  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.8k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    Aktuelle Test Version 0.6.9
    Veröffentlichungsdatum 22-03-2021
    Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
    NPM npm i ioBroker.coronavirus-statistics@latest
    Adapter to show Global Corona Virus information and current reports
    Coronavirus Live Statistics adapter for ioBroker
    There is no configuration required, after installation it will :
    • Receive global information world-wide and write it to "global_totals"
    • Create a folder for each country with all relevant information regarding COVID-19
    • Update the information every 15 minutes
    The following information is available :
    Datapoint Details
    active Amount of current infected people
    cases Amount of totally known cases
    casesPerOneMillion Amount of totally known cases per million citizen
    critical Amount of critical situation (Hospitalized)
    deaths Amount of current registered deaths
    deathsPerOneMillion Amount of current registered deaths per million citizen
    recovered Amount of totally known recovered cases
    todayCases New Cases by Today
    todayDeaths Amount of totally known people died today
    test Total number of covid-19 tests taken globally
    tests per one million counties Total number of covid-19 tests taken globally per one million
    Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
    German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
    Generic Source : https://coronavirus-19-api.herokuapp.com
    Advanced settings
    Option Description
    All Countries Get data for all countries World-Wide (Default: false)
    Continents Group total amounts by continent in seperate state (Default: false)
    Delete unused States Delete data when countries are deselected (Default: false)
    German counties Get counties data for Germany (Selected only, Default false)
    German federal states Get federal state data for Germany (Selected only, Default false)
    Get all German federal states Get federal state data for Germany (Default false)
    Get all German counties Get all counties data for Germany (Default false)
    For Germany only
    It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
    You can choose to recieve all data or just select specific regions in advanced settings.
    Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
    Add missing countries
    It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
    coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
    Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
    List with country names
    With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
    The JSON string then looks like this, for example:
    	"Cabo_Verde": "Cape Verde",
    	"Timor-Leste": "East Timor"
    As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
    Changelog
    #445
    Also Ihr alle hier seit echt der Knaller!
    Komme gar nicht dazu, an meiner Vis zu basteln, und wenn ich sehe, wie geil das bei euch aussieht, an alle ein großes Lob!
    Ich hoffe, wir haben bald schönere Anlässe, um Statistiken zu erstellen.. so n faden Beigeschmack hat das ja schon, spätestens, wenn man jemand kennt oder selbst betroffen ist..
    Allen ein bleibt Gesund!
    • H Hicki
      @Scrounger sagte in Test Coronavirus Statistics for ioBroker:
      Als Anregung hier meine View(s) mit Material Design Widgets:
      View mit Grid Widget mit Selects für Zeitintervall & Filter:
        "settings": {
          "style": {},
          "theme": "redmond",
          "sizex": "",
          "sizey": "",
          "gridSize": "",
          "snapType": null
        "widgets": {
          "e00001": {
            "tpl": "tplVis-materialdesign-Select",
            "data": {
              "oid": "0_userdata.0.vis.Corona.timeInterval",
              "g_fixed": false,
              "g_visibility": false,
              "g_css_font_text": false,
              "g_css_background": false,
              "g_css_shadow_padding": false,
              "g_css_border": false,
              "g_gestures": false,
              "g_signals": false,
              "g_last_change": false,
              "visibility-cond": "==",
              "visibility-val": 1,
              "visibility-groups-action": "hide",
              "inputType": "text",
              "inputLayout": "regular",
              "showInputMessageAlways": "true",
              "showInputCounter": false,
              "clearIconShow": false,
              "listDataMethod": "jsonStringObject",
              "countSelectItems": "1",
              "listPosition": "bottom",
              "showSelectedIcon": "prepend-inner",
              "showValue": false,
              "signals-cond-0": "==",
              "signals-val-0": true,
              "signals-icon-0": "/vis/signals/lowbattery.png",
              "signals-icon-size-0": 0,
              "signals-blink-0": false,
              "signals-horz-0": 0,
              "signals-vert-0": 0,
              "signals-hide-edit-0": false,
              "signals-cond-1": "==",
              "signals-val-1": true,
              "signals-icon-1": "/vis/signals/lowbattery.png",
              "signals-icon-size-1": 0,
              "signals-blink-1": false,
              "signals-horz-1": 0,
              "signals-vert-1": 0,
              "signals-hide-edit-1": false,
              "signals-cond-2": "==",
              "signals-val-2": true,
              "signals-icon-2": "/vis/signals/lowbattery.png",
              "signals-icon-size-2": 0,
              "signals-blink-2": false,
              "signals-horz-2": 0,
              "signals-vert-2": 0,
              "signals-hide-edit-2": false,
              "lc-type": "last-change",
              "lc-is-interval": true,
              "lc-is-moment": false,
              "lc-format": "",
              "lc-position-vert": "top",
              "lc-position-horz": "right",
              "lc-offset-vert": 0,
              "lc-offset-horz": 0,
              "lc-font-size": "12px",
              "lc-font-family": "",
              "lc-font-style": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-border-width": "0",
              "lc-border-style": "",
              "lc-border-color": "",
              "lc-border-radius": 10,
