  5. [gelöst] Tag und Nacht schaltung geht nicht
    5.5k
36 Beiträge 4 Kommentatoren 3.9k Aufrufe 3 Beobachtet
    bullhead
    schrieb am zuletzt editiert von bullhead
    jetzt habe ich eine Fehler meldung
    Hilft das was
    javascript.0	2020-03-12 14:56:38.674	warn	(7681) at processImmediate (timers.js:658:5)
    javascript.0	2020-03-12 14:56:38.674	warn	(7681) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-03-12 14:56:38.674	warn	(7681) at runCallback (timers.js:705:18)
    javascript.0	2020-03-12 14:56:38.673	warn	(7681) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
    javascript.0	2020-03-12 14:56:38.673	warn	(7681) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:450:25)
    javascript.0	2020-03-12 14:56:38.672	warn	(7681) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1123:38)
    javascript.0	2020-03-12 14:56:38.671	warn	(7681) at Object.<anonymous> (script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1:36:7)
    javascript.0	2020-03-12 14:56:38.669	warn	(7681) getState "sonoff-Rack-Schlangen.POWER1" not found (3)
    javascript.0	2020-03-12 14:56:28.334	warn	(7681) at processImmediate (timers.js:658:5)
    javascript.0	2020-03-12 14:56:28.334	warn	(7681) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-03-12 14:56:28.333	warn	(7681) at runCallback (timers.js:705:18)
    javascript.0	2020-03-12 14:56:28.333	warn	(7681) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
    javascript.0	2020-03-12 14:56:28.332	warn	(7681) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:450:25)
    javascript.0	2020-03-12 14:56:28.332	warn	(7681) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1123:38)
    javascript.0	2020-03-12 14:56:28.331	warn	(7681) at Object.<anonymous> (script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1:36:7)
    javascript.0	2020-03-12 14:56:28.329	warn	(7681) getState "sonoff-Rack-Schlangen.POWER1" not found (3)
    javascript.0	2020-03-12 13:55:00.865	info	(7681) script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1: registered 1 subscription and 0 schedules
    javascript.0	2020-03-12 13:55:00.860	info	(7681) Start javascript script.js.Schlangen-Rack.Rack_1.Heizung_Nacht_1
    • B bullhead
      Hilft das was
      @bullhead sagte:
      Die Datenpunkt-ID ist falsch. Richtig: sonoff.0.sonoff-Rack-Schlangen.POWER1. Außerdem darf Wert keine Variable sein, sondern eine Eigenschaft des Trigger-Datenpunktes.
       <variables>
         <variable type="" id="bF1xF|Wnc?9aqBo-}j:F">ist</variable>
         <variable type="" id="Cgu*4]bTekqu6B`AOVaM">soll</variable>
         <variable type="" id="lS[T.(34r52Ro$RrYf$v">Tagessoll</variable>
         <variable type="" id="?9qG~uNR}~O*-o9AVAYZ">aktor</variable>
         <variable type="" id="prt;U,4Y$1:xn})ZeQ71">Nachtsoll</variable>
       </variables>
       <block type="on" id="d8M=06k^P_$Yh$j[{8|L" x="-987" y="-587">
         <field name="OID">mihome.0.devices.weather_v1_158d0002321578.temperature</field>
         <statement name="STATEMENT">
           <block type="controls_if" id="8-yMOI;phMDsfr~;V[2W">
             <mutation elseif="2" else="1"></mutation>
             <value name="IF0">
               <block type="logic_operation" id="g^awKGhR7a,Z3-@C2/|Z" inline="false">
                 <field name="OP">OR</field>
                 <value name="A">
                   <block type="logic_compare" id="iUX5rOd`7?w{Umy8Ti8Y">
                     <field name="OP">EQ</field>
                     <value name="A">
                       <block type="time_get" id="D3xc7?^_P$8=92I.;5kK">
                         <mutation format="false" language="false"></mutation>
                         <field name="OPTION">M</field>
                       </block>
                     </value>
                     <value name="B">
                       <block type="math_number" id="8f^Acdo^6-=3[JI3mJ(p">
                         <field name="NUM">12</field>
                       </block>
                     </value>
                   </block>
                 </value>
                 <value name="B">
                   <block type="logic_compare" id="}^[sxxzogz{MOBfdfEyS">
                     <field name="OP">LT</field>
                     <value name="A">
                       <block type="time_get" id="7^OvZsjNw]hV^Y2zA2yp">
                       </block>
                     </value>
                     <value name="B">
                       <block type="math_number" id="*YJ}fF%z43Ez:~c(uw{B">
                         <field name="NUM">3</field>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
             <statement name="DO0">
               <block type="variables_set" id="%.l]Rt_l`]OS,B6Wb(i=">
                 <field name="VAR" id="lS[T.(34r52Ro$RrYf$v" variabletype="">Tagessoll</field>
                 <value name="VALUE">
