  4. View Adapter Status
    6.6k
View Adapter Status
view adapterview
212 Beiträge 31 Kommentatoren 57.6k Aufrufe 52 Beobachtet
  • GlasfaserG Glasfaser
    @Scrounger
    Sorry ... habe alles gemacht auch mal auf 9999 Z-Index gesetzt ....immer das gleiche
    Habe auch ein ContainerIconDialog genommen , dort auch das gleiche ,
    [{"tpl":"tplContainerIconDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/negalein/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/negalein/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/negalein/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/negalein/Akkuleer.png","class":"","contains_view":"AdapterStatus","modal":true,"dialog_width":"1400","dialog_height":"782","dialog_top":"0","dialog_left":"0","overflowX":"hidden","overflowY":"hidden","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"791px","top":"403px","width":"36px","height":"23px","z-index":"2"},"widgetSet":"jqui"}]
    das merkwürdige ist , wenn man den Select-Widget im Popup aufklappt sieht man den weißen Rand der runtergeht und schließt man den Popup ist die Auflistung im Hintergrund noch auf .
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    #155
    @Glasfaser
    Das dropdown wird hinter dem popup nach dem öffnen angezeigt.
    Bin mir sicher das des ein z-index thema ist.
    Bei mir gehts, auch mit ContainerIconDialog
    • ScroungerS Scrounger
      @Glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      #156
      @Scrounger
      Danke ... dein Popup Video hat mich gerade darauf gebracht ...
      Ich habe ein anderes Design von Material Design CSS V1 ,
      dort ist mir gerade aufgefallen , das im Skript der Fehler liegt , da wenn ich es entferne dann wird der Select-Widget richtig geöffnet .
      Habe mal zum Test das neue Material Design CSS V2 Skript eingefügt , dort ist der Fehler auch
      Hast du eine Idee wo der Fehler sein könnte ??
      SKRIPT :
        Material Design JS for ioBroker.vis
        (c) 2017 Uhula, MIT License
        https://github.com/Uhula/ioBroker-Material-Design-Style
        V1.7 28.12.2017
        o Korrektur mdui-lnav/rnav. Funktionierte mit mdui-toggle nicht korrekt
        V1.6 16.10.2017
        O _toggleFullscreen geändert, damit die function auch im ioBroker
                        fullscreen Mode funktioniert
        o Delegator-Eventhandler für body gesetzt (bisher #vis_container, wirkten dann aber in Dialogen nicht)
        V1.5 11.10.2017
        o MDUI.handleTables fertig
        V1.3 24.09.2017
        + MDUI.handleTables hinzu (in Entwicklung)
        V1.0 01.09.2017
      // Zur sicheren CSS-Erkennung der Runtime eine CSS-Klasse anlegen
      document.documentElement.className +=  " mdui-runtime";
      // Überprüfen ob touch zur Verfügung steht und entsprechend eine
      // CSS Klasse touch bzw no-touch erzeugen
         (("ontouchstart" in document.documentElement) ? " mdui-touch" : " mdui-notouch");
        MDUI
        Sammlung von JS-Funktionen für das Material Design
      var MDUI = (function () {
      var isSubtreeModified = false;
      // liefert den suffix einer gegeben class zurück-Navigieren
      // Bsp: mdui-target-w00002 -> w00002
      //      mdui-zoom-to-200 -> 200
      function _getClassSuffix( $ele, classname ) {
         var suf = "";
         if ($ele) {
             var c = $ele.attr( "class" );
             suf = c.substr(c.indexOf(classname)+classname.length,1000)+" ";
             suf = suf.substr(0,suf.indexOf(" "));
         return suf;
      function _getGroupID( ele ) { return _getClassSuffix(ele, "mdui-group-" ); }
      function _getTargetID( ele ) { return _getClassSuffix(ele, "mdui-target-" ); }
      function _getScrollbarWidth() {
         var $outer = $('<div>').css({visibility: 'hidden', width: 100, overflow: 'scroll'}).appendTo('body'),
             widthWithScroll = $('<div>').css({width: '100%'}).appendTo($outer).outerWidth();
         $outer.remove();
         return 100 - widthWithScroll;
      function _getScrollbarHeight() {
         var $outer = $('<div>').css({visibility: 'hidden', height: 100, overflow: 'scroll'}).appendTo('body'),
             heightWithScroll = $('<div>').css({height: '100%'}).appendTo($outer).outerHeight();
         $outer.remove();
         return 100 - heightWithScroll;
      function _formatDatetime(date, format) {
         function fill(comp) {
             return ((parseInt(comp) < 10) ? ('0' + comp) : comp)
         var months = ['Jan', 'Feb', 'Mär', 'Apr', 'Mai', 'Jun', 'Jul', 'Aug', 'Sep', 'Okt', 'Nov', 'Dez'];
         var d = format;
         var o = {
                 "y+": date.getFullYear(), // year
                 "m+": fill(date.getMonth()+1), //month
                 "M+": months[date.getMonth()], //month
                 "d+": fill(date.getDate()), //day
                 "H+": fill((date.getHours() > 12) ? date.getHours() % 12 : date.getHours()), //hour
                 "h+": fill(date.getHours()), //hour
                 "n+": fill(date.getMinutes()), //minute
                 "s+": fill(date.getSeconds()), //second
                 "S+": fill(date.getMilliseconds()), //millisecond,
                 "b+": (date.getHours() >= 12) ? 'PM' : 'AM'
         for (var k in o) {
             if (new RegExp("(" + k + ")").test(format)) {
                 d = d.replace(RegExp.$1, o[k]);
         return d;
      // alle Elemente mit class "mdui-group-XXX" togglen, in denen
      // XXX aus class "mdui-group-XXX" des ele ist UND
      // alle Elemente mit class "mdui-target-XXX" togglen, in denen
      // XXX aus class "mdui-target-XXX" des ele ist
      function _toggleVisibility( $ele ) {
         $ele.toggleClass("ui-state-active");
