  5. [gelöst] Tag und Nacht schaltung geht nicht
    5.5k
36 Beiträge 4 Kommentatoren 3.9k Aufrufe 3 Beobachtet
  • B bullhead
    hier das Blockly
    kann man da dann das es z.b. vom märz bis mai geht auch noch mit einfügen
    on({id: 'mihome.0.devices.weather_v1_158d0002321578.temperature', change: "ne"}, function (obj) {
      var value = obj.state.val;
      if (compareTime("09:00", "20:00", "between")) {
        if ((obj.state ? obj.state.val : "") <= 28 && (obj.oldState ? obj.oldState.val : "") > 28) {
          setState("sonoff.0.sonoff-Rack-Schlangen.POWER1"/*sonoff-Rack-Schlangen POWER1*/, true);
        } else if ((obj.state ? obj.state.val : "") >= 29 && (obj.oldState ? obj.oldState.val : "") < 29) {
          setState("sonoff.0.sonoff-Rack-Schlangen.POWER1"/*sonoff-Rack-Schlangen POWER1*/, false);
      } else if (compareTime("20:00", "09:00", "between")) {
        if ((obj.state ? obj.state.val : "") <= 25 && (obj.oldState ? obj.oldState.val : "") > 25) {
        } else if ((obj.state ? obj.state.val : "") >= 26 && (obj.oldState ? obj.oldState.val : "") < 26) {
    <block xmlns="http://www.w3.org/1999/xhtml" type="controls_if" id="zD|B/3lF;QNJg4ILclo^" x="-1616" y="-585">
      <value name="IF0">
        <block type="time_compare" id="{7U8ww1vqlUE0#2,WNg^">
          <mutation end_time="true"></mutation>
          <field name="OPTION">between</field>
          <field name="START_TIME">09:00</field>
          <field name="END_TIME">20:00</field>
        </block>
      </value>
      <statement name="DO0">
        <block type="controls_if" id="!ZB-C3F4a~jvkb.D|D8w">
          <value name="IF0">
            <block type="logic_operation" id="VKC1`9[p8Rr*BleBJ}!}" inline="false">
              <field name="OP">AND</field>
              <value name="A">
                <block type="logic_compare" id="+5B/6!tn8y}VfhP)N{LE">
                  <field name="OP">LTE</field>
                  <value name="A">
                    <block type="on_source" id="2|8a8bCC[B?5W2V#uBz2">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="E/Xf-n88Sy#_}|g?k}R2">
                      <field name="NUM">28</field>
                    </block>
                  </value>
                </block>
              </value>
              <value name="B">
                <block type="logic_compare" id="$xVt!a!|wcHU2JH|qS!a">
                  <field name="OP">GT</field>
                  <value name="A">
                    <block type="on_source" id="0qq08Dd?lF{v[7~.WL+K">
                      <field name="ATTR">oldState.val</field>
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="6[:n#~82{uE/cYhm.pr7">
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
            <block type="control" id="mAV9IFI)yXjMtXo2M]D2">
              <mutation delay_input="false"></mutation>
              <field name="OID">sonoff.0.sonoff-Rack-Schlangen.POWER1</field>
              <value name="VALUE">
                <block type="logic_boolean" id=".?ucpaU|BCH~wpk^BXcN">
                </block>
              </value>
            </block>
          </statement>
          <value name="IF1">
            <block type="logic_operation" id="G:|JIMsX)7=HbrREq8u@" inline="false">
              <value name="A">
                <block type="logic_compare" id="37fhU6%N)+/~AU_5WRy1">
                  <field name="OP">GTE</field>
                  <value name="A">
                    <block type="on_source" id="|wgPOLd/d;5|)^`s0E@M">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="vgmNRxtx~R$B1wD0Vo?h">
                      <field name="NUM">29</field>
                    </block>
                  </value>
                </block>
              </value>
              <value name="B">
                <block type="logic_compare" id="AL;l=N%]-}0YJ78+GMj]">
                  <field name="OP">LT</field>
