  4. JavaScript
  5. Script: Alexa Listen pflegen und Anzeigen
javascripttemplate
409 Beiträge 29 Kommentatoren 153.5k Aufrufe 42 Beobachtet
    @liv-in-sky
    Beim ersten Test mit 4 Einträgen hat es geklappt.
    Beim 2. Test mit 4 Einträgen hat er test2 wieder stehen gelassen.
    host.rockpro64	2020-03-28 11:09:08.502	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.version: Not exists
    host.rockpro64	2020-03-28 11:09:08.502	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.value: Not exists
    host.rockpro64	2020-03-28 11:09:08.502	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.updatedDateTime: Not exists
    host.rockpro64	2020-03-28 11:09:08.502	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.shoppingListItem: Not exists
    host.rockpro64	2020-03-28 11:09:08.501	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.listName: Not exists
    host.rockpro64	2020-03-28 11:09:08.501	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.listId: Not exists
    host.rockpro64	2020-03-28 11:09:08.486	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.index: Not exists
    host.rockpro64	2020-03-28 11:09:08.486	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.id: Not exists
    host.rockpro64	2020-03-28 11:09:08.486	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.createdDateTime: Not exists
    host.rockpro64	2020-03-28 11:09:08.485	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.completed: Not exists
    host.rockpro64	2020-03-28 11:09:08.485	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7.#delete: Not exists
    host.rockpro64	2020-03-28 11:09:08.484	warn	Objects 127.0.0.1:34930 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.adafbdd3-532d-4e13-99a2-cadb9a8dc4d7: Not exists
    alexa2.0	2020-03-28 11:09:07.978	info	(3990) Deleting item "test3" from the list SHOPPING_LIST.
    alexa2.0	2020-03-28 11:09:07.796	info	(3990) Deleting item "test2" from the list SHOPPING_LIST.
    alexa2.0	2020-03-28 11:09:07.313	info	(3990) Deleting item "test" from the list SHOPPING_LIST.
    alexa2.0	2020-03-28 11:09:07.064	info	(3990) Deleting item "test1" from the list SHOPPING_LIST.
    alexa2.0	2020-03-28 11:08:49.237	info	(3990) Adding item "test3" ({"value":"test3"}) to the list SHOPPING_LIST.
    alexa2.0	2020-03-28 11:08:41.841	info	(3990) Adding item "test2" ({"value":"test2"}) to the list SHOPPING_LIST.
    alexa2.0	2020-03-28 11:08:34.971	info	(3990) Adding item "test1" ({"value":"test1"}) to the list SHOPPING_LIST.
    alexa2.0	2020-03-28 11:08:28.322	info	(3990) Adding item "test" ({"value":"test"}) to the list SHOPPING_LIST.
    liv-in-skyL
    liv-in-skyL
    #207
    @Yetiberg ehrlich gesagt, ich weiß nicht mal was mit InMemDB gemeint ist
    hab ich noch nie gehabt
    • liv-in-skyL liv-in-sky
      #208
      @liv-in-sky Vermute das es eine art Datenbank für den alexa2 Adapter ist.
      Und dann wird schneller gelöscht als der Adapter das macht und findet dann die Einträge nicht mehr.
      Aber, das muss Dir keinen Kopf machen.
      Wat nicht geht, das geht nicht :-)
        @liv-in-sky
        liv-in-skyL
        liv-in-skyL
        #209
        @Yetiberg ein bischen "kopf machen" muss sein - ein script, dass nicht funktioniert ist ja irgendwie sinnlos
        kannst du das ganze mal testen, indem du über die app eingibst und wartest, bis du die items unter objekte-tab siehst und dann erst in der vis alles löscht
        vielleicht hat das was mit caching zu tun -
          liv-in-skyL
          liv-in-skyL
          #210
          @Yetiberg
          zum test:
          dazu kannst du das schedule runter stellen im script - sonst mußt du lange warten z.b. "*/20 * * * * *" alle 20 sek
            #211
            @liv-in-sky Die items werden sofort on the Fly angelegt.
            Das hatte ich schonmal beobachtet. Und jetzt wieder.
            Nun hat er den letzten test4 stehen lassen.
            Und neuer Fehler:
            host.rockpro64	2020-03-28 11:24:16.630	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.version: Not exists
            host.rockpro64	2020-03-28 11:24:16.630	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.value: Not exists
            host.rockpro64	2020-03-28 11:24:16.609	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.updatedDateTime: Not exists
            host.rockpro64	2020-03-28 11:24:16.609	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.shoppingListItem: Not exists
            host.rockpro64	2020-03-28 11:24:16.608	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.listName: Not exists
            host.rockpro64	2020-03-28 11:24:16.607	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.listId: Not exists
            host.rockpro64	2020-03-28 11:24:16.607	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.index: Not exists
            host.rockpro64	2020-03-28 11:24:16.607	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.id: Not exists
            host.rockpro64	2020-03-28 11:24:16.607	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.createdDateTime: Not exists
            host.rockpro64	2020-03-28 11:24:16.606	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.completed: Not exists
            host.rockpro64	2020-03-28 11:24:16.606	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce.#delete: Not exists
            host.rockpro64	2020-03-28 11:24:16.605	warn	Objects 127.0.0.1:56028 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.b1efb10e-ff48-49ba-bc5a-f63bdf30afce: Not exists
            javascript.0	2020-03-28 11:24:16.466	warn	(3227) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-03-28 11:24:16.462	warn	(3227) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-03-28 11:24:16.461	warn	(3227) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-03-28 11:24:16.461	warn	(3227) at ontimeout (timers.js:438:13)
            javascript.0	2020-03-28 11:24:16.460	warn	(3227) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
            javascript.0	2020-03-28 11:24:16.460	warn	(3227) at Object.timer (script.js.Datenpunkte.Einkaufsliste1:434:4)
            javascript.0	2020-03-28 11:24:16.459	warn	(3227) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
            javascript.0	2020-03-28 11:24:16.455	warn	(3227) State "alexa2.0.Lists.SHOPPING_LIST.items.46b0cade-174a-4fed-95d5-b5c18318dddd.#delete" not found
            alexa2.0	2020-03-28 11:24:16.261	info	(17798) Deleting item "test" from the list SHOPPING_LIST.