         var id = _getGroupID( $ele );
         if (id!=="")
             $("[class*='mdui-group-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
                 $(this).toggleClass("mdui-hide");
         id = _getTargetID( $ele );
         if (id!=="")
             $( "[class*='mdui-target-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
      // das in ele class \"mdui-target-XXX\" angegeben Element mit der id \"XXX\"  wird
      // - fullscreen angezeigt, wenn es noch nicht fullscreen ist
      // - wieder normal angezeigt, wenn es fullscreen ist
      function _toggleFullscreen( $ele ){
         if (!$ele) return;
         var $target = $ele.closest(".vis-view");
         if (!$target) return;
         var styleold = $target.attr("styleold");
         if (styleold) {
             $target.attr("style",styleold);
             $target.removeAttr("styleold");
             $target.appendTo(".mdui-id-"+$target.attr("id"));
             } else {
                 $target.parent().addClass("mdui-id-"+$target.attr("id"));
                 $target.attr("styleold",$target.attr("style"));
                 $target.attr("style","position:fixed; left:0; top:0; width:100%; height:100%; z-index: 2147483647 !important;background:#212121 !important; ");
                 $target.appendTo( "body" );
                 //$target.appendTo( "body #vis_container" );
      // ele muss class Einträge für das Target und den Skalierungsmodus haben
      // "mdui-target-(id) mdui-scale-(scalemode)"
      // id: Ziel-Element mit id=id, welches ein zu skalierendes img enthält
      // scalemode: fit / hfit / vfit / in / out / (number)
      // number: Zahl in %
      function _scale( ele ) {
         var id = _getTargetID( ele );
         var $img = $( "#"+id+" img" );
         if ($img) {
             var scale = _getClassSuffix(ele, "mdui-scale-" );
             $img.width("1px"); // Scrollbars entfernen um die echte Höhe zu bekommen
             $img.height("1px");
             var dim = {
                 pw : $img.parent().width(),
                 ph : $img.parent().height(),
                 w  : $img[0].naturalWidth,
                 h  : $img[0].naturalHeight
             switch(scale) {
                 case "fit":
                     if (dim.pw / dim.w < dim.ph / dim.h ) scale = dim.pw / dim.w;
                     else scale = dim.ph / dim.h;
                     break;
                 case "hfit":
                     else scale = (dim.pw - _getScrollbarWidth() - 4  ) / dim.w;
                     break;
                 case "vfit":
                     if ( dim.pw / dim.w > dim.ph / dim.h ) scale = dim.ph / dim.h;
                     else scale = (dim.ph - _getScrollbarHeight() - 4  ) / dim.h;
                     break;
                 case "in":
                 case "out":
                     var old = $img.attr( "style" );
                     old = old.substr(old.indexOf("scale(")+6,20);
                     old = old.substr(0,old.indexOf(")"));
                     if (old * 1==0) scale = 1;
                     else if (scale=="in") scale = old * 1.41;
                          else scale = old / 1.41;
                     break;
                 default:
                     if (scale<=0 || scale>10000)
                         scale = 100;
                     scale = scale/100;
             scale = Math.round(scale*100)/100;
             $img.attr( "style", "position:absolute;top:0;left:0;transform-origin:0 0;transition: transform 0.3s ease-out; transform:scale("+scale+");" );
      // ersetzt im src-Attribute des Unter-Elements von (id) den "&range=&
      // durch den Wert des in ele angegebenen (span). Für flot-Diagramme
      // "mdui-target-(id) mdui-timespan-(span)"
      // id: Ziel-Element mit id=id, welches das flot (src) enthält
      // span: inc / dec / (number)
      // number: Zahl in Minuten
      function _timespan( ele ) {
         var target = $( "#"+id+" [src]" );
         if (target) {
             var timespan = _getClassSuffix(ele, "mdui-timespan-" );
             var src = target.attr( "src" );
             var min = src.substr(src.indexOf("&range=")+7,20);
             min = min.substr(0,min.indexOf("&"));
             switch(timespan) {
                 case "inc":
                     min = min * 2;
                     break;
                 case "dec":
                     min = min / 2;
                     break;
                 default:
                     if ( timespan<=0 )
                         timespan = 1440;
                     min = timespan;
             src = src.replace(/&range=[0-9]*&/g, "&range="+min+"&");
             target.attr("src",src);
      function _resetTable( $ele, $table ) {
         $ele.removeClass("mdui-table-tile");
         $ele.removeClass("mdui-table-card");
         $ele.removeClass("mdui-table-list");
         $table.find("tbody>tr").each( function(index) {
             $(this).width("auto");
             $(this).height("auto");
             $(this).find("td").each( function(index) {
                 $(this).attr("labelth","");
      function _handleTable( $ele, $table, opt ) {
         function setColWidth( colwidth ) {
                 $(this).outerWidth(colwidth);
         function setColHeight() {
             var height = 0;
                 if ($(this).height() > height ) height = $(this).height();
             if ( height > 0 )
                     $(this).height( height );
         var innerWidth = $ele.innerWidth();
         _resetTable($ele, $table);
         $ele.addClass("mdui-table-"+opt.type);
         if (opt.label) {
             // Zellen mit Labels aus <th> ergänzen ?