                  <value name="A">
                    <block type="on_source" id="KTsDWA6m65IMm8g4WuPB">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="(y5xD-^AIZ,8t=!,z[OE">
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
          <statement name="DO1">
            <block type="control" id="s7=@{`70/E1ZK[]?RR7J">
                <block type="logic_boolean" id="IaSuQt6pqc4FFX%j16(8">
                </block>
              </value>
            </block>
          </statement>
        </block>
      </statement>
      <value name="IF1">
        <block type="time_compare" id="2FBhN?6fkpPW0qTckokB">
          <field name="START_TIME">20:00</field>
          <field name="END_TIME">09:00</field>
        </block>
      </value>
        <block type="controls_if" id="7UofBY.^-J#_T43e6g!H">
          <value name="IF0">
            <block type="logic_operation" id="NORb1QS-u@Cz$/Lb@;xv" inline="false">
              <value name="A">
                <block type="logic_compare" id="j88Z%:2I)agv1a%)z?-R">
                  <value name="A">
                    <block type="on_source" id="3:wbGW3K;2dQUr.IjP!$">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="FZ:ghnLUtoeu/XhoY{SY">
                      <field name="NUM">25</field>
                    </block>
                  </value>
                </block>
              </value>
              <value name="B">
                <block type="logic_compare" id=",|tpq8=##^uMnED+s9T_">
                  <value name="A">
                    <block type="on_source" id="k)*MzDBL_2{:UQpJ*Srq">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id=";OoOWg%hoW}HfbU|p{S0">
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
            <block type="control" id="x2;9cRQ`?p(vy4!*u=C1">
                <block type="logic_boolean" id="*m},B]WD$kELS:|Tqbsp">
                </block>
              </value>
            </block>
          </statement>
          <value name="IF1">
            <block type="logic_operation" id="{rvkS@Z9$D_Pbg5{`cqh" inline="false">
              <value name="A">
                <block type="logic_compare" id="X#vJ=veI]Jn%BOw|Cx0o">
                  <value name="A">
                    <block type="on_source" id="lQxZUnyn#*c`zICw;I}k">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="fY(}.asp=FiJ1)dyf*v*">
                      <field name="NUM">26</field>
                    </block>
                  </value>
                </block>
              </value>
              <value name="B">
                <block type="logic_compare" id="FVVzlT,(raA{_bh-:T~B">
                  <value name="A">
                    <block type="on_source" id=")`M2XbqnD~iIJ-{GKfW%">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="JsMZ#,F@Lf#VqzFCz`VK">
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
            <block type="control" id="x*VHn98ltm(aGr7+|(,F">
                <block type="logic_boolean" id="?]}`/%:aavasou8WiN{V">
                </block>
              </value>
            </block>
          </statement>
        </block>
      </statement>
    </block>
    @bullhead sagte:
    Hier ein Ansatz:
      @bullhead sagte:
      geht aber noch nicht
      Dann poste mal den vom Blockly erzeugten Javascript-Code ohne die letzte Zeile in Code tags.
      @Jan1 sagte in Tag und Nacht schaltung geht nicht:
      Deine Schalthystetese ist sehr eng und könnte Probleme machen.
      1 K Hysterese sollte nicht zu gering sein.
      Jan1
      @paul53 sagte in Tag und Nacht schaltung geht nicht:
      kommt drauf an, wie schnell die Temperatur wechselt, da ist 1K schon nicht viel. Ich hab da nicht komplett durchgespielt, aber das ist mir eben als erstes in den Sinn gekommen.
      Du warst doch auch an der Lösung der anderen Terrarium Steuerung beteiligt, findest Du den Thread noch, da man das Rad ja nicht noch mal erfinden muss.