                   <block type="math_number" id="Jkf6:GW^!p,rVb,GKkP9">
                     <field name="NUM">28</field>
                   </block>
                 </value>
                 <next>
                   <block type="variables_set" id="~zXbbWH}7-RHaI{1yL^b">
                     <field name="VAR" id="prt;U,4Y$1:xn})ZeQ71" variabletype="">Nachtsoll</field>
                       <block type="math_number" id="ES4v@p@Ix|N/{.j~xe8*">
                         <field name="NUM">24</field>
                       </block>
                     </value>
                   </block>
                 </next>
               </block>
             </statement>
             <value name="IF1">
               <block type="logic_compare" id="8D6(!F^,+d/gvVzRu@!5">
                 <value name="A">
                   <block type="time_get" id="]RR)o#6Z(3Isp{G_j3VD">
                   </block>
                 </value>
                 <value name="B">
                   <block type="math_number" id="oY^Mli;qUetc_[k^-v@w">
                     <field name="NUM">6</field>
                   </block>
                 </value>
               </block>
             </value>
             <statement name="DO1">
               <block type="variables_set" id="}F@zjdF4Gh_5Ww}hf]PD">
                   <block type="math_number" id="vv3~^Fw,PfY*:]]SlP/E">
                     <field name="NUM">29</field>
                   </block>
                 </value>
                 <next>
                   <block type="variables_set" id="$A{kn#Q)3`^M7+xo~0R,">
                       <block type="math_number" id="J_#x^in`q`4OtGn5j3=?">
                         <field name="NUM">26</field>
                       </block>
                     </value>
                   </block>
                 </next>
               </block>
             </statement>
             <value name="IF2">
               <block type="logic_compare" id="l8m@TAVItkEcBqf@`e[u">
                 <value name="A">
                   <block type="time_get" id="r@V]M]hXw.X*t*Kz/3[8">
                   </block>
                 </value>
                 <value name="B">
                   <block type="math_number" id="cu`IR32c;eZe3S~h?l1%">
                     <field name="NUM">9</field>
                   </block>
                 </value>
               </block>
             </value>
             <statement name="DO2">
               <block type="variables_set" id="d1h_q@[A,vableeCu}Pk">
                   <block type="math_number" id="5mcGtuJ)/2Q~ha2!cn24">
                     <field name="NUM">32</field>
                   </block>
                 </value>
                 <next>
                   <block type="variables_set" id="zz8}a-[BRF=gSFiobre,">
                       <block type="math_number" id=")@[eR9f^o7tZC5jSUDZT">
                         <field name="NUM">30</field>
                       </block>
                     </value>
                   </block>
                 </next>
               </block>
             </statement>
             <statement name="ELSE">
               <block type="variables_set" id="bIip$EC]g?-{~4zPXXkq">
                   <block type="math_number" id=":VJ$p)qSL/61CF%M[q;,">
                   </block>
                 </value>
                 <next>
                   <block type="variables_set" id="5)rGP-sVEC~y!pVGNOLJ">
                       <block type="math_number" id="dzZU~MjAY{MM$|f/O#]B">
                       </block>
                     </value>
                   </block>
                 </next>
               </block>
             </statement>
             <next>
               <block type="controls_if" id="tqj]c9z!29H`!Idm${_a">
                 <value name="IF0">
                   <block type="time_compare" id="Eb8dLv|-1R6XIc`Wru~0">
                     <mutation end_time="true"></mutation>
                     <field name="OPTION">between</field>
                     <field name="START_TIME">09:00</field>
                     <field name="END_TIME">20:00</field>
                   </block>
                 </value>
                   <block type="procedures_callnoreturn" id="*wIu7J*/)DB/(MCUvVNF" inline="true">
                     <mutation name="Regler">
                       <arg name="ist"></arg>
                       <arg name="soll"></arg>
                     </mutation>
                     <value name="ARG0">
                       <block type="on_source" id="ArzmS4VQ4Hb^pgIG_fo?">
                       </block>
                     </value>
                     <value name="ARG1">
                       <block type="variables_get" id="lt{@-X8A3RJF}!E9xg;L">
                       </block>
                     </value>
                   </block>
                 </statement>
                   <block type="procedures_callnoreturn" id="$4k{;]z?~Dp)P*dHGlXS" inline="true">