             var labels = [];
             $table.find("thead>tr>th").each( function(index) {
                 labels[index] = $(this).text();
                     if (index < labels.length)
                         $(this).attr("labelth",labels[index]);
         if (opt.colwidth>1) setColWidth(opt.colwidth);
         if (opt.colwidth>2) setColHeight();
         return true;
      /* Alle mdui-table durchlaufen und überprüfen, ob die minimale Width erreicht
      wurde um sie in den responsive State zu überführen
      mdui-table-(mode)(-opt1)(-opt2)...(-optn)
      mdui-table-ascard-r600-w200-l */
      function _handleTables( ) {
         $("[class*='mdui-table ']").each( function (index) {
             var $ele = $(this);
             var $table;
             $table = $ele;
             if (!$table.is("table")) $table=$table.find("table");
             if (!$table.is("table")) return true; // next each
             var classes = $ele.attr("class")
                 .split(" ")
                 .filter( function ( ele ) {
                         return  (ele.indexOf("mdui-table-ascard") > -1)
                              || (ele.indexOf("mdui-table-astile") > -1)
                              || (ele.indexOf("mdui-table-aslist") > -1); });
             var opts = [];
             var opt;
             for (var i = 0; i < classes.length; i++) {
                 opts[i] = [];
                 opts[i].reswidth = 9999;
                 opts[i].colwidth = 0;
                 opts[i].label = false;
                 opts[i].type = classes[i].substr(13,4);
                 opt = classes[i].substr(18,200).split("-");
                 for (var j = 0; j < opt.length; j++) {
                     switch(opt[j][0]) {
                     case "r":
                         opts[i].reswidth = parseInt(opt[j].substr(1,5));
                         break;
                     case "w":
                         opts[i].colwidth = parseInt(opt[j].substr(1,5));
                         break;
                     case "c":
                         if (opts[i].colwidth>0) opts[i].colwidth = (innerWidth-_getScrollbarWidth()-8) / opts[i].colwidth;
                         break;
                     case "l":
                         opts[i].label = true;
                         break;
                     default:
             opts.sort(function(a, b){return a.reswidth-b.reswidth});
      //console.log(opts);
             if (opts.length === 0) return true; // next each
             var handled = false;
             for (i = 0; i < opts.length; i++) {
                 if ( innerWidth < opts[i].reswidth )
                    handled = _handleTable( $ele, $table, opts[i]);
                 if (handled) break;
             if (!handled) _resetTable($ele, $table);
      // DOM SubTree-Änderungen einmalig alle 500ms auswerten (diese Events werden
      // u.U. 1000-fach gefeuert und müssen deswegen verzögert ausgeführt werden)
      function _onSubTreeModified( $ele ) {
         if (!isSubtreeModified) {
             isSubtreeModified = true;
             setTimeout(function () {
                 _handleTables();
                 isSubtreeModified=false;
             }, 500);
      return {
         toggleVisibility: _toggleVisibility,
         toggleFullscreen: _toggleFullscreen,
         scale: _scale,
         timespan: _timespan,
         handleTables: _handleTables,
         onSubTreeModified : _onSubTreeModified
      // Eventhandler für body-Delegators setzen (früher:#vis_container)
         // click-Event für das left-nav Element zum Öffnen
         $("body").on( "click", ".mdui-lnavbutton", function() {
             $( ".mdui-lnav" ).addClass( "mdui-lnav-open" );
         // click-Event für die left-nav zum Schließen
         $("body").on( "click", ".mdui-lnav", function() {
             $( ".mdui-lnav" ).removeClass( "mdui-lnav-open" );
         // click-Event für das right-nav Element zum Öffnen
         $("body").on( "click", ".mdui-rnavbutton", function() {
             $( ".mdui-rnav" ).addClass( "mdui-rnav-open" );
         // click-Event für die right-nav zum Schließen
         $("body").on( "click", ".mdui-rnav", function() {
             $( ".mdui-rnav" ).removeClass( "mdui-rnav-open" );
         // click-Eventhandler für "mdui-scale-" setzen
         $("body").on( "click", "[class*='mdui-scale-']", function(event) {
             MDUI.scale( $(this) );
         // click-Handler für "mdui-toggle"
         $("body").on( "click", ".mdui-toggle", function(event) {
             event.preventDefault();
             event.stopImmediatePropagation();
             MDUI.toggleVisibility( $(this) );
         // click-Handler für "mdui-fullscreen"
         $("body").on( "click", ".mdui-fullscreen", function(event) {
             MDUI.toggleFullscreen( $(this) );
         // click-Handler für "mdui-timepsan-"
         $("body").on( "click", "[class*='mdui-timespan-']", function(event) {
             MDUI.timespan( $(this) );
         $( window ).on("resize", function() {
           MDUI.handleTables();
         // Überwachen des #vis_containers auf Änderungen (z.B. wenn views nachgeladen
         // werden)
         $( "#vis_container" ).on( "DOMSubtreeModified", function(event) {
             MDUI.onSubTreeModified( $(this) );
         // für den ersten load einmal aufrufen
         MDUI.onSubTreeModified( );
      }, 1000);
      ScroungerS 1 Antwort Letzte Antwort
        @Scrounger
        SKRIPT :
          V1.7 28.12.2017
          V1.6 16.10.2017
          V1.5 11.10.2017
          V1.3 24.09.2017
          V1.0 01.09.2017
          MDUI
           var suf = "";
           if ($ele) {
           return suf;
           $outer.remove();
           $outer.remove();
           var d = format;
           var o = {
           for (var k in o) {
           return d;
           if (id!=="")
           if (id!=="")
           if (!$ele) return;
           if (styleold) {
               } else {
           if ($img) {
               $img.height("1px");
               var dim = {
               switch(scale) {
                   case "fit":
                       break;
                   case "hfit":
                       break;
                   case "vfit":
                       break;
                   case "in":
                   case "out":
                       break;
                   default:
                           scale = 100;
                       scale = scale/100;
           if (target) {
               switch(timespan) {
                   case "inc":
                       min = min * 2;
                       break;
                   case "dec":
                       min = min / 2;
                       break;
                   default:
                       if ( timespan<=0 )
                           timespan = 1440;
                       min = timespan;
               var height = 0;
               if ( height > 0 )
           if (opt.label) {
               var labels = [];
           return true;
               var $ele = $(this);
               var $table;
               $table = $ele;
                   .split(" ")
               var opts = [];
               var opt;
                   opts[i] = [];
                       switch(opt[j][0]) {
                       case "r":
                           break;
                       case "w":
                           break;
                       case "c":
                           break;
                       case "l":
                           break;
                       default:
                   if (handled) break;
                   _handleTables();
               }, 500);
        return {
           scale: _scale,
           // werden)
        }, 1000);
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #157
        @Glasfaser
        Nee sorry, hab mich mit Material Design CSS noch nie beschäftigt.
          @Glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          #158
          @Scrounger
          Kein Problem , aber trotzdem wurde der Fehler dadurch eingekreißt .
          Danke ....für deine Mühe :)
          • ub.privatU Offline
            ub.privatU Offline
            ub.privat
            #159
            @Scrounger
            Guten entspannten Guten Abend!
            Mit meinem langsam wachsendem Verständnis in der Anwendung deiner MEISTERWERKE versuche ich mich wieder mal.
            Der Adapter-View ist ganz großes Kino. Leider verende ich beim "Trailer".
            Was habe ich bisher gemacht:
            1. notwendige Einstellungen im JS Adapter vorgenommen:
            2. Script eingestellt:
              Leider mit Warnungen...
            3. Datenpunkte angelegt:
              Leider werden keine Werte erzeugt.
            4. View importiert:
              Mit entsprechender Warnung.
            5. NUN IST GUTER RAT TEUER - wo mache ich wie weiter????
              Lesse den Tread hoch und runter, aber die Erleeuchtung will sich nicht einstellen...
            sigi234S ScroungerS GlasfaserG 3 Antworten Letzte Antwort
            • ub.privatU ub.privat
              @Scrounger
              4. View importiert:
              sigi234S Online
              sigi234S Online
              #160
              @ub-privat
              Hast du die Aktuelle Version? 0.2.62
              ub.privatU 1 Antwort Letzte Antwort
                @Scrounger
                4. View importiert:
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                schrieb am zuletzt editiert von Scrounger
                #161
                @ub-privat
                Hast du das skript 1:1 kopiert?