            liv-in-skyL apollon77A 2 Antworten Letzte Antwort
              Und neuer Fehler:
              liv-in-skyL
              liv-in-skyL
              #212
              @Yetiberg
              schau doch mal ob dein cache deaktiviert ist - wir hatten das mal bei einem anderen problem auf true gesetzt - wenn es nix nutzt, kannst du immer noch zurücksetzen
              zitat:
              In der Datei (Pfade stimmen für Linux)
              /opt/iobroker/iobroker-data/iobroker.json
              die Option "noFileCache" auf true stellen und iobroker (nicht nur den Admin, sondern den kompletten Controller) neu starten.
              aber mit vorsicht ändern !!!
                @Yetiberg
                #213
                @liv-in-sky Nee, hat sich nichts geändert.
                Lässt immer ein item stehen und die gleichen InMemDB Fehler
                Wieder rückgängig gemacht.
                  Und neuer Fehler:
                  apollon77A
                  apollon77A
                  #214
                  @Yetiberg also der Fehler sollte in der aktuellsten Version im latest repo weg sein. Welche Version nutzt ihr? Ich glaube 3.1.2 wäre latest version.
                  Und der fehle mit dem inMemDb kommt da es vorkam das er versucht hat die Objekte doppelt zu löschen. Das sollte gefixt sein. Also gelöscht wurde es bisher problemlos (er hat’s nur doppelt versucht und der zweite Befehl gab halt dann einen Fehler)
                  ? liv-in-skyL 2 Antworten Letzte Antwort
                  • apollon77A apollon77
                    #215
                    @apollon77 3.1.2 habe ich installiert seit dem Du die Version rausgebracht hast.
                    apollon77A liv-in-skyL 2 Antworten Letzte Antwort
                      apollon77A
                      apollon77A
                      #216
                      @Yetiberg dann bitte debug log von den problematischen Aktion schicken und GitHub issue anlegen. Üblicher Prozess ;-)
                        liv-in-skyL
                        liv-in-skyL
                        #217
                        @apollon77 manchmal funktioniert es - habe latest version
                        wenn ich mehrere lösche über array dann bleibt manchmal ein (oder auch 2) datenpunkt(e) über - der kann dann nicht mehr über #delete dp gelöscht werden - muss von hand aus den objekten gelöscht werden - in der app ist er jedoch nicht mehr vorhanden - mein script zeigt ihn weiterhin an, da er ja als datenpunkt existiert.
                        ich habe mal eine pause von je einer sekunde beim löschen eingesetzt (= jede sekunde wird ein eintrag gelöscht) - bringt eine kleine verbesserung
                        ich habe keine fehler oder warnungen des scriptes im im log
                        das ist das log, wenn ich über delete versuche die übergebliebenen dp zu löschen
                        2020-03-28 17:06:11.153  - debug: alexa2.0 (31033) Alexa-Push-Connection Device Volume change for G0911B0592830RM7 -> 80/false
                        2020-03-28 17:06:11.154  - debug: alexa2.0 (31033) State changed alexa2.0.Echo-Devices.G0911B0592830RM7.Player.volume: {"val":80,"ack":true,"ts":1585411571153,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1584189053916}
                        2020-03-28 17:06:11.154  - debug: alexa2.0 (31033) State changed alexa2.0.Echo-Devices.G0911B0592830RM7.Player.muted: {"val":false,"ack":true,"ts":1585411571153,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1576952407328}
                        2020-03-28 17:06:15.650  - info: javascript.0 (256) script.js.Armin_Schalter.ALEXA.ALEXAEinkauf3Spalten: 3
                        2020-03-28 17:06:16.651  - info: javascript.0 (256) script.js.Armin_Schalter.ALEXA.ALEXAEinkauf3Spalten: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.94ff57b8-c2a1-49f0-8117-a39d82a82990.#delete
                        2020-03-28 17:06:16.652  - debug: alexa2.0 (31033) State changed alexa2.0.Lists.SHOPPING_LIST.items.94ff57b8-c2a1-49f0-8117-a39d82a82990.#delete: {"val":true,"ack":false,"ts":1585411576651,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1585411084865}
                        2020-03-28 17:06:16.652  - info: alexa2.0 (31033) Deleting item "Sjidnrkrkr" from the list SHOPPING_LIST.