        bullhead
        Habe es jetzt so gemacht, muss aber leider sagen das es nicht geht
        Der sonoff schaltet sich leider nicht ein
        Dachte nicht das es so kompliziert wird eine einfache schaltung
        Ich hoffe ihr könnt mir helfen
        BlocklyJavascriptTypeScript
        Skript läuft nicht
        06:03:15.423	info	javascript.0 (7681) Stop script script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1
        Ausgewählte Blöcke exportieren
          <variables>
            <variable type="" id="0t+.MBIh.VJb~_OO8p.t">ist</variable>
            <variable type="" id="//*oIQ2r($TBY]NTG;Yc">soll</variable>
            <variable type="" id="lS[T.(34r52Ro$RrYf$v">Tagessoll</variable>
            <variable type="" id="?9qG~uNR}~O*-o9AVAYZ">aktor</variable>
            <variable type="" id="prt;U,4Y$1:xn})ZeQ71">Nachtsoll</variable>
            <variable type="" id="FI?EUCIS3PX~=l+m!Tps">Wert</variable>
          </variables>
          <block type="on" id="d8M=06k^P_$Yh$j[{8|L" x="-987" y="-587">
            <field name="OID">mihome.0.devices.weather_v1_158d0002321578.temperature</field>
            <statement name="STATEMENT">
              <block type="controls_if" id="8-yMOI;phMDsfr~;V[2W">
                <mutation elseif="2" else="1"></mutation>
                <value name="IF0">
                  <block type="logic_operation" id="g^awKGhR7a,Z3-@C2/|Z" inline="false">
                    <field name="OP">OR</field>
                    <value name="A">
                      <block type="logic_compare" id="iUX5rOd`7?w{Umy8Ti8Y">
                        <field name="OP">EQ</field>
                        <value name="A">
                          <block type="time_get" id="D3xc7?^_P$8=92I.;5kK">
                            <mutation format="false" language="false"></mutation>
                            <field name="OPTION">M</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="math_number" id="8f^Acdo^6-=3[JI3mJ(p">
                            <field name="NUM">12</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="}^[sxxzogz{MOBfdfEyS">
                        <value name="A">
                          <block type="time_get" id="7^OvZsjNw]hV^Y2zA2yp">
                          </block>
                        </value>
                        <value name="B">
                          <block type="math_number" id="*YJ}fF%z43Ez:~c(uw{B">
                            <field name="NUM">3</field>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="variables_set" id="%.l]Rt_l`]OS,B6Wb(i=">
                    <field name="VAR" id="lS[T.(34r52Ro$RrYf$v" variabletype="">Tagessoll</field>
                      <block type="math_number" id="Jkf6:GW^!p,rVb,GKkP9">
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id="~zXbbWH}7-RHaI{1yL^b">
                        <field name="VAR" id="prt;U,4Y$1:xn})ZeQ71" variabletype="">Nachtsoll</field>
                          <block type="math_number" id="ES4v@p@Ix|N/{.j~xe8*">
                            <field name="NUM">24</field>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_compare" id="8D6(!F^,+d/gvVzRu@!5">
                    <value name="A">
                      <block type="time_get" id="]RR)o#6Z(3Isp{G_j3VD">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="oY^Mli;qUetc_[k^-v@w">
                        <field name="NUM">6</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="variables_set" id="}F@zjdF4Gh_5Ww}hf]PD">
                      <block type="math_number" id="vv3~^Fw,PfY*:]]SlP/E">
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id="$A{kn#Q)3`^M7+xo~0R,">
                          <block type="math_number" id="J_#x^in`q`4OtGn5j3=?">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF2">
                  <block type="logic_compare" id="l8m@TAVItkEcBqf@`e[u">
                    <value name="A">
                      <block type="time_get" id="r@V]M]hXw.X*t*Kz/3[8">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="cu`IR32c;eZe3S~h?l1%">
                        <field name="NUM">9</field>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO2">
                  <block type="variables_set" id="d1h_q@[A,vableeCu}Pk">
                      <block type="math_number" id="5mcGtuJ)/2Q~ha2!cn24">
                        <field name="NUM">32</field>
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id="zz8}a-[BRF=gSFiobre,">
                          <block type="math_number" id=")@[eR9f^o7tZC5jSUDZT">
                            <field name="NUM">30</field>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <statement name="ELSE">
                  <block type="variables_set" id="bIip$EC]g?-{~4zPXXkq">
                      <block type="math_number" id=":VJ$p)qSL/61CF%M[q;,">
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id="5)rGP-sVEC~y!pVGNOLJ">
                          <block type="math_number" id="dzZU~MjAY{MM$|f/O#]B">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <next>
                  <block type="controls_if" id="tqj]c9z!29H`!Idm${_a">
                    <value name="IF0">
                      <block type="time_compare" id="Eb8dLv|-1R6XIc`Wru~0">
                      </block>
                    </value>
                      <block type="procedures_callnoreturn" id="*wIu7J*/)DB/(MCUvVNF" inline="true">
                        <mutation name="Regler">
                          <arg name="ist"></arg>
                          <arg name="soll"></arg>
                        </mutation>
                        <value name="ARG0">
                          <block type="variables_get" id="MPD8ky|QAAEU%7~.Yezf">
                            <field name="VAR" id="FI?EUCIS3PX~=l+m!Tps" variabletype="">Wert</field>