                Die Fehlermeldung bezieht sich auf Zeile 518-520 - das skript hat aber nur 339 Zeilen.
                Und laut deinem Screenshot hast du irgendwas an dem Skript verändert. Weil ab Zeile 8 müssten die settings zu sehen sein.
                Und bitte das vollständige log posten, also aus dem reiter 'log' im admin bereich.
                ub.privatU sigi234S 2 Antworten Letzte Antwort
                • sigi234S sigi234
                  @ub-privat
                  ub.privatU Offline
                  ub.privatU Offline
                  ub.privat
                  #162
                  @sigi234
                  Ja, habe ich!
                    @ub-privat
                    ub.privatU Offline
                    ub.privatU Offline
                    ub.privat
                    #163
                    @Scrounger
                    Bin mir keiner Änderung bewußt!
                    Würdest du das AKTUELLESTE Script nochmals bitte verlinken!?
                    DANKE.
                      Sodele nochmal eine neue Version des Skriptes
                      Voraussetzung Material Design Widgets v0.2.62 (demnächst im latest) !!!
                      • mehr Farbeinstellung
                      • Sortier Funktion
                      • Filter Funktion - wäre sicher als nächster Wunsch gekommen, deshalb hab ich es schon mal eingebaut ;-)
                        (Benötigt ihr weitere schaut ins skript und passt es auf eure Bedürfnisse an)
                      • Adapter Modus wird angezeigt
                      • Fehler behoben
                      Ist auch im Online Beispiel enthalten
                      View:
                        "settings": {
                          "style": {
                            "background_class": ""
                          "theme": "redmond",
                          "sizex": "",
                          "sizey": "",
                          "gridSize": "",
                          "snapType": null
                        "widgets": {
                          "e00001": {
                            "tpl": "tplVis-materialdesign-Icon-List",
                            "data": {
                              "g_fixed": false,
                              "g_visibility": false,
                              "g_css_font_text": false,
                              "g_css_background": false,
                              "g_css_shadow_padding": false,
                              "g_css_border": false,
                              "g_gestures": false,
                              "g_signals": false,
                              "g_last_change": false,
                              "visibility-cond": "==",
                              "visibility-val": 1,
                              "visibility-groups-action": "hide",
                              "wrapItems": true,
                              "listItemDataMethod": "jsonStringObject",
                              "countListItems": "1",
                              "vibrateOnMobilDevices": "50",
                              "listLayout": "card",
                              "itemLayout": "horizontal",
                              "listType0": "text",
                              "showValueLabel0": "true",
                              "listType1": "text",
                              "showValueLabel1": "true",
                              "signals-cond-0": "==",
                              "signals-val-0": true,
                              "signals-icon-0": "/vis/signals/lowbattery.png",
                              "signals-icon-size-0": 0,
                              "signals-blink-0": false,
                              "signals-horz-0": 0,
                              "signals-vert-0": 0,
                              "signals-hide-edit-0": false,
                              "signals-cond-1": "==",
                              "signals-val-1": true,
                              "signals-icon-1": "/vis/signals/lowbattery.png",
                              "signals-icon-size-1": 0,
                              "signals-blink-1": false,
                              "signals-horz-1": 0,
                              "signals-vert-1": 0,
                              "signals-hide-edit-1": false,
                              "signals-cond-2": "==",
                              "signals-val-2": true,
                              "signals-icon-2": "/vis/signals/lowbattery.png",
                              "signals-icon-size-2": 0,
                              "signals-blink-2": false,
                              "signals-horz-2": 0,
                              "signals-vert-2": 0,
                              "signals-hide-edit-2": false,
                              "lc-type": "last-change",
                              "lc-is-interval": true,
                              "lc-is-moment": false,
                              "lc-format": "",
                              "lc-position-vert": "top",
                              "lc-position-horz": "right",
                              "lc-offset-vert": 0,
                              "lc-offset-horz": 0,
                              "lc-font-size": "12px",
                              "lc-font-family": "",
                              "lc-font-style": "",
                              "lc-bkg-color": "",
                              "lc-color": "",
                              "lc-border-width": "0",
                              "lc-border-style": "",
                              "lc-border-color": "",
                              "lc-border-radius": 10,
                              "lc-zindex": 0,
                              "json_string_oid": "0_userdata.0.vis.AdapterStatus.jsonList",
                              "maxItemsperRow": "6",
                              "iconItemMinWidth": "300",
                              "iconHeight": "60",
                              "buttonHeight": "100",
                              "labelFontSize": "22",
                              "subLabelFontSize": "14",
                              "subLabelFontColor": "#000000",
                              "labelFontFamily": "RobotoCondensed-Regular",
                              "subLabelFontFamily": "RobotoCondensed-Light",
                              "horizontalIconContainerWidth": "120"
                            "style": {
                              "left": "0px",
                              "top": "50px",
                              "width": "100%",
                              "height": "calc(100% - 50px)",
                              "overflow-x": "",
                              "overflow-y": "auto",
                              "z-index": "1"
                            "widgetSet": "materialdesign"
                          "e00002": {
                            "tpl": "tplHtml",
                            "data": {
                              "g_fixed": false,
                              "g_css_background": true,
                              "g_signals": false,
                              "refreshInterval": "0",
                              "lc-format": "",
                              "lc-bkg-color": "",
                              "lc-color": "",
                              "lc-zindex": 0
                            "style": {
                              "left": "0",
                              "top": "0",
                              "width": "100%",
                              "height": "50px",
                              "background-color": "#44739e"
                            "widgetSet": "basic"
                          "e00003": {
                            "tpl": "tplVis-materialdesign-Select",
                            "data": {
                              "oid": "0_userdata.0.vis.AdapterStatus.sortMode",
                              "g_fixed": false,
                              "g_signals": false,
                              "inputType": "text",
                              "inputLayout": "regular",
                              "showInputMessageAlways": "true",
                              "showInputCounter": false,
                              "clearIconShow": false,
                              "listDataMethod": "jsonStringObject",
                              "countSelectItems": "1",
                              "listPosition": "bottom",
                              "showSelectedIcon": "prepend-inner",
