). In der HowTo stand aber, wenn man sich unsicher ist, auf jeden fall redis trotzdem installieren, was ich gemacht habe.
                  @simatec IoBroker habe ich wie in seinem Video installiert:
                  sudo apt-get update
                  sudo apt-get upgrade
                  sudo raspi-config /* hier den hostname geändert */
                  curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                  sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                  curl -sL https://iobroker.net/install.sh | bash -
                  J simatecS 2 Antworten Letzte Antwort
                  • R r0b1zZle
                    sudo apt-get update
                    Jan1
                    @r0b1zZle
                    Oh je, ne externe Anleitung und hier Support dafür wollen, wenn das Homoran sieht.
                    Oben ist die Doku und die ist aktuell, alles andere kann, muss aber nicht stimmen.
                    • R r0b1zZle
                      sudo apt-get update
                      simatecS Offline
                      simatecS Offline
                      simatec
                      man
                      Dann setze noch mal neu auf und mach folgendes ...
                      Komplett neues Image nehmen .... nicht die jetztige Installation
                      sudo apt install -y nodejs
                      sudo reboot now
                      iobroker stop
                      iobroker backup
                      // backup in den Ordner /opt/iobroker/backups legen und die Rechtevergabe kontrollieren
                      iobroker restore Dateiname-Backupdatei
                      iobroker start
                      Alternativ den restore mit backitup ausführen
                      • simatecS simatec
                        man
                        sudo reboot now
                        iobroker stop
                        iobroker backup
                        iobroker start
                        r0b1zZle
                        @simatec Raspy komplett neu aufgesetzt, ansonsten nichts weiter außer dem, was du geschrieben hast, gleiches Ergebnis:
                        dietpi@pi:~$ sudo iobroker restore 2020_02_27-19_30_02_backupiobroker.tar.gz
                        host.pi Cannot extract from file "/opt/iobroker/node_modules/iobroker.js-control ler/lib/setup/../../../../backups/2020_02_27-19_30_02_backupiobroker.tar.gz"
                        host.pi Cannot find extracted file from file "/opt/iobroker/node_modules/iobroke r.js-controller/tmp/backup/backup.json"
                        host.pi OK.
                        (node:1349) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or dir ectory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backu p.json'
                            at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-co ntroller/lib/setup/setupBackup.js:566:23)
                            at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/s etup/setupBackup.js:846:22)
                            at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246: 14)
                            at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:1 7)
                            at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/se tup/setupBackup.js:848:20)
                            at process._tickCallback (internal/process/next_tick.js:68:7)
                        (node:1349) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This  error originated either by throwing inside of an async function without a catch  block, or by rejecting a promise which was not handled with .catch(). (rejection  id: 1)
                        (node:1349) [DEP0018] DeprecationWarning: Unhandled promise rejections are depre cated. In the future, promise rejections that are not handled will terminate the  Node.js process with a non-zero exit code.
                        • harrymH Offline
                          harrymH Offline
                          harrym
                          ist da echt ein leerzeichen drinnen????? (backu p.json)
                          ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                          • R r0b1zZle
                            host.pi OK.
                            simatecS Offline
                            simatecS Offline
                            simatec
                            @r0b1zZle Mach mal den Restore ohne sudo
                            • R r0b1zZle
                              host.pi OK.
                              simatecS Offline
                              simatecS Offline
                              simatec
                              host.pi OK.
                              Hast du andere Befehle auch mit sudo ausgeführt? Das hatte ich so nicht geschrieben
                              • harrymH harrym
                                r0b1zZle
                                @harrym nein, das kommt weil ich die Console größer gezogen habe und beim Kopieren jetzt die Zeilenumbrüche nochmal als Leerzeichen gesetzt wurden.
                                @simatec Nein, nur das backup, weil keine Berechtigung.
                                dietpi@pi:~$ iobroker restore 2020_02_27-19_30_02_backupiobroker.tar.gz
                                [sudo] Passwort für dietpi:
                                Leider darf der Benutzer dietpi »/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js restore 2020_02_27-19_30_02_backupiobroker.tar.gz« als iobroker auf pi nicht ausführen.
                                PS: Das neue Backup kann ich ohne Probleme wieder einspielen.
                                • R r0b1zZle
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @r0b1zZle
                                  Gut dann stimmen deine rechte da definitiv nicht und hast ein ganz anderes Problem ...
                                  • simatecS simatec
                                    @r0b1zZle
                                    r0b1zZle
                                    @simatec Dann habe ich wohl Pech gehabt, vielen Dank trotzdem für die ausführliche Hilfe! Dann muss ich eben alle Scripte neu schreiben und das nächste Mal noch einmal separat wegspeichern, falls wieder so ein Fall eintritt.
                                    • R r0b1zZle
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @r0b1zZle Nein du hast du nur etwas falsch gemacht.
                                      Laut der Anleitung wie ich sie geschrieben habe, kann dieser fehler nicht auftreten.
                                      Mache es nach Anleitung. Habe gerade heute genau so einen iobroker so aufgesetzt und der läuft tadellos
                                      • simatecS simatec
                                        r0b1zZle
                                        @simatec Habe es heute nochmals neu aufgesetzt, mit raspbian lite und diesmal brauchte ich kein "sudo". Konnte alle Befehle exakt genau so eintragen, wie du sie oben gepostest hast, Ergebnis: gleicher Fehler wie vorher. Kann es sein, dass man die Backups durch das Zwischenspeichern auf dem Windows-Rechner irgendwie zerschießt oder die Rechte ändert? Ein Backup, das ich gestern erst erstellt habe, testete ich ebenfalls zu restoren, gleicher Fehler. Was alle Backups gemein hatten, war, dass sie eben auf meinem Windows-PC zwischengespeichert wurden.
                                        HomoranH simatecS 2 Antworten Letzte Antwort
                                        • R r0b1zZle
                                          ja!
                                          wenn du sie mit WIN-SCP oder filezilla auf den Pi kopierst haben sie wahrscheinlich die Rechte des Users, mit dem du dich da anmeldest, und nicht des users ioBroker
                                          kannst dir ja mal die Rechte (bei filezilla) ansehen