                        2020-03-28 17:06:16.652  - debug: alexa2.0 (31033) Alexa-Remote: No authentication check needed (time elapsed 423695)
                        2020-03-28 17:06:16.653  - debug: alexa2.0 (31033) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/namedLists/YW16bjEuYWNjb3VudC5BSFpLRkxRNFA1N1ZPVlhMNUZZV0k1TzVOS0NBLVNIT1BQSU5HX0lURU0=/item/94ff57b8-c2a1-49f0-8117-a39d82a82990","method":"DELETE","timeout":10000,"headers":{"Content-Length":144}} and data={"listId":"YW16bjEuYWNjb3VudC5BSFpLRkxRNFA1N1ZPVlhMNUZZV0k1TzVOS0NBLVNIT1BQSU5HX0lURU0=","id":"94ff57b8-c2a1-49f0-8117-a39d82a82990","value":""}
                        2020-03-28 17:06:17.153  - info: javascript.0 (256) script.js.Armin_Schalter.ALEXA.ALEXAEinkauf3Spalten: dummy,94ff57b8-c2a1-49f0-8117-a39d82a82990,ad5130ea-a409-4e5d-803f-f2bd4677bc3e
                        2020-03-28 17:06:17.650  - info: javascript.0 (256) script.js.Armin_Schalter.ALEXA.ALEXAEinkauf3Spalten: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.ad5130ea-a409-4e5d-803f-f2bd4677bc3e.#delete
                        2020-03-28 17:06:17.651  - debug: alexa2.0 (31033) State changed alexa2.0.Lists.SHOPPING_LIST.items.ad5130ea-a409-4e5d-803f-f2bd4677bc3e.#delete: {"val":true,"ack":false,"ts":1585411577650,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1585411084866}
                        2020-03-28 17:06:17.651  - info: alexa2.0 (31033) Deleting item "Rjtjeidl" from the list SHOPPING_LIST.
                        2020-03-28 17:06:17.651  - debug: alexa2.0 (31033) Alexa-Remote: No authentication check needed (time elapsed 424694)
                        2020-03-28 17:06:17.652  - debug: alexa2.0 (31033) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/namedLists/YW16bjEuYWNjb3VudC5BSFpLRkxRNFA1N1ZPVlhMNUZZV0k1TzVOS0NBLVNIT1BQSU5HX0lURU0=/item/ad5130ea-a409-4e5d-803f-f2bd4677bc3e","method":"DELETE","timeout":10000,"headers":{"Content-Length":144}} and data={"listId":"YW16bjEuYWNjb3VudC5BSFpLRkxRNFA1N1ZPVlhMNUZZV0k1TzVOS0NBLVNIT1BQSU5HX0lURU0=","id":"ad5130ea-a409-4e5d-803f-f2bd4677bc3e","value":""}
                        2020-03-28 17:06:20.514  - info: javascript.0 (256) script.js.Armin_Schalter.ALEXA.ALEXAEinkauf3Spalten: dummy,94ff57b8-c2a1-49f0-8117-a39d82a82990,ad5130ea-a409-4e5d-803f-f2bd4677bc3e
                        fehler wenn viele schnell gelöscht werden
                        [iobroker.2020-03-28.log](/assets/uploads/files/1585416636260-iobroker.2020-03-28.log)
                        github: https://github.com/Apollon77/ioBroker.alexa2/issues/420
                          apollon77A
                          apollon77A
                          #218
                          @liv-in-sky ist das Objekt wirklich noch da? Oder zeigt es Admin nur noch an? Mal im Admin Objekte neu geladen bzw Fenster Shift-Reload?
                            liv-in-skyL
                            liv-in-skyL
                            #219
                            @apollon77 alles probiert- muss es tatsächlich von hand löschen - die objekte samt states bleiben stehen - wären sie nicht da, würde das script sie nicht finden
                              liv-in-skyL
                              liv-in-skyL
                              #220
                              @Yetiberg teste doch bitte bei gelegenheit dieses script für die einkaufsliste - hauptsächlich das "alles" löschen ist interessant - das löschen dauert bei dieser version einige zeit länger
                              du kannst das setting von deinem existierenden script kopieren und stoppe bitte das momentan laufende
                               //@liv-in-sky 2020  28.3.-9:42
                               const dpPrefix = "javascript."+ instance +".";
                              createState("Alexa_Listen.ALEXALists.Einkauf.Anlegen"             , "",{ name: 'Anlegen_VIS',  type: 'string', read:  true,  write: true,});
                              createState("Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf"           , { name: 'ALEXAEinkauf_VIS',  type: 'string', read:  true,  write: true,});
                              createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte"   , { name: 'AuswahlDeleteWert_VIS',  type: 'string', read:  true,  write: true,});
                              createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte"  , { name: 'AuswahlDeleteTexte_VIS',  type: 'string', read:  true,  write: true,});
                              createState("Alexa_Listen.ALEXALists.Einkauf.Anzahl"  , { name: 'Einkauf_Anzahl_VIS',  type: 'number', read:  true,  write: true,});
                              createState("Alexa_Listen.ALEXALists.Einkauf.DeleteALL"  , { name: 'Einkauf_DeleteALL',  type: 'boolean', role: 'switch', read:  true,  write: true,});
                              createState("Alexa_Listen.ALEXALists.Einkauf.Refresh"  , { name: 'Refresh',  type: 'boolean', role: 'switch', read:  true,  write: true,});
                              //createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete"       , { name: 'AuswahlDelete_VIS',  type: 'number', read:  true,  write: true,});
                              createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete", {
                               role: "state",
                               type: "number",
                               states: "0:choose ...;1:eeee;2:test1;3:test;",
                               min: 0,
                               max: 50,
                               def: 0,
                               read: true,
                               write: true});
                              //HIER WIRD PFAD UND FILENAME DEFINIERT
                              const path = "/htmltelegram.html";                   //FIlenamen definieren
                              const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                              let   braucheEinFile=false;                          // bei true wird ein file geschrieben - für iqontrol
                              let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben
                              let   braucheTelegram=false;
                              let dpVIS=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf";                      // dp  für VIS-HTML-Basic-Widget // Datentyp: String
                              let dPDELETE=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete";                  // Datentyp: Werteliste
                              let dPDELETEWert=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte";         // Datentyp: String
                              let dPDELETEAuswahl=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte";      // Datentyp: String
                              let dpANLEGEN=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Anlegen";                       // Datentyp: String
                              let dpAnzahl=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Anzahl";                         // Datentyp: Number
                              let dpDelAll=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.DeleteALL";                      // Datentyp: Boolean
                              let dpRefresh=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Refresh";                      // Datentyp: Boolean
                              let mySchedule=" */20 * * * * * ";
                              let sortList=1;        // SORTIERUNG 1=nach datum; 2 nach Einkauf's
                              let mitErstelldatum=false;
                              var symbolLink="⚪";        //  👎  💀 ❌  ⚪  ⚫ ⭕  🔴 🔵
                              let farbeSchalterON="blue";
                              //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                              var htmlFeld1='Einkauf';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left or center
                              var htmlFeld2='Del';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                              var htmlFeld3='Erstellt vor';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                              //hier werden die styles für die tabelle definiert
                              //ÜBERSCHRIFT ÜBER TABELLE
                              let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                              let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                              const htmlFeldUeber='ALEXA Einkaufsliste';              // Überschrift und Signature
                              const htmlFarbUber="white";                         // Farbe der Überschrift
                              const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                              const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                              //MEHRERE TABELLEN NEBENEINANDER
                              let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                              const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                              const farbetrennungsLinie="white";
                              const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                              const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                              //ÜBERSCHRIFT SPALTEN
                              const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                              const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