                              "showValue": false,
                              "lc-format": "",
                              "lc-bkg-color": "",
                              "lc-color": "",
                              "lc-zindex": 0,
                              "inputLabelText": "Sortieren nach",
                              "inputLabelColor": "#ffffff",
                              "inputLabelFontFamily": "RobotoCondensed-LightItalic",
                              "collapseIconColor": "#ffffff",
                              "collapseIconSize": "",
                              "jsonStringObject": "[\n\t{\n\t\t\"text\": \"Adaptername\",\n\t\t\"value\": \"name\",\n\t\t\"icon\": \"sort-alphabetical\"\n\t},\n\t{\n\t\t\"text\": \"Status\",\n\t\t\"value\": \"status\",\n\t\t\"icon\": \"information-variant\"\n\t},\t\n\t{\n\t\t\"text\": \"Modus\",\n\t\t\"value\": \"mode\",\n\t\t\"icon\": \"view-dashboard\"\n\t},\n\t{\n\t\t\"text\": \"Updates verfügbar\",\n\t\t\"value\": \"hasUpdates\",\n\t\t\"icon\": \"package-down\"\n\t},\n\t{\n\t\t\"text\": \"CPU\",\n\t\t\"value\": \"cpu\",\n\t\t\"icon\": \"cpu-64-bit\"\n\t},\n\t{\n\t\t\"text\": \"RAM total\",\n\t\t\"value\": \"memHeapTotal\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"RAM verwendet\",\n\t\t\"value\": \"memHeapUsed\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"RAM reserviert\",\n\t\t\"value\": \"memRss\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"Betriebszeit\",\n\t\t\"value\": \"uptime\",\n\t\t\"icon\": \"clock-check-outline\"\n\t}\n]",
                              "listPositionOffset": true,
                              "inputLayoutBackgroundColor": "transparent",
                              "inputLabelColorSelected": "#ffffff",
                              "inputTranslateX": "-15",
                              "clearIcon": "",
                              "inputLayoutBorderColorHover": "#ffffff",
                              "inputLayoutBorderColorSelected": "#ffffff",
                              "inputLayoutBorderColor": "#a1a1a1",
                              "listItemFontColor": "",
                              "inputTextColor": "#ffffff",
                              "inputTextFontFamily": "RobotoCondensed-LightItalic",
                              "prepandIcon": "",
                              "prepandIconColor": "",
                              "prepandIconSize": "",
                              "prepandInnerIcon": "",
                              "prepandInnerIconColor": "#ffffff",
                              "prepandInnerIconSize": "18",
                              "collapseIcon": "",
                              "inputTranslateY": "-12",
                              "listIconSelectedColor": "#44739e",
                              "listIconColor": "",
                              "appendOuterIcon": "",
                              "appendOuterIconSize": "2",
                              "listItemFont": "RobotoCondensed-Regular",
                              "listItemRippleEffectColor": "",
                              "inputLayoutBackgroundColorSelected": "",
                              "inputLayoutBackgroundColorHover": ""
                            "style": {
                              "left": "10px",
                              "top": "0px",
                              "z-index": "1",
                              "width": "calc(50% - 20px)",
                              "height": "40px"
                          "e00004": {
                            "data": {
                              "oid": "0_userdata.0.vis.AdapterStatus.filterMode",
                              "g_fixed": false,
                              "g_signals": false,
                              "clearIconShow": true,
                              "showValue": false,
                              "lc-format": "",
                              "lc-bkg-color": "",
                              "lc-color": "",
                              "lc-zindex": 0,
                              "inputLabelText": "Filtern nach",
                              "jsonStringObject": "[\n\t{\n\t\t\"text\": \"nicht verbunden\",\n\t\t\"value\": \"notConnected\",\n\t\t\"icon\": \"network-off\"\n\t},\n\t{\n\t\t\"text\": \"deaktiviert\",\n\t\t\"value\": \"deactivated\",\n\t\t\"icon\": \"checkbox-blank-outline\"\n\t},\t\n\t{\n\t\t\"text\": \"aktiviert\",\n\t\t\"value\": \"activated\",\n\t\t\"icon\": \"checkbox-intermediate\"\n\t},\n\t{\n\t\t\"text\": \"Updates verfügbar\",\n\t\t\"value\": \"hasUpdates\",\n\t\t\"icon\": \"package-down\"\n\t}\n]",
                              "clearIcon": "",
                              "prepandIcon": "",
                              "collapseIcon": "",
                              "inputLayoutBackgroundColorHover": "",
                              "clearIconColor": "#ffffff"
                            "style": {
                              "left": "calc(50% + 10px)",
                              "top": "0px",
                              "z-index": "1",
                              "height": "40px"
                        "name": "AdapterStatus",
                        "filterList": []
                      Skript
                      // Imports -> müssen im Javascript Adapter unter 'Zusätzliche NPM-Module' eingetragen sein
                      const moment = require("moment");
                      const momentDurationFormatSetup = require("moment-duration-format");
                      // Skript Einstellungen *************************************************************************************************************************************************
                      let dpList = '0_userdata.0.vis.AdapterStatus.jsonList';                     // Datenpunkt für IconList Widget (Typ: Zeichenkette (String))
                      let dpAdapterRestart = '0_userdata.0.vis.AdapterStatus.restartTrigger';     // Datenpunkt für Adapter restart (Typ: Zeichenkette (String))
                      let dpSortMode = '0_userdata.0.vis.AdapterStatus.sortMode';                 // Datenpunkt für Sortieren (Typ: Zeichenkette (String))
                      let dpFilterMode = '0_userdata.0.vis.AdapterStatus.filterMode';             // Datenpunkt für Filter (Typ: Zeichenkette (String))
                      let adminUpdatesList = 'admin.0.info.updatesList';                          // Datenpunkt Admin Adapter für verfübare Updates der Adapter
                      const checkInterval = 30;                                                   // Interval wie oft Status der Adapter aktualisiert werden soll (in Sekunden)
                      let sprache = 'de';                                                         // Sprache für formatierung Dauer
                      let formatierungDauer = "dd[T] hh[h] mm[m]";                                // Formatierung der Dauer -> siehe momentjs library
                      let neustarten = true;                                                      // true: Adapter wird neugestartet, false: Adapter wird gestoppt oder gestartet
                      let farbeAdapterAktiv = 'green';                                            // Status Bar Farbe wenn Adapter aktiv ist
                      let farbeAdapterNichtAktiv = 'FireBrick';                                   // Status Bar Farbe wenn Adapter nicht aktiv ist oder Fehler vorliegt
                      let farbeAdapterDeaktiviert = 'darkgrey';                                   // Status Bar Farbe wenn Adapter deaktiviert ist
                      let farbeAdapterNichtVerbunden = 'yellow';                                  // Status Bar Farbe wenn Adapter nicht verbunden ist
                      let farbeAdapterZeitgesteuert = 'lightgreen';                               // Status Bar Farbe wenn Adapter zeitgesteuert ist
                      let farbeAdapterErweiterung = '#44739e';                                    // Status Bar Farbe wenn Adapter Erweiterung ist
                      let farbeAdapterSystem = '#44739e';                                         // Status Bar Farbe wenn Adapter mit System gestartet wird
                      let sortResetAfter = 120;                                                   // Sortierung nach X Sekunden auf sortReset zurücksetzen (0=deaktiviert)
                      let sortReset = 'memHeapUsed'                                               // Sortierung auf die zurückgesetzt werden soll
                      let filterResetAfter = 120;                                                 // Filter nach X Sekunden zurücksetzen (0=deaktiviert)
