  4. JavaScript
  5. sitze seit gestern im dunkeln Hue Szenen script ausgefallen
14 Beiträge 5 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • G Offline
    grooovie
    ich hatte bisher immer folgendes Script laufen.
    var HueApi = require("node-hue-api").HueApi;
    var displayResult = function(result) {
    console.log(JSON.stringify(result, null, 2));
     // Replace IP and username!!!
    var hostname = "IP meiner Bridge",
    username = "Token meiner Bridge",
    api;
    api = new HueApi(hostname, username)
    var groups_ = [],
    lights_ = [],
    objects_ = [];
    // Log JSON results
    var displayResults = function(result) {
    console.log('Reponse: '+JSON.stringify(result, null, 2));
    // Parse Light Group 0 (All Lights)
    var parseGroup0 = function(result) {
    if (!result.lights){return} // Empty group
    var id = result.id,
        lights = result.lights,
        name = "All Lights";
    console.debug('group: '+name+', lights: '+lights);
    groups_[lights] = name;
    // Parse Light Groups
    var parseGroups = function(result) {
    for (var i = 0; i < result.length; i++) {
        if (!result[i].lights){continue} // Empty group
        var id = result[i].id,
            lights = result[i].lights,
            name = result[i].name;
    // Parse Lights
    var parseLights = function(result) {
        console.debug('light: '+name+', id: '+id);
        lights_[id] = name;
    // Create States in ioBroker
    var createStates = function(result) {
        // Resync button
    createState('PhilipsHue.Scenes.Resync', false, {role: "button", name: 'Resync Philips Hue Groups, Lights and Scenes'});
        if (!result[i].appdata.data){continue} // skip internal szenes
            name = result[i].name.replace(/"/g,''),
            pathname = name.replace(/ /g,'_');
        // Get light names
        var light_names = [];
        for (var j = 0; j < lights.length; j++) {
            var light_name = lights_[lights[j]];
            light_names.push(light_name);
        // Room, group or lights linked with scene
        var group = 'Group: '+groups_[lights] || 'Lights: '+light_names.join(", ");
        // Create States and skip duplicates
        if (!objects_[lights+pathname]){
            console.debug('scene: '+name+', '+group);
            createState('PhilipsHue.Scenes.'+pathname+'.'+id, false, {role: "button", name: 'Scene: '+name+' ('+group+')'});
            objects_[lights+pathname] = true;
    // Delete States
    function deleteStates(){
        console.log('Deleting current objects for scenes...');
    objects_ = [];
    $('javascript.0.PhilipsHue.Scenes.*').each(function (id) {
        deleteState(id);
    // Fetch data from Hue API
    function init(){
        api.getGroup(0, function(err, group0) {
            if (err) throw err;
            console.log('Processing group 0...');
        //displayResults(group0);
        parseGroup0(group0);
    api.groups(function(err, groups) {
        if (err) throw err;
        console.log('Processing ' + groups.length + ' groups...');
        //displayResults(groups);
        parseGroups(groups);
    api.lights(function(err, lights) {
        if (err) throw err;
        console.log('Processing ' + lights.lights.length + ' lights...');
        //displayResults(lights);
        parseLights(lights.lights);
    api.scenes(function(err, scenes) {
        if (err) throw err;
        console.log('Processing ' + scenes.length + ' scenes...');
        //displayResults(scenes);
         createStates(scenes);
    // Init on start
    init();
    // Activate scene
    on({id: /^javascript\.0\.PhilipsHue.Scenes\./, val: true}, function (obj) {
        if (obj.id == 'javascript.0.PhilipsHue.Scenes.Resync'){return}
    sceneId = obj.id.split('.').pop();
    console.log('Activating '+obj.name);
    api.activateScene(sceneId, function(err, result) {
        if (err) throw err;
        displayResults(result);
    setState(obj.id, false);
    // Resync
    on({id: 'javascript.0.PhilipsHue.Scenes.Resync', val: true}, function (obj) {
    console.log('Resync triggered...');
    groups_ = [];
    lights_ = [];
    deleteStates();
    init();
    schedule("0 20 * * *", function () {
    groups_ = [];
    lights_ = [];
    deleteStates();
    init();
    seit heute kommt ein Fehler:
    ich benötige Hilfe, wir sitzen im Dunkeln :-)
    die Einzige Änderung die ich vorgenommen habe ist ich habe das Multihos enabled und einen slave host hinzugefügt.
    • G Offline
      grooovie
      ich habe jetzt die virtuelle maschine in proxmox, in der iobroker installiert ist mit dem backup von vorgestern
      ersetzt. der fehler ist immernoch vorhanden. ich kann mir das nicht erklären.
      der fehler HueApi is not a constructor, was kann da das Problem plötzlich sein?