              "lc-zindex": 0,
              "inputLabelText": "Zeitintervall",
              "inputLabelColor": "#ffffff",
              "inputLabelFontFamily": "RobotoCondensed-LightItalic",
              "collapseIconColor": "#ffffff",
              "collapseIconSize": "",
              "jsonStringObject": "[   {\n\t\t\"text\": \"1 Tag\",\n\t\t\"value\": \"1 day\"\n\t}, \n\t{\n\t\t\"text\": \"3 Tage\",\n\t\t\"value\": \"3 days\"\n\t}, \n\t{\n\t\t\"text\": \"1 Woche\",\n\t\t\"value\": \"7 days\"\n\t}, \n\t{\n\t\t\"text\": \"2 Wochen\",\n\t\t\"value\": \"14 days\"\n\t}, \n\t{\n\t\t\"text\": \"1 Monat\",\n\t\t\"value\": \"1 month\"\n\t}, \n\t{\n\t\t\"text\": \"2 Monate\",\n\t\t\"value\": \"2 months\"\n\t}, \n\t{\n\t\t\"text\": \"3 Monate\",\n\t\t\"value\": \"3 months\"\n\t}, \n\t{\n\t\t\"text\": \"6 Monate\",\n\t\t\"value\": \"6 months\"\n\t}, \n\t{\n\t\t\"text\": \"1 Jahr\",\n\t\t\"value\": \"1 year\"\n\t}\n]",
              "listPositionOffset": true,
              "inputLayoutBackgroundColor": "transparent",
              "inputLabelColorSelected": "#ffffff",
              "inputTranslateX": "-15",
              "clearIcon": "",
              "inputLayoutBorderColorHover": "#ffffff",
              "inputLayoutBorderColorSelected": "#ffffff",
              "inputLayoutBorderColor": "#a1a1a1",
              "listItemFontColor": "",
              "inputTextColor": "#ffffff",
              "inputTextFontFamily": "RobotoCondensed-LightItalic",
              "prepandIcon": "",
              "prepandIconColor": "",
              "prepandIconSize": "",
              "prepandInnerIcon": "",
              "prepandInnerIconColor": "#ffffff",
              "prepandInnerIconSize": "18",
              "collapseIcon": "",
              "inputTranslateY": "-12",
              "listIconSelectedColor": "#44739e",
              "listIconColor": "",
              "appendOuterIcon": "",
              "appendOuterIconSize": "2",
              "listItemFont": "RobotoCondensed-Regular",
              "listItemRippleEffectColor": "",
              "inputLayoutBackgroundColorSelected": "",
              "inputLayoutBackgroundColorHover": "",
              "listIcon0": ""
            "style": {
              "left": "10px",
              "top": "0px",
              "z-index": "1",
              "width": "calc(50% - 50px)",
              "height": "40px"
            "widgetSet": "materialdesign"
          "e00002": {
            "tpl": "tplHtml",
            "data": {
              "g_fixed": false,
              "g_css_background": true,
              "g_signals": false,
              "refreshInterval": "0",
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0
            "style": {
              "left": "0",
              "top": "0",
              "width": "100%",
              "height": "50px",
              "background-color": "#44739e"
            "widgetSet": "basic"
          "e00003": {
            "tpl": "tplTimeValue",
            "data": {
              "oid": "coronavirus-statistics.0.global_totals.updated",
              "g_fixed": false,
              "g_css_font_text": true,
              "g_signals": false,
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0,
              "format_date": "DD.MM.YYYY<br>hh:mm"
            "style": {
              "left": "calc(100% - 70px)",
              "top": "12px",
              "width": "60px",
              "height": "26px",
              "color": "#ffffff",
              "text-align": "right",
              "z-index": "1",
              "font-family": "RobotoCondensed-Light",
              "font-size": "12px"
          "e00004": {
            "tpl": "tplVis-materialdesign-Grid-Views",
            "data": {
              "g_fixed": false,
              "g_signals": false,
              "countViews": "15",
              "viewVertAlignment": "center",
              "viewHorAlignment": "center",
              "showResolutionAssistant": false,
              "visibilityCondition0": "==",
              "visibilityCondition1": "==",
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0,
              "visibilityCondition2": "==",
              "visibilityCondition3": "==",
              "View0": "CoronaVirus_World",
              "viewsHeight0": "400",
              "viewColSpan0": "4",
              "View1": "CoronaVirus_Europa",
              "viewsHeight1": "400",
              "desktopGaps": "4",
              "View2": "CoronaVirus_America",
              "viewsHeight2": "400",
              "View3": "CoronaVirus_North_America",
              "viewsHeight3": "400",
              "visibilityCondition4": "==",
              "visibilityCondition5": "==",
              "visibilityCondition6": "==",
              "visibilityCondition7": "==",
              "View4": "CoronaVirus_South_America",
              "viewsHeight4": "400",
              "View5": "CoronaVirus_Asia",
              "viewsHeight5": "400",
              "View6": "CoronaVirus_Africa",
              "viewsHeight6": "400",
              "viewColSpan1": "4",
              "viewColSpan2": "4",
              "viewColSpan3": "4",
              "viewColSpan4": "4",
              "viewColSpan5": "4",
              "viewColSpan6": "4",
              "handyGridPortraitColSpan0": "12",
              "handyGridLandscapeColSpan0": "12",
              "tabletGridPortraitColSpan0": "6",
              "tabletGridLandscapeColSpan0": "6",
              "handyGridPortraitColSpan1": "12",
              "handyGridLandscapeColSpan1": "12",
              "tabletGridPortraitColSpan1": "6",
              "tabletGridLandscapeColSpan1": "6",
              "handyGridPortraitColSpan2": "12",
              "handyGridLandscapeColSpan2": "12",
              "tabletGridPortraitColSpan2": "6",
              "tabletGridLandscapeColSpan2": "6",
              "handyGridPortraitColSpan4": "12",
              "handyGridLandscapeColSpan4": "12",
              "tabletGridPortraitColSpan4": "6",
              "tabletGridLandscapeColSpan4": "6",
              "handyGridPortraitColSpan5": "12",
              "handyGridLandscapeColSpan5": "12",
              "tabletGridPortraitColSpan5": "6",
              "tabletGridLandscapeColSpan5": "6",
              "handyGridPortraitColSpan6": "12",
              "handyGridLandscapeColSpan6": "12",
              "tabletGridPortraitColSpan6": "6",