                      // Fomate für moment Lib
                      moment.locale(sprache);
                      // auf .alive Änderungen hören
                      let aliveSelector = `[id=system.adapter.*.alive]`;
                      let adapterAliveList = $(aliveSelector);
                      if (adapterAliveList.length === 0) {
                          // Fehlermeldung ausgeben, wenn selector kein result liefert
                          console.error(`no result for selector '${aliveSelector}'`)
                      } else {
                          // listener nur für Änderung bei alive
                          adapterAliveList.on(adapterStatus);
                      // auf .connection Änderungen hören
                      let connectionSelector = `[id=*.info.connection]`;
                      let adapterConnectionList = $(connectionSelector);
                      if (adapterConnectionList.length === 0) {
                          console.error(`no result for selector '${connectionSelector}'`)
                      } else {
                          adapterConnectionList.on(adapterStatus);
                      // auf .connected Änderungen hören
                      let connectedSelector = `[id=system.adapter.*.connected]`;
                      let adapterConnectedList = $(connectedSelector);
                      if (adapterConnectedList.length === 0) {
                          console.error(`no result for selector '${connectedSelector}'`)
                      } else {
                          adapterConnectedList.on(adapterStatus);
                      // auf Änderungen der Sortieung hören
                      on({ id: dpSortMode, change: 'any' }, adapterStatus);
                      on({ id: dpSortMode, change: 'any' }, resetSort);
                      // auf Änderungen der Filter hören
                      on({ id: dpFilterMode, change: 'any' }, adapterStatus);
                      on({ id: dpFilterMode, change: 'any' }, resetFilter);
                      // Funktion adapterStatus alle x Sekunden ausführen
                      schedule('*/' + checkInterval + ' * * * * *', adapterStatus);
                      function adapterStatus() {
                          // Funktion um Status der Adapter abzurufen und als JSON String für das Material Design Widget IconList aufbereiten
                          let adapterList = [];
                          let updateList = myHelper().getStateValueIfExist(adminUpdatesList);
                          try {
                              for (var i = 0; i <= adapterAliveList.length - 1; i++) {
                                  let id = adapterAliveList[i].replace('.alive', '');
                                  let obj = getObject(adapterAliveList[i].replace('.alive', ''));
                                  let nameArray = id.replace('system.adapter.', '').split(".");
                                  let name = nameArray[0];
                                  name = name.charAt(0).toUpperCase() + name.slice(1);
                                  let nameWithInstance = name;
                                  let adapterInstance = nameArray[1];
                                  if (parseInt(adapterInstance) > 0) {
                                      nameWithInstance = name + '.' + adapterInstance;
                                  let uptime = (existsState(id + '.uptime')) ? moment.duration(getState(id + '.uptime').val, 'seconds').format(formatierungDauer, 0) : '-';
                                  let image = (myHelper().checkCommonPropertyExist(obj, 'icon')) ? `/${nameArray[0]}.admin/${obj.common.icon}` : 'image-off-outline';
                                  let hasUpdates = updateList && updateList.includes(nameArray[0]);
                                  let newVersion = (hasUpdates) ? '<span class="mdi mdi-update" style="color: #ec0909;"></span>' : '';
                                  let text = `<div style="display: flex; flex-direction: row; line-height: 1.5; padding-right: 8px; align-items: center;">
                                                  <div style="flex: 1">${newVersion} ${nameWithInstance}</div>
                                                  <div style="color: grey; font-size: 12px; font-family: RobotoCondensed-LightItalic;">${myHelper().getCommonPropertyIfExist(obj, 'version', '-', 'v', '')}</div>
                                              </div>`
                                  let subText = `<div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;">
                                                      <div style="flex: 1;">CPU</div>
                                                      <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${myHelper().getStateValueIfExist(id + '.cpu', '-', '', ' %')}</div>
                                                  </div>
                                                      <div style="flex: 1;">RAM total</div>
                                                      <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${myHelper().getStateValueIfExist(id + '.memHeapTotal', '-', '', ' MB')}</div>
                                                  </div>
                                                      <div style="flex: 1;">RAM verwendet</div>
                                                      <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${myHelper().getStateValueIfExist(id + '.memHeapUsed', '-', '', ' MB')}</div>
                                                  </div>
                                                      <div style="flex: 1;">RAM reserviert</div>
                                                      <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${myHelper().getStateValueIfExist(id + '.memRss', '-', '', ' MB')}</div>
                                                  </div>
                                                      <div style="flex: 1;">Betriebszeit</div>
                                                      <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${uptime}</div>
                                                  </div>
                                                      <div style="flex: 1;">Modus</div>
                                                      <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${myHelper().getCommonPropertyIfExist(obj, 'mode', '-')}</div>
                                                  </div>`
                                  let statusBarColor = farbeAdapterNichtAktiv;
                                  let status = 3;
                                  if (myHelper().getStateValueIfExist(adapterAliveList[i]) === 'true') {
                                      statusBarColor = farbeAdapterAktiv;
                                      status = 0;
                                      if (existsState(id.replace('system.adapter.', '') + '.info.connection')) {
                                          if (!getState(id.replace('system.adapter.', '') + '.info.connection').val) {
                                              statusBarColor = farbeAdapterNichtVerbunden;
                                              status = 4;
                                      } else {
                                          if (myHelper().getStateValueIfExist(adapterAliveList[i].replace('.alive', '.connected')) === 'false') {
                                              status = 4;
                                  if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'schedule') {
                                      // Adapter ist zeitgesteuert
                                      statusBarColor = farbeAdapterZeitgesteuert;
                                      status = 1;
                                  if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'extension') {
                                      // Adapter ist Extension
                                      statusBarColor = farbeAdapterErweiterung;
                                      status = 1;
                                  if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'once') {
                                      // Adapter wird mit System gestartet
                                      statusBarColor = farbeAdapterSystem;
                                      status = 1;
                                  if (myHelper().getCommonPropertyIfExist(obj, 'enabled', false).toString() === 'false') {
                                      // Adapter ist deaktiviert