                          </block>
                        </value>
                        <value name="ARG1">
                          <block type="variables_get" id="lt{@-X8A3RJF}!E9xg;L">
                          </block>
                        </value>
                      </block>
                    </statement>
                      <block type="procedures_callnoreturn" id="$4k{;]z?~Dp)P*dHGlXS" inline="true">
                        </mutation>
                        <value name="ARG0">
                          <block type="variables_get" id="`lbVb`qU=!bRwrct~7p+">
                          </block>
                        </value>
                        <value name="ARG1">
                          <block type="variables_get" id="R^-+8:6JAd8zy6WuG%xS">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <next>
                      <block type="controls_if" id="7tC3QtnbS[#f[st385TK">
                        <value name="IF0">
                          <block type="logic_compare" id="BS[,Cian(C|t#_4^N.^J">
                            <field name="OP">NEQ</field>
                            <value name="A">
                              <block type="get_value_var" id="1jo*`VAZdDC+$C,ep3o3">
                                <value name="OID">
                                  <shadow type="text" id="rHk4II?vZ#Ok-buhY-le">
                                    <field name="TEXT">sonoff-Rack-Schlangen POWER1</field>
                                  </shadow>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <block type="variables_get" id="BEBiQ4Ne-C.kkXl@mrb|">
                                <field name="VAR" id="?9qG~uNR}~O*-o9AVAYZ" variabletype="">aktor</field>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="control" id="]2+3.aeXxPWVXlE,;}4q">
                              <block type="variables_get" id="BxOpf1`0=}{|#)BnlW|n">
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
          <block type="procedures_defnoreturn" id="kb-O}ffpR!p-{y(H{7kn" x="-363" y="-387">
            <mutation>
              <arg name="ist" varid="0t+.MBIh.VJb~_OO8p.t"></arg>
              <arg name="soll" varid="//*oIQ2r($TBY]NTG;Yc"></arg>
            </mutation>
            <field name="NAME">Regler</field>
            <statement name="STACK">
              <block type="controls_if" id="uBXU(T~2C%^)46+Si?7X">
                <value name="IF0">
                  <block type="logic_compare" id="k4D02ADyI/QoRh}r*V%Y">
                    <value name="A">
                      <block type="variables_get" id="Z5E5ZG~r3tAGoNTS5td7">
                        <field name="VAR" id="0t+.MBIh.VJb~_OO8p.t" variabletype="">ist</field>
                      </block>
                    </value>
                    <value name="B">
                      <block type="variables_get" id="#an=Dx+1C}BaTs0r,%8;">
                        <field name="VAR" id="//*oIQ2r($TBY]NTG;Yc" variabletype="">soll</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="variables_set" id="DpB@.$tm{{mCxSc$1+0l">
                      <block type="logic_boolean" id="^D_0pWJUUzH;EN6q{W4,">
                      </block>
                    </value>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_compare" id="kZIi4OoR[oz))CJNRC*.">
                    <value name="A">
                      <block type="variables_get" id="Fj%$pQV.mnq^!KVAWQ}%">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_arithmetic" id="+W/t_av2pk+^lH0svpWT">
                        <field name="OP">ADD</field>
                        <value name="A">
                          <shadow type="math_number" id="+odctnC6b23q#EZXBnd:">
                            <field name="NUM">1</field>
                          </shadow>
                          <block type="variables_get" id="+uqFEF/UH0Q92DU4DDWb">
                          </block>
                        </value>
                        <value name="B">
                          <shadow type="math_number" id=")a:3t{4J%_.O(N?$7%N5">
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="variables_set" id="E0)N%8C!IC[DGCSSKB7Y">
                      <block type="logic_boolean" id="c(0Px%3xu=^}z%~#7Qk/">
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </xml>
          <variables>
          </variables>
                <value name="IF0">
                    <value name="A">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF1">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                      </block>
                    </value>
                  </block>
                </value>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF2">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                      </block>
                    </value>
                  </block>
                </value>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <next>
                    <value name="IF0">
                      </block>
                    </value>
                        </mutation>
                        <value name="ARG0">
                          </block>
                        </value>
                        <value name="ARG1">
                          </block>
                        </value>
                      </block>
                    </statement>
                        </mutation>
                        <value name="ARG0">
                          </block>
                        </value>
                        <value name="ARG1">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <next>
                        <value name="IF0">
                            <value name="A">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
            <mutation>
            </mutation>
