Драйвер ioBroker MySensors
Console LOG:
root@raspberrypi:/opt/iobroker# npm install https://github.com/DJONvl/iobroker.myse … all/master
npm http GET https://github.com/DJONvl/iobroker.myse ... all/master
npm http 200 https://github.com/DJONvl/iobroker.myse ... all/master
npm http GET https://registry.npmjs.org/sensors
npm http GET https://registry.npmjs.org/serialport
npm http 304 https://registry.npmjs.org/sensors
npm http 304 https://registry.npmjs.org/serialport
npm http GET https://registry.npmjs.org/optimist
npm http GET https://registry.npmjs.org/nan
npm http GET https://registry.npmjs.org/bindings/1.2.1
npm http GET https://registry.npmjs.org/sf/0.1.7
npm http GET https://registry.npmjs.org/async/0.9.0
npm http GET https://registry.npmjs.org/debug
npm http 304 https://registry.npmjs.org/nan
npm http 304 https://registry.npmjs.org/debug
npm http 304 https://registry.npmjs.org/sf/0.1.7
npm http 200 https://registry.npmjs.org/optimist
npm http 304 https://registry.npmjs.org/bindings/1.2.1
npm http 304 https://registry.npmjs.org/async/0.9.0
npm http GET https://registry.npmjs.org/ms/0.7.1
npm http 304 https://registry.npmjs.org/ms/0.7.1
npm http GET https://registry.npmjs.org/wordwrap
npm http GET https://registry.npmjs.org/minimist
npm http 304 https://registry.npmjs.org/wordwrap
npm http 304 https://registry.npmjs.org/minimist
serialport@2.0.6 install /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
node-pre-gyp install --fallback-to-build
node-pre-gyp http GET https://github.com/voodootikigod/node-s … arm.tar.gz
node-pre-gyp http 404 https://github.com/voodootikigod/node-s ... arm.tar.gz
node-pre-gyp http Pre-built binary not available for your system, looked for https://github.com/voodootikigod/node-s ... arm.tar.gz (falling back to source compile with node-gyp)
make: Entering directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
COPY Release/serialport.node
COPY /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
iobroker.mysensors@0.0.1 node_modules/iobroker.mysensors
├── sensors@0.1.0
└── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@2.0.9, debug@2.2.0, optimist@0.6.1)
bind срабатывает, только переменная не сохраняется
смотри что сделай:
нажми bind в списке devices появятся твои юниты щелкни по любому 2 раза и нажми сохранить, чтобы активировалась кнопка Сохранить и выйти
ToDo сделать активацию сохранения при добавлении в список новых юнитов
Ок… Попробую...
14780_2019-01-29_10h34_27.png -
смотрим!!!
не читает… только информация из presentation
смотрим!!!
https://youtu.be/mvjW1XE959E `
1 ты очень торопишься и не даешь запуститься драйверу, поэтому входя в настройки селектор ком портов пустой2 ты добавил один и тот же юнит несколько раз, зачем? все равно имя переменной одно создается
3 для управления реле тебе нужно прописать в RAW посылку управляющую твоим реле без Value
а так все работает отлично
смотрим
почему ack TRUE?
в скетче на ардуине
`present(i, iomodus[i].sensorType, iomodus[i].description, false);` смотрим что происходит [https://youtu.be/mcUTM45SjG8](https://youtu.be/mcUTM45SjG8)[/i][/i] -
смотрим!!!
а так все работает отлично `
1. привык так :-)
2. убрал!
3. смотрим https://youtu.be/IiU1DlUT9cc
проблема в том что VALUE ПРЫГАЕТ, я думаю из за ack=TRUE,
mysensors-0 2016-02-21 11:34:21 info Rx-Raw 0;58;1;1;0;55.91
mysensors-0 2016-02-21 11:32:34 info _0|42|set|true|V_TEMP|_-127.00
mysensors-0 2016-02-21 11:31:43 info raw_data_error 1
mysensors-0 2016-02-21 11:33:36 info Rx-Raw 0;58;1;1;0;56.07
mysensors-0 2016-02-21 11:34:21 info ack is not set!
пробыvал изменит RAW от RELAY…Скрипт зависает! (последнее видео)
BUG
смотри как время в логе выходит!
Или как ты время лога сортируешь?
mysensors-0 2016-02-21 11:34:25 info raw_data_error 1 mysensors-0 2016-02-21 11:31:47 info Rx-Raw -127.00 mysensors-0 2016-02-21 11:33:39 info Rx-Raw TYPE mysensors-0 2016-02-21 11:32:38 info raw_data_error 1 mysensors-0 2016-02-21 11:34:25 info Rx-Raw String mysensors-0 2016-02-21 11:31:47 info raw_data_error 1 mysensors-0 2016-02-21 11:33:39 info raw_data_error 1 mysensors-0 2016-02-21 11:32:38 info Rx-Raw 58 mysensors-0 2016-02-21 11:34:25 info raw_data_error 1 mysensors-0 2016-02-21 11:31:47 info Rx-Raw String mysensors-0 2016-02-21 11:33:39 info Rx-Raw -127.00 mysensors-0 2016-02-21 11:32:38 info raw_data_error 1 mysensors-0 2016-02-21 11:34:25 info Rx-Raw 42 mysensors-0 2016-02-21 11:31:47 info raw_data_error 1 mysensors-0 2016-02-21 11:33:39 info raw_data_error 1 mysensors-0 2016-02-21 11:32:38 info Rx-Raw PIN mysensors-0 2016-02-21 11:34:25 info raw_data_error 1 mysensors-0 2016-02-21 11:31:47 info Rx-Raw 42 mysensors-0 2016-02-21 11:33:39 info Rx-Raw String mysensors-0 2016-02-21 11:32:38 info __0_|_58_|_set_|_true_|_V_TEMP_|_40.08 mysensors-0 2016-02-21 11:34:25 info Rx-Raw PIN mysensors-0 2016-02-21 11:31:47 info raw_data_error 1 mysensors-0 2016-02-21 11:33:39 info raw_data_error 1 -
прыгает потому что твой шлюз отправляет данные постоянно `
вроде не прыгает ( подключил к компу)…в иоброкере...ЛОГ:
stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:28 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:28 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:28 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:27 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:26 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:25 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:24 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:23 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:23 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:23 2016-02-21 12:58:18 stateChange mysensors.0.V_TEMP_0_58 "43.29" false mysensors.0 2016-02-21 12:58:23 2016-02-21 12:58:18