                     </mutation>
                     <value name="ARG0">
                       <block type="on_source" id="6q1C8$4]0TLNTl/OMoS}">
                       </block>
                     </value>
                     <value name="ARG1">
                       <block type="variables_get" id="R^-+8:6JAd8zy6WuG%xS">
                       </block>
                     </value>
                   </block>
                 </statement>
                 <next>
                   <block type="controls_if" id="7tC3QtnbS[#f[st385TK">
                     <value name="IF0">
                       <block type="logic_compare" id="BS[,Cian(C|t#_4^N.^J">
                         <field name="OP">NEQ</field>
                         <value name="A">
                           <block type="get_value_var" id="1jo*`VAZdDC+$C,ep3o3">
                             <value name="OID">
                               <shadow type="text" id="rHk4II?vZ#Ok-buhY-le">
                                 <field name="TEXT">sonoff.0.sonoff-Rack-Schlangen.POWER1</field>
                               </shadow>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                           <block type="variables_get" id="BEBiQ4Ne-C.kkXl@mrb|">
                             <field name="VAR" id="?9qG~uNR}~O*-o9AVAYZ" variabletype="">aktor</field>
                           </block>
                         </value>
                       </block>
                     </value>
                       <block type="control" id="]2+3.aeXxPWVXlE,;}4q">
                         <mutation delay_input="false"></mutation>
                         <field name="OID">sonoff.0.sonoff-Rack-Schlangen.POWER1</field>
                           <block type="variables_get" id="BxOpf1`0=}{|#)BnlW|n">
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </statement>
       </block>
       <block type="procedures_defnoreturn" id="kb-O}ffpR!p-{y(H{7kn" x="-512" y="-187">
         <mutation>
           <arg name="ist" varid="bF1xF|Wnc?9aqBo-}j:F"></arg>
           <arg name="soll" varid="Cgu*4]bTekqu6B`AOVaM"></arg>
         </mutation>
         <field name="NAME">Regler</field>
         <statement name="STACK">
           <block type="controls_if" id="uBXU(T~2C%^)46+Si?7X">
             <value name="IF0">
               <block type="logic_compare" id="k4D02ADyI/QoRh}r*V%Y">
                 <field name="OP">LTE</field>
                 <value name="A">
                   <block type="variables_get" id="Z5E5ZG~r3tAGoNTS5td7">
                     <field name="VAR" id="bF1xF|Wnc?9aqBo-}j:F" variabletype="">ist</field>
                   </block>
                 </value>
                 <value name="B">
                   <block type="variables_get" id="#an=Dx+1C}BaTs0r,%8;">
                     <field name="VAR" id="Cgu*4]bTekqu6B`AOVaM" variabletype="">soll</field>
                   </block>
                 </value>
               </block>
             </value>
               <block type="variables_set" id="DpB@.$tm{{mCxSc$1+0l">
                   <block type="logic_boolean" id="^D_0pWJUUzH;EN6q{W4,">
                   </block>
                 </value>
               </block>
             </statement>
             <value name="IF1">
               <block type="logic_compare" id="kZIi4OoR[oz))CJNRC*.">
                 <field name="OP">GTE</field>
                 <value name="A">
                   <block type="variables_get" id="Fj%$pQV.mnq^!KVAWQ}%">
                   </block>
                 </value>
                 <value name="B">
                   <block type="math_arithmetic" id="+W/t_av2pk+^lH0svpWT">
                     <field name="OP">ADD</field>
                     <value name="A">
                       <shadow type="math_number" id="+odctnC6b23q#EZXBnd:">
                         <field name="NUM">1</field>
                       </shadow>
                       <block type="variables_get" id="+uqFEF/UH0Q92DU4DDWb">
                       </block>
                     </value>
                     <value name="B">
                       <shadow type="math_number" id=")a:3t{4J%_.O(N?$7%N5">
                       </shadow>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
               <block type="variables_set" id="E0)N%8C!IC[DGCSSKB7Y">
                   <block type="logic_boolean" id="c(0Px%3xu=^}z%~#7Qk/">
                   </block>
                 </value>
               </block>
             </statement>
           </block>
         </statement>
       </block>
      </xml>
        bullhead
        Das geht auch nicht.
        hab keinen plan warum das nicht geht 😞 😞
        J paul53P 2 Antworten Letzte Antwort
        • B bullhead
          Jan1
          @bullhead
          Poste mal Dein aktuelles Blockly als Screenshot.