                              const farbeLinieUnterUeberschrift="white";
                              const groesseUeberschrift=16;
                              const UeberschriftStyle="normal"                     // möglich "bold"
                              //GANZE TABELLE
                              let abstandZelle="3";
                              let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                              let farbeGeradeZeilen="#2E2E2E";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                              let weite="auto";                                     //Weite der Tabelle
                              let zentriert=true;                                   //ganze tabelle zentriert
                              const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                              const htmlSchriftart="Helvetica";
                              const htmlSchriftgroesse="14px";
                              //FELDER UND RAHMEN
                              let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                              const htmlFarbFelderschrift="#36d5ec";                  // SchriftFarbe der Felder
                              const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                              const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                              const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                              const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                              let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                              const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                              // HIER NICHTS  ÄNDERN
                              let borderHelpBottum;
                              let borderHelpRight;
                              let htmlcenterHelp;
                              let htmlcenterHelp2;
                              if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                              if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                              if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                              if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                              zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                              zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                              const htmlZentriert='<center>'
                              const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                                 "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                                 " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                                // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                                 " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                                 " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                                 "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                                 " </style></head><body> <div>";
                              //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                              const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                    "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                              const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                              const htmlTabUeber3="</tr>";
                              table td:first-child {}  //1
                              table td:nth-child(2) {} //2
                              table td:nth-child(3) {} //3
                              table td:last-child {}   //4
                              const buttonScript =  '<script> function setOnDblClickCustom( myvalue ) {	var Self = this; var objID = myvalue;	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, true);  }); var2 = \"' + dpPrefix + 'Alexa_Listen.ALEXALists.Einkauf.Refresh\"; Self.servConn.setState(var2, true); console.log("www")} </script>'
                              // const buttonScript =  '<script> function setOnDblClickCustom( myvalue ) {	var Self = this; var objID = myvalue;	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, true);  }); var2 = \"javascript.0.Alexa_Listen.ALEXALists.Einkauf.Refresh\"; Self.servConn.setState(var2, true); console.log("www")} </script>'
                              //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                                 	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                              var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                                 "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                              var htmlTabUeber="";
                              var htmlOut="";
                              var mix;
                              var counter;
                              var warte;
                              var myIDArr=[];
                              var myRememberList="";
                              var myTelegram=false;
                              var telegramString="";
                              //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                              var val1; var val2; var val0; var val3; var valSort;
                              function writeHTML(){
                              htmlOut="";
                              counter=-1;
                              htmlTabUeber="";
                              switch (mehrfachTabelle) {
                                 case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                                 case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                 case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                                 case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                              if (!UeberschriftSpalten) {htmlTabUeber=""}
                              var valID; var myListWerte=""; var myListAuswahl="";
                              //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                              //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                              var myArr=[]; var myList=""; var myListArr=[]; myIDArr=[];
                              myListArr.push('0'+":"+'choose ...'+";");
                                          myListWerte=myListWerte+"choose ..."+";";
                                         myListAuswahl=myListAuswahl+(0+";");
                                         myIDArr.push("dummy");
                              $('alexa2.0.Lists.SHOPPING_LIST.items.*.value').each(function(id, i) {           // hier eigene schleife definierenalexa2.0.Lists.SHOPPING_LIST.items.0f43141e-029c-4860-bcd0-828702b0dc86.value
                                         val0=getState(id).val;
                                         val1=getState(id.replace("value","completed")).val;
                                         val2=valSort=getState(id.replace("value","updatedDateTime")).val;
                                         valID=getState(id.replace("value","id")).val;
                                         myIDArr.push(valID);
                                         var yy= (Math.round((new Date()).getTime() / 1000))-Math.round(val2/1000);
                                         val2=formatDate(getDateObject(val2), "TT.MM(SS:mm)")
                                         val3=(Math.floor( ((yy)/60/60/24) )+"d "+ Math.floor(((yy)/60/60) % 24) +"h "+ Math.floor( ((yy)/60) % 60 )+"m")
                                      //   if (val1==false) {val1="❌"} else{val1="✅"}
                                          let valButton=id.replace("value","#delete")
                                         //log(valButton)
                                         val1="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolLink + "</button> <font color=\""+farbeSchalterON+"\">";
                                         myArr.push([val0,val1,val2,val3,valSort]);
                                         val0=val0.replace(/,/g,'-');
                                         myListArr.push((i+1)+":"+val0+";");
                                         myListWerte=myListWerte+val0+";";
                                         myListAuswahl=myListAuswahl+(i+1)+";";
                                     log(myIDArr.toString())
                                      //log (myListArr.toString());
                                     for (var x=0;x<myListArr.length;x++){
                                       myList=myList.concat(myListArr[x]);
                                      // log(myListArr[x]);
                                       //log(myList);
                                    // log("-----------myList : "+myList)
                                     if(myList!=myRememberList){
                                         myTelegram=true; //log("ist true")
                                         setStateDelayed(dPDELETEWert, myListAuswahl,500);
                                         setStateDelayed(dPDELETEAuswahl,  myListWerte,500);
                                       var timeout = setTimeout(function () {
                                          var obj = getObject(dPDELETE);