              "tabletGridLandscapeColSpan6": "6",
              "handyGridPortraitColSpan3": "12",
              "handyGridLandscapeColSpan3": "12",
              "tabletGridPortraitColSpan3": "6",
              "tabletGridLandscapeColSpan3": "6",
              "viewsHeight7": "400",
              "viewColSpan7": "4",
              "handyGridPortraitColSpan7": "12",
              "handyGridLandscapeColSpan7": "12",
              "tabletGridPortraitColSpan7": "6",
              "tabletGridLandscapeColSpan7": "6",
              "View7": "CoronaVirus_Oceania",
              "visibleResolutionLessThan1": "",
              "visibilityOid0": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue0": "true",
              "visibilityOid1": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue1": "true",
              "visibilityOid2": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue2": "true",
              "visibilityOid3": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue3": "true",
              "visibilityOid4": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue4": "true",
              "visibilityOid5": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue5": "true",
              "visibilityOid6": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue6": "true",
              "visibilityOid7": "0_userdata.0.vis.Corona.visibileContinent",
              "visibilityConditionValue7": "true",
              "visibilityCondition8": "==",
              "visibilityCondition9": "==",
              "visibilityCondition10": "==",
              "visibilityCondition11": "==",
              "visibilityCondition12": "==",
              "visibilityCondition13": "==",
              "visibilityCondition14": "==",
              "View8": "CoronaVirus_Deutschland",
              "viewsHeight8": "400",
              "viewColSpan8": "4",
              "handyGridPortraitColSpan8": "12",
              "handyGridLandscapeColSpan8": "12",
              "tabletGridPortraitColSpan8": "6",
              "tabletGridLandscapeColSpan8": "6",
              "visibilityOid8": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue8": "true",
              "viewsHeight9": "400",
              "viewColSpan9": "4",
              "handyGridPortraitColSpan9": "12",
              "handyGridLandscapeColSpan9": "12",
              "tabletGridPortraitColSpan9": "6",
              "tabletGridLandscapeColSpan9": "6",
              "visibilityOid9": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue9": "true",
              "View9": "CoronaVirus_USA",
              "viewsHeight10": "400",
              "viewColSpan10": "4",
              "handyGridPortraitColSpan10": "12",
              "handyGridLandscapeColSpan10": "12",
              "tabletGridPortraitColSpan10": "6",
              "tabletGridLandscapeColSpan10": "6",
              "visibilityOid10": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue10": "true",
              "View10": "CoronaVirus_Italien",
              "viewsHeight11": "400",
              "viewColSpan11": "4",
              "handyGridPortraitColSpan11": "12",
              "handyGridLandscapeColSpan11": "12",
              "tabletGridPortraitColSpan11": "6",
              "tabletGridLandscapeColSpan11": "6",
              "visibilityOid11": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue11": "true",
              "View11": "CoronaVirus_Spain",
              "viewsHeight12": "400",
              "viewColSpan12": "4",
              "handyGridPortraitColSpan12": "12",
              "handyGridLandscapeColSpan12": "12",
              "tabletGridPortraitColSpan12": "6",
              "tabletGridLandscapeColSpan12": "6",
              "visibilityOid12": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue12": "true",
              "View12": "CoronaVirus_France",
              "tabletGridPortraitColSpan13": "6",
              "viewsHeight13": "400",
              "viewColSpan13": "4",
              "handyGridPortraitColSpan13": "12",
              "handyGridLandscapeColSpan13": "12",
              "tabletGridLandscapeColSpan13": "6",
              "visibilityOid13": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue13": "true",
              "View13": "CoronaVirus_Austria",
              "viewsHeight14": "400",
              "viewColSpan14": "4",
              "handyGridPortraitColSpan14": "12",
              "handyGridLandscapeColSpan14": "12",
              "tabletGridPortraitColSpan14": "6",
              "tabletGridLandscapeColSpan14": "6",
              "visibilityOid14": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue14": "true",
              "View14": "CoronaVirus_Schweiz",
              "visibilityCondition15": "==",
              "viewsHeight15": "400",
              "viewColSpan15": "4",
              "handyGridPortraitColSpan15": "12",
              "handyGridLandscapeColSpan15": "12",
              "tabletGridPortraitColSpan15": "6",
              "tabletGridLandscapeColSpan15": "6",
              "visibilityOid15": "0_userdata.0.vis.Corona.visibileCountries",
              "visibilityConditionValue15": "true",
              "View15": "CoronaVirus_China"
            "style": {
              "left": "0px",
              "top": "50px",
              "width": "100%",
              "height": "calc(100% - 50px)",
              "overflow-y": "auto"
          "e00005": {
            "data": {
              "oid": "0_userdata.0.vis.Corona.filter",
              "g_fixed": false,
              "g_signals": false,
              "clearIconShow": true,
              "showValue": false,
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0,
              "inputLabelText": "Filter",
              "jsonStringObject": "[   {\n\t\t\"text\": \"Kontinente\",\n\t\t\"value\": \"continents\"\n\t}, \n\t{\n\t\t\"text\": \"Länder\",\n\t\t\"value\": \"countries\"\n\t}\n]",
              "clearIcon": "",
              "prepandIcon": "",
              "collapseIcon": "",
              "listIcon0": "",
              "clearIconColor": "#ffffff"
            "style": {
              "left": "calc(50% - 30px)",
              "top": "0px",
              "z-index": "1",
              "height": "40px"
        "name": "CoronaVirus",
        "filterList": []
      View mit Statistik und Line History Graph - am Beispiel Welt:
        "settings": {
          "style": {
            "background_class": ""