          • B bullhead
            @bullhead sagte:
            Hast Du den XML-Code aus dem letzten Post importiert ? Ich hatte ihn zwischenzeitlich nochmal geändert wegen Wert.
              @bullhead sagte:
              bullhead
              ja hab ich
              • B bullhead
                ja hab ich
                @bullhead
                Steht bei Javascript-Code jetzt in Zeile 32 ?
                    Regler((obj.state ? obj.state.val : ""), Tagessoll);
                  @bullhead
                  bullhead
                  nein da steht das
                  Regler(Wert, Tagessoll);
                  • B bullhead
                    nein da steht das
                    @bullhead sagte:
                    nein da steht das
                    Ja, das ist falsch. Da warst Du mit dem Importieren schneller, als ich es korrigieren konnte.
                      @bullhead sagte:
                      nein da steht das
                      bullhead
                      und in 34 steht das
                      Regler(Wert, Nachtsoll);
                      • B bullhead
                        und in 34 steht das
                        @bullhead sagte:
                        und in 34 steht das
                        Ist genauso falsch. Im Export oben ist die Korrektur enthalten.
                        B 2 Antworten Letzte Antwort
                          @bullhead sagte:
                          und in 34 steht das
                          bullhead
                          ich kopiere das oben was im export drinnen ist und importiere es bei mir dann mal schauen ob es geht
                            @bullhead sagte:
                            und in 34 steht das
                            bullhead
                            Also bis jetzt scheint es zu funktionieren Sonoff schaltet
                            und nur mal noch zur info für mich, das Script schaltet dann z.b. wenn ich 29°C einstelle +1°C schaltet er dann aus und unter 29°C wieder ein oder?
                            Wegen dem Script kann man da sagen an was das liegt das er die Datenpunkt-ID nicht richtig nimmt
                            paul53P 3 Antworten Letzte Antwort
                            • B bullhead
                              @bullhead sagte:
                              Ja, bei <= 29°C wird wieder eingeschaltet.
                              • B bullhead
                                @bullhead sagte:
                                Verstehe die Frage nicht. Die Datenpunkt-ID für getState() wird in Blockly als Text übergeben und Du hast Dich wahrscheinlich vertippt.
                                  bullhead
                                  Das kann natürlich auch sein.
                                  Werde ich ja sehen ob ich noch Probleme bekomme, wenn ich noch Blockly Scripte erstelle.
                                  Bin ja erst am Anfang was ich alles vor habe.
                                  Aber Danke nochmal für die Hilfe
                                  • B bullhead
                                    @bullhead sagte:
                                    Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [gelöst].
                                      bullhead
                                      Muss leider sagen das es jetzt nicht mehr geht, seit es Juni (6) ist.