                <value name="IF0">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                      </block>
                    </value>
                  </block>
                </value>
                      </block>
                    </value>
                  </block>
                </statement>
                <value name="IF1">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                        <value name="A">
                          </shadow>
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </xml>
        var ist, soll, Tagessoll, aktor, Nachtsoll, Wert;
         * Beschreibe diese Funktion …
        function Regler(ist, soll) {
          if (ist <= soll) {
            aktor = true;
          } else if (ist >= soll + 1) {
            aktor = false;
        on({id: "mihome.0.devices.weather_v1_158d0002321578.temperature"/*Temperature*/, change: "any"}, function (obj) {
          if ((new Date().getMonth() + 1) == 12 || (new Date().getMonth() + 1) < 3) {
            Tagessoll = 28;
            Nachtsoll = 24;
          } else if ((new Date().getMonth() + 1) < 6) {
            Tagessoll = 29;
            Nachtsoll = 26;
          } else if ((new Date().getMonth() + 1) < 9) {
            Tagessoll = 32;
            Nachtsoll = 30;
          } else {
            Tagessoll = 30;
            Nachtsoll = 28;
            Regler(Wert, Tagessoll);
          } else {
            Regler(Wert, Nachtsoll);
          if (getState('sonoff-Rack-Schlangen POWER1').val != aktor) {
            setState("sonoff.0.sonoff-Rack-Schlangen.POWER1"/*sonoff-Rack-Schlangen POWER1*/, aktor);
        • B bullhead
          Skript läuft nicht
            <variables>
            </variables>
                  <value name="IF0">
                      <value name="A">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <value name="IF1">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <value name="IF2">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <next>
                      <value name="IF0">
                        </block>
                      </value>
                          </mutation>
                          <value name="ARG0">
                            </block>
                          </value>
                          <value name="ARG1">
                            </block>
                          </value>
                        </block>
                      </statement>
                          </mutation>
                          <value name="ARG0">
                            </block>
                          </value>
                          <value name="ARG1">
                            </block>
                          </value>
                        </block>
                      </statement>
                      <next>
                          <value name="IF0">
                              <value name="A">
                                  <value name="OID">
                                    </shadow>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
              <mutation>
              </mutation>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                  <value name="IF1">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </shadow>
                            </block>
                          </value>
                          <value name="B">
                            </shadow>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </xml>
            <variables>
            </variables>
                  <value name="IF0">
                      <value name="A">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <value name="IF1">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <value name="IF2">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <next>
                      <value name="IF0">
                        </block>
                      </value>
                          </mutation>
                          <value name="ARG0">
                            </block>
                          </value>
                          <value name="ARG1">
                            </block>
                          </value>
                        </block>
                      </statement>
                          </mutation>
                          <value name="ARG0">
                            </block>
                          </value>
                          <value name="ARG1">
                            </block>
                          </value>
                        </block>
                      </statement>
                      <next>
                          <value name="IF0">
                              <value name="A">
                                  <value name="OID">
                                    </shadow>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
              <mutation>
              </mutation>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                  <value name="IF1">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </shadow>
                            </block>
                          </value>
                          <value name="B">
                            </shadow>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </xml>
            if (ist <= soll) {
              aktor = true;
              aktor = false;
              Tagessoll = 28;
              Nachtsoll = 24;
              Tagessoll = 29;
              Nachtsoll = 26;
              Tagessoll = 32;
              Nachtsoll = 30;
            } else {
              Tagessoll = 30;
              Nachtsoll = 28;
            } else {
          @bullhead sagte:
          Am Script liegt es nur, wenn falsche Datenpunkte zugeordnet sind. Die Funktionalität ist i.O.