          "theme": "redmond",
          "sizex": "",
          "sizey": "",
          "gridSize": "",
          "snapType": null
        "widgets": {
          "e00001": {
            "tpl": "tplVis-materialdesign-Card",
            "data": {
              "g_fixed": true,
              "g_signals": false,
              "titleLayout": "headline6",
              "subtitleLayout": "headline6",
              "cardLayout": "Basic",
              "cardStyle": "default",
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0,
              "html": "",
              "labelSubTextHeight": "",
              "labelTextHeight": "",
              "subtitle": "",
              "title": "      Welt",
              "name": "Card",
              "colorTitle": "#44739e",
              "class": "my-card-container"
            "style": {
              "left": "",
              "top": "",
              "width": "",
              "height": "400px",
              "z-index": ""
          "e00002": {
            "tpl": "tplVis-materialdesign-Chart-Line-History",
            "data": {
              "g_fixed": false,
              "g_signals": false,
              "dataCount": "3",
              "aggregate": "max",
              "timeIntervalToShow": "1 day",
              "refreshMethod": "timeInterval",
              "refreshTimeInterval": "5 minutes",
              "pointStyle": "circle",
              "showLegend": "true",
              "legendPosition": "top",
              "legendPointStyle": "true",
              "showTooltip": "true",
              "tooltipTimeFormats": "{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}",
              "tooltipShowColorBox": "true",
              "lineSpanGaps0": true,
              "lineSpanGaps1": "true",
              "xAxisPosition": "bottom",
              "xAxisBounds": "dataSet",
              "xAxisTimeFormats": "{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"dd. H:mm\",\"day\":\"dd DD.MM\",\"week\":\"dd DD.MM\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}",
              "xAxisValueDistanceToAxis": "0",
              "xAxisShowAxis": "true",
              "xAxisShowAxisLabels": "true",
              "xAxisShowGridLines": "true",
              "xAxisShowTicks": "true",
              "yAxisValueDistanceToAxis": "10",
              "showYAxis0": "true",
              "yAxisPosition0": "left",
              "yAxisShowGridLines0": true,
              "yAxisShowTicks0": "true",
              "yAxisShowAxisBorder0": "true",
              "showYAxis1": "true",
              "yAxisPosition1": "left",
              "yAxisShowGridLines1": false,
              "yAxisShowTicks1": "true",
              "yAxisShowAxisBorder1": "true",
              "showValues0": false,
              "valuesPositionAnchor0": "end",
              "valuesPositionAlign0": "top",
              "valuesTextAlign0": "center",
              "showValues1": false,
              "valuesPositionAnchor1": "end",
              "valuesPositionAlign1": "top",
              "valuesTextAlign1": "center",
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0,
              "historyAdapterInstance": "sql.0",
              "oid0": "coronavirus-statistics.0.global_totals.cases",
              "dataColor0": "red",
              "legendText0": "Infiziert",
              "pointSizeHover": "",
              "pointSize": "0",
              "oid1": "coronavirus-statistics.0.global_totals.deaths",
              "dataColor1": "",
              "legendText1": "Todesfälle",
              "commonYAxis1": "0",
              "yAxisMinValue1": "0",
              "yAxisMinValue0": "0",
              "useFillColor1": false,
              "lineSpanGaps2": "true",
              "showYAxis2": "true",
              "yAxisPosition2": "left",
              "yAxisShowGridLines2": "true",
              "yAxisShowTicks2": "true",
              "yAxisShowAxisBorder2": "true",
              "showValues2": false,
              "valuesPositionAnchor2": "end",
              "valuesPositionAlign2": "top",
              "valuesTextAlign2": "center",
              "oid2": "coronavirus-statistics.0.global_totals.recovered",
              "commonYAxis2": "0",
              "legendText2": "Genesen",
              "dataColor2": "green",
              "useFillColor0": false,
              "useFillColor2": false,
              "legendFontFamily": "",
              "legendFontSize": "12",
              "legendBoxWidth": "4",
              "legendPadding": "",
              "xAxisValueFontSize": "10",
              "xAxisValueFontFamily": "RobotoCondensed-Light",
              "yAxisValueFontSize": "10",
              "yAxisValueFontFamily": "RobotoCondensed-Light",
              "lineTension2": "",
              "lineThikness2": "2",
              "lineThikness1": "2",
              "lineThikness0": "2",
              "time_interval_oid": "0_userdata.0.vis.Corona.timeInterval",
              "xAxisMaxLabel": "7",
              "maxDataPoints": "50",
              "lineTension0": "",
              "lineSpanGaps3": "true",
              "showYAxis3": "true",
              "yAxisPosition3": "right",
              "yAxisShowGridLines3": false,
              "yAxisShowTicks3": true,
              "yAxisShowAxisBorder3": true,
              "showValues3": false,
              "valuesPositionAnchor3": "end",
              "valuesPositionAlign3": "top",
              "valuesTextAlign3": "center",
              "oid3": "javascript.0.corona.continents.World.todayCases",
              "yAxisMinValue3": "0",
              "dataColor3": "darkorange",
              "legendText3": "Infiziert pro Tag",
              "useFillColor3": false,
              "lineThikness3": "2",
              "chartPaddingLeft": "5"
            "style": {
              "left": "10px",
              "top": "150px",
              "width": "calc(100% - 20px)",
              "height": "250px",
              "z-index": "1"
          "e00003": {
            "tpl": "tplImage",
            "data": {
              "g_fixed": false,
              "g_signals": false,
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0,
              "src": "/vis.0/myImages/flags/world_2.png"
            "style": {
              "left": "10px",
              "top": "18px",
              "width": "30px",
              "height": "30px"