                                      Schaltet den Sonoff nicht richtig also heizt weiter auch wenn die Temp. erreicht ist
                                      Finde leider nicht raus warum, könnte mir da jemand bitte helfen
                                      <variables>
                                      <variable id="x$ePuFJQIhohSRe@U2g">ist</variable>
                                      <variable id="}bm_h$z?kj.FA0Hlb1U">soll</variable> <variable id="lS[T.(34r52Ro$RrYf$v">Tagessoll</variable> <variable id="?9qG~uNR}~O*-o9AVAYZ">aktor</variable> <variable id="prt;U,4Y$1:xn})ZeQ71">Nachtsoll</variable> </variables> <block type="on" id="d8M=06k^P_$Yh$j[{8|L" x="-988" y="-663"> <field name="OID">mihome.0.devices.weather_v1_158d0002321578.temperature</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="8-yMOI;phMDsfr~;V[2W"> <mutation elseif="2" else="1"></mutation> <value name="IF0"> <block type="logic_operation" id="g^awKGhR7a,Z3-@C2/|Z" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="iUX5rOd7?w{Umy8Ti8Y">
                                      <value name="A">
                                      <block type="time_get" id="D3xc7?^P$8=92I.;5kK">
                                      </block>
                                      </value>
                                      <value name="B">
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      <value name="B">
                                      <value name="A">
                                      </block>
                                      </value>
                                      <value name="B">
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      <block type="variables_set" id="%.l]Rt_l]OS,B6Wb(i="> <field name="VAR" id="lS[T.(34r52Ro$RrYf$v">Tagessoll</field> <value name="VALUE"> <block type="math_number" id="Jkf6:GW^!p,rVb,GKkP9"> <field name="NUM">27</field> </block> </value> <next> <block type="variables_set" id="~zXbbWH}7-RHaI{1yL^b"> <field name="VAR" id="prt;U,4Y$1:xn})ZeQ71">Nachtsoll</field> <value name="VALUE"> <block type="math_number" id="ES4v@p@Ix|N/{.j~xe8*"> <field name="NUM">23</field> </block> </value> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_compare" id="8D6(!F^,+d/gvVzRu@!5"> <field name="OP">LT</field> <value name="A"> <block type="time_get" id="]RR)o#6Z(3Isp{G_j3VD"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block type="math_number" id="oY^Mli;qUetc_[k^-v@w"> <field name="NUM">6</field> </block> </value> </block> </value> <statement name="DO1"> <block type="variables_set" id="}F@zjdF4Gh_5Ww}hf]PD"> <field name="VAR" id="lS[T.(34r52Ro$RrYf$v">Tagessoll</field> <value name="VALUE"> <block type="math_number" id="vv3~^Fw,PfY*:]]SlP/E"> <field name="NUM">28</field> </block> </value> <next> <block type="variables_set" id="$A{kn#Q)3^M7+xo~0R,">
                                      #x^inq4OtGn5j3=?">
                                      <field name="NUM">25</field>
                                      </block>
                                      </value>
                                      </block>
                                      </next>
                                      </block>
                                      </statement>
                                      <value name="IF2">
                                      <block type="logic_compare" id="l8m@TAVItkEcBqf@e[u"> <field name="OP">LT</field> <value name="A"> <block type="time_get" id="r@V]M]hXw.X*t*Kz/3[8"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block type="math_number" id="cuIR32c;eZe3S~h?l1%">
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      <next>
                                      </block>
                                      </value>
                                      </block>
                                      </next>
                                      </block>
                                      </statement>
                                      </block>
                                      </value>
                                      <next>
                                      </block>
                                      </value>
                                      </block>
                                      </next>
                                      </block>
                                      </statement>
                                      <next>
                                      <value name="IF0">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                                      <field name="END_TIME">19:00</field>
                                      </block>
                                      </value>
                                      <block type="procedures_callnoreturn" id="wIu7J/)DB/(MCUvVNF" inline="true">
                                      </mutation>
                                      <value name="ARG0">
                                      </block>
                                      </value>
                                      <value name="ARG1">
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      </mutation>
                                      <value name="ARG0">
                                      </block>
                                      </value>
                                      <value name="ARG1">
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      <next>
                                      <value name="IF0">
                                      <block type="logic_compare" id="BS[,Cian(C|t#4^N.^J">
                                      <value name="A">
                                      <value name="OID">
                                      </shadow>
                                      </value>
                                      </block>
                                      </value>
                                      <value name="B">
                                      <field name="VAR" id="?9qG~uNR}~O*-o9AVAYZ">aktor</field>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      </block>
                                      </next>
                                      </block>
                                      </next>
                                      </block>
                                      </statement>
                                      </block>
                                      <block type="procedures_defnoreturn" id="kb-O}ffpR!p-{y(H{7kn" x="-512" y="-262">
                                      <mutation>
                                      <arg name="ist" varid="x$ePuFJQIhohSRe@U2g"></arg>
                                      <arg name="soll" varid="}bm_h$z?kj.FA0Hlb`1U"></arg>
                                      </mutation>
                                      <value name="IF0">
                                      V%Y">
                                      <value name="A">
                                      <field name="VAR" id="x$ePuFJQIhohSRe@U2g">ist</field>
                                      </block>
                                      </value>
                                      <value name="B">
                                      <field name="VAR" id="}bm_h$z?kj.FA0Hlb`1U">soll</field>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      <value name="IF1">
                                      <value name="A">
                                      <field name="VAR" id="*x$ePuFJQIhohSRe@U2g">ist</field>
                                      </block>
                                      </value>
                                      <value name="B">
                                      <value name="A">
                                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="+odctnC6b23q#EZXBnd:">
                                      </shadow>
                                      </block>
                                      </value>
                                      <value name="B">
                                      .O(N?$7%N5">
                                      </shadow>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      </block>
                                      </statement>
                                      </block>
                                      </xml>