                                          // log("11---"+myList);
                                          obj.common.states=myList;
                                          myRememberList=myList;
                                          //log("22---"+myList);
                                         setObject(dPDELETE, obj);
                                       }, 400);
                               //SORT
                                 if (sortList==1) {
                                               myArr.sort(function (alpha, beta) {
                                            if (alpha[4] > beta[4])
                                               return -1;
                                            if (beta[4] > alpha[4])
                                               return 1;
                                            return 0;
                                                  } else
                                     {          myArr.sort(function (alpha, beta) {
                                            if (alpha[0].toUpperCase() > beta[0].toUpperCase())
                                               return 1;
                                            if (beta[0].toUpperCase() > alpha[0].toUpperCase())
                                               return -1;
                                            return 0;
                                                  telegramString="";
                                for (var x=0 ; x<myArr.length ; x++) {
                                    counter++;
                                   //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 2 Felder definiert, braucht man hier 2 Werte
                                     val0=myArr[x][0];
                                     val1=myArr[x][1];
                                     var val2help=myArr[x][2]
                                     var val3help=myArr[x][3];
                                     if (mitErstelldatum) {val2=val3help+" am "+val2help;} else {val2=val3help}
                                     if (backgroundAll) {
                                        telegramString=telegramString+ myArr[x][0] + " - "+myArr[x][2] + '\n';   // "-"+ myArr[x][1]  +
                                      tabelleBind();
                              //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                    tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                              } // function ende
                              //MAIN:
                              schedule(mySchedule,  function () {
                                if(!getState(dpDelAll).val) writeHTML();
                                  if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                  }, 500);
                              writeHTML();
                               }, 2000);                                  //     <tdalign
                               function tabelleBind(){
                                 //  counter=counter+mehrfachTabelle;
                                       case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                                       case 2: if(counter%4==0){
                                                  if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                             else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                                    }else{
                                                              if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                             else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                                       case 3:if(counter%2==0)   {
                                                  if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //Teil1 c=0
                                                             else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        "; \"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //Teil 2 c=1
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";} //Teil 3 c=3
        } break;}else{
                                                  if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        } break;}
                                       case 4:  // counter=counter+8;
                                                 if(counter%8==0)   {
                                                 if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
                                                 if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                                      } //switch ende
                              function tabelleFinish() {
                                     case 1:    break;
                                     case 2:
                                                if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                break;
                                     case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                               if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                               if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                break;
                                     case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                               if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                               if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                               if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                               break; }
                                       var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                     var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                      if (!htmlSignature) htmlUnter="";
                                        //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                         var htmlOutVIS="";
                                       //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                          if (htmlUberschrift)
                                              { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript ;
                                            } else {
                                             zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript;
                                // log("bin raus aus tabelleBind");
                                         if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                               var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                var htmlEnd="</table>"+htmlUnter+"</div></body>";
                               //mit oder ohne überschrift - zentriert oder links
                              htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                               //log(htmlOut);
                               setState(dpANLEGEN,"");
                               setState(dpAnzahl,(counter+1));
                               setState(dPDELETE,0);
                               if(myTelegram && braucheTelegram){
                                   //log("sende");
                                   myTelegram=false;
                                  sendTo('telegram.0', {
                                 text: (telegramString),
                                 type: 'text'
                              telegramString="";
                              } // function ende
                              on({id: dPDELETE, ack: false, change: "ne"}, function (obj) {
                                 let a=getState(dPDELETE).val;
                                 if (a!=0){
                                 let toDelete=myIDArr[getState(dPDELETE).val];
                                 var stateHelp="alexa2.0.Lists.SHOPPING_LIST.items."+toDelete+".#delete"
                                 setState(stateHelp,true);
                                 writeHTML(); }, 2000);
                                // log("1+bin im on !!!+++!"+a+stateHelp)
                                 on({id: dpANLEGEN, ack: false, change: "ne"}, function (obj) {
                                     //log(getState(dpANLEGEN).val+"----aa");
                                     if(getState(dpANLEGEN).val!="") {
                                  setState("alexa2.0.Lists.SHOPPING_LIST.#New",getState(dpANLEGEN).val)
                                     on({id: dpRefresh, ack: false, change: "any"}, function (obj) {
                                     //log(getState(dpANLEGEN).val+"----refresh");
                                     var timeout2 = setTimeout(function () {
                                 writeHTML(); }, 1000);
                                   on({id: dpDelAll, ack: false,val: true}, function (obj) {
                               let i;
                               for (i=0;i<myIDArr.length;i++) {//log("hier : "+myIDArr[i]);
                                 if (myIDArr[i]!="dummy") {
                                 let toDelete=myIDArr[i];
                                    setTimeout( function timer(){
                                 log("Statehelp: "+stateHelp)
                                 }, i*1500 );
                                 log(i.toString())
                                      setState(dpDelAll,false);
                                      writeHTML(); }, (1+myIDArr.length)*1500);
                                // log(stateHelp)