          "e00004": {
            "tpl": "tplVis-materialdesign-Icon-List",
            "data": {
              "g_fixed": false,
              "g_signals": false,
              "wrapItems": false,
              "listItemDataMethod": "inputPerEditor",
              "countListItems": "5",
              "vibrateOnMobilDevices": "50",
              "listLayout": "standard",
              "itemLayout": "vertical",
              "buttonLayout": "round",
              "autoLockAfter": "10",
              "lockIconTop": "5",
              "lockIconLeft": "5",
              "lockFilterGrayscale": "30",
              "lockApplyOnlyOnImage": "true",
              "listType0": "text",
              "showValueLabel0": true,
              "listType1": "text",
              "showValueLabel1": "true",
              "lc-format": "",
              "lc-bkg-color": "",
              "lc-color": "",
              "lc-zindex": 0,
              "listType2": "text",
              "showValueLabel2": "true",
              "listType3": "text",
              "showValueLabel3": "true",
              "listType4": "text",
              "showValueLabel4": "true",
              "listType5": "text",
              "showValueLabel5": "true",
              "listType6": "text",
              "showValueLabel6": "true",
              "listImage0": "biohazard",
              "label0": "<div class=\"my-corona-title\">Infiziert</div>",
              "subLabel0": "<div class=\"my-corona-value\">{coronavirus-statistics.0.global_totals.cases}</div>",
              "listImage1": "heart-pulse",
              "label1": "<div class=\"my-corona-title\">Genesen</div>",
              "subLabel1": "<div class=\"my-corona-value\">{coronavirus-statistics.0.global_totals.recovered}</div>",
              "listImage2": "seat-flat",
              "label2": "<div class=\"my-corona-title\">Kritisch</div>",
              "valueAppendix2": "",
              "subLabel2": "<div class=\"my-corona-value\">{javascript.0.corona.continents.World.critical}</div>",
              "label3": "<div class=\"my-corona-title\">Todesfälle</div>",
              "listImage3": "grave-stone",
              "subLabel3": "<div class=\"my-corona-value\">{coronavirus-statistics.0.global_totals.deaths}</div>",
              "listImage4": "hospital-box",
              "valueAppendix4": "",
              "label4": "<div class=\"my-corona-title\">Heute<br>Infiziert</div>",
              "subLabel4": "<div class=\"my-corona-value\">{javascript.0.corona.continents.World.todayCases}</div>",
              "listImage5": "skull-crossbones",
              "label5": "<div class=\"my-corona-title\">Heute<br>Todesfälle</div>",
              "subLabel5": "<div class=\"my-corona-value\">{javascript.0.corona.continents.World.todayDeaths}</div>",
              "iconHeight": "35",
              "verticalIconContainerHeight": "",
              "labelFontSize": "10",
              "labelFontFamily": "RobotoCondensed-Regular",
              "subLabelFontSize": "12",
              "subLabelFontFamily": "RobotoCondensed-LightItalic",
              "oid0": "",
              "itemGaps": "0",
              "valueFontSize": "",
              "listImageColor0": "red",
              "listImageColor1": "green",
              "listImageColor2": "gold",
              "listImageColor3": "",
              "listImageColor4": "darkorange",
              "listImageColor5": "black",
              "lockEnabled0": false,
              "itemBackgroundColor0": "",
              "horizontalIconContainerWidth": ""
            "style": {
              "left": "0px",
              "top": "60px",
              "width": "100%",
              "height": "96px"
        "name": "CoronaVirus_World",
        "filterList": []
      Für Filter und Zeitinterval Funktion werden noch folgende Datenpunkte benötigt:
      Und folgendes Skript damit man filtern kann:
      // Filter für Corona Statistik
      on({ id: '0_userdata.0.vis.Corona.filter', change: 'any' }, function (obj) {
          if (obj.state.val === 'continents') {
              setState('0_userdata.0.vis.Corona.visibileContinent', true, true);
              setState('0_userdata.0.vis.Corona.visibileCountries', false, true);
          } else if (obj.state.val === 'countries') {
              setState('0_userdata.0.vis.Corona.visibileContinent', false, true);
              setState('0_userdata.0.vis.Corona.visibileCountries', true, true);
          } else {
      wie genau noch einmal installiere ich Dein tolles View?
      Und wo finde ich die Länder-Icon´s?
      GRuß Hicki
      ScroungerS Offline
      ScroungerS Offline
      Scrounger
      #446
      @Hicki sagte in Test Coronavirus Statistics for ioBroker:
      Du musst alle Datenpunkte die im Skript sind anlegen, visible Datenpunkte sind vom typ boolean, filter und timeinterval vom typ string.
      View mit Grid Widget mit Selects für Zeitintervall & Filter importieren.
      Und dann für jedes Land & Bundesland, etc. je eine View wie die View mit Statistik und Line History Graph erstellen. Dort dann deine history instanz angeben und die datenpunkte die du angezeigt bekommen haben möchtest.
      Musst für diese datenpunkte die daten aufzeichnen (z.B. mit sql adapter).
      https://www.flaticon.com/search?word=country+flags
      H ChaotC 3 Antworten Letzte Antwort
      • ScroungerS Scrounger
        Hicki
        #447
        Vielen Dank.
        Ich bin Neuling, wie mache ich das?
        Ich meinte eigentlich die Kontinent-Icon´s.
        Gruß Hicki
        ScroungerS 1 Antwort Letzte Antwort
          ChaotC Offline
          ChaotC Offline
          Chaot
          schrieb am zuletzt editiert von Chaot
          #448
          Sagt mal, sind die aktuellen Daten falsch oder was ist plötzlich passiert:
          In China plötzlich nur noch 2600 aktive Fälle?
          S0NICS 1 Antwort Letzte Antwort
          • H Hicki
            Vielen Dank.
            Gruß Hicki
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            schrieb am zuletzt editiert von Scrounger
            #449
            Vielen Dank.
            ??? Was genau?
            https://thenounproject.com/term/continent/
              Hicki
              #450
              und
              Gruß Hicki
              H 1 Antwort Letzte Antwort
              • K Kuddel
                @Hicki na klar.