                                      var ist, soll, Tagessoll, aktor, Nachtsoll;
                                      // Beschreibe diese Funktion …
                                      function Regler(ist, soll) {
                                      if (ist <= soll) {
                                      aktor = true;
                                      } else if (ist >= soll + 1) {
                                      aktor = false;
                                      on({id: "mihome.0.devices.weather_v1_158d0002321578.temperature"/Temperature/, change: "any"}, function (obj) {
                                      var value = obj.state.val;
                                      if ((new Date().getMonth() + 1) == 12 || (new Date().getMonth() + 1) < 3) {
                                      Tagessoll = 27;
                                      Nachtsoll = 23;
                                      } else if ((new Date().getMonth() + 1) < 6) {
                                      Tagessoll = 28;
                                      Nachtsoll = 25;
                                      } else if ((new Date().getMonth() + 1) < 9) {
                                      Tagessoll = 30;
                                      Nachtsoll = 28;
                                      } else {
                                      Tagessoll = 29;
                                      Nachtsoll = 27;
                                      if (compareTime("09:00", "19:00", "between")) {
                                      } else {
                                      Regler((obj.state ? obj.state.val : ""), Nachtsoll);
                                      if (getState('sonoff.0.sonoff-Rack-Schlangen.POWER1').val != aktor) {
                                      setState("sonoff.0.sonoff-Rack-Schlangen.POWER1"/sonoff-Rack-Schlangen POWER1/, aktor);
                                      • B bullhead
                                        <variables>
                                        <value name="A">
                                        </block>
                                        </value>
                                        <value name="B">
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        <value name="B">
                                        <value name="A">
                                        </block>
                                        </value>
                                        <value name="B">
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        #x^inq4OtGn5j3=?">
                                        </block>
                                        </value>
                                        </block>
                                        </next>
                                        </block>
                                        </statement>
                                        <value name="IF2">
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        <next>
                                        </block>
                                        </value>
                                        </block>
                                        </next>
                                        </block>
                                        </statement>
                                        </block>
                                        </value>
                                        <next>
                                        </block>
                                        </value>
                                        </block>
                                        </next>
                                        </block>
                                        </statement>
                                        <next>
                                        <value name="IF0">
                                        </block>
                                        </value>
                                        </mutation>
                                        <value name="ARG0">
                                        </block>
                                        </value>
                                        <value name="ARG1">
                                        </block>
                                        </value>
                                        </block>
                                        </statement>
                                        </mutation>
                                        <value name="ARG0">
                                        </block>
                                        </value>
                                        <value name="ARG1">
                                        </block>
                                        </value>
                                        </block>
                                        </statement>
                                        <next>
                                        <value name="IF0">
                                        <value name="A">
                                        <value name="OID">
                                        </shadow>
                                        </value>
                                        </block>
                                        </value>
                                        <value name="B">
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </statement>
                                        </block>
                                        </next>
                                        </block>
                                        </next>
                                        </block>
                                        </statement>
                                        </block>
                                        <mutation>
                                        </mutation>
                                        <value name="IF0">
                                        V%Y">
                                        <value name="A">
                                        </block>
                                        </value>
                                        <value name="B">
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </statement>
                                        <value name="IF1">
                                        <value name="A">
                                        </block>
                                        </value>
                                        <value name="B">
                                        <value name="A">
                                        </shadow>
                                        </block>
                                        </value>
                                        <value name="B">
                                        .O(N?$7%N5">
                                        </shadow>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </value>
                                        </block>
                                        </statement>
                                        </block>
                                        </statement>
                                        </block>
                                        </xml>
                                        if (ist <= soll) {
                                        aktor = true;
                                        aktor = false;
                                        Tagessoll = 27;
                                        Nachtsoll = 23;
                                        Tagessoll = 28;
                                        Nachtsoll = 25;
                                        Tagessoll = 30;
                                        Nachtsoll = 28;
                                        } else {
                                        Tagessoll = 29;
                                        Nachtsoll = 27;
                                        } else {
                                        @bullhead sagte:
                                        Wird nicht bei 31°C am Tag ausgeschaltet ?
                                          bullhead
                                          Stimmt da bin ich falsch gewesen
                                          Passt schon alles