                                #221
                                6 Testeinträge gemacht.
                                javascript.0	2020-03-29 18:26:00.508	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,178876ff-80f1-4514-88d1-22cd765fae44,2ecaf1bb-b057-4fe6-b6c9-bc682db9df93,3e51b99a-eeff-4345-a6df-feb59b9d46dd,5c4102de-98b7-47d9-8955-c71fb367b471,a
                                javascript.0	2020-03-29 18:25:48.640	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,178876ff-80f1-4514-88d1-22cd765fae44,2ecaf1bb-b057-4fe6-b6c9-bc682db9df93,3e51b99a-eeff-4345-a6df-feb59b9d46dd,5c4102de-98b7-47d9-8955-c71fb367b471,
                                alexa2.0	2020-03-29 18:25:46.618	info	(3979) Adding item "test5" ({"value":"test5"}) to the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:25:43.068	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,178876ff-80f1-4514-88d1-22cd765fae44,2ecaf1bb-b057-4fe6-b6c9-bc682db9df93,3e51b99a-eeff-4345-a6df-feb59b9d46dd,ad698044-4149-423b-bf09-3af96d65f47e,
                                alexa2.0	2020-03-29 18:25:41.070	info	(3979) Adding item "test4" ({"value":"test4"}) to the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:25:35.375	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,2ecaf1bb-b057-4fe6-b6c9-bc682db9df93,3e51b99a-eeff-4345-a6df-feb59b9d46dd,ad698044-4149-423b-bf09-3af96d65f47e,c5461991-1ea8-4764-ba19-a82de1dd9a27
                                alexa2.0	2020-03-29 18:25:33.375	info	(3979) Adding item "test3" ({"value":"test3"}) to the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:25:24.043	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,3e51b99a-eeff-4345-a6df-feb59b9d46dd,ad698044-4149-423b-bf09-3af96d65f47e,c5461991-1ea8-4764-ba19-a82de1dd9a27
                                alexa2.0	2020-03-29 18:25:22.043	info	(3979) Adding item "test2" ({"value":"test2"}) to the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:25:18.188	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,3e51b99a-eeff-4345-a6df-feb59b9d46dd,c5461991-1ea8-4764-ba19-a82de1dd9a27
                                alexa2.0	2020-03-29 18:25:16.189	info	(3979) Adding item "test1" ({"value":"test1"}) to the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:25:12.665	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,3e51b99a-eeff-4345-a6df-feb59b9d46dd
                                alexa2.0	2020-03-29 18:25:10.652	info	(3979) Adding item "test" ({"value":"test"}) to the list SHOPPING_LIST.
                                6 Testeinträge gelöscht.
                                Massig viele Warnmeldungen aber Liste ist Leer.
                                javascript.0	2020-03-29 18:28:19.565	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy
                                javascript.0	2020-03-29 18:28:18.564	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy
                                javascript.0	2020-03-29 18:28:16.562	warn	(3032) at Timer.processTimers (timers.js:223:10)
                                javascript.0	2020-03-29 18:28:16.561	warn	(3032) at listOnTimeout (timers.js:263:5)
                                javascript.0	2020-03-29 18:28:16.561	warn	(3032) at tryOnTimeout (timers.js:300:5)
                                javascript.0	2020-03-29 18:28:16.561	warn	(3032) at ontimeout (timers.js:438:13)
                                javascript.0	2020-03-29 18:28:16.561	warn	(3032) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                                javascript.0	2020-03-29 18:28:16.561	warn	(3032) at Object.timer (script.js.Datenpunkte.Einkaufsliste2:434:4)
                                javascript.0	2020-03-29 18:28:16.561	warn	(3032) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                                javascript.0	2020-03-29 18:28:16.560	warn	(3032) State "alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.#delete" not found
                                javascript.0	2020-03-29 18:28:16.560	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.#delete
                                host.rockpro64	2020-03-29 18:28:16.079	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.version: Not exists
                                host.rockpro64	2020-03-29 18:28:16.078	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.value: Not exists
                                host.rockpro64	2020-03-29 18:28:16.078	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.updatedDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:16.078	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.shoppingListItem: Not exists
                                host.rockpro64	2020-03-29 18:28:16.078	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.listName: Not exists
                                host.rockpro64	2020-03-29 18:28:16.078	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.listId: Not exists
                                host.rockpro64	2020-03-29 18:28:16.078	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.index: Not exists
                                host.rockpro64	2020-03-29 18:28:16.077	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.id: Not exists
                                host.rockpro64	2020-03-29 18:28:16.077	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.createdDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:16.077	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.completed: Not exists
                                host.rockpro64	2020-03-29 18:28:16.077	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.#delete: Not exists
                                host.rockpro64	2020-03-29 18:28:16.076	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27: Not exists
                                alexa2.0	2020-03-29 18:28:15.562	info	(3979) Deleting item "test1" from the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:28:15.557	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.c5461991-1ea8-4764-ba19-a82de1dd9a27.#delete
                                host.rockpro64	2020-03-29 18:28:15.265	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.version: Not exists
                                host.rockpro64	2020-03-29 18:28:15.265	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.value: Not exists
                                host.rockpro64	2020-03-29 18:28:15.265	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.updatedDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:15.261	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.shoppingListItem: Not exists
                                host.rockpro64	2020-03-29 18:28:15.260	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.listName: Not exists
                                host.rockpro64	2020-03-29 18:28:15.258	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.listId: Not exists