                Da ich viel mit View in Widget arbeite, um die Anzahl der Widgets pro Seite übersichtlich zuhalten, sind es sieben Seiten bei mir:
                Jeweils der View-Export-
                13000_Corona
                 "settings": {
                   "style": {},
                   "theme": "redmond",
                   "sizex": "",
                   "sizey": "",
                   "gridSize": "",
                   "useBackground": false,
                   "snapType": null
                 "widgets": {
                   "e00001": {
                     "tpl": "tplContainerView",
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "contains_view": "13002_Corona_Top_5_1",
                       "name": "13002_Corona_Top_5_1"
                     "style": {
                       "left": "0px",
                       "top": "0px",
                       "width": "420px",
                       "height": "345px"
                   "e00002": {
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "contains_view": "13003_Corona_Top_5_2",
                       "name": "13002_Corona_Top_5_3"
                     "style": {
                       "left": "425px",
                       "top": "0px",
                       "width": "420px",
                       "height": "345px"
                   "e00003": {
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "contains_view": "13004_Corona_Top_5_3",
                     "style": {
                       "left": "850px",
                       "top": "0px",
                       "width": "420px",
                       "height": "345px"
                   "e00004": {
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "contains_view": "13005_Corona_Top_5_4",
                       "name": "13002_Corona_Top_5_4"
                     "style": {
                       "left": "0px",
                       "top": "350px",
                       "width": "420px",
                       "height": "345px"
                   "e00005": {
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "contains_view": "13006_Corona_Top_5_5",
                       "name": "13002_Corona_Top_5_5"
                     "style": {
                       "left": "425px",
                       "top": "350px",
                       "width": "420px",
                       "height": "345px"
                   "e00006": {
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "contains_view": "13001_Corona_Länder_D",
                       "name": "13001_Corona_Länder_D"
                     "style": {
                       "left": "855px",
                       "top": "350px",
                       "width": "420px",
                       "height": "345px"
                   "e00007": {
                     "tpl": "tplValueLastchange",
                     "data": {
                       "oid": "coronavirus-statistics.0.country_Top_5.1.updated",
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "name": "Letzte_Änderung",
                       "format_date": "DD.MM.YYYY -  hh:mm:ss",
                       "html_prepend": "Letzte Aktualisierung: ",
                       "html_append": " Uhr"
                     "style": {
                       "left": "0px",
                       "top": "720px",
                       "width": "600px",
                       "height": "60px",
                       "color": "white",
                       "text-align": "left",
                       "font-family": "Arial, Helvetica, sans-serif",
                       "font-weight": "bolder",
                       "font-size": "x-large"
                 "name": "13000_Corona",
                 "filterList": []
                 "settings": {
                   "style": {
                     "background": "rgb(0, 0, 0) none repeat scroll 0% 0% / auto padding-box border-box",
                   "theme": "dark-hive",
                   "sizex": "1920",
                   "sizey": "1080",
                   "gridSize": "",
                   "useBackground": true,
                   "snapType": null
                 "widgets": {
                   "e00001": {
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "wrapItems": true,
                       "listLayout": "cardOutlined",
                       "itemLayout": "horizontal",
                       "lockIconTop": "5",
                       "lockApplyOnlyOnImage": true,
                       "listType0": "buttonState",
                       "listType1": "buttonState",
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "maxItemsperRow": "2",
                       "oid0": "coronavirus-statistics.0.Germany.cases",
                       "label0": "Infizierte Gesamt",
                       "listImage0": "/vis.0/VIS_v3/Meine_Icons/Corona/biohazard.png",
                       "itemBackgroundColor": "#878787",
                       "iconHeight": "40",
                       "horizontalIconContainerWidth": "100",
                       "labelFontSize": "15",
                       "labelFontFamily": "Arial, Helvetica, sans-serif",
                       "labelFontColor": "white",
                       "listImage1": "/vis.0/VIS_v3/Meine_Icons/Corona/seat-flat.png",
                       "oid1": "coronavirus-statistics.0.Germany.critical",
                       "label1": "Kritisch",
                       "listType2": "buttonState",
                       "listType3": "buttonState",
                       "listType4": "buttonState",
                       "listType5": "buttonState",
                       "oid2": "coronavirus-statistics.0.Germany.todayCases",
                       "label2": "Infizierte Heute",
                       "listImage2": "/vis.0/VIS_v3/Meine_Icons/Corona/hospital-box.png",
                       "oid3": "coronavirus-statistics.0.Germany.recovered",
                       "listImage3": "/vis.0/VIS_v3/Meine_Icons/Corona/heart-pulse.png",
                       "listImage4": "/vis.0/VIS_v3/Meine_Icons/Corona/skull-crossbones.png",
                       "listImage5": "/vis.0/VIS_v3/Meine_Icons/Corona/grave-stone.png",
                       "label3": "Genesen",
                       "oid4": "coronavirus-statistics.0.Germany.todayDeaths",
                       "label4": "Todesfälle Heute",
                       "oid5": "coronavirus-statistics.0.Germany.deaths",
                       "label5": "Todesfälle Summe",
                       "valueAppendix0": "",
                       "buttonHeight": "35",
                       "subLabelFontSize": "",
                       "valueFontSize": "15",
                       "valueFontColor": "red",
                       "valueFontFamily": "Arial, Helvetica, sans-serif",
                       "buttonBgColor1": "",
                       "listImageColor1": "",
                       "listImageActive1": "",
                       "listImageActiveColor1": "",
                       "statusBarColor1": "#e47807",
                       "statusBarColor0": "#b30000",
                       "statusBarColor2": "#b30000",
                       "statusBarColor3": "#0fa800",
                       "statusBarColor4": "#0082f5",
                       "statusBarColor5": "#000000",
                       "itemBackgroundColor0": "#919191",
                       "itemBackgroundColor1": "#919191",
                       "itemBackgroundColor2": "#919191",
                       "itemBackgroundColor3": "#919191",
                       "itemBackgroundColor4": "#919191",
                       "itemBackgroundColor5": "#919191",
                       "name": "Zahlen",
                       "listItemDividerStyle": "standard",
                       "showValueLabel": "true",
                       "subLabelFontFamily": ""