                                      statusBarColor = farbeAdapterDeaktiviert;
                                      status = 2;
                                  adapterList.push({
                                      text: text,
                                      subText: subText,
                                      image: image,
                                      listType: "buttonState",
                                      objectId: dpAdapterRestart,
                                      buttonStateValue: id,
                                      statusBarColor: statusBarColor,
                                      showValueLabel: false,
                                      mode: myHelper().getCommonPropertyIfExist(obj, 'mode'),
                                      hasUpdates: hasUpdates,
                                      cpu: parseFloat(myHelper().getStateValueIfExist(id + '.cpu', '0')),
                                      memHeapTotal: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapTotal', '0')),
                                      memHeapUsed: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapUsed', '0')),
                                      memRss: parseFloat(myHelper().getStateValueIfExist(id + '.memRss', '0')),
                                      uptime: parseFloat(myHelper().getStateValueIfExist(id + '.uptime', 0)),
                                      status: status
                          } catch (err) {
                              console.error(`[adapterStatus] error: ${err.message}, stack: ${err.stack}`);
                          let sortMode = myHelper().getStateValueIfExist(dpSortMode, 'name');
                          if (sortMode === 'name' || sortMode === 'mode') {
                              adapterList.sort(function (a, b) {
                                  return a[sortMode] == b[sortMode] ? 0 : +(a[sortMode] > b[sortMode]) || -1;
                          } else if (sortMode === 'hasUpdates' || sortMode === 'cpu' || sortMode === 'memHeapTotal' || sortMode === 'memHeapUsed' || sortMode === 'memRss' || sortMode === 'uptime' || sortMode === 'status') {
                                  return a[sortMode] == b[sortMode] ? 0 : +(a[sortMode] < b[sortMode]) || -1;
                          } else {
                              // default: nach name sortieren
                              sortMode = 'name'
                          // Filter: not connected, updates, deaktiviert, aktiviert
                          let filterMode = myHelper().getStateValueIfExist(dpFilterMode, null);
                          if (filterMode && filterMode !== null && filterMode !== '') {
                              if (filterMode === 'hasUpdates') {
                                  adapterList = adapterList.filter(function (item) {
                                      return item.hasUpdates === true;
                              } else if (filterMode === 'notConnected') {
                                      return item.status === 4;
                              } else if (filterMode === 'deactivated') {
                                      return item.status === 2;
                              } else if (filterMode === 'activated') {
                                      return item.status <= 1;
                          // adapterList = adapterList.filter(function(item){
                          //     return item.status === 4;
                          let result = JSON.stringify(adapterList);
                          if (getState(dpList) !== result) {
                              setState(dpList, result, true);
                      // Beim Staren des Skriptes Adapter Status abrufen
                      adapterStatus();
                      // Funktion um Adapter zu starten / neu starten
                      on({ id: dpAdapterRestart }, function (obj) {
                          var adapter = getObject(obj.state.val.toString());
                          if (neustarten) {
                              if (adapter.common && adapter.common.enabled === false) {
                                  // Adapter deaktiviert -> starten
                                  adapter.common.enabled = true;
                          } else {
                              if (adapter.common && adapter.common.enabled) {
                                  adapter.common.enabled = !adapter.common.enabled;
                              } else {
                          setObject(obj.state.val, adapter);
                          console.log(`${obj.state.val.replace('system.adapter.', '')} neugestartet`);
                      function resetSort() {
                          let sortMode = myHelper().getStateValueIfExist(dpSortMode, null);
                          if (sortResetAfter > 0) {
                                  if (sortMode !== null && sortMode === myHelper().getStateValueIfExist(dpSortMode, null)) {
                                      setState(dpSortMode, sortReset);
                              }, sortResetAfter * 1000);
                      function resetFilter() {
                          if (filterResetAfter > 0) {
                                  if (filterMode !== null && filterMode === myHelper().getStateValueIfExist(dpFilterMode, null)) {
                                      setState(dpFilterMode, '');
                              }, filterResetAfter * 1000);
                      function myHelper() {
                          return {
                              getStateValueIfExist: function (id, nullValue = undefined, prepand = '', append = '') {
                                  if (existsState(id)) {
                                      return prepand + getState(id).val + append;
                                  } else {
                                      return nullValue;
                              getCommonPropertyIfExist: function (object, prop, nullValue = undefined, prepand = '', append = '') {
                                  if (myHelper().checkCommonPropertyExist(object, prop)) {
                                      return prepand + object.common[prop] + append;
                                  } else {
                                      return nullValue;
                              checkCommonPropertyExist: function (object, prop) {
                                  if (object && object.common && object.common[prop]) {
                                      return true;
                                  } else {
                                      return false;
                      ub.privatU Offline
                      ub.privatU Offline
                      ub.privat
                      #164
                      @Scrounger
                      Habe dieses Script verwendet und das hat nach dem kopieren 679 Zeilen
                      Leerzeilen sind natürlich mitgezählt...
                        @Scrounger
                        DANKE.
                        sigi234S Online
                        sigi234S Online
                        #165
                        @ub-privat sagte in View Adapter Status:
                        @Scrounger
                        DANKE.
                        Edit: Falsches Skript gewesen.
                          @ub-privat
                          sigi234S Online
                          sigi234S Online
                          #166
                          @Scrounger sagte in View Adapter Status:
                          Ich habe 310?
                          • sigi234S sigi234
                            Ich habe 310?
                            ScroungerS Offline
                            ScroungerS Offline
                            Scrounger
                            #167
                            @sigi234
                            https://forum.iobroker.net/topic/26533/view-adapter-status/142
                            Hatte ich geschrieben das ich es nochmal dort aktualisiert habe ;)
                              @sigi234
                              ub.privatU Offline
                              ub.privatU Offline
                              ub.privat
                              schrieb am zuletzt editiert von ub.privat
                              #168
                              @Scrounger
                              @sigi234
                              Habe es nochmals kopiert und neu angelegt.
                              Hat nunmehr die "339" Zeilen und ab Zeile 8 beginnen die settings.