                                host.rockpro64	2020-03-29 18:28:15.258	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.index: Not exists
                                host.rockpro64	2020-03-29 18:28:15.258	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.id: Not exists
                                host.rockpro64	2020-03-29 18:28:15.258	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.createdDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:15.257	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.completed: Not exists
                                host.rockpro64	2020-03-29 18:28:15.257	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.#delete: Not exists
                                host.rockpro64	2020-03-29 18:28:15.256	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e: Not exists
                                alexa2.0	2020-03-29 18:28:15.241	info	(3979) Deleting item "test2" from the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:28:15.060	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.#delete
                                alexa2.0	2020-03-29 18:28:14.070	info	(3979) Deleting item "test2" from the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:28:14.057	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.ad698044-4149-423b-bf09-3af96d65f47e.#delete
                                javascript.0	2020-03-29 18:28:13.565	warn	(3032) at Timer.processTimers (timers.js:223:10)
                                javascript.0	2020-03-29 18:28:13.565	warn	(3032) at listOnTimeout (timers.js:263:5)
                                javascript.0	2020-03-29 18:28:13.564	warn	(3032) at tryOnTimeout (timers.js:300:5)
                                javascript.0	2020-03-29 18:28:13.564	warn	(3032) at ontimeout (timers.js:438:13)
                                javascript.0	2020-03-29 18:28:13.564	warn	(3032) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                                javascript.0	2020-03-29 18:28:13.563	warn	(3032) at Object.timer (script.js.Datenpunkte.Einkaufsliste2:434:4)
                                javascript.0	2020-03-29 18:28:13.563	warn	(3032) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                                javascript.0	2020-03-29 18:28:13.561	warn	(3032) State "alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.#delete" not found
                                javascript.0	2020-03-29 18:28:13.560	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.#delete
                                host.rockpro64	2020-03-29 18:28:13.088	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.version: Not exists
                                host.rockpro64	2020-03-29 18:28:13.088	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.value: Not exists
                                host.rockpro64	2020-03-29 18:28:13.087	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.updatedDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:13.074	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.shoppingListItem: Not exists
                                host.rockpro64	2020-03-29 18:28:13.074	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.listName: Not exists
                                host.rockpro64	2020-03-29 18:28:13.074	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.listId: Not exists
                                host.rockpro64	2020-03-29 18:28:13.074	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.index: Not exists
                                host.rockpro64	2020-03-29 18:28:13.074	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.id: Not exists
                                host.rockpro64	2020-03-29 18:28:13.073	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.createdDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:13.073	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.completed: Not exists
                                host.rockpro64	2020-03-29 18:28:13.073	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.#delete: Not exists
                                host.rockpro64	2020-03-29 18:28:13.072	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471: Not exists
                                alexa2.0	2020-03-29 18:28:12.566	info	(3979) Deleting item "test5" from the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:28:12.557	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.5c4102de-98b7-47d9-8955-c71fb367b471.#delete
                                javascript.0	2020-03-29 18:28:12.062	warn	(3032) at Timer.processTimers (timers.js:223:10)
                                javascript.0	2020-03-29 18:28:12.062	warn	(3032) at listOnTimeout (timers.js:263:5)
                                javascript.0	2020-03-29 18:28:12.062	warn	(3032) at tryOnTimeout (timers.js:300:5)
                                javascript.0	2020-03-29 18:28:12.061	warn	(3032) at ontimeout (timers.js:438:13)
                                javascript.0	2020-03-29 18:28:12.061	warn	(3032) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                                javascript.0	2020-03-29 18:28:12.061	warn	(3032) at Object.timer (script.js.Datenpunkte.Einkaufsliste2:434:4)
                                javascript.0	2020-03-29 18:28:12.061	warn	(3032) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                                javascript.0	2020-03-29 18:28:12.060	warn	(3032) State "alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.#delete" not found
                                javascript.0	2020-03-29 18:28:12.060	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.#delete
                                host.rockpro64	2020-03-29 18:28:11.528	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.version: Not exists
                                host.rockpro64	2020-03-29 18:28:11.527	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.value: Not exists
                                host.rockpro64	2020-03-29 18:28:11.523	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.updatedDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:11.523	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.shoppingListItem: Not exists
                                host.rockpro64	2020-03-29 18:28:11.523	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.listName: Not exists
                                host.rockpro64	2020-03-29 18:28:11.523	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.listId: Not exists
                                host.rockpro64	2020-03-29 18:28:11.523	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.index: Not exists
                                host.rockpro64	2020-03-29 18:28:11.523	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.id: Not exists
                                host.rockpro64	2020-03-29 18:28:11.523	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.createdDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:11.522	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.completed: Not exists