      • OliverIOO Offline
        OliverIOO Offline
        OliverIO
        der fehler sagt, das hueapi nicht gefunden wird.
        wenn du auf linux bist, probier mal
        cd /opt/iobroker
        npm i node-hue-api
        Meine Adapter und Widgets
        Links im Profil
        • G grooovie
          @grooovie
          node-hue-api ist als zusätzliches NPM-Modul in der Konfiguration der Javascript-Instanz eingetragen ?
          • G Offline
            grooovie
            @paul53 said in sitze seit gestern im dunkeln Hue Szenen script ausgefallen:
            node-hue-api
            war nicht eingetragen, habe es jetzt nachgeholt, aber leider keine Änderung, Fehler immer noch gleich.
            @OliverIO
            danke, das habe ich gleich probiert, das kam dabei raus
            aber auch danach keine Veränderung, Fehler immer noch gleich.
            • G Offline
              grooovie
              im script ist auch eine rote wellenline, wenn man den mauszeiger darüber hält kommt immer ein tip was los ist, habe gerade bemerkt das man das in der 1. zeile nicht sieht und hab alles mal runtergerückt.
              wie kann ich denn feststellen ob das modul geladen ist/wird ?
              • G grooovie
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @grooovie
                die bibliothek wurde aktualisiert und der von dir verwendete v2 syntax wurde entfernt.
                Hier steht drin was man machen kann
                https://github.com/peter-murray/node-hue-api#v2-api-compatibility
                Allerdings ist immer noch nicht geklärt, ob die Bibiothek bei dir überhaupt installiert und geladen wird
                Links im Profil
                • G Offline
                  grooovie
                  GELÖST!
                  danke @OliverIO, ich hatte zwar schon über V3 gelesen und mir sowas gedacht, ich konnte mir aber nicht vorstellen das das über nacht einfach ersatzlos gestrichen wurde,
                  ich habe nun die übergangslösung (V2) installiert mit
                  npm install node-hue-api-v2-shim
                  dann habe ich in der Javascript Instanz das Modul "node-hue-api-v2-shim" hinzugefügt
                  und schon funktioniert alles wieder. wieder Licht yippi! und eine zufriedene Frau :-))))
                  jetzt habe ich genug zeit den code an V3 anzupassen.
                  Vielen Dank für Eure Hilfe und Eure Zeit!
                  OliverIOO paul53P 2 Antworten Letzte Antwort
                  • G grooovie
                    GELÖST!
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @grooovie
                    über nacht war das nicht. die sind jetzt bei v4.
                    iobroker kann in diesem Feld kein version pinning, das geht nur manuell mit npm,
                    dann wäre es unverändert weitergelaufen, halt mit einer alten bibliothek
                    Links im Profil
                    • G Offline
                      grooovie
                      ok, verstehe, aber warum das nicht mit der alten bibliothek einfach weiterlaufen konnte kann ich mir nicht erklären
                      cashC 1 Antwort Letzte Antwort
                      • G grooovie
                        GELÖST!
                        @grooovie sagte:
                        Das war unnötig, denn die Installation erledigt der Javascript-Adapter nach Eintragen in die Konfiguration selbst.
                        • G grooovie
                          cashC Offline
                          cashC Offline
                          cash
                          @grooovie Du könntest auch einfach den Hue Adapter oder die Extended Version installieren. Beide unterstützen die Szenen von sich aus. Somit ist eigentlich schon sehr lange kein eigenes Script mehr nötig....
                          • G grooovie
                            api;
                            var groups_ = [],
                            lights_ = [],
                            objects_ = [];
                            // Log JSON results
                            var id = result.id,
                            // Parse Lights
                                lights_[id] = name;
                                // Resync button
                                // Get light names
                            // Delete States
                            objects_ = [];
                                deleteState(id);
                            function init(){
                                    if (err) throw err;
                                if (err) throw err;
                                if (err) throw err;
                                if (err) throw err;
                            // Init on start
                            init();
                            // Activate scene
                                if (err) throw err;
                            // Resync
                            groups_ = [];
                            lights_ = [];
                            deleteStates();
                            init();
                            groups_ = [];
                            lights_ = [];
                            deleteStates();
                            init();
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            @grooovie warum nutzt du nicht einen der beiden hue Adapter? Die können das doch inzwischen beide?
                            • G Offline
                              grooovie
                              echt, das wusste ich nicht.
                              in den Objekten den der normale Hue Adapter erzeugt sind jedenfalls keine Szenen zu sehen.
                              hab jetzt mal den Hue Extended genommen, da ist alle dabei, toll!
                              Vielen Dank für den tipp. So ist das eben, man richtet irgendwann mal was ein und das funktioniert dann auch, weiter kümmert man sich meist nicht. es war immer etwas umständlich mit dem extra script. aber der extendet adapter hat alles was man sich wünscht. hatte den schon mal gesehen, dachte aber er ist für eine neue Generation von Hue-Bridges.
                              Also sorry leute, bin aus einem Datendorf gerade in die grosse stadt gekommen XDD
                              Vielen Dank