                              Folgende Warnung wird immer in Zeile 259 - 260 ausgewiesen:
                              27.2.2020, 20:44:17.792	[info ]: javascript.0 (31416) Stop script script.js.Adapter_MaterialDesignWidget
                              27.2.2020, 20:44:22.557	[info ]: javascript.0 (31416) Start javascript script.js.Adapter_MaterialDesignWidget
                              27.2.2020, 20:44:23.017	[warn ]: javascript.0 (31416)     at adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:44:23.017	[warn ]: javascript.0 (31416)     at script.js.Adapter_MaterialDesignWidget:267:1
                              27.2.2020, 20:44:23.018	[warn ]: javascript.0 (31416)     at adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:44:23.019	[warn ]: javascript.0 (31416)     at script.js.Adapter_MaterialDesignWidget:267:1
                              27.2.2020, 20:44:23.019	[info ]: javascript.0 (31416) script.js.Adapter_MaterialDesignWidget: registered 105 subscriptions and 1 schedule
                              27.2.2020, 20:44:30.196	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:44:30.199	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:44:32.200	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:44:32.204	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:44:33.250	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:44:33.252	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:00.287	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:00.291	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:02.541	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:02.545	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:02.857	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:02.859	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:03.452	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:03.456	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:09.499	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:09.503	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:11.106	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:11.109	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:17.548	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:17.552	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:29.638	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:29.641	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:30.233	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:30.242	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:32.297	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:32.300	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:45:33.280	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:45:33.281	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:46:00.359	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:46:00.364	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:46:04.589	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:46:04.591	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:46:04.772	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:46:04.775	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:46:05.625	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:46:05.628	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:46:30.164	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:46:30.167	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:46:31.916	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:46:31.919	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:46:32.858	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:46:32.860	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:47:00.326	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:47:00.331	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:47:02.429	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:47:02.431	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:47:02.669	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:47:02.672	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:47:03.396	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:47:03.399	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:48:30.164	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:48:30.167	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:48:31.763	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:48:31.770	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:48:32.770	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:48:32.771	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:49:00.258	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:49:00.261	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:49:02.564	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:49:02.568	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:49:02.817	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:49:02.819	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:49:03.517	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:49:03.521	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:49:32.178	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:49:32.180	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:49:33.143	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:49:33.146	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:50:00.338	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:50:00.342	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:50:02.898	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:50:02.901	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:50:03.205	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:50:03.207	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:50:03.885	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:50:03.892	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              27.2.2020, 20:50:09.069	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:259:9)
                              27.2.2020, 20:50:09.073	[warn ]: javascript.0 (31416)     at Object.adapterStatus (script.js.Adapter_MaterialDesignWidget:260:9)
                              Das steht im Script:
                              ![20bd8d6a-e81d-48de-a58b-2ab78550537b-grafik.png](/assets/uploads/files/1582833432058-20bd8d6a-e81d-48de-a58b-2ab78550537b-grafik.png)
                                @Scrounger
                                @sigi234
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                #169
                                @ub-privat
                                Datenpunkt bei dir 0_userdata.0.AdapterStatus.sortMode
                                Datenpunkt im skript 0_userdata.0.vis.AdapterStatus.sortMode
                                D.h. Datenpunkte findet er nicht.
                                  @Scrounger
                                  4. View importiert:
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #170
                                  Die Datenpunkte sind im Skript :
                                  deine sind :
                                  0_userdata.0.AdapterStatus.jsonList
                                  EDIT : @Scrounger war schneller :)
                                    deine sind :
                                    ub.privatU Offline
                                    ub.privatU Offline
                                    ub.privat
                                    #171
                                    @Glasfaser
                                    @Scrounger
                                    Vielen Dank! dieses kleine "vis" 😠 hat so eine riesige Wirkung.
                                    Tata... es funzt!
                                    Vielen Dank!
                                    Nun noch schick und schön alá @sigi234 und die Visu ist wieder um einen View reicher!
                                    DANKE 👍 👍
                                    • smartboartS Offline
                                      smartboartS Offline
                                      smartboart
                                      #172
                                      Tolle Sache!!! Danke für view und script...Wie wäre es das Script noch um einen Filter und Sortierung nach Instanz zu erweitern?
                                        • Sortier Funktion
                                        • Fehler behoben
                                        View:
                                          "settings": {
                                            "style": {
                                            "theme": "redmond",
                                            "sizex": "",
                                            "sizey": "",
                                            "gridSize": "",
                                            "snapType": null
                                          "widgets": {
                                            "e00001": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "wrapItems": true,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "iconHeight": "60",
                                              "style": {
                                                "left": "0px",
                                                "top": "50px",
                                                "width": "100%",
                                                "overflow-x": "",
                                                "z-index": "1"
                                            "e00002": {
                                              "tpl": "tplHtml",
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0
                                              "style": {
                                                "left": "0",
                                                "top": "0",
                                                "width": "100%",
                                                "height": "50px",
                                            "e00003": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "showValue": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "clearIcon": "",
                                                "prepandIcon": "",
                                                "collapseIcon": "",
                                              "style": {
                                                "left": "10px",
                                                "top": "0px",
                                                "z-index": "1",
                                                "height": "40px"
                                            "e00004": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "showValue": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "clearIcon": "",
                                                "prepandIcon": "",
                                                "collapseIcon": "",
                                              "style": {
                                                "top": "0px",
                                                "z-index": "1",
                                                "height": "40px"
                                          "filterList": []
                                        Skript
                                        } else {
                                        } else {
                                        } else {
                                            try {
        </div>`
        </div>
        </div>
        </div>
        </div>
        </div>
        </div>`
                                                    let status = 3;
                                                        status = 0;
        status = 4;
                                                        } else {
        status = 4;
                                                        status = 1;
                                                        status = 1;
                                                        status = 1;
                                                        status = 2;
                                                    adapterList.push({
                                                        text: text,
                                                        subText: subText,
                                                        image: image,
                                                        status: status
                                            } catch (err) {
                                            } else {
                                                sortMode = 'name'
                                        adapterStatus();
                                            if (neustarten) {
                                            } else {
                                                } else {
                                            return {
                                                    } else {
                                                        return nullValue;
                                                    } else {
                                                        return nullValue;
                                                        return true;
                                                    } else {
                                                        return false;
                                        skokarl
                                        #173
                                        @Scrounger
                                        Jetzt hast Du aber wieder einen rausgehauen mit der View und dem Script ... 😀
                                        Super klasse !!!
                                        H 1 Antwort Letzte Antwort
                                        • smartboartS smartboart
                                          ScroungerS Offline
                                          ScroungerS Offline
                                          Scrounger
                                          #174
                                          @smartboart sagte in View Adapter Status:
                                          Filter gibt es doch schon?
                                          Und was meinst du mit Sortierung nach Instanz, also was sollte nach Auswahl angezeigt werden?
                                          O smartboartS 2 Antworten Letzte Antwort