          EDIT: Wert muss die Eigenschaft des Trigger-Datenpunktes sein, keine Variable.
            bullhead
            schrieb am zuletzt editiert von bullhead
            jetzt habe ich eine Fehler meldung
            Hilft das was
            javascript.0	2020-03-12 14:56:38.674	warn	(7681) at processImmediate (timers.js:658:5)
            javascript.0	2020-03-12 14:56:38.674	warn	(7681) at tryOnImmediate (timers.js:676:5)
            javascript.0	2020-03-12 14:56:38.674	warn	(7681) at runCallback (timers.js:705:18)
            javascript.0	2020-03-12 14:56:38.673	warn	(7681) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
            javascript.0	2020-03-12 14:56:38.673	warn	(7681) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:450:25)
            javascript.0	2020-03-12 14:56:38.672	warn	(7681) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1123:38)
            javascript.0	2020-03-12 14:56:38.671	warn	(7681) at Object.<anonymous> (script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1:36:7)
            javascript.0	2020-03-12 14:56:38.669	warn	(7681) getState "sonoff-Rack-Schlangen.POWER1" not found (3)
            javascript.0	2020-03-12 14:56:28.334	warn	(7681) at processImmediate (timers.js:658:5)
            javascript.0	2020-03-12 14:56:28.334	warn	(7681) at tryOnImmediate (timers.js:676:5)
            javascript.0	2020-03-12 14:56:28.333	warn	(7681) at runCallback (timers.js:705:18)
            javascript.0	2020-03-12 14:56:28.333	warn	(7681) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
            javascript.0	2020-03-12 14:56:28.332	warn	(7681) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:450:25)
            javascript.0	2020-03-12 14:56:28.332	warn	(7681) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1123:38)
            javascript.0	2020-03-12 14:56:28.331	warn	(7681) at Object.<anonymous> (script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1:36:7)
            javascript.0	2020-03-12 14:56:28.329	warn	(7681) getState "sonoff-Rack-Schlangen.POWER1" not found (3)
            javascript.0	2020-03-12 13:55:00.865	info	(7681) script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1: registered 1 subscription and 0 schedules
            javascript.0	2020-03-12 13:55:00.860	info	(7681) Start javascript script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1
            • B bullhead
              Hilft das was
              @bullhead sagte:
              Die Datenpunkt-ID ist falsch. Richtig: sonoff.0.sonoff-Rack-Schlangen.POWER1. Außerdem darf Wert keine Variable sein, sondern eine Eigenschaft des Trigger-Datenpunktes.