                     "style": {
                       "left": "0px",
                       "top": "35px",
                       "width": "430px",
                       "height": "313px",
                       "z-index": "5",
                       "background": "",
                       "color": "white",
                   "e00002": {
                     "tpl": "tplImage",
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "name": "Fahne",
                       "src": "/vis.0/VIS_v3/Meine_Icons/Corona/Flaggen/deutschland.png"
                     "style": {
                       "left": "370px",
                       "top": "0px",
                       "width": "60px",
                       "height": "30px",
                       "z-index": "10"
                   "e00003": {
                     "tpl": "tplHtml",
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "name": "!_Überschrift",
                       "html": "Germnay"
                     "style": {
                       "left": "0px",
                       "top": "0px",
                       "width": "430px",
                       "height": "30px",
                       "color": "white",
                       "text-align": "center",
                       "font-size": "large",
                       "line-height": "30px",
                       "background": "grey",
                       "background-color": "grey",
                       "z-index": "5"
                   "e00004": {
                     "tpl": "tplShapes",
                     "data": {
                       "g_fixed": true,
                       "g_css_shadow_padding": true,
                       "g_css_border": true,
                       "g_signals": false,
                       "svgType": "square",
                       "strokeColor": "",
                       "fill": "#212121",
                       "strokeWidth": "5",
                       "scaleWidth": "1",
                       "scaleHeight": "1",
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "rotate": "45",
                       "name": "!_Hintergrund"
                     "style": {
                       "left": "0px",
                       "top": "0px",
                       "background": "#212121",
                       "background-color": "#212121",
                       "z-index": "0",
                       "width": "430px",
                       "height": "345px",
                       "border-radius": "10px",
                       "box-shadow": "2px 2px 3px rgba(20, 20, 20, 50)",
                 "name": "13001_Corona_Länder_D",
                 "filterList": []
                 "settings": {
                   "style": {
                   "theme": "redmond",
                   "sizex": "",
                   "sizey": "",
                   "gridSize": "",
                   "snapType": null
                 "widgets": {
                   "e00001": {
                     "tpl": "tplValueStringImg",
                     "data": {
                       "oid": "coronavirus-statistics.0.country_Top_5.1.flag",
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "name": "Flagge"
                     "style": {
                       "left": "380px",
                       "top": "0px",
                       "z-index": "10",
                       "width": "50px",
                       "height": "30px"
                   "e00002": {
                     "tpl": "tplValueStringRaw",
                     "data": {
                       "oid": "coronavirus-statistics.0.country_Top_5.1.country",
                       "g_fixed": true,
                       "g_signals": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                     "style": {
                       "left": "0px",
                       "top": "0px",
                       "z-index": "5",
                       "width": "430px",
                       "height": "30px",
                       "color": "white",
                   "e00003": {
                     "tpl": "tplVis-materialdesign-Chart-Bar",
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "dataCount": "3",
                       "chartType": "vertical",
                       "showValues": true,
                       "valuesPositionAnchor": "end",
                       "valuesPositionAlign": "top",
                       "valuesTextAlign": "center",
                       "yAxisPosition": "left",
                       "yAxisShowAxis": false,
                       "yAxisShowAxisLabels": true,
                       "yAxisShowGridLines": false,
                       "yAxisShowTicks": false,
                       "xAxisShowGridLines": false,
                       "xAxisShowTicks": true,
                       "legendPointStyle": false,
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "oid0": "coronavirus-statistics.0.country_Top_5.1.cases",
                       "oid1": "coronavirus-statistics.0.country_Top_5.1.todayCases",
                       "oid2": "coronavirus-statistics.0.country_Top_5.1.todayDeaths",
                       "oid3": "coronavirus-statistics.0.country_Top_5.1.deaths",
                       "label0": "Infiziert",
                       "label1": "Infiziert Heute",
                       "label2": "Todesfälle Heute",
                       "label3": "Todesfälle",
                       "backgroundColor": "transparent",
                       "chartAreaBackgroundColor": "transparent",
                       "dataColor0": "#b30000",
                       "dataColor1": "#b30000",
                       "valueTextColor2": "",
                       "dataColor2": "#fc1df9",
                       "dataColor3": "white",
                       "yAxisValueLabelColor": "white",
                       "xAxisValueLabelColor": "white",
                       "valuesMaxDecimals": "0",
                       "valuesFontSize": "15",
                       "valuesFontColor": "#ffffff",
                       "barLabelText": "",
                       "barWidth": "",
                       "showLegend": false,
                       "legendBoxWidth": "0",
                       "name": "Graph",
                       "colorScheme": "",
                       "axisValueMax": "150000"
                     "style": {
                       "left": "0px",
                       "top": "35px",
                       "z-index": "5",
                       "width": "430px",
                       "height": "310px"
                   "e00004": {
                     "tpl": "tplShapes",
                     "data": {
                       "g_fixed": true,
                       "g_signals": false,
                       "strokeColor": "",
                       "fill": "#212121",
                       "strokeWidth": "5",
                       "scaleWidth": "1",
                       "scaleHeight": "1",
                       "lc-format": "",
                       "lc-bkg-color": "",
                       "lc-color": "",
                       "lc-zindex": 0,
                       "rotate": "45",
                     "style": {
                       "left": "0px",
                       "top": "0px",
                       "z-index": "0",
                       "width": "430px",
                       "height": "345px",
                 "name": "13002_Corona_Top_5_1",
                 "filterList": []
                Bei der anderen Seiten (13003 - 13006) muss einfach nur die IDs der DPs ändern. Am besten per Notepad (Suchen und erstzen)
                Uli977U Offline
                Uli977U Offline
                Uli977
                #451
                @Kuddel sagte in Test Coronavirus Statistics for ioBroker:
                Wo finde ich denn 13003-13006 von dir?