                                host.rockpro64	2020-03-29 18:28:11.522	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.#delete: Not exists
                                host.rockpro64	2020-03-29 18:28:11.522	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd: Not exists
                                alexa2.0	2020-03-29 18:28:11.064	info	(3979) Deleting item "test" from the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:28:11.057	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.3e51b99a-eeff-4345-a6df-feb59b9d46dd.#delete
                                javascript.0	2020-03-29 18:28:10.567	warn	(3032) at Timer.processTimers (timers.js:223:10)
                                javascript.0	2020-03-29 18:28:10.566	warn	(3032) at listOnTimeout (timers.js:263:5)
                                javascript.0	2020-03-29 18:28:10.566	warn	(3032) at tryOnTimeout (timers.js:300:5)
                                javascript.0	2020-03-29 18:28:10.566	warn	(3032) at ontimeout (timers.js:438:13)
                                javascript.0	2020-03-29 18:28:10.565	warn	(3032) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                                javascript.0	2020-03-29 18:28:10.564	warn	(3032) at Object.timer (script.js.Datenpunkte.Einkaufsliste2:434:4)
                                javascript.0	2020-03-29 18:28:10.564	warn	(3032) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                                javascript.0	2020-03-29 18:28:10.562	warn	(3032) State "alexa2.0.Lists.SHOPPING_LIST.items.2ecaf1bb-b057-4fe6-b6c9-bc682db9df93.#delete" not found
                                javascript.0	2020-03-29 18:28:10.560	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.2ecaf1bb-b057-4fe6-b6c9-bc682db9df93.#delete
                                alexa2.0	2020-03-29 18:28:09.588	info	(3979) Deleting item "test3" from the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:28:09.576	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.2ecaf1bb-b057-4fe6-b6c9-bc682db9df93.#delete
                                alexa2.0	2020-03-29 18:28:09.540	info	(3979) Deleting item "test4" from the list SHOPPING_LIST.
                                host.rockpro64	2020-03-29 18:28:09.476	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.version: Not exists
                                host.rockpro64	2020-03-29 18:28:09.475	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.value: Not exists
                                host.rockpro64	2020-03-29 18:28:09.475	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.updatedDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:09.475	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.shoppingListItem: Not exists
                                host.rockpro64	2020-03-29 18:28:09.475	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.listName: Not exists
                                host.rockpro64	2020-03-29 18:28:09.474	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.listId: Not exists
                                host.rockpro64	2020-03-29 18:28:09.474	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.index: Not exists
                                host.rockpro64	2020-03-29 18:28:09.474	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.id: Not exists
                                host.rockpro64	2020-03-29 18:28:09.474	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.createdDateTime: Not exists
                                host.rockpro64	2020-03-29 18:28:09.473	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.completed: Not exists
                                host.rockpro64	2020-03-29 18:28:09.473	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.#delete: Not exists
                                host.rockpro64	2020-03-29 18:28:09.472	warn	Objects 127.0.0.1:43366 Error from InMemDB: Error: ERROR delObject alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44: Not exists
                                javascript.0	2020-03-29 18:28:09.060	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.#delete
                                alexa2.0	2020-03-29 18:28:08.071	info	(3979) Deleting item "test4" from the list SHOPPING_LIST.
                                javascript.0	2020-03-29 18:28:08.057	info	(3032) script.js.Datenpunkte.Einkaufsliste2: Statehelp: alexa2.0.Lists.SHOPPING_LIST.items.178876ff-80f1-4514-88d1-22cd765fae44.#delete
                                javascript.0	2020-03-29 18:28:07.559	info	(3032) script.js.Datenpunkte.Einkaufsliste2: 7
                                javascript.0	2020-03-29 18:28:06.557	info	(3032) script.js.Datenpunkte.Einkaufsliste2: 7
                                javascript.0	2020-03-29 18:28:00.509	info	(3032) script.js.Datenpunkte.Einkaufsliste2: dummy,178876ff-80f1-4514-88d1-22cd765fae44,2ecaf1bb-b057-4fe6-b6c9-bc682db9df93,3e51b99a-eeff-4345-a6df-feb59b9d46dd,5c4102de-98b7-47d9-8955-c71fb367b471,a
                                liv-in-skyL S 2 Antworten Letzte Antwort
                                  liv-in-skyL
                                  liv-in-skyL
                                  #222
                                  @Yetiberg warten wir mal ob apollon noch was rausfindet - bei diesem fehler (den ich nicht habe) weiß ich nicht weiter
                                    #223
                                    @liv-in-sky Gut, mit den gelben Warnmeldungen kann ich leben.
                                    Das Löschen funktioniert nun einwandfrei.
                                    Ich beobachte das mal weiter.
                                    Klasse Arbeit von Dir!
                                    Und was sind das für Meldungen?
                                    Die kommen ja aus Deinem Script:
                                      liv-in-skyL
                                      liv-in-skyL
                                      #224
                                      @Yetiberg hast du im script etwas rot unterkringelt ? außer date befehle
                                        #225
                                        @liv-in-sky Jo, da ist was:
                                        Zeile 216 : states
                                        Zeile 346 : (new Date().getTime())
                                        Zeile 349 (new Date().getTime())
                                        Zeile 367: (new Date().getTime())
                                          Zeile 216 : states
                                          liv-in-skyL
                                          liv-in-skyL
                                          #226
                                          @Yetiberg nee - alles gut - ist kein problem
                                          33.2k
                                          84.3k