               <variables>
                 <variable type="" id="bF1xF|Wnc?9aqBo-}j:F">ist</variable>
                 <variable type="" id="Cgu*4]bTekqu6B`AOVaM">soll</variable>
               </variables>
                     <value name="IF0">
                         <value name="A">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <value name="IF1">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <value name="IF2">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <next>
                         <value name="IF0">
                           </block>
                         </value>
                             </mutation>
                             <value name="ARG0">
                               <block type="on_source" id="ArzmS4VQ4Hb^pgIG_fo?">
                               </block>
                             </value>
                             <value name="ARG1">
                               </block>
                             </value>
                           </block>
                         </statement>
                             </mutation>
                             <value name="ARG0">
                               <block type="on_source" id="6q1C8$4]0TLNTl/OMoS}">
                               </block>
                             </value>
                             <value name="ARG1">
                               </block>
                             </value>
                           </block>
                         </statement>
                         <next>
                             <value name="IF0">
                                 <value name="A">
                                     <value name="OID">
                                         <field name="TEXT">sonoff.0.sonoff-Rack-Schlangen.POWER1</field>
                                       </shadow>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                                   </block>
                                 </value>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
               <block type="procedures_defnoreturn" id="kb-O}ffpR!p-{y(H{7kn" x="-512" y="-187">
                 <mutation>
                   <arg name="ist" varid="bF1xF|Wnc?9aqBo-}j:F"></arg>
                   <arg name="soll" varid="Cgu*4]bTekqu6B`AOVaM"></arg>
                 </mutation>
                     <value name="IF0">
                         <value name="A">
                             <field name="VAR" id="bF1xF|Wnc?9aqBo-}j:F" variabletype="">ist</field>
                           </block>
                         </value>
                         <value name="B">
                             <field name="VAR" id="Cgu*4]bTekqu6B`AOVaM" variabletype="">soll</field>
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                     <value name="IF1">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                               </shadow>
                               </block>
                             </value>
                             <value name="B">
                               </shadow>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
              </xml>
                bullhead
                Das geht auch nicht.
                hab keinen plan warum das nicht geht 😞 😞
                J paul53P 2 Antworten Letzte Antwort
                • B bullhead
                  Jan1
                  @bullhead
                  Poste mal Dein aktuelles Blockly als Screenshot.
                  • B bullhead
                    @bullhead sagte:
                    Hast Du den XML-Code aus dem letzten Post importiert ? Ich hatte ihn zwischenzeitlich nochmal geändert wegen Wert.
                      @bullhead sagte:
                      bullhead
                      ja hab ich
                      • B bullhead
                        ja hab ich
                        @bullhead
                        Steht bei Javascript-Code jetzt in Zeile 32 ?
                            Regler((obj.state ? obj.state.val : ""), Tagessoll);
                          @bullhead
                          bullhead
                          nein da steht das
                          • B bullhead
                            nein da steht das
                            @bullhead sagte:
                            nein da steht das
                            Ja, das ist falsch. Da warst Du mit dem Importieren schneller, als ich es korrigieren konnte.
                              @bullhead sagte:
                              nein da steht das
                              bullhead
                              und in 34 steht das
                              • B bullhead
                                und in 34 steht das
                                @bullhead sagte:
                                und in 34 steht das
                                Ist genauso falsch. Im Export oben ist die Korrektur enthalten.
                                B 2 Antworten Letzte Antwort
                                  @bullhead sagte:
                                  und in 34 steht das
                                  bullhead
                                  ich kopiere das oben was im export drinnen ist und importiere es bei mir dann mal schauen ob es geht
                                    @bullhead sagte:
                                    und in 34 steht das
                                    bullhead
                                    Also bis jetzt scheint es zu funktionieren Sonoff schaltet
                                    und nur mal noch zur info für mich, das Script schaltet dann z.b. wenn ich 29°C einstelle +1°C schaltet er dann aus und unter 29°C wieder ein oder?
                                    Wegen dem Script kann man da sagen an was das liegt das er die Datenpunkt-ID nicht richtig nimmt
                                    paul53P 3 Antworten Letzte Antwort
                                    • B bullhead
                                      @bullhead sagte:
                                      Ja, bei <= 29°C wird wieder eingeschaltet.
                                      • B bullhead
                                        @bullhead sagte:
                                        Verstehe die Frage nicht. Die Datenpunkt-ID für getState() wird in Blockly als Text übergeben und Du hast Dich wahrscheinlich vertippt.
                                          bullhead
                                          Das kann natürlich auch sein.
                                          Werde ich ja sehen ob ich noch Probleme bekomme, wenn ich noch Blockly Scripte erstelle.
                                          Bin ja erst am Anfang was ich alles vor habe.
                                          Aber Danke nochmal für die Hilfe