                • Uli977U Uli977
                  Kuddel
                  #452
                  @Uli977 habe ich auf Grund von Faulheit nicht hochgeladen.
                  kopiere 13002 und passe alle IDs an und schon hast du 13003
                  Uli977U 1 Antwort Letzte Antwort
                  • K Kuddel
                    Uli977U Offline
                    Uli977U Offline
                    Uli977
                    #453
                    @Kuddel Ahh, verstanden! Danke
                    • H Hicki
                      und
                      Gruß Hicki
                      Hicki
                      #454
                      und
                      Gruß Hicki
                      Ich benötige bitte hier Hilfe.
                      • H Offline
                        Hicki
                        schrieb am zuletzt editiert von Hicki
                        #455
                        Ich bekomme einfach keine Linien in die Diagramme. Auch wenn ich oben den Zeitinterval und den Filter betätige, passiert auch nichts.
                        • H Hicki
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #456
                          @Hicki
                          Hast du das gemacht?
                            @Hicki
                            Hicki
                            #457
                            @crunchip Wo mache ich das. ich bin Neuling.
                            • H Hicki
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #458
                              @Hicki am Beispiel global totals auf den Schraubenschlüssel
                              dann Settings for history.0 auswählen, Haken bei Aktiviert setzen, Haken bei Nur Änderungen aufzeichnen
                              das wiederholst du für alle, die du loggen möchtest
                              solltest du sql oder influx eingerichtet haben, musst du entsprechend die jeweilige Datenbank auswählen, die du benutzen möchtest.
                              • H Offline
                                Hicki
                                #459
                                Ok. Vielen Dank.
                                nach den Änderungen muss ich eh erst mal warten, bis sich grafisch was tut. Oder?
                                Gruß Hicki
                                crunchipC ChaotC 2 Antworten Letzte Antwort
                                • H Hicki
                                  Ok. Vielen Dank.
                                  Gruß Hicki
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #460
                                  @Hicki zumindest sollte mal ein Ansatz in der Grafik zu erkennen sein, wenn alles richtig eingestellt ist
                                  • H Hicki
                                    Ok. Vielen Dank.
                                    Gruß Hicki
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #461
                                    @Hicki Je nach eingestelltem Zeitintervall wirst du eine ganze Weile warten müssen.
                                    Eine "richtige" Grafik siehst du erst wenn du mehrere Datenpunkte hast.Meis erst nach 12 - 24 Stunden.
                                    • H Offline
                                      Hicki
                                      #462
                                      Sollte der Ansatz gleich zu sehen sein, oder später.
                                      • H Offline
                                        Hicki
                                        #463
                                        So, Diagramme funktionieren jetzt. Danke an alle die geholfen haben.
                                        Aber, der Filter noch nicht. was könnte ich übersehen haben?
                                        Gruß Hicki
                                            "settings": {
                                              "style": {},
                                              "theme": "redmond",
                                              "sizex": "",
                                              "sizey": "",
                                              "gridSize": "",
                                              "snapType": null
                                            "widgets": {
                                              "e00001": {
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "showValue": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "clearIcon": "",
                                                  "prepandIcon": "",
                                                  "collapseIcon": "",
                                                  "listIcon0": ""
                                                "style": {
                                                  "left": "10px",
                                                  "top": "0px",
                                                  "z-index": "1",
                                                  "height": "40px"
                                              "e00002": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0
                                                "style": {
                                                  "left": "0",
                                                  "top": "0",
                                                  "width": "100%",
                                                  "height": "50px",
                                              "e00003": {
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "12px",
                                                  "width": "60px",
                                                  "height": "26px",
                                                  "color": "#ffffff",
                                                  "z-index": "1",
                                                  "font-size": "12px"
                                              "e00004": {
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "countViews": "15",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "desktopGaps": "4",
                                                "style": {
                                                  "left": "0px",
                                                  "top": "50px",
                                                  "width": "100%",
                                              "e00005": {
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "showValue": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "clearIcon": "",
                                                  "prepandIcon": "",
                                                  "collapseIcon": "",
                                                  "listIcon0": "",
                                                "style": {
                                                  "top": "0px",
                                                  "z-index": "1",
                                                  "height": "40px"
                                            "filterList": []
                                            "settings": {
                                              "style": {
                                              "theme": "redmond",
                                              "sizex": "",
                                              "sizey": "",
                                              "gridSize": "",
                                              "snapType": null
                                            "widgets": {
                                              "e00001": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html": "",
                                                  "subtitle": "",
                                                  "title": "      Welt",
                                                  "name": "Card",
                                                "style": {
                                                  "left": "",
                                                  "top": "",
                                                  "width": "",
                                                  "height": "400px",
                                                  "z-index": ""
                                              "e00002": {
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "dataCount": "3",
                                                  "aggregate": "max",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "pointSize": "0",
                                                  "dataColor1": "",
                                                  "lineTension2": "",
                                                  "lineTension0": "",
                                                "style": {
                                                  "left": "10px",
                                                  "top": "150px",
                                                  "height": "250px",
                                                  "z-index": "1"
                                              "e00003": {
                                                "tpl": "tplImage",
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "left": "10px",
                                                  "top": "18px",
                                                  "width": "30px",
                                                  "height": "30px"
                                              "e00004": {
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "wrapItems": false,
                                                  "lockIconTop": "5",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "iconHeight": "35",
                                                  "oid0": "",
                                                  "itemGaps": "0",
                                                "style": {
                                                  "left": "0px",
                                                  "top": "60px",
                                                  "width": "100%",
                                                  "height": "96px"
                                            "filterList": []
                                              } else {
                                          Hicki
                                          #464
                                              } else {
                                          Wo trägt man das Script eigentlich ein?
                                          Gruß Hicki
